GDM hangs with the mouse frozen
I believe I am experiencing the same issue after the 2025-12-08 Anh-Linh Preview update. My system is working if I use a TTY session, but logging in with GDM hangs with the mouse frozen. I took a video of the experience for reference: https://youtu.be/e4_xux17BIM
Things that I’ve tried that didn’t fix the issue:
  • booting an older kernel (6.12)
  • downgrading to the video-nvidia-575xx driver
  • using the free video-linux driver
  • disabling user extensions with gsettings set org.gnome.shell disable-user-extensions true
Here is my inxi -zv8 output
  Kernel: 6.18.0-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1 clocksource: tsc
    avail: hpet,acpi_pm parameters: BOOT_IMAGE=/boot/vmlinuz-6.18-x86_64
    root=UUID=a00987d8-776e-4c90-9249-92a768927523 rw quiet udev.log_priority=3
  Console: pty pts/0 DM: GDM v: 49.2 Distro: Manjaro base: Arch Linux
  Type: Desktop System: Gigabyte product: B550 AORUS ELITE AX V3 v: N/A serial: N/A
  Mobo: Gigabyte model: B550 AORUS ELITE AX V3 v: x.x serial: N/A
    uuid: 03ff0210-04e0-050c-3906-de0700080009 Firmware: UEFI vendor: American Megatrends LLC.
    v: F2c date: 09/02/2024
  Device-1: hidpp_battery_0 model: Logitech MX Vertical Advanced Ergonomic Mouse serial: <filter>
    charge: 50% (should be ignored) rechargeable: yes status: N/A
  System RAM: total: 64 GiB available: 62.71 GiB used: 2.23 GiB (3.6%)
  Array-1: capacity: 128 GiB slots: 4 modules: 2 EC: None max-module-size: 32 GiB note: est.
  Device-1: Channel-A DIMM 0 type: no module installed
  Device-2: Channel-A DIMM 1 type: DDR4 detail: synchronous unbuffered (unregistered)
    size: 32 GiB speed: 2133 MT/s volts: curr: 1.2 min: 1.2 max: 1.2 width (bits): data: 64
    total: 64 manufacturer: Corsair part-no: CMK64GX4M2D3600C18 serial: N/A
  Device-3: Channel-B DIMM 0 type: no module installed
  Device-4: Channel-B DIMM 1 type: DDR4 detail: synchronous unbuffered (unregistered)
  Slot: 12 type: PCIe status: in use info: J10 length: short volts: 3.3 bus-ID: 00:03.1 children:
    1: 06:00.0 class-ID: 0300 type: display 2: 06:00.1 class-ID: 0403 type: audio 3: 06:00.2
    class-ID: 0c03 type: serialbus 4: 06:00.3 class-ID: 0c80 type: serialbus
  Slot: 14 type: PCIe status: available info: J3700, M.2 length: short volts: 3.3
    bus-ID: 00:1f.7
  Slot: 128 type: PCIe status: available info: J3708 length: short volts: 3.3 bus-ID: 00:1f.7
  Info: model: AMD Ryzen 7 5700X3D socket: AM4 bits: 64 type: MT MCP arch: Zen 3+ gen: 3 level: v3
    note: check built: 2022 process: TSMC n6 (7nm) family: 0x19 (25) model-id: 0x21 (33) stepping: 2
    microcode: 0xA201211
  Topology: cpus: 1x dies: 1 clusters: 1 cores: 8 threads: 16 tpc: 2 smt: enabled cache:
    L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB L3: 96 MiB desc: 1x96 MiB
  Speed (MHz): avg: 2994 min/max: N/A base/boost: 3000/3400 volts: 1.1 V ext-clock: 100 MHz
    cores: 1: 2994 2: 2994 3: 2994 4: 2994 5: 2994 6: 2994 7: 2994 8: 2994 9: 2994 10: 2994 11: 2994
    12: 2994 13: 2994 14: 2994 15: 2994 16: 2994 bogomips: 95819
  Flags: 3dnowprefetch abm adx aes aperfmperf apic arat avic avx avx2 bmi1 bmi2 bpext cat_l3
    cdp_l3 clflush clflushopt clwb clzero cmov cmp_legacy constant_tsc cpb cpuid cqm cqm_llc
    cqm_mbm_local cqm_mbm_total cqm_occup_llc cr8_legacy cx16 cx8 de debug_swap decodeassists
    erms extapic extd_apicid f16c flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht hw_pstate
    ibpb ibrs ibs invpcid irperf lahf_lm lbrv lm mba mca mce misalignsse mmx mmxext monitor movbe
    msr mtrr mwaitx nonstop_tsc nopl npt nrip_save nx ospke osvw overflow_recov pae pat
    pausefilter pclmulqdq pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pku pni
    popcnt pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni skinit smap
    smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor svm_lock syscall tce topoext
    tsc tsc_scale umip user_shstk v_spec_ctrl v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall
    vpclmulqdq wbnoinvd wdt x2apic xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves xtopology
  Type: spec_store_bypass mitigation: Speculative Store Bypass disabled via prctl
  Type: spectre_v2 mitigation: Retpolines; IBPB: conditional; IBRS_FW; STIBP: always-on; RSB
    filling; PBRSB-eIBRS: Not affected; BHI: Not affected
  Device-1: NVIDIA TU106 [GeForce RTX 2070] vendor: Micro-Star MSI driver: nvidia v: 580.105.08
    alternate: nouveau,nova_core,nvidia_drm non-free: 550-580.xx+ status: current (as of 2025-11;
    EOL~2026-12-xx) arch: Turing code: TUxxx process: TSMC 12nm FF built: 2018-2022 pcie: gen: 1
    speed: 2.5 GT/s lanes: 16 link-max: gen: 3 speed: 8 GT/s ports: active: DP-3 empty: DP-1,
    DP-2, HDMI-A-1, Unknown-2 bus-ID: 06:00.0 chip-ID: 10de:1f02 class-ID: 0300
  Device-2: Logitech C920 HD Pro Webcam driver: snd-usb-audio,uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 5-3:4 chip-ID: 046d:0892 class-ID: 0102
    serial: <filter>
  Display: unspecified server: X.org v: 1.21.1.21 with: Xwayland v: 24.1.9
    compositor: gnome-shell driver: X: loaded: nvidia gpu: nv_platform,nvidia,nvidia-nvswitch
    tty: 192x60
  Monitor-1: DP-3 model: LG (GoldStar) 27GK750F serial: <filter> built: 2019 res: 1920x1080
    dpi: 81 gamma: 1.2 chroma: red: x: 0.651 y: 0.333 green: x: 0.325 y: 0.624 blue: x: 0.157
    y: 0.055 white: x: 0.314 y: 0.329 size: 531x298mm (20.91x11.73") diag: 685mm (27") ratio: 16:9
    modes: 1920x1080, 1280x1024, 1280x960, 1280x720, 1024x768, 800x600, 720x576, 720x480, 640x480
  API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia device: 2 drv: swrast gbm:
    drv: nvidia surfaceless: drv: nvidia inactive: wayland,x11,device-1
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: mesa v: 25.3.1-arch1.2 note: console (EGL sourced)
    renderer: NVIDIA GeForce RTX 2070/PCIe/SSE2, llvmpipe (LLVM 21.1.6 256 bits)
  API: Vulkan v: 1.4.328 layers: 2 device: 0 type: discrete-gpu name: NVIDIA GeForce RTX 2070
    driver: nvidia v: 580.105.08 device-ID: 10de:1f02 surfaces: N/A
  Info: Tools: api: eglinfo, glxinfo, vulkaninfo gpu: nvidia-settings,nvidia-smi
    x11: xdpyinfo, xprop, xrandr
  Device-1: NVIDIA TU106 High Definition Audio vendor: Micro-Star MSI driver: snd_hda_intel
    v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 06:00.1 chip-ID: 10de:10f9 class-ID: 0403
  Device-2: Advanced Micro Devices [AMD] Starship/Matisse HD Audio vendor: Gigabyte
    driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 08:00.4
    chip-ID: 1022:1487 class-ID: 0403
  Device-3: Logitech C920 HD Pro Webcam driver: snd-usb-audio,uvcvideo type: USB rev: 2.0
    serial: <filter>
  Device-4: Generalplus USB Audio Device driver: hid-generic,snd-usb-audio,usbhid type: USB
    rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 5-4.1:6 chip-ID: 1b3f:2008 class-ID: 0300
  API: ALSA v: k6.18.0-1-MANJARO status: kernel-api with: aoss type: oss-emulator
  Server-1: PipeWire v: 1.4.9 status: n/a (root, process) with: 1: pipewire-pulse status: active
    2: pipewire-media-session status: active 3: pipewire-alsa type: plugin 4: pw-jack type: plugin
    tools: pactl,pw-cat,pw-cli
  Device-1: Realtek RTL8125 2.5GbE vendor: Gigabyte driver: r8169 v: kernel pcie: gen: 2
    speed: 5 GT/s lanes: 1 port: e000 bus-ID: 04:00.0 chip-ID: 10ec:8125 class-ID: 0200
  IP v4: <filter> type: dynamic noprefixroute scope: global broadcast: <filter>
  Device-2: Realtek RTL8851BE PCIe 802.11ax Wireless Network driver: rtw89_8851be v: kernel
    pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 05:00.0 chip-ID: 10ec:b851
    class-ID: 0280
  IF: wlp5s0 state: down mac: <filter>
  IF-ID-1: tailscale0 state: unknown speed: -1 duplex: full mac: N/A
  IP v6: <filter> virtual: stable-privacy proto kernel_ll scope: link
  Device-1: Realtek Bluetooth Radio driver: btusb v: 0.8 type: USB rev: 1.0 speed: 12 Mb/s
    lanes: 1 mode: 1.1 bus-ID: 1-5:2 chip-ID: 0bda:b850 class-ID: e001 serial: <filter>
  Report: btmgmt ID: hci0 rfk-id: 0 state: up address: <filter> bt-v: 5.3 lmp-v: 12 status:
    discoverable: no pairing: no class-ID: 104
  Local Storage: total: 6.17 TiB used: 2.73 TiB (44.3%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: WD BLACK SN850X 4000GB
    size: 3.64 TiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s lanes: 4 tech: SSD
    serial: <filter> fw-rev: 624361WD temp: 39.9 C
  ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 500GB size: 465.76 GiB
    block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s tech: SSD serial: <filter>
    fw-rev: 1B6Q scheme: GPT
  ID-3: /dev/sdb maj-min: 8:16 vendor: Western Digital model: WD6401AALS-00L3B2 size: 596.17 GiB
    block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s tech: N/A serial: <filter>
    fw-rev: 3B01 temp: 45 C scheme: MBR
  ID-4: /dev/sdc maj-min: 8:32 vendor: Western Digital model: WD6401AALS-00L3B2 size: 596.17 GiB
    fw-rev: 3B01 temp: 43 C scheme: MBR
  ID-5: /dev/sdd maj-min: 8:48 vendor: Crucial model: CT1000MX500SSD4 size: 931.51 GiB
    block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s tech: SSD serial: <filter>
    fw-rev: 023 temp: 42 C scheme: GPT
  ID-1: / raw-size: 930.51 GiB size: 914.84 GiB (98.32%) used: 838.2 GiB (91.6%) fs: ext4
    block-size: 4096 B dev: /dev/sdd2 maj-min: 8:50 label: N/A
    uuid: a00987d8-776e-4c90-9249-92a768927523
  ID-2: /boot/efi raw-size: 1024 MiB size: 1022 MiB (99.80%) used: 280 KiB (0.0%) fs: vfat
    block-size: 512 B dev: /dev/sdd1 maj-min: 8:49 label: N/A uuid: EFF7-15BD
  ID-3: /bulk raw-size: 3.64 TiB size: 3.58 TiB (98.40%) used: 1.44 TiB (40.2%) fs: ext4
    block-size: 4096 B dev: /dev/nvme0n1 maj-min: 259:0 label: The Matrix
    uuid: 3bb2783d-253e-4b79-90b2-3679a77f5c18
  ID-4: /media0 raw-size: 449.76 GiB size: 441.63 GiB (98.19%) used: 11.51 GiB (2.6%) fs: ext4
    block-size: 4096 B dev: /dev/sda1 maj-min: 8:1 label: N/A
    uuid: 48ca8e34-8561-4e89-89e1-86cad44d43b3
  ID-5: /media1 raw-size: 596.17 GiB size: 585.74 GiB (98.25%) used: 86.19 GiB (14.7%) fs: ext4
    block-size: 4096 B dev: /dev/sdc1 maj-min: 8:33 label: media0
    uuid: a6e3f400-3c5f-4229-a6ea-5d99b04fab19
  ID-6: /media2 raw-size: 596.17 GiB size: 585.74 GiB (98.25%) used: 390.49 GiB (66.7%) fs: ext4
    block-size: 4096 B dev: /dev/sdb1 maj-min: 8:17 label: media1
    uuid: 4b2d2e05-9732-4f3f-931c-65cc32fa033b
  Kernel: swappiness: 10 (default 60) cache-pressure: 50 (default 100) zswap: yes compressor: zstd
    max-pool: 20%
  ID-1: swap-1 type: partition size: 16 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/sda2
    maj-min: 8:2 label: N/A uuid: 6b8f5169-2ef2-4996-a06c-b0a8f7c70146
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 10 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
    lanes: 1 mode: 2.0 chip-ID: 1d6b:0002 class-ID: 0900
  Device-1: 1-5:2 info: Realtek Bluetooth Radio type: bluetooth driver: btusb interfaces: 2
    rev: 1.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 500mA chip-ID: 0bda:b850
  Hub-2: 1-6:3 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
    mode: 2.0 power: 100mA chip-ID: 05e3:0608 class-ID: 0900
  Device-1: 1-7:4 info: Integrated Express RGB LED Controller type: HID
    driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
    power: 100mA chip-ID: 048d:5702 class-ID: 0300
  Device-2: 1-8:5 info: Logitech Unifying Receiver type: keyboard,mouse,HID
    driver: logitech-djreceiver,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
    mode: 1.1 power: 98mA chip-ID: 046d:c52b class-ID: 0300
  Hub-3: 2-0:1 info: super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s (1.16 GiB/s) lanes: 1
    mode: 3.2 gen-2x1 chip-ID: 1d6b:0003 class-ID: 0900
  Hub-4: 3-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
  Hub-5: 4-0:1 info: super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s (1.16 GiB/s) lanes: 1
  Hub-6: 5-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
  Device-1: 5-1:2 info: Lenovo Essential Wired Combo type: keyboard,HID
    driver: hid-generic,usbhid interfaces: 2 rev: 2.0 speed: 1.5 Mb/s (183 KiB/s) lanes: 1 mode: 1.0
    power: 100mA chip-ID: 17ef:60a1 class-ID: 0300
  Device-2: 5-2:3 info: Valve Wireless Steam Controller type: keyboard,HID
    driver: hid-steam,usbhid interfaces: 5 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
    power: 100mA chip-ID: 28de:1142 class-ID: 0300
  Device-3: 5-3:4 info: Logitech C920 HD Pro Webcam type: video,audio
    driver: snd-usb-audio,uvcvideo interfaces: 4 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
    mode: 2.0 power: 500mA chip-ID: 046d:0892 class-ID: 0102 serial: <filter>
  Hub-7: 5-4:5 info: Genesys Logic Hub ports: 4 rev: 2.1 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
    mode: 2.0 power: 100mA chip-ID: 05e3:0610 class-ID: 0900
  Device-1: 5-4.1:6 info: Generalplus USB Audio Device type: audio,HID
    driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s)
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 1b3f:2008 class-ID: 0300
  Hub-8: 6-0:1 info: super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s (1.16 GiB/s) lanes: 1
  Hub-9: 6-4:2 info: Genesys Logic Hub ports: 4 rev: 3.1 speed: 5 Gb/s (596.0 MiB/s) lanes: 1
    mode: 3.2 gen-1x1 chip-ID: 05e3:0626 class-ID: 0900
  System Temperatures: cpu: 42.0 C mobo: 33.0 C gpu: nvidia temp: 32 C
  Fan Speeds (rpm): N/A
  Packages: 2475 pm: pacman pkgs: 2379 libs: 514 tools: gnome-software,pamac,yay pm: flatpak
    pkgs: 96
    1: https://mirror.xenyth.net/manjaro/stable/$repo/$arch
    2: https://muug.ca/mirror/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 317
  1: cpu: 0.5% command: tailscaled pid: 784 mem: 104.6 MiB (0.1%)
  2: cpu: 0.4% command: syncthing pid: 4917 mem: 82.7 MiB (0.1%)
  3: cpu: 0.4% command: sudo pid: 5251 mem: 11.3 MiB (0.0%)
  4: cpu: 0.1% command: jellyfin pid: 674 mem: 352.3 MiB (0.5%)
  5: cpu: 0.0% command: init pid: 1 mem: 13.9 MiB (0.0%)
  Memory top: 5 of 317
  1: mem: 352.3 MiB (0.5%) command: jellyfin pid: 674 cpu: 0.1%
  2: mem: 245.8 MiB (0.3%) command: main.py started-by: python pid: 5034 cpu: 0.0%
  3: mem: 233.0 MiB (0.3%) command: gnome-shell pid: 1194 cpu: 0.0%
  4: mem: 104.6 MiB (0.1%) command: tailscaled pid: 784 cpu: 0.5%
  5: mem: 95.2 MiB (0.1%) command: Xwayland pid: 2871 cpu: 0.0%
  Processes: 317 Power: uptime: 1h 6m states: freeze,mem,disk suspend: deep avail: s2idle
    wakeups: 0 hibernate: platform avail: shutdown, reboot, suspend, test_resume image: 25.03 GiB
    services: gsd-power, power-profiles-daemon, upowerd Init: systemd v: 258 default: graphical
    tool: systemctl
  Compilers: clang: 21.1.6 gcc: 15.2.1 Shell: Sudo (sudo) v: 1.9.17p2 default: Bash v: 5.3.8
    running-in: pty pts/0 inxi: 3.3.40
Edit: updated output run as root
Your video shows exactly the behavior on my computer!
