I updated grub according to a remark during ‘pacman’ update, stating that one may consider re-installing grub due to the package update.
Consequently, I conducted the update, following the documentation:
grub-install --target=x86_64-efi --efi-directory=/boot/efi --bootloader-id=Manjaro
update-grub
Please note that I was in a chrooted environment, which I created like this:
sudo cryptsetup /dev/sda2 tmp # Open my luks system partition
sudo mount /dev/mapper/tmp /mnt # mount the open luks device to /mnt
sudo mount /dev/sda1 /mnt/boot/efi # Mount my efi parition inside
sudo manjaro-chroot /mnt
Now I stuck at boot time with this error:
error: symbol 'grub_is_cli_need_auth' not found.
Entering rescue mode...
Can someone help?
This is my system:
sh-5.2# inxi --admin --verbosity=8 --filter --no-host --width
12System:
12Kernel 6.10.13-3-MANJARO 12arch x86_64 12bits 64 12compiler gcc 12v 14.2.1
12clocksource tsc 12avail acpi_pm 12parameters BOOT_IMAGE=/boot/vmlinuz-x86_64
lang=en_US keytable=de tz=UTC misobasedir=manjaro
misolabel=MANJARO_KDE_2412 quiet systemd.show_status=1 splash driver=free
nouveau.modeset=1 i915.modeset=1 radeon.modeset=1
12Desktop KDE Plasma 12v ERR-101 12tk Qt 12v N/A 12dm N/A 12Distro Manjaro
12base Arch Linux
12Machine:
12Type Laptop 12System Acer 12product TravelMate B117-M 12v V1.24 12serial <filter>
12Chassis 12type 10 12serial N/A
12Mobo Acer 12model Lepus_BA 12v V1.24 12serial <filter>
12part-nu TravelMate B117-M_108C_1.24 12uuid f8f6e022-35af-2f48-90a6-0000ff00703c
12UEFI Insyde 12v 1.24 12date 10/25/2018
12Battery:
12ID-1 BAT1 12charge 33.7 Wh (81.2%) 12condition 41.5/48.9 Wh (84.8%) 12volts 17.0
12min 15.2 12model LGC AC14B8K 12type Li-ion 12serial <filter> 12status charging
12Memory:
12System RAM 12total 4 GiB 12available 3.74 GiB 12used 2.63 GiB (70.3%) 12igpu 32 MiB
12Array-1 12capacity 8 GiB 12slots 2 12modules 2 12EC None 12max-module-size 4 GiB
12note est.
12Device-1 ChannelA-DIMM0 12type DDR3 12detail synchronous 12size 2 GiB
12speed 1600 MT/s 12volts 12min 1.5 12max 1.5 12width (bits) 12data 8 12total 8
12manufacturer Hynix/Hyundai 12part-no N/A 12serial N/A
12Device-2 ChannelB-DIMM0 12type DDR3 12detail synchronous 12size 2 GiB
12PCI Slots:
12Message No PCI Slot data found.
12CPU:
12Info 12model Intel Pentium N3710 12socket CHV 12bits 64 12type MCP 12arch Airmont
12level v2 12built 2015-17 12process Intel 14nm 12family 6 12model-id 0x4C (76)
12stepping 4 12microcode 0x411
12Topology 12cpus 1x 12dies 1 12clusters 2 12cores 4 12smt <unsupported> 12cache
12L1 224 KiB 12desc d-4x24 KiB; i-4x32 KiB 12L2 2 MiB 12desc 2x1024 KiB
12Speed (MHz) 12avg 2560 12min/max 480/2560 12base/boost 1600/1660 12scaling
12driver intel_cpufreq 12governor schedutil 12volts 3.8 V 12ext-clock 83 MHz 12cores
121 2560 122 2560 123 2560 124 2560 12bogomips 12805
12Flags 3dnowprefetch acpi aes aperfmperf apic arat arch_perfmon bts clflush
cmov constant_tsc cpuid cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept erms
est flexpriority fpu fxsr ht ibpb ibrs ida lahf_lm lm mca mce md_clear mmx
monitor movbe msr mtrr nonstop_tsc nopl nx pae pat pbe pclmulqdq pdcm pebs
pge pni popcnt pse pse36 pti rdrand rdtscp rep_good sep smep ss sse sse2
tsc_deadline_timer tsc_known_freq tsc_reliable vme vmx vnmi vpid xtopology
xtpr
12Vulnerabilities
12Type gather_data_sampling 12status Not affected
12Type itlb_multihit 12status Not affected
12Type l1tf 12status Not affected
12Type mds 12mitigation Clear CPU buffers; SMT disabled
12Type meltdown 12mitigation PTI
12Type mmio_stale_data 12status Unknown: No mitigations
12Type reg_file_data_sampling 12status Not affected
12Type retbleed 12status Not affected
12Type spec_rstack_overflow 12status Not affected
12Type spec_store_bypass 12status Not affected
12Type spectre_v1 12mitigation usercopy/swapgs barriers and __user pointer
