I have two OSes on two different hard disks. On my 256GB SSD I am running Manjaro KDE and on my 1TB SSD Windows 10. In BIOS, the first device in the boot order is the M2 256 SSD/Manjaro KDE.
I have edited the /etc/default/grub file to:
GRUB_DEFAULT=0
GRUB_TIMEOUT=0
GRUB_TIMEOUT_STYLE=hidden
GRUB_DISTRIBUTOR="Manjaro"
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash resume=UUID=5d178c61-fac8-46ec-8b66-37f2b97fce07 udev.log_priority=3"
GRUB_CMDLINE_LINUX=""
Output when I run sudo update-grub:
Found linux image: /boot/vmlinuz-6.1-x86_64
Found initrd image: /boot/intel-ucode.img /boot/initramfs-6.1-x86_64.img
Found initrd fallback image: /boot/initramfs-6.1-x86_64-fallback.img
Root filesystem isn't btrfs
If you think an error has occurred, please file a bug report at "https://github.com/Antynea/grub-btrfs"
Found memtest86+ EFI image: /boot/memtest86+/memtest.efi
done
Yet whenever I restart the PC, the GRUB loader always open first. I want Manjaro to begin booting directly and not having to manually write exit every time the GRUB starts up.
System info:
Kernel: 6.1.19-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=30b101f0-84c0-4963-8856-274804c75768 rw quiet splash
Desktop: KDE Plasma v: 5.26.5 tk: Qt v: 5.15.8 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop Mobo: ASUSTeK model: TUF Z270 MARK 2 v: Rev 1.xx
serial: <superuser required> UEFI-[Legacy]: American Megatrends v: 1301
date: 03/14/2018
Device-1: hidpp_battery_2 model: Logitech G304 Lightspeed Wireless Gaming
Mouse serial: <filter> charge: 100% (should be ignored) rechargeable: yes
status: discharging
RAM: total: 15.5 GiB used: 3.7 GiB (23.9%)
Info: model: Intel Core i7-7700K bits: 64 type: MT MCP arch: Kaby Lake
gen: core 7 level: v3 note: check built: 2018 process: Intel 14nm family: 6
model-id: 0x9E (158) stepping: 9 microcode: 0xF0
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 1650 high: 4200 min/max: 800/4600 scaling:
driver: intel_pstate governor: powersave cores: 1: 800 2: 4200 3: 4200 4: 800
5: 800 6: 800 7: 800 8: 800 bogomips: 67224
intel_pt invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor
movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm
pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand rdseed rdtscp
rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
vulnerable
Type: spectre_v2 mitigation: IBRS, IBPB: conditional, STIBP: conditional,
RSB filling, PBRSB-eIBRS: Not affected
Device-1: Intel HD Graphics 630 vendor: ASUSTeK driver: i915 v: kernel
arch: Gen-9.5 process: Intel 14nm built: 2016-20 ports: active: HDMI-A-1
empty: HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:5912 class-ID: 0300
Device-2: Logitech Webcam C310 type: USB driver: snd-usb-audio,uvcvideo
bus-ID: 1-8:10 chip-ID: 046d:081b class-ID: 0102 serial: <filter>
Display: x11 server: X.Org v: 21.1.7 compositor: kwin_x11 driver: X:
loaded: modesetting alternate: fbdev,vesa dri: iris gpu: i915 display-ID: :0
screens: 1
s-diag: 582mm (22.93")
Monitor-1: HDMI-A-1 mapped: HDMI-1 model: Dell U2417H serial: <filter>
built: 2018 res: 1920x1080 hz: 60 dpi: 93 gamma: 1.2
size: 527x296mm (20.75x11.65") diag: 604mm (23.8") ratio: 16:9 modes:
max: 1920x1080 min: 720x400
API: OpenGL v: 4.6 Mesa 22.3.5 renderer: Mesa Intel HD Graphics 630 (KBL
GT2) direct-render: Yes
Device-1: Intel 200 Series PCH HD Audio vendor: ASUSTeK driver: snd_hda_intel
bus-ID: 1-8:10 v: kernel bus-ID: 00:1f.3 chip-ID: 046d:081b class-ID: 0102
chip-ID: 8086:a2f0 class-ID: 0403 serial: <filter>
Sound API: ALSA v: k6.1.19-1-MANJARO running: yes
Sound Server-1: JACK v: 1.9.22 running: no
Sound Server-3: PipeWire v: 0.3.65 running: yes
Device-1: Intel Ethernet I219-V vendor: ASUSTeK driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15b8 class-ID: 0200
IF: enp0s31f6 state: up speed: 1000 Mbps duplex: full mac: <filter>
driver: btusb v: 0.8 bus-ID: 1-1.4:17 chip-ID: 0a12:0001 class-ID: e001
Local Storage: total: 6.6 TiB used: 3.17 TiB (48.0%)
model: WDS100T3X0C-00SJG0 size: 931.51 GiB block-size: physical: 512 B
rev: 111110WD temp: 49.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 850 EVO M.2 250GB
size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 1B6Q scheme: MBR
ID-3: /dev/sdb maj-min: 8:16 vendor: Western Digital
model: WD10EZEX-21WN4A0 size: 931.51 GiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s type: HDD rpm: 7200 serial: <filter>
rev: 1A01 scheme: GPT
ID-4: /dev/sdc maj-min: 8:32 type: USB vendor: Seagate model: BUP Slim RD
size: 931.51 GiB block-size: physical: 4096 B logical: 512 B type: N/A
serial: <filter> rev: 0304 scheme: MBR
ID-5: /dev/sdd maj-min: 8:48 type: USB vendor: Western Digital
model: WD40NDZW-11MR8S1 size: 3.64 TiB block-size: physical: 4096 B
logical: 512 B type: HDD rpm: 5400 serial: <filter> rev: 4008 scheme: GPT
ID-1: / raw-size: 215.84 GiB size: 211.39 GiB (97.94%)
used: 27.57 GiB (13.0%) fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: 30b101f0-84c0-4963-8856-274804c75768
ID-2: /mnt/Lord Lance raw-size: 3.64 TiB size: 3.64 TiB (100.00%)
used: 3.14 TiB (86.3%) fs: ntfs dev: /dev/sdd1 maj-min: 8:49
label: Lord Lance uuid: A2F647BFF6479309
ID-1: swap-1 type: partition size: 17.05 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/sda2 maj-min: 8:2 label: swap
uuid: 5d178c61-fac8-46ec-8b66-37f2b97fce07
ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 100 MiB fs: vfat label: N/A
uuid: C4C9-FCA3
ID-2: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-3: /dev/nvme0n1p3 maj-min: 259:3 size: 930.9 GiB fs: ntfs label: N/A
uuid: 9E50D3D450D3B0EF
ID-4: /dev/nvme0n1p4 maj-min: 259:4 size: 509 MiB fs: ntfs label: N/A
uuid: BE04EE2204EDDE01
ID-5: /dev/sdb1 maj-min: 8:17 size: 931.51 GiB fs: ntfs label: Local Disk
uuid: 406096B36096AF62
ID-6: /dev/sdc1 maj-min: 8:33 size: 931.51 GiB fs: ntfs
label: Seagate Backup uuid: 4E72C35E72C34983
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 16 rev: 2.0
Hub-2: 1-1:15 info: Microchip (formerly SMSC) USB2137B ports: 7 rev: 2.1
speed: 480 Mb/s chip-ID: 0424:2137 class-ID: 0900
Device-1: 1-1.3:16 info: Logitech USB Receiver type: Keyboard,Mouse,HID
power: 98mA chip-ID: 046d:c53f class-ID: 0300
Device-2: 1-1.4:17 info: Cambridge Silicon Radio Bluetooth Dongle (HCI
mode) type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 0a12:0001 class-ID: e001
Device-3: 1-1.5:18 info: Microchip U2417H_0B29_15083001 type: HID
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 12 Mb/s power: 100mA
chip-ID: 04d8:0b29 class-ID: 0300
Device-4: 1-3:3 info: Logitech Keyboard K120 type: Keyboard,HID
driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 1.5 Mb/s power: 90mA
chip-ID: 046d:c31c class-ID: 0300
Device-5: 1-8:10 info: Logitech Webcam C310 type: Video,Audio
power: 500mA chip-ID: 046d:081b class-ID: 0102 serial: <filter>
Device-6: 1-9:8 info: Corsair H100iRGBPROXT type: Keyboard
chip-ID: 1b1c:0c20 class-ID: 0300
Device-7: 1-14:9 info: Seagate RSS LLC Backup Plus Portable Drive
type: Mass Storage driver: uas interfaces: 1 rev: 2.1 speed: 480 Mb/s
power: 100mA chip-ID: 0bc2:ab24 class-ID: 0806 serial: <filter>
Hub-3: 2-0:1 info: Super-speed hub ports: 10 rev: 3.0 speed: 5 Gb/s
Hub-4: 2-1:5 info: Microchip (formerly SMSC) USB5537B ports: 7 rev: 3.0
speed: 5 Gb/s chip-ID: 0424:5537 class-ID: 0900
Device-1: 2-2:3 info: Western Digital My Passport 2627 type: Mass Storage
driver: usb-storage interfaces: 1 rev: 3.1 speed: 5 Gb/s power: 896mA
chip-ID: 1058:2627 class-ID: 0806 serial: <filter>
Hub-5: 3-0:1 info: Hi-speed hub with single TT ports: 2 rev: 2.0
Hub-6: 4-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 48.0 C mobo: N/A
Processes: 242 Uptime: 16h 13m wakeups: 8 Init: systemd v: 252
default: graphical tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7
Packages: pm: pacman pkgs: 1218 libs: 329 tools: pamac,yay pm: flatpak
pkgs: 0 Shell: Zsh v: 5.9 default: Bash v: 5.1.16 running-in: konsole
inxi: 3.3.25
If I understand you correctly, then you are looking to reverse the order of the items in the UEFI boot menu, is that correct? If so, please read…
man efibootmgr
As an aside, you cannot disable GRUB except by removing it, but in that case, you’ll need another boot loader, and — no offense — setting that up is probably beyond your skill level.
Oh I forgot to include the actual question: No, I am looking for a way to skip the GRUB screen so that I don’t have to write exit every single time the PC boots up. When I turn on the PC, Manjaro should load up every time.
fasto
18 March 2023 00:51
4
When GRUB opens, is it a menu that you can select different entries from or is it like a command line?
It’s command line and pressing enter does not do anything. I have to write exit to load up Manjaro.
fasto
18 March 2023 01:06
6
The settings you have in your /etc/default/grub should cause you to automatically boot into Manjaro without interruption. The fact that you are seeing a CLI means that something has gone wrong with GRUB, that is your real issue here.
Unfortunately, I don’t have the knowledge required to help you further with this, but I have gone ahead and edited your title to make it easier for someone who does to find this thread.
Then you probably need to reinstall Grub2.
I think I have read (here in the forum, too) that setting the
GRUB_TIMEOUT=0
will have no effect when you have OS_PROBER enabled and have more than just one system that Grub is supposed to boot.
The menu will always be shown (hearsay, not knowledge or experience, as noted)
But your issue is not (just) the timeout setting.
Did you include all enabled options in /etc/default/grub ?
grep -v ^# /etc/default/grub
Strange behavior - that Grub apparently ends up in edit mode
Normally, one needs to press “E” at the Grub menu to even get there.
(if I understood your description correctly)
Can you post your complete /etc/default/grub.
Here’s my complete GRUB: View paste 4MEOO
Is some setting set wrong?
I’d first revert the change you made to GRUB_TIMEOUT and set it to 5 again (what it was)
update-grub
and see whether that has some effect
The file looks ok otherwise.
just FYI:
you uncommented
GRUB_DISABLE_OS_PROBER=false
the original was:
#GRUB_DISABLE_OS_PROBER=false
this had no effect because
this is the default already - you did not need to uncomment that - only if you wanted to change it to “true”
update-grub
No change after a grub-update and restart. Still need to manually write exit.
just FYI:
you uncommented
the original was:
I did not comment or uncomment any part of this file. I only changed the numbers of the first two lines.
How do I do that?
mkay - for me (and in the .pacnew file I have) it is commented out
but I did not check this one with Manjaro - I’m at Arch (EOS) at the moment
doesn’t matter - was just some info and the line is ok in any case
so: please disregard/ignore what I said about that
This is what I get when I run the sudo update-grub command if it’s any help:
Warning: os-prober will not be executed to detect other bootable partitions.
Systems on them will not be added to the GRUB boot configuration.
Check GRUB_DISABLE_OS_PROBER documentation entry.
done
System info as well:
date: 03/14/2018
status: discharging
vulnerable
screens: 1
uuid: C4C9-FCA3
inxi: 3.3.25
This is what I see every time I boot my PC:
Pressing keys won’t exit it. I need to write exit.
thats strange - it does not jive with what is in the config file you posted
but I can’t help - I only have one system and no experience with two or why os_prober would not work
So is there a specific way to fix the os_prober issue? Again I don’t know if it’s related to BIOS setting but considering the fact that this hard disk has only one OS I would imagine the existence of other OSes on other hard disks shouldn’t matter one bit to Manjaro.
Perhaps the system info and GRUB screen picture that I posted may help.
it’s not even sure that that is the issue
in fact it’s likely not
I think already said that I’m not even sure that I understood your description of the problem you have.
Why would you end up, without so much as a keystroke, in the grub rescue/edit mode
is the question I’d have.
ps:
perhaps try taking the picture of your monitor without a flash -
so there is actually something to see in the picture
the screen is bright enough by itself - the camera flash does not help … quite the contrary - as you can (not) see
and use an external service for the pic and link it here
just as you did with your grub config
I recommend to delete the one in your post above
it’s rather useless anyway
I am out of my depth here, so this is just speculation, but with so many drives (including a mix of MBR and GPT), I wonder if there are multiple copies of GRUB installed. That could explain why your GRUB doesn’t seem consistent with your settings.
lordlance:
GRUB_TIMEOUT=0
Try setting it to 1 so it times out immediately or -1 to wait for a selection(multiboot etc). Being set to 0 may be why your sent to a shell.
Of course
update-grub
