Get all installed packages on a non running system
Hi. My Manjaro SSD is not booting anymore.
I tried to follow the instruction to recreate GRUB but it fails so I will set up Manjaro on a new SSD.
I can still access the root partition and all data on it. Is there a way to get a list of all installed packages from this non running partition?
So, that I can use this list to install the same packages on the new SSD.
Each package has an entry in /var/lib/pacman/local/
as a separate subdirectory
and in each one there is a file “descr”
The content starts with the keyword %NAME%
and in the next line is the name of the package
for example:
%NAME%
zsh
for
less /var/lib/pacman/local/zsh-5.9-5/desc
How to extract all of them with one command I don’t know.
Something with grep …
chroot into the system from a booted live ISO should let you use pacman for that - see the Arch wiki where you’ll find the command to create the list
Yes! Boot up from the live USB and chroot into your installed system, and then run these two commands… :point_down:
pacman -Qnq > pkglist-repos.txt
pacman -Qmq > pkglist-foreign.txt
The first of those files will contain a list of all the installed packages from the official Manjaro repos, and the second one will contain a list of all the installed packages from the AUR.
I’m afraid I can’t tell you how to list Snaps or FlatPaks, though — I don’t have either of those installed — but I’m sure there’s a way for that too by using the appropriate tools. :wink:
Fantastic! Thanks! :+1:
I only use native and Arch packages so your suggestions cover all what I need.
There is a wiki page for this situation
pacman/Restore local database - ArchWiki
[root tip] [Utililty Script] Backup configuration and package list
I would also advise you to make a backup copy of your /etc directory and its subdirectories, and especially so if you’ve made any changes to system-wide configuration files that you would like to retain, such as for instance if you’ve changed anything under /etc/pam.d, or files like /etc/default/grub, /etc/mkinitcpio.conf and/or /etc/sysctl.d/*.
It’s easier to restore a backup than to have to reconfigure everything by hand. :wink:
