Gnome hangs after opening certain programs
When opening programs like nvidia x server settings, discord or even the settings, Gnome hangs and stops being responsive for a moment. The cursor stays put on a same spot on the screen even if I’m moving the mouse. And does not allow to switch between running programs. What is causing this? Is there a fix?.
I’m using proprietary video-nvidia-340xx driver.
Hello and welcome,
At least provide this information from terminal:
inxi -Fxza --no-host
Would be useful for us to give you some advice. Please use </> to properly format the output text or ``` above and bellow it.
Here it is.
  Kernel: 5.7.15-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.1.0
  parameters: BOOT_IMAGE=/boot/vmlinuz-5.7-x86_64
  root=UUID=fc318805-8fb5-4378-82cb-d704668e66cf rw quiet splash
  nouveau.modeset=0 apparmor=1 security=apparmor udev.log_priority=3
  Desktop: GNOME 3.36.5 tk: GTK 3.24.22 wm: gnome-shell dm: GDM 3.36.3
  Distro: Manjaro Linux
  Type: Laptop System: Dell product: Precision M4500 v: 0001
  serial: <filter> Chassis: type: 9 serial: <filter>
  Mobo: Dell model: 0RRH3K v: A02 serial: <filter> BIOS: Dell v: A16
  date: 05/12/2017
  ID-1: BAT0 charge: 2.3 Wh condition: 2.3/94.1 Wh (2%) volts: 12.4/11.2
  model: Samsung SDI DELL C207208 type: Li-ion serial: <filter> status: Full
  Topology: Quad Core model: Intel Core i7 X 920 bits: 64 type: MT MCP
  arch: Nehalem family: 6 model-id: 1E (30) stepping: 5 microcode: A
  L2 cache: 8192 KiB
  flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 31942
  Speed: 2309 MHz min/max: 1199/2000 MHz boost: enabled Core speeds (MHz):
  1: 1197 2: 1197 3: 1197 4: 1197 5: 1197 6: 1197 7: 1197 8: 1197
  Type: l1tf
  Type: mds status: Vulnerable: Clear CPU buffers attempted, no microcode;
  SMT vulnerable
  Device-1: NVIDIA GT216GLM [Quadro FX 880M] vendor: Dell driver: nvidia
  v: 340.108 alternate: nouveau bus ID: 01:00.0 chip ID: 10de:0a3c
  Device-2: Ricoh HD Webcam type: USB driver: uvcvideo bus ID: 1-1.4:3
  chip ID: 05ca:1814
  Display: x11 server: X.Org 1.20.8 compositor: gnome-shell driver: nvidia
  display ID: :1 screens: 1
  Screen-1: 0 s-res: 1920x1080 s-dpi: 143 s-size: 341x191mm (13.4x7.5")
  s-diag: 391mm (15.4")
  Monitor-1: DP-3 res: 1920x1080 hz: 60 dpi: 142 size: 344x194mm (13.5x7.6")
  diag: 395mm (15.5")
  OpenGL: renderer: Quadro FX 880M/PCIe/SSE2 v: 3.3.0 NVIDIA 340.108
  direct render: Yes
  Device-1: Intel 5 Series/3400 Series High Definition Audio vendor: Dell
  driver: snd_hda_intel v: kernel bus ID: 00:1b.0 chip ID: 8086:3b56
  Device-2: NVIDIA GT216 HDMI Audio vendor: Dell driver: snd_hda_intel
  v: kernel bus ID: 01:00.1 chip ID: 10de:0be2
  Sound Server: ALSA v: k5.7.15-1-MANJARO
  Device-1: Intel 82577LM Gigabit Network vendor: Dell driver: e1000e
  v: 3.2.6-k port: 8040 bus ID: 00:19.0 chip ID: 8086:10ea
  Device-2: Intel Centrino Advanced-N 6200 driver: iwlwifi v: kernel
  port: 7000 bus ID: 03:00.0 chip ID: 8086:422c
  Local Storage: total: 149.05 GiB used: 42.16 GiB (28.3%)
  ID-1: /dev/sda vendor: Seagate model: ST9160310AS size: 149.05 GiB
  block size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
  serial: <filter> rev: 0303 scheme: MBR
  ID-1: / raw size: 140.25 GiB size: 137.05 GiB (97.72%)
  used: 42.16 GiB (30.8%) fs: ext4 dev: /dev/sda1
  ID-1: swap-1 type: partition size: 8.80 GiB used: 1.5 MiB (0.0%)
  priority: -2 dev: /dev/sda2
  System Temperatures: cpu: 65.0 C mobo: N/A sodimm: 45.0 C gpu: nvidia
  temp: 58 C
  Fan Speeds (RPM): cpu: 2880
  Processes: 310 Uptime: 20h 26m Memory: 7.77 GiB used: 4.13 GiB (53.2%)
  Init: systemd v: 245 Compilers: gcc: 10.1.0 Packages: pacman: 1276
  lib: 356 flatpak: 0 Shell: Zsh v: 5.8 running in: gnome-terminal
  inxi: 3.1.05
Just a heads-up:
It seems you have
as KBP … but yet
AFAIK there should be no alternate there.
