Hello,
I am trying to utilize Linux Kernel 5.15 on my GPD Win 2 running Manjaro Stable because of the improved game performance (I’ve gotten a noticeable fps increase in games like Metal Gear Rising), but 3 out 4 times when booting into the computer with linux kernel 5.15, it either freezes on the /dev/sda2 screen or on a black screen. When it does boot, it either works great, or it will boot into desktop only to not detect the wifi card, forcing me to restart and try again. Having to force shutdown the device and hope it will boot correctly isn’t healthy for the computer. None of these happen on kernel 5.4. I have also tried 5.10 and 5.18 to similar issues. I have tried other distros and all have similar issues, so it seems to be related to the kernel. I have had this issue for months when testing newer kernels and I have been hoping it would be fixed in some sort of patch but that has not happened yet. Since it does boot correctly sometimes, there may be some sort of tweaking on my end to make it boot correctly everytime. Any suggestions on what the issue might be?
provide formatted output from:
inxi -Fazy
journalctl --boot=0 --priority=3 --no-pager
~ inxi -Fazy ✔
Kernel: 5.15.46-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=93f4f5ab-ac06-4a59-9232-5c1ffbc66061 rw quiet
resume=UUID=550c15ed-2b7b-44ed-bfd0-b50697230d51 udev.log_priority=3
Desktop: GNOME v: 42.2 tk: GTK v: 3.24.34 wm: gnome-shell dm: GDM v: 42.0
Type: Desktop Mobo: N/A model: N/A serial: <superuser required>
UEFI: American Megatrends v: 5.12 date: 03/23/2018
ID-1: BAT0 charge: 26.3 Wh (79.0%) condition: 33.3/37.2 Wh (89.4%)
volts: 7.6 min: N/A model: Intel SR 1 SR Real Battery type: Unknown
serial: <filter> status: discharging
Info: model: Intel Core m3-7Y30 bits: 64 type: MT MCP arch: Amber/Kaby Lake
note: check built: 2017 process: Intel 14nm family: 6 model-id: 0x8E (142)
stepping: 9 microcode: 0xF0
L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 2478 high: 2597 min/max: 400/2600 scaling:
driver: intel_pstate governor: powersave cores: 1: 2400 2: 2597 3: 2400
4: 2516 bogomips: 12805
Type: l1tf
Device-1: Intel HD Graphics 615 driver: i915 v: kernel arch: Gen9.5
process: Intel 14nm built: 2016-20 ports: active: eDP-1
empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2, HDMI-A-3 bus-ID: 00:02.0
chip-ID: 8086:591e class-ID: 0300
Display: wayland server: X.org v: 1.21.1.3 with: Xwayland v: 22.1.2
compositor: gnome-shell driver: X: loaded: modesetting alternate: fbdev,vesa
gpu: i915 display-ID: 0
Monitor-1: eDP-1 model-id: LTM 0x3937 serial: <filter> built: 2018
res: 720x1280 dpi: 141 gamma: 1.2 size: 160x90mm (6.3x3.54")
diag: 153mm (6") ratio: 16:10, 16:9 modes: 720x1280
Message: Wayland GBM/EGL data currently not available.
Device-1: Intel Xeon E3-1200 v5/E3-1500 v5/6th Gen Core Processor Imaging
Unit
driver: ipu3-imgu alternate: ipu3_imgu bus-ID: 00:05.0 chip-ID: 8086:1919
class-ID: 0480
Device-2: Intel CSI-2 Host driver: ipu3-cio2 alternate: ipu3_cio2
bus-ID: 00:14.3 chip-ID: 8086:9d32 class-ID: 0480
Device-3: Intel Sunrise Point-LP HD Audio driver: snd_hda_intel v: kernel
alternate: snd_soc_skl bus-ID: 00:1f.3 chip-ID: 8086:9d71 class-ID: 0403
Sound Server-1: ALSA v: k5.15.46-1-MANJARO running: yes
Sound Server-3: PulseAudio v: 16.0 running: yes
Sound Server-4: PipeWire v: 0.3.52 running: no
Device-1: Intel Wireless 7265 driver: iwlwifi v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 01:00.0 chip-ID: 8086:095a class-ID: 0280
bus-ID: 1-7:3 chip-ID: 8087:0a2a class-ID: e001
Local Storage: total: 1.4 TiB used: 1.43 TiB (102.5%)
ID-1: /dev/mmcblk0 maj-min: 179:0 model: SD01T size: 953.55 GiB
block-size: physical: 512 B logical: 512 B type: SSD serial: <filter>
scheme: MBR
ID-2: /dev/sda maj-min: 8:0 vendor: Transcend model: TS512GMTS430S
size: 476.94 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: TBD1 scheme: GPT
ID-1: / raw-size: 467.84 GiB size: 459.43 GiB (98.20%)
used: 331.43 GiB (72.1%) fs: ext4 dev: /dev/sda2 maj-min: 8:2
used: 288 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1
dev: /dev/sda3 maj-min: 8:3
System Temperatures: cpu: 42.0 C pch: 36.5 C mobo: N/A
Processes: 209 Uptime: 0m wakeups: 1 Memory: 7.68 GiB used: 1.32 GiB (17.2%)
Init: systemd v: 251 default: graphical tool: systemctl Compilers:
gcc: 12.1.0 clang: 13.0.1 Packages: pacman: 1210 lib: 404 flatpak: 0
Shell: Zsh v: 5.9 running-in: gnome-terminal inxi: 3.3.18
~ journalctl --boot=0 --priority=3 --no-pager ✔
Jun 15 17:23:56 jacob-defaultstring kernel: x86/cpu: SGX disabled by BIOS.
