Gnome 46 Bug Source audio missing when disconnecting HDMI out
Manjaro latest stable Gnome 46. Laptop with extra monitor.
Had a fresh install. Now disconnecting second monitor with speakers (single monitor config) HDMI with audio out and selected as source will cause a bug which there is no audio source available. No audio playback. Checking quick settings show volume slider with no audio output and going into Gnome Settings shows the same, no audio source available.
From there if I plug in headphones the sources reappear, no audio playback but I can now select Speakers or Headphones from the Gnome Settings and audio will play, however If I instead plug the HDMI back in everything goes back to normal.
Here some logs
may 19 23:15:20 dell systemd[587]: Started Application launched by gnome-shell.
may 19 23:15:20 dell systemd[587]: Created slice Slice /app/org.gnome.Terminal.
may 19 23:15:20 dell systemd[587]: Starting GNOME Terminal Server...
may 19 23:15:21 dell systemd[587]: Started GNOME Terminal Server.
may 19 23:15:21 dell gnome-shell[674]: meta_window_set_stack_position_no_sync: >
may 19 23:15:21 dell systemd[587]: Started VTE child process 5171 launched by g>
may 19 23:15:21 dell tracker-miner-fs-3[5206]: (tracker-extract-3:5206): GLib-G>
may 19 23:15:34 dell tracker-miner-fs-3[5250]: (tracker-extract-3:5250): GLib-G>
may 19 23:15:39 dell gsd-media-keys[837]: Unable to get default sink
may 19 23:15:39 dell gsd-media-keys[837]: Unable to get default source
may 19 23:15:50 dell tracker-miner-fs-3[5279]: (tracker-extract-3:5279): GLib-G>
may 19 23:16:13 dell rtkit-daemon[710]: Successfully made thread 708 of process>
may 19 23:16:13 dell rtkit-daemon[710]: Supervising 6 threads of 4 processes of>
may 19 23:16:13 dell gsd-media-keys[837]: Unable to get default sink
may 19 23:16:13 dell gsd-media-keys[837]: Unable to get default source
may 19 23:16:13 dell rtkit-daemon[710]: Supervising 5 threads of 3 processes of>
lines 1-23
lines 1-22
lines 1-23
may 19 23:15:21 dell gnome-shell[674]: meta_window_set_stack_position_no_sync: as>
may 19 23:15:21 dell systemd[587]: Started VTE child process 5171 launched by gno>
may 19 23:15:21 dell tracker-miner-fs-3[5206]: (tracker-extract-3:5206): GLib-GIO>
may 19 23:15:34 dell tracker-miner-fs-3[5250]: (tracker-extract-3:5250): GLib-GIO>
may 19 23:15:50 dell tracker-miner-fs-3[5279]: (tracker-extract-3:5279): GLib-GIO>
may 19 23:16:13 dell rtkit-daemon[710]: Successfully made thread 708 of process 6>
may 19 23:16:13 dell rtkit-daemon[710]: Supervising 6 threads of 4 processes of 1>
may 19 23:16:13 dell rtkit-daemon[710]: Supervising 5 threads of 3 processes of 1>
lines 1-23
may 19 23:15:21 dell gnome-shell[674]: meta_window_set_stack_position_no_sync: asse>
may 19 23:15:21 dell systemd[587]: Started VTE child process 5171 launched by gnome>
may 19 23:15:21 dell tracker-miner-fs-3[5206]: (tracker-extract-3:5206): GLib-GIO-W>
may 19 23:15:34 dell tracker-miner-fs-3[5250]: (tracker-extract-3:5250): GLib-GIO-W>
may 19 23:15:50 dell tracker-miner-fs-3[5279]: (tracker-extract-3:5279): GLib-GIO-W>
may 19 23:16:13 dell rtkit-daemon[710]: Successfully made thread 708 of process 674>
may 19 23:16:13 dell rtkit-daemon[710]: Supervising 6 threads of 4 processes of 1 u>
may 19 23:16:13 dell rtkit-daemon[710]: Supervising 5 threads of 3 processes of 1 u>
lines 1-23...skipping...
may 19 23:15:21 dell gnome-shell[674]: meta_window_set_stack_position_no_sync: asser>
may 19 23:15:21 dell systemd[587]: Started VTE child process 5171 launched by gnome->
may 19 23:15:21 dell tracker-miner-fs-3[5206]: (tracker-extract-3:5206): GLib-GIO-WA>
may 19 23:15:34 dell tracker-miner-fs-3[5250]: (tracker-extract-3:5250): GLib-GIO-WA>
may 19 23:15:50 dell tracker-miner-fs-3[5279]: (tracker-extract-3:5279): GLib-GIO-WA>
may 19 23:16:13 dell rtkit-daemon[710]: Successfully made thread 708 of process 674 >
may 19 23:16:13 dell rtkit-daemon[710]: Supervising 6 threads of 4 processes of 1 us>
may 19 23:16:13 dell rtkit-daemon[710]: Supervising 5 threads of 3 processes of 1 us>
may 19 23:16:18 dell systemd[587]: Started Application launched by gnome-shell.
