Hey…can u notice this behaviour with the LTS kernel?
Just install and switch to lts kernel and report back pls
What’s the output to:
loginctl show-session $(loginctl | grep $USER | awk '{print $1}') --property Type
if there is nothing in /etc/X11/xorg.conf.d ?
I tried toggling that flag on and off, and nothing changed (I read on another thread that it might be needed).
There’s another file, but it’s just setting up the keyboard
I need the nVidia GPU, the HDMI output goes directly to it and I plan to only use the laptop with an external screen
It shows Type=tty
That… worked! Thank you!
Thanks a lot @Fabby and @SLaItEr for the feedback and for the time.
I will keep this unresolved, until I play around with the system and be sure it doesn’t crash.
For completeness, here is the state that works:
mhwd --listinstalled
> Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
video-modesetting 2020.01.13 true PCI
video-hybrid-intel-nvidia-440xx-prime 2019.10.25 false PCI
cat /etc/default/grub
GRUB_DEFAULT="saved"
GRUB_TIMEOUT="10"
GRUB_TIMEOUT_STYLE="hidden"
GRUB_DISTRIBUTOR="Manjaro"
GRUB_CMDLINE_LINUX_DEFAULT="acpi_rev_override=1 pcie_aspm=off acpi_blacklight=none acpi_osi=! acpi_osi='Windows 2009' apparmor=1 security=apparmor resume=UUID=997a0a2e-1817-4b2e-8a35-0da6cbca7efe udev.log_priority=3"
GRUB_CMDLINE_LINUX=""
# If you want to enable the save default function, uncomment the following
# line, and set GRUB_DEFAULT to saved.
GRUB_SAVEDEFAULT="true"
#GRUB_ENABLE_CRYPTODISK="y"
GRUB_TERMINAL_INPUT="console"
#GRUB_TERMINAL_OUTPUT="console"
GRUB_GFXMODE="auto"
GRUB_GFXPAYLOAD_LINUX="keep"
#GRUB_DISABLE_LINUX_UUID="true"
GRUB_DISABLE_RECOVERY="true"
# Uncomment and set to the desired menu colors. Used by normal and wallpaper
# modes only. Entries specified as foreground/background.
#GRUB_THEME="/path/to/gfxtheme"
#GRUB_INIT_TUNE="480 440 1"
Great it works now with the LTS kernel.
small question just for my learning experience .
You did rebuild grub after the changes earlier?
Welcome😀
Yes, everytime I did anything I ran sudo update-grub, otherwise the changes weren’t effective.