Can you check /etc/modprobe.d/mhwd-gpu.conf if has this lines:
blacklist nouveau
blacklist ttm
blacklist drm_kms_helper
blacklist drm
I suppose you are not using Wayland session. Is that correct?
From terminal
echo $XDG_SESSION_TYPE
Please also check the extensions you use, disable them for a moment and see if the hang is still happening when opening applications.
what $XDG_SESSION_TYPE prints
x11
/etc/modprobe.d/mhwd-gpu.conf content
## Generated by mhwd - Manjaro Hardware Detection
blacklist nouveau
blacklist ttm
blacklist drm
I disabled some of the extensions that modify the topbar. Gnome no longer hangs but I still experience some slowdown when opening discord.
Is an Electron application and for sure has some long list of protocols to do before is opened. Mind you, but the slowness is probably due to the rotational HDD your system has. I see nothing wrong per se with your setup.
Now you have to identify exactly what extension is causing the hang, so you don’t drop the usage of all of them.
I tried and enabled the extensions back. Gnome no longer hangs when they are active.
I ran dmesg -l emerg,alert,crit,err,warn
this is what I got:
[33322.243603] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33322.433422] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33322.449036] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33322.633007] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33322.666006] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33322.833660] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33322.866506] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33322.999802] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33323.215759] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33323.282033] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33323.298841] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33323.332807] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33323.349708] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33323.649364] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33324.095496] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33324.095842] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33324.096253] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33324.176064] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33324.327473] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33324.437709] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33324.768737] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33325.435143] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33325.456223] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33325.547931] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33325.550519] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33325.550948] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33325.551311] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33325.631814] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33325.656065] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33325.677187] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33325.797942] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33326.028469] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33326.062670] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33326.194447] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33326.201826] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33326.412142] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33326.440686] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33326.786868] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33326.787273] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33326.787648] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33326.789521] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33326.872884] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33326.922504] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33326.989619] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33327.031015] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33327.041020] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33327.074607] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33327.089226] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33327.121483] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33327.137395] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33328.321639] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33328.381861] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33331.140749] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33331.153625] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33331.172973] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33331.402089] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33332.299260] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33332.322986] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33332.392593] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33332.443689] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33335.782992] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33335.988994] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33336.037502] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33339.425011] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33340.545971] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33340.561868] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33340.705802] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33340.718676] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33340.726994] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33344.191039] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33344.760087] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33344.774958] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33344.786226] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33344.966251] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33344.983016] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33345.010863] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33345.270017] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33345.302905] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33345.500249] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33345.578932] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33345.882056] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33345.908126] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33345.938522] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33346.049838] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33346.066516] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33346.266327] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33346.282845] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33346.299237] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33346.450410] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33346.517445] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33346.734859] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33346.905442] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33346.915540] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33347.843569] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33347.843864] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33347.875121] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33348.230984] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33349.729109] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33349.751781] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33349.767769] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33349.845901] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33349.847891] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33350.812000] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33350.832448] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33350.853721] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33351.303399] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33351.399555] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33352.066407] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33353.221430] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33353.221839] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33353.222250] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33353.249166] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33353.297643] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33361.782517] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33362.349337] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33362.449789] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33362.849709] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33362.867563] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33363.341762] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33363.372395] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33363.381138] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33363.383383] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33363.549528] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33363.786747] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33363.833126] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33363.850722] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33363.882596] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33363.932835] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33363.949068] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33364.015802] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33364.382391] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33367.332597] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33367.383748] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33367.399280] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33367.982987] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33368.733563] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33368.972120] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33368.984268] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33369.282915] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33369.463967] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33369.499520] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33369.515649] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33370.034947] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33370.082089] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33370.531056] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33370.551014] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33370.568198] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33371.222951] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33372.551730] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33373.768156] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33373.999668] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33374.232537] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33374.337458] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33374.359089] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33375.199298] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33375.310469] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33375.750459] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33375.779514] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33375.873541] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33375.882393] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33376.270918] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33376.300903] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33376.332717] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33376.450338] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33376.468734] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33376.682479] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33376.899316] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33376.998810] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33377.036554] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33377.036971] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33377.074737] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33377.099677] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33377.257684] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33377.276888] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33377.306221] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33377.315729] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