Hi
I have very similar problem as the one described in the post GRUB disappeared after attempt to recover.
I have dual boot Win 8.1/Manjaro system. After Clonezilla whole-drive backup, GRUB startup menu disappeared completely and the system has been booting directly into Windows.
I tried the instructions from the GRUB /Restore the GRUB Bootloader
Wiki page but got stuck.
After several unsuccessful attempts (had to do the full set of commands as the base solution didn’t work) I managed to get all the way to the last step ‘sudo update-grub’ which came up with similar error message as in last section of the quoted post above (cannot find GRUB for dev/sdb1
), which suggests that the Grub was not updated properly.
Upon restart of the system, the GRUB menu showed up, however, it only has a single option which is Windows (the boot loader is EFI/Manjaro/grubx64.efi). Now I am stuck how to get the Manjaro system option as well as the other two standard menu items (memtest and advanced).
My ext4 partition is sda6 and my vfat (efi) partition is sda2
Any help is much appreciated. Thanks!
Here are some outputs:
parted -l
(doesn’t give any result)
efibootmgr -v
[manjaro@manjaro Desktop]$ efibootmgr -v
BootCurrent: 0003
Timeout: 0 seconds
BootOrder: 0005,0000,2001,2003,2002
Boot0000* Windows Boot Manager HD(2,GPT,c4ffa206-eb78-11e3-9c30-aa19f3c567a3,0x200800,0x32000)/File(\EFI\Microsoft\Boot\bootmgfw.efi)RC
Boot0001* Realtek PXE PciRoot(0x0)/Pci(0x1c,0x0)/Pci(0x0,0x0)/MAC(008cfa83f959,0)/IPv4(0.0.0.00.0.0.0,0,0)RC
Boot0002* Realtek PXE PciRoot(0x0)/Pci(0x1c,0x0)/Pci(0x0,0x0)/MAC(008cfa83f959,0)/IPv6([::]:<->[::]:,0,0)RC
Boot0003* EFI USB Device (Generic Flash Disk) PciRoot(0x0)/Pci(0x1d,0x0)/USB(0,0)/USB(3,0)/HD(1,MBR,0x0,0x5499e8,0x2000)RC
Boot0004* Windows Boot Manager HD(2,GPT,c4ffa206-eb78-11e3-9c30-aa19f3c567a3,0x200800,0x32000)/File(\EFI\Microsoft\Boot\bootmgfw.efi)RC
Boot0005* Manjaro HD(2,GPT,c4ffa206-eb78-11e3-9c30-aa19f3c567a3,0x200800,0x32000)/File(\EFI\Manjaro\grubx64.efi)
Boot2001* EFI USB Device RC
Boot2002* EFI DVD/CDROM RC
Boot2003* EFI Network RC
lsblk -f
> [manjaro@manjaro Desktop]$ lsblk -f
> NAME FSTYPE FSVER LABEL UUID FSAVAIL FSUSE% MOUNTPOINT
> loop0
> squash 4.0 0 100% /run/miso/
> loop1
> loop2
> loop3
> sda
> ├─sda1
> │ ntfs System
> │ 5012E7DE12E7C6D6
> ├─sda2
> │ vfat FAT32 74E8-F25E
> ├─sda3
> │ ntfs 48A4EA45A4EA34DA
> ├─sda4
> │ ntfs HDD1
> │ D4FCEC4AFCEC2886
> ├─sda5
> │ ntfs Recovery
> │ D002825302823F0A
> ├─sda6
> │ ext4 1.0 5c64cc09-b113-44ec-9ccb-e9c10153808d
> └─sda7
> ntfs HDD2
> 5082CE5482CE3E6A
> sdb iso966 Jolie MANJARO_XFCE_2003
> │ 2020-06-06-07-11-25-00 0 100% /run/miso/
> ├─sdb1
> │ iso966 Jolie MANJARO_XFCE_2003
> └─sdb2
> vfat FAT12 MISO_EFI
> 08E4-9928
> sr0
