Getting Soulseek to work
Hi there, first i tried to run the AppImage that is available on their site but it gives an SElinux library error.
Then i tried install SElinux through AUR but it failed building at the end.
How can i get this to work?
The only Soulseek client I know of with much development is Nicotine +. The recent stable version is available in the repos as nicotine+ and the development version is in the AUR as nicotine-plus-git.
In Pamac i only see nicotine-plus. I installed it and it does not open.
Where can i find the stable version?
It turns out nicotine was renamed to nicotine+ in the repos. It still should have come up searching for nicotine, though.
What’s the output running nicotine from the terminal?
  File "/usr/bin/nicotine", line 38, in <module>
    ApplyTranslation()
  File "/usr/lib/python3.8/site-packages/pynicotine/utils.py", line 250, in ApplyTranslation
    locale.setlocale(locale.LC_ALL, '')
  File "/usr/lib/python3.8/locale.py", line 608, in setlocale
    return _setlocale(category, locale)
locale.Error: unsupported locale setting
What is your locale set to? You can find out by running locale from the terminal.
    locale: Cannot set LC_CTYPE to default locale: No such file or directory
    locale: Cannot set LC_MESSAGES to default locale: No such file or directory
    locale: Cannot set LC_ALL to default locale: No such file or directory
    LANG=en_DE.UTF-8
    LC_CTYPE="en_DE.UTF-8"
    LC_NUMERIC=en_DE.UTF-8
    LC_TIME=en_DE.UTF-8
    LC_COLLATE="en_DE.UTF-8"
    LC_MONETARY=en_DE.UTF-8
    LC_MESSAGES="en_DE.UTF-8"
    LC_PAPER=de_DE.UTF-8
    LC_NAME=de_DE.UTF-8
    LC_ADDRESS=de_DE.UTF-8
    LC_TELEPHONE=de_DE.UTF-8
    LC_MEASUREMENT=en_DE.UTF-8
    LC_IDENTIFICATION=de_DE.UTF-8
    LC_ALL=
Moderator edit: In the future, please use proper formatting: [HowTo] Post command output and file content as formatted text
Something is wrong with your locale settings, but I’m not sure what.
I suggest creating a new topic in #support about it.
I have English as display language and German for formats, but it is on purpose.
The problematic part is LC_ALL has no value.
Again, this line of troubleshooting is off topic now for this thread and a new one should be created about it.
OK, thank you for your time.
You might want to try updating nicotine-plus-git as a new commit was added that may resolve the error you had:
I already have my locale setting correct, and nicotine running. Thanks anyway.
