I was using the GUI, and after installing my updates, rc6 was listed.
So I’ve installed rc6, and can confirm that the touchpad is now working.
Thanks.
FYI: I’ll keep rc6 installed, but probably not be using it by default, as I always use a wireless keyboard and mouse. But if I go out, then rc6 will be useful.
I’ve marked the below answer as the solution to your question as it is by far the best answer you’ll get.
However, if you disagree with my choice, please feel free to take any other answer as the solution to your question or even remove the solution altogether: You are in control! (I just want to avoid even more subjective opinions being posted and confusing you even more)
P.S. In the future, please mark a solution like this:
