Git isn't working
That’s it, that’s my problem.
On a more serious tone. I noticed I couldn’t download from the aur. After a few checks here and there it seems the problem is from git.
The git command isn’t working altogether.
It’s not returning anything.
Thanks in advance
I assume you are using Pamac - right?
And you have read the pinned topic? And understood how to do it the AUR way?
Yeah, I unfortunately did. Kinda of dumb of me to put it in the aur section.
But I’m pretty sure it’s a git issue since yay isn’t working either and the git command isn’t returning anything.
I don’t know where you are located but AUR works fine from my location in the northern part of Europe.
➜  ~ git clone https://aur.archlinux.org/postman-bin.git
Cloning into 'postman-bin'...
remote: Enumerating objects: 571, done.
remote: Counting objects: 100% (571/571), done.
remote: Compressing objects: 100% (357/357), done.
remote: Total 571 (delta 214), reused 571 (delta 214), pack-reused 0
Receiving objects: 100% (571/571), 87.28 KiB | 2.91 MiB/s, done.
Resolving deltas: 100% (214/214), done.
Did you get the Rate limit message?
Here’s what happens when I use git:
[stormer@stormer ~]$ git clone https://aur.archlinux.org/spotify.git
➜  ~ git clone https://aur.archlinux.org/spotify.git
Cloning into 'spotify'...
remote: Enumerating objects: 374, done.
remote: Counting objects: 100% (374/374), done.
remote: Compressing objects: 100% (236/236), done.
remote: Total 374 (delta 137), reused 370 (delta 135), pack-reused 0
Receiving objects: 100% (374/374), 158.21 KiB | 2.43 MiB/s, done.
Resolving deltas: 100% (137/137), done.
probably a git issue then?
It was working fine until today, I don’t know what I broke again lmao.
Tried updating with pacman, but I can’t. The fiels are already in the system.
Then I tried removing it but I can’t because it’s a dependency of pamac, timeshift and yay.
I want to die.
No, I didn’t get the rate limit message.
test:
GIT_TRACE=true git clone -v -4 "https://aur.archlinux.org/spotify.git"
test also with a github repo :wink:
Doesn’t change much
For the sake of curiosity, what does this command do exactly?
please : no screenshot !! only copy/paste text from terminal here
Tu sélectionnes le texte dans ton terminal et recopie ici après utilisation du bouton ‘</>’
is in documentation : force ipv4 and show more informations
I won’t post screenshots again xD.
But now I’m pretty sure it’s a git issue. Nothing related to git is working properly.
So how I can I fix a broken git.
As I said earlier I tried deleting with pacman but it wouldn’t let me. I din’t try deleting it anymore. I don’t want to reduce to atom what remains of my install xD.
is ok or not ? ex: git clone https://gitlab.manjaro.org/packages/core/pacman.git
If you use proxy: disable it (or firewall ?)
user git config is in ~/.gitconfig
for me is more a network problem …
not working, git returns nothing whatever I do :man_shrugging:
What returns git or git --version ? And which git and alias git?
[stormer@stormer ~]$ alias git
bash: alias: git : non trouvé
[stormer@stormer ~]$ which git
/usr/bin/git
[stormer@stormer ~]$ git --version
Ever tried reinstalling git?
sudo pacman -S git
yup, it won’t let me.
sorry for baguette language, but it’s basically : file is already present in the system.
[stormer@stormer ~]$ sudo pacman -S git
[sudo] Mot de passe de stormer :
avertissement : git-2.31.1-1 est à jour -- réinstallation
résolution des dépendances…
recherche des conflits entre paquets…
Paquets (1) git-2.31.1-1
Taille totale installée :  31,54 MiB
:: Procéder à l’installation ? [O/n] O
(1/1) vérification des clés dans le trousseau                                                             [###############################################################] 100%
(1/1) vérification de l’intégrité des paquets                                                             [###############################################################] 100%
(1/1) chargement des fichiers des paquets        [###############################################################] 100%
(1/1) analyse des conflits entre fichiers        [###############################################################] 100%
erreur : la validation de la transaction a échoué (conflit de fichiers)
git : /usr/bin/git est déjà présent dans le système de fichiers
git : /usr/bin/git-cvsserver est déjà présent dans le système de fichiers
git : /usr/bin/git-receive-pack est déjà présent dans le système de fichiers
git : /usr/bin/git-shell est déjà présent dans le système de fichiers
git : /usr/bin/git-upload-archive est déjà présent dans le système de fichiers
git : /usr/bin/git-upload-pack est déjà présent dans le système de fichiers
git : /usr/bin/gitk est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-add est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-add--interactive est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-am est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-annotate est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-apply est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-archimport est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-archive est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-bisect est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-bisect--helper est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-blame est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-branch est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-bugreport est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-bundle est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-cat-file est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-check-attr est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-check-ignore est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-check-mailmap est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-check-ref-format est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-checkout est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-checkout-index est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-cherry est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-cherry-pick est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-citool est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-clean est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-clone est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-column est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-commit est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-commit-graph est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-commit-tree est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-config est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-count-objects est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-credential est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-credential-cache est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-credential-cache--daemon est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-credential-gnome-keyring est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-credential-libsecret est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-credential-store