Jun 15 17:23:56 jacob-defaultstring kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.I2C1.TPL1._PS0], AE_ALREADY_EXISTS (20210730/dswload2-326)
Jun 15 17:23:56 jacob-defaultstring kernel: ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20210730/psobject-220)
Jun 15 17:23:56 jacob-defaultstring kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.I2C1.TPL1._PS3], AE_ALREADY_EXISTS (20210730/dswload2-326)
Jun 15 17:23:56 jacob-defaultstring kernel: ACPI Error: AE_NOT_FOUND, While resolving a named reference package element - \_SB_.MODS (20210730/dspkginit-438)
Jun 15 17:23:57 jacob-defaultstring kernel: int3472-discrete INT3472:01: INT3472 seems to have no dependents.
Jun 15 17:23:57 jacob-defaultstring kernel: int3472-discrete INT3472:02: INT3472 seems to have no dependents.
Jun 15 17:23:59 jacob-defaultstring gdm-autologin][561]: gkr-pam: couldn't unlock the login keyring.
Jun 15 17:24:00 jacob-defaultstring systemd[647]: Failed to start Application launched by gnome-session-binary.
Jun 15 17:24:05 jacob-defaultstring systemd[647]: Failed to start Application launched by gnome-session-binary.
Also Im not sure if this influenced the results for this particular test, but I booted into the computer with 5.4, then restarted and went to grub and booted into 5.15. In past tests I still encounter black screen boots this way, but I thought I should share that additional bit of info if it could influence the terminal results.
noticed you using wayland, does the same black screen happens also on x11?
Yeah, the black screen issue happens with xorg/x11 too.
so when the black screen happens and you have to reboot, post logs from the black screen boot:
journalctl --boot=-1 --priority=3 --no-pager
Here are the results when I get a black screen:
journalctl --boot=-1 --priority=3 --no-pager ✔
Jun 16 05:04:58 jacob-defaultstring kernel: x86/cpu: SGX disabled by BIOS.
Jun 16 05:04:58 jacob-defaultstring kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.I2C1.TPL1._PS0], AE_ALREADY_EXISTS (20210730/dswload2-326)
Jun 16 05:04:58 jacob-defaultstring kernel: ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20210730/psobject-220)
Jun 16 05:04:58 jacob-defaultstring kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.I2C1.TPL1._PS3], AE_ALREADY_EXISTS (20210730/dswload2-326)
Jun 16 05:04:58 jacob-defaultstring kernel: ACPI Error: AE_NOT_FOUND, While resolving a named reference package element - \_SB_.MODS (20210730/dspkginit-438)
And here are the results when it manages to boot into desktop with 5.15 but the wifi does not work:
Jun 16 05:07:08 jacob-defaultstring kernel: x86/cpu: SGX disabled by BIOS.
Jun 16 05:07:08 jacob-defaultstring kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.I2C1.TPL1._PS0], AE_ALREADY_EXISTS (20210730/dswload2-326)
Jun 16 05:07:08 jacob-defaultstring kernel: ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20210730/psobject-220)
Jun 16 05:07:08 jacob-defaultstring kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.I2C1.TPL1._PS3], AE_ALREADY_EXISTS (20210730/dswload2-326)
Jun 16 05:07:08 jacob-defaultstring kernel: ACPI Error: AE_NOT_FOUND, While resolving a named reference package element - \_SB_.MODS (20210730/dspkginit-438)
Jun 16 05:07:08 jacob-defaultstring kernel: int3472-discrete INT3472:01: INT3472 seems to have no dependents.
Jun 16 05:07:08 jacob-defaultstring kernel: int3472-discrete INT3472:02: INT3472 seems to have no dependents.
