Around a week ago I started having a problem with one of my Manjaro laptops where the login screen became unusable. The central widget with the username doesn’t appear, no clicks seem to work, but the clock widget is working. I can SSH into the system.
I have a couple of laptops with the same Manjaro and Gnome config. Only the one with an Intel GPU is having this problem, two with Nvidia are fine.
I can’t pinpoint which upgrade broke it. I tried downgrading gdm, gnome-shell, and mkinitcpio (these were updated recently). It may actually be the dbus-daemon’s fault, but I didn’t downgrade that, since downgrading that may be too problematic.
Any suggestions as to what might be the cause and how to fix it?
On 6.6 kernel, the journal is spammed with these warning messages:
sty 25 21:11:24 lemur /usr/lib/gdm-wayland-session[5269]: dbus-daemon[5269]: [session uid=120 pid=5269] The maximum number of pending replies for ":1.3" (uid=120 pid=5282 comm="/usr/bin/gnome-shell") has been reached (max_replies_per_connection=50000)
On kernel 5.15 a different warning message is spammed:
sty 25 18:44:14 lemur gnome-shell[3460]: Attempting to call back into JSAPI during the sweeping phase of GC. This is most likely caused by not destroying a Clutter actor or Gtk+ widget with ::destroy signals connected, but can also be caused by using the destroy(), dispose(), or remove() vfuncs. Because it would crash the application, it has been blocked and the JS callback not invoked.
The offending signal was g-properties-changed on GDBusProxy 0x560ae4b481a0.
== Stack trace for context 0x560ae2bd50c0 ==
#0 560ae2c9c0b8 i resource:///org/gnome/shell/ui/init.js:21 (3ed696c70ba0 @ 48)
On that kernel the gnome-shell is doing a coredump.
inxi --full --admin --filter --width output for the affected laptop:
Kernel: 6.6.10-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
clocksource: tsc available: acpi_pm
parameters: initrd=\deaaf6ad665c40d881a9ebd980b3a4b1\6.6.10-1-MANJARO\microcode-intel-ucode.img
initrd=\deaaf6ad665c40d881a9ebd980b3a4b1\6.6.10-1-MANJARO\initrd
root=/dev/mapper/priv_systems-manjaro rw rootflags=subvol=@
cryptdevice=UUID=5e1bd4b3-0260-42bf-9afb-aec5f29a31a9:crypt_priv_systems
systemd.machine_id=deaaf6ad665c40d881a9ebd980b3a4b1
Console: pty pts/0 DM: GDM v: 45.0.1 Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: System76 product: Lemur Pro v: lemp11
serial: <superuser required> Chassis: type: 9 serial: <superuser required>
Mobo: System76 model: Lemur Pro v: lemp11 serial: <superuser required>
UEFI: coreboot v: 2023-09-08_42bf7a6 date: 09/08/2023
ID-1: BAT0 charge: 49.4 Wh (70.0%) condition: 70.6/73.9 Wh (95.5%) volts: 7.5
min: 7.7 model: Notebook BAT type: Li-ion serial: <filter>
status: discharging cycles: 149
Info: model: 12th Gen Intel Core i7-1255U bits: 64 type: MST AMCP
arch: Alder Lake level: v3 note: check built: 2021+
process: Intel 7 (10nm ESF) family: 6 model-id: 0x9A (154) stepping: 4
microcode: 0x430
Topology: cpus: 1x cores: 10 mt: 2 tpc: 2 st: 8 threads: 12 smt: enabled
cache: L1: 928 KiB desc: d-8x32 KiB, 2x48 KiB; i-2x32 KiB, 8x64 KiB
L2: 6.5 MiB desc: 2x1.2 MiB, 2x2 MiB L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 2232 high: 4100 min/max: 400/4700:3500 scaling:
driver: intel_pstate governor: powersave cores: 1: 4100 2: 3999 3: 3999
