I’m running a fresh install of Manjaro Gnome. When I boot, I get a black screen. After going into the terminal mode, I can run startx or systemctl restart gdm and everything works, but I have to go into the terminal mode to do that… Any ideas what seems to be the problem?
> Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
video-hybrid-intel-nvidia-450xx-prime 2019.10.25 false PCI
video-modesetting 2020.01.13 true PCI
[ 3.434] (--) Log file renamed from "/var/log/Xorg.pid-813.log" to "/var/log/Xorg.0.log"
[ 3.434] (WW) Failed to open protocol names file lib/xorg/protocol.txt
[ 3.435]
X.Org X Server 1.20.9
[ 3.435] Build Operating System: Linux Manjaro Linux
[ 3.435] Current Operating System: Linux yecine-xps159560 5.8.11-1-MANJARO #1 SMP PREEMPT Wed Sep 23 14:35:40 UTC 2020 x86_64
[ 3.435] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.8-x86_64 root=UUID=fa197283-acde-4f0e-966c-e1fc4f8f94df rw acpi_rev_override=1 pcie_aspm=off acpi_blacklight=none acpi_osi=Linux acpi_osi=! "acpi_osi=Windows 2009" systemd.mask=mhwd.live.service apparmor=1 security=apparmor resume=UUID=997a0a2e-1817-4b2e-8a35-0da6cbca7efe udev.log_priority=3
[ 3.435] Build Date: 02 September 2020 07:39:17AM
[ 3.435]
[ 3.435] Current version of pixman: 0.40.0
[ 3.435] Before reporting problems, check http://wiki.x.org
[ 3.435] Markers: (--) probed, (**) from config file, (==) default setting,
[ 3.435] (==) Log file: "/var/log/Xorg.0.log", Time: Tue Oct 13 14:19:38 2020
[ 3.436] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 3.436] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 3.437] (==) ServerLayout "layout"
[ 3.437] (==) No screen section available. Using defaults.
[ 3.437] (**) |-->Screen "Default Screen Section" (0)
[ 3.437] (**) | |-->Monitor "<default monitor>"
[ 3.437] (==) No monitor specified for screen "Default Screen Section".
[ 3.437] (==) Automatically adding devices
[ 3.437] (==) Automatically enabling devices
[ 3.437] (==) Automatically adding GPU devices
[ 3.437] (==) Automatically binding GPU devices
[ 3.437] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 3.438] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/misc".
[ 3.438] Entry deleted from font path.
[ 3.438] (Run 'mkfontdir' on "/usr/share/fonts/misc").
[ 3.438] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/TTF".
[ 3.438] (Run 'mkfontdir' on "/usr/share/fonts/TTF").
[ 3.438] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[ 3.438] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[ 3.438] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[ 3.438] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[ 3.438] (==) FontPath set to:
[ 3.438] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 3.438] (II) The server relies on udev to provide the list of input devices.
[ 3.438] (II) Module ABI versions:
[ 3.438] X.Org ANSI C Emulation: 0.4
[ 3.438] X.Org Video Driver: 24.1
[ 3.438] X.Org XInput driver : 24.1
[ 3.438] X.Org Server Extension : 10.0
[ 3.439] (++) using VT number 1
[ 3.441] (II) systemd-logind: took control of session /org/freedesktop/login1/session/_31
[ 3.444] (--) PCI:*(0@0:2:0) 8086:591b:1028:07be rev 4, Mem @ 0xeb000000/16777216, 0x80000000/268435456, I/O @ 0x0000f000/64, BIOS @ 0x????????/131072
[ 3.444] (--) PCI: (1@0:0:0) 10de:1c8d:1028:07be rev 161, Mem @ 0xec000000/16777216, 0xc0000000/268435456, 0xd0000000/33554432, I/O @ 0x0000e000/128, BIOS @ 0x????????/524288
[ 3.444] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[ 3.444] (II) LoadModule: "glx"
[ 3.445] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 3.451] (II) Module glx: vendor="X.Org Foundation"
[ 3.451] compiled for 1.20.9, module version = 1.0.0
[ 3.451] ABI class: X.Org Server Extension, version 10.0
[ 3.451] (==) Matched intel as autoconfigured driver 0
[ 3.451] (==) Matched modesetting as autoconfigured driver 1
[ 3.451] (==) Matched fbdev as autoconfigured driver 2
[ 3.451] (==) Matched vesa as autoconfigured driver 3
[ 3.451] (==) Assigned the driver to the xf86ConfigLayout
[ 3.451] (II) LoadModule: "intel"
[ 3.451] (WW) Warning, couldn't open module intel
[ 3.451] (EE) Failed to load module "intel" (module does not exist, 0)
[ 3.451] (II) LoadModule: "modesetting"
[ 3.451] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[ 3.453] (II) Module modesetting: vendor="X.Org Foundation"
[ 3.453] compiled for 1.20.9, module version = 1.20.9
[ 3.453] Module class: X.Org Video Driver
[ 3.453] ABI class: X.Org Video Driver, version 24.1
[ 3.453] (II) LoadModule: "fbdev"
[ 3.453] (WW) Warning, couldn't open module fbdev
[ 3.453] (EE) Failed to load module "fbdev" (module does not exist, 0)
[ 3.453] (II) LoadModule: "vesa"
[ 3.453] (WW) Warning, couldn't open module vesa
[ 3.453] (EE) Failed to load module "vesa" (module does not exist, 0)
[ 3.453] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 3.453] (EE) open /dev/dri/card0: No such file or directory
[ 3.453] (WW) Falling back to old probe method for modesetting
[ 3.453] (EE) Screen 0 deleted because of no matching config section.
[ 3.453] (II) UnloadModule: "modesetting"
[ 3.453] (EE) Device(s) detected, but none match those in the config file.
[ 3.453] (EE)
Fatal server error:
[ 3.453] (EE) no screens found(EE)
[ 3.454] (EE)
Please consult the The X.Org Foundation support
at http://wiki.x.org
for help.
[ 3.454] (EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
[ 3.454] (EE)
[ 3.454] (EE) Server terminated with error (1). Closing log file.
/etc/default/grub
GRUB_DEFAULT="saved"
GRUB_TIMEOUT="10"
GRUB_TIMEOUT_STYLE="hidden"
GRUB_DISTRIBUTOR="Manjaro"
GRUB_CMDLINE_LINUX_DEFAULT="acpi_rev_override=1 pcie_aspm=off acpi_blacklight=none acpi_osi=Linux acpi_osi=! acpi_osi='Windows 2009' systemd.mask=mhwd.live.service apparmor=1 security=apparmor resume=UUID=997a0a2e-1817-4b2e-8a35-0da6cbca7efe udev.log_priority=3"
GRUB_CMDLINE_LINUX=""
# If you want to enable the save default function, uncomment the following
# line, and set GRUB_DEFAULT to saved.
GRUB_SAVEDEFAULT="true"
#GRUB_ENABLE_CRYPTODISK="y"
GRUB_TERMINAL_INPUT="console"
#GRUB_TERMINAL_OUTPUT="console"
GRUB_GFXMODE="auto"
GRUB_GFXPAYLOAD_LINUX="keep"
#GRUB_DISABLE_LINUX_UUID="true"
GRUB_DISABLE_RECOVERY="true"
# Uncomment and set to the desired menu colors. Used by normal and wallpaper
# modes only. Entries specified as foreground/background.
#GRUB_THEME="/path/to/gfxtheme"
#GRUB_INIT_TUNE="480 440 1"
Still, stuck on the boot
However, the logs are slightly changed: /var/log/Xorg.0.log
[ 3.398] (--) Log file renamed from "/var/log/Xorg.pid-803.log" to "/var/log/Xorg.0.log"
[ 3.398] (WW) Failed to open protocol names file lib/xorg/protocol.txt
[ 3.399]
[ 3.399] Build Operating System: Linux Manjaro Linux
[ 3.399] Current Operating System: Linux yecine-xps159560 5.8.11-1-MANJARO #1 SMP PREEMPT Wed Sep 23 14:35:40 UTC 2020 x86_64
[ 3.399] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.8-x86_64 root=UUID=fa197283-acde-4f0e-966c-e1fc4f8f94df rw acpi_rev_override=1 pcie_aspm=off acpi_blacklight=none acpi_osi=Linux acpi_osi=! "acpi_osi=Windows 2009" systemd.mask=mhwd.live.service apparmor=1 security=apparmor resume=UUID=997a0a2e-1817-4b2e-8a35-0da6cbca7efe udev.log_priority=3
[ 3.399] Build Date: 02 September 2020 07:39:17AM
[ 3.399]
[ 3.399] Current version of pixman: 0.40.0
[ 3.399] Before reporting problems, check http://wiki.x.org
[ 3.399] Markers: (--) probed, (**) from config file, (==) default setting,
[ 3.399] (==) Log file: "/var/log/Xorg.0.log", Time: Tue Oct 13 16:24:19 2020
[ 3.400] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 3.400] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 3.401] (==) ServerLayout "layout"
[ 3.401] (==) No screen section available. Using defaults.
[ 3.401] (**) |-->Screen "Default Screen Section" (0)
[ 3.401] (**) | |-->Monitor "<default monitor>"
[ 3.401] (==) No monitor specified for screen "Default Screen Section".
[ 3.401] (==) Automatically adding devices
[ 3.401] (==) Automatically enabling devices
[ 3.401] (==) Automatically adding GPU devices
[ 3.401] (==) Automatically binding GPU devices
[ 3.401] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 3.401] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/misc".
[ 3.401] Entry deleted from font path.
[ 3.401] (Run 'mkfontdir' on "/usr/share/fonts/misc").
[ 3.402] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/TTF".