est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-cvsexportcommit est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-cvsimport est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-cvsserver est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-daemon est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-describe est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-diff est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-diff-files est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-diff-index est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-diff-tree est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-difftool est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-difftool--helper est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-env--helper est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-fast-export est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-fast-import est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-fetch est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-fetch-pack est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-filter-branch est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-fmt-merge-msg est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-for-each-ref est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-for-each-repo est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-format-patch est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-fsck est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-fsck-objects est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-gc est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-get-tar-commit-id est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-grep est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-gui est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-gui--askpass est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-hash-object est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-help est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-http-backend est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-http-fetch est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-http-push est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-imap-send est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-index-pack est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-init est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-init-db est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-instaweb est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-interpret-trailers est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-log est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-ls-files est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-ls-remote est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-ls-tree est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-mailinfo est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-mailsplit est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-maintenance est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-merge est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-merge-base est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-merge-file est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-merge-index est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-merge-octopus est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-merge-one-file est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-merge-ours est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-merge-recursive est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-merge-resolve est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-merge-subtree est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-merge-tree est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-mergetool est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-mergetool--lib est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-mktag est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-mktree est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-multi-pack-index est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-mv est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-mw est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-name-rev est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-notes est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-p4 est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-pack-objects est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-pack-redundant est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-pack-refs est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-patch-id est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-prune est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-prune-packed est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-pull est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-push est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-quiltimport est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-range-diff est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-read-tree est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-rebase est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-rebase--preserve-merges est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-receive-pack est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-reflog est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-remote est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-remote-ext est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-remote-fd est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-remote-ftp est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-remote-ftps est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-remote-http est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-remote-https est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-remote-mediawiki est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-repack est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-replace est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-request-pull est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-rerere est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-reset est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-restore est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-rev-list est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-rev-parse est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-revert est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-rm est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-send-email est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-send-pack est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-sh-i18n est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-sh-i18n--envsubst est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-sh-setup est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-shell est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-shortlog est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-show