Gnome Not Booting
Hi, so ever since i tried manjaro I have always wanted to use the gnome version. However, whenever i try to install specifically the gnome version and reboot, it just lands on a black screen and just shows “Starting arch Version…”. I always have to press alt + f1 and alt + f2 to get into it. Experienced the same issue on endeavour os Gnome. Any idea why this is happening?. (I have an nvidia card but I choose to use the open source drivers)
Welcome to the forum!
Please take a look at the thread below. Please update your post with your hardware information.
Hello @Zingy :wink:
Looks like the timing issue. 2 possible solutions:
Do what now? What version? Arch is not Manjaro; Manjaro is not Arch. What did you install?
Sorry it’s been a long time since I’ve tried to install manjaro gnome. It just came to my mind now and that’s all I remember of it.
Can this be fixed in a future update?
Well I am not the person who could fix it. Maybe @philm could say more?
As I see it affects mostly systems which boots very fast and where the gpu switches slow to graphical mode. Can’t confirm that, since i have had never that problem, but i guess it affects most systems with amd gpus, so it is not general problem. No idea where to report that. Is it GDM or the driver or is it the hardware?
At least there is a workaround for letting GDM wait more time.
@Zingy Could you post your system information?
inxi -Fazy
Well I’m not actually using Manjaro Gnome rn but here is my system info. Maybe it helps
  Kernel: 5.12.10-arch1-1 x86_64 bits: 64 compiler: gcc v: 11.1.0
  parameters: BOOT_IMAGE=/boot/vmlinuz-linux
  root=UUID=e0d45db4-4476-4e78-8f84-8b73a1f723b9 rw quiet loglevel=3
  nowatchdog
  Desktop: KDE Plasma 5.22.0 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
  Distro: EndeavourOS base: Arch Linux
  Type: Laptop System: HP product: HP Pavilion Gaming Laptop 15-ec1xxx v: N/A
  serial: <filter> Chassis: type: 10 serial: <filter>
  Mobo: HP model: 87B2 v: 31.21 serial: <filter> UEFI: AMI v: F.20
  date: 11/04/2020
  ID-1: BAT0 charge: 44.7 Wh (91.6%) condition: 48.8/48.8 Wh (100.0%)
  volts: 12.1 min: 11.6 model: Hewlett-Packard Primary type: Li-ion
  serial: N/A status: Discharging cycles: 439
  Device-1: hidpp_battery_0
  model: Logitech G304 Lightspeed Wireless Gaming Mouse serial: <filter>
  charge: 100% (should be ignored) rechargeable: yes status: Discharging
  Info: 6-Core model: AMD Ryzen 5 4600H with Radeon Graphics bits: 64
  type: MT MCP arch: Zen 2 family: 17 (23) model-id: 60 (96) stepping: 1
  microcode: 8600106 cache: L2: 3 MiB
  bogomips: 71894
  Speed: 1397 MHz min/max: 1400/3000 MHz boost: enabled Core speeds (MHz):
  1: 1397 2: 1397 3: 1397 4: 1397 5: 1397 6: 1397 7: 1397 8: 1397 9: 1397
  10: 1397 11: 1397 12: 1397
  Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional, IBRS_FW,
  Device-1: NVIDIA TU117M [GeForce GTX 1650 Ti Mobile] driver: nouveau
  v: kernel bus-ID: 01:00.0 chip-ID: 10de:1f95 class-ID: 0300
  Device-2: AMD Renoir vendor: Hewlett-Packard driver: amdgpu v: kernel
  bus-ID: 05:00.0 chip-ID: 1002:1636 class-ID: 0300
  Device-3: Luxvisions Innotech Limited HP TrueVision HD Camera type: USB
  driver: uvcvideo bus-ID: 3-3:3 chip-ID: 30c9:0013 class-ID: 0e02
  serial: <filter>
  Display: x11 server: X.org 1.20.11 compositor: kwin_x11 driver:
  loaded: amdgpu,ati,modesetting unloaded: fbdev,vesa alternate: nouveau,nv
  Device-1: NVIDIA driver: snd_hda_intel v: kernel bus-ID: 01:00.1
  chip-ID: 10de:10fa class-ID: 0403
  Device-2: AMD Raven/Raven2/FireFlight/Renoir Audio Processor
  vendor: Hewlett-Packard driver: N/A
  alternate: snd_pci_acp3x, snd_rn_pci_acp3x bus-ID: 05:00.5
  chip-ID: 1022:15e2 class-ID: 0480
  Device-3: AMD Family 17h HD Audio vendor: Hewlett-Packard
  driver: snd_hda_intel v: kernel bus-ID: 05:00.6 chip-ID: 1022:15e3
  class-ID: 0403
  Sound Server-1: ALSA v: k5.12.10-arch1-1 running: yes
  Sound Server-4: PipeWire v: 0.3.30 running: no
  vendor: Hewlett-Packard driver: r8169 v: kernel modules: r8168 port: e000
  bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
  Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel port: e000
  bus-ID: 03:00.0 chip-ID: 8086:2723 class-ID: 0280
  Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 1-4:2
  Local Storage: total: 476.94 GiB used: 18.64 GiB (3.9%)
  model: PC SN530 SDBPNPZ-512G-1006 size: 476.94 GiB block-size:
  physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 rotation: SSD
  serial: <filter> rev: HPS2 scheme: GPT
  ID-1: / raw-size: 100 GiB size: 97.87 GiB (97.87%) used: 18.57 GiB (19.0%)
  fs: ext4 dev: /dev/nvme0n1p5 maj-min: 259:5
  ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%)
  used: 79.3 MiB (31.0%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
  System Temperatures: cpu: 35.5 C mobo: N/A
  GPU: device: amdgpu temp: 34.0 C device: nouveau temp: N/A
  Processes: 286 Uptime: 11h 35m wakeups: 13 Memory: 7.2 GiB
  used: 2.95 GiB (40.9%) Init: systemd v: 248 tool: systemctl Compilers:
  gcc: 11.1.0 Packages: 1124 pacman: 1120 lib: 257 flatpak: 4 Shell: Zsh
  v: 5.8 running-in: konsole inxi: 3.3.03
And again AMD GPU :see_no_evil:
I don’t run into this issue with kde plasma on manjaro or endeavor. Very weird. Seems that sddm fixed the issue
This behaviour happens due to the fact that your hardware has dual GPUs and GDM sometimes starts before kernel DRM has the graphic drivers ready.
On Manjaro Gnome, I’d recommend doing Early KMS as explained in the Arch Wiki.
You would need to do this just for one of the GPUs, tipically for the integrated one.
For example, if your integrated GPU is the AMD, you need to add amdgpu to the modules line in the file /etc/mkinitcpio.conf
MODULES=(amdgpu)
Then, you need to regenerate your initramfs with the mkinitcpio script:
sudo mkinitcpio -P
Be aware that this setting should persist across updates, unless there is an update to the mkinitcpio package and you overwrite your configuration with the .pacnew file coming along the update.
Again, this is just my suggestion. Hope that helps!
I had the same issue of endeavour os gnome (with gnome 40) as well. I will try to install it again soon and I will try this method and I’ll let you know what happens. Thanks!
Also just remembered something. When I install opensuse tumbleweed gnome, I do not face this issue. Seems distro specific.
Nope, it is version specific, always. Different Distros could use different versions and even use different patches.
Oh ok, seems that whatever opensuse does works
