2022-08-30 Grub bootloader upgrade and configuration incompatibilities
Recent changes in grub added a new command option to fwsetup and changed the
way the command is invoked in the generated boot configuration. Depending on
your system hardware and setup this could cause an unbootable system due to
incompatibilities between the installed bootloader and configuration. After a
grub package update it is advised to run both, installation and regeneration
of configuration:
there is a new grub 2:2.06.r322.gd9b4638c5-3, which is in arch stable now, which is also probably held back in manjaro repos. the changes indicate a message shown to users to manually re-install bootloader and “reverting of reverted commit”
Recent changes in grub added a new command option to fwsetup and changed the way the command is invoked in the generated boot configuration. Depending on your system hardware and setup this could cause an unbootable system due to incompatibilities between the installed bootloader and configuration. After a grub package update it is advised to run both, installation and regeneration of configuration:
