Grub found non-existent partitions and the system stopped booting
Two days or so ago, grub started finding the non-existent partitions, where is none. Grub commands are also takes A LOT of time to complete (3+ mins or so). Today I couldn’t boot into my system at all, and had to go through the grub restore guide. Here’s output of grub-mkconfig -o /boot/grub/grub.cfg from there:
[manjaro /]# grub-mkconfig -o /boot/grub/grub.cfg
Found linux image: /boot/vmlinuz-linux-xanmod-linux-bin-x64v3
Found initrd image: /boot/amd-ucode.img /boot/initramfs-linux-xanmod-linux-bin-x64v3.img
Found initrd fallback image: /boot/initramfs-linux-xanmod-linux-bin-x64v3-fallback.img
Found linux image: /boot/vmlinuz-6.1-x86_64
Found initrd image: /boot/amd-ucode.img /boot/initramfs-6.1-x86_64.img
Found initrd fallback image: /boot/initramfs-6.1-x86_64-fallback.img
Found linux image: /boot/vmlinuz-5.15-x86_64
Found initrd image: /boot/amd-ucode.img /boot/initramfs-5.15-x86_64.img
Found initrd fallback image: /boot/initramfs-5.15-x86_64-fallback.img
grub-probe: error: cannot find a GRUB drive for /dev/sda1.  Check your device.map.
Found Manjaro Linux on /dev/nvme1n1p2
Detecting snapshots ...
No snapshots found.
If you think an error has occurred, please file a bug report at "https://github.com/Antynea/grub-btrfs"
Unmount /tmp/grub-btrfs.o5znpQkCze .. Success
/usr/bin/grub-probe: warning: unknown device type nvme1n1.
done
I’m not yet sure if I’ll be able to boot into my system this time, but I guess it’s related.
Nope, it doesn’t boots. It hangs up on a motherboard creator logo before the grub. I have no idea how to restore on this point, seems like timeshift also is not an option. Output from timeshift --restore:
[manjaro /]# timeshift --restore
Select backup device:
Num    Device  Size  Type  Label
Enter device name or number (a=Abort): a
Aborted.
I also must note, that I made a manual chroot, since manjaro-chroot -a throw an error ==> ERROR: No Linux partitions detected!
Welcome to Manjaro! :smiling_face_with_three_hearts:
  1. Please read the information behind this link. It will help you to post necessary information. [HowTo] Provide System Information
  2. Please press the three dots … below your post and then press the :pencil2:
  • If you give us information about your system, we can see what we’re talking about and make better suggestions.
  • You can do this by using inxi in a terminal or in console.
  • Personally identifiable information such as serial numbers and MAC addresses are filtered out by this command
  • Presenting the information in this way allows everyone to be familiar with the format and quickly find the items they need without missing anything.
  1. Copy the output from inxi (including the command) and paste it into your post.
  • To make it more readable, add 3 backticks ``` on an extra line before and after the pasted text.
    (Wisdom lies in reading :wink: )
May be your hardware has a problem ?
  • Replug all connections of motherboard / devices ?
Here’s an output from inxi:
[manjaro manjaro]# inxi --admin --verbosity=7 --filter --no-host --width
  Kernel: 6.1.1-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
    parameters: BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=us tz=UTC
    misobasedir=manjaro misolabel=MANJARO_KDE_220 quiet systemd.show_status=1
    splash driver=free nouveau.modeset=1 i915.modeset=1 radeon.modeset=1
  Desktop: KDE Plasma v: 5.26.4 tk: Qt v: 5.15.7 wm: kwin_x11 vt: 1 dm: SDDM
  Type: Laptop System: Acer product: Nitro AN515-45 v: V1.08 serial: <filter>
  Mobo: CZ model: Scala_CAS v: V1.08 serial: <filter> UEFI: Insyde v: 1.08
    date: 07/21/2021
  ID-1: BAT1 charge: 51.4 Wh (100.0%) condition: 51.4/57.5 Wh (89.4%)
    volts: 16.8 min: 15.4 model: LGC AP18E8M type: Li-ion serial: <filter>
    status: full
  RAM: total: 14.99 GiB used: 3.47 GiB (23.1%)
  Array-1: capacity: 64 GiB slots: 2 EC: None max-module-size: 32 GiB
    note: est.
  Device-1: DIMM 0 type: DDR4 detail: synchronous unbuffered (unregistered)
    size: 8 GiB speed: 3200 MT/s volts: curr: 1.2 min: 1.2 max: 1.2 width (bits):
    data: 64 total: 64 manufacturer: Micron Technology
    part-no: 4ATF1G64HZ-3G2B2 serial: <filter>
  Device-2: DIMM 0 type: DDR4 detail: synchronous unbuffered (unregistered)
  Info: model: AMD Ryzen 5 5600H with Radeon Graphics socket: FP6 bits: 64
    type: MT MCP arch: Zen 3 gen: 4 level: v3 note: check built: 2021-22
    microcode: 0xA50000C
    L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB L3: 16 MiB
    desc: 1x16 MiB
  Speed (MHz): avg: 1375 high: 3300 min/max: 1200/4280 boost: enabled
    base/boost: 3300/4250 scaling: driver: acpi-cpufreq governor: schedutil
    volts: 1.2 V ext-clock: 100 MHz cores: 1: 1200 2: 1200 3: 1200 4: 1200
    5: 1200 6: 1200 7: 1200 8: 1200 9: 1200 10: 1200 11: 1200 12: 3300
    bogomips: 79080
    cqm_occup_llc cr8_legacy cx16 cx8 de decodeassists erms extapic
    extd_apicid f16c flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht
    hw_pstate ibpb ibrs ibs invpcid irperf lahf_lm lbrv lm mba mca mce
    pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt
    pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
    skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor
    svm svm_lock syscall tce topoext tsc tsc_scale umip v_spec_ctrl
    v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vpclmulqdq wbnoinvd wdt
    STIBP: always-on, RSB filling, PBRSB-eIBRS: Not affected
  Device-1: NVIDIA GA106M [GeForce RTX 3060 Mobile / Max-Q]
    vendor: Acer Incorporated ALI driver: nouveau v: kernel non-free: 525.xx+
    status: current (as of 2022-12) arch: Ampere code: GAxxx
    process: TSMC n7 (7nm) built: 2020-22 pcie: speed: Unknown lanes: 63
    link-max: gen: 6 speed: 64 GT/s ports: active: none empty: HDMI-A-1
    bus-ID: 01:00.0 chip-ID: 10de:2520 class-ID: 0300
  Device-2: AMD Cezanne [Radeon Vega Series / Radeon Mobile Series]
    vendor: Acer Incorporated ALI driver: amdgpu v: kernel arch: GCN-5.1
    code: Vega-2 process: TSMC n7 (7nm) built: 2018-21 pcie: gen: 3
    speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s ports:
    active: eDP-1 empty: none bus-ID: 06:00.0 chip-ID: 1002:1638 class-ID: 0300
    temp: 31.0 C
  Device-3: Quanta HD User Facing type: USB driver: uvcvideo bus-ID: 3-3:3
    chip-ID: 0408:a061 class-ID: 0e02
  Display: x11 server: X.Org v: 21.1.6 compositor: kwin_x11 driver: X:
    loaded: amdgpu unloaded: modesetting alternate: fbdev,vesa dri: radeonsi
    gpu: amdgpu display-ID: :0 screens: 1
    s-diag: 582mm (22.93")
  Monitor-1: eDP-1 mapped: eDP model: ChiMei InnoLux 0x1521 built: 2020
    res: 1920x1080 hz: 144 dpi: 142 gamma: 1.2 size: 344x193mm (13.54x7.6")
    diag: 394mm (15.5") ratio: 16:9 modes: max: 1920x1080 min: 640x480
  API: OpenGL v: 4.6 Mesa 22.3.1 renderer: AMD Radeon Graphics (renoir LLVM
    14.0.6 DRM 3.49 6.1.1-1-MANJARO) direct render: Yes
  Device-1: NVIDIA GA106 High Definition Audio vendor: Acer Incorporated ALI
    driver: snd_hda_intel v: kernel pcie: speed: Unknown lanes: 63 link-max:
    gen: 6 speed: 64 GT/s bus-ID: 01:00.1 chip-ID: 10de:228e class-ID: 0403
  Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor
    vendor: Acer Incorporated ALI driver: N/A alternate: snd_pci_acp3x,
    snd_rn_pci_acp3x, snd_pci_acp5x, snd_pci_acp6x, snd_acp_pci,
    snd_rpl_pci_acp6x, snd_pci_ps, snd_sof_amd_renoir, snd_sof_amd_rembrandt
    pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s
    bus-ID: 06:00.5 chip-ID: 1022:15e2 class-ID: 0480
  Device-3: AMD Family 17h/19h HD Audio vendor: Acer Incorporated ALI
    link-max: gen: 4 speed: 16 GT/s bus-ID: 06:00.6 chip-ID: 1022:15e3
    class-ID: 0403
  Sound API: ALSA v: k6.1.1-1-MANJARO running: yes
  Sound Server-3: PipeWire v: 0.3.63 running: yes
  Device-1: Realtek vendor: Acer Incorporated ALI driver: r8169 v: kernel pcie:
    gen: 1 speed: 2.5 GT/s lanes: 1 port: 2000 bus-ID: 04:00.0 chip-ID: 10ec:2600
    class-ID: 0200
  IF: enp4s0 state: down mac: <filter>
  Device-2: MEDIATEK MT7921 802.11ax PCI Express Wireless Network Adapter
    vendor: Lite-On driver: mt7921e v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1
    bus-ID: 05:00.0 chip-ID: 14c3:7961 class-ID: 0280
  IF: wlp5s0 state: up mac: <filter>
  Device-1: Lite-On Wireless_Device type: USB driver: btusb v: 0.8