est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-show-branch est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-show-index est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-show-ref est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-sparse-checkout est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-stage est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-stash est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-status est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-stripspace est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-submodule est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-submodule--helper est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-subtree est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-svn est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-switch est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-symbolic-ref est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-tag est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-unpack-file est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-unpack-objects est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-update-index est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-update-ref est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-update-server-info est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-upload-archive est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-upload-pack est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-var est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-verify-commit est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-verify-pack est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-verify-tag est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-web--browse est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-whatchanged est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-worktree est déjà présent dans le système de fichiers
git : /usr/lib/git-core/git-write-tree est déjà présent dans le système de fichiers
git : /usr/lib/git-core/mergetools/araxis est déjà présent dans le système de fichiers
git : /usr/lib/git-core/mergetools/bc est déjà présent dans le système de fichiers
git : /usr/lib/git-core/mergetools/codecompare est déjà présent dans le système de fichiers
git : /usr/lib/git-core/mergetools/deltawalker est déjà présent dans le système de fichiers
git : /usr/lib/git-core/mergetools/diffmerge est déjà présent dans le système de fichiers
git : /usr/lib/git-core/mergetools/diffuse est déjà présent dans le système de fichiers
git : /usr/lib/git-core/mergetools/ecmerge est déjà présent dans le système de fichiers
git : /usr/lib/git-core/mergetools/emerge est déjà présent dans le système de fichiers
git : /usr/lib/git-core/mergetools/examdiff est déjà présent dans le système de fichiers
git : /usr/lib/git-core/mergetools/guiffy est déjà présent dans le système de fichiers
git : /usr/lib/git-core/mergetools/gvimdiff est déjà présent dans le système de fichiers
git : /usr/lib/git-core/mergetools/kdiff3 est déjà présent dans le système de fichiers
git : /usr/lib/git-core/mergetools/kompare est déjà présent dans le système de fichiers
git : /usr/lib/git-core/mergetools/meld est déjà présent dans le système de fichiers
git : /usr/lib/git-core/mergetools/nvimdiff est déjà présent dans le système de fichiers
git : /usr/lib/git-core/mergetools/opendiff est déjà présent dans le système de fichiers
git : /usr/lib/git-core/mergetools/p4merge est déjà présent dans le système de fichiers
git : /usr/lib/git-core/mergetools/smerge est déjà présent dans le système de fichiers
git : /usr/lib/git-core/mergetools/tkdiff est déjà présent dans le système de fichiers
git : /usr/lib/git-core/mergetools/tortoisemerge est déjà présent dans le système de fichiers
git : /usr/lib/git-core/mergetools/vimdiff est déjà présent dans le système de fichiers
git : /usr/lib/git-core/mergetools/winmerge est déjà présent dans le système de fichiers
git : /usr/lib/git-core/mergetools/xxdiff est déjà présent dans le système de fichiers
git : /usr/lib/systemd/system/git-daemon.socket est déjà présent dans le système de fichiers
git : /usr/lib/systemd/system/git-daemon@.service est déjà présent dans le système de fichiers
git : /usr/lib/sysusers.d/git.conf est déjà présent dans le système de fichiers
git : /usr/share/bash-completion/completions/git est déjà présent dans le système de fichiers
git : /usr/share/git-core/templates/description est déjà présent dans le système de fichiers
git : /usr/share/git-core/templates/hooks/applypatch-msg.sample est déjà présent dans le système de fichiers
git : /usr/share/git-core/templates/hooks/commit-msg.sample est déjà présent dans le système de fichiers
git : /usr/share/git-core/templates/hooks/fsmonitor-watchman.sample est déjà présent dans le système de fichiers
git : /usr/share/git-core/templates/hooks/post-update.sample est déjà présent dans le système de fichiers
git : /usr/share/git-core/templates/hooks/pre-applypatch.sample est déjà présent dans le système de fichiers
git : /usr/share/git-core/templates/hooks/pre-commit.sample est déjà présent dans le système de fichiers
git : /usr/share/git-core/templates/hooks/pre-merge-commit.sample est déjà présent dans le système de fichiers
git : /usr/share/git-core/templates/hooks/pre-push.sample est déjà présent dans le système de fichiers
git : /usr/share/git-core/templates/hooks/pre-rebase.sample est déjà présent dans le système de fichiers
git : /usr/share/git-core/templates/hooks/pre-receive.sample est déjà présent dans le système de fichiers
git : /usr/share/git-core/templates/hooks/prepare-commit-msg.sample est déjà présent dans le système de fichiers
git : /usr/share/git-core/templates/hooks/push-to-checkout.sample est déjà présent dans le système de fichiers
git : /usr/share/git-core/templates/hooks/update.sample est déjà présent dans le système de fichiers
git : /usr/share/git-core/templates/info/exclude est déjà présent dans le système de fichiers
git : /usr/share/git-gui/lib/about.tcl est déjà présent dans le système de fichiers
git : /usr/share/git-gui/lib/blame.tcl est déjà présent dans le système de fichiers
git : /usr/share/git-gui/lib/branch.tcl est déjà présent dans le système de fichiers
git : /usr/share/git-gui/lib/branch_checkout.tcl est déjà présent dans le système de fichiers
git : /usr/share/git-gui/lib/branch_create.tcl est déjà présent dans le système de fichiers
git : /usr/share/git-gui/lib/branch_delete.tcl est déjà présent dans le système de fichiers
git : /usr/share/git-gui/lib/branch_rename.tcl est déjà présent dans le système de fichiers
git : /usr/share/git-gui/lib/browser.tcl est déjà présent dans le système de fichiers
git : /usr/share/git-gui/lib/checkout_op.tcl est déjà présent dans le système de fichiers
git : /usr/share/git-gui/lib/choose_font.tcl est déjà présent dans le système de fichiers
git : /usr/share/git-gui/lib/choose_repository.tcl est déjà présent dans le système de fichiers
git : /usr/share/git-gui/lib/choose_rev.tcl est déjà présent dans le système de fichiers
git : /usr/share/git-gui/lib/chord.tcl est déjà présent dans le système de fichiers
