An update to this issue:
After reporting this glitch to the mesa devs, there were updates made to the mesa master branch to try fix the issue (see https://gitlab.freedesktop.org/mesa/mesa/-/issues/4157). The latest mesa master branch seems better, but I still get pretty much the same issues with the missing letters and glitches when it tries to draw what’s supposed to be on the screen. One of the devs there thought that my dmesg reflected a S922 coherency issue (I attach the full dmesg below - error messages reflect more than the graphics as the ethernet/wifi sometimes intermittently drops also). They were saying these issues were in 5.10 but fixed in 5.11.
[aurion@neurofire ~]$ dmesg
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[ 0.000000] Linux version 5.10.5-1-MANJARO-ARM (spikerguy@Manjaro-Beelink) (gcc (GCC) 10.2.0, GNU ld (GNU Binutils) 2.35) #1 SMP PREEMPT Tue Jan 12 21:01:04 +03 2021
[ 0.000000] Machine model: Khadas VIM3
[ 0.000000] efi: UEFI not found.
[ 0.000000] Reserved memory: created CMA memory pool at 0x00000000e0800000, size 256 MiB
[ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000000000000-0x000000003fffffff]
[ 0.000000] DMA32 [mem 0x0000000040000000-0x00000000f4ffffff]
[ 0.000000] Normal empty
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000000000000-0x0000000004ffffff]
[ 0.000000] node 0: [mem 0x0000000005300000-0x00000000f4ffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x00000000f4ffffff]
[ 0.000000] On node 0 totalpages: 1002752
[ 0.000000] DMA zone: 4096 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 261376 pages, LIFO batch:63
[ 0.000000] DMA32 zone: 11584 pages used for memmap
[ 0.000000] DMA32 zone: 741376 pages, LIFO batch:63
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.1
[ 0.000000] percpu: Embedded 23 pages/cpu s54616 r8192 d31400 u94208
[ 0.000000] pcpu-alloc: s54616 r8192 d31400 u94208 alloc=23*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5
[ 0.000000] Detected VIPT I-cache on CPU0
[ 0.000000] CPU features: detected: ARM erratum 845719
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 987072
[ 0.000000] Kernel command line: root=LABEL=ROOT_MNJRO rootflags=data=writeback rw console=ttyAML0,115200n8 console=tty0 no_console_suspend consoleblank=0 fsck.fix=yes fsck.repair=yes net.ifnames=0 bootsplash.bootfile=bootsplash-themes/manjaro/bootsplash
[ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] software IO TLB: mapped [mem 0x000000003bfff000-0x000000003ffff000] (64MB)
[ 0.000000] Memory: 3564608K/4011008K available (17088K kernel code, 2432K rwdata, 6560K rodata, 3776K init, 974K bss, 184256K reserved, 262144K cma-reserved)
[ 0.000000] random: get_random_u64 called from cache_random_seq_create+0x84/0x180 with crng_init=0
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=6.
[ 0.000000] Trampoline variant of Tasks RCU enabled.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=6
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] irq_meson_gpio: 100 to 8 gpio interrupt mux initialized
[ 0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[ 0.000004] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[ 0.000240] Console: colour dummy device 80x25
[ 0.000593] printk: console [tty0] enabled
[ 0.000636] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[ 0.000658] pid_max: default: 32768 minimum: 301
[ 0.000784] LSM: Security Framework initializing
[ 0.000842] SELinux: Initializing.
[ 0.000965] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.000993] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.002720] rcu: Hierarchical SRCU implementation.
[ 0.005008] EFI services will not be available.
[ 0.005379] smp: Bringing up secondary CPUs ...
[ 0.006005] Detected VIPT I-cache on CPU1
[ 0.006064] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[ 0.007199] CPU features: detected: ARM erratum 858921
[ 0.007207] CPU features: detected: Spectre-v2
[ 0.007211] CPU features: detected: Spectre-v4
[ 0.007217] Detected VIPT I-cache on CPU2
[ 0.007241] arch_timer: Enabling local workaround for ARM erratum 858921
[ 0.007254] arch_timer: CPU2: Trapping CNTVCT access
[ 0.007266] CPU2: Booted secondary processor 0x0000000100 [0x410fd092]
[ 0.007861] Detected VIPT I-cache on CPU3
[ 0.007876] arch_timer: Enabling local workaround for ARM erratum 858921
[ 0.007883] arch_timer: CPU3: Trapping CNTVCT access
[ 0.007890] CPU3: Booted secondary processor 0x0000000101 [0x410fd092]
[ 0.008457] Detected VIPT I-cache on CPU4
[ 0.008473] arch_timer: Enabling local workaround for ARM erratum 858921
[ 0.008479] arch_timer: CPU4: Trapping CNTVCT access
[ 0.008487] CPU4: Booted secondary processor 0x0000000102 [0x410fd092]
[ 0.009060] Detected VIPT I-cache on CPU5
[ 0.009076] arch_timer: Enabling local workaround for ARM erratum 858921
[ 0.009082] arch_timer: CPU5: Trapping CNTVCT access
[ 0.009090] CPU5: Booted secondary processor 0x0000000103 [0x410fd092]
[ 0.009164] smp: Brought up 1 node, 6 CPUs
[ 0.009328] SMP: Total of 6 processors activated.
[ 0.009341] CPU features: detected: 32-bit EL0 Support
[ 0.009354] CPU features: detected: CRC32 instructions
[ 0.009365] CPU features: detected: 32-bit EL1 Support
[ 0.023245] CPU: All CPU(s) started at EL2
[ 0.023312] alternatives: patching kernel code
[ 0.024937] devtmpfs: initialized
[ 0.032083] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.032115] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
[ 0.036114] pinctrl core: initialized pinctrl subsystem
[ 0.036499] DMI not present or invalid.
[ 0.036784] NET: Registered protocol family 16
[ 0.037984] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
[ 0.038162] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.038394] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.038456] audit: initializing netlink subsys (disabled)
[ 0.038563] audit: type=2000 audit(0.030:1): state=initialized audit_enabled=0 res=1
[ 0.039495] thermal_sys: Registered thermal governor 'step_wise'
[ 0.039766] cpuidle: using governor ladder
[ 0.039819] cpuidle: using governor menu
[ 0.039927] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.040028] ASID allocator initialised with 65536 entries
[ 0.040866] Serial: AMBA PL011 UART driver
[ 0.065444] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.065468] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[ 0.065478] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.065487] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[ 0.066902] cryptd: max_cpu_qlen set to 1000
[ 0.229877] raid6: neonx8 gen() 2793 MB/s
[ 0.399963] raid6: neonx8 xor() 2060 MB/s
[ 0.570017] raid6: neonx4 gen() 3129 MB/s
[ 0.740074] raid6: neonx4 xor() 2333 MB/s
[ 0.910142] raid6: neonx2 gen() 2628 MB/s
[ 1.080204] raid6: neonx2 xor() 2179 MB/s
[ 1.250288] raid6: neonx1 gen() 1919 MB/s
[ 1.420333] raid6: neonx1 xor() 1727 MB/s
[ 1.590408] raid6: int64x8 gen() 1355 MB/s
[ 1.760457] raid6: int64x8 xor() 716 MB/s
[ 1.930521] raid6: int64x4 gen() 1439 MB/s
[ 2.100596] raid6: int64x4 xor() 699 MB/s
[ 2.270656] raid6: int64x2 gen() 1341 MB/s
[ 2.440726] raid6: int64x2 xor() 611 MB/s
[ 2.610782] raid6: int64x1 gen() 1112 MB/s
[ 2.780850] raid6: int64x1 xor() 454 MB/s
[ 2.780859] raid6: using algorithm neonx4 gen() 3129 MB/s
[ 2.780867] raid6: .... xor() 2333 MB/s, rmw enabled
[ 2.780874] raid6: using neon recovery algorithm
[ 2.781026] ACPI: Interpreter disabled.
[ 2.782122] VSYS_3V3: supplied by DC_IN
[ 2.782379] iommu: Default domain type: Translated
[ 2.782552] vgaarb: loaded
[ 2.782898] SCSI subsystem initialized
[ 2.783067] libata version 3.00 loaded.
[ 2.783199] usbcore: registered new interface driver usbfs
[ 2.783231] usbcore: registered new interface driver hub
[ 2.783284] usbcore: registered new device driver usb
[ 2.783511] pps_core: LinuxPPS API ver. 1 registered
[ 2.783520] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 2.783537] PTP clock support registered
[ 2.783561] EDAC MC: Ver: 3.0.0
[ 2.784074] FPGA manager framework
[ 2.784126] Advanced Linux Sound Architecture Driver Initialized.
[ 2.784474] NetLabel: Initializing
[ 2.784484] NetLabel: domain hash size = 128
[ 2.784492] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO
[ 2.784532] NetLabel: unlabeled traffic allowed by default
[ 2.784736] clocksource: Switched to clocksource arch_sys_counter
[ 2.784876] VFS: Disk quotas dquot_6.6.0
[ 2.784918] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 2.784987] FS-Cache: Loaded
[ 2.785187] pnp: PnP ACPI: disabled
[ 2.788601] NET: Registered protocol family 2
[ 2.788985] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
[ 2.789042] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 2.789193] TCP bind hash table entries: 32768 (order: 7, 524288 bytes, linear)
[ 2.789386] TCP: Hash tables configured (established 32768 bind 32768)
[ 2.789479] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
[ 2.789521] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
[ 2.789671] NET: Registered protocol family 1
[ 2.789993] RPC: Registered named UNIX socket transport module.
[ 2.790004] RPC: Registered udp transport module.
[ 2.790012] RPC: Registered tcp transport module.
[ 2.790019] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 2.790032] PCI: CLS 0 bytes, default 64
[ 2.790168] Trying to unpack rootfs image as initramfs...
[ 3.025756] Freeing initrd memory: 6820K
[ 3.026412] kvm [1]: IPA Size Limit: 40 bits
[ 3.027189] kvm [1]: vgic interrupt IRQ9
[ 3.027319] kvm [1]: Hyp mode initialized successfully
[ 3.032209] Initialise system trusted keyrings
[ 3.032320] workingset: timestamp_bits=46 max_order=20 bucket_order=0
[ 3.035385] zbud: loaded
[ 3.036223] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 3.036394] FS-Cache: Netfs 'nfs' registered for caching
[ 3.036755] NFS: Registering the id_resolver key type
[ 3.036779] Key type id_resolver registered
[ 3.036787] Key type id_legacy registered
[ 3.036847] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 3.036857] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[ 3.037559] FS-Cache: Netfs 'cifs' registered for caching
[ 3.037722] Key type cifs.spnego registered
[ 3.037737] Key type cifs.idmap registered
[ 3.037748] ntfs: driver 2.1.32 [Flags: R/W].
[ 3.038091] JFS: nTxBlock = 8192, nTxLock = 65536
[ 3.041013] SGI XFS with ACLs, security attributes, realtime, quota, no debug enabled
[ 3.042102] ocfs2: Registered cluster interface o2cb
[ 3.042245] OCFS2 User DLM kernel interface loaded
[ 3.043348] gfs2: GFS2 installed
[ 3.072286] xor: measuring software checksum speed
[ 3.075146] 8regs : 3467 MB/sec
[ 3.077556] 32regs : 4096 MB/sec
[ 3.080231] arm64_neon : 3688 MB/sec
[ 3.080239] xor: using function: 32regs (4096 MB/sec)
[ 3.080253] Key type asymmetric registered
[ 3.080261] Asymmetric key parser 'x509' registered
[ 3.080268] Asymmetric key parser 'pkcs8' registered
[ 3.080299] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[ 3.080411] io scheduler mq-deadline registered
[ 3.080421] io scheduler kyber registered
[ 3.080494] io scheduler bfq registered
[ 3.092989] soc soc0: Amlogic Meson G12B (A311D) Revision 29:b (10:2) Detected
[ 3.094310] VCC_3V3: supplied by VSYS_3V3
[ 3.094349] VCC_1V8: supplied by VCC_3V3
[ 3.094383] VDDIO_AO1V8: supplied by VSYS_3V3
[ 3.094428] EMMC_AO1V8: supplied by VCC_3V3
[ 3.094462] VDDCPU_A: supplied by regulator-dummy
[ 3.094757] VDDCPU_B: supplied by regulator-dummy
[ 3.097326] Serial: 8250/16550 driver, 5 ports, IRQ sharing enabled
[ 3.098554] Serial: AMBA driver
[ 3.098777] ff803000.serial: ttyAML0 at MMIO 0xff803000 (irq = 22, base_baud = 1500000) is a meson_uart
[ 4.210669] printk: console [ttyAML0] enabled
[ 4.215434] ffd24000.serial: ttyAML6 at MMIO 0xffd24000 (irq = 29, base_baud = 1500000) is a meson_uart
[ 4.224355] serial serial0: tty port ttyAML6 registered
[ 4.233051] panfrost ffe40000.gpu: clock rate = 24000000
[ 4.234793] panfrost ffe40000.gpu: dev_pm_opp_set_regulators: no regulator (mali) found: -19
[ 4.243762] panfrost ffe40000.gpu: mali-g52 id 0x7212 major 0x0 minor 0x0 status 0x0
[ 4.250775] panfrost ffe40000.gpu: features: 00000000,13de77ff, issues: 00000000,00000400
[ 4.258893] panfrost ffe40000.gpu: Features: L2:0x07110206 Shader:0x00000000 Tiler:0x00000809 Mem:0x1 MMU:0x00002830 AS:0xff JS:0x7
[ 4.270617] panfrost ffe40000.gpu: shader_present=0x3 l2_present=0x1
[ 4.291404] [drm] Initialized panfrost 1.1.0 20180908 for ffe40000.gpu on minor 0
[ 4.299116] brd: module loaded
[ 4.304463] loop: module loaded
[ 4.306540] libphy: Fixed MDIO Bus: probed
[ 4.308241] VFIO - User Level meta-driver version: 0.3
[ 4.312086] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 4.317624] ehci-pci: EHCI PCI platform driver
[ 4.322019] ehci-platform: EHCI generic platform driver
[ 4.327302] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 4.333300] ohci-pci: OHCI PCI platform driver
[ 4.337725] ohci-platform: OHCI generic platform driver
[ 4.343243] usbcore: registered new interface driver usb-storage
[ 4.348948] mousedev: PS/2 mouse device common for all mice
[ 4.354754] i2c /dev entries driver
[ 4.358429] pca953x 0-0020: using no AI
[ 4.367793] cpufreq: cpufreq_online: CPU2: Running at unlisted initial frequency: 999999 KHz, changing to: 1000000 KHz
[ 4.373925] sdhci: Secure Digital Host Controller Interface driver
[ 4.379116] sdhci: Copyright(c) Pierre Ossman
[ 4.383265] Synopsys Designware Multimedia Card Interface Driver
[ 4.389484] sdhci-pltfm: SDHCI platform and OF driver helper
[ 4.389803] meson-gx-mmc ffe03000.sd: allocated mmc-pwrseq
[ 4.389814] meson-gx-mmc ffe05000.sd: Got CD GPIO
[ 4.390397] meson-gx-mmc ffe07000.mmc: allocated mmc-pwrseq
[ 4.410444] ledtrig-cpu: registered to indicate activity on CPUs
[ 4.416499] meson-sm: secure-monitor enabled
[ 4.420692] hid: raw HID events driver (C) Jiri Kosina
[ 4.425987] usbcore: registered new interface driver usbhid
[ 4.431231] usbhid: USB HID core driver
[ 4.438472] Initializing XFRM netlink socket
[ 4.439396] NET: Registered protocol family 10
[ 4.451700] Segment Routing with IPv6
[ 4.451972] NET: Registered protocol family 17
[ 4.454216] Key type dns_resolver registered
[ 4.458697] registered taskstats version 1
[ 4.462427] Loading compiled-in X.509 certificates
[ 4.467227] zswap: loaded using pool lzo/zbud
[ 4.470818] mmc0: queuing unknown CIS tuple 0x80 (2 bytes)
[ 4.471671] Key type ._fscrypt registered
[ 4.478986] mmc0: queuing unknown CIS tuple 0x80 (3 bytes)
[ 4.480875] Key type .fscrypt registered
[ 4.488391] mmc0: queuing unknown CIS tuple 0x80 (3 bytes)
[ 4.490195] Key type fscrypt-provisioning registered
[ 4.499426] mmc0: queuing unknown CIS tuple 0x80 (7 bytes)
[ 4.500881] Btrfs loaded, crc32c=crc32c-generic
[ 4.510549] mmc0: queuing unknown CIS tuple 0x81 (9 bytes)
[ 4.514275] Key type encrypted registered
[ 4.520467] mmc0: queuing unknown CIS tuple 0x8e (9 bytes)
[ 4.527866] VCC_5V: supplied by DC_IN
[ 4.529165] USB_PWR: supplied by VCC_5V
[ 4.578077] meson-drm ff900000.vpu: Queued 2 outputs on vpu
[ 4.578386] meson-drm ff900000.vpu: CVBS Output connector not available
[ 4.585274] random: fast init done
[ 4.593634] mmc0: new high speed SDIO card at address 0001
[ 4.634746] meson-dw-hdmi ff600000.hdmi-tx: Detected HDMI TX controller v2.01a with HDCP (meson_dw_hdmi_phy)
[ 4.639095] meson-dw-hdmi ff600000.hdmi-tx: registered DesignWare HDMI I2C bus driver
[ 4.647001] meson-drm ff900000.vpu: bound ff600000.hdmi-tx (ops meson_dw_hdmi_ops)
[ 4.654404] [drm] Initialized meson 1.0.0 20161109 for ff900000.vpu on minor 1
[ 4.665876] mmc2: new HS200 MMC card at address 0001
[ 4.666543] mmcblk2: mmc2:0001 BJTD4R 29.1 GiB
[ 4.670875] mmcblk2boot0: mmc2:0001 BJTD4R partition 1 4.00 MiB
[ 4.676764] mmcblk2boot1: mmc2:0001 BJTD4R partition 2 4.00 MiB
[ 4.682539] mmcblk2rpmb: mmc2:0001 BJTD4R partition 3 4.00 MiB, chardev (243:0)
[ 4.690606] mmcblk2: p1 p2
[ 5.008719] Console: switching to colour frame buffer device 240x67
[ 5.023313] meson-drm ff900000.vpu: [drm] fb0: mesondrmfb frame buffer device
[ 5.030881] meson8b-dwmac ff3f0000.ethernet: IRQ eth_wake_irq not found
[ 5.036942] meson8b-dwmac ff3f0000.ethernet: IRQ eth_lpi not found
[ 5.043144] meson8b-dwmac ff3f0000.ethernet: PTP uses main clock
[ 5.049419] meson8b-dwmac ff3f0000.ethernet: User ID: 0x11, Synopsys ID: 0x37
[ 5.056093] meson8b-dwmac ff3f0000.ethernet: DWMAC1000
[ 5.061261] meson8b-dwmac ff3f0000.ethernet: DMA HW capability register supported
[ 5.068682] meson8b-dwmac ff3f0000.ethernet: RX Checksum Offload Engine supported
[ 5.076101] meson8b-dwmac ff3f0000.ethernet: COE Type 2
[ 5.081270] meson8b-dwmac ff3f0000.ethernet: TX Checksum insertion supported
[ 5.088259] meson8b-dwmac ff3f0000.ethernet: Wake-Up On Lan supported
[ 5.094663] meson8b-dwmac ff3f0000.ethernet: Normal descriptors
[ 5.100506] meson8b-dwmac ff3f0000.ethernet: Ring mode enabled
[ 5.106287] meson8b-dwmac ff3f0000.ethernet: Enable RX Mitigation via HW Watchdog Timer
[ 5.114349] libphy: stmmac: probed
[ 5.118253] dwc3-meson-g12a ffe09000.usb: USB2 ports: 2
[ 5.122757] dwc3-meson-g12a ffe09000.usb: USB3 ports: 1
[ 5.130549] dwc2 ff400000.usb: supply vusb_d not found, using dummy regulator
[ 5.135044] dwc2 ff400000.usb: supply vusb_a not found, using dummy regulator
[ 5.142150] dwc2 ff400000.usb: EPs: 7, dedicated fifos, 712 entries in SPRAM
[ 5.149508] xhci-hcd xhci-hcd.3.auto: xHCI Host Controller
[ 5.154503] xhci-hcd xhci-hcd.3.auto: new USB bus registered, assigned bus number 1
[ 5.162173] xhci-hcd xhci-hcd.3.auto: hcc params 0x0228fe6c hci version 0x110 quirks 0x0000000000010010
[ 5.171418] xhci-hcd xhci-hcd.3.auto: irq 38, io mem 0xff500000
[ 5.177379] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[ 5.185464] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 5.192619] usb usb1: Product: xHCI Host Controller
[ 5.197454] usb usb1: Manufacturer: Linux 5.10.5-1-MANJARO-ARM xhci-hcd
[ 5.204003] usb usb1: SerialNumber: xhci-hcd.3.auto
[ 5.208990] hub 1-0:1.0: USB hub found
[ 5.212550] hub 1-0:1.0: 2 ports detected
[ 5.216612] xhci-hcd xhci-hcd.3.auto: xHCI Host Controller
[ 5.221946] xhci-hcd xhci-hcd.3.auto: new USB bus registered, assigned bus number 2
[ 5.229543] xhci-hcd xhci-hcd.3.auto: Host supports USB 3.0 SuperSpeed
[ 5.236022] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[ 5.244046] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
[ 5.252220] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 5.259380] usb usb2: Product: xHCI Host Controller
[ 5.264206] usb usb2: Manufacturer: Linux 5.10.5-1-MANJARO-ARM xhci-hcd
[ 5.270763] usb usb2: SerialNumber: xhci-hcd.3.auto
[ 5.275721] hub 2-0:1.0: USB hub found
[ 5.279306] hub 2-0:1.0: 1 port detected
[ 5.284629] printk: console [netcon0] enabled
[ 5.287503] netconsole: network logging started
[ 5.292281] ALSA device list:
[ 5.294917] No soundcards found.
[ 5.299079] Freeing unused kernel memory: 3776K
[ 5.324777] Run /init as init process
[ 5.326408] with arguments:
[ 5.326410] /init
[ 5.326412] with environment:
[ 5.326413] HOME=/
[ 5.326415] TERM=linux
[ 5.447303] input: gpio-keys-polled as /devices/platform/gpio-keys-polled/input/input0
[ 5.451656] input: adc-keys as /devices/platform/adc-keys/input/input1
[ 5.594745] usb 1-1: new high-speed USB device number 2 using xhci-hcd
[ 5.774930] usb 1-1: New USB device found, idVendor=1a40, idProduct=0801, bcdDevice= 1.00
[ 5.778760] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 5.785837] usb 1-1: Product: USB 2.0 Hub
[ 5.844125] hub 1-1:1.0: USB hub found
[ 5.845464] hub 1-1:1.0: 4 ports detected
[ 5.905072] EXT4-fs (mmcblk2p2): mounted filesystem with writeback data mode. Opts: data=writeback
[ 5.944840] usb 2-1: new SuperSpeed Gen 1 USB device number 2 using xhci-hcd
[ 5.975751] usb 2-1: New USB device found, idVendor=090c, idProduct=1000, bcdDevice=11.00
[ 5.981642] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 5.988722] usb 2-1: Product: Flash Drive FIT
[ 5.993041] usb 2-1: Manufacturer: Samsung
[ 5.997073] usb 2-1: SerialNumber: 0373820080000937
[ 6.002727] usb-storage 2-1:1.0: USB Mass Storage device detected
[ 6.008249] usb-storage 2-1:1.0: Quirks match for vid 090c pid 1000: 400
[ 6.014648] scsi host0: usb-storage 2-1:1.0
[ 6.087185] systemd[1]: System time before build time, advancing clock.
[ 6.116410] systemd[1]: systemd 247.2-1-arch running in system mode. (+PAM +AUDIT -SELINUX -IMA -APPARMOR +SMACK -SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +ZSTD +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=hybrid)
[ 6.136518] systemd[1]: Detected architecture arm64.
[ 6.164749] usb 1-1.2: new high-speed USB device number 3 using xhci-hcd
[ 6.250844] systemd[1]: Set hostname to <neurofire>.
[ 6.297936] usb 1-1.2: New USB device found, idVendor=1a40, idProduct=0101, bcdDevice= 1.11
[ 6.302456] usb 1-1.2: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 6.309705] usb 1-1.2: Product: USB 2.0 Hub
[ 6.356186] hub 1-1.2:1.0: USB hub found
[ 6.358349] hub 1-1.2:1.0: 4 ports detected
[ 6.426846] systemd[1]: Configuration file /usr/lib/systemd/system/sound.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 6.453728] systemd[1]: Configuration file /usr/lib/systemd/system/bluetooth-khadas.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 6.467944] systemd[1]: Queued start job for default target Graphical Interface.
[ 6.473163] random: systemd: uninitialized urandom read (16 bytes read)
[ 6.494099] systemd[1]: Created slice system-getty.slice.
[ 6.498065] random: systemd: uninitialized urandom read (16 bytes read)
[ 6.502562] systemd[1]: Created slice system-modprobe.slice.
[ 6.509564] random: systemd: uninitialized urandom read (16 bytes read)
[ 6.514680] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ 6.522700] systemd[1]: Created slice User and Session Slice.
[ 6.528884] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ 6.536151] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 6.543516] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 6.552727] systemd[1]: Reached target Local Encrypted Volumes.
[ 6.558625] systemd[1]: Reached target Paths.
[ 6.563215] systemd[1]: Reached target Remote Encrypted Volumes.
[ 6.569249] systemd[1]: Reached target Remote File Systems.
[ 6.574372] systemd[1]: Reached target Slices.
[ 6.578909] systemd[1]: Reached target Swap.
[ 6.583155] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[ 6.589623] systemd[1]: Listening on LVM2 metadata daemon socket.
[ 6.596313] systemd[1]: Listening on LVM2 poll daemon socket.
[ 6.603464] systemd[1]: Listening on Process Core Dump Socket.
[ 6.608188] systemd[1]: Listening on Journal Audit Socket.
[ 6.613068] systemd[1]: Listening on Journal Socket (/dev/log).
[ 6.619295] systemd[1]: Listening on Journal Socket.
[ 6.624200] systemd[1]: Listening on Network Service Netlink Socket.
[ 6.630563] systemd[1]: Listening on udev Control Socket.
[ 6.635832] systemd[1]: Listening on udev Kernel Socket.
[ 6.640783] systemd[1]: Listening on User Database Manager Socket.
[ 6.648500] systemd[1]: Mounting Huge Pages File System...
[ 6.655129] systemd[1]: Mounting POSIX Message Queue File System...
[ 6.661040] systemd[1]: Mounting Kernel Debug File System...
[ 6.665854] systemd[1]: Condition check resulted in Kernel Trace File System being skipped.
[ 6.673284] systemd[1]: Mounting Temporary Directory (/tmp)...
[ 6.679817] systemd[1]: Condition check resulted in Load AppArmor profiles being skipped.
[ 6.686945] systemd[1]: Starting Create list of static device nodes for the current kernel...
[ 6.697976] systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
[ 6.708713] systemd[1]: Starting Load Kernel Module configfs...
[ 6.715066] systemd[1]: Starting Load Kernel Module drm...
[ 6.721828] systemd[1]: Starting Load Kernel Module fuse...