Jun 16 05:07:10 jacob-defaultstring kernel: pci 0000:01:00.0: can't change power state from D3cold to D0 (config space inaccessible)
Jun 16 05:07:10 jacob-defaultstring kernel: iwlwifi 0000:01:00.0: can't change power state from D3cold to D0 (config space inaccessible)
Jun 16 05:07:10 jacob-defaultstring kernel: iwlwifi 0000:01:00.0: HW_REV=0xFFFFFFFF, PCI issues?
Jun 16 05:07:11 jacob-defaultstring gdm-autologin][523]: gkr-pam: couldn't unlock the login keyring.
Jun 16 05:07:12 jacob-defaultstring kernel: Bluetooth: hci0: unexpected event for opcode 0xfc2f
theres really nothing there… can you do the same again but this time post more logs with this:
journalctl -b-1 -p5 --no-pager
journalctl -b-2 -p5 --no-pager 1 ✘
Jun 16 05:22:31 jacob-defaultstring kernel: Linux version 5.15.46-1-MANJARO (builduser@fv-az186-238) (gcc (GCC) 12.1.0, GNU ld (GNU Binutils) 2.38) #1 SMP PREEMPT Thu Jun 9 09:54:17 UTC 2022
Jun 16 05:22:31 jacob-defaultstring kernel: Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.15-x86_64 root=UUID=93f4f5ab-ac06-4a59-9232-5c1ffbc66061 rw quiet resume=UUID=550c15ed-2b7b-44ed-bfd0-b50697230d51 udev.log_priority=3
Jun 16 05:22:31 jacob-defaultstring kernel: Unknown kernel command line parameters "BOOT_IMAGE=/boot/vmlinuz-5.15-x86_64", will be passed to user space.
Jun 16 05:22:31 jacob-defaultstring kernel: x86/cpu: SGX disabled by BIOS.
Jun 16 05:22:31 jacob-defaultstring kernel: MDS CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/mds.html for more details.
Jun 16 05:22:31 jacob-defaultstring kernel: #3
Jun 16 05:22:31 jacob-defaultstring kernel: audit: type=2000 audit(1655371348.016:1): state=initialized audit_enabled=0 res=1
Jun 16 05:22:31 jacob-defaultstring kernel: ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
Jun 16 05:22:31 jacob-defaultstring kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.I2C1.TPL1._PS0], AE_ALREADY_EXISTS (20210730/dswload2-326)
Jun 16 05:22:31 jacob-defaultstring kernel: ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20210730/psobject-220)
Jun 16 05:22:31 jacob-defaultstring kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.I2C1.TPL1._PS3], AE_ALREADY_EXISTS (20210730/dswload2-326)
Jun 16 05:22:31 jacob-defaultstring kernel: ACPI Error: AE_NOT_FOUND, While resolving a named reference package element - \_SB_.MODS (20210730/dspkginit-438)
Jun 16 05:22:31 jacob-defaultstring kernel: SCSI subsystem initialized
Jun 16 05:22:31 jacob-defaultstring kernel: VFS: Disk quotas dquot_6.6.0
Jun 16 05:22:31 jacob-defaultstring kernel: Initialise system trusted keyrings
Jun 16 05:22:31 jacob-defaultstring kernel: Key type blacklist registered
Jun 16 05:22:31 jacob-defaultstring kernel: Key type asymmetric registered
Jun 16 05:22:31 jacob-defaultstring kernel: Asymmetric key parser 'x509' registered
Jun 16 05:22:31 jacob-defaultstring kernel: ACPI: thermal: [Firmware Bug]: No valid trip found
Jun 16 05:22:31 jacob-defaultstring kernel: hpet_acpi_add: no address or irqs in _CRS
Jun 16 05:22:31 jacob-defaultstring kernel: Loading compiled-in X.509 certificates
Jun 16 05:22:31 jacob-defaultstring kernel: Loaded X.509 cert 'Build time autogenerated kernel key: 6551b71b65e44a69be546551634a6ae29142d98f'
Jun 16 05:22:31 jacob-defaultstring kernel: Key type ._fscrypt registered
Jun 16 05:22:31 jacob-defaultstring kernel: Key type .fscrypt registered
Jun 16 05:22:31 jacob-defaultstring kernel: Key type fscrypt-provisioning registered
Jun 16 05:22:31 jacob-defaultstring kernel: scsi 1:0:0:0: Direct-Access ATA TS512GMTS430S TBD1 PQ: 0 ANSI: 5
Jun 16 05:22:31 jacob-defaultstring kernel: sd 1:0:0:0: [sda] 1000215216 512-byte logical blocks: (512 GB/477 GiB)
Jun 16 05:22:31 jacob-defaultstring kernel: sd 1:0:0:0: [sda] Write Protect is off
Jun 16 05:22:31 jacob-defaultstring kernel: sd 1:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
Jun 16 05:22:31 jacob-defaultstring kernel: sd 1:0:0:0: [sda] Attached SCSI disk
Jun 16 05:22:31 jacob-defaultstring kernel: usb: port power management may be unreliable
Jun 16 05:22:31 jacob-defaultstring kernel: i8042: PNP: PS/2 appears to have AUX port disabled, if this is incorrect please boot with i8042.nopnp
Jun 16 05:22:31 jacob-defaultstring kernel: random: lvm: uninitialized urandom read (4 bytes read)
Jun 16 05:22:31 jacob-defaultstring kernel: audit: type=1130 audit(1655371351.404:2): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=ufw comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 16 05:22:31 jacob-defaultstring systemd-random-seed[230]: Kernel entropy pool is not initialized yet, waiting until it is.