33377.732931] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33377.767877] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33377.818312] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33378.767432] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33378.986168] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33379.349974] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33379.383428] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33379.525678] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33379.526079] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33380.082113] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33380.086255] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33380.516115] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33380.782706] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33381.315576] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33381.476736] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33381.498743] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33381.516839] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33382.079904] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33382.116200] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33382.316367] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33382.399052] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33382.615645] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33383.238669] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33383.272116] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33383.289459] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33383.354802] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33383.659830] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33384.246071] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33384.303727] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33384.322879] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33384.411811] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33384.435470] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33384.662883] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33384.683260] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33384.719698] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33385.013546] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33385.019548] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33385.055238] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33385.103957] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33385.236769] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33385.318435] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33385.332636] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33386.164954] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33386.313899] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33386.456718] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33386.581988] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33389.061644] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33390.009015] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33390.042106] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33390.076033] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33390.092470] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33390.195487] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33391.090126] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33391.142786] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33391.176204] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33391.359551] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33391.426773] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33392.086233] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33392.326708] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33392.377802] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33392.408623] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33392.768182] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33392.825375] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33393.163997] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33393.877713] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33394.592709] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33394.626494] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33394.645363] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33394.659419] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33394.861837] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33394.888704] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33394.892563] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33394.946877] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33395.137426] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33395.676229] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33395.691896] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33395.850719] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33395.858646] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33395.937505] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33396.003827] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33396.376367] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33396.410946] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33396.493195] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33397.132704] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33397.434577] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33397.461564] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33397.672022] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33397.705740] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33398.196630] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33398.213061] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33398.243615] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33398.280725] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33398.291852] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33398.600158] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33398.721542] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33398.793565] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33398.808593] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33398.975639] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33399.051246] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33399.224647] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33400.398674] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33400.410534] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33401.177359] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33401.645418] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33403.139585] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33403.172545] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33403.480852] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33403.547367] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33403.580262] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33403.646868] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33403.763247] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33403.945625] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33403.962640] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33403.978765] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33404.029470] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33404.061925] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33404.081269] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33404.158922] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33405.084762] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33405.085246] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33405.717125] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33405.724837] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33405.740153] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33405.775103] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33407.696756] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33407.747716] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33407.813052] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33407.862637] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33408.079945] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33409.195156] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33409.375003] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33409.378312] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33410.166191] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33411.332044] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33412.695812] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33412.715253] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33413.076755] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33413.825739] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33414.939561] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33414.966775] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33415.525338] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33415.544349] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33415.545320] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33415.592534] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33416.100927] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33416.188196] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33417.723291] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33417.738511] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33418.137822] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33418.167550] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33418.167945] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33418.220371] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33418.235732] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33418.419238] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33418.502822] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33420.634242] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33420.749615] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33421.000461] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33421.950034] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33422.150710] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33422.550904] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33422.766800] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33422.903438] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33423.051361] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33423.465386] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33423.513581] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33423.562913] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33423.568232] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33423.933319] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33424.120760] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33425.514254] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33425.665998] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33425.831611] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33426.280890] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33426.432625] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33426.551108] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33439.033207] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33439.248946] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33439.512402] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33439.555800] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33439.605869] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33439.613690] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33439.655612] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33439.708193] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33440.198563] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33440.331623] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33441.525282] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33441.556468] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33442.159934] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33442.509988] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33442.532199] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33442.543433] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33442.575739] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