Output:
inxi -Fza
Kernel: 6.1.23-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=5d57ac7a-1678-4d0c-8f7d-bde006b7fa1d rw quiet splash
resume=UUID=271283db-ac0a-435d-8f25-e154dba11049 udev.log_priority=3
Desktop: KDE Plasma v: 5.27.4 tk: Qt v: 5.15.8 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop System: MSI product: MS-7917 v: 1.0
serial: <superuser required>
Mobo: MSI model: Z97 GAMING 5 (MS-7917) v: 1.0
serial: <superuser required> UEFI: American Megatrends v: 1.13
date: 02/16/2016
Device-1: wacom_battery_1 model: Wacom Intuos S serial: N/A charge: 0%
status: N/A
Info: model: Intel Core i5-4690K bits: 64 type: MCP arch: Haswell
gen: core 4 level: v3 note: check built: 2013-15 process: Intel 22nm
family: 6 model-id: 0x3C (60) stepping: 3 microcode: 0x28
Topology: cpus: 1x cores: 4 smt: <unsupported> cache: L1: 256 KiB
desc: d-4x32 KiB; i-4x32 KiB L2: 1024 KiB desc: 4x256 KiB L3: 6 MiB
desc: 1x6 MiB
Speed (MHz): avg: 800 min/max: 800/4000 scaling: driver: intel_cpufreq
governor: schedutil cores: 1: 800 2: 800 3: 800 4: 800 bogomips: 28011
disabled
STIBP: disabled, RSB filling, PBRSB-eIBRS: Not affected
Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor Integrated Graphics
vendor: Micro-Star MSI driver: i915 v: kernel arch: Gen-7.5
process: Intel 22nm built: 2013 ports: active: none
empty: HDMI-A-1,HDMI-A-2,VGA-1 bus-ID: 00:02.0 chip-ID: 8086:0412
class-ID: 0380
Device-2: NVIDIA TU116 [GeForce GTX 1660] vendor: ZOTAC driver: nouveau
v: kernel non-free: 530.xx+ status: current (as of 2023-03) arch: Turing
code: TUxxx process: TSMC 12nm FF built: 2018-22 pcie: gen: 1
speed: 2.5 GT/s lanes: 16 link-max: gen: 3 speed: 8 GT/s ports:
active: DP-2,HDMI-A-3 empty: DP-1,DP-3 bus-ID: 01:00.0 chip-ID: 10de:2184
class-ID: 0300 temp: 31.0 C
Display: x11 server: X.Org v: 21.1.8 compositor: kwin_x11 driver: X:
loaded: modesetting alternate: fbdev,vesa dri: nouveau,crocus gpu: nouveau
display-ID: :0 screens: 1
Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1016x285mm (40.00x11.22")
s-diag: 1055mm (41.54")
Monitor-1: DP-2 pos: right model: Acer G246HL serial: <filter> built: 2015
res: 1920x1080 hz: 60 dpi: 92 gamma: 1.2 size: 531x299mm (20.91x11.77")
diag: 609mm (24") ratio: 16:9 modes: max: 1920x1080 min: 720x400
Monitor-2: HDMI-A-3 mapped: HDMI-3 pos: primary,left model: Asus VE228
serial: <filter> built: 2012 res: 1920x1080 hz: 60 dpi: 102 gamma: 1.2
size: 477x268mm (18.78x10.55") diag: 547mm (21.5") ratio: 16:9 modes:
API: OpenGL v: 4.3 Mesa 23.0.2 renderer: NV168 direct-render: Yes
Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor HD Audio
vendor: Micro-Star MSI driver: snd_hda_intel v: kernel bus-ID: 00:03.0
chip-ID: 8086:0c0c class-ID: 0403
Device-2: Intel 9 Series Family HD Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:8ca0
class-ID: 0403
Device-3: NVIDIA TU116 High Definition Audio vendor: ZOTAC
driver: snd_hda_intel v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 16