12Type spectre_v2 12mitigation Retpolines; IBPB: conditional; IBRS_FW; STIBP:
12Type srbds 12status Not affected
12Type tsx_async_abort 12status Not affected
12Graphics:
12Device-1 Intel Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx
Integrated Graphics 12vendor Acer Incorporated ALI 12driver i915 12v kernel
12arch Gen-8 12process Intel 14nm 12built 2014-15 12ports 12active eDP-1 12empty DP-1,
DP-2, HDMI-A-1, HDMI-A-2 12bus-ID 00:02.0 12chip-ID 8086:22b1 12class-ID 0300
12Device-2 Chicony HD WebCam 12driver uvcvideo 12type USB 12rev 2.0 12speed 480 Mb/s
12lanes 1 12mode 2.0 12bus-ID 1-4:3 12chip-ID 04f2:b577 12class-ID 0e02
12Display 12server X.org 12v 1.21.1.18 12with Xwayland 12v 24.1.8 12driver 12X
12loaded modesetting 12alternate fbdev,vesa 12dri crocus 12gpu i915 12display-ID :0
12Monitor-1 eDP-1 12model ChiMei InnoLux 0x1132 12built 2013 12res 1366x768 12dpi 136
12gamma 1.2 12chroma 12red 12x 0.573 12y 0.333 12green 12x 0.325 12y 0.584 12blue 12x 0.161
12y 0.141 12white 12x 0.314 12y 0.329 12size 256x144mm (10.08x5.67")
12diag 294mm (11.6") 12ratio 16:9 12modes 1366x768
12API EGL 12v 1.5 12hw 12drv intel crocus 12platforms 12device 0 12drv crocus 12device 1
12drv swrast 12gbm 12drv crocus 12surfaceless 12drv crocus 12inactive wayland,x11
12API OpenGL 12v 4.6 12compat-v 4.5 12vendor mesa 12v 25.1.4-arch1.1 12note incomplete
(EGL sourced) 12renderer Mesa Intel HD Graphics 405 (BSW), llvmpipe (LLVM
20.1.6 128 bits)
12API Vulkan 12Message No Vulkan data available.
12Info 12Tools 12api clinfo, eglinfo, glxinfo, vulkaninfo
12de kscreen-console,kscreen-doctor 12wl wayland-info 12x11 xdpyinfo, xprop, xrandr
12Audio:
12Device-1 Intel Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series
High Definition Audio 12vendor Acer Incorporated ALI 12driver snd_hda_intel
12v kernel 12bus-ID 00:1b.0 12chip-ID 8086:2284 12class-ID 0403
12API ALSA 12v k6.10.13-3-MANJARO 12status kernel-api 12with aoss 12type oss-emulator
12tools alsactl,alsamixer,amixer
12Server-1 JACK 12v 1.9.22 12status off 12tools N/A
12Server-2 PipeWire 12v 1.4.5 12status off 12with pipewire-media-session 12status off
12tools pw-cli
12Server-3 PulseAudio 12v 17.0-43-g3e2bb 12status off 12with 121 pulseaudio-alsa
12type plugin 122 pulseaudio-jack 12type module 12tools pacat,pactl
12Network:
12Device-1 Intel Wireless 7265 12driver iwlwifi 12v kernel 12pcie 12gen 1
12speed 2.5 GT/s 12lanes 1 12bus-ID 02:00.0 12chip-ID 8086:095a 12class-ID 0280
12IF wlp2s0 12state up 12mac <filter>
12IP v4 <filter> 12type dynamic noprefixroute 12scope global 12broadcast <filter>
12IP v6 <filter> 12type dynamic noprefixroute 12scope global
12IP v6 <filter> 12type noprefixroute 12scope link
12Info 12services No services found.
12WAN IP <filter>
12Bluetooth:
12Device-1 Intel Bluetooth wireless interface 12driver btusb 12v 0.8 12type USB
12rev 2.0 12speed 12 Mb/s 12lanes 1 12mode 1.1 12bus-ID 1-5:4 12chip-ID 8087:0a2a
12class-ID e001
12Report rfkill 12ID hci0 12rfk-id 2 12state down 12bt-service N/A 12rfk-block
12hardware no 12software no 12address see --recommends
12Logical:
12Message No logical block device data found.
12RAID:
12Message No RAID data found.
12Drives:
12Local Storage 12total 261.53 GiB 12used 69.86 GiB (26.7%)
12ID-1 /dev/sda 12maj-min 8:0 12vendor Samsung 12model SSD 840 EVO 250GB
12family based SSDs 12size 232.89 GiB 12block-size 12physical 512 B 12logical 512 B
12sata 3.1 12speed 6.0 Gb/s 12tech SSD 12serial <filter> 12fw-rev CB6Q 12temp 34 C
12SMART yes 12state enabled 12health PASSED 12on 142d 8h 12cycles 2755
12written 5.16 TiB
12ID-2 /dev/sdb 12maj-min 8:16 12vendor SanDisk 12model Ultra Fit 12size 28.64 GiB
12block-size 12physical 512 B 12logical 512 B 12type USB 12rev 3.0 12spd 5 Gb/s 12lanes 1
12mode 3.2 gen-1x1 12tech N/A 12serial <filter> 12fw-rev 1.00
12SMART Message Unknown USB bridge. Flash drive/Unsupported enclosure?
