I currently have two identical Dell 1080p monitors connected to an Intel NUC8i7HVK running Manjaro Linux GNOME.
Once logged in, I can easily change the desktop display setup, i.e. tell GNOME which display is located where and which display is the primary display, in the “Displays” pane of GNOME settings.
However, The login screen is then still the wrong way around!
Does anyone know how to alter the display configuration of the GDM login screen without physically re-arranging the monitors?
My output of inxi -Fazy
is below:
Kernel: 5.8.11-1-MANJARO x86_64 bits: 64 compiler: N/A
parameters: BOOT_IMAGE=/boot/vmlinuz-5.8-x86_64
root=UUID=f5245ffc-4c91-4b47-b905-1d35123f8237 rw quiet apparmor=1
security=apparmor udev.log_priority=3 mitigations=off
Desktop: GNOME 3.36.6 tk: GTK 3.24.23 wm: gnome-shell dm: GDM 3.36.3
Distro: Manjaro Linux
Type: Desktop System: Intel Client Systems product: NUC8i7HVK v: J71485-504
serial: <filter> Chassis: Intel Corporation type: 3 v: 2.0 serial: <filter>
Mobo: Intel model: NUC8i7HVB v: J68196-504 serial: <filter> UEFI: Intel
v: HNKBLi70.86A.0059.2019.1112.1124 date: 11/12/2019
Topology: Quad Core model: Intel Core i7-8809G bits: 64 type: MT MCP
arch: Kaby Lake family: 6 model-id: 9E (158) stepping: 9 microcode: D6
L2 cache: 8192 KiB
bogomips: 49618
Speed: 1961 MHz min/max: 800/8300 MHz Core speeds (MHz): 1: 2566 2: 2884
3: 2666 4: 2888 5: 2816 6: 2675 7: 2889 8: 2757
Type: l1tf mitigation: PTE Inversion; VMX: vulnerable
Type: mds status: Vulnerable; SMT vulnerable
Type: meltdown status: Vulnerable
Type: spectre_v1 status: Vulnerable: __user pointer sanitization and
usercopy barriers only; no swapgs barriers
Type: spectre_v2 status: Vulnerable, IBPB: disabled, STIBP: disabled
Type: srbds status: Vulnerable
Device-1: Intel HD Graphics 630 driver: i915 v: kernel bus ID: 00:02.0
chip ID: 8086:591b
Device-2: AMD Polaris 22 XT [Radeon RX Vega M GH] vendor: Intel
driver: amdgpu v: kernel bus ID: 01:00.0 chip ID: 1002:694c
Display: wayland server: X.Org 1.20.9 compositor: gnome-shell
driver: amdgpu,ati,intel unloaded: modesetting,radeon alternate: fbdev,vesa
display ID: :0 screens: 1
Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1016x286mm (40.0x11.3")
s-diag: 1055mm (41.6")
Monitor-1: XWAYLAND0 res: 1920x1080 hz: 60 dpi: 92
size: 530x300mm (20.9x11.8") diag: 609mm (24")
Monitor-2: XWAYLAND1 res: 1920x1080 hz: 60 dpi: 92
OpenGL: renderer: AMD VEGAM (DRM 3.38.0 5.8.11-1-MANJARO LLVM 10.0.1)
v: 4.6 Mesa 20.1.8 direct render: Yes
Device-1: Intel CM238 HD Audio driver: snd_hda_intel v: kernel
bus ID: 00:1f.3 chip ID: 8086:a171
Device-2: AMD Polaris 22 HDMI Audio vendor: Intel driver: snd_hda_intel
v: kernel bus ID: 01:00.1 chip ID: 1002:ab08
Device-3: Logitech Logitech StreamCam type: USB
driver: hid-generic,snd-usb-audio,usbhid,uvcvideo bus ID: 6-1:2
chip ID: 046d:0893 serial: <filter>
Sound Server: ALSA v: k5.8.11-1-MANJARO
Device-1: Intel Ethernet I219-LM driver: e1000e v: 3.2.6-k port: f040
bus ID: 00:1f.6 chip ID: 8086:15b7
Device-2: Intel I210 Gigabit Network driver: igb v: 5.6.0-k port: b000
bus ID: 05:00.0 chip ID: 8086:157b
IF: enp5s0 state: down mac: <filter>
Device-3: Intel Wireless 8265 / 8275 driver: iwlwifi v: kernel port: b000
bus ID: 06:00.0 chip ID: 8086:24fd
IF: wlp6s0 state: down mac: <filter>
Local Storage: total: 953.87 GiB used: 539.99 GiB (56.6%)
ID-1: /dev/nvme0n1 vendor: Samsung model: SSD 970 PRO 1TB size: 953.87 GiB
block size: physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4
serial: <filter> rev: 1B2QEXP7 scheme: GPT
ID-2: /dev/nvme1n1 vendor: A-Data model: SX8200PNP size: 953.87 GiB
serial: <filter> rev: SS0411B scheme: GPT
ID-1: / raw size: 953.57 GiB size: 937.61 GiB (98.33%)
used: 290.86 GiB (31.0%) fs: ext4 dev: /dev/nvme0n1p2
ID-1: swap-1 type: file size: 32.00 GiB used: 0 KiB (0.0%) priority: -2
file: /swapfile
System Temperatures: cpu: 62.5 C mobo: 29.8 C gpu: amdgpu temp: 49 C
Processes: 297 Uptime: 3h 44m Memory: 31.28 GiB used: 6.24 GiB (19.9%)
Init: systemd v: 246 Compilers: gcc: 10.2.0 alt: 8 Packages: pacman: 1754
lib: 420 flatpak: 0 Shell: Zsh v: 5.8 running in: gnome-terminal
inxi: 3.1.05
