GRUB disappeared after attempt to recover
Hello,
I bought a new computer and installed Windows 10 (2004) and Manjaro (latest KDE iso). Instalation worked fine. After booting to Manjaro, update manager showed 550 packets that needed update. I proceeded with the update and I got no errors. After reboot GRUB showed only Windows and UEFI Firmware settings (just like in thread: Grub missing manjaro entry)
I tried to recover GRUB with the instructions from Wiki page but with no success. I think, that at first I might have mounted EFI partition like for BIOS setup, and it caused grub-install to fail. Later I went through the instructions more thorough, grub-install finished without errors, grub-update finished with ‘done’ but it didn’t have any line telling that any OS was found. Now GRUB is not loading at all. I get black screen and UEFI loads. I can still boot Windows from UEFI but not Manjaro. When I mount EFI partition there are Windows and Manjaro folders.
My setup is NVME SSD partitioned with GPT label and UEFI boot (wihout CSM).
When I get home I can post all the steps I’m trying from terminal.
:+1: Welcome to Manjaro! :+1:
Please read this:
and post some more information so we can see what’s really going on. Now we know the symptom of the disease, but we need some more probing to know where the origin lies…
An inxi --admin --verbosity=7 --filter --no-host would be the minimum required information… (Personally Identifiable Information like serial numbers and MAC addresses will be filtered out by the above command)
In your particular case the output to:
parted --list
efibootmgr --verbose
would be beneficial as well.
:innocent:
Thanks Fabby,
Here’s the output of commands:
[manjaro@manjaro ~]$ inxi --admin --verbosity=7 --filter --no-host
System:    Kernel: 5.6.15-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.1.0
           parameters: BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=us tz=UTC driver=free
           nouveau.modeset=1 i915.modeset=1 radeon.modeset=1 misobasedir=manjaro misolabel=MANJARO_KDE_2003 quiet
           systemd.show_status=1 apparmor=1 security=apparmor
           Desktop: KDE Plasma 5.18.5 tk: Qt 5.14.2 wm: kwin_x11 dm: SDDM Distro: Manjaro Linux
Machine:   Type: Desktop System: Gigabyte product: B450M DS3H v: N/A serial: <filter>
           Mobo: Gigabyte model: B450M DS3H-CF v: x.x serial: <filter> UEFI: American Megatrends v: F50
           date: 11/27/2019
Memory:    RAM: total: 15.65 GiB used: 1.41 GiB (9.0%)
CPU:       Topology: 6-Core model: AMD Ryzen 5 3600 bits: 64 type: MT MCP arch: Zen family: 17 (23)
           model-id: 71 (113) stepping: N/A microcode: 8701013 L2 cache: 3072 KiB bogomips: 86271
           Speed: 2196 MHz min/max: 2200/3600 MHz boost: enabled Core speeds (MHz): 1: 2196 2: 2196 3: 2190
           4: 2190 5: 2193 6: 2195 7: 2196 8: 2196 9: 2197 10: 2196 11: 2196 12: 2188
           Flags: 3dnowprefetch abm adx aes aperfmperf apic arat avic avx avx2 bmi1 bmi2 bpext cat_l3 cdp_l3
           clflush clflushopt clwb clzero cmov cmp_legacy constant_tsc cpb cpuid cqm cqm_llc cqm_mbm_local
           cqm_mbm_total cqm_occup_llc cr8_legacy cx16 cx8 de decodeassists extapic extd_apicid f16c flushbyasid
           fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibs irperf lahf_lm lbrv lm mba mca mce misalignsse
           mmx mmxext monitor movbe msr mtrr mwaitx nonstop_tsc nopl npt nrip_save nx osvw overflow_recov pae pat
           pausefilter pclmulqdq pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse pse36
           rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sev sha_ni skinit smap smca sme smep ssbd sse sse2
           sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce topoext tsc tsc_scale umip
           v_vmsave_vmload vgif vmcb_clean vme vmmcall wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt
           xsaves
           Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional, STIBP: conditional, RSB filling
