This is a weird problem and I’m not sure how to explain it. I’m not one who usually cares about these things, but I am running into an issue.
There’s a game called Salt and Sanctuary that I play with my wired 360 controller.
The problem in Manjaro (I’ve been distrohopping of late, and haven’t encountered this in other distros; it didn’t even exist in Manjaro until recently) is that if I hit the X button rapidly (as you do), quite often nothing happens. The action only translates onto the screen after the 2nd input
Its really frustrating and I’m not sure why this is happening.
Anyone with any clue?
Fabby
30 March 2021 12:49
2
Welcome to Manjaro!
Please read this:
How to provide good information
and post some more information so we can see what’s really going on. Now we know the symptom of the disease, but we need some more probing to know where the origin lies…
An inxi --admin --verbosity=7 --filter --no-host --width would be the minimum required information… (Personally Identifiable Information like serial numbers and MAC addresses will be filtered out by the above command)
Also, please copy-paste that output in-between 3 backticks ``` at the beginning and end of the code/text .
P.S. If you enter a bit more details in your profile, we can also see which Desktop Environment you’re using, which CPU/GPU or Kernel, … you have without typing it every time
Here’s the output to inxi
Kernel: 5.13.13-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=56b72b32-0a04-4dc6-8886-b622ea20285a rw quiet apparmor=1
security=apparmor resume=UUID=6615673e-d89d-4223-86dd-b04660ae5f7c
udev.log_priority=3 processor.max_cstate=1 idle=nomwait
Desktop: KDE Plasma 5.22.5 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1
Type: Desktop Mobo: ASRock model: B450 Pro4 serial: <filter>
UEFI-[Legacy]: American Megatrends v: P3.50 date: 07/18/2019
RAM: total: 7.69 GiB used: 5.83 GiB (75.8%)
Info: 6-Core model: AMD Ryzen 5 1600 bits: 64 type: MT MCP arch: Zen
family: 17 (23) model-id: 1 stepping: 1 microcode: 8001138 cache: L2: 3 MiB
bogomips: 76672
Speed: 3294 MHz min/max: 1550/3200 MHz boost: enabled Core speeds (MHz):
1: 3294 2: 2304 3: 1526 4: 1860 5: 1675 6: 2478 7: 1834 8: 1408 9: 3352
10: 1933 11: 1640 12: 2040
bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb cpuid
fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb irperf lahf_lm lbrv lm mca
mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx nonstop_tsc nopl
npt nrip_save nx osvw overflow_recov pae pat pausefilter pclmulqdq pdpe1gb
perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse pse36
rdrand rdseed rdtscp rep_good sep sev sha_ni skinit smap smca sme smep ssbd
sse sse2 sse4_1 sse4_2 sse4a ssse3 succor svm svm_lock syscall tce topoext
tsc tsc_scale v_vmsave_vmload vgif vmcb_clean vme vmmcall wdt xgetbv1 xsave
xsavec xsaveerptr xsaveopt xsaves
disabled, RSB filling
Device-1: AMD Ellesmere [Radeon RX 470/480/570/570X/580/580X/590]
vendor: XFX Pine driver: amdgpu v: kernel bus-ID: 09:00.0 chip-ID: 1002:67df
class-ID: 0300
loaded: amdgpu,ati unloaded: modesetting alternate: fbdev,vesa
display-ID: :0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: HDMI-A-0 res: 1920x1080 hz: 60 dpi: 93
size: 527x296mm (20.7x11.7") diag: 604mm (23.8")
OpenGL: renderer: Radeon RX 570 Series (POLARIS10 DRM 3.41.0
5.13.13-1-MANJARO LLVM 12.0.1)
v: 4.6 Mesa 21.2.1 direct render: Yes
Device-1: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]
vendor: XFX Pine driver: snd_hda_intel v: kernel bus-ID: 09:00.1
chip-ID: 1002:aaf0 class-ID: 0403
Device-2: AMD Family 17h HD Audio vendor: ASRock driver: snd_hda_intel
v: kernel bus-ID: 0b:00.3 chip-ID: 1022:1457 class-ID: 0403
Sound Server-1: ALSA v: k5.13.13-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.34 running: yes
Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel bus-ID: 05:00.0
chip-ID: 8086:2723 class-ID: 0280
IF: wlp5s0 state: up mac: <filter>
IP v6: <filter> type: noprefixroute scope: global