git : /usr/share/git-gui/lib/class.tcl est déjà présent dans le système de fichiers
git : /usr/share/git-gui/lib/commit.tcl est déjà présent dans le système de fichiers
git : /usr/share/git-gui/lib/console.tcl est déjà présent dans le système de fichiers
git : /usr/share/git-gui/lib/database.tcl est déjà présent dans le système de fichiers
git : /usr/share/git-gui/lib/date.tcl est déjà présent dans le système de fichiers
git : /usr/share/git-gui/lib/diff.tcl est déjà présent dans le système de fichiers
git : /usr/share/git-gui/lib/encoding.tcl est déjà présent dans le système de fichiers
git : /usr/share/git-gui/lib/error.tcl est déjà présent dans le système de fichiers
git : /usr/share/git-gui/lib/git-gui.ico est déjà présent dans le système de fichiers
git : /usr/share/git-gui/lib/index.tcl est déjà présent dans le système de fichiers
git : /usr/share/git-gui/lib/line.tcl est déjà présent dans le système de fichiers
git : /usr/share/git-gui/lib/logo.tcl est déjà présent dans le système de fichiers
git : /usr/share/git-gui/lib/merge.tcl est déjà présent dans le système de fichiers
git : /usr/share/git-gui/lib/mergetool.tcl est déjà présent dans le système de fichiers
git : /usr/share/git-gui/lib/msgs/bg.msg est déjà présent dans le système de fichiers
git : /usr/share/git-gui/lib/msgs/de.msg est déjà présent dans le système de fichiers
git : /usr/share/git-gui/lib/msgs/el.msg est déjà présent dans le système de fichiers
git : /usr/share/git-gui/lib/msgs/fr.msg est déjà présent dans le système de fichiers
git : /usr/share/git-gui/lib/msgs/hu.msg est déjà présent dans le système de fichiers
git : /usr/share/git-gui/lib/msgs/it.msg est déjà présent dans le système de fichiers
git : /usr/share/git-gui/lib/msgs/ja.msg est déjà présent dans le système de fichiers
git : /usr/share/git-gui/lib/msgs/nb.msg est déjà présent dans le système de fichiers
git : /usr/share/git-gui/lib/msgs/pt_br.msg est déjà présent dans le système de fichiers
git : /usr/share/git-gui/lib/msgs/pt_pt.msg est déjà présent dans le système de fichiers
git : /usr/share/git-gui/lib/msgs/ru.msg est déjà présent dans le système de fichiers
git : /usr/share/git-gui/lib/msgs/sv.msg est déjà présent dans le système de fichiers
git : /usr/share/git-gui/lib/msgs/vi.msg est déjà présent dans le système de fichiers
git : /usr/share/git-gui/lib/msgs/zh_cn.msg est déjà présent dans le système de fichiers
git : /usr/share/git-gui/lib/option.tcl est déjà présent dans le système de fichiers
git : /usr/share/git-gui/lib/remote.tcl est déjà présent dans le système de fichiers
git : /usr/share/git-gui/lib/remote_add.tcl est déjà présent dans le système de fichiers
git : /usr/share/git-gui/lib/remote_branch_delete.tcl est déjà présent dans le système de fichiers
git : /usr/share/git-gui/lib/search.tcl est déjà présent dans le système de fichiers
git : /usr/share/git-gui/lib/shortcut.tcl est déjà présent dans le système de fichiers
git : /usr/share/git-gui/lib/spellcheck.tcl est déjà présent dans le système de fichiers
git : /usr/share/git-gui/lib/sshkey.tcl est déjà présent dans le système de fichiers
git : /usr/share/git-gui/lib/status_bar.tcl est déjà présent dans le système de fichiers
git : /usr/share/git-gui/lib/tclIndex est déjà présent dans le système de fichiers
git : /usr/share/git-gui/lib/themed.tcl est déjà présent dans le système de fichiers
git : /usr/share/git-gui/lib/tools.tcl est déjà présent dans le système de fichiers
git : /usr/share/git-gui/lib/tools_dlg.tcl est déjà présent dans le système de fichiers
git : /usr/share/git-gui/lib/transport.tcl est déjà présent dans le système de fichiers
git : /usr/share/git-gui/lib/win32.tcl est déjà présent dans le système de fichiers
git : /usr/share/git-gui/lib/win32_shortcut.js est déjà présent dans le système de fichiers
git : /usr/share/git/README est déjà présent dans le système de fichiers
git : /usr/share/git/buildsystems/CMakeLists.txt est déjà présent dans le système de fichiers
git : /usr/share/git/buildsystems/Generators.pm est déjà présent dans le système de fichiers
git : /usr/share/git/buildsystems/Generators/QMake.pm est déjà présent dans le système de fichiers
git : /usr/share/git/buildsystems/Generators/Vcproj.pm est déjà présent dans le système de fichiers
git : /usr/share/git/buildsystems/Generators/Vcxproj.pm est déjà présent dans le système de fichiers
git : /usr/share/git/buildsystems/engine.pl est déjà présent dans le système de fichiers
git : /usr/share/git/buildsystems/generate est déjà présent dans le système de fichiers
git : /usr/share/git/buildsystems/parse.pl est déjà présent dans le système de fichiers
git : /usr/share/git/coccinelle/README est déjà présent dans le système de fichiers
git : /usr/share/git/coccinelle/array.cocci est déjà présent dans le système de fichiers
git : /usr/share/git/coccinelle/commit.cocci est déjà présent dans le système de fichiers
git : /usr/share/git/coccinelle/flex_alloc.cocci est déjà présent dans le système de fichiers
git : /usr/share/git/coccinelle/free.cocci est déjà présent dans le système de fichiers
git : /usr/share/git/coccinelle/hashmap.cocci est déjà présent dans le système de fichiers
git : /usr/share/git/coccinelle/object_id.cocci est déjà présent dans le système de fichiers
git : /usr/share/git/coccinelle/preincr.cocci est déjà présent dans le système de fichiers
git : /usr/share/git/coccinelle/qsort.cocci est déjà présent dans le système de fichiers
git : /usr/share/git/coccinelle/strbuf.cocci est déjà présent dans le système de fichiers
git : /usr/share/git/coccinelle/swap.cocci est déjà présent dans le système de fichiers
git : /usr/share/git/coccinelle/the_repository.pending.cocci est déjà présent dans le système de fichiers
git : /usr/share/git/coccinelle/xcalloc.cocci est déjà présent dans le système de fichiers
git : /usr/share/git/coccinelle/xstrdup_or_null.cocci est déjà présent dans le système de fichiers
git : /usr/share/git/completion/.gitattributes est déjà présent dans le système de fichiers
git : /usr/share/git/completion/git-completion.bash est déjà présent dans le système de fichiers
git : /usr/share/git/completion/git-completion.tcsh est déjà présent dans le système de fichiers
git : /usr/share/git/completion/git-completion.zsh est déjà présent dans le système de fichiers
git : /usr/share/git/completion/git-prompt.sh est déjà présent dans le système de fichiers
git : /usr/share/git/contacts/Makefile est déjà présent dans le système de fichiers
git : /usr/share/git/contacts/git-contacts est déjà présent dans le système de fichiers
git : /usr/share/git/contacts/git-contacts.txt est déjà présent dans le système de fichiers
git : /usr/share/git/coverage-diff.sh est déjà présent dans le système de fichiers
git : /usr/share/git/credential/gnome-keyring/Makefile est déjà présent dans le système de fichiers
git : /usr/share/git/credential/gnome-keyring/git-credential-gnome-keyring.c est déjà présent dans le système de fichiers
git : /usr/share/git/credential/libsecret/Makefile est déjà présent dans le système de fichiers
git : /usr/share/git/credential/libsecret/git-credential-libsecret.c est déjà présent dans le système de fichiers
git : /usr/share/git/credential/netrc/Makefile est déjà présent dans le système de fichiers
