Glibc_eac fails validity check
After installing linux as my daily driver recently i wanted to play sea of thieves. Because it didnt start properly i looked it up on protonDB. Someone there wrote that for it to run with eac i need to install glibc-eac. when using yay with the give flags i get the error
yay --mflags "--nocheck" glibc-eac
3 aur/lib32-glibc-eac 2.39-2 (+8 2.97)
    GNU C Library (32-bit) with DT_HASH patch for games using EAC
2 aur/glibc-eac-locales 2.39-2 (+8 2.97)
    Pregenerated locales for GNU C Library
1 aur/glibc-eac 2.39-2 (+8 2.97)
    GNU C Library with DT_HASH patch for games using EAC
==> Packages to install (eg: 1 2 3, 1-3 or ^4)
==> 1
AUR Explicit (1): glibc-eac-2.39-2
:: PKGBUILD up to date, skipping download: glibc-eac
  1 glibc-eac                                (Build Files Exist)
==> Packages to cleanBuild?
==> [N]one [A]ll [Ab]ort [I]nstalled [No]tInstalled or (1 2 3, 1-3, ^4)
==> Diffs to show?
==> Making package: glibc-eac 2.39-2 (Sa 20 Apr 2024 00:17:52 CEST)
==> Retrieving sources...
  -> Updating glibc git repo...
  -> Found locale.gen.txt
  -> Found locale-gen
  -> Found lib32-glibc.conf
  -> Found sdt.h
  -> Found sdt-config.h
  -> Found reenable_DT_HASH.patch
==> WARNING: Skipping verification of source file PGP signatures.
==> Validating source files with b2sums...
    glibc ... NOT FOUND
    locale.gen.txt ... Passed
    locale-gen ... Passed
    lib32-glibc.conf ... Passed
    sdt.h ... Passed
    sdt-config.h ... Passed
    reenable_DT_HASH.patch ... Passed
==> ERROR: One or more files did not pass the validity check!
 -> error downloading sources: /home/heckjo/.cache/yay/glibc-eac
	 context: exit status 1
:: (1/1) Parsing SRCINFO: glibc-eac
pub   rsa4096 2016-08-02 [SC] [expired: 2022-07-23]
      7273542B39962DF7B299931416792B4EA25340F8
uid           [ expired] Carlos O'Donell <carlos@systemhalted.org>
uid           [ expired] Carlos O'Donell (Work) <carlos@redhat.com>
uid           [ expired] Carlos O'Donell (Work) <codonell@redhat.com>
pub   rsa2048 2014-02-16 [SC]
      BC7C7372637EC10C57D7AA6579C43DFBF1CF2187
uid           [ unknown] Siddhesh Poyarekar <siddhesh@gotplt.org>
uid           [ unknown] Siddhesh Poyarekar (https://sourceware.org) <siddhesh@sourceware.org>
uid           [ unknown] Siddhesh Poyarekar <sid@reserved-bit.com>
uid           [ unknown] Siddhesh Poyarekar (Personal) <siddhesh.poyarekar@gmail.com>
sub   rsa2048 2014-02-16 [E]
==> Making package: glibc-eac 2.39-2 (Sa 20 Apr 2024 00:17:57 CEST)
  -> Found locale-gen
  -> Found sdt.h
    glibc ... NOT FOUND
    sdt.h ... Passed
 -> error making: glibc-eac-exit status 1
 -> Failed to install the following packages. Manual intervention is required:
glibc-eac - exit status 1
i also tried installing it locally but it still doesnt pass the validity checks. when using updpkgsums (from this post) it does acctually go futhen than before but it will get stuck entering and leaving the same folders from the repo.
When building it from a different repo (github, 1, 2) it does the same.
Any ideas?
cd /home/heckjo/.cache/yay/glibc-eac
use makepkg without option --nocheck
run updpkgsums
I did not run the complete compilation - I interrupted it in the check phase
Building it now.
Ill have to see if it works cause it takes some time …
This did the trick.
Still some stuttering but it can live with that.
Tank you
From what I can see, no, you don’t, here’s SoT EAC log from right now:
[17:45:21:128] [Windows] [EAC Launcher] [Info] Loaded the following settings .json file: 'Z:\home\omano\.local\share\Steam\steamapps\common\Sea of Thieves\EasyAntiCheat\Settings.json'
[17:45:21:128] [Windows] [EAC Launcher] [Info] Provided settings:
[17:45:21:128] [Windows] [EAC Launcher] [Info] ProcessTitle: Sea of Thieves.
[17:45:21:128] [Windows] [EAC Launcher] [Info] ExecutablePath: Athena/Binaries/Win64/SotGame.exe.
[17:45:21:128] [Windows] [EAC Launcher] [Info] ProductId: 0367a3a8ea344f08851d76facf6f66d3.
[17:45:21:128] [Windows] [EAC Launcher] [Info] SandboxId: 681b0e60c5d24d3cb2455752f98de6fa.
[17:45:21:128] [Windows] [EAC Launcher] [Info] DeploymentId: ab3dcc35b343407b80dfe60cc9d1f450.
[17:45:21:128] [Windows] [EAC Launcher] [Info] RequestedSplashScreen: EasyAntiCheat/SplashScreen.png.
[17:45:21:128] [Windows] [EAC Launcher] [Info] WaitForGameProcessExit: false.
[17:45:21:128] [Windows] [EAC Launcher] [Info] HideGUI: false.
[17:45:21:128] [Windows] [EAC Launcher] [Info] HideBootstrapper: false.
[17:45:21:277] [Windows] [EAC Launcher] [Info] Embedded resources successfully loaded.
[17:45:21:279] [Windows] [EAC Launcher] [Info] Will use the icon extracted from the game executable.
[17:45:21:422] [Windows] [EAC Launcher] [Info] Loader initializing with bootstrapper version 1.6.3.
[17:45:21:440] [Windows] [EAC Launcher] [Info] Loader component initialized.
[17:45:21:449] [Windows] [EAC Launcher] [Info] [Connection] Connecting to URL: https://modules-cdn.eac-prod.on.epicgames.com/modules/0367a3a8ea344f08851d76facf6f66d3/ab3dcc35b343407b80dfe60cc9d1f450/linux64
[17:45:21:490] [Windows] [EAC Launcher] [Info] Current progress: 0 (0/0).
[17:45:21:491] [Windows] [EAC Launcher] [Info] Current progress: 0 (0/0).
[17:45:21:492] [Windows] [EAC Launcher] [Info] Current progress: 0 (0/0).
[17:45:21:493] [Windows] [EAC Launcher] [Info] Current progress: 0 (0/0).
[17:45:21:494] [Windows] [EAC Launcher] [Info] Current progress: 0 (0/0).
[17:45:21:495] [Windows] [EAC Launcher] [Info] Current progress: 0 (0/0).
[17:45:21:499] [Windows] [EAC Launcher] [Info] Current progress: 0 (0/0).
[17:45:21:500] [Windows] [EAC Launcher] [Info] Current progress: 0 (0/0).
[17:45:21:504] [Windows] [EAC Launcher] [Info] Current progress: 0 (0/0).
[17:45:21:507] [Windows] [EAC Launcher] [Info] Current progress: 0 (0/0).
[17:45:21:518] [Windows] [EAC Launcher] [Info] Current progress: 0 (0/0).
[17:45:21:519] [Windows] [EAC Launcher] [Info] Current progress: 0 (0/0).
[17:45:21:579] [Windows] [EAC Launcher] [Info] Current progress: 0 (0/0).
[17:45:21:580] [Windows] [EAC Launcher] [Info] Current progress: 0 (0/0).
[17:45:21:641] [Windows] [EAC Launcher] [Info] Current progress: 0 (0/0).
[17:45:21:642] [Windows] [EAC Launcher] [Info] Current progress: 0 (0/0).
[17:45:21:643] [Windows] [EAC Launcher] [Info] Current progress: 0 (0/0).
[17:45:21:644] [Windows] [EAC Launcher] [Info] Current progress: 0 (0/0).
[17:45:21:703] [Windows] [EAC Launcher] [Info] Current progress: 0 (0/0).
[17:45:21:704] [Windows] [EAC Launcher] [Info] Current progress: 0 (0/0).
[17:45:21:707] [Windows] [EAC Launcher] [Info] Current progress: 0 (0/0).
[17:45:21:709] [Windows] [EAC Launcher] [Info] Current progress: 0 (0/0).
[17:45:21:767] [Windows] [EAC Launcher] [Info] Current progress: 0 (0/0).
[17:45:21:767] [Windows] [EAC Launcher] [Info] [Connection] Connect result: No error (0) Response Code: 304 Destination IP: 3.160.196.112
[17:45:21:767] [Windows] [EAC Launcher] [Info] No update needed.
[17:45:21:767] [Windows] [EAC Launcher] [Info] Current progress: 100 (1/1).
[17:45:21:786] [Windows] [EAC Launcher] [Info] Starting Wine module mapping, Wine version: 8.0.
[17:45:22:659] [Windows] [EAC Launcher] [Info] Launcher finished with: 301, 'Easy Anti-Cheat chargé dans le jeu avec succès'.
[17:45:22:659] [Windows] [EAC Launcher] [Info] Successfully initialized the Easy Anti-Cheat service, waiting for game window to become visible.
[17:45:22:659] [Windows] [EAC Launcher] [Info] Unlocking the launch lock, allowing next game to launch to take place.
[17:45:22:676] [Windows] [EAC Launcher] [Info] Downloaded 1 bytes in 484 ms (0.00 KB/s)
Seems to load just fine.
Can’t connect to servers though currently to fully confirm I don’t get kicked because of EAC not working.
If i dont need glibc-eac then i guess it has to do something with proton. I get the game to open but it just gets stuck in the loading screen.
When using Mangohud it just has a very hight tpf.
I get to the main menu when using the hotfix version of proton in steam.
What is 100% sure is that you don’t need it to reach the menu, to login, to buy in the emporium, and to start loading to the game server, I don’t need it I just tested.
I’m using the current Proton 8 version from Steam.
I don’t know what a “hotfix version” of Proton is.
I don’t know what a TPF is in MangoHud.
The Hotfix version of proton is a version when minor patches get pushed, that dont require a whole version of experimental.
What i ment by TPF was TimePerFrame, because it get like Max 3secs between each frame when starting.
Ill try it with Proton 8 again a keep you updated
Don’t forget to delete the prefix at ~/.local/share/Steam/steamapps/compatdata/1172620/ if you messed with other Proton version so you start on a clean Proton 8 prefix. Check your game files too.
//EDIT: I played a long session without any issue, just to confirm EAC works as intended without installing the AUR patched version of a system component, all default here. I would advise to reset your changes and work on the issue.
