Just as the title says, how do I reset gnome themes to be like a fresh install (OOTB)? I was working on clearing up some orphans, caches, etc. and for some reason all my theme’ing I had previously got reset. Somehow I reset my dialog boxes for volume, brightness, and even my mouse pointer. I am trying to modify these but am unsure what settings control the look and feel of these settings. At this point, I just want to go to back to a fresh install experience and start my theme’ing adventure over from scratch.
Can anyone provide some steps or how to achieve this or how I can reset all the themes using the Gnome tweak tool possibly?
Any assistance would be greatly appreciated. Thanks in advance to everyone for your time and help.
Apologies, let me give some more context and try to be clear. I am using Gnome 43.2 under Wayland and following some guidance in the post below I broke my system in terms of its appearance:
I mainly was trying to go through and follow the steps under the “System Maintenance” document, linked below for ease:
After completing this steps, somehow my custom theme that I had been using broke. Possibly during the step where I was removing the orphans.
Goal:
I want to ‘reset’ my theme settings as if I just did a fresh install of Manjaro. That way I can re-apply my specific theme configurations and maybe document what I did along the way. That way, if something happens in the future (or I do a fresh install) I can refer back and get things to look and feel how I like them to be.
Pacman Log:
If I can provide any additional information to help troubleshoot this issue around the themes / appearance, please let me know.
Thank you in advance for all of your time and help, it is greatly appreciated!
Reinstall manjaro-gnome-extension-settings, it will pull in the required dependencies you might have also removed. Check optional dependencies as well to suit your needs.
sudo pacman -Syu manjaro-gnome-extension-settings
core is up to date
extra is up to date
community is up to date
multilib is up to date
warning: manjaro-gnome-extension-settings-20221211-2 is up to date -- reinstalling
resolving dependencies...
Packages (1) manjaro-gnome-extension-settings-20221211-2
Total Installed Size: 0.00 MiB
Net Upgrade Size: 0.00 MiB
:: Proceed with installation? [Y/n] y
(1/1) checking keys in keyring [###############################################################] 100%
(1/1) checking package integrity [###############################################################] 100%
(1/1) loading package files [###############################################################] 100%
(1/1) checking for file conflicts [###############################################################] 100%
(1/1) checking available disk space [###############################################################] 100%
(1/1) reinstalling manjaro-gnome-extension-settings [###############################################################] 100%
No schema files found: doing nothing.
(process:3175): dconf-WARNING **: 00:24:41.895: failed to commit changes to dconf: Error spawning command line “dbus-launch --autolaunch=5c166ed1c96d428789ce495bd8ade62d --binary-syntax --close-stderr”: Child process exited with code 1
(1/2) Arming ConditionNeedsUpdate...
(2/2) Compiling GSettings XML schema files...
en trying to install one of the packages you listed above:
Also got this output:
Any thoughts would be super appreciated. Thank you!
core is up to date
extra is up to date
(process:3145): dconf-WARNING **: 14:52:20.145: failed to commit changes to dconf: Error spawning command line “dbus-launch --autolaunch=5c166ed1c96d428789ce495bd8ade62d --binary-syntax --close-stderr”: Child process exited with code 1
Besides that ‘reinstall’ error, I think everything is working. Thank you @Yochanan for helping get my system back up and running. I guess may more of a final curious question is why did these packages get marked as orphan’s if they are clearly needed (and I assume being used)?
Thanks again for all of your time and help, it is greatly appreciated!