git : /usr/share/git/credential/netrc/git-credential-netrc.perl est déjà présent dans le système de fichiers
git : /usr/share/git/credential/netrc/t-git-credential-netrc.sh est déjà présent dans le système de fichiers
git : /usr/share/git/credential/netrc/test.command-option-gpg est déjà présent dans le système de fichiers
git : /usr/share/git/credential/netrc/test.git-config-gpg est déjà présent dans le système de fichiers
git : /usr/share/git/credential/netrc/test.netrc est déjà présent dans le système de fichiers
git : /usr/share/git/credential/netrc/test.netrc.gpg est déjà présent dans le système de fichiers
git : /usr/share/git/credential/netrc/test.pl est déjà présent dans le système de fichiers
git : /usr/share/git/credential/osxkeychain/Makefile est déjà présent dans le système de fichiers
git : /usr/share/git/credential/osxkeychain/git-credential-osxkeychain.c est déjà présent dans le système de fichiers
git : /usr/share/git/credential/wincred/Makefile est déjà présent dans le système de fichiers
git : /usr/share/git/credential/wincred/git-credential-wincred.c est déjà présent dans le système de fichiers
git : /usr/share/git/diff-highlight/DiffHighlight.pm est déjà présent dans le système de fichiers
git : /usr/share/git/diff-highlight/Makefile est déjà présent dans le système de fichiers
git : /usr/share/git/diff-highlight/README est déjà présent dans le système de fichiers
git : /usr/share/git/diff-highlight/diff-highlight est déjà présent dans le système de fichiers
git : /usr/share/git/diff-highlight/diff-highlight.perl est déjà présent dans le système de fichiers
git : /usr/share/git/diff-highlight/shebang.perl est déjà présent dans le système de fichiers
git : /usr/share/git/diff-highlight/t/Makefile est déjà présent dans le système de fichiers
git : /usr/share/git/diff-highlight/t/t9400-diff-highlight.sh est déjà présent dans le système de fichiers
git : /usr/share/git/emacs/README est déjà présent dans le système de fichiers
git : /usr/share/git/emacs/git-blame.el est déjà présent dans le système de fichiers
git : /usr/share/git/emacs/git.el est déjà présent dans le système de fichiers
git : /usr/share/git/examples/README est déjà présent dans le système de fichiers
git : /usr/share/git/fast-import/git-import.perl est déjà présent dans le système de fichiers
git : /usr/share/git/fast-import/git-import.sh est déjà présent dans le système de fichiers
git : /usr/share/git/fast-import/git-p4.README est déjà présent dans le système de fichiers
git : /usr/share/git/fast-import/import-directories.perl est déjà présent dans le système de fichiers
git : /usr/share/git/fast-import/import-tars.perl est déjà présent dans le système de fichiers
git : /usr/share/git/fast-import/import-zips.py est déjà présent dans le système de fichiers
git : /usr/share/git/git-jump/README est déjà présent dans le système de fichiers
git : /usr/share/git/git-jump/git-jump est déjà présent dans le système de fichiers
git : /usr/share/git/git-prompt.sh est déjà présent dans le système de fichiers
git : /usr/share/git/git-resurrect.sh est déjà présent dans le système de fichiers
git : /usr/share/git/git-shell-commands/README est déjà présent dans le système de fichiers
git : /usr/share/git/git-shell-commands/help est déjà présent dans le système de fichiers
git : /usr/share/git/git-shell-commands/list est déjà présent dans le système de fichiers
git : /usr/share/git/hg-to-git/hg-to-git.py est déjà présent dans le système de fichiers
git : /usr/share/git/hg-to-git/hg-to-git.txt est déjà présent dans le système de fichiers
git : /usr/share/git/hooks/multimail/CHANGES est déjà présent dans le système de fichiers
git : /usr/share/git/hooks/multimail/CONTRIBUTING.rst est déjà présent dans le système de fichiers
git : /usr/share/git/hooks/multimail/README.Git est déjà présent dans le système de fichiers
git : /usr/share/git/hooks/multimail/README.migrate-from-post-receive-email est déjà présent dans le système de fichiers
git : /usr/share/git/hooks/multimail/README.rst est déjà présent dans le système de fichiers
git : /usr/share/git/hooks/multimail/doc/customizing-emails.rst est déjà présent dans le système de fichiers
git : /usr/share/git/hooks/multimail/doc/gerrit.rst est déjà présent dans le système de fichiers
git : /usr/share/git/hooks/multimail/doc/gitolite.rst est déjà présent dans le système de fichiers
git : /usr/share/git/hooks/multimail/doc/troubleshooting.rst est déjà présent dans le système de fichiers
git : /usr/share/git/hooks/multimail/git_multimail.py est déjà présent dans le système de fichiers
git : /usr/share/git/hooks/multimail/migrate-mailhook-config est déjà présent dans le système de fichiers
git : /usr/share/git/hooks/multimail/post-receive.example est déjà présent dans le système de fichiers
git : /usr/share/git/hooks/post-receive-email est déjà présent dans le système de fichiers
git : /usr/share/git/hooks/pre-auto-gc-battery est déjà présent dans le système de fichiers
git : /usr/share/git/hooks/setgitperms.perl est déjà présent dans le système de fichiers
git : /usr/share/git/hooks/update-paranoid est déjà présent dans le système de fichiers
git : /usr/share/git/long-running-filter/example.pl est déjà présent dans le système de fichiers
git : /usr/share/git/mw-to-git/.perlcriticrc est déjà présent dans le système de fichiers
git : /usr/share/git/mw-to-git/Git/Mediawiki.pm est déjà présent dans le système de fichiers
git : /usr/share/git/mw-to-git/Makefile est déjà présent dans le système de fichiers
git : /usr/share/git/mw-to-git/bin-wrapper/git est déjà présent dans le système de fichiers
git : /usr/share/git/mw-to-git/git-mw est déjà présent dans le système de fichiers
git : /usr/share/git/mw-to-git/git-mw.perl est déjà présent dans le système de fichiers
git : /usr/share/git/mw-to-git/git-remote-mediawiki est déjà présent dans le système de fichiers
git : /usr/share/git/mw-to-git/git-remote-mediawiki.perl est déjà présent dans le système de fichiers
git : /usr/share/git/mw-to-git/git-remote-mediawiki.txt est déjà présent dans le système de fichiers
git : /usr/share/git/mw-to-git/t/Makefile est déjà présent dans le système de fichiers
git : /usr/share/git/mw-to-git/t/README est déjà présent dans le système de fichiers
git : /usr/share/git/mw-to-git/t/install-wiki.sh est déjà présent dans le système de fichiers
git : /usr/share/git/mw-to-git/t/push-pull-tests.sh est déjà présent dans le système de fichiers
git : /usr/share/git/mw-to-git/t/t9360-mw-to-git-clone.sh est déjà présent dans le système de fichiers
git : /usr/share/git/mw-to-git/t/t9361-mw-to-git-push-pull.sh est déjà présent dans le système de fichiers
git : /usr/share/git/mw-to-git/t/t9362-mw-to-git-utf8.sh est déjà présent dans le système de fichiers
git : /usr/share/git/mw-to-git/t/t9363-mw-to-git-export-import.sh est déjà présent dans le système de fichiers
git : /usr/share/git/mw-to-git/t/t9364-pull-by-rev.sh est déjà présent dans le système de fichiers
git : /usr/share/git/mw-to-git/t/t9365-continuing-queries.sh est déjà présent dans le système de fichiers
git : /usr/share/git/mw-to-git/t/test-gitmw-lib.sh est déjà présent dans le système de fichiers
git : /usr/share/git/mw-to-git/t/test-gitmw.pl est déjà présent dans le système de fichiers