33442.593988] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33443.217511] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33443.252418] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33443.254333] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33443.264394] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33443.455122] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33443.513578] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33444.656176] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33444.751047] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33444.795140] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33444.810336] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33444.844705] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33444.925818] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33445.042143] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33445.138751] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33445.147416] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33445.147729] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33445.164644] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33445.186635] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33445.193334] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33445.229222] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33445.259058] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33445.345469] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33445.402114] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33445.453727] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33445.475464] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33445.761253] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33445.802966] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33445.819545] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33445.836401] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33446.306600] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33446.542642] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33446.609320] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33446.742751] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33446.825524] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33446.885343] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33447.010020] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33447.042457] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33447.070615] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33447.076511] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33448.042135] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33448.069409] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33448.125169] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33448.128392] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33448.491719] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33448.501969] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33448.658745] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33448.677194] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33448.936339] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33448.966175] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33449.113705] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33449.117245] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33452.021207] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33453.953974] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33453.987594] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33453.993726] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33454.196222] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33455.365967] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33456.136895] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33456.179722] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33456.300360] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33456.309928] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33456.450819] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33456.543117] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33457.007821] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33457.021683] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33457.079556] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33457.082602] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33457.353012] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33457.419413] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33457.569125] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33457.586787] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33457.911957] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33457.945746] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33459.053010] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33459.075695] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33459.136513] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33459.271719] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33459.386916] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33460.903331] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33460.986117] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33461.003656] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33462.085931] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33462.136762] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33462.270029] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33462.285465] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33462.485938] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33462.518926] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33462.569889] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33462.719375] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33462.736475] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33462.752637] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33462.786790] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33462.803081] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33462.887813] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33463.436319] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33463.452356] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33463.790751] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33464.488485] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33464.506273] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33464.785896] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33466.137242] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33467.603404] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33467.702836] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33467.757463] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33467.786555] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33467.836352] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33468.137380] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33468.153597] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33468.187124] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33468.213323] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33468.219946] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33468.237037] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33468.327019] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33468.335791] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33468.402612] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33468.419796] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33468.536564] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33468.869327] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33468.902550] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33468.952014] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33469.085157] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33469.119355] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33469.136672] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33469.202122] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33469.236116] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33469.619056] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33469.652538] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33469.685868] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33469.702948] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33469.736370] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33469.752573] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33469.769416] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33469.785773] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33469.803195] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33469.887636] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33470.130348] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33470.160858] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33470.236530] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33470.402792] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33471.719461] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33471.735915] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33471.835464] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33481.186621] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33482.011808] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33482.011866] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33482.102647] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33482.119930] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33482.471333] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33482.505233] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33482.658549] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33482.676804] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33482.803311] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33491.902698] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33492.054429] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33492.072312] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33492.118887] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33492.187129] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33492.204098] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33492.253007] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33492.870239] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33492.890518] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33493.785458] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33493.985866] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33495.494962] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33495.552619] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33495.569472] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33495.591991] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33495.686702] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33495.702319] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33495.736039] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33495.768750] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33495.787796] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33495.808557] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33495.889258] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33495.902424] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33495.971486] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33495.991432] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33496.010402] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33496.024286] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33496.046738] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33496.052430] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33496.269202] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33496.712428] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33496.754322] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33496.920094] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33497.536802] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33499.454545] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33499.665807] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33499.735845] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33499.869320] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33499.986790] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33500.750180] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33501.087353] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33502.330574] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33502.404550] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33502.418842] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33502.569482] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33502.608681] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33504.850605] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33505.129094] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33505.139991] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33505.168771] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33505.369763] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33506.936743] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33507.036119] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33507.053963] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33507.140297] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33507.142790] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33507.195473] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33507.930387] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33507.980456] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33508.048710] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33508.088739] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33508.117256] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33508.585646] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33509.012601] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33509.146101] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33509.219806] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33509.548637] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33509.566432] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33509.592449] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33509.747537] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33509.776096] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33509.779493] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33510.118569] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33510.163060] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33511.364455] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33511.561543] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33516.379504] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33517.971815] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33517.972292] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33519.399197] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33520.770325] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33520.881033] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33520.899319] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33520.983180] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33521.031474] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33522.342098] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33522.362170] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33522.925609] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33522.996859] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33523.368754] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33523.382986] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33523.907263] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33525.428341] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33525.510413] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33528.630132] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33528.812064] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33528.829193] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33528.845343] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33536.062931] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33536.113296] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33536.129338] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33536.213511] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33536.384666] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33536.519093] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33536.526049] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33536.560411] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33540.359240] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33540.380060] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33540.524454] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33540.687021] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33540.736389] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33540.953887] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33541.675627] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33544.637834] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33545.068083] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33545.238924] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33546.069217] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33546.155232] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33546.168103] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33546.185232] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33546.203261] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33546.218173] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33546.270238] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33546.302086] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33546.334269] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33546.334640] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33546.385635] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33547.275410] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33547.280337] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33547.297320] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33547.315067] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33547.341412] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33547.349216] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33547.381269] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33547.482292] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33547.498196] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33547.501222] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33547.501618] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33547.505666] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33548.037271] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33549.035880] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33550.089317] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33550.749901] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33551.871265] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33554.944853] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33557.948455] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33561.022882] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33564.058198] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33567.061540] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33590.330653] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33590.341417] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33591.024519] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33591.029397] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33591.088650] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33591.322677] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33591.627778] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33591.636318] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33591.636916] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33592.394130] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33592.430460] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33592.463576] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33592.476175] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33599.098946] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33599.221929] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33599.601193] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33600.284070] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33600.392523] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33600.393392] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33600.476298] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33600.519105] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33604.977102] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33604.981288] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33605.111134] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33605.128929] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33605.879343] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33606.601264] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33607.775604] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33608.694713] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33609.837543] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33609.854800] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33609.886785] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33610.531824] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33610.548550] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33614.141904] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33614.156353] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33615.256667] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33615.257059] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33615.649288] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33615.655247] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33615.739350] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33622.448205] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33622.488719] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33630.953162] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33631.007629] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33631.092707] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33632.557957] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33632.566974] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33632.945765] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33633.801144] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33633.916225] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33634.233369] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33635.859253] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33636.000016] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33636.036896] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33638.116007] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33638.234004] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33641.075281] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33641.091090] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33642.430096] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33642.443369] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33693.897292] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33693.972795] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33693.991282] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33694.316799] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33694.584085] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33694.589273] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33694.889261] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33694.903545] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33696.002578] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33696.983159] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33697.004908] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33697.005315] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33701.200634] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33704.564865] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33704.815602] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33704.924736] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33705.107302] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33713.522485] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33713.577017] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33713.579469] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33713.579860] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33713.889478] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33755.202520] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33755.541112] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33755.548600] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33755.671707] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33755.688459] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33755.803919] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33756.011212] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33756.972424] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33757.016417] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33757.051977] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33757.118710] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33757.135623] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33757.152729] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33772.310824] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33772.349525] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33773.225871] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33773.574583] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33773.574992] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33773.575381] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33774.674427] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33774.709731] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33782.319484] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33782.335268] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33782.577943] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33782.604237] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33782.870319] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33782.884565] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33782.917445] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33783.167766] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33783.467978] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33783.518695] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33783.602197] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33783.670815] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33785.800798] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33785.809229] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33786.798941] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33786.899807] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33787.382479] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33787.609584] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33801.497528] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33801.504520] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33801.551623] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33801.568417] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33801.819642] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33801.939813] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33802.095403] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33802.111363] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33802.270313] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33802.294624] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33802.387082] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33802.443791] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33802.461094] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33802.653564] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33802.808592] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33802.809118] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33802.813833] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33802.814282] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33802.819462] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33862.776772] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33862.799712] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33862.901003] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33862.983402] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33863.016608] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33863.082895] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33864.543505] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33881.306657] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33881.341364] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33881.341772] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33881.557334] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33881.841217] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33881.993554] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33882.407407] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33882.590379] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33882.857342] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33883.196975] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33883.211515] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33883.227317] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33883.240304] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33883.290170] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33883.307437] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33883.321300] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33883.324192] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33896.311198] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33897.446262] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33897.470187] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33897.487093] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33897.503715] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33897.641366] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33939.295197] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33939.394985] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33939.703046] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33939.790400] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33939.798954] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33941.581362] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33941.594676] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33941.611849] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33941.795062] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33941.944484] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33941.995053] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33942.044954] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33942.097140] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33942.161575] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33942.445550] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33942.461593] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33942.569499] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33942.569847] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33942.579308] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33942.594536] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33942.845028] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33942.866048] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33942.962486] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33942.978497] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33943.061326] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33943.078472] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33943.193290] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33943.212018] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33943.228052] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33943.278044] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33943.395666] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33945.147922] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33945.182248] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33945.221317] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33945.248949] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33945.265235] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33946.481021] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33947.356790] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33947.406937] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33949.890569] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33949.891039] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33950.206297] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33950.536970] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33950.601037] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33950.601527] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33950.789045] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33952.754416] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33952.893673] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33953.060845] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33953.089363] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33953.135739] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33953.144612] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33953.167799] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33953.211993] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33953.255812] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33953.886793] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33954.208313] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33954.251167] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33954.296239] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33955.500128] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33955.512033] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33955.529193] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33955.623332] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33955.623748] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33956.045547] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33956.295656] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33956.402754] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33957.757902] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33958.326533] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33960.352205] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33962.737605] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33962.768907] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33962.992120] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33963.008844] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33963.049279] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33963.701148] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33963.781728] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33969.932854] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33970.907416] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33970.907859] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33971.376232] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33973.966610] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33974.525513] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33982.960278] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33986.033106] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[33986.050555] NVRM: Xid (PCI:0000:01:00): 56, CMDre 00000000 00000080 00000000 00000005 00000005
[36104.448375] CE: hpet6 increased min_delta_ns to 20115 nsec
[39657.774072] kauditd_printk_skb: 17 callbacks suppressed
[39677.012646] kauditd_printk_skb: 10 callbacks suppressed
Should I worry?
Some people report xid are hardware error, many just from heat or by failing hardware.
https://docs.nvidia.com/deploy/xid-errors/index.html
But i’m not familiar with any of this.
Maybe for that you can disable hpet See if there are options in BIOS or maybe use hpet=disable command line parameter.
No clue about this one.
Can you do a test with 5.4 kernel ?
I have it Installed but I have never changed kernels. How do I do that?
You chose it from GRUB BOOT Menu. If you don’t see it, just press Shift or Esc right after the BIOS loads, and select the 5.4 kernel from the list.
ran dmesg -l emerg,alert,crit,err,warn on kernel 5.4.58-1.
And I got this:
[    0.502259] core: CPUID marked event: 'bus cycles' unavailable
[    0.704738] MDS CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/mds.html for more details.
[    0.742265]  #5 #6 #7
[    0.890113] pci 0000:00:1c.2: bridge has subordinate 05 but max busn 08
[    1.489498] i8042: Warning: Keylock active
[    2.589284] usb 2-1.8: config 0 descriptor??
[   14.853201] nvidia: loading out-of-tree module taints kernel.
[   14.853220] nvidia: module license 'NVIDIA' taints kernel.