Jun 16 05:22:31 jacob-defaultstring kernel: audit: type=1130 audit(1655371351.454:3): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-journald comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
first check this:
did you edited your grub?
there is something susspicious: rw
Doubt it. There was an attempt a while ago to fix it via editing the grub boot options but that didn’t work and changed it back, I also uninstalled 5.15 and eventually reinstalled 5.15 since then. I have not noticed a change in its behavior.
but there is some strange parameter in grub: rw
- this looks strange to me… and reinstalling kernel, will not fix the parameter… run this:
cat /etc/default/grub
and copy this line here: GRUB_CMDLINE_LINUX_DEFAULT=...
GRUB_DEFAULT=saved
GRUB_TIMEOUT=5
GRUB_TIMEOUT_STYLE=hidden
GRUB_DISTRIBUTOR="Manjaro"
GRUB_CMDLINE_LINUX_DEFAULT="quiet resume=UUID=550c15ed-2b7b-44ed-bfd0-b50697230d51 udev.log_priority=3"
GRUB_CMDLINE_LINUX=""
# If you want to enable the save default function, uncomment the following
# line, and set GRUB_DEFAULT to saved.
GRUB_SAVEDEFAULT=true
#GRUB_ENABLE_CRYPTODISK=y
GRUB_TERMINAL_INPUT=console
#GRUB_TERMINAL_OUTPUT=console
GRUB_GFXMODE=auto
GRUB_GFXPAYLOAD_LINUX=keep
#GRUB_DISABLE_LINUX_UUID=true
GRUB_DISABLE_RECOVERY=true
GRUB_DISABLE_OS_PROBER=false
# Uncomment and set to the desired menu colors. Used by normal and wallpaper
# modes only. Entries specified as foreground/background.
GRUB_THEME="/usr/share/grub/themes/manjaro/theme.txt"
#GRUB_INIT_TUNE="480 440 1"
# Uncomment to ensure that the root filesystem is mounted read-only so that
# systemd-fsck can run the check automatically. We use 'fsck' by default, which
# needs 'rw' as boot parameter, to avoid delay in boot-time. 'fsck' needs to be
# removed from 'mkinitcpio.conf' to make 'systemd-fsck' work.
# See also Arch-Wiki: https://wiki.archlinux.org/index.php/Fsck#Boot_time_checking
#GRUB_ROOT_FS_RO=true
interesting, it looks ok, there is no rw
there…
open this file:
sudo nano /etc/mkinitcpio.conf
and edit the modules section to look like this:
MODULES=(i915)
then press ctrl+x
to save it
and run this:
sudo mkinitcpio -P
now run this:
sudo systemctl edit gdm
edit the service to:
[Service]
ExecStartPre=/bin/sleep 1
save the file, reboot and test
Didn’t work unfortunately
so go to etc/default/grub and add to this line GRUB_CMDLINE_LINUX_DEFAULT
this parameter:
random.trust_cpu=on
it should look like this:
GRUB_CMDLINE_LINUX_DEFAULT="quiet resume=UUID=550c15ed-2b7b-44ed-bfd0-b50697230d51 udev.log_priority=3 random.trust_cpu=on"
save the file, run this:
sudo update-grub
reboot and test
so remove the parameter and also remove this parameter: quiet
run again:
sudo update-grub
without quiet it will show logs, so check where it is stuck
The forum won’t let me attach photos or links, so on boot it freezes at:
[Ok] Started Accounts Service
[5.073963] pci 0000:01:00.0: can’t change power state from D3cold to D0 (config space inaccessible)
[ 5.075998] pcieport 0000:00:1d.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, (Requester ID)
[ 5.076111] pcieport 0000:00:1d.0: device [8086:9d18] error status/mask=00100000/00010000
[ 5.0762271] pcieport 0000:00:1d.0: [20] UnsupReq (First)
[ 5.076293] pcieport 0000:00:1d.0: AER: TLP Header: 34000000 01001f10 00000000 00000000
And I just tried another time and while the log was running on boot the screen went black before it could finish unlike the one above.