git : /usr/share/git/mw-to-git/t/test.config est déjà présent dans le système de fichiers
git : /usr/share/git/persistent-https/LICENSE est déjà présent dans le système de fichiers
git : /usr/share/git/persistent-https/Makefile est déjà présent dans le système de fichiers
git : /usr/share/git/persistent-https/README est déjà présent dans le système de fichiers
git : /usr/share/git/persistent-https/client.go est déjà présent dans le système de fichiers
git : /usr/share/git/persistent-https/main.go est déjà présent dans le système de fichiers
git : /usr/share/git/persistent-https/proxy.go est déjà présent dans le système de fichiers
git : /usr/share/git/persistent-https/socket.go est déjà présent dans le système de fichiers
git : /usr/share/git/remote-helpers/README est déjà présent dans le système de fichiers
git : /usr/share/git/remote-helpers/git-remote-bzr est déjà présent dans le système de fichiers
git : /usr/share/git/remote-helpers/git-remote-hg est déjà présent dans le système de fichiers
git : /usr/share/git/remotes2config.sh est déjà présent dans le système de fichiers
git : /usr/share/git/rerere-train.sh est déjà présent dans le système de fichiers
git : /usr/share/git/stats/git-common-hash est déjà présent dans le système de fichiers
git : /usr/share/git/stats/mailmap.pl est déjà présent dans le système de fichiers
git : /usr/share/git/stats/packinfo.pl est déjà présent dans le système de fichiers
git : /usr/share/git/subtree/COPYING est déjà présent dans le système de fichiers
git : /usr/share/git/subtree/INSTALL est déjà présent dans le système de fichiers
git : /usr/share/git/subtree/Makefile est déjà présent dans le système de fichiers
git : /usr/share/git/subtree/README est déjà présent dans le système de fichiers
git : /usr/share/git/subtree/git-subtree est déjà présent dans le système de fichiers
git : /usr/share/git/subtree/git-subtree.1 est déjà présent dans le système de fichiers
git : /usr/share/git/subtree/git-subtree.sh est déjà présent dans le système de fichiers
git : /usr/share/git/subtree/git-subtree.txt est déjà présent dans le système de fichiers
git : /usr/share/git/subtree/git-subtree.xml est déjà présent dans le système de fichiers
git : /usr/share/git/subtree/t/Makefile est déjà présent dans le système de fichiers
git : /usr/share/git/subtree/t/t7900-subtree.sh est déjà présent dans le système de fichiers
git : /usr/share/git/subtree/todo est déjà présent dans le système de fichiers
git : /usr/share/git/thunderbird-patch-inline/README est déjà présent dans le système de fichiers
git : /usr/share/git/thunderbird-patch-inline/appp.sh est déjà présent dans le système de fichiers
git : /usr/share/git/update-unicode/README est déjà présent dans le système de fichiers
git : /usr/share/git/update-unicode/update_unicode.sh est déjà présent dans le système de fichiers
git : /usr/share/git/vscode/.gitattributes est déjà présent dans le système de fichiers
git : /usr/share/git/vscode/README.md est déjà présent dans le système de fichiers
git : /usr/share/git/vscode/init.sh est déjà présent dans le système de fichiers
git : /usr/share/git/workdir/.gitattributes est déjà présent dans le système de fichiers
git : /usr/share/git/workdir/git-new-workdir est déjà présent dans le système de fichiers
git : /usr/share/gitk/lib/msgs/bg.msg est déjà présent dans le système de fichiers
git : /usr/share/gitk/lib/msgs/ca.msg est déjà présent dans le système de fichiers
git : /usr/share/gitk/lib/msgs/de.msg est déjà présent dans le système de fichiers
git : /usr/share/gitk/lib/msgs/es.msg est déjà présent dans le système de fichiers
git : /usr/share/gitk/lib/msgs/fr.msg est déjà présent dans le système de fichiers
git : /usr/share/gitk/lib/msgs/hu.msg est déjà présent dans le système de fichiers
git : /usr/share/gitk/lib/msgs/it.msg est déjà présent dans le système de fichiers
git : /usr/share/gitk/lib/msgs/ja.msg est déjà présent dans le système de fichiers
git : /usr/share/gitk/lib/msgs/pt_br.msg est déjà présent dans le système de fichiers
git : /usr/share/gitk/lib/msgs/pt_pt.msg est déjà présent dans le système de fichiers
git : /usr/share/gitk/lib/msgs/ru.msg est déjà présent dans le système de fichiers
git : /usr/share/gitk/lib/msgs/sv.msg est déjà présent dans le système de fichiers
git : /usr/share/gitk/lib/msgs/vi.msg est déjà présent dans le système de fichiers
git : /usr/share/gitk/lib/msgs/zh_cn.msg est déjà présent dans le système de fichiers
git : /usr/share/gitweb/gitweb.cgi est déjà présent dans le système de fichiers
git : /usr/share/gitweb/static/git-favicon.png est déjà présent dans le système de fichiers
git : /usr/share/gitweb/static/git-logo.png est déjà présent dans le système de fichiers
git : /usr/share/gitweb/static/gitweb.css est déjà présent dans le système de fichiers
git : /usr/share/gitweb/static/gitweb.js est déjà présent dans le système de fichiers
git : /usr/share/locale/bg/LC_MESSAGES/git.mo est déjà présent dans le système de fichiers
git : /usr/share/locale/ca/LC_MESSAGES/git.mo est déjà présent dans le système de fichiers
git : /usr/share/locale/de/LC_MESSAGES/git.mo est déjà présent dans le système de fichiers
git : /usr/share/locale/el/LC_MESSAGES/git.mo est déjà présent dans le système de fichiers
git : /usr/share/locale/es/LC_MESSAGES/git.mo est déjà présent dans le système de fichiers
git : /usr/share/locale/fr/LC_MESSAGES/git.mo est déjà présent dans le système de fichiers
git : /usr/share/locale/id/LC_MESSAGES/git.mo est déjà présent dans le système de fichiers
git : /usr/share/locale/is/LC_MESSAGES/git.mo est déjà présent dans le système de fichiers
git : /usr/share/locale/it/LC_MESSAGES/git.mo est déjà présent dans le système de fichiers
git : /usr/share/locale/ko/LC_MESSAGES/git.mo est déjà présent dans le système de fichiers
git : /usr/share/locale/pl/LC_MESSAGES/git.mo est déjà présent dans le système de fichiers
git : /usr/share/locale/pt_PT/LC_MESSAGES/git.mo est déjà présent dans le système de fichiers
git : /usr/share/locale/ru/LC_MESSAGES/git.mo est déjà présent dans le système de fichiers
git : /usr/share/locale/sv/LC_MESSAGES/git.mo est déjà présent dans le système de fichiers
git : /usr/share/locale/tr/LC_MESSAGES/git.mo est déjà présent dans le système de fichiers
git : /usr/share/locale/vi/LC_MESSAGES/git.mo est déjà présent dans le système de fichiers
git : /usr/share/locale/zh_CN/LC_MESSAGES/git.mo est déjà présent dans le système de fichiers
git : /usr/share/locale/zh_TW/LC_MESSAGES/git.mo est déjà présent dans le système de fichiers