[   14.853222] Disabling lock debugging due to kernel taint
[   14.872949] NVRM: loading NVIDIA UNIX x86_64 Kernel Module  340.108  Wed Dec 11 11:06:58 PST 2019
[   17.449825] kauditd_printk_skb: 5 callbacks suppressed
[   19.160351] wmi_bus wmi_bus-PNP0C14:00: WQBC data block query control method not found
[   19.313634]  excluding 0xe3100000-0xe4d2ffff 0xe5770000-0xe59fffff
[   19.313651]  excluding 0xe9b00000-0xe9cfffff
[   20.133604] ACPI Warning: SystemIO range 0x0000000000000428-0x000000000000042F conflicts with OpRegion 0x0000000000000400-0x000000000000047F (\PMIO) (20190816/utaddress-204)
[   20.133623] ACPI Warning: SystemIO range 0x0000000000000540-0x000000000000054F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20190816/utaddress-204)
[   20.133631] ACPI Warning: SystemIO range 0x0000000000000530-0x000000000000053F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20190816/utaddress-204)
[   20.133638] ACPI Warning: SystemIO range 0x0000000000000500-0x000000000000052F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20190816/utaddress-204)
[   20.133645] lpc_ich: Resource conflict(s) found affecting gpio_ich
[   20.195707] i801_smbus 0000:00:1f.3: Accelerometer lis3lv02d is present on SMBus but its address is unknown, skipping registration
[   20.743295] dell-smbios PNP0C14:00-A80593CE-A997-11DA-B012-B622A1EF5492: WMI SMBIOS userspace interface not supported(0), try upgrading to a newer BIOS
[   21.928200] kvm: VM_EXIT_LOAD_IA32_PERF_GLOBAL_CTRL does not work properly. Using workaround
[   22.126797] iwlwifi 0000:03:00.0: can't disable ASPM; OS doesn't have ASPM control
[   22.127732] iwlwifi 0000:03:00.0: Direct firmware load for iwlwifi-6000-6.ucode failed with error -2
[   22.127796] iwlwifi 0000:03:00.0: Direct firmware load for iwlwifi-6000-5.ucode failed with error -2
[   28.309899] uvcvideo 1-1.4:1.0: Entity type for entity Extension 4 was not initialized!
[   28.309903] uvcvideo 1-1.4:1.0: Entity type for entity Extension 3 was not initialized!
[   28.309906] uvcvideo 1-1.4:1.0: Entity type for entity Processing 2 was not initialized!
[   28.309909] uvcvideo 1-1.4:1.0: Entity type for entity Camera 1 was not initialized!
[   56.039474] kauditd_printk_skb: 1 callbacks suppressed
[   59.643328] ACPI Warning: \_SB.PCI0.PEG3.VID._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20190816/nsarguments-59)
[   60.484708] NVRM: Your system is not currently configured to drive a VGA console
[   60.484710] NVRM: on the primary VGA device. The NVIDIA Linux graphics driver
[   60.484711] NVRM: requires the use of a text-mode VGA console. Use of other console
[   60.484713] NVRM: drivers including, but not limited to, vesafb, may result in
[   60.484714] NVRM: corruption and stability problems, and is not supported.
[   60.539734] ------------[ cut here ]------------
[   60.539740] Bad or missing usercopy whitelist? Kernel memory exposure attempt detected from SLUB object 'nvidia_stack_t' (offset 11864, size 3)!
