Glconv_vaapi_x11 gl error: vaInitialize: unknown libva error
Hi there, I have a fresh new reinstallation of gnome manjaro, I’m a newbie to Linux, and actually, i search a lot before reinstalling manjaro but I didn’t get anything from it
so my question is why when I start VLC in the terminal and drag & drop a movie on it (i think it doesn’t matter it starts with terminal or GUI, terminal just shows errors), it gives me these errors also i think the VLC sound freezing after a pause and play came from this
VLC media player 3.0.16 Vetinari (revision 3.0.13-8-g41878ff4f2)
[000055a7527cb580] main libvlc: Running vlc with the default interface. Use 'cvlc' to use vlc without interface.
[000055a752868110] main playlist: playlist is empty
[00007fcb500064d0] gl gl: Initialized libplacebo v4.192.1 (API v192)
[00007fcb500064d0] glconv_vaapi_x11 gl error: vaInitialize: unknown libva error
libva error: vaGetDriverNameByIndex() failed with unknown libva error, driver_name = (null)
[00007fcb500064d0] glconv_vaapi_drm gl error: vaInitialize: unknown libva error
Failed to open VDPAU backend libvdpau_va_gl.so: cannot open shared object file: No such file or directory
QObject::~QObject: Timers cannot be stopped from another thread
because I try manjaro on VirtualBox of my windows and it worked fine and there was no freezing and also there was no errors like them
Note: my PC has an intel integrated and Nvidia graphic
And, did you installed libvdpau-va-gl ?
What settings you use for Video output in VLC ?
Better share your system information as described here [HowTo] Provide System Information
Thanks for your answer, yep I just installed it but nothing changed, the settings in VLC are default settings and I didn’t change anything
 inxi --admin --verbosity=7 --filter --width                  ✔
  Kernel: 5.15.25-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.2.0
    root=UUID=d2a6d1cd-6083-412a-a61f-f17227f50f9e rw apparmor=1
    security=apparmor resume=UUID=387b68a0-1061-4610-a3b7-a824ab969fde
    udev.log_priority=3
  Desktop: GNOME 41.4 tk: GTK 3.24.31 wm: gnome-shell dm: GDM 41.3
  Mobo: ASUSTeK model: PRO H410M-C v: Rev 1.xx serial: <superuser required>
    UEFI: American Megatrends v: 0602 date: 04/15/2020
  RAM: total: 15.47 GiB used: 2.73 GiB (17.7%)
  RAM Report:
  Info: model: Intel Core i7-10700 bits: 64 type: MT MCP arch: Comet Lake
    family: 6 model-id: 0xA5 (165) stepping: 5 microcode: 0xEE
  Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
    L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 2 MiB desc: 8x256 KiB
    L3: 16 MiB desc: 1x16 MiB
  Speed (MHz): avg: 978 high: 2684 min/max: 800/4800 scaling:
    driver: intel_pstate governor: powersave cores: 1: 2684 2: 1594 3: 800
    4: 800 5: 800 6: 800 7: 800 8: 800 9: 800 10: 800 11: 971 12: 800 13: 800
    14: 801 15: 800 16: 800 bogomips: 92838
    arch_capabilities arch_perfmon art avx avx2 bmi1 bmi2 bts clflush clflushopt
    cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts
    epb ept ept_ad erms est f16c flexpriority flush_l1d fma fpu fsgsbase fxsr
    ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs ibrs_enhanced ida
    intel_pt invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor
    movbe mpx msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq
    pdcm pdpe1gb pebs pge pku pln pni popcnt pse pse36 pts rdrand rdseed
    rdtscp rep_good sdbg sep smap smep smx ss ssbd sse sse2 sse4_1 sse4_2
    ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer
    vme vmx vnmi vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology
    xtpr
  Device-1: Intel CometLake-S GT2 [UHD Graphics 630] vendor: ASUSTeK
    driver: i915 v: kernel ports: active: DP-1 empty: HDMI-A-1,HDMI-A-2
    bus-ID: 00:02.0 chip-ID: 8086:9bc5 class-ID: 0300
  Device-2: NVIDIA GP108 [GeForce GT 1030] vendor: ASUSTeK driver: nvidia
    v: 510.54 alternate: nouveau,nvidia_drm pcie: gen: 1 speed: 2.5 GT/s
    lanes: 4 link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.0 chip-ID: 10de:1d01
    class-ID: 0300
  Display: x11 server: X.org v: 1.21.1.3 compositor: gnome-shell driver: X:
    loaded: modesetting,nvidia alternate: fbdev,nouveau,nv,vesa gpu: i915
    display-ID: :1 screens: 1
  Screen-1: 0 s-res: 1920x1080 s-size: <missing: xdpyinfo>
  Monitor-1: DP-1 model: Dell SE2419H serial: <filter> built: 2019
    res: 1920x1080 hz: 60 dpi: 93 gamma: 1.2 size: 527x296mm (20.7x11.7")
    diag: 604mm (23.8") ratio: 16:9 modes: max: 1920x1080 min: 720x400
  Message: Unable to show GL data. Required tool glxinfo missing.