4: 4049 5: 400 6: 2110 7: 2212 8: 2837 9: 400 10: 400 11: 1881 12: 400
bogomips: 62688
Type: spectre_v2 mitigation: Enhanced / Automatic IBRS, IBPB: conditional,
RSB filling, PBRSB-eIBRS: SW sequence
Device-1: Intel Alder Lake-UP3 GT2 [Iris Xe Graphics] vendor: CLEVO/KAPOK
driver: i915 v: kernel arch: Gen-12.2 process: Intel 10nm built: 2021-22+
ports: active: none off: eDP-1 empty: DP-1, DP-2, DP-3, DP-4, HDMI-A-1
bus-ID: 00:02.0 chip-ID: 8086:46a8 class-ID: 0300
Device-2: Bison BisonCam NB Pro driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-7:2 chip-ID: 5986:214c
Display: server: X.org v: 1.21.1.10 with: Xwayland v: 23.2.3
compositor: gnome-shell driver: X: loaded: modesetting alternate: fbdev,vesa
dri: iris gpu: i915 tty: 212x23
Monitor-1: eDP-1 model: ChiMei InnoLux 0x1408 built: 2019 res: 1920x1080
dpi: 158 gamma: 1.2 size: 309x173mm (12.17x6.81") diag: 354mm (13.9")
ratio: 16:9 modes: 1920x1080
device: 1 drv: swrast surfaceless: drv: iris inactive: gbm,wayland,x11
API: OpenGL v: 4.6 compat-v: 4.5 vendor: mesa v: 23.3.3-manjaro1.1
note: console (EGL sourced) renderer: Mesa Intel Graphics (ADL GT2),
llvmpipe (LLVM 16.0.6 256 bits)
Device-1: Intel Alder Lake PCH-P High Definition Audio vendor: CLEVO/KAPOK
driver: snd_hda_intel v: kernel alternate: snd_sof_pci_intel_tgl
bus-ID: 00:1f.3 chip-ID: 8086:51c8 class-ID: 0403
API: ALSA v: k6.6.10-1-MANJARO status: kernel-api with: aoss
Server-3: PipeWire v: 1.0.0 status: off with: wireplumber status: active
tools: pw-cli,wpctl
Server-4: PulseAudio v: 16.1 status: off with: pulseaudio-alsa type: plugin
tools: pacat,pactl
Device-1: Intel Alder Lake-P PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:51f0 class-ID: 0280
IF-ID-1: br-53919a9e03e2 state: down mac: <filter>
IF-ID-2: br-b8cdac03077b state: down mac: <filter>
IF-ID-3: docker0 state: down mac: <filter>
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:3 chip-ID: 8087:0026
class-ID: e001
Report: btmgmt ID: hci0 rfk-id: 0 state: up address: <filter> bt-v: 5.2
lmp-v: 11 status: discoverable: no pairing: no class-ID: 10c
Local Storage: total: 1.82 TiB used: 756.42 GiB (40.6%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 PRO 2TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 5B2QGXA7 temp: 28.9 C
scheme: GPT
ID-1: / raw-size: 1.18 TiB size: 1.18 TiB (100.00%) used: 755.94 GiB (62.7%)
fs: btrfs dev: /dev/dm-2 maj-min: 254:2 mapped: priv_systems-manjaro
ID-2: /home raw-size: 1.18 TiB size: 1.18 TiB (100.00%)
used: 755.94 GiB (62.7%) fs: btrfs dev: /dev/dm-2 maj-min: 254:2
ID-3: /var/log raw-size: 1.18 TiB size: 1.18 TiB (100.00%)
System Temperatures: cpu: 77.0 C mobo: N/A
Fan Speeds (rpm): cpu: 4968
Processes: 298 Uptime: 29m wakeups: 0 Memory: total: 40 GiB note: est.
available: 39.02 GiB used: 2.61 GiB (6.7%) Init: systemd v: 255
Packages: 2276 pm: pacman pkgs: 2271 libs: 525 tools: gnome-software,pamac
pm: flatpak pkgs: 5 Shell: Zsh v: 5.9 running-in: pty pts/0 inxi: 3.3.31
Maybe these bugs are related:
- Bug #2042909 “keyboard backlight slider and automatic brightness...” : Bugs : gnome-shell package : Ubuntu
- Bug #2044336 “gnome-shell freezes while flooding the log with: A...” : Bugs : gnome-shell package : Ubuntu
Also, my problem looks similar to the one described in Strange behaviour after GNOME 45 update