[   60.539759] WARNING: CPU: 3 PID: 1236 at mm/usercopy.c:75 usercopy_warn+0x7a/0x90
[   60.539761] Modules linked in: ccm ebtable_filter ebtables ip6table_filter ip6_tables iptable_filter squashfs loop uvcvideo videobuf2_vmalloc videobuf2_memops videobuf2_v4l2 videobuf2_common videodev mc iwldvm mac80211 libarc4 snd_hda_codec_hdmi snd_hda_codec_idt snd_hda_codec_generic snd_hda_intel intel_powerclamp snd_intel_nhlt joydev iwlwifi snd_hda_codec coretemp mousedev snd_hda_core kvm_intel dell_rbtn kvm snd_hwdep cfg80211 irqbypass snd_pcm dell_laptop snd_timer snd ledtrig_audio dell_wmi e1000e rfkill soundcore iTCO_wdt dell_smbios iTCO_vendor_support dell_smm_hwmon dcdbas intel_cstate psmouse i2c_i801 wmi_bmof dell_wmi_descriptor lpc_ich input_leds sparse_keymap intel_uncore ppdev battery pcmcia i7core_edac mac_hid parport_pc yenta_socket pcmcia_rsrc parport pcmcia_core wmi pcspkr evdev ac dell_smo8800 acpi_cpufreq uinput nvidia(POE) drm agpgart crypto_user ip_tables x_tables ext4 crc32c_generic crc16 mbcache jbd2 hid_generic usbhid hid sr_mod cdrom sd_mod serio_raw atkbd libps2
[   60.539820]  ahci libahci libata sdhci_pci cqhci firewire_ohci sdhci crc32c_intel scsi_mod ehci_pci firewire_core mmc_core ehci_hcd crc_itu_t i8042 serio
[   60.539835] CPU: 3 PID: 1236 Comm: Xorg Tainted: P           OE     5.4.58-1-MANJARO #1
[   60.539837] Hardware name: Dell Inc. Precision M4500/0RRH3K, BIOS A16 05/12/2017
[   60.539841] RIP: 0010:usercopy_warn+0x7a/0x90
[   60.539845] Code: 9b 41 51 49 89 c0 49 89 f1 49 0f 45 d2 49 c7 c2 6f f0 4d 9b 48 89 f9 48 c7 c7 50 22 4f 9b 4d 0f 45 d3 4c 89 d6 e8 94 b0 dd ff <0f> 0b 48 83 c4 18 c3 48 c7 c6 fa 4c 50 9b 49 89 f1 48 89 f0 eb 99
[   60.539847] RSP: 0018:ffff9b82414bfbc0 EFLAGS: 00010282
[   60.539849] RAX: 0000000000000000 RBX: 0000000000000003 RCX: 0000000000000000
[   60.539851] RDX: 0000000000000001 RSI: 0000000000000096 RDI: 00000000ffffffff
[   60.539853] RBP: ffff91c487c15e5b R08: 00000000000003d0 R09: 0000000000000001
[   60.539855] R10: 0000000000000000 R11: 0000000000000001 R12: ffff91c487c15e58
[   60.539856] R13: 0000000000000001 R14: ffff91c487c15e58 R15: ffff91c487c15ea0
[   60.539859] FS:  00007f5b032fa280(0000) GS:ffff91c4a7ac0000(0000) knlGS:0000000000000000
[   60.539861] CS:  0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[   60.539863] CR2: 00007f5afe7ddf40 CR3: 000000020ceaa000 CR4: 00000000000006e0
[   60.539865] Call Trace:
[   60.539873]  __check_object_size+0x136/0x147
[   60.540060]  os_memcpy_to_user+0x27/0x50 [nvidia]
[   60.540248]  _nv001372rm+0xa5/0x260 [nvidia]
[   60.540445]  ? _nv004782rm+0x4eba/0x5500 [nvidia]
[   60.540640]  ? _nv004329rm+0xec/0xf0 [nvidia]
[   60.540832]  ? _nv004324rm+0xca/0x650 [nvidia]
[   60.541015]  ? _nv015124rm+0x576/0x5c0 [nvidia]
[   60.541202]  ? _nv000694rm+0x2e/0x60 [nvidia]
[   60.541373]  ? _nv000789rm+0x5f5/0x8b0 [nvidia]
[   60.541379]  ? _raw_spin_unlock_irqrestore+0x20/0x40
[   60.541546]  ? rm_ioctl+0x73/0x100 [nvidia]
[   60.541715]  ? nvidia_ioctl+0x171/0x4b0 [nvidia]
[   60.541882]  ? nvidia_frontend_unlocked_ioctl+0x40/0x60 [nvidia]
[   60.541886]  ? do_vfs_ioctl+0x3eb/0x6c0
[   60.541892]  ? syscall_trace_enter+0x1d1/0x2e0
[   60.541895]  ? ksys_ioctl+0x5e/0x90
[   60.541898]  ? __x64_sys_ioctl+0x16/0x20
[   60.541901]  ? do_syscall_64+0x49/0x90
[   60.541905]  ? entry_SYSCALL_64_after_hwframe+0x44/0xa9
[   60.541910] ---[ end trace 42ed7c417ee9a111 ]---
[  112.508264] kauditd_printk_skb: 2 callbacks suppressed
