Yesterday after update my laptop was super slow due to some weird issue with nvidia driver and i have to reinstall everything using a bootable drive…
The problem happend during installation is that it was asking for 300mb of storage for boot partition and i had only one partition with 260mb, I gone with installation and everything working now but its does not show the boot screen where i can select the manjaro and window…
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINTS
sda 8:0 0 931.5G 0 disk
├─sda1 8:1 0 301.8G 0 part /home
├─sda2 8:2 0 518.7M 0 part
└─sda3 8:3 0 629G 0 part /run/media/username/Local Disk
nvme0n1 259:0 0 465.8G 0 disk
├─nvme0n1p1 259:1 0 260M 0 part /boot/efi
├─nvme0n1p2 259:2 0 16M 0 part
├─nvme0n1p3 259:3 0 367.3G 0 part
├─nvme0n1p4 259:4 0 522M 0 part
└─nvme0n1p5 259:5 0 97.7G 0 part /var/lib/systemd-swap
/var/log
/var/cache
here is partition structure windows partition is there with all files and stuff, nvme0n1p1
and nvme0n1p5
are where i installed manjaro boot and root partition respectively
Some more details
Model: ATA TOSHIBA MQ04ABF1 (scsi)
Disk /dev/sda: 1000GB
Sector size (logical/physical): 512B/4096B
Partition Table: gpt
Disk Flags:
Number Start End Size File system Name Flags
3 290MB 676GB 675GB ntfs Basic data partition msftdata
1 676GB 1000GB 324GB btrfs
2 1000GB 1000GB 544MB fat32 bios_grub
Model: WDC WDS500G2B0C-00PXH0 (nvme)
Disk /dev/nvme0n1: 500GB
Disk Flags:
1 1049kB 274MB 273MB fat32 SYSTEM boot, esp
2 274MB 290MB 16.8MB No name msftres
3 290MB 395GB 394GB ntfs Basic data partition msftdata
5 395GB 500GB 105GB btrfs
4 500GB 500GB 547MB ntfs Basic data partition hidden, diag
System details
Kernel: 5.17.9-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-5.17-x86_64
root=UUID=af5123d1-e707-4e2a-be32-384ddc671227 rw rootflags=subvol=@ quiet
Desktop: KDE Plasma v: 5.24.5 tk: Qt v: 5.15.4 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: HP product: HP Pavilion Gaming Laptop 15-ec1xxx v: N/A
Mobo: HP model: 87B1 v: 31.23 serial: <superuser required> UEFI: AMI
v: F.25 date: 08/18/2021
ID-1: BAT0 charge: 26.6 Wh (55.8%) condition: 47.7/47.7 Wh (100.0%)
volts: 12.2 min: 11.6 model: Hewlett-Packard Primary type: Li-ion
serial: N/A status: charging cycles: 429
Info: model: AMD Ryzen 5 4600H with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 2 family: 0x17 (23) model-id: 0x60 (96) stepping: 1
microcode: 0x8600106
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB L3: 8 MiB
desc: 2x4 MiB
Speed (MHz): avg: 1481 high: 1751 min/max: 1400/3000 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1751 2: 1397
3: 1550 4: 1515 5: 1570 6: 1458 7: 1397 8: 1397 9: 1489 10: 1462 11: 1397
12: 1397 bogomips: 71880
Device-1: NVIDIA TU117M vendor: Hewlett-Packard driver: nouveau v: kernel
non-free: 515.xx+ status: current (as of 2022-05) arch: Turing pcie:
speed: Unknown lanes: 63 link-max: gen: 6 speed: 64 GT/s ports:
active: none empty: HDMI-A-1 bus-ID: 01:00.0 chip-ID: 10de:1f99
class-ID: 0300
Device-2: AMD Renoir vendor: Hewlett-Packard driver: amdgpu v: kernel
pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s ports:
active: eDP-1 empty: none bus-ID: 05:00.0 chip-ID: 1002:1636
class-ID: 0300
Device-3: Quanta HP TrueVision HD Camera type: USB driver: uvcvideo
bus-ID: 3-3:3 chip-ID: 0408:5365 class-ID: 0e02
Display: x11 server: X.Org v: 21.1.3 compositor: kwin_x11 driver: X:
loaded: amdgpu,modesetting alternate: fbdev,vesa gpu: amdgpu display-ID: :0
screens: 1
s-diag: 582mm (22.93")
Monitor-1: eDP-1 mapped: eDP model: ChiMei InnoLux 0x150d built: 2018
res: 1920x1080 hz: 60 dpi: 142 gamma: 1.2 size: 344x193mm (13.54x7.6")
diag: 394mm (15.5") ratio: 16:9 modes: max: 1920x1080 min: 640x480
OpenGL: renderer: AMD RENOIR (LLVM 13.0.1 DRM 3.44 5.17.9-1-MANJARO)
v: 4.6 Mesa 22.0.4 direct render: Yes
Device-1: NVIDIA vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
pcie: speed: Unknown lanes: 63 link-max: gen: 6 speed: 64 GT/s
bus-ID: 01:00.1 chip-ID: 10de:10fa class-ID: 0403
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Hewlett-Packard
driver: N/A alternate: snd_pci_acp3x, snd_rn_pci_acp3x, snd_pci_acp5x,
snd_sof_amd_renoir
bus-ID: 05:00.5 chip-ID: 1022:15e2 class-ID: 0480
Device-3: AMD Family 17h/19h HD Audio vendor: Hewlett-Packard
link-max: gen: 4 speed: 16 GT/s bus-ID: 05:00.6 chip-ID: 1022:15e3
class-ID: 0403
Sound Server-1: ALSA v: k5.17.9-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.51 running: yes
vendor: Hewlett-Packard driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: e000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 bus-ID: 03:00.0 chip-ID: 8086:2723 class-ID: 0280
Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 1-4:3
Report: rfkill ID: hci0 rfk-id: 6 state: down bt-service: enabled,running
Local Storage: total: 1.36 TiB used: 752.52 GiB (53.9%)
model: WDS500G2B0C-00PXH0 size: 465.76 GiB block-size: physical: 512 B
rev: 211210WD temp: 44.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Toshiba model: MQ04ABF100
type: HDD rpm: 5400 serial: <filter> rev: 7C scheme: GPT
ID-1: / raw-size: 97.66 GiB size: 97.66 GiB (100.00%)
used: 16.84 GiB (17.2%) fs: btrfs dev: /dev/nvme0n1p5 maj-min: 259:5
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%)
used: 554 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 301.76 GiB size: 301.76 GiB (100.00%)
used: 210.76 GiB (69.8%) fs: btrfs dev: /dev/sda1 maj-min: 8:1
ID-4: /var/log raw-size: 97.66 GiB size: 97.66 GiB (100.00%)
ID-1: swap-1 type: file size: 256 MiB used: 256 MiB (100.0%) priority: 50
file: /var/lib/systemd-swap/swapfc/1
ID-2: swap-2 type: file size: 256 MiB used: 256 MiB (100.0%) priority: 49
file: /var/lib/systemd-swap/swapfc/2
ID-3: swap-3 type: file size: 256 MiB used: 256 MiB (100.0%) priority: 48
file: /var/lib/systemd-swap/swapfc/3
ID-4: swap-4 type: file size: 256 MiB used: 203.7 MiB (79.6%) priority: 47
file: /var/lib/systemd-swap/swapfc/4
ID-5: swap-5 type: file size: 256 MiB used: 97.8 MiB (38.2%) priority: 46
file: /var/lib/systemd-swap/swapfc/5
ID-6: swap-6 type: file size: 256 MiB used: 35 MiB (13.7%) priority: 45
file: /var/lib/systemd-swap/swapfc/6
ID-7: swap-7 type: file size: 256 MiB used: 49.9 MiB (19.5%) priority: 40
file: /var/lib/systemd-swap/swapfc/7
ID-8: swap-8 type: file size: 256 MiB used: 0 KiB (0.0%) priority: 39
file: /var/lib/systemd-swap/swapfc/8
System Temperatures: cpu: 55.0 C mobo: N/A
Fan Speeds (RPM): cpu: 0 fan-2: 0
GPU: device: amdgpu temp: 47.0 C device: nouveau temp: N/A
Processes: 353 Uptime: 9h 10m wakeups: 12 Memory: 7.19 GiB
used: 3.53 GiB (49.0%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 12.1.0 clang: 13.0.1 Packages: pacman: 1304 lib: 348 flatpak: 0
Shell: Zsh v: 5.9 default: Bash v: 5.1.16 running-in: yakuake inxi: 3.3.16