lines 1-24
may 19 23:15:21 dell gnome-shell[674]: meta_window_set_stack_position_no_sync: asserti>
may 19 23:15:21 dell systemd[587]: Started VTE child process 5171 launched by gnome-te>
may 19 23:15:21 dell tracker-miner-fs-3[5206]: (tracker-extract-3:5206): GLib-GIO-WARN>
may 19 23:15:34 dell tracker-miner-fs-3[5250]: (tracker-extract-3:5250): GLib-GIO-WARN>
may 19 23:15:50 dell tracker-miner-fs-3[5279]: (tracker-extract-3:5279): GLib-GIO-WARN>
may 19 23:16:13 dell rtkit-daemon[710]: Successfully made thread 708 of process 674 ow>
may 19 23:16:13 dell rtkit-daemon[710]: Supervising 6 threads of 4 processes of 1 user>
may 19 23:16:13 dell rtkit-daemon[710]: Supervising 5 threads of 3 processes of 1 user>
lines 1-24
may 19 23:15:21 dell gnome-shell[674]: meta_window_set_stack_position_no_sync: assertion >
may 19 23:15:21 dell systemd[587]: Started VTE child process 5171 launched by gnome-termi>
may 19 23:15:21 dell tracker-miner-fs-3[5206]: (tracker-extract-3:5206): GLib-GIO-WARNING>
may 19 23:15:34 dell tracker-miner-fs-3[5250]: (tracker-extract-3:5250): GLib-GIO-WARNING>
may 19 23:15:50 dell tracker-miner-fs-3[5279]: (tracker-extract-3:5279): GLib-GIO-WARNING>
may 19 23:16:13 dell rtkit-daemon[710]: Successfully made thread 708 of process 674 owned>
may 19 23:16:13 dell rtkit-daemon[710]: Supervising 6 threads of 4 processes of 1 users.
may 19 23:16:13 dell rtkit-daemon[710]: Supervising 5 threads of 3 processes of 1 users.
lines 1-24
may 19 23:15:21 dell gnome-shell[674]: meta_window_set_stack_position_no_sync: assertion 'wi>
may 19 23:15:21 dell systemd[587]: Started VTE child process 5171 launched by gnome-terminal>
may 19 23:15:21 dell tracker-miner-fs-3[5206]: (tracker-extract-3:5206): GLib-GIO-WARNING **>
may 19 23:15:34 dell tracker-miner-fs-3[5250]: (tracker-extract-3:5250): GLib-GIO-WARNING **>
may 19 23:15:50 dell tracker-miner-fs-3[5279]: (tracker-extract-3:5279): GLib-GIO-WARNING **>
may 19 23:16:13 dell rtkit-daemon[710]: Successfully made thread 708 of process 674 owned by>
lines 1-24
may 19 23:15:21 dell gnome-shell[674]: meta_window_set_stack_position_no_sync: assertion 'window>
may 19 23:15:21 dell systemd[587]: Started VTE child process 5171 launched by gnome-terminal-ser>
may 19 23:15:21 dell tracker-miner-fs-3[5206]: (tracker-extract-3:5206): GLib-GIO-WARNING **: 23>
may 19 23:15:34 dell tracker-miner-fs-3[5250]: (tracker-extract-3:5250): GLib-GIO-WARNING **: 23>
may 19 23:15:50 dell tracker-miner-fs-3[5279]: (tracker-extract-3:5279): GLib-GIO-WARNING **: 23>
may 19 23:16:13 dell rtkit-daemon[710]: Successfully made thread 708 of process 674 owned by '10>
lines 1-24...skipping...
may 19 23:15:21 dell gnome-shell[674]: meta_window_set_stack_position_no_sync: assertion 'window->s>
may 19 23:15:21 dell systemd[587]: Started VTE child process 5171 launched by gnome-terminal-server>
may 19 23:15:21 dell tracker-miner-fs-3[5206]: (tracker-extract-3:5206): GLib-GIO-WARNING **: 23:15>
may 19 23:15:34 dell tracker-miner-fs-3[5250]: (tracker-extract-3:5250): GLib-GIO-WARNING **: 23:15>
may 19 23:15:50 dell tracker-miner-fs-3[5279]: (tracker-extract-3:5279): GLib-GIO-WARNING **: 23:15>
may 19 23:16:13 dell rtkit-daemon[710]: Successfully made thread 708 of process 674 owned by '1000'>
may 19 23:16:20 dell gnome-shell[674]: meta_window_set_stack_position_no_sync: assertion 'window->s>
lines 1-25
may 19 23:15:21 dell gnome-shell[674]: meta_window_set_stack_position_no_sync: assertion 'window->st>
may 19 23:15:21 dell systemd[587]: Started VTE child process 5171 launched by gnome-terminal-server >
may 19 23:15:21 dell tracker-miner-fs-3[5206]: (tracker-extract-3:5206): GLib-GIO-WARNING **: 23:15:>
may 19 23:15:34 dell tracker-miner-fs-3[5250]: (tracker-extract-3:5250): GLib-GIO-WARNING **: 23:15:>
may 19 23:15:50 dell tracker-miner-fs-3[5279]: (tracker-extract-3:5279): GLib-GIO-WARNING **: 23:15:>
may 19 23:16:13 dell rtkit-daemon[710]: Successfully made thread 708 of process 674 owned by '1000' >
may 19 23:16:20 dell gnome-shell[674]: meta_window_set_stack_position_no_sync: assertion 'window->st>
lines 1-25
may 19 23:15:21 dell gnome-shell[674]: meta_window_set_stack_position_no_sync: assertion 'window->sta>
may 19 23:15:21 dell systemd[587]: Started VTE child process 5171 launched by gnome-terminal-server p>
may 19 23:15:21 dell tracker-miner-fs-3[5206]: (tracker-extract-3:5206): GLib-GIO-WARNING **: 23:15:2>
may 19 23:15:34 dell tracker-miner-fs-3[5250]: (tracker-extract-3:5250): GLib-GIO-WARNING **: 23:15:3>
may 19 23:15:50 dell tracker-miner-fs-3[5279]: (tracker-extract-3:5279): GLib-GIO-WARNING **: 23:15:5>
may 19 23:16:13 dell rtkit-daemon[710]: Successfully made thread 708 of process 674 owned by '1000' h>
may 19 23:16:13 dell rtkit-daemon[710]: Successfully made thread 708 of process 674 owned by '1000' R>
may 19 23:16:20 dell gnome-shell[674]: meta_window_set_stack_position_no_sync: assertion 'window->sta>
lines 1-25
may 19 23:15:21 dell gnome-shell[674]: meta_window_set_stack_position_no_sync: assertion 'window->stac>
may 19 23:15:21 dell systemd[587]: Started VTE child process 5171 launched by gnome-terminal-server pr>
may 19 23:15:21 dell tracker-miner-fs-3[5206]: (tracker-extract-3:5206): GLib-GIO-WARNING **: 23:15:21>
may 19 23:15:34 dell tracker-miner-fs-3[5250]: (tracker-extract-3:5250): GLib-GIO-WARNING **: 23:15:34>
may 19 23:15:50 dell tracker-miner-fs-3[5279]: (tracker-extract-3:5279): GLib-GIO-WARNING **: 23:15:50>
may 19 23:16:13 dell rtkit-daemon[710]: Successfully made thread 708 of process 674 owned by '1000' hi>
may 19 23:16:13 dell rtkit-daemon[710]: Successfully made thread 708 of process 674 owned by '1000' RT>
may 19 23:16:20 dell gnome-shell[674]: meta_window_set_stack_position_no_sync: assertion 'window->stac>
lines 1-25
may 19 23:15:21 dell gnome-shell[674]: meta_window_set_stack_position_no_sync: assertion 'window->stack>
may 19 23:15:21 dell systemd[587]: Started VTE child process 5171 launched by gnome-terminal-server pro>
may 19 23:15:21 dell tracker-miner-fs-3[5206]: (tracker-extract-3:5206): GLib-GIO-WARNING **: 23:15:21.>
may 19 23:15:34 dell tracker-miner-fs-3[5250]: (tracker-extract-3:5250): GLib-GIO-WARNING **: 23:15:34.>
may 19 23:15:50 dell tracker-miner-fs-3[5279]: (tracker-extract-3:5279): GLib-GIO-WARNING **: 23:15:50.>
may 19 23:16:13 dell rtkit-daemon[710]: Successfully made thread 708 of process 674 owned by '1000' hig>
may 19 23:16:13 dell rtkit-daemon[710]: Successfully made thread 708 of process 674 owned by '1000' RT >
may 19 23:16:20 dell gnome-shell[674]: meta_window_set_stack_position_no_sync: assertion 'window->stack>
lines 1-25...skipping...
may 19 23:15:21 dell gnome-shell[674]: meta_window_set_stack_position_no_sync: assertion 'window->stack_>
may 19 23:15:21 dell systemd[587]: Started VTE child process 5171 launched by gnome-terminal-server proc>
may 19 23:15:21 dell tracker-miner-fs-3[5206]: (tracker-extract-3:5206): GLib-GIO-WARNING **: 23:15:21.6>
may 19 23:15:34 dell tracker-miner-fs-3[5250]: (tracker-extract-3:5250): GLib-GIO-WARNING **: 23:15:34.1>
may 19 23:15:50 dell tracker-miner-fs-3[5279]: (tracker-extract-3:5279): GLib-GIO-WARNING **: 23:15:50.3>
may 19 23:16:13 dell rtkit-daemon[710]: Successfully made thread 708 of process 674 owned by '1000' high>
may 19 23:16:13 dell rtkit-daemon[710]: Successfully made thread 708 of process 674 owned by '1000' RT a>
may 19 23:16:20 dell gnome-shell[674]: meta_window_set_stack_position_no_sync: assertion 'window->stack_>
may 19 23:16:20 dell gnome-control-c[5331]: gvc_mixer_control_get_stream_from_device: assertion 'GVC_IS_>
lines 1-26
may 19 23:15:21 dell gnome-shell[674]: meta_window_set_stack_position_no_sync: assertion 'window->stack_p>
may 19 23:15:21 dell systemd[587]: Started VTE child process 5171 launched by gnome-terminal-server proce>
may 19 23:15:21 dell tracker-miner-fs-3[5206]: (tracker-extract-3:5206): GLib-GIO-WARNING **: 23:15:21.61>
may 19 23:15:34 dell tracker-miner-fs-3[5250]: (tracker-extract-3:5250): GLib-GIO-WARNING **: 23:15:34.14>
may 19 23:15:50 dell tracker-miner-fs-3[5279]: (tracker-extract-3:5279): GLib-GIO-WARNING **: 23:15:50.38>
may 19 23:16:13 dell rtkit-daemon[710]: Successfully made thread 708 of process 674 owned by '1000' high >
may 19 23:16:13 dell rtkit-daemon[710]: Successfully made thread 708 of process 674 owned by '1000' RT at>
may 19 23:16:20 dell gnome-shell[674]: meta_window_set_stack_position_no_sync: assertion 'window->stack_p>
may 19 23:16:20 dell gnome-control-c[5331]: gvc_mixer_control_get_stream_from_device: assertion 'GVC_IS_M>
lines 1-26
may 19 23:15:21 dell gnome-shell[674]: meta_window_set_stack_position_no_sync: assertion 'window->stack_pos>
may 19 23:15:21 dell systemd[587]: Started VTE child process 5171 launched by gnome-terminal-server process>
may 19 23:15:21 dell tracker-miner-fs-3[5206]: (tracker-extract-3:5206): GLib-GIO-WARNING **: 23:15:21.616:>
may 19 23:15:34 dell tracker-miner-fs-3[5250]: (tracker-extract-3:5250): GLib-GIO-WARNING **: 23:15:34.149:>
may 19 23:15:50 dell tracker-miner-fs-3[5279]: (tracker-extract-3:5279): GLib-GIO-WARNING **: 23:15:50.386:>
may 19 23:16:13 dell rtkit-daemon[710]: Successfully made thread 708 of process 674 owned by '1000' high pr>
may 19 23:16:13 dell rtkit-daemon[710]: Successfully made thread 708 of process 674 owned by '1000' RT at p>
may 19 23:16:20 dell gnome-shell[674]: meta_window_set_stack_position_no_sync: assertion 'window->stack_pos>
may 19 23:16:20 dell gnome-control-c[5331]: gvc_mixer_control_get_stream_from_device: assertion 'GVC_IS_MIX>
lines 1-26
I can go specifics and have screenshots to reproduce it step-by-step.