12Message No optical or floppy data found.
12Partition:
12ID-1 / 12raw-size 100 GiB 12size 97.87 GiB (97.87%) 12used 69.86 GiB (71.4%)
12fs ext4 12block-size 4096 B 12dev /dev/dm-0 12maj-min 254:0 12mapped tmp 12label N/A
12uuid N/A
12Swap:
12Alert No swap data was found.
12Unmounted:
12ID-1 /dev/sda1 12maj-min 8:1 12size 300 MiB 12fs fat (32 bit) 12label N/A
12uuid EF2D-725F
12ID-2 /dev/sda2 12maj-min 8:2 12size 100 GiB 12fs N/A 12label N/A
12uuid 29fdfcca-132c-4086-817d-32213e24c3be
12ID-3 /dev/sda3 12maj-min 8:3 12size 132.59 GiB 12fs N/A 12label N/A
12uuid fe92912b-e39a-45aa-8ca5-80c32bcf2563
12ID-4 /dev/sdb1 12maj-min 8:17 12size 3.87 GiB 12fs N/A 12label MANJARO_KDE_2412
12uuid 2024-11-04-04-24-27-00
12ID-5 /dev/sdb2 12maj-min 8:18 12size 4 MiB 12fs N/A 12label MISO_EFI 12uuid 8BF0-EDB3
12USB:
12Hub-1 1-0:1 12info hi-speed hub with single TT 12ports 7 12rev 2.0
12speed 480 Mb/s (57.2 MiB/s) 12lanes 1 12mode 2.0 12chip-ID 1d6b:0002 12class-ID 0900
12Device-1 1-3:2 12info Realtek RTS5129 Card Reader Controller
12type <vendor specific> 12driver rtsx_usb,rtsx_usb_ms,rtsx_usb_sdmmc
12interfaces 1 12rev 2.0 12speed 480 Mb/s (57.2 MiB/s) 12lanes 1 12mode 2.0
12power 500mA 12chip-ID 0bda:0129 12class-ID ff00 12serial <filter>
12Device-2 1-4:3 12info Chicony HD WebCam 12type video 12driver uvcvideo
12interfaces 2 12rev 2.0 12speed 480 Mb/s (57.2 MiB/s) 12lanes 1 12mode 2.0 12power 500mA
12Device-3 1-5:4 12info Intel Bluetooth wireless interface 12type bluetooth
12driver btusb 12interfaces 2 12rev 2.0 12speed 12 Mb/s (1.4 MiB/s) 12lanes 1 12mode 1.1
12power 100mA 12chip-ID 8087:0a2a 12class-ID e001
12Hub-2 2-0:1 12info super-speed hub 12ports 6 12rev 3.0 12speed 5 Gb/s (596.0 MiB/s)
12lanes 1 12mode 3.2 gen-1x1 12chip-ID 1d6b:0003 12class-ID 0900
12Device-1 2-1:2 12info SanDisk Ultra Fit 12type mass storage 12driver usb-storage
12interfaces 1 12rev 3.0 12speed 5 Gb/s (596.0 MiB/s) 12lanes 1 12mode 3.2 gen-1x1
12power 896mA 12chip-ID 0781:5583 12class-ID 0806 12serial <filter>
12Sensors:
12System Temperatures 12cpu 53.0 C 12mobo N/A
12Fan Speeds (rpm) N/A
12Repos:
12Packages 1656 12pm pacman 12pkgs 1651 12libs 430 12tools pamac 12pm flatpak 12pkgs 5
12Active pacman repo servers in /etc/pacman.d/mirrorlist
121 https: //www.mirrorservice.org/sites/repo.manjaro.org/repos/stable/$repo/$arch
122 https: //mirrors.ft.uam.es/manjaro/stable/$repo/$arch
123 https: //ftp.lysator.liu.se/pub/manjaro/stable/$repo/$arch
124 https: //fastmirror.pp.ua/manjaro/stable/$repo/$arch
125 https: //volico.mm.fcix.net/manjaro/stable/$repo/$arch
126 https: //edgeuno-bog2.mm.fcix.net/manjaro/stable/$repo/$arch
127 https: //mirror.freedif.org/Manjaro/stable/$repo/$arch
128 https: //mirror.kamtv.ru/manjaro/stable/$repo/$arch
12Processes:
12Message No process data available.
12Info:
12Processes 0 12Power 12uptime 21m 12states freeze,mem,disk 12suspend deep 12avail s2idle
12wakeups 0 12hibernate platform 12avail shutdown, reboot, suspend, test_resume
12image 1.45 GiB 12Init systemd 12v 257 12default graphical 12tool systemctl
12Compilers 12clang 20.1.6 12gcc 15.1.1 12Client systemd 12inxi 3.3.38