git : /usr/share/man/man1/git-add.1.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man1/git-am.1.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man1/git-annotate.1.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man1/git-apply.1.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man1/git-archimport.1.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man1/git-archive.1.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man1/git-bisect.1.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man1/git-blame.1.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man1/git-branch.1.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man1/git-bugreport.1.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man1/git-bundle.1.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man1/git-cat-file.1.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man1/git-check-attr.1.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man1/git-check-ignore.1.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man1/git-check-mailmap.1.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man1/git-check-ref-format.1.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man1/git-checkout-index.1.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man1/git-checkout.1.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man1/git-cherry-pick.1.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man1/git-cherry.1.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man1/git-citool.1.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man1/git-clean.1.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man1/git-clone.1.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man1/git-column.1.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man1/git-commit-graph.1.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man1/git-commit-tree.1.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man1/git-commit.1.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man1/git-config.1.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man1/git-count-objects.1.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man1/git-credential-cache--daemon.1.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man1/git-credential-cache.1.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man1/git-credential-store.1.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man1/git-credential.1.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man1/git-cvsexportcommit.1.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man1/git-cvsimport.1.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man1/git-cvsserver.1.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man1/git-daemon.1.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man1/git-describe.1.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man1/git-diff-files.1.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man1/git-diff-index.1.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man1/git-diff-tree.1.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man1/git-diff.1.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man1/git-difftool.1.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man1/git-fast-export.1.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man1/git-fast-import.1.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man1/git-fetch-pack.1.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man1/git-fetch.1.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man1/git-filter-branch.1.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man1/git-fmt-merge-msg.1.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man1/git-for-each-ref.1.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man1/git-for-each-repo.1.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man1/git-format-patch.1.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man1/git-fsck-objects.1.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man1/git-fsck.1.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man1/git-gc.1.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man1/git-get-tar-commit-id.1.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man1/git-grep.1.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man1/git-gui.1.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man1/git-hash-object.1.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man1/git-help.1.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man1/git-http-backend.1.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man1/git-http-fetch.1.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man1/git-http-push.1.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man1/git-imap-send.1.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man1/git-index-pack.1.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man1/git-init-db.1.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man1/git-init.1.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man1/git-instaweb.1.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man1/git-interpret-trailers.1.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man1/git-log.1.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man1/git-ls-files.1.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man1/git-ls-remote.1.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man1/git-ls-tree.1.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man1/git-mailinfo.1.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man1/git-mailsplit.1.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man1/git-maintenance.1.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man1/git-merge-base.1.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man1/git-merge-file.1.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man1/git-merge-index.1.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man1/git-merge-one-file.1.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man1/git-merge-tree.1.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man1/git-merge.1.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man1/git-mergetool--lib.1.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man1/git-mergetool.1.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man1/git-mktag.1.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man1/git-mktree.1.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man1/git-multi-pack-index.1.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man1/git-mv.1.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man1/git-name-rev.1.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man1/git-notes.1.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man1/git-p4.1.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man1/git-pack-objects.1.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man1/git-pack-redundant.1.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man1/git-pack-refs.1.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man1/git-patch-id.1.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man1/git-prune-packed.1.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man1/git-prune.1.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man1/git-pull.1.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man1/git-push.1.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man1/git-quiltimport.1.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man1/git-range-diff.1.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man1/git-read-tree.1.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man1/git-rebase.1.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man1/git-receive-pack.1.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man1/git-reflog.1.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man1/git-remote-ext.1.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man1/git-remote-fd.1.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man1/git-remote.1.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man1/git-repack.1.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man1/git-replace.1.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man1/git-request-pull.1.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man1/git-rerere.1.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man1/git-reset.1.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man1/git-restore.1.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man1/git-rev-list.1.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man1/git-rev-parse.1.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man1/git-revert.1.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man1/git-rm.1.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man1/git-send-email.1.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man1/git-send-pack.1.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man1/git-sh-i18n--envsubst.1.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man1/git-sh-i18n.1.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man1/git-sh-setup.1.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man1/git-shell.1.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man1/git-shortlog.1.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man1/git-show-branch.1.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man1/git-show-index.1.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man1/git-show-ref.1.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man1/git-show.1.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man1/git-sparse-checkout.1.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man1/git-stage.1.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man1/git-stash.1.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man1/git-status.1.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man1/git-stripspace.1.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man1/git-submodule.1.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man1/git-subtree.1.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man1/git-svn.1.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man1/git-switch.1.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man1/git-symbolic-ref.1.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man1/git-tag.1.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man1/git-unpack-file.1.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man1/git-unpack-objects.1.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man1/git-update-index.1.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man1/git-update-ref.1.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man1/git-update-server-info.1.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man1/git-upload-archive.1.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man1/git-upload-pack.1.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man1/git-var.1.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man1/git-verify-commit.1.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man1/git-verify-pack.1.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man1/git-verify-tag.1.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man1/git-web--browse.1.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man1/git-whatchanged.1.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man1/git-worktree.1.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man1/git-write-tree.1.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man1/git.1.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man1/gitk.1.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man1/gitweb.1.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man3/Git.3pm.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man5/gitattributes.5.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man5/githooks.5.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man5/gitignore.5.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man5/gitmailmap.5.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man5/gitmodules.5.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man5/gitrepository-layout.5.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man5/gitweb.conf.5.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man7/gitcli.7.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man7/gitcore-tutorial.7.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man7/gitcredentials.7.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man7/gitcvs-migration.7.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man7/gitdiffcore.7.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man7/giteveryday.7.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man7/gitfaq.7.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man7/gitglossary.7.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man7/gitnamespaces.7.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man7/gitremote-helpers.7.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man7/gitrevisions.7.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man7/gitsubmodules.7.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man7/gittutorial-2.7.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man7/gittutorial.7.gz est déjà présent dans le système de fichiers
git : /usr/share/man/man7/gitworkflows.7.gz est déjà présent dans le système de fichiers
git : /usr/share/perl5/vendor_perl/Git.pm est déjà présent dans le système de fichiers
git : /usr/share/perl5/vendor_perl/Git/I18N.pm est déjà présent dans le système de fichiers
git : /usr/share/perl5/vendor_perl/Git/IndexInfo.pm est déjà présent dans le système de fichiers
git : /usr/share/perl5/vendor_perl/Git/LoadCPAN.pm est déjà présent dans le système de fichiers
git : /usr/share/perl5/vendor_perl/Git/LoadCPAN/Error.pm est déjà présent dans le système de fichiers
git : /usr/share/perl5/vendor_perl/Git/LoadCPAN/Mail/Address.pm est déjà présent dans le système de fichiers
git : /usr/share/perl5/vendor_perl/Git/Mediawiki.pm est déjà présent dans le système de fichiers
git : /usr/share/perl5/vendor_perl/Git/Packet.pm est déjà présent dans le système de fichiers
git : /usr/share/perl5/vendor_perl/Git/SVN.pm est déjà présent dans le système de fichiers
git : /usr/share/perl5/vendor_perl/Git/SVN/Editor.pm est déjà présent dans le système de fichiers
git : /usr/share/perl5/vendor_perl/Git/SVN/Fetcher.pm est déjà présent dans le système de fichiers
git : /usr/share/perl5/vendor_perl/Git/SVN/GlobSpec.pm est déjà présent dans le système de fichiers
git : /usr/share/perl5/vendor_perl/Git/SVN/Log.pm est déjà présent dans le système de fichiers
git : /usr/share/perl5/vendor_perl/Git/SVN/Memoize/YAML.pm est déjà présent dans le système de fichiers
git : /usr/share/perl5/vendor_perl/Git/SVN/Migration.pm est déjà présent dans le système de fichiers
git : /usr/share/perl5/vendor_perl/Git/SVN/Prompt.pm est déjà présent dans le système de fichiers
git : /usr/share/perl5/vendor_perl/Git/SVN/Ra.pm est déjà présent dans le système de fichiers
git : /usr/share/perl5/vendor_perl/Git/SVN/Utils.pm est déjà présent dans le système de fichiers
Des erreurs se sont produites, aucun paquet n’a été mis à jour.
[stormer@stormer ~]$
Try overwriting all the files:
sudo pacman -S git --overwrite "*"
I love you.