Hardware and more info:
  Kernel: 6.6.30-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
  Desktop: GNOME v: 46.1 Distro: Manjaro base: Arch Linux
  Type: Laptop System: Dell product: Inspiron 15-3567 v: N/A
    serial: <superuser required>
  Mobo: Dell model: 04YVDP v: A00 serial: <superuser required> UEFI: Dell
    v: 2.9.0 date: 01/17/2019
  Info: dual core model: Intel Core i5-7200U bits: 64 type: MT MCP
    arch: Amber/Kaby Lake note: check rev: 9 cache: L1: 128 KiB L2: 512 KiB
    L3: 3 MiB
  Speed (MHz): avg: 400 min/max: 400/3100 cores: 1: 400 2: 400 3: 400 4: 400
    bogomips: 21607
  Device-1: Intel HD Graphics 620 vendor: Dell driver: i915 v: kernel
    arch: Gen-9.5 bus-ID: 00:02.0
  Device-2: Sunplus Innovation Integrated_Webcam_HD driver: uvcvideo
    type: USB bus-ID: 1-5:4
  Display: wayland server: X.Org v: 23.2.6 with: Xwayland v: 23.2.6
    compositor: gnome-shell driver: gpu: i915 resolution: 1920x1080~60Hz
  API: EGL v: 1.5 drivers: iris,swrast platforms:
    active: wayland,x11,surfaceless,device inactive: gbm
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.0.6-manjaro1.1
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel HD Graphics 620 (KBL GT2)
  Device-1: Intel Sunrise Point-LP HD Audio vendor: Dell driver: snd_hda_intel
    v: kernel bus-ID: 00:1f.3
  API: ALSA v: k6.6.30-2-MANJARO status: kernel-api
  Server-1: JACK v: 1.9.22 status: off
  Server-2: PipeWire v: 1.0.5 status: active
  Device-1: Qualcomm Atheros QCA9565 / AR9565 Wireless Network Adapter
    vendor: Dell Vostro 3470 driver: ath9k v: kernel bus-ID: 01:00.0
  Device-2: Realtek RTL810xE PCI Express Fast Ethernet vendor: Dell
    driver: r8169 v: kernel port: e000 bus-ID: 02:00.0
  Device-1: Qualcomm Atheros driver: btusb v: 0.8 type: USB bus-ID: 1-8:8
  Local Storage: total: 447.13 GiB used: 93.04 GiB (20.8%)
  ID-1: /dev/sda vendor: Kingston model: SA400S37480G size: 447.13 GiB
  ID-1: / size: 80 GiB used: 34.13 GiB (42.7%) fs: btrfs dev: /dev/sda6
  ID-2: /boot/efi size: 299.4 MiB used: 600 KiB (0.2%) fs: vfat
    dev: /dev/sda8
  ID-3: /home size: 250.84 GiB used: 58.91 GiB (23.5%) fs: btrfs
    dev: /dev/sda7
  ID-4: /var/log size: 80 GiB used: 34.13 GiB (42.7%) fs: btrfs
    dev: /dev/sda6
  ID-1: swap-1 type: partition size: 15.9 GiB used: 256 KiB (0.0%)
    dev: /dev/sda5
  System Temperatures: cpu: 51.0 C pch: 50.0 C mobo: 50.0 C
  Fan Speeds (rpm): cpu: 2539
  Memory: total: 8 GiB available: 7.63 GiB used: 3.15 GiB (41.3%)
  Processes: 278 Uptime: 41m Init: systemd
  Packages: 1425 Compilers: clang: 17.0.6 gcc: 13.2.1 Shell: Zsh v: 5.9
    inxi: 3.3.34
Thank you for the time and attention. Have a good day!
Probably try the --no-pager parameter. The log would be then readable. :wink:
Probably a Gnome bug directly, not Manjaro itself. Have you tried another GUI like “pavucontrol”? Does the same effect occur?
Did you try restarting pipewire?
systemctl --user restart pipewire
Thanks for the help.
No, restarting pipewire didn’t help. Nor does restarting the laptop.
So, I made this log, does it help now?
journalctl --since "5 min ago" --no-pager                        ✔
may 20 19:59:16 dell systemd[587]: Started Application launched by gnome-shell.
may 20 19:59:16 dell systemd[587]: Started app-flatpak-io.gitlab.librewolf\x2dcommunity-50328.scope.
may 20 19:59:19 dell gnome-shell[674]: ../glib/gobject/gsignal.c:2685: instance '0x564eec051000' has no handler with id '1014130'
may 20 19:59:38 dell io.gitlab.librewolf-community.desktop[50342]: Crash Annotation GraphicsCriticalError: |[0][GFX1-]: RenderCompositorSWGL failed mapping default framebuffer, no dt (t=22.1647) [GFX1-]: RenderCompositorSWGL failed mapping default framebuffer, no dt
may 20 20:00:34 dell systemd[587]: Started Application launched by gnome-shell.
may 20 20:00:34 dell systemd[587]: Starting GNOME Terminal Server...
may 20 20:00:34 dell systemd[587]: Started GNOME Terminal Server.
may 20 20:00:34 dell gnome-shell[674]: meta_window_set_stack_position_no_sync: assertion 'window->stack_position >= 0' failed
may 20 20:00:34 dell systemd[587]: Started VTE child process 50937 launched by gnome-terminal-server process 50927.
may 20 20:00:35 dell tracker-miner-fs-3[50971]: (tracker-extract-3:50971): GLib-GIO-WARNING **: 20:00:35.204: Error creating IO channel for /proc/self/mountinfo: Invalid argument (g-io-error-quark, 13)
may 20 20:00:46 dell systemd[587]: Stopping Multimedia Service Session Manager...
may 20 20:00:46 dell wireplumber[1180]: stopped by signal: Terminated
may 20 20:00:46 dell wireplumber[1180]: disconnected from pipewire
may 20 20:00:46 dell wireplumber[1180]: 0x55b56a3b9100: leaked proxy 0x55b56a423cc0 id:3
may 20 20:00:46 dell wireplumber[1180]: 0x55b56a3b9100: leaked proxy 0x55b56a4596a0 id:5
may 20 20:00:46 dell wireplumber[1180]: 0x55b56a3b9100: leaked proxy 0x55b56a42b4a0 id:7
may 20 20:00:46 dell wireplumber[1180]: 0x55b56a3b9100: leaked proxy 0x55b56a5945b0 id:8
may 20 20:00:46 dell wireplumber[1180]: 0x55b56a3b9100: leaked proxy 0x55b56a58d890 id:9
may 20 20:00:46 dell gsd-media-keys[837]: Unable to get default source
may 20 20:00:46 dell gsd-media-keys[837]: Unable to get default sink
may 20 20:00:46 dell tracker-miner-fs-3[50991]: (tracker-extract-3:50991): GLib-GIO-WARNING **: 20:00:46.555: Error creating IO channel for /proc/self/mountinfo: Invalid argument (g-io-error-quark, 13)
may 20 20:00:46 dell bluetoothd[686]: Endpoint unregistered: sender=:1.71 path=/MediaEndpoint/A2DPSource/ldac
may 20 20:00:46 dell bluetoothd[686]: Endpoint unregistered: sender=:1.71 path=/MediaEndpoint/A2DPSink/aptx_hd
may 20 20:00:46 dell bluetoothd[686]: Endpoint unregistered: sender=:1.71 path=/MediaEndpoint/A2DPSource/aptx_hd
may 20 20:00:46 dell bluetoothd[686]: Endpoint unregistered: sender=:1.71 path=/MediaEndpoint/A2DPSink/aac
may 20 20:00:46 dell bluetoothd[686]: Endpoint unregistered: sender=:1.71 path=/MediaEndpoint/A2DPSource/aac
may 20 20:00:46 dell bluetoothd[686]: Endpoint unregistered: sender=:1.71 path=/MediaEndpoint/A2DPSink/sbc
may 20 20:00:46 dell bluetoothd[686]: Endpoint unregistered: sender=:1.71 path=/MediaEndpoint/A2DPSource/sbc
may 20 20:00:46 dell bluetoothd[686]: Endpoint unregistered: sender=:1.71 path=/MediaEndpoint/A2DPSink/sbc_xq
may 20 20:00:46 dell bluetoothd[686]: Endpoint unregistered: sender=:1.71 path=/MediaEndpoint/A2DPSource/sbc_xq
may 20 20:00:46 dell bluetoothd[686]: Endpoint unregistered: sender=:1.71 path=/MediaEndpoint/A2DPSource/aptx_ll_1
may 20 20:00:46 dell bluetoothd[686]: Endpoint unregistered: sender=:1.71 path=/MediaEndpoint/A2DPSource/aptx_ll_0
may 20 20:00:46 dell bluetoothd[686]: Endpoint unregistered: sender=:1.71 path=/MediaEndpoint/A2DPSource/aptx_ll_duplex_1
may 20 20:00:46 dell bluetoothd[686]: Endpoint unregistered: sender=:1.71 path=/MediaEndpoint/A2DPSource/aptx_ll_duplex_0
may 20 20:00:46 dell bluetoothd[686]: Endpoint unregistered: sender=:1.71 path=/MediaEndpoint/A2DPSource/faststream
may 20 20:00:46 dell bluetoothd[686]: Endpoint unregistered: sender=:1.71 path=/MediaEndpoint/A2DPSource/faststream_duplex
may 20 20:00:46 dell bluetoothd[686]: Endpoint unregistered: sender=:1.71 path=/MediaEndpoint/A2DPSink/opus_05
may 20 20:00:46 dell bluetoothd[686]: Endpoint unregistered: sender=:1.71 path=/MediaEndpoint/A2DPSource/opus_05
may 20 20:00:46 dell bluetoothd[686]: Endpoint unregistered: sender=:1.71 path=/MediaEndpoint/A2DPSink/opus_05_duplex
may 20 20:00:46 dell bluetoothd[686]: Endpoint unregistered: sender=:1.71 path=/MediaEndpoint/A2DPSource/opus_05_duplex
may 20 20:00:46 dell systemd[587]: Stopped Multimedia Service Session Manager.
may 20 20:00:46 dell systemd[587]: wireplumber.service: Consumed 3.928s CPU time.
may 20 20:00:46 dell systemd[587]: Stopping PipeWire Multimedia Service...
may 20 20:00:46 dell xdg-desktop-por[1349]: Caught PipeWire error: connection error
may 20 20:00:46 dell systemd[587]: Stopped PipeWire Multimedia Service.
may 20 20:00:46 dell systemd[587]: pipewire.service: Consumed 38.025s CPU time.
may 20 20:00:46 dell systemd[587]: Started PipeWire Multimedia Service.
may 20 20:00:46 dell systemd[587]: Started Multimedia Service Session Manager.
may 20 20:00:46 dell rtkit-daemon[710]: Successfully made thread 51002 of process 51002 owned by '1000' high priority at nice level -11.
may 20 20:00:46 dell rtkit-daemon[710]: Supervising 4 threads of 3 processes of 1 users.
may 20 20:00:46 dell rtkit-daemon[710]: Successfully made thread 51010 of process 51002 owned by '1000' RT at priority 20.
may 20 20:00:46 dell rtkit-daemon[710]: Supervising 5 threads of 3 processes of 1 users.
may 20 20:00:46 dell rtkit-daemon[710]: Successfully made thread 51005 of process 51005 owned by '1000' high priority at nice level -11.
may 20 20:00:46 dell rtkit-daemon[710]: Supervising 6 threads of 4 processes of 1 users.
may 20 20:00:47 dell bluetoothd[686]: Endpoint registered: sender=:1.501 path=/MediaEndpoint/A2DPSource/ldac
may 20 20:00:47 dell bluetoothd[686]: Endpoint registered: sender=:1.501 path=/MediaEndpoint/A2DPSink/aptx_hd
may 20 20:00:47 dell bluetoothd[686]: Endpoint registered: sender=:1.501 path=/MediaEndpoint/A2DPSource/aptx_hd
may 20 20:00:47 dell bluetoothd[686]: Endpoint registered: sender=:1.501 path=/MediaEndpoint/A2DPSink/aac
may 20 20:00:47 dell bluetoothd[686]: Endpoint registered: sender=:1.501 path=/MediaEndpoint/A2DPSource/aac
may 20 20:00:47 dell bluetoothd[686]: Endpoint registered: sender=:1.501 path=/MediaEndpoint/A2DPSink/sbc
may 20 20:00:47 dell bluetoothd[686]: Endpoint registered: sender=:1.501 path=/MediaEndpoint/A2DPSource/sbc
may 20 20:00:47 dell bluetoothd[686]: Endpoint registered: sender=:1.501 path=/MediaEndpoint/A2DPSink/sbc_xq
may 20 20:00:47 dell bluetoothd[686]: Endpoint registered: sender=:1.501 path=/MediaEndpoint/A2DPSource/sbc_xq
may 20 20:00:47 dell bluetoothd[686]: Endpoint registered: sender=:1.501 path=/MediaEndpoint/A2DPSource/aptx_ll_1
may 20 20:00:47 dell bluetoothd[686]: Endpoint registered: sender=:1.501 path=/MediaEndpoint/A2DPSource/aptx_ll_0
may 20 20:00:47 dell bluetoothd[686]: Endpoint registered: sender=:1.501 path=/MediaEndpoint/A2DPSource/aptx_ll_duplex_1
may 20 20:00:47 dell bluetoothd[686]: Endpoint registered: sender=:1.501 path=/MediaEndpoint/A2DPSource/aptx_ll_duplex_0
may 20 20:00:47 dell bluetoothd[686]: Endpoint registered: sender=:1.501 path=/MediaEndpoint/A2DPSource/faststream
may 20 20:00:47 dell bluetoothd[686]: Endpoint registered: sender=:1.501 path=/MediaEndpoint/A2DPSource/faststream_duplex
may 20 20:00:47 dell bluetoothd[686]: Endpoint registered: sender=:1.501 path=/MediaEndpoint/A2DPSink/opus_05
may 20 20:00:47 dell bluetoothd[686]: Endpoint registered: sender=:1.501 path=/MediaEndpoint/A2DPSource/opus_05
may 20 20:00:47 dell bluetoothd[686]: Endpoint registered: sender=:1.501 path=/MediaEndpoint/A2DPSink/opus_05_duplex
may 20 20:00:47 dell bluetoothd[686]: Endpoint registered: sender=:1.501 path=/MediaEndpoint/A2DPSource/opus_05_duplex
may 20 20:00:47 dell bluetoothd[686]: src/gatt-database.c:database_add_chrc() Failed to create characteristic entry in database
may 20 20:00:47 dell bluetoothd[686]: src/gatt-database.c:database_add_service() Failed to add characteristic
may 20 20:00:47 dell bluetoothd[686]: src/gatt-database.c:database_add_app() Failed to add service
may 20 20:00:47 dell bluetoothd[686]: src/gatt-database.c:client_ready_cb() Failed to create GATT service entry in local database
may 20 20:00:47 dell wireplumber[51005]: org.bluez.GattManager1.RegisterApplication() failed: GDBus.Error:org.bluez.Error.Failed: Failed to create entry in database
may 20 20:00:47 dell wireplumber[51005]: [8:01:03.383974492] [51005] ERROR IPAModule ipa_module.cpp:172 Symbol ipaModuleInfo not found
may 20 20:00:47 dell wireplumber[51005]: [8:01:03.383998949] [51005] ERROR IPAModule ipa_module.cpp:292 v4l2-compat.so: IPA module has no valid info
may 20 20:00:47 dell wireplumber[51005]: [8:01:03.384044770] [51005]  INFO Camera camera_manager.cpp:284 libcamera v0.2.0
may 20 20:01:14 dell rtkit-daemon[710]: Successfully made thread 708 of process 674 owned by '1000' high priority at nice level 0.
may 20 20:01:14 dell rtkit-daemon[710]: Supervising 6 threads of 4 processes of 1 users.
may 20 20:01:14 dell gsd-media-keys[837]: Unable to get default sink
may 20 20:01:14 dell gsd-media-keys[837]: Unable to get default source
may 20 20:01:14 dell rtkit-daemon[710]: Supervising 5 threads of 3 processes of 1 users.
may 20 20:01:14 dell rtkit-daemon[710]: Successfully made thread 708 of process 674 owned by '1000' RT at priority 20.
may 20 20:01:27 dell xdg-desktop-por[1364]: Monitor 'Built-in display' has no configuration which is-current!
may 20 20:01:27 dell rtkit-daemon[710]: Successfully made thread 708 of process 674 owned by '1000' high priority at nice level 0.
may 20 20:01:27 dell rtkit-daemon[710]: Supervising 6 threads of 4 processes of 1 users.
may 20 20:01:27 dell rtkit-daemon[710]: Supervising 5 threads of 3 processes of 1 users.
may 20 20:01:27 dell rtkit-daemon[710]: Successfully made thread 708 of process 674 owned by '1000' RT at priority 20.
