I installed it via both apps and software and terminal
sudo Pacman -S gnome-tweaks
There were no error are the time
When I open the tweaks app from the menu
The busy icon in mouse only appears but the app is not opening
When I try to open it in terminal the below error shown.
File “/usr/bin/gnome-tweaks”, line 17, in
import gtweak
ModuleNotFoundError: No module named ‘gtweak’
I have also read something about building packages
But I don’t know how to do that.
I don’t know if it’ll work, but it’s worth a shot.
P.S.:
Thank you for the terminal output. I meant, bacticks, a.k.a. accent mark, a.k.a grave accent, and not the single-quote character. ( ` and not ’ ). If using the en_US keyboard layout, as me, that is the key just to the left of the 1:
Test it, and you’ll see.
Also remember, Linux, thus Majaro is case-sensitive. So,
If that doesn’t work, 1) make sure your repos on your mirrorlist are updated and update, 2) look at the Archwiki re python2 to see if there’s any troubleshooting, 3) try some of the renaming paths in your tweak.bin file in some of those threads as a last resort (this shouldn’t be necessary; I have gnome on Arch and I’ve never had an issue with the tweak tool).
Sorry I can’t be of more help.
Edit:
After some more digging, I came across this page, where:
The error you are getting indicates that the code has the wrong version of libhandy.
So I don’t know which version is necessary nor which one you have, but it might be something to check out.
Just for giggles, try anaconda2. It’s also in the AUR:
$ pamac search anaconda
anaconda2 2019.10-1 AUR
Completely free enterprise-ready Python distribution for large-scale data processing, predictive analytics, and scientific computing.
anaconda 2021.05-1 AUR
So, can be installed using:
pamac build anaconda2
Don’t really have much to lose at this stage.
If you wish to remove it afterward:
(Only do this if you don’t have it installed currently and don’t want to keep it if it doesn’t help.)
