Gnome-keyring 42.0 and autologin
I use autologin in Gnome. Wwhen upgrading to gnome-keyring 42.0
.There is an ERROR in journalctl:
gdm-autologin]: gkr-pam: couldn't unlock the login keyring
Thats normal, when you use autologin, the keyring cannot be unlocked automaticly (afaik).
==> Better “warning level 4” than error (3) or better better notice (5)???
gdm-autologin]: gkr-pam: couldn’t unlock the login keyring
and:
Terminal gives the message "discover_other_daemon: 1
Look into: GNOME/Keyring - ArchWiki
Solution:
systemctl --user mask gnome-keyring-daemon.service
and
systemctl --user mask gnome-keyring-daemon.socket
Continuing:
It’s only necessary to disable gnome-keyring-daemon.service.
Additional:
go to: /etc/ xdg/autostart/ and create a folder “OFF”;
move the (3) entries containing “gnome-keyring” into this directory, and reboot.
==> Messages in journald have disappeared.