[ 6.726762] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[ 6.732919] fuse: init (API version 7.32)
[ 6.735132] systemd[1]: Starting Load Kernel Modules...
[ 6.745995] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 6.752595] systemd[1]: Condition check resulted in Repartition Root Disk being skipped.
[ 6.759299] systemd[1]: Starting Coldplug All udev Devices...
[ 6.768435] systemd[1]: Mounted Huge Pages File System.
[ 6.772511] systemd[1]: Mounted POSIX Message Queue File System.
[ 6.775849] usb 1-1.2.1: new low-speed USB device number 4 using xhci-hcd
[ 6.785256] systemd[1]: Mounted Kernel Debug File System.
[ 6.790500] systemd[1]: Mounted Temporary Directory (/tmp).
[ 6.796661] systemd[1]: Finished Create list of static device nodes for the current kernel.
[ 6.805193] systemd[1]: modprobe@configfs.service: Succeeded.
[ 6.808095] systemd[1]: Finished Load Kernel Module configfs.
[ 6.815537] systemd[1]: modprobe@drm.service: Succeeded.
[ 6.819003] systemd[1]: Finished Load Kernel Module drm.
[ 6.826399] systemd[1]: modprobe@fuse.service: Succeeded.
[ 6.829622] systemd[1]: Finished Load Kernel Module fuse.
[ 6.837455] systemd[1]: Finished Load Kernel Modules.
[ 6.842003] systemd[1]: Finished Remount Root and Kernel File Systems.
[ 6.851871] systemd[1]: Mounting FUSE Control File System...
[ 6.857580] systemd[1]: Mounting Kernel Configuration File System...
[ 6.862232] systemd[1]: Condition check resulted in First Boot Wizard being skipped.
[ 6.868630] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
[ 6.876345] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped.
[ 6.887379] systemd[1]: Starting Load/Save Random Seed...
[ 6.894557] systemd[1]: Starting Apply Kernel Variables...
[ 6.899219] systemd[1]: Condition check resulted in Create System Users being skipped.
[ 6.906513] systemd[1]: Starting Create Static Device Nodes in /dev...
[ 6.915652] systemd[1]: Finished Coldplug All udev Devices.
[ 6.921233] systemd[1]: Mounted FUSE Control File System.
[ 6.925735] systemd[1]: Mounted Kernel Configuration File System.
[ 6.932695] systemd[1]: Finished Apply Kernel Variables.
[ 6.938082] systemd[1]: Finished Create Static Device Nodes in /dev.
[ 6.945122] systemd[1]: Started Entropy Daemon based on the HAVEGE algorithm.
[ 6.953204] systemd[1]: Starting Journal Service...
[ 6.960406] systemd[1]: Starting Rule-based Manager for Device Events and Files...
[ 7.019601] systemd[1]: Started Journal Service.
[ 7.019928] usb 1-1.2.1: New USB device found, idVendor=1a2c, idProduct=4c5e, bcdDevice= 1.10
[ 7.029487] usb 1-1.2.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 7.029493] usb 1-1.2.1: Product: USB Keyboard
[ 7.041279] usb 1-1.2.1: Manufacturer: SEMICO
[ 7.047681] audit: type=1130 audit(1608522710.950:2): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=kernel msg='unit=systemd-journald comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 7.091350] audit: type=1130 audit(1608522710.990:3): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=kernel msg='unit=systemd-udevd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 7.122042] audit: type=1130 audit(1608522711.010:4): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=kernel msg='unit=lvm2-lvmetad comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 7.127306] input: SEMICO USB Keyboard as /devices/platform/soc/ffe09000.usb/ff500000.usb/xhci-hcd.3.auto/usb1/1-1/1-1.2/1-1.2.1/1-1.2.1:1.0/0003:1A2C:4C5E.0001/input/input2
[ 7.225675] hid-generic 0003:1A2C:4C5E.0001: input,hidraw0: USB HID v1.10 Keyboard [SEMICO USB Keyboard] on usb-xhci-hcd.3.auto-1.2.1/input0
[ 7.241992] input: SEMICO USB Keyboard Consumer Control as /devices/platform/soc/ffe09000.usb/ff500000.usb/xhci-hcd.3.auto/usb1/1-1/1-1.2/1-1.2.1/1-1.2.1:1.1/0003:1A2C:4C5E.0002/input/input3
[ 7.261288] audit: type=1130 audit(1608522711.160:5): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=kernel msg='unit=systemd-journal-flush comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 7.297702] audit: type=1130 audit(1608522711.200:6): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=kernel msg='unit=systemd-networkd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 7.325379] input: SEMICO USB Keyboard System Control as /devices/platform/soc/ffe09000.usb/ff500000.usb/xhci-hcd.3.auto/usb1/1-1/1-1.2/1-1.2.1/1-1.2.1:1.1/0003:1A2C:4C5E.0002/input/input4
[ 7.339386] input: SEMICO USB Keyboard as /devices/platform/soc/ffe09000.usb/ff500000.usb/xhci-hcd.3.auto/usb1/1-1/1-1.2/1-1.2.1/1-1.2.1:1.1/0003:1A2C:4C5E.0002/input/input6
[ 7.355179] mc: Linux media interface: v0.10
[ 7.356250] hid-generic 0003:1A2C:4C5E.0002: input,hiddev0,hidraw1: USB HID v1.10 Keyboard [SEMICO USB Keyboard] on usb-xhci-hcd.3.auto-1.2.1/input1
[ 7.379378] videodev: Linux video capture interface: v2.00
[ 7.402116] meson_vdec: module is from the staging directory, the quality is unknown, you have been warned.
[ 7.415447] libphy: mdio_mux: probed
[ 7.433284] libphy: mdio_mux: probed
[ 7.445483] rtc-hym8563 0-0051: no valid clock/calendar values available
[ 7.453418] rtc-hym8563 0-0051: registered as rtc0
[ 7.461338] rtc-hym8563 0-0051: no valid clock/calendar values available
[ 7.469309] rtc-hym8563 0-0051: hctosys: unable to read the hardware clock
[ 7.470745] meson-vrtc ff8000a8.rtc: registered as rtc1
[ 7.475063] Registered IR keymap rc-khadas
[ 7.490492] IR NEC protocol handler initialized
[ 7.490513] Bluetooth: Core ver 2.22
[ 7.499600] NET: Registered protocol family 31
[ 7.507289] axg-sound-card sound: ASoC: no DMI vendor name!