Graphics:  Device-1: Advanced Micro Devices [AMD/ATI] Ellesmere [Radeon RX 470/480/570/570X/580/580X/590]
           vendor: XFX Pine driver: amdgpu v: kernel bus ID: 07:00.0 chip ID: 1002:67df
           Display: x11 server: X.Org 1.20.8 driver: amdgpu FAILED: ati unloaded: modesetting
           alternate: fbdev,vesa compositor: kwin_x11 resolution: 1920x1080~60Hz
           OpenGL: renderer: Radeon RX 580 Series (POLARIS10 DRM 3.36.0 5.6.15-1-MANJARO LLVM 10.0.0)
           v: 4.6 Mesa 20.0.7 direct render: Yes
Audio:     Device-1: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590] vendor: XFX Pine
           driver: snd_hda_intel v: kernel bus ID: 07:00.1 chip ID: 1002:aaf0
           Device-2: Advanced Micro Devices [AMD] Starship/Matisse HD Audio vendor: Gigabyte
           driver: snd_hda_intel v: kernel bus ID: 09:00.4 chip ID: 1022:1487
           Sound Server: ALSA v: k5.6.15-1-MANJARO
Network:   Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Gigabyte driver: r8169
           v: kernel port: f000 bus ID: 05:00.0 chip ID: 10ec:8168
           IF: enp5s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
           IP v4: <filter> type: dynamic noprefixroute scope: global broadcast: <filter>
Drives:    Local Storage: total: 1.39 TiB used: 168.1 MiB (0.0%)
           ID-1: /dev/nvme0n1 vendor: Kingston model: SA2000M8500G size: 465.76 GiB block size: physical: 512 B
           logical: 512 B speed: 31.6 Gb/s lanes: 4 serial: <filter> rev: S5Z42105 scheme: GPT
           ID-2: /dev/sda vendor: Western Digital model: WD1002FAEX-00Z3A0 size: 931.51 GiB block size:
           physical: 512 B logical: 512 B speed: 6.0 Gb/s serial: <filter> rev: 1D05 scheme: GPT
           ID-3: /dev/sdb type: USB vendor: Verbatim model: STORE N GO size: 29.39 GiB block size:
           physical: 512 B logical: 512 B serial: <filter> rev: 1.00 scheme: MBR
           Optical-1: /dev/sr0 vendor: ASUS model: DRW-24B5ST rev: 1.00 dev-links: cdrom
           Features: speed: 48 multisession: yes audio: yes dvd: yes rw: cd-r,cd-rw,dvd-r,dvd-ram state: running
RAID:      Message: No RAID data was found.
Partition: ID-1: / raw size: N/A size: 11.74 GiB used: 168.1 MiB (1.4%) fs: overlay source: ERR-102 label: N/A
           uuid: N/A
           ID-2: /run/miso/bootmnt raw size: 2.91 GiB size: <root required> used: <root required> fs: iso9660
           dev: /dev/sdb1 label: MANJARO_KDE_2003 uuid: 2020-06-06-08-14-33-00
           ID-3: /run/miso/sfs/desktopfs raw size: 1.69 GiB size: <root required> used: <root required>
           fs: squashfs dev: /dev/loop2 label: N/A uuid: N/A
           ID-4: /run/miso/sfs/livefs raw size: 20.8 MiB size: <root required> used: <root required> fs: squashfs
           dev: /dev/loop0 label: N/A uuid: N/A
           ID-5: /run/miso/sfs/mhwdfs raw size: 565.6 MiB size: <root required> used: <root required>
           fs: squashfs dev: /dev/loop1 label: N/A uuid: N/A
           ID-6: /run/miso/sfs/rootfs raw size: 596.1 MiB size: <root required> used: <root required>
           fs: squashfs dev: /dev/loop3 label: N/A uuid: N/A
Unmounted: ID-1: /dev/nvme0n1p1 size: 100.0 MiB fs: vfat label: N/A uuid: 6458-726F
           ID-2: /dev/nvme0n1p2 size: 16.0 MiB fs: <root required> label: N/A uuid: N/A
           ID-3: /dev/nvme0n1p3 size: 390.01 GiB fs: ntfs label: N/A uuid: 5C5A64275A63FBE0
           ID-4: /dev/nvme0n1p4 size: 515.0 MiB fs: ntfs label: N/A uuid: 7ED4BF58D4BF10FF
           ID-5: /dev/nvme0n1p5 size: 75.13 GiB fs: ext4 label: Manjaro
           uuid: 0859a9ac-15dc-45fb-bbe1-6d1e7ba09123
           ID-6: /dev/sda1 size: 931.51 GiB fs: ntfs label: Dane uuid: 60C9461120DA5B93
           ID-7: /dev/sdb2 size: 4.0 MiB fs: vfat label: MISO_EFI uuid: F327-8F27
USB:       Hub: 1-0:1 info: Full speed (or root) Hub ports: 10 rev: 2.0 speed: 480 Mb/s chip ID: 1d6b:0002
           Device-1: 1-7:2 info: A4Tech USB Device type: Keyboard,Mouse,HID driver: hid-generic,usbhid