link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.1 chip-ID: 10de:1aeb
class-ID: 0403
API: ALSA v: k6.1.23-1-MANJARO status: kernel-api with: aoss
type: oss-emulator tools: alsamixer,amixer
Server-2: PipeWire v: 0.3.68 status: off with: wireplumber status: active
tools: pw-cli,wpctl
Server-3: PulseAudio v: 16.1 status: active tools: pacat,pactl
Device-1: Qualcomm Atheros Killer E220x Gigabit Ethernet
vendor: Micro-Star MSI driver: alx v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: d000 bus-ID: 03:00.0 chip-ID: 1969:e091 class-ID: 0200
Device-2: Realtek RTL8153 Gigabit Ethernet Adapter type: USB driver: r8152
bus-ID: 4-5.4:3 chip-ID: 0bda:8153 class-ID: 0000 serial: <filter>
IF: enp0s20u5u4 state: down mac: <filter>
Local Storage: total: 238.47 GiB used: 38.55 GiB (16.2%)
ID-1: /dev/sda maj-min: 8:0 vendor: SanDisk model: SDSSDHP256G
size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 6RL scheme: GPT
ID-1: / raw-size: 50.37 GiB size: 49.28 GiB (97.83%) used: 23.74 GiB (48.2%)
fs: ext4 dev: /dev/sda2 maj-min: 8:2
used: 5.4 MiB (1.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 178.49 GiB size: 174.63 GiB (97.84%)
used: 14.81 GiB (8.5%) fs: ext4 dev: /dev/sda3 maj-min: 8:3
ID-1: swap-1 type: partition size: 8 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda4 maj-min: 8:4
System Temperatures: cpu: 37.0 C mobo: N/A gpu: nouveau temp: 31.0 C
Fan Speeds (RPM): N/A gpu: nouveau fan: 1094
Processes: 198 Uptime: 57m wakeups: 2 Memory: 7.64 GiB
used: 2.87 GiB (37.5%) Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7 Packages: 1552
pm: pacman pkgs: 1529 libs: 387 tools: pamac,yay pm: flatpak pkgs: 23
Shell: Bash v: 5.1.16 running-in: terminator inxi: 3.3.26
sudo mhwd-kernel -li
Currently running: 6.1.23-1-MANJARO (linux61)
* linux61
sudo mhwd -li
> Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
I also did just boot onto Kernel 5.15 LTS
Here is the output again:
inxi -Fza
Kernel: 5.15.106-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
date: 02/16/2016
desc: 1x6 MiB
Speed (MHz): avg: 2605 high: 4001 min/max: 800/4000 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 4001 2: 1450 3: 2600
4: 2370 bogomips: 28011
disabled
prctl and seccomp
class-ID: 0380
class-ID: 0403
class-ID: 0403
API: ALSA v: k5.15.106-1-MANJARO status: kernel-api with: aoss
tools: pw-cli,wpctl
Local Storage: total: 238.47 GiB used: 38.84 GiB (16.3%)
ID-1: / raw-size: 50.37 GiB size: 49.28 GiB (97.83%) used: 24.02 GiB (48.7%)
System Temperatures: cpu: 39.0 C mobo: N/A gpu: nouveau temp: 31.0 C
Fan Speeds (RPM): N/A gpu: nouveau fan: 1142
Processes: 204 Uptime: 1m wakeups: 1 Memory: 7.64 GiB used: 2.19 GiB (28.6%)
Init: systemd v: 252 default: graphical tool: systemctl Compilers:
gcc: 12.2.1 clang: 15.0.7 Packages: 1553 pm: pacman pkgs: 1530 libs: 387
tools: pamac,yay pm: flatpak pkgs: 23 Shell: Bash v: 5.1.16
Currently running: 5.15.106-1-MANJARO (linux515)
* linux515
* linux61
sudo mhwd -li