[ 7.507955] Bluetooth: HCI device and connection manager initialized
[ 7.518906] Bluetooth: HCI socket layer initialized
[ 7.518916] Bluetooth: L2CAP socket layer initialized
[ 7.518952] Bluetooth: SCO socket layer initialized
[ 7.521611] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 7.534969] rc rc0: meson-ir as /devices/platform/soc/ff800000.bus/ff808000.ir/rc/rc0
[ 7.542129] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 7.550259] rc rc0: lirc_dev: driver meson-ir registered at minor = 0, raw IR receiver, no transmitter
[ 7.564777] usb 1-1.2.4: new low-speed USB device number 5 using xhci-hcd
[ 7.574372] input: meson-ir as /devices/platform/soc/ff800000.bus/ff808000.ir/rc/rc0/input7
[ 7.585518] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[ 7.595056] meson-ir ff808000.ir: receiver initialized
[ 7.595494] cfg80211: failed to load regulatory.db
[ 7.637123] brcmfmac: F1 signature read @0x18000000=0x17294359
[ 7.639904] Bluetooth: HCI UART driver ver 2.3
[ 7.641802] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac4359-sdio for chip BCM4359/9
[ 7.655408] usbcore: registered new interface driver brcmfmac
[ 7.661819] Bluetooth: HCI UART protocol H4 registered
[ 7.661837] Bluetooth: HCI UART protocol BCSP registered
[ 7.662913] Bluetooth: HCI UART protocol LL registered
[ 7.662916] Bluetooth: HCI UART protocol ATH3K registered
[ 7.662945] Bluetooth: HCI UART protocol Three-wire (H5) registered
[ 7.663251] Bluetooth: HCI UART protocol Intel registered
[ 7.663410] Bluetooth: HCI UART protocol Broadcom registered
[ 7.663441] Bluetooth: HCI UART protocol QCA registered
[ 7.663443] Bluetooth: HCI UART protocol AG6XX registered
[ 7.663472] Bluetooth: HCI UART protocol Marvell registered
[ 7.663859] hci_uart_bcm serial0-0: supply vbat not found, using dummy regulator
[ 7.663970] hci_uart_bcm serial0-0: supply vddio not found, using dummy regulator
[ 7.751022] random: crng init done
[ 7.756882] random: 7 urandom warning(s) missed due to ratelimiting
[ 7.782064] audit: type=1130 audit(1608522711.680:7): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=kernel msg='unit=systemd-random-seed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 7.808836] usb 1-1.2.4: New USB device found, idVendor=093a, idProduct=2521, bcdDevice= 1.00
[ 7.808841] usb 1-1.2.4: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[ 7.808843] usb 1-1.2.4: Product: USB OPTICAL MOUSE
[ 7.831074] audit: type=1130 audit(1608522711.740:8): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=kernel msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 7.863672] input: USB OPTICAL MOUSE as /devices/platform/soc/ffe09000.usb/ff500000.usb/xhci-hcd.3.auto/usb1/1-1/1-1.2/1-1.2.4/1-1.2.4:1.0/0003:093A:2521.0003/input/input8
[ 7.876863] hid-generic 0003:093A:2521.0003: input,hidraw2: USB HID v1.11 Mouse [USB OPTICAL MOUSE] on usb-xhci-hcd.3.auto-1.2.4/input0
[ 7.920087] audit: type=1130 audit(1608522711.820:9): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=kernel msg='unit=lvm2-monitor comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 7.982195] audit: type=1130 audit(1608522711.880:10): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=kernel msg='unit=systemd-tmpfiles-setup comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 8.015383] Bluetooth: hci1: BCM: chip id 121
[ 8.016077] audit: type=1127 audit(1608522711.920:11): pid=458 uid=0 auid=4294967295 ses=4294967295 subj=kernel msg=' comm="systemd-update-utmp" exe="/usr/lib/systemd/systemd-update-utmp" hostname=? addr=? terminal=? res=success'
[ 8.020744] Bluetooth: hci1: BCM: features 0x0e
[ 8.047003] Bluetooth: hci1: BCM4359C0
[ 8.052335] Bluetooth: hci1: BCM4359C0 (003.001.006) build 0000
[ 8.057471] Bluetooth: hci1: BCM4359C0 'brcm/BCM4359C0.hcd' Patch
[ 8.314295] zram: Added device: zram0
[ 8.322838] zram0: detected capacity change from 0 to 5894168576
[ 8.375059] Adding 5756020k swap on /dev/zram0. Priority:100 extents:1 across:5756020k SSFS
[ 8.444022] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 8.453840] Bluetooth: BNEP filters: protocol multicast
[ 8.458768] Bluetooth: BNEP socket layer initialized
[ 8.587326] scsi 0:0:0:0: Direct-Access Samsung Flash Drive FIT 1100 PQ: 0 ANSI: 6
[ 8.591866] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 8.597285] sd 0:0:0:0: [sda] 501253132 512-byte logical blocks: (257 GB/239 GiB)
[ 8.604192] sd 0:0:0:0: [sda] Write Protect is off
[ 8.608801] sd 0:0:0:0: [sda] Mode Sense: 43 00 00 00
[ 8.609014] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 8.714871] meson8b-dwmac ff3f0000.ethernet eth0: PHY [0.0:00] driver [RTL8211F Gigabit Ethernet] (irq=39)
[ 8.726896] sda: sda1
[ 8.728200] sd 0:0:0:0: [sda] Attached SCSI removable disk
[ 8.927812] Bluetooth: hci1: BCM43596 UART 37.4MHz AMPAK AP6359S2 CL1.5[Baseline: 0134]
[ 8.930166] Bluetooth: hci1: BCM4359C0 (003.001.006) build 0268
[ 8.934769] meson8b-dwmac ff3f0000.ethernet: Failed to reset the dma
[ 8.942333] meson8b-dwmac ff3f0000.ethernet eth0: stmmac_hw_setup: DMA engine initialization failed
[ 8.951398] meson8b-dwmac ff3f0000.ethernet eth0: stmmac_open: Hw setup failed
[ 8.974655] NET: Registered protocol family 38
[ 8.990337] meson8b-dwmac ff3f0000.ethernet eth0: PHY [0.0:00] driver [RTL8211F Gigabit Ethernet] (irq=39)
[ 9.051961] usbcore: registered new interface driver uas
[ 9.204746] meson8b-dwmac ff3f0000.ethernet: Failed to reset the dma
[ 9.205465] meson8b-dwmac ff3f0000.ethernet eth0: stmmac_hw_setup: DMA engine initialization failed
[ 9.214432] meson8b-dwmac ff3f0000.ethernet eth0: stmmac_open: Hw setup failed
[ 9.239953] meson8b-dwmac ff3f0000.ethernet eth0: PHY [0.0:00] driver [RTL8211F Gigabit Ethernet] (irq=39)
[ 9.454890] meson8b-dwmac ff3f0000.ethernet: Failed to reset the dma
[ 9.455608] meson8b-dwmac ff3f0000.ethernet eth0: stmmac_hw_setup: DMA engine initialization failed
[ 9.464576] meson8b-dwmac ff3f0000.ethernet eth0: stmmac_open: Hw setup failed
[ 9.489555] meson8b-dwmac ff3f0000.ethernet eth0: PHY [0.0:00] driver [RTL8211F Gigabit Ethernet] (irq=39)