           interfaces: 3 rev: 1.1 speed: 12 Mb/s chip ID: 09da:107e
           Device-2: 1-8:3 info: SiGma Micro Keyboard type: Keyboard,HID driver: hid-generic,usbhid interfaces: 2
           rev: 1.1 speed: 1.5 Mb/s chip ID: 1c4f:0026
           Hub: 2-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s chip ID: 1d6b:0003
           Device-3: 2-3:2 info: Verbatim Flash Drive (StorenGo) type: Mass Storage driver: usb-storage
           interfaces: 1 rev: 3.0 speed: 5 Gb/s chip ID: 18a5:0243 serial: <filter>
           Hub: 3-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0 speed: 480 Mb/s chip ID: 1d6b:0002
           Hub: 4-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s chip ID: 1d6b:0003
Sensors:   System Temperatures: cpu: 39.8 C mobo: N/A gpu: amdgpu temp: 30 C
           Fan Speeds (RPM): N/A gpu: amdgpu fan: 768
Info:      Processes: 278 Uptime: 6m Init: systemd v: 245 Compilers: gcc: 10.1.0 Shell: bash v: 5.0.17
           running in: konsole inxi: 3.0.37
    [manjaro@manjaro ~]$ sudo parted --list
    Model: ATA WDC WD1002FAEX-0 (scsi)
    Disk /dev/sda: 1000GB
    Partition Table: gpt
    Disk Flags:
    Number  Start   End     Size    File system  Name  Flags
     1      1049kB  1000GB  1000GB  ntfs               msftdata
    Model: Verbatim STORE N GO (scsi)
    Disk /dev/sdb: 31.6GB
    Partition Table: msdos
    Disk Flags:
    Number  Start   End     Size    Type     File system  Flags
     2      3120MB  3124MB  4194kB  primary               esp
    Model: KINGSTON SA2000M8500G (nvme)
    Disk /dev/nvme0n1: 500GB
    Disk Flags:
     1      1049kB  106MB  105MB   fat32        EFI system partition          boot, esp
     2      106MB   123MB  16.8MB               Microsoft reserved partition  msftres
     3      123MB   419GB  419GB   ntfs         Basic data partition          msftdata
     4      419GB   419GB  540MB   ntfs                                       hidden, diag
     5      419GB   500GB  80.7GB  ext4
[manjaro@manjaro ~]$ efibootmgr --verbose
BootCurrent: 0002
Timeout: 1 seconds
BootOrder: 0001,0000,0002,0003
Boot0000* Windows Boot Manager  HD(1,GPT,f871bca4-157d-4f01-8074-e40c5ffb2675,0x800,0x32000)/File(\EFI\MICROSOFT\BOOT\BOOTMGFW.EFI)WINDOWS.........x...B.C.D.O.B.J.E.C.T.=.{.9.d.e.a.8.6.2.c.-.5.c.d.d.-.4.e.7.0.-.a.c.c.1.-.f.3.2.b.3.4.4.d.4.7.9.5.}...a................
Boot0001* manjaro       HD(1,GPT,f871bca4-157d-4f01-8074-e40c5ffb2675,0x800,0x32000)/File(\EFI\MANJARO\GRUBX64.EFI)
Boot0002* UEFI: VerbatimSTORE N GO 1.00 PciRoot(0x0)/Pci(0x1,0x3)/Pci(0x0,0x0)/USB(2,0)/CDROM(1,0x5cf8f0,0x8000)..BO
Boot0003* UEFI: VerbatimSTORE N GO 1.00, Partition 2    PciRoot(0x0)/Pci(0x1,0x3)/Pci(0x0,0x0)/USB(2,0)/HD(2,MBR,0x0,0x5cf8f0,0x2000)..BO
As for the GRUB restore attempt it went like this:
[manjaro@manjaro ~]$ lsblk -f
NAME        FSTYPE   FSVER      LABEL            UUID                                 FSAVAIL FSUSE% MOUNTPOINT
loop0       squashfs 4.0        0   100% /run/miso/sfs/li
loop1       squashfs 4.0        0   100% /run/miso/sfs/mh
loop2       squashfs 4.0        0   100% /run/miso/sfs/de
loop3       squashfs 4.0        0   100% /run/miso/sfs/ro
sda
└─sda1      ntfs                Dane             60C9461120DA5B93
sdb         iso9660  Joliet Ext MANJARO_KDE_2003 2020-06-06-08-14-33-00
├─sdb1      iso9660  Joliet Ext MANJARO_KDE_2003 2020-06-06-08-14-33-00                     0   100% /run/miso/bootmn
└─sdb2      vfat     FAT12      MISO_EFI         F327-8F27
sr0
nvme0n1
├─nvme0n1p1 vfat     FAT32                       6458-726F
├─nvme0n1p2
├─nvme0n1p3 ntfs                                 5C5A64275A63FBE0
├─nvme0n1p4 ntfs                                 7ED4BF58D4BF10FF
└─nvme0n1p5 ext4     1.0        Manjaro          0859a9ac-15dc-45fb-bbe1-6d1e7ba09123
[manjaro@manjaro ~]$ sudo manjaro-chroot -a
==> Detected systems:
 --> 0) ManjaroLinux
==> Select system to mount [0-0] :
0
==> ERROR: You can't mount 0!
