Hello all,
I’ve been dabbling with Linux for a few years at beginner level and have decided that I want to really expand my knowledge of Linux by installing and sticking with Manjaro. I installed it on my Razer Blade 15 Mid 2021 Base model laptop and ran into some issues in what I expect to be graphics drivers related (I have an nVidia graphics card).
I posted this problem on a reddit-post and was directed to bring this here, where better assistance will be available. I am determined to resolve this and support Manjaro for years to come. Troubleshooting, fixing, and stabilizing a system for daily driving is my intention.
I have an nVidia 3070 mobile GPU in my laptop and initially aimed to see how well the computer would function with the default linux driver. All seems fine except when attempting to sleep/suspend/shut-down/reboot the computer, the laptop freezes as terminal commands and processes cease and close out. I found online that using the correct drivers may fix this problem.
When the recommended nVidia driver (video-hybrid-intel-nvidia-prime) is installed, I noticed that VLC, or any video playback softwares won’t play videos. Upon attempting to launch any video, the attempt crashes (the window in-application quickly opens and closes). Further, I am able to sleep/reboot/shut down the laptop about 50% of the time without having to hard-power-off the machine.
Any other nVidia drivers causes the laptop to be unable to boot into the desktop environment, freezing on the initial terminal-launch screen (I apologize I don’t have the proper terminology).
My attempts that fail to suspend/sleep/etc the machine were performed both via icons in the desktop environment as well as via terminal. Successful outcomes are independent from whether I use the terminal or not, but only have a chance to succeed with this graphics driver installed. I am using KDE Plasma.
My aim is to find a way to stabilize my Manjaro build so that I can power-on/power-off/sleep my device without graphics drivers crashing as well as, obviously, be able to play videos and use video playback software.
Any help is greatly appreciated. I will post any terminal output requested. I currently am reverted to no graphics driver installed (using linux default). Thanks so much in advance!
inxi -Faz
mhwd -l && mhwd -li
The results for this is:
Kernel: 5.15.65-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=322c6c67-9869-4d4e-8055-251448e55813 rw quiet
udev.log_priority=3
Desktop: KDE Plasma v: 5.25.5 tk: Qt v: 5.15.5 wm: kwin_x11 vt: 1
Type: Laptop System: Razer product: Blade 15 Base Model (Mid 2021) -
RZ09-0410 v: 7.04 serial: <superuser required> Chassis: type: 10
Mobo: Razer model: DA570 v: 4 serial: <superuser required> UEFI: Razer
v: 1.03 date: 08/03/2021
ID-1: BAT0 charge: 30.6 Wh (47.7%) condition: 64.1/65.0 Wh (98.7%)
volts: 16.2 min: 15.4 model: Razer Blade type: Unknown serial: <filter>
status: charging
Info: model: 11th Gen Intel Core i7-11800H bits: 64 type: MT MCP
arch: Tiger Lake gen: core 11 level: v4 built: 2020 process: Intel 10nm
family: 6 model-id: 0x8D (141) stepping: 1 microcode: 0x40
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 640 KiB desc: d-8x48 KiB; i-8x32 KiB L2: 10 MiB desc: 8x1.2 MiB
L3: 24 MiB desc: 1x24 MiB
Speed (MHz): avg: 969 high: 1223 min/max: 800/4600 scaling:
driver: intel_pstate governor: powersave cores: 1: 1028 2: 969 3: 1040
4: 1223 5: 801 6: 801 7: 802 8: 1013 9: 799 10: 1031 11: 947 12: 1160
13: 801 14: 777 15: 1117 16: 1201 bogomips: 73744
prctl and seccomp
Type: spectre_v2 status: Vulnerable: eIBRS with unprivileged eBPF
Device-1: Intel TigerLake-H GT1 [UHD Graphics] vendor: Razer USA
driver: i915 v: kernel arch: Gen-12.1 process: Intel 10nm built: 2020-21
