Hi,
I had installed several months ago Arch Linux along with Windows 10 in my laptop. It has a SSD and I added a second SSD to it. It was running without problems.
Some weeks ago, after a kernel update that does not ended correctly, I had my Arch Linux unusable. I was trying to fix but finally I decided to move to a more stable distribution and choose Manjaro. Before I play with EndeavourOS but finally I prefer a Arch Linux based distribution.
The problem was at installation… It seems I didn’t clean at all my previous installation and, I do not how, I ended with a strange (for me) configuration…
When I boot, grub menu does not appear… If I want to boot in Windows, I have to choose it from the BIOS or through the efibootmgr command…
sudo os-prober does not return anything…
Any help will be welcome
Here you have info from my system:
~ sudo efibootmgr -v ✔ 11s
BootCurrent: 0003
Timeout: 5 seconds
BootOrder: 0003,0001,2001,2002,2003
Boot0001* Windows Boot Manager HD(1,GPT,0ceaa01c-00c9-4570-b6ad-fdc5b1f46efa,0x28,0x64000)/File(\EFI\Microsoft\Boot\bootmgfw.efi)WINDOWS.........x...B.C.D.O.B.J.E.C.T.=.{.9.d.e.a.8.6.2.c.-.5.c.d.d.-.4.e.7.0.-.a.c.c.1.-.f.3.2.b.3.4.4.d.4.7.9.5.}...M................
Boot0003* Manjaro HD(1,GPT,0ceaa01c-00c9-4570-b6ad-fdc5b1f46efa,0x28,0x64000)/File(\EFI\Manjaro\grubx64.efi)
Boot2001* EFI USB Device RC
Boot2002* EFI DVD/CDROM RC
Boot2003* EFI Network RC
sudo fdisk -l ✔
Disk /dev/nvme0n1: 238,47 GiB, 256060514304 bytes, 500118192 sectors
Disk model: SAMSUNG MZVLW256HEHP-00000
Disklabel type: gpt
Disk identifier: CD161E81-1698-456E-98D3-EBB419AF6AF8
Dispositiu Start Final Sectors Size Tipus
/dev/nvme0n1p1 40 409639 409600 200M BIOS boot
/dev/nvme0n1p2 411648 444415 32768 16M Microsoft reserved
/dev/nvme0n1p3 444416 165445631 165001216 78,7G Linux filesystem
/dev/nvme0n1p4 165445632 499095831 333650200 159,1G Microsoft basic data
Disk /dev/sda: 465,76 GiB, 500107862016 bytes, 976773168 sectors
Disk model: WDC WDS500G2B0B
Disklabel type: gpt
Disk identifier: 1DDFB5F4-5664-43B3-A731-4701F15695AB
/dev/sda1 34 32767 32734 16M Microsoft reserved
/dev/sda2 32768 567171071 567138304 270,4G Microsoft basic data
/dev/sda3 567171072 632709119 65538048 31,3G Intercanvi Linux
/dev/sda4 632709120 976773134 344064015 164,1G Linux filesystem
sudo parted -l ✔
Model: ATA WDC WDS500G2B0B (scsi)
Disk /dev/sda: 500GB
Partition Table: gpt
Disk Flags:
Number Start End Size File system Name Flags
1 17,4kB 16,8MB 16,8MB Microsoft reserved partition msftres
2 16,8MB 290GB 290GB ntfs Basic data partition msftdata
3 290GB 324GB 33,6GB linux-swap(v1) swap
4 324GB 500GB 176GB ext4
Model: SAMSUNG MZVLW256HEHP-00000 (nvme)
Disk /dev/nvme0n1: 256GB
Disk Flags:
1 20,5kB 210MB 210MB fat32 EFI System Partition bios_grub
2 211MB 228MB 16,8MB Microsoft reserved partition msftres
3 228MB 84,7GB 84,5GB ext4
4 84,7GB 256GB 171GB ntfs msftdata
~ sudo update-grub ✔
Es genera un fitxer de configuració...
S'ha trobat el tema :/usr/share/grub/themes/manjaro/theme.txt
S'ha trobat una imatge de linux: /boot/vmlinuz-5.15-x86_64
S'ha trobat una imatge de initrd: /boot/intel-ucode.img /boot/initramfs-5.15-x86_64.img
Found initrd fallback image: /boot/initramfs-5.15-x86_64-fallback.img
Avís: os-prober will be executed to detect other bootable partitions.
/usr/bin/grub-probe: avís: el tipus de dispositiu nvme0n1 és desconegut.
fet
lsblk -f | grep efi ✔ 1m 8s
├─nvme0n1p1 vfat FAT32 NO_LABEL 67E3-17ED 133,7M 32% /boot/efi
cat /etc/fstab | grep efi ✔
UUID=67E3-17ED /boot/efi vfat umask=0077 0 2
su -c "ls -l /boot/efi/EFI/" ✔ 4s
total 7
drwx------ 3 root root 512 29 d’abr. 2018 APPLE
drwx------ 2 root root 512 29 d’abr. 2018 BOOT
drwx------ 7 root root 1536 27 de maig 2018 CLOVER
-rwx------ 1 root root 1906 14 d’abr. 2018 Clover_Install_Log.txt
drwx------ 3 root root 512 5 de maig 2019 EFI
drwx------ 2 root root 512 4 de maig 2019 GRUB
drwx------ 2 root root 512 18 d’oct. 00:59 Manjaro
drwx------ 4 root root 512 27 de maig 2018 Microsoft
su -c "ls -l /boot/efi/EFI/Microsoft/Boot/*.efi"
-rwx------ 1 root root 1558864 6 d’oct. 00:16 /boot/efi/EFI/Microsoft/Boot/bootmgfw.efi
-rwx------ 1 root root 1542992 6 d’oct. 00:16 /boot/efi/EFI/Microsoft/Boot/bootmgr.efi
-rwx------ 1 root root 1348920 17 de set. 00:10 /boot/efi/EFI/Microsoft/Boot/memtest.efi
I tried to add the Windows entry in /etc/grub.d/40_custom but grub does not appear
menuentry ‘Windows 10’ --class windows --class os --id windows-custom {
search --fs-uuid --no-floppy --set=root 67E3-17ED
chainloader (${root})/EFI/Microsoft/Boot/bootmgfw.efi