[manjaro@manjaro ~]$ sudo su
[manjaro manjaro]# mount /dev/nvme0n1p5 /mnt
[manjaro manjaro]# cd /mnt
[manjaro mnt]# mount -t proc proc /mnt/proc
[manjaro mnt]# mount -t sysfs sys /mnt/sys
[manjaro mnt]# mount -o bind /dev /mnt/dev
[manjaro mnt]# mount -t devpts pts /mnt/dev/pts/
[manjaro mnt]# chroot /mnt
[manjaro /]# sudo pacman -S mtools os-prober
warning: mtools-4.0.24-1 is up to date -- reinstalling
warning: os-prober-1.77-1 is up to date -- reinstalling
resolving dependencies...
Packages (2) mtools-4.0.24-1  os-prober-1.77-1
Total Installed Size:  0.48 MiB
Net Upgrade Size:      0.00 MiB
(2/2) checking keys in keyring                                         [#######################################] 100%
(2/2) checking package integrity                                       [#######################################] 100%
(2/2) loading package files                                            [#######################################] 100%
(2/2) checking for file conflicts                                      [#######################################] 100%
(2/2) checking available disk space                                    [#######################################] 100%
(1/2) reinstalling mtools                                              [#######################################] 100%
(2/2) reinstalling os-prober                                           [#######################################] 100%
(1/2) Arming ConditionNeedsUpdate...
(2/2) Updating the info directory file...
[manjaro /]# mount /dev/nvme0n1p1 /boot/efi
[manjaro /]# sudo grub-install --target=x86_64-efi --efi-directory=/boot/efi --bootloader-id=manjaro --recheck
Installing for x86_64-efi platform.
EFI variables are not supported on this system.
grub-install: error: efibootmgr failed to register the boot entry: No such file or directory.
[manjaro /]# sudo pacman -S efibootmgr dosfstools grub
warning: efibootmgr-17-1 is up to date -- reinstalling
warning: dosfstools-4.1-3 is up to date -- reinstalling
warning: grub-2.04-11.1 is up to date -- reinstalling
Packages (3) dosfstools-4.1-3  efibootmgr-17-1  grub-2.04-11.1
Total Installed Size:  49.12 MiB
(3/3) checking keys in keyring                                         [#######################################] 100%
(3/3) checking package integrity                                       [#######################################] 100%
(3/3) loading package files                                            [#######################################] 100%
(3/3) checking for file conflicts                                      [#######################################] 100%
(3/3) checking available disk space                                    [#######################################] 100%
(1/3) reinstalling efibootmgr                                          [#######################################] 100%
(2/3) reinstalling dosfstools                                          [#######################################] 100%
(3/3) reinstalling grub                                                [#######################################] 100%
[manjaro /]# exit
exit
[manjaro mnt]# sudo modprobe efivarfs
mount: /mnt/proc: proc already mounted on /proc.
mount: /mnt/sys: sys already mounted on /sys.
[manjaro /]# mount -t efivarfs efivarfs /sys/firmware/efi/efivars
Installation finished. No error reported.
[manjaro /]# sudo update-grub
grub-probe: error: cannot find a GRUB drive for /dev/sdb1.  Check your device.map.
/usr/bin/grub-probe: warning: unknown device type nvme0n1.
done
[manjaro /]#
I don’t really know what could go wrong. At the end GRUB installed just fine, but still couldn’t find installed systems.
Can you chroot again and show us content of your /boot folder by
ls -la /boot
Here it is.
/boot/efi folder was empty until I mounted EFI partition there.
[manjaro /]# ls -la /boot
total 64
drwxr-xr-x  5 root root  4096 Sep  7 21:20 .
drwxr-xr-x 17 root root  4096 Sep  7 21:22 ..
-rw-r--r--  1 root root 40960 Aug 17 14:42 amd-ucode.img
drwxr-xr-x  2 root root  4096 Sep  4 19:44 efi
drwxr-xr-x  5 root root  4096 Sep  8 22:31 grub
drwxr-xr-x  2 root root  4096 Jun  6 10:03 memtest86+
[manjaro /]# ls -la /boot/efi
total 6
drwxr-xr-x 3 root root 1024 Jan  1  1970 .
drwxr-xr-x 5 root root 4096 Sep  7 21:20 ..
drwxr-xr-x 5 root root 1024 Sep  4 21:45 EFI
[manjaro /]# ls -la /boot/efi/EFI
total 5
drwxr-xr-x 5 root root 1024 Sep  4 21:45 .
drwxr-xr-x 3 root root 1024 Jan  1  1970 ..
drwxr-xr-x 2 root root 1024 Sep  4 16:40 Boot
drwxr-xr-x 2 root root 1024 Sep  4 21:45 Manjaro
drwxr-xr-x 4 root root 1024 Sep  4 16:36 Microsoft
[manjaro /]#
I think you might have to mount the efi partition before entering the command grub-install… in chroot.
I did it this way. I followed instructions on Wiki page step by step.
Strangely enough, when I go to /mnt/boot/efi/ in Dolphin it seems empty. Dolphin still shows available space correctly, but no files are shown. Maybe it’s some clue?
  1. This is strange and must be fixed first. :thinking: Have you booted the live iso in UEFI mode? Your system looks like UEFI.
  2. As all your kernels are missing, within manjaro-chroot you could try to install a kernel, e.g. 5.4 (or chose your preffered one) by
mhwd-kernel -i linux54
mkinitcpio -P
depmod -a
update-grub
exit
I’m pretty sure that I booted live iso in UEFI mode. I selected boot override from UEFI. Also CSM (BIOS-legacy boot) is turned off in UEFI settings.
I use the same pendrive trying to restore GRUB that I used to install Manjaro. And it worked fine - installed system booted with no problems.
I’ll try installing new kernel and see if it helps.
EDIT:
Looks like even installing new kernel won’t that easy after all…
mhwd-kernel -i linux58
 core                                      169.9 KiB   849 KiB/s 00:00 [#######################################] 100%
 extra                                    2016.3 KiB   966 KiB/s 00:02 [#######################################] 100%
 community                                   6.1 MiB   980 KiB/s 00:06 [#######################################] 100%
 multilib                                  194.6 KiB  1871 KiB/s 00:00 [#######################################] 100%
The following packages are out of date, please update your system first: accounts-qml-module accountsservice amd-ucode apr-util ark at-spi2-core baloo-widgets binutils breeze cfitsio chromaprint chromium cups-filters discount dolphin dolphin-plugins editorconfig-core-c exiv2 f2fs-tools ffmpegthumbs filelight firefox gcc gcc-libs gettext glibc gnupg gnutls gtk-update-icon-cache gtk3 gwenview harfbuzz harfbuzz-icu htop iana-etc imagemagick iw jasper k3b kaccounts-integration kaccounts-providers kactivitymanagerd kamera kate kcalc kde-cli-tools kde-gtk-config kdeconnect kdecoration kdegraphics-thumbnailers kdenetwork-filesharing kdeplasma-addons kdialog keditbookmarks kfind kgamma5 kget khelpcenter khotkeys kinfocenter kio-extras kmenuedit knetattach konsole kscreen kscreenlocker ksshaskpass ksysguard ksystemlog kwallet-pam kwalletmanager kwayland-integration kwayland-server kwin kwrited lib32-gcc-libs lib32-glibc lib32-libcap lib32-libva-mesa-driver lib32-libx11 lib32-mesa lib32-mesa-vdpau lib32-sqlite lib32-systemd lib32-vulkan-icd-loader lib32-vulkan-intel lib32-vulkan-radeon libao libcap libcap-ng libde265 libedit libgpg-error libjpeg-turbo libkcddb libkdcraw libkexiv2 libkipi libksane libksba libkscreen libksysguard liblouis libmpdclient libpsl libqmi libreoffice-still libssh libutil-linux libva-mesa-driver libwacom libx11 libxcrypt linux-api-headers linux-firmware llvm-libs manjaro-hello manjaro-release md4c mesa mesa-vdpau milou mkinitcpio-busybox mpd nano ntfs-3g okular openssh opera opera-ffmpeg-codecs oxygen