philco
26 October 2020 19:37
1
The video on the Chrome OS client of GeForce NOW go into slow-motion after some time (it may happens after some seconds or minutes with the game opened), the audio continues to play as if the video was not in slow-motion (with this, I can relate that the controls continue to be sent without problems). During this slow-motion, all CPU threads are over 50% in use, as I can check in htop. If I pause the game and wait the CPU threads usage reach around 20% of use and return to game, the slow-motion stops. I tested on Chromium and Google Chrome (AUR ).
P.S.: I use VPN to open the game, but I disable when the game starts (and I tested stay with VPN during the game).
P.S. 2: I tested it on Chrome on Windows 10 and I didn’t have this problem.
Kernel: 5.8.16-2-MANJARO x86_64 bits: 64 compiler: N/A
parameters: BOOT_IMAGE=/boot/vmlinuz-5.8-x86_64
root=UUID=bc25527c-e1e8-4753-a400-02ce7f4fe30b rw quiet apparmor=1
security=apparmor resume=UUID=00e25de2-5851-4013-a934-22c04453383f
udev.log_priority=3
Desktop: GNOME 3.36.6 tk: GTK 3.24.23 wm: gnome-shell dm: GDM 3.36.3
Distro: Manjaro Linux
Type: Laptop System: Acer product: Aspire E1-571 v: V2.21 serial: <filter>
Chassis: Insyde Corp. type: 10 v: 2.21 serial: <filter>
Mobo: Acer model: EA50_HC_CR v: Type2 - Board Version serial: <filter>
UEFI: Insyde v: 2.21 date: 12/16/2013
Topology: Dual Core model: Intel Core i5-3230M bits: 64 type: MT MCP
arch: Ivy Bridge family: 6 model-id: 3A (58) stepping: 9 microcode: 21
L2 cache: 3072 KiB
flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 20761
Speed: 1257 MHz min/max: 1200/3200 MHz Core speeds (MHz): 1: 1197 2: 1197
3: 1197 4: 1197
Type: l1tf
Type: srbds status: Vulnerable: No microcode
Device-1: Intel 3rd Gen Core processor Graphics
vendor: Acer Incorporated ALI driver: i915 v: kernel bus ID: 00:02.0
chip ID: 8086:0166
Display: x11 server: X.org 1.20.9 compositor: gnome-shell driver: intel
unloaded: modesetting alternate: fbdev,vesa resolution: <xdpyinfo missing>
OpenGL: renderer: Mesa DRI Intel HD Graphics 4000 (IVB GT2)
v: 4.2 Mesa 20.1.8 compat-v: 3.0 direct render: Yes
Device-1: Intel 7 Series/C216 Family High Definition Audio
vendor: Acer Incorporated ALI driver: snd_hda_intel v: kernel
bus ID: 00:1b.0 chip ID: 8086:1e20
Sound Server: ALSA v: k5.8.16-2-MANJARO
Device-1: Broadcom and subsidiaries NetLink BCM57785 Gigabit Ethernet PCIe
vendor: Acer Incorporated ALI driver: tg3 v: kernel port: 2040
bus ID: 02:00.0 chip ID: 14e4:16b5
IF: enp2s0f0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-2: Qualcomm Atheros AR9485 Wireless Network Adapter vendor: Lite-On
driver: ath9k v: kernel port: 2040 bus ID: 03:00.0 chip ID: 168c:0032
IF: wlp3s0 state: down mac: <filter>
IF-ID-1: anbox0 state: down mac: <filter>
Local Storage: total: 465.76 GiB used: 224.00 GiB (48.1%)
ID-1: /dev/sda vendor: Seagate model: ST500VT000-1DK142 size: 465.76 GiB
block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
rotation: 5400 rpm serial: <filter> rev: SDC1 scheme: GPT
ID-1: / raw size: 80.47 GiB size: 78.71 GiB (97.81%) used: 43.99 GiB (55.9%)
fs: ext4 dev: /dev/sda7
ID-2: /home raw size: 210.01 GiB size: 205.71 GiB (97.95%)
used: 180.00 GiB (87.5%) fs: ext4 dev: /dev/sda8
ID-1: swap-1 type: partition size: 2.00 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda6
System Temperatures: cpu: 68.0 C mobo: N/A
Processes: 267 Uptime: 3h 44m Memory: 5.70 GiB used: 2.40 GiB (42.2%)
Init: systemd v: 246 Compilers: gcc: 10.2.0 clang: 10.0.1 Packages: 1553
pacman: 1499 lib: 392 flatpak: 47 snap: 7 Shell: Zsh v: 5.8
running in: gnome-terminal inxi: 3.1.05
Fabby
27 October 2020 14:49
2
It’s unclear to me what you’re running exactly in the Chrome browser, but you’re on an Intel GPU, so the best thing to do is to try out another kernel as the Intel GPU modules are built into the kernel.
As you’re on a rather old processor 4.19 and 5.4 (both LTS) come to mind first:
Print this page so you have it as a reference while in TTY2
Log off
Switch to TTY2 by pressing Ctrl +Alt +F2
Log in there
Execute:
sudo mhwd-kernel --install linux419
sudo mhwd-kernel --install linux54
to ensure grub is showing, execute:
sudo nano --backup /etc/default/grub
Change (or add?) the following 3 lines:
GRUB_TIMEOUT=3
#GRUB_HIDDEN_TIMEOUT=0
#GRUB_TIMEOUT_STYLE=hidden
(3 or higher is fine, add the # before the lines above if those lines are present)
Ctrl +X Y Enter to save if there is anything to save
If you did save, execute:
sudo update-grub
Reboot
Go to grub’s Advanced options
Choose these kernels one by one and try them out one by one and see if that helps.
philco
27 October 2020 19:20
3
I tried what you said. I had already tried the GeForce NOW on Linux 5.4 before changing to Linux 5.8, I tried the 5.4 again and the 4.19. In both I had the same behavior as in the 5.8. (After reinstalling 5.4 or installing the 4.19, the 5.8 had an error to start, something related to loading kernel modules. I had to reinstall the 5.8, and now it appears to be normal.)
I’m testing the GeForce NOW , that is a cloud gaming service. Recently it added Chrome OS support, and it can now run on Linux (https://www.gamingonlinux.com/2020/08/nvidia-geforce-now-adds-chromebook-support-so-you-can-run-it-on-linux-too ).
cscs
27 October 2020 19:26
4
Seems you need to get hw-accel working in your chrom*
(check the archwiki and/or some threads here)
cscs
27 October 2020 19:31
6
Maybe try with these as a test:
chromium --enable-accelerated-video --enable-accelerated-mjpeg-decode --enable-gpu-rasterization --enable-oop-rasterization --enable-quic --enable-zero-copy --enable-native-gpu-memory-buffers --ignore-gpu-blocklist --use-gl=desktop --enable-accelerated-video-decode
https://wiki.archlinux.org/index.php/Chromium#Hardware_video_acceleration
(PS - I am assuming xorg … might be important to note if using wayland)
philco
27 October 2020 19:40
7
I noticed that libva-intel-driver was not installed.
(Wasn’t this meant to be preinstalled?)
cscs
27 October 2020 19:43
8
Depends on your hardware … that ones technically older…
HD Graphics series starting from Broadwell (2014) and newer are supported by intel-media-driver.
So make sure you have one of them
(preferably the newer intel-media-driver)
https://wiki.archlinux.org/index.php/Hardware_video_acceleration
PS - in chrom* check chrome://gpu for the first section like this
[here is mine from ungoogled-chromium… notice all is good except vulkan]
Graphics Feature Status
Canvas: Hardware accelerated
Compositing: Hardware accelerated
Multiple Raster Threads: Enabled
Out-of-process Rasterization: Hardware accelerated
OpenGL: Enabled
Hardware Protected Video Decode: Hardware accelerated
Rasterization: Hardware accelerated on all pages
Skia Renderer: Enabled
Vulkan: Disabled
WebGL: Hardware accelerated
WebGL2: Hardware accelerated
cscs
27 October 2020 19:48
10
I guess that means one of those flags didnt work well for you ?
Do you have one of those vaapi packages? media or otherwise?
Is this xorg or wayland ?
philco
27 October 2020 19:49
11
I have an Ivy Bridge, so it’s one generation before Broadwell.
cscs
27 October 2020 19:50
12
OK… well then you would want to have libva-intel-driver rather than intel-media-driver
So make sure thats the case.
(sorry I should have looked back up at your inxi)
philco
27 October 2020 19:53
13
Maybe
No, I will install the libva-intel-driver now.
Xorg
cscs
27 October 2020 20:06
16
Is that using the flags above ?
Once you have those packages … please try with the flags again
(I guess I should remove quic and mjpeg…)
chromium --enable-gpu-rasterization --enable-oop-rasterization --enable-zero-copy --enable-native-gpu-memory-buffers --ignore-gpu-blocklist --use-gl=desktop --enable-accelerated-video-decode
philco
27 October 2020 20:10
17
No, but with the flags, I had this:
cscs
27 October 2020 20:11
18
Well please try again with the line shown above. (I removed some unnecessary options)
Reposting the same picture doesnt help
philco
27 October 2020 20:13
19
I had this (on a first moment, it’s stucked and I can’t scroll the page. But after some seconds, the page seems to respond):
cscs
27 October 2020 20:15
20
Remove the options, adding them back one by one until you find out which is causing the issue.
For all we know … maybe vaapi+chrom is funky on this hardware.