  Device-1: Intel Comet Lake PCH-V cAVS vendor: ASUSTeK driver: snd_hda_intel
    v: kernel alternate: snd_sof_pci_intel_cnl bus-ID: 00:1f.3
    chip-ID: 8086:a3f0 class-ID: 0403
  Device-2: NVIDIA GP108 High Definition Audio vendor: ASUSTeK
    driver: snd_hda_intel v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 4
    link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.1 chip-ID: 10de:0fb8
    class-ID: 0403
  Sound Server-1: ALSA v: k5.15.25-1-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.47 running: no
  Device-1: Intel Ethernet I219-V vendor: ASUSTeK driver: e1000e v: kernel
    port: N/A bus-ID: 00:1f.6 chip-ID: 8086:0d55 class-ID: 0200
  Local Storage: total: 1.14 TiB used: 396.34 GiB (34.0%)
    model: SSD 970 EVO Plus 250GB size: 232.89 GiB block-size: physical: 512 B
    rev: 2B2QEXM7 temp: 29.9 C scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Western Digital
    model: WD10EZEX-00WN4A0 size: 931.51 GiB block-size: physical: 4096 B
    logical: 512 B speed: 6.0 Gb/s type: HDD rpm: 7200 serial: <filter>
    rev: 1A01 scheme: GPT
  ID-1: / raw-size: 107.42 GiB size: 105.18 GiB (97.91%)
    used: 11.36 GiB (10.8%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
    uuid: d2a6d1cd-6083-412a-a61f-f17227f50f9e
  ID-2: /boot/efi raw-size: 1.95 GiB size: 1.95 GiB (99.80%)
    used: 288 KiB (0.0%) fs: vfat dev: /dev/sda4 maj-min: 8:4 label: NO_LABEL
    uuid: C522-62C0
  ID-3: /home raw-size: 70.32 GiB size: 68.66 GiB (97.65%)
    used: 1.17 GiB (1.7%) fs: ext4 dev: /dev/sda5 maj-min: 8:5 label: N/A
    uuid: 1558df9c-3a0e-47e9-8341-bf274fe05508
  ID-4: /run/media/mohammadali/Local Disk raw-size: 736.2 GiB
    size: 736.2 GiB (100.00%) used: 383.81 GiB (52.1%) fs: ntfs dev: /dev/sda1
    maj-min: 8:1 label: Local Disk uuid: D0929A5F929A49BC
  ID-1: swap-1 type: partition size: 15.62 GiB used: 0 KiB (0.0%)
    priority: -2 dev: /dev/sda3 maj-min: 8:3 label: N/A
    uuid: 387b68a0-1061-4610-a3b7-a824ab969fde
  ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 100 MiB fs: vfat label: N/A
    uuid: 1EFD-A621
  ID-2: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-3: /dev/nvme0n1p3 maj-min: 259:3 size: 225.44 GiB fs: ntfs label: N/A
    uuid: B80A00DE0A009C0E
  ID-4: /dev/nvme0n1p5 maj-min: 259:4 size: 499 MiB fs: ntfs label: N/A
    uuid: 1A00D80900D7EA31
  Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 10 rev: 2.0
  Device-1: 1-3:2 info: Pixart Imaging Optical Mouse type: Mouse
    driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s
    power: 100mA chip-ID: 093a:2510 class-ID: 0301
  Device-2: 1-4:3 info: SiGma Micro Keyboard TRACER Gamma Ivory
    type: Keyboard,HID driver: hid-generic,usbhid interfaces: 2 rev: 1.1
    speed: 1.5 Mb/s power: 98mA chip-ID: 1c4f:0002 class-ID: 0300
  Hub-2: 2-0:1 info: Super-speed hub ports: 4 rev: 3.0 speed: 5 Gb/s
  System Temperatures: cpu: 27.8 C mobo: N/A
  Processes: 364 Uptime: 4m wakeups: 0 Init: systemd v: 250 tool: systemctl
  Compilers: gcc: 11.2.0 clang: 13.0.1 Packages: pacman: 1259 lib: 314
  Shell: Zsh v: 5.8.1 running-in: gnome-terminal inxi: 3.3.13
So you are on a desktop with dual GPU, and you connected your monitor to the iGPU not the Nvidia one … Was never my thing on desktop with iGPU and a dedicated one. I would simply turn off the iGPU from BIOS.
What i don’t get, why you have
because on my end i only see:
and i asume is because i only have the nvidia driver installed, so i presume you installed almost all the available drivers t in the MHWD list.
mhwd -li
would show that …
video-vesa and video-linux can be removed, regardless if you want to keep the iGPU, but you cal also remove video-modesetting if you disable the iGPU from BIOS. Or might want to take a look into Hybrid graphics - ArchWiki
and also this
VLC media player - ArchWiki
Yes, type is Desktop and actually, I didn’t install anything special, as I said earlier I just reinstall manjaro and update it that’s it,
And here is mhwd li result:
mhwd -li                                                    ✔
> Installed PCI configs:
video-hybrid-intel-nvidia-prime            2021.12.18               false            PCI
and here is hardware section of manjaro-setting app
Ok, you have the “correct” drivers installed for hibrid GPU, but probably better wait to someone that has better understanding on how video-hybrid-intel-nvidia-prime works on a Desktop PC, because i don’t. Anyway, the links above should help you out a bit …
I don’t know it can be a solution or not, but changing the audio module to alsa audio output and change its device to HDA intel PCH, ALC887-VD analog default audio device
has solved freezing of audio after pause/unpause video or sound
terminal errors still exist but freezing gone
I’ve found the solution from here
https://superuser.com/questions/651964/how-to-fix-choppy-sound-replay-with-vlc
UPDATE : sound freezing really didn’t get solved, and when I connect pc to HDMI i had to change sound settings so I found another and better way that solved my problem completely
I change the kernel version from linux 515 to linux 54 from manjaro settings manger and also did reset the vlc setting to default then the problem get solved