pamac-cli pamac-common pamac-flatpak-plugin pamac-gtk pamac-snap-plugin pamac-tray-appindicator perl-html-parser perl-path-tiny pipewire plasma-desktop plasma-integration plasma-nm plasma-pa plasma-workspace plasma-workspace-wallpapers polkit-kde-agent poppler poppler-qt5 powerdevil print-manager python python-pycurl python-pyqt5-sip python-reportlab python-setuptools python-sip python2 qqc2-desktop-style qrencode qt5-base qt5-declarative ruby s-nail sane sddm-kcm signon-kwallet-extension smartmontools snapd socat spectacle spirv-tools sqlite steam-manjaro systemd systemd-libs systemd-sysvcompat systemsettings talloc transcode user-manager util-linux vmaf vulkan-icd-loader vulkan-intel vulkan-radeon xapian-core xdg-desktop-portal-kde
Do you want to continue anyway? [y/N] y
error: no targets specified (use -h for help)
I’m starting to wonder if full reinstall wouldn’t be easiest and fastest solution, but I’m afraid that I’ll just end up in the same place I’m in now.
I agree with @Wollie.
Please run the following command:
test -d /sys/firmware/efi && echo "EFI :)" || echo "BIOS :("
That will tell you if you’re running in BIOS or EFI mode if you’re in BIOS mode tell us how exactly you’re booting the Store’NGo (that seems to be formatted in EFI mode, so that’s good, but it has a Joliet system too)
:innocent:
Here it goes:
[manjaro@manjaro ~]$ test -d /sys/firmware/efi && echo "EFI :)" || echo "BIOS :("
EFI :)
I was pretty sure I was in UEFI mode :slight_smile:
As for the way I’ve booted Live iso, I used Boot Override and selected UEFI: Verbatim Store’NGo
Nevertheless, have you disabled CSM in your firmware? Some UEFI implementations are really strange and get a system booted in legacy mode as they believe to have detected a BIOS system.
Yes, I disabled CSM prior to installation of Windows 10 and Manjaro. I wanted to be sure as I had some problems with my old computer because of it.
EDIT: I’ve found this topic fresh-manjaro-doesnt-boot-at-all-after-package-manager-update-upgrade/22781 and it’s strangely similar to my problem. I think I’ll try my luck with reinstall and updating system with terminal.
Answer 1. It’s a bug.
You can run pacman -Syu first. Be sure to be chrooted first. After that you have to install a kernel. Your /boot has no kernels, so nothing is added to grub menu.
After that you should be able to do an update-grub but check and recheck that the right partition is mounted in /boot/efi
I reinstalled Manjaro, although reinstallation is always a last resort for me. Took me some time because Calamares hung twice installing LibreOffice, but all in all it’s a success :relieved:
I updated the freshly installed system with
sudo pacman-mirrors --fasttrack && sudo pacman -Syyu
and it did the trick. System is up and running, GRUB shows both systems and everything works.
It seems that broken update was the reason for boot failure and maybe for GRUB repairing problems.
Thank you all for help :slightly_smiling_face:
I have very similar problem as one described in this post.
I have dual boon Win 8.1 / Manjaro system. After Clonezilla whole-drive backup, GRUB startup menu disappeared completely and the system goes direct into Windows.
I tried the instructions from the GRUB /Restore GRUB Bootloader, starting the system from USB and after several unsuccessful attempts managed to get all the way to the last step ‘sudo update-grub’ which came up with similar error as in last section of post 3 above (cannot find GRUB for dev/sdb1)
Upon restart of the system, the GRUB menu showed up, however, it only had a single option which is Windows. Now I am stuck how to get the Manjaro option as well as the other two standard menu items (memtest and advanced).
my ext4 partition is sda6 and my vfat (efi) partition is sda2
/boot/EFI directory contains /Boot; /Manjaro; /Microsoft
Any help is much appreciated. Thanks!
Hello. Please, open your own topic about your problem, where you include the output of:
parted -l
efibootmgr -v
lsblk -f
Done
here is the link:
GRUB menu disappeared after Clonezilla backup
Thanks