ports: active: eDP-1 empty: DP-1, DP-2, DP-3, DP-4 bus-ID: 00:02.0
chip-ID: 8086:9a60 class-ID: 0300
Device-2: NVIDIA GA104M [GeForce RTX 3070 Mobile / Max-Q]
vendor: Razer USA driver: nouveau v: kernel non-free: 515.xx+ status: current
(as of 2022-08) arch: Ampere code: GAxxx process: TSMC n7 (7nm)
built: 2020-22 pcie: gen: 4 speed: 16 GT/s lanes: 8 link-max: lanes: 16
ports: active: none empty: DP-5, DP-6, DP-7, HDMI-A-1 bus-ID: 01:00.0
chip-ID: 10de:249d class-ID: 0300
Device-3: IMC Networks USB Camera type: USB driver: uvcvideo
bus-ID: 3-8:3 chip-ID: 13d3:56bd class-ID: 0e02 serial: <filter>
Display: x11 server: v: 21.1.4 compositor: kwin_x11 driver: X:
loaded: modesetting alternate: fbdev,vesa gpu: i915 display-ID: :0
screens: 1
Screen-1: 0 s-res: 2560x1440 s-dpi: 96 s-size: 677x381mm (26.65x15.00")
s-diag: 777mm (30.58")
Monitor-1: eDP-1 model: ChiMei InnoLux 0x152a built: 2020 res: 2560x1440
dpi: 189 gamma: 1.2 size: 344x193mm (13.54x7.6") diag: 394mm (15.5")
ratio: 16:9 modes: 2560x1440
OpenGL: renderer: Mesa Intel UHD Graphics (TGL GT1) v: 4.6 Mesa 22.1.7
direct render: Yes
Device-1: Intel Tiger Lake-H HD Audio vendor: Razer USA
driver: snd_hda_intel v: kernel alternate: snd_sof_pci_intel_tgl
bus-ID: 00:1f.3 chip-ID: 8086:43c8 class-ID: 0403
Device-2: NVIDIA GA104 High Definition Audio vendor: Razer USA
driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 8
link-max: lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:228b class-ID: 0403
Sound Server-1: ALSA v: k5.15.65-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.57 running: yes
Device-1: Intel Tiger Lake PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:43f0 class-ID: 0280
vendor: Razer USA driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: 3000 bus-ID: 30:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp48s0 state: down mac: <filter>
bus-ID: 3-14:4 chip-ID: 8087:0026 class-ID: e001
Local Storage: total: 2.73 TiB used: 35.78 GiB (1.3%)
ID-1: /dev/nvme0n1 maj-min: 259:5 vendor: Smart Modular Tech.
model: SHGP31-1000GM-2 size: 931.51 GiB block-size: physical: 512 B
rev: 41060C20 temp: 43.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Samsung model: SSD 980 PRO 2TB
lanes: 4 type: SSD serial: <filter> rev: 3B2QGXA7 temp: 33.9 C
scheme: GPT
ID-1: / raw-size: 931.22 GiB size: 915.53 GiB (98.32%) used: 35.78 GiB
(3.9%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:7
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 316 KiB
(0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:6
ID-1: swap-1 type: file size: 512 MiB used: 0 KiB (0.0%) priority: -2
file: /swapfile
System Temperatures: cpu: 57.0 C mobo: N/A
Processes: 329 Uptime: 18m wakeups: 4351 Memory: 31.1 GiB used: 3.46 GiB
(11.1%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: 1463 pm: pacman pkgs: 1442
libs: 421 tools: pamac,yay pm: flatpak pkgs: 21 Shell: Zsh v: 5.9
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.21
> 0000:30:00.0 (0200:10ec:8168) Network controller Realtek Semiconductor Co., Ltd.:
NAME VERSION FREEDRIVER TYPE
network-r8168 2016.04.20 true PCI
> 0000:01:00.0 (0300:10de:249d) Display controller nVidia Corporation:
video-hybrid-intel-nvidia-prime 2021.11.04 false PCI
video-hybrid-intel-nvidia-470xx-prime 2021.11.04 false PCI
video-nvidia 2021.11.04 false PCI
video-nvidia-470xx 2021.11.04 false PCI
video-modesetting 2020.01.13 true PCI
video-vesa 2017.03.12 true PCI
> 0000:00:02.0 (0300:8086:9a60) Display controller Intel Corporation:
> Installed PCI configs:
Side note: Running these commands froze my laptop for about 30 seconds.
Moderator edit: In the future, please use proper formatting: [HowTo] Post command output and file content as formatted text