    bus-ID: 1-4:3 chip-ID: 04ca:3802 class-ID: e001 serial: <filter>
  Local Storage: total: 1.38 TiB used: 445.07 GiB (31.4%)
  ID-1: /dev/nvme0n1 maj-min: 259:4 vendor: Kingston model: OM8PDP3512B-AA1
    lanes: 4 type: SSD serial: <filter> rev: EDFK0S03 temp: 33.9 C scheme: GPT
  SMART: yes health: PASSED on: 142d 5h cycles: 1,428
    read-units: 23,299,311 [11.9 TB] written-units: 8,497,299 [4.35 TB]
  ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Western Digital
    model: WDS100T1X0E-00AFY0 size: 931.51 GiB block-size: physical: 512 B
    logical: 512 B speed: 63.2 Gb/s lanes: 4 type: SSD serial: <filter>
    rev: 614600WD temp: 27.9 C scheme: GPT
  SMART: yes health: PASSED on: 83d 7h cycles: 1,396
    read-units: 6,233,859,587 [3.19 PB] written-units: 251,610,369 [128 TB]
  ID-3: /dev/sda maj-min: 8:0 type: USB vendor: Verbatim model: STORE N GO
    size: 7.22 GiB block-size: physical: 512 B logical: 512 B type: N/A
    serial: <filter> rev: PMAP scheme: MBR
  ID-1: /mnt raw-size: 922.42 GiB size: 922.42 GiB (100.00%)
    used: 445.07 GiB (48.3%) fs: btrfs block-size: 4096 B dev: /dev/nvme1n1p2
    maj-min: 259:2 label: N/A uuid: 9561de22-96e5-46aa-9810-bb027c4815e9
  ID-1: /dev/nvme0n1p1 maj-min: 259:5 size: 1024 MiB fs: vfat label: UEFISHELL
    uuid: C8B0-ECD1
  ID-2: /dev/nvme0n1p2 maj-min: 259:6 size: 16 MiB fs: N/A label: N/A
    uuid: N/A
  ID-3: /dev/nvme0n1p3 maj-min: 259:7 size: 468.02 GiB fs: ntfs label: N/A
    uuid: BA464D86464D43FB
  ID-4: /dev/nvme0n1p4 maj-min: 259:8 size: 641 MiB fs: ntfs label: N/A
    uuid: 6C94DF4194DF0C88
  ID-5: /dev/nvme0n1p5 maj-min: 259:9 size: 7.27 GiB fs: ntfs
    label: WINDRIVER uuid: 6880B95880B92E06
  ID-6: /dev/nvme1n1p1 maj-min: 259:1 size: 300 MiB fs: vfat label: NO_LABEL
    uuid: F6A7-CC4B
  ID-7: /dev/nvme1n1p3 maj-min: 259:3 size: 8.8 GiB fs: swap label: N/A
    uuid: 095652b9-970d-4821-b278-407d8bcae184
  ID-8: /dev/sda1 maj-min: 8:1 size: 3.57 GiB fs: iso9660
  ID-9: /dev/sda2 maj-min: 8:2 size: 4 MiB fs: vfat label: MISO_EFI
    uuid: 5C67-4BF8
  Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
  Device-1: 1-2:2 info: Razer USA Naga Trinity type: Mouse,Keyboard
    driver: hid-generic,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s power: 500mA
    chip-ID: 1532:0067 class-ID: 0300 serial: <filter>
  Device-2: 1-4:3 info: Lite-On Wireless_Device type: Bluetooth driver: btusb
    interfaces: 3 rev: 2.1 speed: 480 Mb/s power: 100mA chip-ID: 04ca:3802
  Hub-2: 2-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
  Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
  Device-1: 3-2:2 info: Verbatim Flash Drive type: Mass Storage
    driver: usb-storage interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 200mA
    chip-ID: 18a5:0302 class-ID: 0806 serial: <filter>
  Device-2: 3-3:3 info: Quanta HD User Facing type: Video driver: uvcvideo
    interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 0408:a061
    class-ID: 0e02
  Hub-4: 4-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
  System Temperatures: cpu: 39.8 C mobo: N/A gpu: amdgpu temp: 32.0 C
  Processes: 316 Uptime: 21m wakeups: 1 Init: systemd v: 252 default: graphical
  tool: systemctl Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: pm: pacman
  pkgs: 1175 libs: 321 tools: pamac pm: flatpak pkgs: 0 Shell: Bash (su)
  v: 5.1.16 running-in: konsole inxi: 3.3.24
No, I don’t think it’s a hardware problem, since I can mount my partition from a live-CD
My grub.cfg weights more than 10MiB, is it normal? I mean, it has TONS of recurring non-existent partitions
I started having a similar problem regards multiple entries for Manjaro. As far as I can figure out these are timeshift snapshots being seen as multiple OS’s.
I’ve managed to boot into my system. I’ve made so by removing os-prober in grub settings (setting the GRUB_DISABLE_OS_PROBER in /etc/default/grub to true) and running update-grub in a chroot from live-cd. But that actually doesn’t seem like the right solution.
In my case my system boots just fine. It just irritates me that the grub is screwed up.
I hope anyone finds out what to do with that bug, or at least will tell me, to which repo it’s better to be reported. i don’t feel “safe” without permission to my timeshifts from grub, but afaik there’s no other way to boot the system at current state of grub’s config