[ 3.402] Entry deleted from font path.
[ 3.402] (Run 'mkfontdir' on "/usr/share/fonts/TTF").
[ 3.402] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[ 3.402] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[ 3.402] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[ 3.402] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[ 3.402] (==) FontPath set to:
[ 3.402] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 3.402] (II) The server relies on udev to provide the list of input devices.
[ 3.402] (II) Module ABI versions:
[ 3.402] X.Org ANSI C Emulation: 0.4
[ 3.402] X.Org Video Driver: 24.1
[ 3.402] X.Org XInput driver : 24.1
[ 3.402] X.Org Server Extension : 10.0
[ 3.402] (++) using VT number 1
[ 3.404] (II) systemd-logind: took control of session /org/freedesktop/login1/session/_31
[ 3.406] (--) PCI:*(0@0:2:0) 8086:591b:1028:07be rev 4, Mem @ 0xeb000000/16777216, 0x80000000/268435456, I/O @ 0x0000f000/64, BIOS @ 0x????????/131072
[ 3.406] (--) PCI: (1@0:0:0) 10de:1c8d:1028:07be rev 161, Mem @ 0xec000000/16777216, 0xc0000000/268435456, 0xd0000000/33554432, I/O @ 0x0000e000/128, BIOS @ 0x????????/524288
[ 3.406] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[ 3.406] (II) LoadModule: "glx"
[ 3.407] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 3.412] (II) Module glx: vendor="X.Org Foundation"
[ 3.412] compiled for 1.20.9, module version = 1.0.0
[ 3.412] ABI class: X.Org Server Extension, version 10.0
[ 3.412] (==) Matched intel as autoconfigured driver 0
[ 3.412] (==) Matched modesetting as autoconfigured driver 1
[ 3.412] (==) Matched fbdev as autoconfigured driver 2
[ 3.412] (==) Matched vesa as autoconfigured driver 3
[ 3.412] (==) Assigned the driver to the xf86ConfigLayout
[ 3.412] (II) LoadModule: "intel"
[ 3.413] (WW) Warning, couldn't open module intel
[ 3.413] (EE) Failed to load module "intel" (module does not exist, 0)
[ 3.413] (II) LoadModule: "modesetting"
[ 3.413] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[ 3.414] (II) Module modesetting: vendor="X.Org Foundation"
[ 3.414] compiled for 1.20.9, module version = 1.20.9
[ 3.414] Module class: X.Org Video Driver
[ 3.414] ABI class: X.Org Video Driver, version 24.1
[ 3.414] (II) LoadModule: "fbdev"
[ 3.414] (WW) Warning, couldn't open module fbdev
[ 3.414] (EE) Failed to load module "fbdev" (module does not exist, 0)
[ 3.414] (II) LoadModule: "vesa"
[ 3.415] (WW) Warning, couldn't open module vesa
[ 3.415] (EE) Failed to load module "vesa" (module does not exist, 0)
[ 3.415] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 3.415] (EE) open /dev/dri/card0: No such file or directory
[ 3.415] (WW) Falling back to old probe method for modesetting
[ 3.415] (EE) Screen 0 deleted because of no matching config section.
[ 3.415] (II) UnloadModule: "modesetting"
[ 3.415] (EE) Device(s) detected, but none match those in the config file.
[ 3.415] (EE)
Fatal server error:
[ 3.415] (EE) no screens found(EE)
[ 3.415] (EE)
for help.
[ 3.415] (EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
[ 3.415] (EE)
[ 3.415] (EE) Server terminated with error (1). Closing log file.
Nope, plain old Manjaro I also tried to follow a guide specific to dell-xps (only specifying kernel parameters)… I’m seriously thinking of wiping it out and going bare-Arch. Do you have something specific I should pay attention to if I go that way?
I’m on Manjaro because I don’t want to deal with the head-ache of installing Arch from scratch (Manjaro Architect is like Arch from scratch, but with the advantages of not having to compile everything yourself)
Just wait until someone more knowledgeable than me shows up.
I didn’t mess with the configs, I just added some kernel parameters.
I need the nVidia card to be usable, because I will almost always have an external screen plugged in, and as far as I’m aware, that only goes through the nVidia GPU
If you did not did not set anything in a config regarding this the only thing I can think of is that something in the kernel lines bites. Just not sure what I am oke with kernels but not that good.
Guess it will be a trail and error thing.
In tjhe kernel line does this help anything?
random.trust_cpu=on
Still I wonder about your xorg config file.
So what is your /etc/X11/xorg.conf.d/90-mhwd.conf look like?
and there are no more files in xorg.conf.d?
I guess there is also no etc/X11/xorg.conf or is there?
since your disabled mhwd does it help when you enable it?
so perhaps removing
Helps… unless there is a specific reason you set this like boot problems without it?
Also do you want to get your nvidia working or just work in with intel graphics?
Also please remove the nomodeset because intel needs it if you use that driver.