may 20 20:01:27 dell gsd-media-keys[837]: Unable to get default sink
may 20 20:01:27 dell gsd-media-keys[837]: Unable to get default source
may 20 20:01:58 dell tracker-miner-fs-3[51154]: (tracker-extract-3:51154): GLib-GIO-WARNING **: 20:01:58.269: Error creating IO channel for /proc/self/mountinfo: Invalid argument (g-io-error-quark, 13)
may 20 20:02:34 dell systemd[587]: vte-spawn-87e449a2-a542-4fa8-9a55-36b469291b2c.scope: Consumed 36.103s CPU time.
may 20 20:02:34 dell tracker-miner-fs-3[51209]: (tracker-extract-3:51209): GLib-GIO-WARNING **: 20:02:34.251: Error creating IO channel for /proc/self/mountinfo: Invalid argument (g-io-error-quark, 13)
may 20 20:02:34 dell systemd[587]: gnome-terminal-server.service: Consumed 10.242s CPU time.
may 20 20:02:35 dell systemd[587]: Started Application launched by gnome-shell.
may 20 20:02:36 dell systemd[587]: Starting GNOME Terminal Server...
may 20 20:02:36 dell systemd[587]: Started GNOME Terminal Server.
may 20 20:02:36 dell gnome-shell[674]: meta_window_set_stack_position_no_sync: assertion 'window->stack_position >= 0' failed
may 20 20:02:36 dell systemd[587]: Started VTE child process 51236 launched by gnome-terminal-server process 51229.
I also think is a Gnome issue but I usually start here.
Again, I was asking if the issue is a problem of the GUI (Gnome) or is it the backend/driver. Therefore I ask about other GUI’s what would be a quick test.
Gnome’s volume control is very limited. Therefore use pavucontrol to switch the profile for example.
Yeah it is now readable.
Probably it is related to gsd-media-keys ?
Share the output of:
pactl list cards
Yes sir!
pactl list cards                                                 ✔
Card #48
	Driver: alsa
	Owner Module: n/a
	Properties:
		api.acp.auto-port = "false"
		api.alsa.card = "0"
		api.alsa.card.longname = "HDA Intel PCH at 0xd1228000 irq 129"
		api.alsa.card.name = "HDA Intel PCH"
		api.alsa.path = "hw:0"
		api.alsa.use-acp = "true"
		api.dbus.ReserveDevice1.Priority = "-20"
		device.api = "alsa"
		device.bus = "pci"
		device.description = "Built-in Audio"
		device.enum.api = "udev"
		device.icon_name = "audio-card-analog-pci"
		device.name = "alsa_card.pci-0000_00_1f.3"
		device.nick = "HDA Intel PCH"
		device.plugged.usec = "7665564"
		device.product.id = "0x9d71"
		device.product.name = "Sunrise Point-LP HD Audio"
		device.subsystem = "sound"
		sysfs.path = "/devices/pci0000:00/0000:00:1f.3/sound/card0"
		device.vendor.id = "0x8086"
		media.class = "Audio/Device"
		factory.id = "14"
		client.id = "46"
		object.id = "48"
		object.serial = "48"
		object.path = "alsa:pcm:0"
		alsa.card = "0"
		alsa.long_card_name = "HDA Intel PCH at 0xd1228000 irq 129"
		alsa.mixer_name = "Realtek ALC3246"
		alsa.components = "HDA:10ec0256,1028078b,00100002 HDA:8086280b,80860101,00100000"
		alsa.id = "PCH"
		device.string = "0"
	Profiles:
		off: Off (sinks: 0, sources: 0, priority: 0, available: yes)
		output:analog-stereo+input:analog-stereo: Analog Stereo Duplex (sinks: 1, sources: 1, priority: 6565, available: yes)
		output:analog-stereo: Analog Stereo Output (sinks: 1, sources: 0, priority: 6500, available: yes)
		output:hdmi-stereo+input:analog-stereo: Digital Stereo (HDMI) Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 5965, available: yes)
		output:hdmi-stereo: Digital Stereo (HDMI) Output (sinks: 1, sources: 0, priority: 5900, available: yes)
		output:hdmi-stereo-extra1+input:analog-stereo: Digital Stereo (HDMI 2) Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 5765, available: no)
		output:hdmi-stereo-extra2+input:analog-stereo: Digital Stereo (HDMI 3) Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 5765, available: no)
		output:hdmi-stereo-extra1: Digital Stereo (HDMI 2) Output (sinks: 1, sources: 0, priority: 5700, available: no)
		output:hdmi-stereo-extra2: Digital Stereo (HDMI 3) Output (sinks: 1, sources: 0, priority: 5700, available: no)
		output:hdmi-surround+input:analog-stereo: Digital Surround 5.1 (HDMI) Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 865, available: yes)
		output:hdmi-surround: Digital Surround 5.1 (HDMI) Output (sinks: 1, sources: 0, priority: 800, available: yes)
		output:hdmi-surround-extra1+input:analog-stereo: Digital Surround 5.1 (HDMI 2) Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 665, available: no)
		output:hdmi-surround71-extra1+input:analog-stereo: Digital Surround 7.1 (HDMI 2) Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 665, available: no)
		output:hdmi-surround-extra2+input:analog-stereo: Digital Surround 5.1 (HDMI 3) Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 665, available: no)
		output:hdmi-surround71-extra2+input:analog-stereo: Digital Surround 7.1 (HDMI 3) Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 665, available: no)
		output:hdmi-surround-extra1: Digital Surround 5.1 (HDMI 2) Output (sinks: 1, sources: 0, priority: 600, available: no)
		output:hdmi-surround71-extra1: Digital Surround 7.1 (HDMI 2) Output (sinks: 1, sources: 0, priority: 600, available: no)
		output:hdmi-surround-extra2: Digital Surround 5.1 (HDMI 3) Output (sinks: 1, sources: 0, priority: 600, available: no)
		output:hdmi-surround71-extra2: Digital Surround 7.1 (HDMI 3) Output (sinks: 1, sources: 0, priority: 600, available: no)
		input:analog-stereo: Analog Stereo Input (sinks: 0, sources: 1, priority: 65, available: yes)
		pro-audio: Pro Audio (sinks: 4, sources: 1, priority: 1, available: yes)
	Active Profile: output:hdmi-stereo+input:analog-stereo
	Ports:
		analog-input-internal-mic: Internal Microphone (type: Mic, priority: 8900, latency offset: 0 usec, availability group: Legacy 1, availability unknown)
			Properties:
				port.type = "mic"
				port.availability-group = "Legacy 1"
				card.profile.port = "0"
			Part of profile(s): input:analog-stereo, output:analog-stereo+input:analog-stereo, output:hdmi-stereo+input:analog-stereo, output:hdmi-surround+input:analog-stereo, output:hdmi-stereo-extra1+input:analog-stereo, output:hdmi-surround-extra1+input:analog-stereo, output:hdmi-surround71-extra1+input:analog-stereo, output:hdmi-stereo-extra2+input:analog-stereo, output:hdmi-surround-extra2+input:analog-stereo, output:hdmi-surround71-extra2+input:analog-stereo
		analog-input-headphone-mic: Microphone (type: Mic, priority: 8700, latency offset: 0 usec, availability group: Legacy 2, not available)
			Properties:
				port.type = "mic"
				port.availability-group = "Legacy 2"
				card.profile.port = "1"
		analog-input-headset-mic: Headset Microphone (type: Headset, priority: 8800, latency offset: 0 usec, availability group: Legacy 2, not available)
			Properties:
				port.type = "headset"
				card.profile.port = "2"
		analog-output-speaker: Speakers (type: Speaker, priority: 10000, latency offset: 0 usec, availability group: Legacy 3, availability unknown)
			Properties:
				port.type = "speaker"
				port.availability-group = "Legacy 3"
				card.profile.port = "3"
			Part of profile(s): output:analog-stereo, output:analog-stereo+input:analog-stereo
		analog-output-headphones: Headphones (type: Headphones, priority: 9900, latency offset: 0 usec, availability group: Legacy 2, not available)
			Properties:
				port.type = "headphones"
				card.profile.port = "4"
		hdmi-output-0: HDMI / DisplayPort (type: HDMI, priority: 5900, latency offset: 0 usec, availability group: Legacy 4, available)
			Properties:
				port.type = "hdmi"
				port.availability-group = "Legacy 4"
				card.profile.port = "5"
				device.product.name = "M2362D"
			Part of profile(s): output:hdmi-stereo, output:hdmi-stereo+input:analog-stereo, output:hdmi-surround, output:hdmi-surround+input:analog-stereo
		hdmi-output-1: HDMI / DisplayPort 2 (type: HDMI, priority: 5800, latency offset: 0 usec, availability group: Legacy 5, not available)
			Properties:
				port.type = "hdmi"
				port.availability-group = "Legacy 5"
				card.profile.port = "6"
			Part of profile(s): output:hdmi-stereo-extra1, output:hdmi-stereo-extra1+input:analog-stereo, output:hdmi-surround-extra1, output:hdmi-surround-extra1+input:analog-stereo, output:hdmi-surround71-extra1, output:hdmi-surround71-extra1+input:analog-stereo
		hdmi-output-2: HDMI / DisplayPort 3 (type: HDMI, priority: 5700, latency offset: 0 usec, availability group: Legacy 6, not available)
			Properties:
				port.type = "hdmi"
				port.availability-group = "Legacy 6"
				card.profile.port = "7"
			Part of profile(s): output:hdmi-stereo-extra2, output:hdmi-stereo-extra2+input:analog-stereo, output:hdmi-surround-extra2, output:hdmi-surround-extra2+input:analog-stereo, output:hdmi-surround71-extra2, output:hdmi-surround71-extra2+input:analog-stereo
Sorry I got confused about the GUI and hardware. Is not a hardware issue as doing the same in windows doesn’t trigger it and I noticed this when I installed Gnome 46
So here is the active profile:
If that is the output/state after disconnecting the second screen while audio was set as default on that screen via HDMI, then it must be a bug in Gnome GUI where nothing is listed. Probably an old one. It has difficulty finding the saved default device. Pavucontrol should be able to handle this.
Pipewire-pulse works normally and you see all possible profiles. So the backend is not affected.
Thank you so much for the time and effort!
So if I understand correctly… new Manjaro stable now comes with Pipewire instead of Pulseaudio and using Pavucontrol should not cause issues with Pipewire.
No. Pipewire is a framework. It supports ALSA, PULSE and JACK as direct replacement.
Thanks again. I’m going off to the Gnome git to see if there’s a solution there or report the issue.
Manjaro replaced PulseAudio and JACK with PipeWire as default audio server in Jan 2024
PipeWire is described as a drop-in replacement for PulseAudio and JACK. not a direct replacement
PipeWire does not replace ALSA kernel API
Data from pactl list cards is what I would expect to see if the Monitor was plugged-in:
If the HDMI output is disconnected, the profile should change to available: no and the Active Profile should switch to another available profile, most likely the analog output and input:
If the Profile is not switching automatically, it can be changed manually in pavucontrol
Or
pactl set-card-profile alsa_card.pci-0000_00_1f.3 output:analog-stereo+input:analog-stereo
Well, with this cmd when I disconnect the HDMI it not longer shows no output sources and I can change oudio output so its an improvement. Thanks!
Still no audio after disconnecting HDMI so no auto switch. Haven’t installed pavucontrol but I will check into it.
wiki.archlinux.org - PipeWire - Auto-switching is not working
If auto-switching is not working it may be an issue with WirePlumber state
delete WirePlumber’s local state and restart the daemon to see if that helps:
rm -r ~/.local/state/wireplumber/
Then restart the wireplumber.service user unit
systemctl --user restart wireplumber.service