vendor: ASRock driver: r8169 v: kernel port: d000 bus-ID: 08:00.0
IF: enp8s0 state: down mac: <filter>
Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 1-8:3
Report: rfkill ID: hci0 rfk-id: 17 state: up address: see --recommends
Local Storage: total: 1.21 TiB used: 418.8 GiB (33.7%)
ID-1: /dev/sda maj-min: 8:0 vendor: Kingston model: SHFS37A240G
size: 223.57 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: BBF2 scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST9320423AS
size: 298.09 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
type: HDD rpm: 7200 serial: <filter> rev: LVM1 scheme: GPT
ID-3: /dev/sdc maj-min: 8:32 vendor: Crucial model: CT275MX300SSD1
size: 256.17 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: R060 scheme: GPT
ID-4: /dev/sdd maj-min: 8:48 vendor: Toshiba model: DT01ACA050
size: 465.76 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
type: HDD rpm: 7200 serial: <filter> rev: A750 scheme: GPT
ID-1: / raw-size: 214.77 GiB size: 210.34 GiB (97.94%) used: 14.7 GiB (7.0%)
fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: 56b72b32-0a04-4dc6-8886-b622ea20285a
ID-2: /run/media/user/Backup raw-size: 465.76 GiB size: 465.76 GiB (100.00%)
used: 403.79 GiB (86.7%) fs: ntfs dev: /dev/sdd1 maj-min: 8:49 label: Backup
uuid: 5CA794D1793D3AC5
ID-1: swap-1 type: partition size: 8.8 GiB used: 316.5 MiB (3.5%)
priority: -2 dev: /dev/sda2 maj-min: 8:2 label: swap
uuid: 6615673e-d89d-4223-86dd-b04660ae5f7c
ID-1: /dev/sdb1 maj-min: 8:17 size: 298.09 GiB fs: ntfs label: Second Backup
uuid: 49B89AA45F1559CE
ID-2: /dev/sdc1 maj-min: 8:33 size: 529 MiB fs: ntfs label: Recovery
uuid: 5EB43888B43864A5
ID-3: /dev/sdc2 maj-min: 8:34 size: 100 MiB fs: vfat label: N/A
uuid: 083B-33D9
ID-4: /dev/sdc3 maj-min: 8:35 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-5: /dev/sdc4 maj-min: 8:36 size: 255.54 GiB fs: ntfs label: N/A
uuid: EAE84ACDE84A9829
Device-1: 1-7:2 info: Microdia USB DEVICE type: Keyboard,Mouse
power: 400mA chip-ID: 0c45:672e class-ID: 0301
Device-2: 1-8:3 info: Intel AX200 Bluetooth type: Bluetooth driver: btusb
class-ID: e001
Device-3: 1-10:4 info: SINOWEALTH Game Mouse type: Mouse,Keyboard
driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 12 Mb/s
power: 256mA chip-ID: 258a:1007 class-ID: 0301
Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Device-1: 3-3:2 info: Microsoft Xbox360 Controller type: <vendor specific>
driver: xpad interfaces: 4 rev: 2.0 speed: 12 Mb/s power: 500mA
chip-ID: 045e:028e class-ID: ff00 serial: <filter>
Device-2: 3-4:3 info: Elan Micro type: Keyboard driver: hid-generic,usbhid
interfaces: 1 rev: 1.1 speed: 1.5 Mb/s power: 100mA chip-ID: 04f3:0104
class-ID: 0301
Hub-4: 4-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 45.0 C mobo: N/A gpu: amdgpu temp: 53.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 1064
Processes: 350 Uptime: 1d 10h 14m wakeups: 112 Init: systemd v: 248
tool: systemctl Compilers: gcc: 11.1.0 Packages: pacman: 1283 lib: 359
flatpak: 0 Shell: Zsh v: 5.8 default: Bash v: 5.1.8 running-in: konsole
inxi: 3.3.06
Unfortunately the output of journalctl is a little wonky, I don’t think its right
Sep 09 08:36:06 user-desk kernel: xpad 3-3:1.0: xpad_try_sending_next_out_packet - usb_submit_urb failed with result -2
Fabby
9 September 2021 13:54
4
helpcomputer:
5.13.13-1-MANJARO
Please read this:
Difficulty: ☆☆☆☆☆
Remember when you installed your very first Windows, added bells and whistles and then couldn’t see the wood for the trees any more and had to re-install?
Well, you’re in the same situation now: You’re a N00b again! Embrace it!
I know right now you’re thinking:
Why is this so much more difficult than Windows? [image]
Whereas in 6 months time, you’ll be like:
Why can't I make Windows jump through fiery hoops like I do with Linux??? <a class="lightbox&qu…
Especially the Linux has multiple kernels section, then try an LTS kernel and see if the problem goes away automagically.
If not:
