yesterday i installed majaro on my old mac, and i feel very good. I get an incredible boost!
but when i try to clone some repositories with git@ prefix and so using ssh key, git remains stucked and after some minute i get this message:
git clone git@github.com:helix-editor/helix.git
ssh: connect to host github.com port 22: Connection timed out
fatal: Could not read from remote repository.
Please make sure you have the correct access rights
and the repository exists.
my /.ssh/config:
Host github.com
User git
Port 22
Hostname github.com
IdentityFile ~/.ssh/id_rsa
also i tried to make a simple ssh prova2@tty.sdf.org using a fake server from SDFORG, but nothing i receive this message:
ssh: connect to host tty.sdf.org port 22: Connection timed out
what can be the problem? i think git isn’t the problem, but something related to 22 port?
What are the chances of having two of these back to back? …
That is: I believe you will find that plugging in through ethernet will have things work fine, and will want to look at Wi-Fi adapter/driver issues for that old mac.
Please first just test over ethernet lest you as in that other thread waste a lot of time looking at a problem that does not exist other than as a Wi-Fi driver problem.
thanks for your hints:
the problem was an documented error in my network card: broadcom_wireless wiki in the #SSH_freeze_for_BCM4331_with_b43 section.
i try to install the broadcom-wl-dkms, but don’t work. instead the precise broadcom-wl version of my installed kernel work fine!!!. i can use ssh now ^^ !!!