[ 9.704771] meson8b-dwmac ff3f0000.ethernet: Failed to reset the dma
[ 9.705482] meson8b-dwmac ff3f0000.ethernet eth0: stmmac_hw_setup: DMA engine initialization failed
[ 9.714449] meson8b-dwmac ff3f0000.ethernet eth0: stmmac_open: Hw setup failed
[ 9.731998] meson8b-dwmac ff3f0000.ethernet eth0: PHY [0.0:00] driver [RTL8211F Gigabit Ethernet] (irq=39)
[ 9.944738] meson8b-dwmac ff3f0000.ethernet: Failed to reset the dma
[ 9.945445] meson8b-dwmac ff3f0000.ethernet eth0: stmmac_hw_setup: DMA engine initialization failed
[ 9.954461] meson8b-dwmac ff3f0000.ethernet eth0: stmmac_open: Hw setup failed
[ 10.054931] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac4359-sdio for chip BCM4359/9
[ 10.057854] brcmfmac: brcmf_c_process_clm_blob: no clm_blob available (err=-2), device may have limited channels available
[ 10.084912] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4359/9 wl0: Jan 19 2018 12:14:30 version 9.87.51.11.8 (a85e25e@shgit) (r) FWID 01-cb5aa0a5
[ 11.004894] ieee80211 phy0: brcmf_dongle_roam: WLC_SET_ROAM_TRIGGER error (-52)
[ 12.133194] kauditd_printk_skb: 45 callbacks suppressed
[ 12.133199] audit: type=1130 audit(1612133648.881:57): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=kernel msg='unit=udisks2 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 12.151907] audit: type=1334 audit(1612133648.901:58): prog-id=16 op=LOAD
[ 12.158510] audit: type=1334 audit(1612133648.911:59): prog-id=17 op=LOAD
[ 12.353301] audit: type=1130 audit(1612133649.101:60): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=kernel msg='unit=upower comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 12.778167] panfrost ffe40000.gpu: js fault, js=1, status=DATA_INVALID_FAULT, head=0x31c7540, tail=0x31c7540
[ 12.782348] panfrost ffe40000.gpu: gpu sched timeout, js=1, config=0x7300, status=0x58, head=0x31c7540, tail=0x31c7540, sched_job=000000006bef8f1e
[ 13.031520] panfrost ffe40000.gpu: js fault, js=1, status=INSTR_INVALID_ENC, head=0x31ca240, tail=0x31ca240
[ 13.035704] panfrost ffe40000.gpu: gpu sched timeout, js=1, config=0x7300, status=0x51, head=0x31ca240, tail=0x31ca240, sched_job=0000000025eea6a8
[ 15.302096] audit: type=1131 audit(1612133652.051:61): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=kernel msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 17.235252] audit: type=1100 audit(1612133653.991:62): pid=930 uid=0 auid=4294967295 ses=4294967295 subj=kernel msg='op=PAM:authentication grantors=pam_shells,pam_faillock,pam_permit,pam_faillock acct="aurion" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
[ 17.254643] audit: type=1101 audit(1612133653.991:63): pid=930 uid=0 auid=4294967295 ses=4294967295 subj=kernel msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="aurion" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
[ 17.278365] audit: type=1103 audit(1612133653.991:64): pid=930 uid=0 auid=4294967295 ses=4294967295 subj=kernel msg='op=PAM:setcred grantors=pam_shells,pam_faillock,pam_permit,pam_faillock acct="aurion" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
[ 17.302613] audit: type=1006 audit(1612133653.991:65): pid=930 uid=0 subj=kernel old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=2 res=1
[ 17.316154] audit: type=1130 audit(1612133654.041:66): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=kernel msg='unit=user-runtime-dir@1000 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 17.336324] audit: type=1101 audit(1612133654.051:67): pid=932 uid=0 auid=4294967295 ses=4294967295 subj=kernel msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="aurion" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 17.360056] audit: type=1103 audit(1612133654.051:68): pid=932 uid=0 auid=4294967295 ses=4294967295 subj=kernel msg='op=PAM:setcred grantors=? acct="aurion" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 17.380162] audit: type=1006 audit(1612133654.051:69): pid=932 uid=0 subj=kernel old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=3 res=1
[ 17.393678] audit: type=1105 audit(1612133654.061:70): pid=932 uid=0 auid=1000 ses=3 subj=kernel msg='op=PAM:session_open grantors=pam_loginuid,pam_loginuid,pam_keyinit,pam_limits,pam_unix,pam_permit,pam_mail,pam_systemd,pam_env acct="aurion" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 17.421241] audit: type=1334 audit(1612133654.071:71): prog-id=18 op=LOAD
[ 21.541333] Bluetooth: RFCOMM TTY layer initialized
[ 21.541389] Bluetooth: RFCOMM socket layer initialized
[ 21.545817] Bluetooth: RFCOMM ver 1.11
[ 23.657215] panfrost ffe40000.gpu: js fault, js=1, status=INSTR_INVALID_ENC, head=0x31c7100, tail=0x31c7100
[ 23.661363] panfrost ffe40000.gpu: gpu sched timeout, js=1, config=0x7303, status=0x51, head=0x31c7100, tail=0x31c7100, sched_job=000000007e20fe41
[ 23.819916] panfrost ffe40000.gpu: js fault, js=1, status=INSTR_INVALID_ENC, head=0x31c7640, tail=0x31c7640
[ 23.824062] panfrost ffe40000.gpu: gpu sched timeout, js=1, config=0x7300, status=0x51, head=0x31c7640, tail=0x31c7640, sched_job=000000007b1ef333
[ 24.147089] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 25.658791] kauditd_printk_skb: 7 callbacks suppressed
[ 25.658796] audit: type=1130 audit(1612133662.411:79): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=kernel msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 26.042536] audit: type=1701 audit(1612133662.791:80): auid=1000 uid=1000 gid=1000 ses=2 subj=kernel pid=1042 comm=5468726561642028706F6F6C656429 exe="/usr/bin/baloo_file" sig=11 res=1
[ 26.102494] audit: type=1334 audit(1612133662.851:81): prog-id=19 op=LOAD
[ 26.103678] audit: type=1334 audit(1612133662.851:82): prog-id=20 op=LOAD
[ 26.110498] audit: type=1130 audit(1612133662.851:83): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=kernel msg='unit=systemd-coredump@0-1202-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 26.635003] audit: type=1131 audit(1612133663.391:84): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=kernel msg='unit=systemd-coredump@0-1202-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 27.054910] audit: type=1334 audit(1612133663.811:85): prog-id=20 op=UNLOAD
