pacman -Qs virtualbox
local/linux515 5.15.76-1
The Linux515 kernel and modules
local/linux515-virtualbox-host-modules 7.0.2-3 (linux515-extramodules)
Virtualbox host kernel modules for Manjaro Kernel
local/virtualbox 7.0.2-1
Powerful x86 virtualization for enterprise as well as home use
pacman -Qs genymotion
local/genymotion 3.3.1-1
Complete set of tools that provides a virtual environment for Android.
vboxmanage --version
7.0.2r154219
uname -a
Linux bul 5.15.76-1-MANJARO #1 SMP PREEMPT Sat Oct 29 14:22:16 UTC 2022 x86_64 GNU/Linux
pacman-mirrors
Pacman-mirrors version 4.23.2
Local mirror status for stable branch
Mirror #1 OK 00:38 Australia https://manjaro.lucassymons.net/
Mirror #2 OK 00:18 Austria https://mirror.alwyzon.net/manjaro/
Mirror #3 OK 01:48 Canada https://mirror.xenyth.net/manjaro/
Mirror #4 OK 00:52 United_States https://mnvoip.mm.fcix.net/manjaro/
Mirror #5 OK 04:40 Netherlands https://mirror.koddos.net/manjaro/
Mirror #6 OK 00:08 Bulgaria https://manjaro.ipacct.com/manjaro/
Mirror #7 OK 04:40 Italy https://ct.mirror.garr.it/mirrors/manjaro/
neofetch
██████████████████ ████████ bul@bul
██████████████████ ████████ OS: Manjaro Linux x86_64
██████████████████ ████████ Kernel: 5.15.76-1-MANJARO
████████ ████████ Uptime: 6 hours, 55 mins
████████ ████████ ████████ Packages: 1258 (pacman), 7 (snap)
████████ ████████ ████████ Shell: bash 5.1.16
████████ ████████ ████████ Resolution: 1920x1080
████████ ████████ ████████ DE: Xfce 4.16
████████ ████████ ████████ WM: Xfwm4
████████ ████████ ████████ WM Theme: Matcha-sea
████████ ████████ ████████ Theme: Matcha-sea [GTK2], Adwaita [GTK3]
████████ ████████ ████████ Icons: Papirus-Maia [GTK2], Adwaita [GTK3]
████████ ████████ ████████ Terminal: xfce4-terminal
Terminal Font: Monospace 12
CPU: Intel i7-3770 (8) @ 3.900GHz
GPU: Intel IvyBridge GT2 [HD Graphics 4000]
Memory: 4531MiB / 18948MiB
I dont think this is a local issue. Please see screenshot attached
Please see my screenshot as well as this link:
https://support.genymotion.com/hc/en-us/articles/115002720469-VirtualBox-supported-versions
Thank you, ill try the dkms package and report back
Does anyone know why this is happening?
sudo pacman -Syu virtualbox-host-dkms
[sudo] password for bul:
core is up to date
extra is up to date
community is up to date
multilib is up to date
:: virtualbox-host-dkms is in IgnorePkg/IgnoreGroup. Install anyway? [Y/n] y
resolving dependencies...
:: virtualbox-host-dkms and linux515-virtualbox-host-modules are in conflict. Remove linux515-virtualbox-host-modules? [y/N] y
Packages (2) linux515-virtualbox-host-modules-7.0.2-3 [removal]
virtualbox-host-dkms-7.0.2-1
Total Installed Size: 11.12 MiB
Net Upgrade Size: 10.87 MiB
:: Proceed with installation? [Y/n] y
(1/1) checking keys in keyring [######################] 100%
(1/1) checking package integrity [######################] 100%
(1/1) loading package files [######################] 100%
(1/1) checking for file conflicts [######################] 100%
(2/2) checking available disk space [######################] 100%
(1/1) removing linux515-virtualbox-host-modules [######################] 100%
(1/1) installing virtualbox-host-dkms [######################] 100%
(1/3) Arming ConditionNeedsUpdate...
(2/3) Updating module dependencies...
(3/3) Install DKMS modules
==> ERROR: Missing sys kernel headers for module vboxhost/7.0.2_OSE.
==> ERROR: Missing srv kernel headers for module vboxhost/7.0.2_OSE.
==> ERROR: Missing lost+found kernel headers for module vboxhost/7.0.2_OSE.
==> ERROR: Missing sbin kernel headers for module vboxhost/7.0.2_OSE.
==> ERROR: Missing opt kernel headers for module vboxhost/7.0.2_OSE.
==> ERROR: Missing usr kernel headers for module vboxhost/7.0.2_OSE.
==> ERROR: Missing media kernel headers for module vboxhost/7.0.2_OSE.
==> ERROR: Missing run kernel headers for module vboxhost/7.0.2_OSE.
==> ERROR: Missing rootfs-pkgs.txt kernel headers for module vboxhost/7.0.2_OSE.
==> ERROR: Missing var kernel headers for module vboxhost/7.0.2_OSE.
==> ERROR: Missing lib64 kernel headers for module vboxhost/7.0.2_OSE.
==> ERROR: Missing bin kernel headers for module vboxhost/7.0.2_OSE.
==> ERROR: Missing proc kernel headers for module vboxhost/7.0.2_OSE.
==> ERROR: Missing boot kernel headers for module vboxhost/7.0.2_OSE.
==> ERROR: Missing lib kernel headers for module vboxhost/7.0.2_OSE.
==> ERROR: Missing mnt kernel headers for module vboxhost/7.0.2_OSE.
==> ERROR: Missing dev kernel headers for module vboxhost/7.0.2_OSE.
==> ERROR: Missing root kernel headers for module vboxhost/7.0.2_OSE.
==> ERROR: Missing tmp kernel headers for module vboxhost/7.0.2_OSE.
==> ERROR: Missing desktopfs-pkgs.txt kernel headers for module vboxhost/7.0.2_OSE.
==> ERROR: Missing etc kernel headers for module vboxhost/7.0.2_OSE.
==> ERROR: Missing home kernel headers for module vboxhost/7.0.2_OSE.
sudo vboxreload
Unloading modules: vboxnetadp vboxnetflt vboxdrv
Loading modules: modprobe: FATAL: Module vboxnetadp not found in directory /lib/modules/5.15.76-1-MANJARO
modprobe: FATAL: Module vboxnetflt not found in directory /lib/modules/5.15.76-1-MANJARO
modprobe: FATAL: Module vboxdrv not found in directory /lib/modules/5.15.76-1-MANJARO
Moderator edit: In the future, please use proper formatting: [HowTo] Post command output and file content as formatted text
