pacman -Qs virtualbox
local/linux515 5.15.76-1
The Linux515 kernel and modules
local/linux515-virtualbox-host-modules 6.1.38-2 (linux515-extramodules)
Virtualbox host kernel modules for Manjaro Kernel
local/virtualbox 6.1.38-1
Powerful x86 virtualization for enterprise as well as home use
sudo vboxreload
[sudo] password for bul:
Unloading modules:
Loading modules: modprobe: ERROR: could not insert 'vboxnetadp': Exec format error
modprobe: ERROR: could not insert 'vboxnetflt': Exec format error
modprobe: ERROR: could not insert 'vboxdrv': Exec format error
How does one successfully downgrade virtualbox without getting the Kernel Driver Not Installed (rc=-1908) error from virtualbox itself (if you try to run a VM from within Virtualbox only)
Is a successful virtualbox downgrade in Manjaro possible?
but Manjaro stable is a different thing than Arch - I think I saw someone mentioning in this thread here that the testing or unstable branch of Manjaro would be more suitable for this kind of thing - it’s closer to Arch
If i remove linux515-virtualbox-host-modules 6.1.38-2 (linux515-extramodules) and virtualbox 6.1.38-1, how can i install the previous (non v7) versions without going the downgrade route? What is the correct way to do it?
Ok, can you tell me how does virtualbox-host-modules and dkms differ?
the dkms is built against your actual installed kernel version and whatever virtualbox version you have
the precompiled version requires that kernel version and kernel module version and virtualbox version match
dkms will always match because it’s built against the installed versions of the two
If i have a closer look at your provided screenshot, the Genymotion icon seems like the one from a previous version (3.2.x).
If i would like to try to install a previous version of genymotion, how would i go about that (as i think the virtualbox v7 error was introduced in the 3.3.x versions)
local/linux515 5.15.78-1
local/linux61 6.1.0rc4-1
The Linux61 kernel and modules
local/linux61-virtualbox-host-modules 7.0.2-0.5 (linux61-extramodules)
local/virtualbox 7.0.2-2
local/virtualbox-guest-iso 7.0.2-1
The official VirtualBox Guest Additions ISO image