[ 27.056234] audit: type=1334 audit(1612133663.811:86): prog-id=19 op=UNLOAD
[ 27.208033] panfrost ffe40000.gpu: js fault, js=1, status=INSTR_INVALID_ENC, head=0x31c7100, tail=0x31c7100
[ 27.212138] panfrost ffe40000.gpu: gpu sched timeout, js=1, config=0x7302, status=0x51, head=0x31c7100, tail=0x31c7100, sched_job=000000001b3af599
[ 27.249753] panfrost ffe40000.gpu: js fault, js=1, status=INSTR_INVALID_ENC, head=0x309ba40, tail=0x309ba40
[ 27.253878] panfrost ffe40000.gpu: gpu sched timeout, js=1, config=0x7300, status=0x51, head=0x309ba40, tail=0x309ba40, sched_job=00000000b4cc7ac2
[ 27.307609] panfrost ffe40000.gpu: js fault, js=1, status=INSTR_INVALID_ENC, head=0x309a100, tail=0x309a100
[ 27.311713] panfrost ffe40000.gpu: gpu sched timeout, js=1, config=0x7300, status=0x51, head=0x309a100, tail=0x309a100, sched_job=0000000059566bf3
[ 27.345193] panfrost ffe40000.gpu: js fault, js=1, status=INSTR_INVALID_ENC, head=0x31c8a40, tail=0x31c8a40
[ 27.349374] panfrost ffe40000.gpu: gpu sched timeout, js=1, config=0x7300, status=0x51, head=0x31c8a40, tail=0x31c8a40, sched_job=00000000ed53769a
[ 27.452865] panfrost ffe40000.gpu: js fault, js=0, status=INSTR_INVALID_ENC, head=0x309e500, tail=0x309e500
[ 27.457050] panfrost ffe40000.gpu: gpu sched timeout, js=0, config=0x7300, status=0x51, head=0x309e500, tail=0x309e500, sched_job=0000000035ed151b
[ 27.865901] audit: type=1131 audit(1612133664.621:87): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=kernel msg='unit=user@971 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 27.901566] audit: type=1131 audit(1612133664.651:88): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=kernel msg='unit=user-runtime-dir@971 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 30.185568] panfrost ffe40000.gpu: js fault, js=1, status=INSTR_INVALID_ENC, head=0x31c7100, tail=0x31c7100
[ 30.189671] panfrost ffe40000.gpu: gpu sched timeout, js=1, config=0x7300, status=0x51, head=0x31c7100, tail=0x31c7100, sched_job=00000000a06b4c7b
[ 30.210526] panfrost ffe40000.gpu: js fault, js=1, status=INSTR_INVALID_ENC, head=0x309a100, tail=0x309a100
[ 30.214605] panfrost ffe40000.gpu: gpu sched timeout, js=1, config=0x7300, status=0x51, head=0x309a100, tail=0x309a100, sched_job=000000003715592c
[ 36.009730] audit: type=1131 audit(1612133672.761:89): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=kernel msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 38.583187] audit: type=1131 audit(1612133675.331:90): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=kernel msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 39.094820] audit: type=1334 audit(1612133675.851:91): prog-id=12 op=UNLOAD
[ 39.096145] audit: type=1334 audit(1612133675.851:92): prog-id=11 op=UNLOAD
[ 40.029662] panfrost ffe40000.gpu: Unhandled Page fault in AS1 at VA 0x0000000000000000
Reason: TODO
raw fault status: 0x10002C2
decoded fault status: SLAVE FAULT
exception type 0xC2: TRANSLATION_FAULT_LEVEL2
access type 0x2: READ
source id 0x100
[ 40.074951] panfrost ffe40000.gpu: Unhandled Page fault in AS1 at VA 0x0000000000000000
Reason: TODO
source id 0x100
[ 40.105434] panfrost ffe40000.gpu: Unhandled Page fault in AS1 at VA 0x0000000000000000
Reason: TODO
source id 0x100
[ 40.534764] panfrost ffe40000.gpu: gpu sched timeout, js=1, config=0x7301, status=0x8, head=0x31c7000, tail=0x31c7100, sched_job=000000000791a9e3
[ 40.723719] panfrost ffe40000.gpu: js fault, js=1, status=INSTR_INVALID_ENC, head=0x31c7100, tail=0x31c7100
[ 40.727839] panfrost ffe40000.gpu: gpu sched timeout, js=1, config=0x7300, status=0x51, head=0x31c7100, tail=0x31c7100, sched_job=00000000adbf27db
[ 98.739664] panfrost ffe40000.gpu: Unhandled Page fault in AS1 at VA 0x0000000000000000
Reason: TODO
source id 0x100
[ 99.242887] panfrost ffe40000.gpu: gpu sched timeout, js=1, config=0x7301, status=0x8, head=0x3186000, tail=0x3186100, sched_job=0000000018b5b4fe
[ 99.710491] panfrost ffe40000.gpu: Unhandled Page fault in AS2 at VA 0x0000000000000000
Reason: TODO
raw fault status: 0x4002C2
source id 0x40
[ 99.772914] panfrost ffe40000.gpu: Unhandled Page fault in AS2 at VA 0x0000000000000000
Reason: TODO
source id 0x40
[ 99.872879] panfrost ffe40000.gpu: Unhandled Page fault in AS2 at VA 0x0000000000000000
Reason: TODO
source id 0x40
[ 99.972863] panfrost ffe40000.gpu: Unhandled Page fault in AS2 at VA 0x0000000000000000
Reason: TODO
source id 0x40
[ 100.092898] panfrost ffe40000.gpu: Unhandled Page fault in AS2 at VA 0x0000000000000000
Reason: TODO
source id 0x40
[ 100.132912] panfrost ffe40000.gpu: Unhandled Page fault in AS2 at VA 0x0000000000000000
Reason: TODO
source id 0x40
[ 100.212754] panfrost ffe40000.gpu: gpu sched timeout, js=1, config=0x7302, status=0x8, head=0x309a000, tail=0x309a100, sched_job=00000000b0802b78
[ 100.318558] panfrost ffe40000.gpu: js fault, js=0, status=DATA_INVALID_FAULT, head=0x31c7980, tail=0x31c7980
[ 100.322752] panfrost ffe40000.gpu: gpu sched timeout, js=0, config=0x7300, status=0x58, head=0x31c7980, tail=0x31c7980, sched_job=00000000d17ca4dc
[ 105.944250] panfrost ffe40000.gpu: js fault, js=1, status=INSTR_INVALID_ENC, head=0x313f100, tail=0x313f100
[ 105.948369] panfrost ffe40000.gpu: gpu sched timeout, js=1, config=0x7300, status=0x51, head=0x313f100, tail=0x313f100, sched_job=000000005b735dcd
[ 190.106530] panfrost ffe40000.gpu: js fault, js=1, status=DATA_INVALID_FAULT, head=0x309a000, tail=0x309a000
[ 190.110850] panfrost ffe40000.gpu: gpu sched timeout, js=1, config=0x7301, status=0x58, head=0x309a000, tail=0x309a000, sched_job=00000000e9d01669
[ 198.657978] panfrost ffe40000.gpu: Unhandled Page fault in AS2 at VA 0x0000000000000000
Reason: TODO
source id 0x40
[ 198.695586] panfrost ffe40000.gpu: Unhandled Page fault in AS2 at VA 0x0000000000000000
Reason: TODO
source id 0x40
[ 199.165466] panfrost ffe40000.gpu: gpu sched timeout, js=1, config=0x7302, status=0x8, head=0x53d7000, tail=0x53d7100, sched_job=000000004d0ac174