In search of more information I ran a minimal interaction and collected some journalctl messages that I hoped would be relevant. By that I mean I booted the computer, logged in to replicate the issue, and then immediately restarted the computer with ctrl+alt+del. Afterwards I logged into TTY and retrieved the output below.
journalctl -o short-precise -p err -b -1 --no-pager
Dec 10 16:03:16.803809 omicron kernel:
Dec 10 16:03:16.976924 omicron (udev-worker)[482]: sdc: /etc/udev/rules.d/60-ioscheduler.rules:6 ATTR{queue/scheduler}="bfq-sq": Failed to write "bfq-sq" to sysfs attribute "queue/scheduler", ignoring: Invalid argument
Dec 10 16:03:16.979927 omicron (udev-worker)[448]: sdb: /etc/udev/rules.d/60-ioscheduler.rules:6 ATTR{queue/scheduler}="bfq-sq": Failed to write "bfq-sq" to sysfs attribute "queue/scheduler", ignoring: Invalid argument
Dec 10 16:03:17.824892 omicron kernel: gspca_vc032x: reg_r err -32
Dec 10 16:03:17.824904 omicron kernel: vc032x 5-3:1.0: probe with driver vc032x failed with error -32
Dec 10 16:03:19.801345 omicron systemd[1]: Failed to start Service to inject keycodes without the GUI application.
Dec 10 16:03:20.771041 omicron dbus-broker-launch[972]: Ignoring duplicate name 'org.gnome.Builder' in service file '/usr/share//dbus-1/services/org.gnome.Builder.service'
Dec 10 16:03:27.493260 omicron gdm-password][4610]: gkr-pam: unable to locate daemon control file
Dec 10 16:03:27.739996 omicron dbus-broker-launch[5057]: Ignoring duplicate name 'org.gnome.Builder' in service file '/usr/share//dbus-1/services/org.gnome.Builder.service'
Dec 10 16:03:39.100434 omicron systemd-coredump[5786]: Failed to send coredump datagram: Broken pipe
Dec 10 16:03:40.972663 omicron dbus-broker-launch[669]: Activation request for 'org.freedesktop.nm_dispatcher' failed.
Dec 10 16:03:41.267893 omicron kernel: watchdog: watchdog0: watchdog did not stop!
journalctl -o short-precise -k -b -1 --no-pager
Dec 10 16:03:16.619341 omicron kernel: Linux version 6.18.0-1-MANJARO (linux618@manjaro) (gcc (GCC) 15.2.1 20251112, GNU ld (GNU Binutils) 2.45.1) #1 SMP PREEMPT_DYNAMIC Tue, 02 Dec 2025 04:30:24 +0000
Dec 10 16:03:16.619384 omicron kernel: Command line: BOOT_IMAGE=/boot/vmlinuz-6.18-x86_64 root=UUID=a00987d8-776e-4c90-9249-92a768927523 rw quiet udev.log_priority=3
Dec 10 16:03:16.619401 omicron kernel: BIOS-provided physical RAM map:
Dec 10 16:03:16.619411 omicron kernel: BIOS-e820: [mem 0x0000000000000000-0x000000000009ffff] usable
Dec 10 16:03:16.619419 omicron kernel: BIOS-e820: [mem 0x00000000000a0000-0x00000000000fffff] reserved
Dec 10 16:03:16.619428 omicron kernel: BIOS-e820: [mem 0x0000000000100000-0x0000000009c3efff] usable
Dec 10 16:03:16.619437 omicron kernel: BIOS-e820: [mem 0x0000000009c3f000-0x0000000009ffffff] reserved
Dec 10 16:03:16.619446 omicron kernel: BIOS-e820: [mem 0x000000000a000000-0x000000000a1fffff] usable
Dec 10 16:03:16.619454 omicron kernel: BIOS-e820: [mem 0x000000000a200000-0x000000000a20dfff] ACPI NVS
Dec 10 16:03:16.619462 omicron kernel: BIOS-e820: [mem 0x000000000a20e000-0x000000000affffff] usable
Dec 10 16:03:16.619471 omicron kernel: BIOS-e820: [mem 0x000000000b000000-0x000000000b01ffff] reserved
Dec 10 16:03:16.619480 omicron kernel: BIOS-e820: [mem 0x000000000b020000-0x00000000bad31fff] usable
Dec 10 16:03:16.619488 omicron kernel: BIOS-e820: [mem 0x00000000bad32000-0x00000000bc49efff] reserved
Dec 10 16:03:16.619496 omicron kernel: BIOS-e820: [mem 0x00000000bc49f000-0x00000000bc5fefff] ACPI data
Dec 10 16:03:16.619508 omicron kernel: BIOS-e820: [mem 0x00000000bc5ff000-0x00000000bcce5fff] ACPI NVS
Dec 10 16:03:16.619516 omicron kernel: BIOS-e820: [mem 0x00000000bcce6000-0x00000000bdb72fff] reserved
Dec 10 16:03:16.619524 omicron kernel: BIOS-e820: [mem 0x00000000bdb73000-0x00000000bdbfefff] type 20
Dec 10 16:03:16.619533 omicron kernel: BIOS-e820: [mem 0x00000000bdbff000-0x00000000beffffff] usable
Dec 10 16:03:16.619541 omicron kernel: BIOS-e820: [mem 0x00000000bf000000-0x00000000bfffffff] reserved
Dec 10 16:03:16.619549 omicron kernel: BIOS-e820: [mem 0x00000000f0000000-0x00000000f7ffffff] reserved
Dec 10 16:03:16.619558 omicron kernel: BIOS-e820: [mem 0x00000000fd200000-0x00000000fd2fffff] reserved
Dec 10 16:03:16.619566 omicron kernel: BIOS-e820: [mem 0x00000000fd600000-0x00000000fd7fffff] reserved
Dec 10 16:03:16.619574 omicron kernel: BIOS-e820: [mem 0x00000000fea00000-0x00000000fea0ffff] reserved
Dec 10 16:03:16.619581 omicron kernel: BIOS-e820: [mem 0x00000000feb80000-0x00000000fec01fff] reserved
Dec 10 16:03:16.619589 omicron kernel: BIOS-e820: [mem 0x00000000fec10000-0x00000000fec10fff] reserved
Dec 10 16:03:16.619597 omicron kernel: BIOS-e820: [mem 0x00000000fec30000-0x00000000fec30fff] reserved
Dec 10 16:03:16.619605 omicron kernel: BIOS-e820: [mem 0x00000000fed00000-0x00000000fed00fff] reserved
Dec 10 16:03:16.619615 omicron kernel: BIOS-e820: [mem 0x00000000fed40000-0x00000000fed44fff] reserved
Dec 10 16:03:16.619621 omicron kernel: BIOS-e820: [mem 0x00000000fed80000-0x00000000fed8ffff] reserved
Dec 10 16:03:16.619629 omicron kernel: BIOS-e820: [mem 0x00000000fedc2000-0x00000000fedcffff] reserved
Dec 10 16:03:16.619637 omicron kernel: BIOS-e820: [mem 0x00000000fedd4000-0x00000000fedd5fff] reserved
Dec 10 16:03:16.619646 omicron kernel: BIOS-e820: [mem 0x00000000ff000000-0x00000000ffffffff] reserved
Dec 10 16:03:16.619654 omicron kernel: BIOS-e820: [mem 0x0000000100000000-0x000000103f37ffff] usable
Dec 10 16:03:16.619662 omicron kernel: BIOS-e820: [mem 0x000000103f380000-0x000000103fffffff] reserved
Dec 10 16:03:16.619671 omicron kernel: NX (Execute Disable) protection: active
Dec 10 16:03:16.619677 omicron kernel: APIC: Static calls initialized
Dec 10 16:03:16.619685 omicron kernel: efi: EFI v2.7 by American Megatrends
Dec 10 16:03:16.619693 omicron kernel: efi: ACPI=0xbcccf000 ACPI 2.0=0xbcccf014 TPMFinalLog=0xbcc99000 SMBIOS=0xbd9ef000 SMBIOS 3.0=0xbd9ee000 MEMATTR=0xb6505698 ESRT=0xb8eb9498
Dec 10 16:03:16.619702 omicron kernel: efi: Remove mem317: MMIO range=[0xf0000000-0xf7ffffff] (128MB) from e820 map
Dec 10 16:03:16.619710 omicron kernel: e820: remove [mem 0xf0000000-0xf7ffffff] reserved
Dec 10 16:03:16.619723 omicron kernel: efi: Remove mem318: MMIO range=[0xfd200000-0xfd2fffff] (1MB) from e820 map
Dec 10 16:03:16.619731 omicron kernel: e820: remove [mem 0xfd200000-0xfd2fffff] reserved
Dec 10 16:03:16.619739 omicron kernel: efi: Remove mem319: MMIO range=[0xfd600000-0xfd7fffff] (2MB) from e820 map
Dec 10 16:03:16.619748 omicron kernel: e820: remove [mem 0xfd600000-0xfd7fffff] reserved
Dec 10 16:03:16.619757 omicron kernel: efi: Not removing mem320: MMIO range=[0xfea00000-0xfea0ffff] (64KB) from e820 map
Dec 10 16:03:16.619765 omicron kernel: efi: Remove mem321: MMIO range=[0xfeb80000-0xfec01fff] (0MB) from e820 map
Dec 10 16:03:16.619774 omicron kernel: e820: remove [mem 0xfeb80000-0xfec01fff] reserved
Dec 10 16:03:16.619780 omicron kernel: efi: Not removing mem322: MMIO range=[0xfec10000-0xfec10fff] (4KB) from e820 map
Dec 10 16:03:16.619789 omicron kernel: efi: Not removing mem323: MMIO range=[0xfec30000-0xfec30fff] (4KB) from e820 map
Dec 10 16:03:16.619798 omicron kernel: efi: Not removing mem324: MMIO range=[0xfed00000-0xfed00fff] (4KB) from e820 map
Dec 10 16:03:16.619806 omicron kernel: efi: Not removing mem325: MMIO range=[0xfed40000-0xfed44fff] (20KB) from e820 map
Dec 10 16:03:16.619813 omicron kernel: efi: Not removing mem326: MMIO range=[0xfed80000-0xfed8ffff] (64KB) from e820 map
Dec 10 16:03:16.619821 omicron kernel: efi: Not removing mem327: MMIO range=[0xfedc2000-0xfedcffff] (56KB) from e820 map
Dec 10 16:03:16.619830 omicron kernel: efi: Not removing mem328: MMIO range=[0xfedd4000-0xfedd5fff] (8KB) from e820 map
Dec 10 16:03:16.619838 omicron kernel: efi: Remove mem329: MMIO range=[0xff000000-0xffffffff] (16MB) from e820 map
Dec 10 16:03:16.619844 omicron kernel: e820: remove [mem 0xff000000-0xffffffff] reserved
Dec 10 16:03:16.619852 omicron kernel: SMBIOS 3.3.0 present.
Dec 10 16:03:16.619861 omicron kernel: DMI: Gigabyte Technology Co., Ltd. B550 AORUS ELITE AX V3/B550 AORUS ELITE AX V3, BIOS F2c 09/02/2024
Dec 10 16:03:16.619868 omicron kernel: DMI: Memory slots populated: 2/4
Dec 10 16:03:16.619877 omicron kernel: tsc: Fast TSC calibration using PIT
Dec 10 16:03:16.619885 omicron kernel: tsc: Detected 2994.394 MHz processor
Dec 10 16:03:16.619897 omicron kernel: e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
Dec 10 16:03:16.619910 omicron kernel: e820: remove [mem 0x000a0000-0x000fffff] usable
Dec 10 16:03:16.619918 omicron kernel: last_pfn = 0x103f380 max_arch_pfn = 0x400000000
Dec 10 16:03:16.619931 omicron kernel: total RAM covered: 3071M
Dec 10 16:03:16.619943 omicron kernel: Found optimal setting for mtrr clean up
Dec 10 16:03:16.619956 omicron kernel:  gran_size: 64K         chunk_size: 64M         num_reg: 3          lose cover RAM: 0G
Dec 10 16:03:16.619967 omicron kernel: MTRR map: 7 entries (3 fixed + 4 variable; max 20), built from 9 variable MTRRs
Dec 10 16:03:16.619979 omicron kernel: x86/PAT: Configuration [0-7]: WB  WC  UC- UC  WB  WP  UC- WT
Dec 10 16:03:16.619991 omicron kernel: e820: update [mem 0xbc770000-0xbc77ffff] usable ==> reserved
Dec 10 16:03:16.620004 omicron kernel: e820: update [mem 0xc0000000-0xffffffff] usable ==> reserved
Dec 10 16:03:16.620014 omicron kernel: last_pfn = 0xbf000 max_arch_pfn = 0x400000000
Dec 10 16:03:16.620026 omicron kernel: esrt: Reserving ESRT space from 0x00000000b8eb9498 to 0x00000000b8eb94d0.
Dec 10 16:03:16.620038 omicron kernel: e820: update [mem 0xb8eb9000-0xb8eb9fff] usable ==> reserved
Dec 10 16:03:16.620051 omicron kernel: Using GB pages for direct mapping
Dec 10 16:03:16.620061 omicron kernel: Secure boot could not be determined
Dec 10 16:03:16.620071 omicron kernel: RAMDISK: [mem 0x280a5000-0x30049fff]
Dec 10 16:03:16.620083 omicron kernel: ACPI: Early table checksum verification disabled
Dec 10 16:03:16.620096 omicron kernel: ACPI: RSDP 0x00000000BCCCF014 000024 (v02 ALASKA)
Dec 10 16:03:16.620108 omicron kernel: ACPI: XSDT 0x00000000BCCCE728 0000D4 (v01 ALASKA A M I    01072009 AMI  01000013)
Dec 10 16:03:16.620119 omicron kernel: ACPI: FACP 0x00000000BC5E4000 000114 (v06 ALASKA A M I    01072009 AMI  00010013)
Dec 10 16:03:16.620131 omicron kernel: ACPI: DSDT 0x00000000BC4E7000 00683B (v02 ALASKA A M I    01072009 INTL 20190509)
Dec 10 16:03:16.620143 omicron kernel: ACPI: FACS 0x00000000BCCC9000 000040
Dec 10 16:03:16.620155 omicron kernel: ACPI: SSDT 0x00000000BC5F3000 00B7BF (v02 GBT    GSWApp   00000001 INTL 20190509)
Dec 10 16:03:16.620167 omicron kernel: ACPI: SSDT 0x00000000BC5EA000 008CE9 (v02 AMD    AmdTable 00000002 MSFT 04000000)
Dec 10 16:03:16.620179 omicron kernel: ACPI: SSDT 0x00000000BC5E6000 003D7C (v02 AMD    AMD AOD  00000001 INTL 20190509)
Dec 10 16:03:16.620191 omicron kernel: ACPI: SSDT 0x00000000BC5E5000 000221 (v02 ALASKA CPUSSDT  01072009 AMI  01072009)
Dec 10 16:03:16.620204 omicron kernel: ACPI: FIDT 0x00000000BC5DD000 00009C (v01 ALASKA A M I    01072009 AMI  00010013)
Dec 10 16:03:16.620217 omicron kernel: ACPI: MCFG 0x00000000BC5DC000 00003C (v01 ALASKA A M I    01072009 MSFT 00010013)
Dec 10 16:03:16.620230 omicron kernel: ACPI: HPET 0x00000000BC5DB000 000038 (v01 ALASKA A M I    01072009 AMI  00000005)
Dec 10 16:03:16.620240 omicron kernel: ACPI: IVRS 0x00000000BC5DA000 0000D0 (v02 AMD    AmdTable 00000001 AMD  00000001)
Dec 10 16:03:16.620250 omicron kernel: ACPI: FPDT 0x00000000BC5D9000 000044 (v01 ALASKA A M I    01072009 AMI  01000013)
Dec 10 16:03:16.620263 omicron kernel: ACPI: BGRT 0x00000000BC5D8000 000038 (v01 ALASKA A M I    01072009 AMI  00010013)
Dec 10 16:03:16.620273 omicron kernel: ACPI: TPM2 0x00000000BC5D7000 00004C (v04 ALASKA A M I    00000001 AMI  00000000)
Dec 10 16:03:16.620286 omicron kernel: ACPI: PCCT 0x00000000BC5D6000 00006E (v02 AMD    AmdTable 00000001 AMD  00000001)
Dec 10 16:03:16.620299 omicron kernel: ACPI: CRAT 0x00000000BC5D5000 000F10 (v01 AMD    AmdTable 00000001 AMD  00000001)
Dec 10 16:03:16.620310 omicron kernel: ACPI: CDIT 0x00000000BC5D4000 000029 (v01 AMD    AmdTable 00000001 AMD  00000001)
Dec 10 16:03:16.620318 omicron kernel: ACPI: WPBT 0x00000000BC4F5000 000038 (v01 ALASKA A M I    00000001 GBT  20181220)
Dec 10 16:03:16.620327 omicron kernel: ACPI: SSDT 0x00000000BC4F4000 000625 (v02 AMD    ArticDGP 00000001 INTL 20190509)
Dec 10 16:03:16.620339 omicron kernel: ACPI: SSDT 0x00000000BC4F0000 003A23 (v02 AMD    ArticN   00000001 INTL 20190509)
Dec 10 16:03:16.620351 omicron kernel: ACPI: WSMT 0x00000000BC4EF000 000028 (v01 ALASKA A M I    01072009 AMI  00010013)
Dec 10 16:03:16.620363 omicron kernel: ACPI: APIC 0x00000000BC4EE000 00015E (v04 ALASKA A M I    01072009 AMI  00010013)
Dec 10 16:03:16.620373 omicron kernel: ACPI: SSDT 0x00000000BC5E2000 00147F (v02 AMD    ArticC   00000001 INTL 20190509)
Dec 10 16:03:16.620384 omicron kernel: ACPI: SSDT 0x00000000BC5E1000 0000BF (v01 AMD    AmdTable 00001000 INTL 20190509)
Dec 10 16:03:16.620394 omicron kernel: ACPI: Reserving FACP table memory at [mem 0xbc5e4000-0xbc5e4113]
Dec 10 16:03:16.620407 omicron kernel: ACPI: Reserving DSDT table memory at [mem 0xbc4e7000-0xbc4ed83a]
Dec 10 16:03:16.620413 omicron kernel: ACPI: Reserving FACS table memory at [mem 0xbccc9000-0xbccc903f]
Dec 10 16:03:16.620425 omicron kernel: ACPI: Reserving SSDT table memory at [mem 0xbc5f3000-0xbc5fe7be]
Dec 10 16:03:16.620434 omicron kernel: ACPI: Reserving SSDT table memory at [mem 0xbc5ea000-0xbc5f2ce8]
Dec 10 16:03:16.620446 omicron kernel: ACPI: Reserving SSDT table memory at [mem 0xbc5e6000-0xbc5e9d7b]
Dec 10 16:03:16.620456 omicron kernel: ACPI: Reserving SSDT table memory at [mem 0xbc5e5000-0xbc5e5220]
Dec 10 16:03:16.620462 omicron kernel: ACPI: Reserving FIDT table memory at [mem 0xbc5dd000-0xbc5dd09b]
Dec 10 16:03:16.620473 omicron kernel: ACPI: Reserving MCFG table memory at [mem 0xbc5dc000-0xbc5dc03b]
Dec 10 16:03:16.620481 omicron kernel: ACPI: Reserving HPET table memory at [mem 0xbc5db000-0xbc5db037]
Dec 10 16:03:16.620495 omicron kernel: ACPI: Reserving IVRS table memory at [mem 0xbc5da000-0xbc5da0cf]
Dec 10 16:03:16.620503 omicron kernel: ACPI: Reserving FPDT table memory at [mem 0xbc5d9000-0xbc5d9043]
Dec 10 16:03:16.620510 omicron kernel: ACPI: Reserving BGRT table memory at [mem 0xbc5d8000-0xbc5d8037]
Dec 10 16:03:16.620522 omicron kernel: ACPI: Reserving TPM2 table memory at [mem 0xbc5d7000-0xbc5d704b]
Dec 10 16:03:16.620534 omicron kernel: ACPI: Reserving PCCT table memory at [mem 0xbc5d6000-0xbc5d606d]
Dec 10 16:03:16.620545 omicron kernel: ACPI: Reserving CRAT table memory at [mem 0xbc5d5000-0xbc5d5f0f]
Dec 10 16:03:16.620553 omicron kernel: ACPI: Reserving CDIT table memory at [mem 0xbc5d4000-0xbc5d4028]
Dec 10 16:03:16.620561 omicron kernel: ACPI: Reserving WPBT table memory at [mem 0xbc4f5000-0xbc4f5037]
Dec 10 16:03:16.620573 omicron kernel: ACPI: Reserving SSDT table memory at [mem 0xbc4f4000-0xbc4f4624]
Dec 10 16:03:16.620582 omicron kernel: ACPI: Reserving SSDT table memory at [mem 0xbc4f0000-0xbc4f3a22]
Dec 10 16:03:16.620589 omicron kernel: ACPI: Reserving WSMT table memory at [mem 0xbc4ef000-0xbc4ef027]
Dec 10 16:03:16.620595 omicron kernel: ACPI: Reserving APIC table memory at [mem 0xbc4ee000-0xbc4ee15d]
Dec 10 16:03:16.620605 omicron kernel: ACPI: Reserving SSDT table memory at [mem 0xbc5e2000-0xbc5e347e]
Dec 10 16:03:16.620614 omicron kernel: ACPI: Reserving SSDT table memory at [mem 0xbc5e1000-0xbc5e10be]
Dec 10 16:03:16.620621 omicron kernel: No NUMA configuration found
Dec 10 16:03:16.620628 omicron kernel: Faking a node at [mem 0x0000000000000000-0x000000103f37ffff]
Dec 10 16:03:16.620636 omicron kernel: NODE_DATA(0) allocated [mem 0x103f355280-0x103f37ffff]
Dec 10 16:03:16.620647 omicron kernel: Zone ranges:
Dec 10 16:03:16.620659 omicron kernel:   DMA      [mem 0x0000000000001000-0x0000000000ffffff]
Dec 10 16:03:16.620669 omicron kernel:   DMA32    [mem 0x0000000001000000-0x00000000ffffffff]
Dec 10 16:03:16.620680 omicron kernel:   Normal   [mem 0x0000000100000000-0x000000103f37ffff]
Dec 10 16:03:16.620689 omicron kernel:   Device   empty
Dec 10 16:03:16.620699 omicron kernel: Movable zone start for each node
Dec 10 16:03:16.620707 omicron kernel: Early memory node ranges
Dec 10 16:03:16.620719 omicron kernel:   node   0: [mem 0x0000000000001000-0x000000000009ffff]
Dec 10 16:03:16.620728 omicron kernel:   node   0: [mem 0x0000000000100000-0x0000000009c3efff]
Dec 10 16:03:16.620735 omicron kernel:   node   0: [mem 0x000000000a000000-0x000000000a1fffff]
Dec 10 16:03:16.620743 omicron kernel:   node   0: [mem 0x000000000a20e000-0x000000000affffff]
Dec 10 16:03:16.620752 omicron kernel:   node   0: [mem 0x000000000b020000-0x00000000bad31fff]
Dec 10 16:03:16.620758 omicron kernel:   node   0: [mem 0x00000000bdbff000-0x00000000beffffff]
Dec 10 16:03:16.620770 omicron kernel:   node   0: [mem 0x0000000100000000-0x000000103f37ffff]
Dec 10 16:03:16.620778 omicron kernel: Initmem setup node 0 [mem 0x0000000000001000-0x000000103f37ffff]
Dec 10 16:03:16.620787 omicron kernel: On node 0, zone DMA: 1 pages in unavailable ranges
Dec 10 16:03:16.620799 omicron kernel: On node 0, zone DMA: 96 pages in unavailable ranges
Dec 10 16:03:16.620808 omicron kernel: On node 0, zone DMA32: 961 pages in unavailable ranges
Dec 10 16:03:16.620821 omicron kernel: On node 0, zone DMA32: 14 pages in unavailable ranges
Dec 10 16:03:16.620833 omicron kernel: On node 0, zone DMA32: 32 pages in unavailable ranges
Dec 10 16:03:16.620843 omicron kernel: On node 0, zone DMA32: 11981 pages in unavailable ranges
Dec 10 16:03:16.620853 omicron kernel: On node 0, zone Normal: 4096 pages in unavailable ranges
Dec 10 16:03:16.620868 omicron kernel: On node 0, zone Normal: 3200 pages in unavailable ranges
Dec 10 16:03:16.620881 omicron kernel: ACPI: PM-Timer IO Port: 0x808
Dec 10 16:03:16.620893 omicron kernel: CPU topo: Ignoring hot-pluggable APIC ID 0 in present package.
Dec 10 16:03:16.620905 omicron kernel: ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
Dec 10 16:03:16.620914 omicron kernel: IOAPIC[0]: apic_id 17, version 33, address 0xfec00000, GSI 0-23
Dec 10 16:03:16.620924 omicron kernel: IOAPIC[1]: apic_id 18, version 33, address 0xfec01000, GSI 24-55
Dec 10 16:03:16.620935 omicron kernel: ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
Dec 10 16:03:16.620945 omicron kernel: ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 low level)
Dec 10 16:03:16.620955 omicron kernel: ACPI: Using ACPI (MADT) for SMP configuration information
Dec 10 16:03:16.620969 omicron kernel: ACPI: HPET id: 0x10228201 base: 0xfed00000
Dec 10 16:03:16.620981 omicron kernel: e820: update [mem 0xb6ab8000-0xb6b0efff] usable ==> reserved
Dec 10 16:03:16.620993 omicron kernel: CPU topo: Max. logical packages:   1
Dec 10 16:03:16.621004 omicron kernel: CPU topo: Max. logical dies:       1
Dec 10 16:03:16.621016 omicron kernel: CPU topo: Max. dies per package:   1
Dec 10 16:03:16.621024 omicron kernel: CPU topo: Max. threads per core:   2
Dec 10 16:03:16.621037 omicron kernel: CPU topo: Num. cores per package:     8
Dec 10 16:03:16.621043 omicron kernel: CPU topo: Num. threads per package:  16
Dec 10 16:03:16.621054 omicron kernel: CPU topo: Allowing 16 present CPUs plus 0 hotplug CPUs
Dec 10 16:03:16.621062 omicron kernel: CPU topo: Rejected CPUs 16
Dec 10 16:03:16.621069 omicron kernel: PM: hibernation: Registered nosave memory: [mem 0x00000000-0x00000fff]
Dec 10 16:03:16.621079 omicron kernel: PM: hibernation: Registered nosave memory: [mem 0x000a0000-0x000fffff]
Dec 10 16:03:16.621090 omicron kernel: PM: hibernation: Registered nosave memory: [mem 0x09c3f000-0x09ffffff]
Dec 10 16:03:16.621101 omicron kernel: PM: hibernation: Registered nosave memory: [mem 0x0a200000-0x0a20dfff]
Dec 10 16:03:16.621110 omicron kernel: PM: hibernation: Registered nosave memory: [mem 0x0b000000-0x0b01ffff]
Dec 10 16:03:16.621122 omicron kernel: PM: hibernation: Registered nosave memory: [mem 0xb6ab8000-0xb6b0efff]
Dec 10 16:03:16.621132 omicron kernel: PM: hibernation: Registered nosave memory: [mem 0xb8eb9000-0xb8eb9fff]
Dec 10 16:03:16.621144 omicron kernel: PM: hibernation: Registered nosave memory: [mem 0xbad32000-0xbdbfefff]
Dec 10 16:03:16.621153 omicron kernel: PM: hibernation: Registered nosave memory: [mem 0xbf000000-0xffffffff]
Dec 10 16:03:16.621163 omicron kernel: [mem 0xc0000000-0xfe9fffff] available for PCI devices
Dec 10 16:03:16.621172 omicron kernel: Booting paravirtualized kernel on bare hardware
Dec 10 16:03:16.621183 omicron kernel: clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1910969940391419 ns
Dec 10 16:03:16.621190 omicron kernel: setup_percpu: NR_CPUS:8192 nr_cpumask_bits:16 nr_cpu_ids:16 nr_node_ids:1
Dec 10 16:03:16.621199 omicron kernel: percpu: Embedded 62 pages/cpu s217088 r8192 d28672 u262144
Dec 10 16:03:16.621207 omicron kernel: pcpu-alloc: s217088 r8192 d28672 u262144 alloc=1*2097152
Dec 10 16:03:16.621216 omicron kernel: pcpu-alloc: [0] 00 01 02 03 04 05 06 07 [0] 08 09 10 11 12 13 14 15
Dec 10 16:03:16.621225 omicron kernel: Kernel command line: BOOT_IMAGE=/boot/vmlinuz-6.18-x86_64 root=UUID=a00987d8-776e-4c90-9249-92a768927523 rw quiet udev.log_priority=3
Dec 10 16:03:16.621237 omicron kernel: random: crng init done
Dec 10 16:03:16.621250 omicron kernel: printk: log buffer data + meta data: 131072 + 458752 = 589824 bytes
Dec 10 16:03:16.621263 omicron kernel: Dentry cache hash table entries: 8388608 (order: 14, 67108864 bytes, linear)
Dec 10 16:03:16.621275 omicron kernel: Inode-cache hash table entries: 4194304 (order: 13, 33554432 bytes, linear)
Dec 10 16:03:16.621284 omicron kernel: software IO TLB: area num 16.
Dec 10 16:03:16.621296 omicron kernel: Fallback order for Node 0: 0
Dec 10 16:03:16.621305 omicron kernel: Built 1 zonelists, mobility grouping on.  Total pages: 16756835
Dec 10 16:03:16.621316 omicron kernel: Policy zone: Normal
Dec 10 16:03:16.621327 omicron kernel: mem auto-init: stack:all(zero), heap alloc:on, heap free:off
Dec 10 16:03:16.621340 omicron kernel: SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=16, Nodes=1
Dec 10 16:03:16.621351 omicron kernel: ftrace: allocating 57154 entries in 224 pages
Dec 10 16:03:16.621363 omicron kernel: ftrace: allocated 224 pages with 3 groups
Dec 10 16:03:16.621371 omicron kernel: Dynamic Preempt: full
Dec 10 16:03:16.621382 omicron kernel: rcu: Preemptible hierarchical RCU implementation.
Dec 10 16:03:16.621391 omicron kernel: rcu:         RCU restricting CPUs from NR_CPUS=8192 to nr_cpu_ids=16.
Dec 10 16:03:16.621398 omicron kernel: rcu:         RCU priority boosting: priority 1 delay 500 ms.
Dec 10 16:03:16.621408 omicron kernel:         Trampoline variant of Tasks RCU enabled.
Dec 10 16:03:16.621419 omicron kernel:         Rude variant of Tasks RCU enabled.
Dec 10 16:03:16.621428 omicron kernel:         Tracing variant of Tasks RCU enabled.
Dec 10 16:03:16.621436 omicron kernel: rcu: RCU calculated value of scheduler-enlistment delay is 100 jiffies.
Dec 10 16:03:16.621446 omicron kernel: rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=16
Dec 10 16:03:16.621456 omicron kernel: RCU Tasks: Setting shift to 4 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=16.
Dec 10 16:03:16.621465 omicron kernel: RCU Tasks Rude: Setting shift to 4 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=16.
Dec 10 16:03:16.621474 omicron kernel: RCU Tasks Trace: Setting shift to 4 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=16.
Dec 10 16:03:16.621486 omicron kernel: NR_IRQS: 524544, nr_irqs: 1096, preallocated irqs: 16
Dec 10 16:03:16.621497 omicron kernel: rcu: srcu_init: Setting srcu_struct sizes based on contention.
Dec 10 16:03:16.621510 omicron kernel: kfence: initialized - using 2097152 bytes for 255 objects at 0x(____ptrval____)-0x(____ptrval____)
Dec 10 16:03:16.621521 omicron kernel: Console: colour dummy device 80x25
Dec 10 16:03:16.621534 omicron kernel: printk: legacy console [tty0] enabled
Dec 10 16:03:16.621545 omicron kernel: ACPI: Core revision 20250807
Dec 10 16:03:16.621556 omicron kernel: clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 133484873504 ns
Dec 10 16:03:16.621566 omicron kernel: APIC: Switch to symmetric I/O mode setup
Dec 10 16:03:16.621573 omicron kernel: AMD-Vi: Using global IVHD EFR:0x0, EFR2:0x0
Dec 10 16:03:16.621584 omicron kernel: x2apic: IRQ remapping doesn't support X2APIC mode
Dec 10 16:03:16.621593 omicron kernel: ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
Dec 10 16:03:16.621605 omicron kernel: clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x2b2995a487c, max_idle_ns: 440795241944 ns
Dec 10 16:03:16.621618 omicron kernel: Calibrating delay loop (skipped), value calculated using timer frequency.. 5988.78 BogoMIPS (lpj=2994394)
Dec 10 16:03:16.621630 omicron kernel: SVM disabled (by BIOS) in MSR_VM_CR
Dec 10 16:03:16.621638 omicron kernel: x86/cpu: User Mode Instruction Prevention (UMIP) activated
Dec 10 16:03:16.621649 omicron kernel: LVT offset 1 assigned for vector 0xf9
Dec 10 16:03:16.621659 omicron kernel: LVT offset 2 assigned for vector 0xf4
Dec 10 16:03:16.621672 omicron kernel: Last level iTLB entries: 4KB 512, 2MB 512, 4MB 256
Dec 10 16:03:16.621681 omicron kernel: Last level dTLB entries: 4KB 2048, 2MB 2048, 4MB 1024, 1GB 0
Dec 10 16:03:16.621690 omicron kernel: process: using mwait in idle threads
Dec 10 16:03:16.621702 omicron kernel: mitigations: Enabled attack vectors: user_kernel, user_user, guest_host, guest_guest, SMT mitigations: auto
Dec 10 16:03:16.621712 omicron kernel: Speculative Store Bypass: Mitigation: Speculative Store Bypass disabled via prctl
Dec 10 16:03:16.621721 omicron kernel: Transient Scheduler Attacks: Mitigation: Clear CPU buffers
Dec 10 16:03:16.621733 omicron kernel: Spectre V2 : Mitigation: Retpolines
Dec 10 16:03:16.621742 omicron kernel: Spectre V2 : User space: Mitigation: STIBP always-on protection
Dec 10 16:03:16.621751 omicron kernel: Speculative Return Stack Overflow: Mitigation: Safe RET
Dec 10 16:03:16.621758 omicron kernel: VMSCAPE: Mitigation: IBPB before exit to userspace
Dec 10 16:03:16.621767 omicron kernel: Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization
Dec 10 16:03:16.621776 omicron kernel: Spectre V2 : Spectre v2 / SpectreRSB: Filling RSB on context switch and VMEXIT
Dec 10 16:03:16.621789 omicron kernel: Spectre V2 : Enabling Restricted Speculation for firmware calls
Dec 10 16:03:16.621799 omicron kernel: Spectre V2 : mitigation: Enabling conditional Indirect Branch Prediction Barrier
Dec 10 16:03:16.621811 omicron kernel: active return thunk: srso_alias_return_thunk
Dec 10 16:03:16.621824 omicron kernel: x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
Dec 10 16:03:16.621831 omicron kernel: x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
Dec 10 16:03:16.621839 omicron kernel: x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
Dec 10 16:03:16.621848 omicron kernel: x86/fpu: Supporting XSAVE feature 0x200: 'Protection Keys User registers'
Dec 10 16:03:16.621854 omicron kernel: x86/fpu: Supporting XSAVE feature 0x800: 'Control-flow User registers'
Dec 10 16:03:16.621865 omicron kernel: x86/fpu: Supporting XSAVE feature 0x1000: 'Control-flow Kernel registers (KVM only)'
Dec 10 16:03:16.621878 omicron kernel: x86/fpu: xstate_offset[2]:  576, xstate_sizes[2]:  256
Dec 10 16:03:16.621890 omicron kernel: x86/fpu: xstate_offset[9]:  832, xstate_sizes[9]:    8
Dec 10 16:03:16.621904 omicron kernel: x86/fpu: xstate_offset[11]:  840, xstate_sizes[11]:   16
Dec 10 16:03:16.621910 omicron kernel: x86/fpu: xstate_offset[12]:  856, xstate_sizes[12]:   24
Dec 10 16:03:16.621919 omicron kernel: x86/fpu: Enabled xstate features 0x1a07, context size is 880 bytes, using 'compacted' format.
Dec 10 16:03:16.621930 omicron kernel: Freeing SMP alternatives memory: 56K
Dec 10 16:03:16.621937 omicron kernel: pid_max: default: 32768 minimum: 301
Dec 10 16:03:16.621947 omicron kernel: LSM: initializing lsm=capability,landlock,lockdown,yama,bpf
Dec 10 16:03:16.621956 omicron kernel: landlock: Up and running.
Dec 10 16:03:16.621969 omicron kernel: Yama: becoming mindful.
Dec 10 16:03:16.621981 omicron kernel: LSM support for eBPF active
Dec 10 16:03:16.621991 omicron kernel: Mount-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
Dec 10 16:03:16.622002 omicron kernel: Mountpoint-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
Dec 10 16:03:16.622012 omicron kernel: smpboot: CPU0: AMD Ryzen 7 5700X3D 8-Core Processor (family: 0x19, model: 0x21, stepping: 0x2)
Dec 10 16:03:16.622022 omicron kernel: Performance Events: Fam17h+ core perfctr, AMD PMU driver.
Dec 10 16:03:16.622029 omicron kernel: ... version:                   0
Dec 10 16:03:16.622038 omicron kernel: ... bit width:                 48
Dec 10 16:03:16.622046 omicron kernel: ... generic counters:          6
Dec 10 16:03:16.622055 omicron kernel: ... generic bitmap:            000000000000003f
Dec 10 16:03:16.622067 omicron kernel: ... fixed-purpose counters:    0
Dec 10 16:03:16.622074 omicron kernel: ... fixed-purpose bitmap:      0000000000000000
Dec 10 16:03:16.622082 omicron kernel: ... value mask:                0000ffffffffffff
Dec 10 16:03:16.622093 omicron kernel: ... max period:                00007fffffffffff
Dec 10 16:03:16.622105 omicron kernel: ... global_ctrl mask:          000000000000003f
Dec 10 16:03:16.622116 omicron kernel: signal: max sigframe size: 3376
Dec 10 16:03:16.622129 omicron kernel: rcu: Hierarchical SRCU implementation.
Dec 10 16:03:16.622139 omicron kernel: rcu:         Max phase no-delay instances is 400.
Dec 10 16:03:16.622149 omicron kernel: Timer migration: 2 hierarchy levels; 8 children per group; 2 crossnode level
Dec 10 16:03:16.622159 omicron kernel: MCE: In-kernel MCE decoding enabled.
Dec 10 16:03:16.622166 omicron kernel: NMI watchdog: Enabled. Permanently consumes one hw-PMU counter.
Dec 10 16:03:16.622175 omicron kernel: smp: Bringing up secondary CPUs ...
Dec 10 16:03:16.622186 omicron kernel: smpboot: x86: Booting SMP configuration:
Dec 10 16:03:16.622195 omicron kernel: .... node  #0, CPUs:        #1  #2  #3  #4  #5  #6  #7  #8  #9 #10 #11 #12 #13 #14 #15
Dec 10 16:03:16.622202 omicron kernel: Spectre V2 : Update user space SMT mitigation: STIBP always-on
Dec 10 16:03:16.622212 omicron kernel: smp: Brought up 1 node, 16 CPUs
Dec 10 16:03:16.622219 omicron kernel: smpboot: Total of 16 processors activated (95820.60 BogoMIPS)
Dec 10 16:03:16.622228 omicron kernel: Memory: 65595836K/67027340K available (20248K kernel code, 2953K rwdata, 16372K rodata, 4728K init, 4784K bss, 1406908K reserved, 0K cma-reserved)
Dec 10 16:03:16.622238 omicron kernel: devtmpfs: initialized
Dec 10 16:03:16.622247 omicron kernel: x86/mm: Memory block size: 2048MB
Dec 10 16:03:16.622254 omicron kernel: ACPI: PM: Registering ACPI NVS region [mem 0x0a200000-0x0a20dfff] (57344 bytes)
Dec 10 16:03:16.622265 omicron kernel: ACPI: PM: Registering ACPI NVS region [mem 0xbc5ff000-0xbcce5fff] (7237632 bytes)
Dec 10 16:03:16.622271 omicron kernel: clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275000 ns
Dec 10 16:03:16.622280 omicron kernel: posixtimers hash table entries: 8192 (order: 5, 131072 bytes, linear)
Dec 10 16:03:16.622288 omicron kernel: futex hash table entries: 4096 (262144 bytes on 1 NUMA nodes, total 256 KiB, linear).
Dec 10 16:03:16.622297 omicron kernel: pinctrl core: initialized pinctrl subsystem
Dec 10 16:03:16.622305 omicron kernel: PM: RTC time: 21:03:10, date: 2025-12-10
Dec 10 16:03:16.622316 omicron kernel: NET: Registered PF_NETLINK/PF_ROUTE protocol family
Dec 10 16:03:16.622326 omicron kernel: DMA: preallocated 4096 KiB GFP_KERNEL pool for atomic allocations
Dec 10 16:03:16.622333 omicron kernel: DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
Dec 10 16:03:16.622342 omicron kernel: DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
Dec 10 16:03:16.622352 omicron kernel: audit: initializing netlink subsys (disabled)
Dec 10 16:03:16.622359 omicron kernel: audit: type=2000 audit(1765400589.174:1): state=initialized audit_enabled=0 res=1
Dec 10 16:03:16.622368 omicron kernel: thermal_sys: Registered thermal governor 'fair_share'
Dec 10 16:03:16.622374 omicron kernel: thermal_sys: Registered thermal governor 'bang_bang'
Dec 10 16:03:16.622381 omicron kernel: thermal_sys: Registered thermal governor 'step_wise'
Dec 10 16:03:16.622387 omicron kernel: thermal_sys: Registered thermal governor 'user_space'
Dec 10 16:03:16.622394 omicron kernel: thermal_sys: Registered thermal governor 'power_allocator'
Dec 10 16:03:16.622401 omicron kernel: cpuidle: using governor ladder
Dec 10 16:03:16.622410 omicron kernel: cpuidle: using governor menu
Dec 10 16:03:16.622417 omicron kernel: Detected 1 PCC Subspaces
Dec 10 16:03:16.622425 omicron kernel: Registering PCC driver as Mailbox controller
Dec 10 16:03:16.622431 omicron kernel: acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
Dec 10 16:03:16.622440 omicron kernel: PCI: ECAM [mem 0xf0000000-0xf7ffffff] (base 0xf0000000) for domain 0000 [bus 00-7f]
Dec 10 16:03:16.622447 omicron kernel: PCI: Using configuration type 1 for base access
Dec 10 16:03:16.622456 omicron kernel: kprobes: kprobe jump-optimization is enabled. All kprobes are optimized if possible.
Dec 10 16:03:16.622465 omicron kernel: HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
Dec 10 16:03:16.622476 omicron kernel: HugeTLB: 16380 KiB vmemmap can be freed for a 1.00 GiB page
Dec 10 16:03:16.622482 omicron kernel: HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
Dec 10 16:03:16.622489 omicron kernel: HugeTLB: 28 KiB vmemmap can be freed for a 2.00 MiB page
Dec 10 16:03:16.622496 omicron kernel: raid6: skipped pq benchmark and selected avx2x4
Dec 10 16:03:16.622505 omicron kernel: raid6: using avx2x2 recovery algorithm
Dec 10 16:03:16.622516 omicron kernel: ACPI: Added _OSI(Module Device)
Dec 10 16:03:16.622525 omicron kernel: ACPI: Added _OSI(Processor Device)
Dec 10 16:03:16.622535 omicron kernel: ACPI: Added _OSI(Processor Aggregator Device)
Dec 10 16:03:16.622546 omicron kernel: ACPI: 9 ACPI AML tables successfully acquired and loaded
Dec 10 16:03:16.622557 omicron kernel: ACPI: [Firmware Bug]: BIOS _OSI(Linux) query ignored
Dec 10 16:03:16.622567 omicron kernel: ACPI: Interpreter enabled
Dec 10 16:03:16.622576 omicron kernel: ACPI: PM: (supports S0 S3 S4 S5)
Dec 10 16:03:16.622585 omicron kernel: ACPI: Using IOAPIC for interrupt routing
Dec 10 16:03:16.622593 omicron kernel: PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
Dec 10 16:03:16.622600 omicron kernel: PCI: Ignoring E820 reservations for host bridge windows
Dec 10 16:03:16.622607 omicron kernel: ACPI: Enabled 8 GPEs in block 00 to 1F
Dec 10 16:03:16.622616 omicron kernel: ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
Dec 10 16:03:16.622821 omicron kernel: acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI EDR HPX-Type3]
Dec 10 16:03:16.623010 omicron kernel: acpi PNP0A08:00: _OSC: platform does not support [SHPCHotplug LTR DPC]
Dec 10 16:03:16.623182 omicron kernel: acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug PME AER PCIeCapability]
Dec 10 16:03:16.623352 omicron kernel: acpi PNP0A08:00: [Firmware Info]: ECAM [mem 0xf0000000-0xf7ffffff] for domain 0000 [bus 00-7f] only partially covers this bridge
Dec 10 16:03:16.623362 omicron kernel: PCI host bridge to bus 0000:00
Dec 10 16:03:16.623523 omicron kernel: pci_bus 0000:00: root bus resource [io  0x0000-0x03af window]
Dec 10 16:03:16.623684 omicron kernel: pci_bus 0000:00: root bus resource [io  0x03e0-0x0cf7 window]
Dec 10 16:03:16.623841 omicron kernel: pci_bus 0000:00: root bus resource [io  0x03b0-0x03df window]
Dec 10 16:03:16.624023 omicron kernel: pci_bus 0000:00: root bus resource [io  0x0d00-0xffff window]
Dec 10 16:03:16.624180 omicron kernel: pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000dffff window]
Dec 10 16:03:16.624337 omicron kernel: pci_bus 0000:00: root bus resource [mem 0xc0000000-0xfec2ffff window]
Dec 10 16:03:16.624494 omicron kernel: pci_bus 0000:00: root bus resource [mem 0xfee00000-0xffffffff window]
Dec 10 16:03:16.624647 omicron kernel: pci_bus 0000:00: root bus resource [bus 00-ff]
Dec 10 16:03:16.624834 omicron kernel: pci 0000:00:00.0: [1022:1480] type 00 class 0x060000 conventional PCI endpoint
Dec 10 16:03:16.625014 omicron kernel: pci 0000:00:00.2: [1022:1481] type 00 class 0x080600 conventional PCI endpoint
Dec 10 16:03:16.625218 omicron kernel: pci 0000:00:01.0: [1022:1482] type 00 class 0x060000 conventional PCI endpoint
Dec 10 16:03:16.625410 omicron kernel: pci 0000:00:01.2: [1022:1483] type 01 class 0x060400 PCIe Root Port
Dec 10 16:03:16.625589 omicron kernel: pci 0000:00:01.2: PCI bridge to [bus 01-05]
Dec 10 16:03:16.625764 omicron kernel: pci 0000:00:01.2:   bridge window [io  0xd000-0xefff]
Dec 10 16:03:16.625929 omicron kernel: pci 0000:00:01.2:   bridge window [mem 0xfc200000-0xfc5fffff]
Dec 10 16:03:16.626099 omicron kernel: pci 0000:00:01.2: enabling Extended Tags
Dec 10 16:03:16.626265 omicron kernel: pci 0000:00:01.2: PME# supported from D0 D3hot D3cold
Dec 10 16:03:16.626432 omicron kernel: pci 0000:00:02.0: [1022:1482] type 00 class 0x060000 conventional PCI endpoint
Dec 10 16:03:16.626596 omicron kernel: pci 0000:00:03.0: [1022:1482] type 00 class 0x060000 conventional PCI endpoint
Dec 10 16:03:16.626755 omicron kernel: pci 0000:00:03.1: [1022:1483] type 01 class 0x060400 PCIe Root Port
Dec 10 16:03:16.626925 omicron kernel: pci 0000:00:03.1: PCI bridge to [bus 06]
Dec 10 16:03:16.627088 omicron kernel: pci 0000:00:03.1:   bridge window [io  0xf000-0xffff]
Dec 10 16:03:16.627251 omicron kernel: pci 0000:00:03.1:   bridge window [mem 0xfb000000-0xfc0fffff]
Dec 10 16:03:16.627409 omicron kernel: pci 0000:00:03.1:   bridge window [mem 0xd0000000-0xe20fffff 64bit pref]
Dec 10 16:03:16.627570 omicron kernel: pci 0000:00:03.1: PME# supported from D0 D3hot D3cold
Dec 10 16:03:16.627742 omicron kernel: pci 0000:00:04.0: [1022:1482] type 00 class 0x060000 conventional PCI endpoint
Dec 10 16:03:16.627913 omicron kernel: pci 0000:00:05.0: [1022:1482] type 00 class 0x060000 conventional PCI endpoint
Dec 10 16:03:16.628077 omicron kernel: pci 0000:00:07.0: [1022:1482] type 00 class 0x060000 conventional PCI endpoint
Dec 10 16:03:16.628243 omicron kernel: pci 0000:00:07.1: [1022:1484] type 01 class 0x060400 PCIe Root Port
Dec 10 16:03:16.628411 omicron kernel: pci 0000:00:07.1: PCI bridge to [bus 07]
Dec 10 16:03:16.628573 omicron kernel: pci 0000:00:07.1: enabling Extended Tags
Dec 10 16:03:16.628734 omicron kernel: pci 0000:00:07.1: PME# supported from D0 D3hot D3cold
Dec 10 16:03:16.628911 omicron kernel: pci 0000:00:08.0: [1022:1482] type 00 class 0x060000 conventional PCI endpoint
Dec 10 16:03:16.629088 omicron kernel: pci 0000:00:08.1: [1022:1484] type 01 class 0x060400 PCIe Root Port
Dec 10 16:03:16.629278 omicron kernel: pci 0000:00:08.1: PCI bridge to [bus 08]
Dec 10 16:03:16.629440 omicron kernel: pci 0000:00:08.1:   bridge window [mem 0xfc600000-0xfc8fffff]
Dec 10 16:03:16.629603 omicron kernel: pci 0000:00:08.1: enabling Extended Tags
Dec 10 16:03:16.629767 omicron kernel: pci 0000:00:08.1: PME# supported from D0 D3hot D3cold
Dec 10 16:03:16.629934 omicron kernel: pci 0000:00:08.3: [1022:1484] type 01 class 0x060400 PCIe Root Port
Dec 10 16:03:16.630098 omicron kernel: pci 0000:00:08.3: PCI bridge to [bus 09]
Dec 10 16:03:16.630259 omicron kernel: pci 0000:00:08.3:   bridge window [mem 0xfc900000-0xfc9fffff]
Dec 10 16:03:16.630423 omicron kernel: pci 0000:00:08.3: enabling Extended Tags
Dec 10 16:03:16.630585 omicron kernel: pci 0000:00:08.3: PME# supported from D0 D3hot D3cold
Dec 10 16:03:16.630749 omicron kernel: pci 0000:00:14.0: [1022:790b] type 00 class 0x0c0500 conventional PCI endpoint
Dec 10 16:03:16.630928 omicron kernel: pci 0000:00:14.3: [1022:790e] type 00 class 0x060100 conventional PCI endpoint
Dec 10 16:03:16.631107 omicron kernel: pci 0000:00:18.0: [1022:1440] type 00 class 0x060000 conventional PCI endpoint
Dec 10 16:03:16.631275 omicron kernel: pci 0000:00:18.1: [1022:1441] type 00 class 0x060000 conventional PCI endpoint
Dec 10 16:03:16.631437 omicron kernel: pci 0000:00:18.2: [1022:1442] type 00 class 0x060000 conventional PCI endpoint
Dec 10 16:03:16.631602 omicron kernel: pci 0000:00:18.3: [1022:1443] type 00 class 0x060000 conventional PCI endpoint
Dec 10 16:03:16.631771 omicron kernel: pci 0000:00:18.4: [1022:1444] type 00 class 0x060000 conventional PCI endpoint
Dec 10 16:03:16.631943 omicron kernel: pci 0000:00:18.5: [1022:1445] type 00 class 0x060000 conventional PCI endpoint
Dec 10 16:03:16.632109 omicron kernel: pci 0000:00:18.6: [1022:1446] type 00 class 0x060000 conventional PCI endpoint
Dec 10 16:03:16.632272 omicron kernel: pci 0000:00:18.7: [1022:1447] type 00 class 0x060000 conventional PCI endpoint
Dec 10 16:03:16.632447 omicron kernel: pci 0000:01:00.0: [1022:43ee] type 00 class 0x0c0330 PCIe Legacy Endpoint
Dec 10 16:03:16.632617 omicron kernel: pci 0000:01:00.0: BAR 0 [mem 0xfc5a0000-0xfc5a7fff 64bit]
Dec 10 16:03:16.632787 omicron kernel: pci 0000:01:00.0: enabling Extended Tags
Dec 10 16:03:16.632981 omicron kernel: pci 0000:01:00.0: PME# supported from D3hot D3cold
Dec 10 16:03:16.633156 omicron kernel: pci 0000:01:00.1: [1022:43eb] type 00 class 0x010601 PCIe Legacy Endpoint
Dec 10 16:03:16.633329 omicron kernel: pci 0000:01:00.1: BAR 5 [mem 0xfc580000-0xfc59ffff]
Dec 10 16:03:16.633498 omicron kernel: pci 0000:01:00.1: ROM [mem 0xfc500000-0xfc57ffff pref]
Dec 10 16:03:16.633669 omicron kernel: pci 0000:01:00.1: enabling Extended Tags
Dec 10 16:03:16.633843 omicron kernel: pci 0000:01:00.1: PME# supported from D3hot D3cold
Dec 10 16:03:16.634025 omicron kernel: pci 0000:01:00.2: [1022:43e9] type 01 class 0x060400 PCIe Switch Upstream Port
Dec 10 16:03:16.634199 omicron kernel: pci 0000:01:00.2: PCI bridge to [bus 02-05]
Dec 10 16:03:16.634368 omicron kernel: pci 0000:01:00.2:   bridge window [io  0xd000-0xefff]
Dec 10 16:03:16.634537 omicron kernel: pci 0000:01:00.2:   bridge window [mem 0xfc200000-0xfc4fffff]
Dec 10 16:03:16.634701 omicron kernel: pci 0000:01:00.2: enabling Extended Tags
Dec 10 16:03:16.634872 omicron kernel: pci 0000:01:00.2: PME# supported from D3hot D3cold
Dec 10 16:03:16.635040 omicron kernel: pci 0000:00:01.2: PCI bridge to [bus 01-05]
Dec 10 16:03:16.635215 omicron kernel: pci 0000:02:04.0: [1022:43ea] type 01 class 0x060400 PCIe Switch Downstream Port
Dec 10 16:03:16.635394 omicron kernel: pci 0000:02:04.0: PCI bridge to [bus 03]
Dec 10 16:03:16.635573 omicron kernel: pci 0000:02:04.0:   bridge window [mem 0xfc400000-0xfc4fffff]
Dec 10 16:03:16.635754 omicron kernel: pci 0000:02:04.0: enabling Extended Tags
Dec 10 16:03:16.635936 omicron kernel: pci 0000:02:04.0: PME# supported from D3hot D3cold
Dec 10 16:03:16.636111 omicron kernel: pci 0000:02:08.0: [1022:43ea] type 01 class 0x060400 PCIe Switch Downstream Port
Dec 10 16:03:16.636290 omicron kernel: pci 0000:02:08.0: PCI bridge to [bus 04]
Dec 10 16:03:16.636463 omicron kernel: pci 0000:02:08.0:   bridge window [io  0xe000-0xefff]
Dec 10 16:03:16.636636 omicron kernel: pci 0000:02:08.0:   bridge window [mem 0xfc300000-0xfc3fffff]
Dec 10 16:03:16.636809 omicron kernel: pci 0000:02:08.0: enabling Extended Tags
Dec 10 16:03:16.637067 omicron kernel: pci 0000:02:08.0: PME# supported from D3hot D3cold
Dec 10 16:03:16.637250 omicron kernel: pci 0000:02:09.0: [1022:43ea] type 01 class 0x060400 PCIe Switch Downstream Port
Dec 10 16:03:16.637429 omicron kernel: pci 0000:02:09.0: PCI bridge to [bus 05]
Dec 10 16:03:16.637603 omicron kernel: pci 0000:02:09.0:   bridge window [io  0xd000-0xdfff]
Dec 10 16:03:16.637780 omicron kernel: pci 0000:02:09.0:   bridge window [mem 0xfc200000-0xfc2fffff]
Dec 10 16:03:16.637965 omicron kernel: pci 0000:02:09.0: enabling Extended Tags
Dec 10 16:03:16.638149 omicron kernel: pci 0000:02:09.0: PME# supported from D3hot D3cold
Dec 10 16:03:16.638321 omicron kernel: pci 0000:01:00.2: PCI bridge to [bus 02-05]
Dec 10 16:03:16.638504 omicron kernel: pci 0000:03:00.0: [15b7:5030] type 00 class 0x010802 PCIe Endpoint
Dec 10 16:03:16.638698 omicron kernel: pci 0000:03:00.0: BAR 0 [mem 0xfc400000-0xfc403fff 64bit]
Dec 10 16:03:16.638884 omicron kernel: pci 0000:03:00.0: 31.504 Gb/s available PCIe bandwidth, limited by 8.0 GT/s PCIe x4 link at 0000:00:01.2 (capable of 63.012 Gb/s with 16.0 GT/s PCIe x4 link)
Dec 10 16:03:16.639064 omicron kernel: pci 0000:02:04.0: PCI bridge to [bus 03]
Dec 10 16:03:16.639251 omicron kernel: pci 0000:04:00.0: [10ec:8125] type 00 class 0x020000 PCIe Endpoint
Dec 10 16:03:16.639437 omicron kernel: pci 0000:04:00.0: BAR 0 [io  0xe000-0xe0ff]
Dec 10 16:03:16.639623 omicron kernel: pci 0000:04:00.0: BAR 2 [mem 0xfc300000-0xfc30ffff 64bit]
Dec 10 16:03:16.639802 omicron kernel: pci 0000:04:00.0: BAR 4 [mem 0xfc310000-0xfc313fff 64bit]
Dec 10 16:03:16.639992 omicron kernel: pci 0000:04:00.0: supports D1 D2
Dec 10 16:03:16.640177 omicron kernel: pci 0000:04:00.0: PME# supported from D0 D1 D2 D3hot D3cold
Dec 10 16:03:16.640351 omicron kernel: pci 0000:02:08.0: PCI bridge to [bus 04]
Dec 10 16:03:16.640531 omicron kernel: pci 0000:05:00.0: [10ec:b851] type 00 class 0x028000 PCIe Endpoint
Dec 10 16:03:16.640717 omicron kernel: pci 0000:05:00.0: BAR 0 [io  0xd000-0xd0ff]
Dec 10 16:03:16.640901 omicron kernel: pci 0000:05:00.0: BAR 2 [mem 0xfc200000-0xfc2fffff 64bit]
Dec 10 16:03:16.641083 omicron kernel: pci 0000:05:00.0: PME# supported from D0 D3hot D3cold
Dec 10 16:03:16.641261 omicron kernel: pci 0000:02:09.0: PCI bridge to [bus 05]
Dec 10 16:03:16.641431 omicron kernel: pci 0000:06:00.0: [10de:1f02] type 00 class 0x030000 PCIe Legacy Endpoint
Dec 10 16:03:16.641601 omicron kernel: pci 0000:06:00.0: BAR 0 [mem 0xfb000000-0xfbffffff]
Dec 10 16:03:16.641766 omicron kernel: pci 0000:06:00.0: BAR 1 [mem 0xd0000000-0xdfffffff 64bit pref]
Dec 10 16:03:16.641945 omicron kernel: pci 0000:06:00.0: BAR 3 [mem 0xe0000000-0xe1ffffff 64bit pref]
Dec 10 16:03:16.642112 omicron kernel: pci 0000:06:00.0: BAR 5 [io  0xf000-0xf07f]
Dec 10 16:03:16.642284 omicron kernel: pci 0000:06:00.0: ROM [mem 0xfc000000-0xfc07ffff pref]
Dec 10 16:03:16.642453 omicron kernel: pci 0000:06:00.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
Dec 10 16:03:16.642625 omicron kernel: pci 0000:06:00.0: PME# supported from D0 D3hot
Dec 10 16:03:16.642796 omicron kernel: pci 0000:06:00.0: 32.000 Gb/s available PCIe bandwidth, limited by 2.5 GT/s PCIe x16 link at 0000:00:03.1 (capable of 126.016 Gb/s with 8.0 GT/s PCIe x16 link)
Dec 10 16:03:16.642968 omicron kernel: pci 0000:06:00.1: [10de:10f9] type 00 class 0x040300 PCIe Endpoint
Dec 10 16:03:16.643133 omicron kernel: pci 0000:06:00.1: BAR 0 [mem 0xfc080000-0xfc083fff]
Dec 10 16:03:16.643300 omicron kernel: pci 0000:06:00.2: [10de:1ada] type 00 class 0x0c0330 PCIe Endpoint
Dec 10 16:03:16.643471 omicron kernel: pci 0000:06:00.2: BAR 0 [mem 0xe2000000-0xe203ffff 64bit pref]
Dec 10 16:03:16.643642 omicron kernel: pci 0000:06:00.2: BAR 3 [mem 0xe2040000-0xe204ffff 64bit pref]
Dec 10 16:03:16.643815 omicron kernel: pci 0000:06:00.2: PME# supported from D0 D3hot
Dec 10 16:03:16.643993 omicron kernel: pci 0000:06:00.3: [10de:1adb] type 00 class 0x0c8000 PCIe Endpoint
Dec 10 16:03:16.644167 omicron kernel: pci 0000:06:00.3: BAR 0 [mem 0xfc084000-0xfc084fff]
Dec 10 16:03:16.644336 omicron kernel: pci 0000:06:00.3: PME# supported from D0 D3hot
Dec 10 16:03:16.644496 omicron kernel: pci 0000:00:03.1: PCI bridge to [bus 06]
Dec 10 16:03:16.644669 omicron kernel: pci 0000:07:00.0: [1022:148a] type 00 class 0x130000 PCIe Endpoint
Dec 10 16:03:16.644837 omicron kernel: pci 0000:07:00.0: enabling Extended Tags
Dec 10 16:03:16.645034 omicron kernel: pci 0000:00:07.1: PCI bridge to [bus 07]
Dec 10 16:03:16.645227 omicron kernel: pci 0000:08:00.0: [1022:1485] type 00 class 0x130000 PCIe Endpoint
Dec 10 16:03:16.645403 omicron kernel: pci 0000:08:00.0: enabling Extended Tags
Dec 10 16:03:16.645577 omicron kernel: pci 0000:08:00.1: [1022:1486] type 00 class 0x108000 PCIe Endpoint
Dec 10 16:03:16.645747 omicron kernel: pci 0000:08:00.1: BAR 2 [mem 0xfc700000-0xfc7fffff]
Dec 10 16:03:16.645939 omicron kernel: pci 0000:08:00.1: BAR 5 [mem 0xfc808000-0xfc809fff]
Dec 10 16:03:16.646109 omicron kernel: pci 0000:08:00.1: enabling Extended Tags
Dec 10 16:03:16.646284 omicron kernel: pci 0000:08:00.3: [1022:149c] type 00 class 0x0c0330 PCIe Endpoint
Dec 10 16:03:16.646453 omicron kernel: pci 0000:08:00.3: BAR 0 [mem 0xfc600000-0xfc6fffff 64bit]
Dec 10 16:03:16.646622 omicron kernel: pci 0000:08:00.3: enabling Extended Tags
Dec 10 16:03:16.646791 omicron kernel: pci 0000:08:00.3: PME# supported from D0 D3hot D3cold
Dec 10 16:03:16.646963 omicron kernel: pci 0000:08:00.4: [1022:1487] type 00 class 0x040300 PCIe Endpoint
Dec 10 16:03:16.647134 omicron kernel: pci 0000:08:00.4: BAR 0 [mem 0xfc800000-0xfc807fff]
Dec 10 16:03:16.647303 omicron kernel: pci 0000:08:00.4: enabling Extended Tags
Dec 10 16:03:16.647471 omicron kernel: pci 0000:08:00.4: PME# supported from D0 D3hot D3cold
Dec 10 16:03:16.647633 omicron kernel: pci 0000:00:08.1: PCI bridge to [bus 08]
Dec 10 16:03:16.647799 omicron kernel: pci 0000:09:00.0: [1022:7901] type 00 class 0x010601 PCIe Endpoint
Dec 10 16:03:16.647974 omicron kernel: pci 0000:09:00.0: BAR 5 [mem 0xfc900000-0xfc9007ff]
Dec 10 16:03:16.648139 omicron kernel: pci 0000:09:00.0: enabling Extended Tags
Dec 10 16:03:16.648309 omicron kernel: pci 0000:09:00.0: PME# supported from D3hot D3cold
Dec 10 16:03:16.648470 omicron kernel: pci 0000:00:08.3: PCI bridge to [bus 09]
Dec 10 16:03:16.648480 omicron kernel: ACPI: PCI: Interrupt link LNKA configured for IRQ 0
Dec 10 16:03:16.648494 omicron kernel: ACPI: PCI: Interrupt link LNKB configured for IRQ 0
Dec 10 16:03:16.648503 omicron kernel: ACPI: PCI: Interrupt link LNKC configured for IRQ 0
Dec 10 16:03:16.648512 omicron kernel: ACPI: PCI: Interrupt link LNKD configured for IRQ 0
Dec 10 16:03:16.648523 omicron kernel: ACPI: PCI: Interrupt link LNKE configured for IRQ 0
Dec 10 16:03:16.648530 omicron kernel: ACPI: PCI: Interrupt link LNKF configured for IRQ 0
Dec 10 16:03:16.648537 omicron kernel: ACPI: PCI: Interrupt link LNKG configured for IRQ 0
Dec 10 16:03:16.648546 omicron kernel: ACPI: PCI: Interrupt link LNKH configured for IRQ 0
Dec 10 16:03:16.648556 omicron kernel: iommu: Default domain type: Translated
Dec 10 16:03:16.648568 omicron kernel: iommu: DMA domain TLB invalidation policy: lazy mode
Dec 10 16:03:16.648577 omicron kernel: SCSI subsystem initialized
Dec 10 16:03:16.648584 omicron kernel: libata version 3.00 loaded.
Dec 10 16:03:16.648591 omicron kernel: ACPI: bus type USB registered
Dec 10 16:03:16.648600 omicron kernel: usbcore: registered new interface driver usbfs
Dec 10 16:03:16.648606 omicron kernel: usbcore: registered new interface driver hub
Dec 10 16:03:16.648615 omicron kernel: usbcore: registered new device driver usb
Dec 10 16:03:16.648622 omicron kernel: EDAC MC: Ver: 3.0.0
Dec 10 16:03:16.648629 omicron kernel: efivars: Registered efivars operations
Dec 10 16:03:16.648636 omicron kernel: NetLabel: Initializing
Dec 10 16:03:16.648642 omicron kernel: NetLabel:  domain hash size = 128
Dec 10 16:03:16.648649 omicron kernel: NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
Dec 10 16:03:16.648658 omicron kernel: NetLabel:  unlabeled traffic allowed by default
Dec 10 16:03:16.648665 omicron kernel: mctp: management component transport protocol core
Dec 10 16:03:16.648672 omicron kernel: NET: Registered PF_MCTP protocol family
Dec 10 16:03:16.648679 omicron kernel: PCI: Using ACPI for IRQ routing
Dec 10 16:03:16.648688 omicron kernel: PCI: pci_cache_line_size set to 64 bytes
Dec 10 16:03:16.648695 omicron kernel: e820: reserve RAM buffer [mem 0x09c3f000-0x0bffffff]
Dec 10 16:03:16.648702 omicron kernel: e820: reserve RAM buffer [mem 0x0a200000-0x0bffffff]
Dec 10 16:03:16.648711 omicron kernel: e820: reserve RAM buffer [mem 0x0b000000-0x0bffffff]
Dec 10 16:03:16.648719 omicron kernel: e820: reserve RAM buffer [mem 0xb6ab8000-0xb7ffffff]
Dec 10 16:03:16.648728 omicron kernel: e820: reserve RAM buffer [mem 0xb8eb9000-0xbbffffff]
Dec 10 16:03:16.648735 omicron kernel: e820: reserve RAM buffer [mem 0xbad32000-0xbbffffff]
Dec 10 16:03:16.648744 omicron kernel: e820: reserve RAM buffer [mem 0xbf000000-0xbfffffff]
Dec 10 16:03:16.648751 omicron kernel: e820: reserve RAM buffer [mem 0x103f380000-0x103fffffff]
Dec 10 16:03:16.648920 omicron kernel: pci 0000:06:00.0: vgaarb: setting as boot VGA device
Dec 10 16:03:16.649087 omicron kernel: pci 0000:06:00.0: vgaarb: bridge control possible
Dec 10 16:03:16.649251 omicron kernel: pci 0000:06:00.0: vgaarb: VGA device added: decodes=io+mem,owns=io+mem,locks=none
Dec 10 16:03:16.649261 omicron kernel: vgaarb: loaded
Dec 10 16:03:16.649268 omicron kernel: hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0
Dec 10 16:03:16.649275 omicron kernel: hpet0: 3 comparators, 32-bit 14.318180 MHz counter
Dec 10 16:03:16.649285 omicron kernel: clocksource: Switched to clocksource tsc-early
Dec 10 16:03:16.649292 omicron kernel: VFS: Disk quotas dquot_6.6.0
Dec 10 16:03:16.649301 omicron kernel: VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
Dec 10 16:03:16.649308 omicron kernel: pnp: PnP ACPI init
Dec 10 16:03:16.649468 omicron kernel: system 00:00: [mem 0xf0000000-0xf7ffffff] has been reserved
Dec 10 16:03:16.649626 omicron kernel: system 00:01: [mem 0xfd200000-0xfd2fffff] has been reserved
Dec 10 16:03:16.649787 omicron kernel: system 00:03: [io  0x0a00-0x0a2f] has been reserved
Dec 10 16:03:16.649947 omicron kernel: system 00:03: [io  0x0a30-0x0a3f] has been reserved
Dec 10 16:03:16.650105 omicron kernel: system 00:03: [io  0x0a40-0x0a4f] has been reserved
Dec 10 16:03:16.650257 omicron kernel: system 00:03: [mem 0xfe000000-0xfe00ffff] has been reserved
Dec 10 16:03:16.650414 omicron kernel: system 00:04: [io  0x04d0-0x04d1] has been reserved
Dec 10 16:03:16.650567 omicron kernel: system 00:04: [io  0x040b] has been reserved
Dec 10 16:03:16.650723 omicron kernel: system 00:04: [io  0x04d6] has been reserved
Dec 10 16:03:16.650878 omicron kernel: system 00:04: [io  0x0c00-0x0c01] has been reserved
Dec 10 16:03:16.651035 omicron kernel: system 00:04: [io  0x0c14] has been reserved
Dec 10 16:03:16.651192 omicron kernel: system 00:04: [io  0x0c50-0x0c51] has been reserved
Dec 10 16:03:16.651343 omicron kernel: system 00:04: [io  0x0c52] has been reserved
Dec 10 16:03:16.651494 omicron kernel: system 00:04: [io  0x0c6c] has been reserved
Dec 10 16:03:16.651649 omicron kernel: system 00:04: [io  0x0c6f] has been reserved
Dec 10 16:03:16.651804 omicron kernel: system 00:04: [io  0x0cd8-0x0cdf] has been reserved
Dec 10 16:03:16.651960 omicron kernel: system 00:04: [io  0x0800-0x089f] has been reserved
Dec 10 16:03:16.652116 omicron kernel: system 00:04: [io  0x0b00-0x0b0f] has been reserved
Dec 10 16:03:16.652272 omicron kernel: system 00:04: [io  0x0b20-0x0b3f] has been reserved
Dec 10 16:03:16.652428 omicron kernel: system 00:04: [io  0x0900-0x090f] has been reserved
Dec 10 16:03:16.652579 omicron kernel: system 00:04: [io  0x0910-0x091f] has been reserved
Dec 10 16:03:16.652744 omicron kernel: system 00:04: [mem 0xfec00000-0xfec00fff] could not be reserved
Dec 10 16:03:16.652907 omicron kernel: system 00:04: [mem 0xfec01000-0xfec01fff] could not be reserved
Dec 10 16:03:16.653065 omicron kernel: system 00:04: [mem 0xfedc0000-0xfedc0fff] has been reserved
Dec 10 16:03:16.653216 omicron kernel: system 00:04: [mem 0xfee00000-0xfee00fff] has been reserved
Dec 10 16:03:16.653372 omicron kernel: system 00:04: [mem 0xfed80000-0xfed8ffff] could not be reserved
Dec 10 16:03:16.653528 omicron kernel: system 00:04: [mem 0xfec10000-0xfec10fff] has been reserved
Dec 10 16:03:16.653684 omicron kernel: system 00:04: [mem 0xff000000-0xffffffff] has been reserved
Dec 10 16:03:16.653693 omicron kernel: pnp: PnP ACPI: found 5 devices
Dec 10 16:03:16.653700 omicron kernel: clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
Dec 10 16:03:16.653710 omicron kernel: NET: Registered PF_INET protocol family
Dec 10 16:03:16.653717 omicron kernel: IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
Dec 10 16:03:16.653727 omicron kernel: tcp_listen_portaddr_hash hash table entries: 32768 (order: 7, 524288 bytes, linear)
Dec 10 16:03:16.653736 omicron kernel: Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
Dec 10 16:03:16.653747 omicron kernel: TCP established hash table entries: 524288 (order: 10, 4194304 bytes, linear)
Dec 10 16:03:16.653756 omicron kernel: TCP bind hash table entries: 65536 (order: 9, 2097152 bytes, linear)
Dec 10 16:03:16.653765 omicron kernel: TCP: Hash tables configured (established 524288 bind 65536)
Dec 10 16:03:16.653772 omicron kernel: MPTCP token hash table entries: 65536 (order: 9, 1572864 bytes, linear)
Dec 10 16:03:16.653779 omicron kernel: UDP hash table entries: 32768 (order: 9, 2097152 bytes, linear)
Dec 10 16:03:16.653790 omicron kernel: UDP-Lite hash table entries: 32768 (order: 9, 2097152 bytes, linear)
Dec 10 16:03:16.653797 omicron kernel: NET: Registered PF_UNIX/PF_LOCAL protocol family
Dec 10 16:03:16.653804 omicron kernel: NET: Registered PF_XDP protocol family
Dec 10 16:03:16.653986 omicron kernel: pci 0000:02:04.0: PCI bridge to [bus 03]
Dec 10 16:03:16.654161 omicron kernel: pci 0000:02:04.0:   bridge window [mem 0xfc400000-0xfc4fffff]
Dec 10 16:03:16.654335 omicron kernel: pci 0000:02:08.0: PCI bridge to [bus 04]
Dec 10 16:03:16.654513 omicron kernel: pci 0000:02:08.0:   bridge window [io  0xe000-0xefff]
Dec 10 16:03:16.654687 omicron kernel: pci 0000:02:08.0:   bridge window [mem 0xfc300000-0xfc3fffff]
Dec 10 16:03:16.654860 omicron kernel: pci 0000:02:09.0: PCI bridge to [bus 05]
Dec 10 16:03:16.655038 omicron kernel: pci 0000:02:09.0:   bridge window [io  0xd000-0xdfff]
Dec 10 16:03:16.655213 omicron kernel: pci 0000:02:09.0:   bridge window [mem 0xfc200000-0xfc2fffff]
Dec 10 16:03:16.655379 omicron kernel: pci 0000:01:00.2: PCI bridge to [bus 02-05]
Dec 10 16:03:16.655545 omicron kernel: pci 0000:01:00.2:   bridge window [io  0xd000-0xefff]
Dec 10 16:03:16.655712 omicron kernel: pci 0000:01:00.2:   bridge window [mem 0xfc200000-0xfc4fffff]
Dec 10 16:03:16.655871 omicron kernel: pci 0000:00:01.2: PCI bridge to [bus 01-05]
Dec 10 16:03:16.656042 omicron kernel: pci 0000:00:01.2:   bridge window [io  0xd000-0xefff]
Dec 10 16:03:16.656210 omicron kernel: pci 0000:00:01.2:   bridge window [mem 0xfc200000-0xfc5fffff]
Dec 10 16:03:16.656377 omicron kernel: pci 0000:00:03.1: PCI bridge to [bus 06]
Dec 10 16:03:16.656539 omicron kernel: pci 0000:00:03.1:   bridge window [io  0xf000-0xffff]
Dec 10 16:03:16.656701 omicron kernel: pci 0000:00:03.1:   bridge window [mem 0xfb000000-0xfc0fffff]
Dec 10 16:03:16.656861 omicron kernel: pci 0000:00:03.1:   bridge window [mem 0xd0000000-0xe20fffff 64bit pref]
Dec 10 16:03:16.657027 omicron kernel: pci 0000:00:07.1: PCI bridge to [bus 07]
Dec 10 16:03:16.657186 omicron kernel: pci 0000:00:08.1: PCI bridge to [bus 08]
Dec 10 16:03:16.657344 omicron kernel: pci 0000:00:08.1:   bridge window [mem 0xfc600000-0xfc8fffff]
Dec 10 16:03:16.657501 omicron kernel: pci 0000:00:08.3: PCI bridge to [bus 09]
Dec 10 16:03:16.657659 omicron kernel: pci 0000:00:08.3:   bridge window [mem 0xfc900000-0xfc9fffff]
Dec 10 16:03:16.657813 omicron kernel: pci_bus 0000:00: resource 4 [io  0x0000-0x03af window]
Dec 10 16:03:16.657976 omicron kernel: pci_bus 0000:00: resource 5 [io  0x03e0-0x0cf7 window]
Dec 10 16:03:16.658128 omicron kernel: pci_bus 0000:00: resource 6 [io  0x03b0-0x03df window]
Dec 10 16:03:16.658279 omicron kernel: pci_bus 0000:00: resource 7 [io  0x0d00-0xffff window]
Dec 10 16:03:16.658435 omicron kernel: pci_bus 0000:00: resource 8 [mem 0x000a0000-0x000dffff window]
Dec 10 16:03:16.658589 omicron kernel: pci_bus 0000:00: resource 9 [mem 0xc0000000-0xfec2ffff window]
Dec 10 16:03:16.658740 omicron kernel: pci_bus 0000:00: resource 10 [mem 0xfee00000-0xffffffff window]
Dec 10 16:03:16.658906 omicron kernel: pci_bus 0000:01: resource 0 [io  0xd000-0xefff]
Dec 10 16:03:16.659073 omicron kernel: pci_bus 0000:01: resource 1 [mem 0xfc200000-0xfc5fffff]
Dec 10 16:03:16.659249 omicron kernel: pci_bus 0000:02: resource 0 [io  0xd000-0xefff]
Dec 10 16:03:16.659423 omicron kernel: pci_bus 0000:02: resource 1 [mem 0xfc200000-0xfc4fffff]
Dec 10 16:03:16.659604 omicron kernel: pci_bus 0000:03: resource 1 [mem 0xfc400000-0xfc4fffff]
Dec 10 16:03:16.659787 omicron kernel: pci_bus 0000:04: resource 0 [io  0xe000-0xefff]
Dec 10 16:03:16.659974 omicron kernel: pci_bus 0000:04: resource 1 [mem 0xfc300000-0xfc3fffff]
Dec 10 16:03:16.660156 omicron kernel: pci_bus 0000:05: resource 0 [io  0xd000-0xdfff]
Dec 10 16:03:16.660336 omicron kernel: pci_bus 0000:05: resource 1 [mem 0xfc200000-0xfc2fffff]
Dec 10 16:03:16.660501 omicron kernel: pci_bus 0000:06: resource 0 [io  0xf000-0xffff]
Dec 10 16:03:16.660660 omicron kernel: pci_bus 0000:06: resource 1 [mem 0xfb000000-0xfc0fffff]
Dec 10 16:03:16.660818 omicron kernel: pci_bus 0000:06: resource 2 [mem 0xd0000000-0xe20fffff 64bit pref]
Dec 10 16:03:16.660989 omicron kernel: pci_bus 0000:08: resource 1 [mem 0xfc600000-0xfc8fffff]
Dec 10 16:03:16.661150 omicron kernel: pci_bus 0000:09: resource 1 [mem 0xfc900000-0xfc9fffff]
Dec 10 16:03:16.661322 omicron kernel: pci 0000:06:00.1: extending delay after power-on from D3hot to 20 msec
Dec 10 16:03:16.661497 omicron kernel: pci 0000:06:00.1: D0 power state depends on 0000:06:00.0
Dec 10 16:03:16.661670 omicron kernel: pci 0000:06:00.2: D0 power state depends on 0000:06:00.0
Dec 10 16:03:16.661836 omicron kernel: pci 0000:06:00.3: D0 power state depends on 0000:06:00.0
Dec 10 16:03:16.661845 omicron kernel: PCI: CLS 64 bytes, default 64
Dec 10 16:03:16.662008 omicron kernel: pci 0000:00:00.2: AMD-Vi: IOMMU performance counters supported
Dec 10 16:03:16.662021 omicron kernel: Trying to unpack rootfs image as initramfs...
Dec 10 16:03:16.662181 omicron kernel: pci 0000:00:01.0: Adding to iommu group 0
Dec 10 16:03:16.662344 omicron kernel: pci 0000:00:01.2: Adding to iommu group 1
Dec 10 16:03:16.662506 omicron kernel: pci 0000:00:02.0: Adding to iommu group 2
Dec 10 16:03:16.662664 omicron kernel: pci 0000:00:03.0: Adding to iommu group 3
Dec 10 16:03:16.662827 omicron kernel: pci 0000:00:03.1: Adding to iommu group 4
Dec 10 16:03:16.663017 omicron kernel: pci 0000:00:04.0: Adding to iommu group 5
Dec 10 16:03:16.663181 omicron kernel: pci 0000:00:05.0: Adding to iommu group 6
Dec 10 16:03:16.663339 omicron kernel: pci 0000:00:07.0: Adding to iommu group 7
Dec 10 16:03:16.663497 omicron kernel: pci 0000:00:07.1: Adding to iommu group 8
Dec 10 16:03:16.663659 omicron kernel: pci 0000:00:08.0: Adding to iommu group 9
Dec 10 16:03:16.663820 omicron kernel: pci 0000:00:08.1: Adding to iommu group 10
Dec 10 16:03:16.663985 omicron kernel: pci 0000:00:08.3: Adding to iommu group 11
Dec 10 16:03:16.664147 omicron kernel: pci 0000:00:14.0: Adding to iommu group 12
Dec 10 16:03:16.664308 omicron kernel: pci 0000:00:14.3: Adding to iommu group 12
Dec 10 16:03:16.664469 omicron kernel: pci 0000:00:18.0: Adding to iommu group 13
Dec 10 16:03:16.664628 omicron kernel: pci 0000:00:18.1: Adding to iommu group 13
Dec 10 16:03:16.664788 omicron kernel: pci 0000:00:18.2: Adding to iommu group 13
Dec 10 16:03:16.664950 omicron kernel: pci 0000:00:18.3: Adding to iommu group 13
Dec 10 16:03:16.665114 omicron kernel: pci 0000:00:18.4: Adding to iommu group 13
Dec 10 16:03:16.665272 omicron kernel: pci 0000:00:18.5: Adding to iommu group 13
Dec 10 16:03:16.665429 omicron kernel: pci 0000:00:18.6: Adding to iommu group 13
Dec 10 16:03:16.665588 omicron kernel: pci 0000:00:18.7: Adding to iommu group 13
Dec 10 16:03:16.665754 omicron kernel: pci 0000:01:00.0: Adding to iommu group 14
Dec 10 16:03:16.665930 omicron kernel: pci 0000:01:00.1: Adding to iommu group 14
Dec 10 16:03:16.666104 omicron kernel: pci 0000:01:00.2: Adding to iommu group 14
Dec 10 16:03:16.666287 omicron kernel: pci 0000:02:04.0: Adding to iommu group 14
Dec 10 16:03:16.666460 omicron kernel: pci 0000:02:08.0: Adding to iommu group 14
Dec 10 16:03:16.666638 omicron kernel: pci 0000:02:09.0: Adding to iommu group 14
Dec 10 16:03:16.666825 omicron kernel: pci 0000:03:00.0: Adding to iommu group 14
Dec 10 16:03:16.667011 omicron kernel: pci 0000:04:00.0: Adding to iommu group 14
Dec 10 16:03:16.667192 omicron kernel: pci 0000:05:00.0: Adding to iommu group 14
Dec 10 16:03:16.667357 omicron kernel: pci 0000:06:00.0: Adding to iommu group 15
Dec 10 16:03:16.667522 omicron kernel: pci 0000:06:00.1: Adding to iommu group 15
Dec 10 16:03:16.667687 omicron kernel: pci 0000:06:00.2: Adding to iommu group 15
Dec 10 16:03:16.667862 omicron kernel: pci 0000:06:00.3: Adding to iommu group 15
Dec 10 16:03:16.668036 omicron kernel: pci 0000:07:00.0: Adding to iommu group 16
Dec 10 16:03:16.668205 omicron kernel: pci 0000:08:00.0: Adding to iommu group 17
Dec 10 16:03:16.668371 omicron kernel: pci 0000:08:00.1: Adding to iommu group 18
Dec 10 16:03:16.668538 omicron kernel: pci 0000:08:00.3: Adding to iommu group 19
Dec 10 16:03:16.668703 omicron kernel: pci 0000:08:00.4: Adding to iommu group 20
Dec 10 16:03:16.668869 omicron kernel: pci 0000:09:00.0: Adding to iommu group 21
Dec 10 16:03:16.668882 omicron kernel: AMD-Vi: Extended features (0x58f77ef22294a5a, 0x0): PPR NX GT IA PC GA_vAPIC
Dec 10 16:03:16.668897 omicron kernel: AMD-Vi: Interrupt remapping enabled
Dec 10 16:03:16.668907 omicron kernel: PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
Dec 10 16:03:16.668914 omicron kernel: software IO TLB: mapped [mem 0x00000000b1fe3000-0x00000000b5fe3000] (64MB)
Dec 10 16:03:16.668921 omicron kernel: LVT offset 0 assigned for vector 0x400
Dec 10 16:03:16.668928 omicron kernel: perf: AMD IBS detected (0x000003ff)
Dec 10 16:03:16.668935 omicron kernel: perf/amd_iommu: Detected AMD IOMMU #0 (2 banks, 4 counters/bank).
Dec 10 16:03:16.668943 omicron kernel: Initialise system trusted keyrings
Dec 10 16:03:16.668949 omicron kernel: Key type blacklist registered
Dec 10 16:03:16.668959 omicron kernel: workingset: timestamp_bits=36 max_order=24 bucket_order=0
Dec 10 16:03:16.668968 omicron kernel: fuse: init (API version 7.45)
Dec 10 16:03:16.668975 omicron kernel: integrity: Platform Keyring initialized
Dec 10 16:03:16.668982 omicron kernel: integrity: Machine keyring initialized
Dec 10 16:03:16.668989 omicron kernel: xor: automatically using best checksumming function   avx
Dec 10 16:03:16.668996 omicron kernel: Key type asymmetric registered
Dec 10 16:03:16.669003 omicron kernel: Asymmetric key parser 'x509' registered
Dec 10 16:03:16.669010 omicron kernel: Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
Dec 10 16:03:16.669017 omicron kernel: io scheduler mq-deadline registered
Dec 10 16:03:16.669024 omicron kernel: io scheduler kyber registered
Dec 10 16:03:16.669034 omicron kernel: io scheduler bfq registered
Dec 10 16:03:16.669041 omicron kernel: ledtrig-cpu: registered to indicate activity on CPUs
Dec 10 16:03:16.669204 omicron kernel: pcieport 0000:00:01.2: PME: Signaling with IRQ 27
Dec 10 16:03:16.669367 omicron kernel: pcieport 0000:00:03.1: PME: Signaling with IRQ 28
Dec 10 16:03:16.669530 omicron kernel: pcieport 0000:00:07.1: PME: Signaling with IRQ 30
Dec 10 16:03:16.669693 omicron kernel: pcieport 0000:00:07.1: AER: enabled with IRQ 30
Dec 10 16:03:16.669853 omicron kernel: pcieport 0000:00:08.1: PME: Signaling with IRQ 31
Dec 10 16:03:16.670017 omicron kernel: pcieport 0000:00:08.1: AER: enabled with IRQ 31
Dec 10 16:03:16.670175 omicron kernel: pcieport 0000:00:08.3: PME: Signaling with IRQ 32
Dec 10 16:03:16.670339 omicron kernel: pcieport 0000:00:08.3: AER: enabled with IRQ 32
Dec 10 16:03:16.670348 omicron kernel: input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0
Dec 10 16:03:16.670359 omicron kernel: ACPI: button: Power Button [PWRB]
Dec 10 16:03:16.670366 omicron kernel: input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input1
Dec 10 16:03:16.670373 omicron kernel: ACPI: button: Power Button [PWRF]
Dec 10 16:03:16.670380 omicron kernel: Could not retrieve perf counters (-19)
Dec 10 16:03:16.670387 omicron kernel: Freeing initrd memory: 130708K
Dec 10 16:03:16.670396 omicron kernel: tsc: Refined TSC clocksource calibration: 2994.379 MHz
Dec 10 16:03:16.670404 omicron kernel: clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x2b29878afe4, max_idle_ns: 440795254686 ns
Dec 10 16:03:16.670413 omicron kernel: clocksource: Switched to clocksource tsc
Dec 10 16:03:16.670421 omicron kernel: ACPI: \_TZ_.TZ10: _PSL evaluation failure
Dec 10 16:03:16.670595 omicron kernel: thermal LNXTHERM:00: registered as thermal_zone0
Dec 10 16:03:16.670605 omicron kernel: ACPI: thermal: Thermal Zone [TZ10] (17 C)
Dec 10 16:03:16.670616 omicron kernel: ACPI: \_TZ_.UAD0: _PSL evaluation failure
Dec 10 16:03:16.670785 omicron kernel: thermal LNXTHERM:01: registered as thermal_zone1
Dec 10 16:03:16.670795 omicron kernel: ACPI: thermal: Thermal Zone [UAD0] (17 C)
Dec 10 16:03:16.670807 omicron kernel: Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
Dec 10 16:03:16.670816 omicron kernel: Non-volatile memory driver v1.3
Dec 10 16:03:16.670827 omicron kernel: Linux agpgart interface v0.103
Dec 10 16:03:16.671079 omicron kernel: tpm_crb MSFT0101:00: Disabling hwrng
Dec 10 16:03:16.671129 omicron kernel: ACPI: bus type drm_connector registered
Dec 10 16:03:16.671340 omicron kernel: ahci 0000:01:00.1: SSS flag set, parallel bus scan disabled
Dec 10 16:03:16.671572 omicron kernel: ahci 0000:01:00.1: AHCI vers 0001.0301, 32 command slots, 6 Gbps, SATA mode
Dec 10 16:03:16.671739 omicron kernel: ahci 0000:01:00.1: 6/6 ports implemented (port mask 0x3f)
Dec 10 16:03:16.671944 omicron kernel: ahci 0000:01:00.1: flags: 64bit ncq sntf stag pm led clo only pmp pio slum part sxs deso sadm sds apst
Dec 10 16:03:16.672155 omicron kernel: scsi host0: ahci
Dec 10 16:03:16.672334 omicron kernel: scsi host1: ahci
Dec 10 16:03:16.672513 omicron kernel: scsi host2: ahci
Dec 10 16:03:16.672688 omicron kernel: scsi host3: ahci
Dec 10 16:03:16.672864 omicron kernel: scsi host4: ahci
Dec 10 16:03:16.673072 omicron kernel: scsi host5: ahci
Dec 10 16:03:16.673137 omicron kernel: ata1: SATA max UDMA/133 abar m131072@0xfc580000 port 0xfc580100 irq 39 lpm-pol 1 ext
Dec 10 16:03:16.673151 omicron kernel: ata2: SATA max UDMA/133 abar m131072@0xfc580000 port 0xfc580180 irq 39 lpm-pol 1 ext
Dec 10 16:03:16.673166 omicron kernel: ata3: SATA max UDMA/133 abar m131072@0xfc580000 port 0xfc580200 irq 39 lpm-pol 1 ext
Dec 10 16:03:16.673175 omicron kernel: ata4: SATA max UDMA/133 abar m131072@0xfc580000 port 0xfc580280 irq 39 lpm-pol 1 ext
Dec 10 16:03:16.673182 omicron kernel: ata5: SATA max UDMA/133 abar m131072@0xfc580000 port 0xfc580300 irq 39 lpm-pol 1 ext
Dec 10 16:03:16.673197 omicron kernel: ata6: SATA max UDMA/133 abar m131072@0xfc580000 port 0xfc580380 irq 39 lpm-pol 1 ext
Dec 10 16:03:16.673542 omicron kernel: ahci 0000:09:00.0: AHCI vers 0001.0301, 32 command slots, 6 Gbps, SATA mode
Dec 10 16:03:16.673763 omicron kernel: ahci 0000:09:00.0: 1/1 ports implemented (port mask 0x20)
Dec 10 16:03:16.673957 omicron kernel: ahci 0000:09:00.0: flags: 64bit ncq sntf ilck pm led clo only pmp fbs pio slum part
Dec 10 16:03:16.674139 omicron kernel: scsi host6: ahci
Dec 10 16:03:16.674321 omicron kernel: scsi host7: ahci
Dec 10 16:03:16.674514 omicron kernel: scsi host8: ahci
Dec 10 16:03:16.674701 omicron kernel: scsi host9: ahci
Dec 10 16:03:16.674884 omicron kernel: scsi host10: ahci
Dec 10 16:03:16.675074 omicron kernel: scsi host11: ahci
Dec 10 16:03:16.675085 omicron kernel: ata7: DUMMY
Dec 10 16:03:16.675092 omicron kernel: ata8: DUMMY
Dec 10 16:03:16.675099 omicron kernel: ata9: DUMMY
Dec 10 16:03:16.675109 omicron kernel: ata10: DUMMY
Dec 10 16:03:16.675116 omicron kernel: ata11: DUMMY
Dec 10 16:03:16.675125 omicron kernel: ata12: SATA max UDMA/133 abar m2048@0xfc900000 port 0xfc900380 irq 46 lpm-pol 3
Dec 10 16:03:16.675291 omicron kernel: xhci_hcd 0000:01:00.0: xHCI Host Controller
Dec 10 16:03:16.675462 omicron kernel: xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
Dec 10 16:03:16.675632 omicron kernel: xhci_hcd 0000:01:00.0: hcc params 0x0200ef81 hci version 0x110 quirks 0x0000000000000010
Dec 10 16:03:16.675803 omicron kernel: xhci_hcd 0000:01:00.0: xHCI Host Controller
Dec 10 16:03:16.675977 omicron kernel: xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
Dec 10 16:03:16.676143 omicron kernel: xhci_hcd 0000:01:00.0: Host supports USB 3.1 Enhanced SuperSpeed
Dec 10 16:03:16.676287 omicron kernel: usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.18
Dec 10 16:03:16.676428 omicron kernel: usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Dec 10 16:03:16.676565 omicron kernel: usb usb1: Product: xHCI Host Controller
Dec 10 16:03:16.676706 omicron kernel: usb usb1: Manufacturer: Linux 6.18.0-1-MANJARO xhci-hcd
Dec 10 16:03:16.676840 omicron kernel: usb usb1: SerialNumber: 0000:01:00.0
Dec 10 16:03:16.677034 omicron kernel: hub 1-0:1.0: USB hub found
Dec 10 16:03:16.677220 omicron kernel: hub 1-0:1.0: 10 ports detected
Dec 10 16:03:16.677405 omicron kernel: usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
Dec 10 16:03:16.677547 omicron kernel: usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.18
Dec 10 16:03:16.677687 omicron kernel: usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Dec 10 16:03:16.677819 omicron kernel: usb usb2: Product: xHCI Host Controller
Dec 10 16:03:16.677962 omicron kernel: usb usb2: Manufacturer: Linux 6.18.0-1-MANJARO xhci-hcd
Dec 10 16:03:16.678100 omicron kernel: usb usb2: SerialNumber: 0000:01:00.0
Dec 10 16:03:16.678289 omicron kernel: hub 2-0:1.0: USB hub found
Dec 10 16:03:16.678472 omicron kernel: hub 2-0:1.0: 4 ports detected
Dec 10 16:03:16.678638 omicron kernel: xhci_hcd 0000:06:00.2: xHCI Host Controller
Dec 10 16:03:16.678804 omicron kernel: xhci_hcd 0000:06:00.2: new USB bus registered, assigned bus number 3
Dec 10 16:03:16.678984 omicron kernel: xhci_hcd 0000:06:00.2: hcc params 0x0180ff05 hci version 0x110 quirks 0x0000000000000010
Dec 10 16:03:16.679151 omicron kernel: xhci_hcd 0000:06:00.2: xHCI Host Controller
Dec 10 16:03:16.679317 omicron kernel: xhci_hcd 0000:06:00.2: new USB bus registered, assigned bus number 4
Dec 10 16:03:16.679487 omicron kernel: xhci_hcd 0000:06:00.2: Host supports USB 3.1 Enhanced SuperSpeed
Dec 10 16:03:16.679625 omicron kernel: usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.18
Dec 10 16:03:16.679764 omicron kernel: usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Dec 10 16:03:16.679901 omicron kernel: usb usb3: Product: xHCI Host Controller
Dec 10 16:03:16.680045 omicron kernel: usb usb3: Manufacturer: Linux 6.18.0-1-MANJARO xhci-hcd
Dec 10 16:03:16.680181 omicron kernel: usb usb3: SerialNumber: 0000:06:00.2
Dec 10 16:03:16.680367 omicron kernel: hub 3-0:1.0: USB hub found
Dec 10 16:03:16.680559 omicron kernel: hub 3-0:1.0: 2 ports detected
Dec 10 16:03:16.680738 omicron kernel: usb usb4: We don't know the algorithms for LPM for this host, disabling LPM.
Dec 10 16:03:16.680878 omicron kernel: usb usb4: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.18
Dec 10 16:03:16.681017 omicron kernel: usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Dec 10 16:03:16.681157 omicron kernel: usb usb4: Product: xHCI Host Controller
Dec 10 16:03:16.681294 omicron kernel: usb usb4: Manufacturer: Linux 6.18.0-1-MANJARO xhci-hcd
Dec 10 16:03:16.681425 omicron kernel: usb usb4: SerialNumber: 0000:06:00.2
Dec 10 16:03:16.681613 omicron kernel: hub 4-0:1.0: USB hub found
Dec 10 16:03:16.681804 omicron kernel: hub 4-0:1.0: 4 ports detected
Dec 10 16:03:16.681978 omicron kernel: xhci_hcd 0000:08:00.3: xHCI Host Controller
Dec 10 16:03:16.682157 omicron kernel: xhci_hcd 0000:08:00.3: new USB bus registered, assigned bus number 5
Dec 10 16:03:16.682329 omicron kernel: xhci_hcd 0000:08:00.3: hcc params 0x0278ffe5 hci version 0x110 quirks 0x0000000000000010
Dec 10 16:03:16.682500 omicron kernel: xhci_hcd 0000:08:00.3: xHCI Host Controller
Dec 10 16:03:16.682668 omicron kernel: xhci_hcd 0000:08:00.3: new USB bus registered, assigned bus number 6
Dec 10 16:03:16.682835 omicron kernel: xhci_hcd 0000:08:00.3: Host supports USB 3.1 Enhanced SuperSpeed
Dec 10 16:03:16.682987 omicron kernel: usb usb5: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.18
Dec 10 16:03:16.683127 omicron kernel: usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Dec 10 16:03:16.683259 omicron kernel: usb usb5: Product: xHCI Host Controller
Dec 10 16:03:16.683390 omicron kernel: usb usb5: Manufacturer: Linux 6.18.0-1-MANJARO xhci-hcd
Dec 10 16:03:16.683528 omicron kernel: usb usb5: SerialNumber: 0000:08:00.3
Dec 10 16:03:16.683717 omicron kernel: hub 5-0:1.0: USB hub found
Dec 10 16:03:16.683906 omicron kernel: hub 5-0:1.0: 4 ports detected
Dec 10 16:03:16.684087 omicron kernel: usb usb6: We don't know the algorithms for LPM for this host, disabling LPM.
Dec 10 16:03:16.684222 omicron kernel: usb usb6: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.18
Dec 10 16:03:16.684355 omicron kernel: usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Dec 10 16:03:16.684492 omicron kernel: usb usb6: Product: xHCI Host Controller
Dec 10 16:03:16.684623 omicron kernel: usb usb6: Manufacturer: Linux 6.18.0-1-MANJARO xhci-hcd
Dec 10 16:03:16.684755 omicron kernel: usb usb6: SerialNumber: 0000:08:00.3
Dec 10 16:03:16.684944 omicron kernel: hub 6-0:1.0: USB hub found
Dec 10 16:03:16.685135 omicron kernel: hub 6-0:1.0: 4 ports detected
Dec 10 16:03:16.685148 omicron kernel: usbcore: registered new interface driver usbserial_generic
Dec 10 16:03:16.685155 omicron kernel: usbserial: USB Serial support registered for generic
Dec 10 16:03:16.685162 omicron kernel: i8042: PNP: No PS/2 controller found.
Dec 10 16:03:16.685319 omicron kernel: rtc_cmos 00:02: RTC can wake from S4
Dec 10 16:03:16.685474 omicron kernel: rtc_cmos 00:02: registered as rtc0
Dec 10 16:03:16.685626 omicron kernel: rtc_cmos 00:02: setting system clock to 2025-12-10T21:03:12 UTC (1765400592)
Dec 10 16:03:16.685779 omicron kernel: rtc_cmos 00:02: alarms up to one month, y3k, 114 bytes nvram
Dec 10 16:03:16.685789 omicron kernel: amd_pstate: the _CPC object is not present in SBIOS or ACPI disabled
Dec 10 16:03:16.685796 omicron kernel: Relocating firmware framebuffer to offset 0x0000000001000000[d] within [mem 0xe0000000-0xe1ffffff flags 0x14220c]
Dec 10 16:03:16.685979 omicron kernel: simple-framebuffer simple-framebuffer.0: [drm] Registered 1 planes with drm panic
Dec 10 16:03:16.685995 omicron kernel: [drm] Initialized simpledrm 1.0.0 for simple-framebuffer.0 on minor 0
Dec 10 16:03:16.686002 omicron kernel: fbcon: Deferring console take-over
Dec 10 16:03:16.686171 omicron kernel: simple-framebuffer simple-framebuffer.0: [drm] fb0: simpledrmdrmfb frame buffer device
Dec 10 16:03:16.686184 omicron kernel: hid: raw HID events driver (C) Jiri Kosina
Dec 10 16:03:16.686191 omicron kernel: usbcore: registered new interface driver usbhid
Dec 10 16:03:16.686198 omicron kernel: usbhid: USB HID core driver
Dec 10 16:03:16.686207 omicron kernel: drop_monitor: Initializing network drop monitor service
Dec 10 16:03:16.686216 omicron kernel: NET: Registered PF_INET6 protocol family
Dec 10 16:03:16.686223 omicron kernel: Segment Routing with IPv6
Dec 10 16:03:16.686232 omicron kernel: RPL Segment Routing with IPv6
Dec 10 16:03:16.686241 omicron kernel: In-situ OAM (IOAM) with IPv6
Dec 10 16:03:16.686248 omicron kernel: NET: Registered PF_PACKET protocol family
Dec 10 16:03:16.686255 omicron kernel: x86/amd: Previous system reset reason [0x00010800]: system reset pin BP_SYS_RST_L was tripped
Dec 10 16:03:16.686262 omicron kernel: microcode: Current revision: 0x0a201211
Dec 10 16:03:16.686271 omicron kernel: microcode: Updated early from: 0x0a201210
Dec 10 16:03:16.686280 omicron kernel: resctrl: L3 allocation detected
Dec 10 16:03:16.686289 omicron kernel: resctrl: MB allocation detected
Dec 10 16:03:16.686296 omicron kernel: resctrl: L3 monitoring detected
Dec 10 16:03:16.686304 omicron kernel: IPI shorthand broadcast: enabled
Dec 10 16:03:16.686311 omicron kernel: sched_clock: Marking stable (2698001211, 629266240)->(3344381777, -17114326)
Dec 10 16:03:16.686318 omicron kernel: registered taskstats version 1
Dec 10 16:03:16.686325 omicron kernel: Loading compiled-in X.509 certificates
Dec 10 16:03:16.686333 omicron kernel: Loaded X.509 cert 'Build time autogenerated kernel key: ce56ceb3df2455334b6b85e2fbaa9454cac66fba'
Dec 10 16:03:16.686342 omicron kernel: zswap: loaded using pool zstd
Dec 10 16:03:16.686348 omicron kernel: Demotion targets for Node 0: null
Dec 10 16:03:16.686356 omicron kernel: Key type .fscrypt registered
Dec 10 16:03:16.686364 omicron kernel: Key type fscrypt-provisioning registered
Dec 10 16:03:16.686371 omicron kernel: Btrfs loaded, zoned=yes, fsverity=yes
Dec 10 16:03:16.686378 omicron kernel: Key type big_key registered
Dec 10 16:03:16.686385 omicron kernel: PM:   Magic number: 5:530:95
Dec 10 16:03:16.686392 omicron kernel: RAS: Correctable Errors collector initialized.
Dec 10 16:03:16.686399 omicron kernel: clk: Disabling unused clocks
Dec 10 16:03:16.686406 omicron kernel: PM: genpd: Disabling unused power domains
Dec 10 16:03:16.686596 omicron kernel: usb 1-5: new full-speed USB device number 2 using xhci_hcd
Dec 10 16:03:16.686783 omicron kernel: usb 5-1: new low-speed USB device number 2 using xhci_hcd
Dec 10 16:03:16.686940 omicron kernel: usb 5-1: New USB device found, idVendor=17ef, idProduct=60a1, bcdDevice= 1.02
Dec 10 16:03:16.687082 omicron kernel: usb 5-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Dec 10 16:03:16.687221 omicron kernel: usb 5-1: Product: Lenovo Essential Wired Combo
Dec 10 16:03:16.687366 omicron kernel: usb 5-1: Manufacturer: LiteOn
Dec 10 16:03:16.687375 omicron kernel: ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
Dec 10 16:03:16.687383 omicron kernel: ata12: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
Dec 10 16:03:16.687390 omicron kernel: ata1.00: Model 'Samsung SSD 860 EVO 500GB', rev 'RVT01B6Q', applying quirks: noncqtrim zeroaftertrim noncqonati nolpmonati
Dec 10 16:03:16.687400 omicron kernel: ata1.00: supports DRM functions and may not be fully accessible
Dec 10 16:03:16.687407 omicron kernel: ata1.00: ATA-11: Samsung SSD 860 EVO 500GB, RVT01B6Q, max UDMA/133
Dec 10 16:03:16.687414 omicron kernel: ata12.00: supports DRM functions and may not be fully accessible
Dec 10 16:03:16.687421 omicron kernel: ata12.00: ATA-10: CT1000MX500SSD4, M3CR023, max UDMA/133
Dec 10 16:03:16.687428 omicron kernel: ata12.00: 1953525168 sectors, multi 1: LBA48 NCQ (depth 32), AA
Dec 10 16:03:16.687435 omicron kernel: ata1.00: 976773168 sectors, multi 1: LBA48 NCQ (depth 32), AA
Dec 10 16:03:16.687442 omicron kernel: ata12.00: Features: Trust Dev-Sleep DIPM
Dec 10 16:03:16.687449 omicron kernel: ata12.00: supports DRM functions and may not be fully accessible
Dec 10 16:03:16.687456 omicron kernel: ata12.00: configured for UDMA/133
Dec 10 16:03:16.687464 omicron kernel: ata1.00: Features: Trust Dev-Sleep DIPM NCQ-sndrcv
Dec 10 16:03:16.687471 omicron kernel: ata1.00: supports DRM functions and may not be fully accessible
Dec 10 16:03:16.687478 omicron kernel: ata1.00: configured for UDMA/133
Dec 10 16:03:16.687485 omicron kernel: input: LiteOn Lenovo Essential Wired Combo as /devices/pci0000:00/0000:00:08.1/0000:08:00.3/usb5/5-1/5-1:1.0/0003:17EF:60A1.0001/input/input2
Dec 10 16:03:16.687653 omicron kernel: ahci 0000:01:00.1: port does not support device sleep
Dec 10 16:03:16.687856 omicron kernel: scsi 0:0:0:0: Direct-Access     ATA      Samsung SSD 860  1B6Q PQ: 0 ANSI: 5
Dec 10 16:03:16.687866 omicron kernel: ata1.00: Enabling discard_zeroes_data
Dec 10 16:03:16.688068 omicron kernel: sd 0:0:0:0: [sda] 976773168 512-byte logical blocks: (500 GB/466 GiB)
Dec 10 16:03:16.688268 omicron kernel: sd 0:0:0:0: [sda] Write Protect is off
Dec 10 16:03:16.688461 omicron kernel: sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
Dec 10 16:03:16.688654 omicron kernel: sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
Dec 10 16:03:16.688847 omicron kernel: sd 0:0:0:0: [sda] Preferred minimum I/O size 512 bytes
Dec 10 16:03:16.688860 omicron kernel: ata1.00: Enabling discard_zeroes_data
Dec 10 16:03:16.688867 omicron kernel:  sda: sda1 sda2
Dec 10 16:03:16.689065 omicron kernel: sd 0:0:0:0: [sda] supports TCG Opal
Dec 10 16:03:16.689262 omicron kernel: sd 0:0:0:0: [sda] Attached SCSI disk
Dec 10 16:03:16.689471 omicron kernel: hid-generic 0003:17EF:60A1.0001: input,hidraw0: USB HID v1.11 Keyboard [LiteOn Lenovo Essential Wired Combo] on usb-0000:08:00.3-1/input0
Dec 10 16:03:16.689485 omicron kernel: input: LiteOn Lenovo Essential Wired Combo System Control as /devices/pci0000:00/0000:00:08.1/0000:08:00.3/usb5/5-1/5-1:1.1/0003:17EF:60A1.0002/input/input3
Dec 10 16:03:16.689672 omicron kernel: usb 6-4: new SuperSpeed USB device number 2 using xhci_hcd
Dec 10 16:03:16.689825 omicron kernel: usb 6-4: New USB device found, idVendor=05e3, idProduct=0626, bcdDevice= 6.54
Dec 10 16:03:16.689974 omicron kernel: usb 6-4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Dec 10 16:03:16.690115 omicron kernel: usb 6-4: Product: USB3.1 Hub
Dec 10 16:03:16.690258 omicron kernel: usb 6-4: Manufacturer: GenesysLogic
Dec 10 16:03:16.690450 omicron kernel: hub 6-4:1.0: USB hub found
Dec 10 16:03:16.690645 omicron kernel: hub 6-4:1.0: 4 ports detected
Dec 10 16:03:16.690788 omicron kernel: usb 1-5: New USB device found, idVendor=0bda, idProduct=b850, bcdDevice= 0.00
Dec 10 16:03:16.690934 omicron kernel: usb 1-5: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Dec 10 16:03:16.691075 omicron kernel: usb 1-5: Product: Bluetooth Radio
Dec 10 16:03:16.691214 omicron kernel: usb 1-5: Manufacturer: Realtek
Dec 10 16:03:16.691356 omicron kernel: usb 1-5: SerialNumber: 00e04c000001
Dec 10 16:03:16.691370 omicron kernel: input: LiteOn Lenovo Essential Wired Combo Consumer Control as /devices/pci0000:00/0000:00:08.1/0000:08:00.3/usb5/5-1/5-1:1.1/0003:17EF:60A1.0002/input/input4
Dec 10 16:03:16.691570 omicron kernel: hid-generic 0003:17EF:60A1.0002: input,hidraw1: USB HID v1.11 Device [LiteOn Lenovo Essential Wired Combo] on usb-0000:08:00.3-1/input1
Dec 10 16:03:16.691761 omicron kernel: usb 5-2: new full-speed USB device number 3 using xhci_hcd
Dec 10 16:03:16.691971 omicron kernel: usb 1-6: new high-speed USB device number 3 using xhci_hcd
Dec 10 16:03:16.691982 omicron kernel: ata2: SATA link down (SStatus 0 SControl 300)
Dec 10 16:03:16.692132 omicron kernel: usb 5-2: New USB device found, idVendor=28de, idProduct=1142, bcdDevice= 0.01
Dec 10 16:03:16.692279 omicron kernel: usb 5-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Dec 10 16:03:16.692419 omicron kernel: usb 5-2: Product: Steam Controller
Dec 10 16:03:16.692558 omicron kernel: usb 5-2: Manufacturer: Valve Software
Dec 10 16:03:16.692571 omicron kernel: input: Valve Software Steam Controller Keyboard as /devices/pci0000:00/0000:00:08.1/0000:08:00.3/usb5/5-2/5-2:1.0/0003:28DE:1142.0003/input/input5
Dec 10 16:03:16.692581 omicron kernel: input: Valve Software Steam Controller Mouse as /devices/pci0000:00/0000:00:08.1/0000:08:00.3/usb5/5-2/5-2:1.0/0003:28DE:1142.0003/input/input6
Dec 10 16:03:16.692781 omicron kernel: hid-generic 0003:28DE:1142.0003: input,hidraw2: USB HID v1.11 Keyboard [Valve Software Steam Controller] on usb-0000:08:00.3-2/input0
Dec 10 16:03:16.693004 omicron kernel: hid-generic 0003:28DE:1142.0004: hiddev96,hidraw3: USB HID v1.11 Device [Valve Software Steam Controller] on usb-0000:08:00.3-2/input1
Dec 10 16:03:16.693208 omicron kernel: hid-generic 0003:28DE:1142.0005: hiddev97,hidraw4: USB HID v1.11 Device [Valve Software Steam Controller] on usb-0000:08:00.3-2/input2
Dec 10 16:03:16.693408 omicron kernel: hid-generic 0003:28DE:1142.0006: hiddev98,hidraw5: USB HID v1.11 Device [Valve Software Steam Controller] on usb-0000:08:00.3-2/input3
Dec 10 16:03:16.693610 omicron kernel: hid-generic 0003:28DE:1142.0007: hiddev99,hidraw6: USB HID v1.11 Device [Valve Software Steam Controller] on usb-0000:08:00.3-2/input4
Dec 10 16:03:16.693754 omicron kernel: usb 1-6: New USB device found, idVendor=05e3, idProduct=0608, bcdDevice=60.70
Dec 10 16:03:16.693899 omicron kernel: usb 1-6: New USB device strings: Mfr=0, Product=1, SerialNumber=0
Dec 10 16:03:16.694045 omicron kernel: usb 1-6: Product: USB2.0 Hub
Dec 10 16:03:16.694244 omicron kernel: hub 1-6:1.0: USB hub found
Dec 10 16:03:16.694437 omicron kernel: hub 1-6:1.0: 4 ports detected
Dec 10 16:03:16.694626 omicron kernel: usb 5-3: new high-speed USB device number 4 using xhci_hcd
Dec 10 16:03:16.694813 omicron kernel: usb 1-7: new full-speed USB device number 4 using xhci_hcd
Dec 10 16:03:16.694824 omicron kernel: ata3: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
Dec 10 16:03:16.694831 omicron kernel: ata3.00: ATA-8: WDC WD6401AALS-00L3B2, 01.03B01, max UDMA/133
Dec 10 16:03:16.694841 omicron kernel: ata3.00: 1250263728 sectors, multi 16: LBA48 NCQ (depth 32), AA
Dec 10 16:03:16.694851 omicron kernel: ata3.00: configured for UDMA/133
Dec 10 16:03:16.695056 omicron kernel: scsi 2:0:0:0: Direct-Access     ATA      WDC WD6401AALS-0 3B01 PQ: 0 ANSI: 5
Dec 10 16:03:16.695260 omicron kernel: sd 2:0:0:0: [sdb] 1250263728 512-byte logical blocks: (640 GB/596 GiB)
Dec 10 16:03:16.695453 omicron kernel: sd 2:0:0:0: [sdb] Write Protect is off
Dec 10 16:03:16.695645 omicron kernel: sd 2:0:0:0: [sdb] Mode Sense: 00 3a 00 00
Dec 10 16:03:16.695842 omicron kernel: sd 2:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
Dec 10 16:03:16.696071 omicron kernel: sd 2:0:0:0: [sdb] Preferred minimum I/O size 512 bytes
Dec 10 16:03:16.696084 omicron kernel:  sdb: sdb1
Dec 10 16:03:16.696280 omicron kernel: sd 2:0:0:0: [sdb] Attached SCSI disk
Dec 10 16:03:16.696432 omicron kernel: usb 1-7: New USB device found, idVendor=048d, idProduct=5702, bcdDevice= 0.01
Dec 10 16:03:16.696575 omicron kernel: usb 1-7: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Dec 10 16:03:16.696719 omicron kernel: usb 1-7: Product: ITE Device
Dec 10 16:03:16.696858 omicron kernel: usb 1-7: Manufacturer: ITE Tech. Inc.
Dec 10 16:03:16.697066 omicron kernel: hid-generic 0003:048D:5702.0008: hiddev100,hidraw7: USB HID v1.12 Device [ITE Tech. Inc. ITE Device] on usb-0000:01:00.0-7/input0
Dec 10 16:03:16.697080 omicron kernel: ata4: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
Dec 10 16:03:16.697088 omicron kernel: ata4.00: ATA-8: WDC WD6401AALS-00L3B2, 01.03B01, max UDMA/133
Dec 10 16:03:16.697095 omicron kernel: ata4.00: 1250263728 sectors, multi 16: LBA48 NCQ (depth 32), AA
Dec 10 16:03:16.697101 omicron kernel: ata4.00: configured for UDMA/133
Dec 10 16:03:16.697286 omicron kernel: usb 1-8: new full-speed USB device number 5 using xhci_hcd
Dec 10 16:03:16.697482 omicron kernel: scsi 3:0:0:0: Direct-Access     ATA      WDC WD6401AALS-0 3B01 PQ: 0 ANSI: 5
Dec 10 16:03:16.697677 omicron kernel: sd 3:0:0:0: [sdc] 1250263728 512-byte logical blocks: (640 GB/596 GiB)
Dec 10 16:03:16.697869 omicron kernel: sd 3:0:0:0: [sdc] Write Protect is off
Dec 10 16:03:16.698071 omicron kernel: sd 3:0:0:0: [sdc] Mode Sense: 00 3a 00 00
Dec 10 16:03:16.698264 omicron kernel: sd 3:0:0:0: [sdc] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
Dec 10 16:03:16.698458 omicron kernel: sd 3:0:0:0: [sdc] Preferred minimum I/O size 512 bytes
Dec 10 16:03:16.698467 omicron kernel:  sdc: sdc1
Dec 10 16:03:16.698658 omicron kernel: sd 3:0:0:0: [sdc] Attached SCSI disk
Dec 10 16:03:16.698802 omicron kernel: usb 5-3: New USB device found, idVendor=046d, idProduct=0892, bcdDevice= 0.19
Dec 10 16:03:16.698949 omicron kernel: usb 5-3: New USB device strings: Mfr=0, Product=2, SerialNumber=1
Dec 10 16:03:16.699096 omicron kernel: usb 5-3: Product: HD Pro Webcam C920
Dec 10 16:03:16.699236 omicron kernel: usb 5-3: SerialNumber: 6118C9DF
Dec 10 16:03:16.699423 omicron kernel: usb 5-4: new high-speed USB device number 5 using xhci_hcd
Dec 10 16:03:16.699569 omicron kernel: usb 5-4: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice= 6.54
Dec 10 16:03:16.699714 omicron kernel: usb 5-4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Dec 10 16:03:16.699854 omicron kernel: usb 5-4: Product: USB2.1 Hub
Dec 10 16:03:16.700036 omicron kernel: usb 5-4: Manufacturer: GenesysLogic
Dec 10 16:03:16.700046 omicron kernel: ata5: SATA link down (SStatus 0 SControl 330)
Dec 10 16:03:16.700196 omicron kernel: usb 1-8: New USB device found, idVendor=046d, idProduct=c52b, bcdDevice=12.11
Dec 10 16:03:16.700336 omicron kernel: usb 1-8: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Dec 10 16:03:16.700475 omicron kernel: usb 1-8: Product: USB Receiver
Dec 10 16:03:16.700618 omicron kernel: usb 1-8: Manufacturer: Logitech
Dec 10 16:03:16.700812 omicron kernel: hub 5-4:1.0: USB hub found
Dec 10 16:03:16.701009 omicron kernel: hub 5-4:1.0: 4 ports detected
Dec 10 16:03:16.701020 omicron kernel: input: Logitech USB Receiver as /devices/pci0000:00/0000:00:01.2/0000:01:00.0/usb1/1-8/1-8:1.0/0003:046D:C52B.0009/input/input7
Dec 10 16:03:16.701219 omicron kernel: hid-generic 0003:046D:C52B.0009: input,hidraw8: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-0000:01:00.0-8/input0
Dec 10 16:03:16.701230 omicron kernel: input: Logitech USB Receiver Mouse as /devices/pci0000:00/0000:00:01.2/0000:01:00.0/usb1/1-8/1-8:1.1/0003:046D:C52B.000A/input/input8
Dec 10 16:03:16.701237 omicron kernel: input: Logitech USB Receiver Consumer Control as /devices/pci0000:00/0000:00:01.2/0000:01:00.0/usb1/1-8/1-8:1.1/0003:046D:C52B.000A/input/input9
Dec 10 16:03:16.701244 omicron kernel: input: Logitech USB Receiver System Control as /devices/pci0000:00/0000:00:01.2/0000:01:00.0/usb1/1-8/1-8:1.1/0003:046D:C52B.000A/input/input10
Dec 10 16:03:16.701438 omicron kernel: hid-generic 0003:046D:C52B.000A: input,hiddev101,hidraw9: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-0000:01:00.0-8/input1
Dec 10 16:03:16.701637 omicron kernel: hid-generic 0003:046D:C52B.000B: hiddev102,hidraw10: USB HID v1.11 Device [Logitech USB Receiver] on usb-0000:01:00.0-8/input2
Dec 10 16:03:16.701650 omicron kernel: ata6: SATA link down (SStatus 0 SControl 330)
Dec 10 16:03:16.701845 omicron kernel: usb 5-4.1: new full-speed USB device number 6 using xhci_hcd
Dec 10 16:03:16.702047 omicron kernel: scsi 11:0:0:0: Direct-Access     ATA      CT1000MX500SSD4  023  PQ: 0 ANSI: 5
Dec 10 16:03:16.702248 omicron kernel: sd 11:0:0:0: [sdd] 1953525168 512-byte logical blocks: (1.00 TB/932 GiB)
Dec 10 16:03:16.702441 omicron kernel: sd 11:0:0:0: [sdd] 4096-byte physical blocks
Dec 10 16:03:16.702634 omicron kernel: sd 11:0:0:0: [sdd] Write Protect is off
Dec 10 16:03:16.702826 omicron kernel: sd 11:0:0:0: [sdd] Mode Sense: 00 3a 00 00
Dec 10 16:03:16.703024 omicron kernel: sd 11:0:0:0: [sdd] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
Dec 10 16:03:16.703222 omicron kernel: sd 11:0:0:0: [sdd] Preferred minimum I/O size 4096 bytes
Dec 10 16:03:16.703232 omicron kernel:  sdd: sdd1 sdd2
Dec 10 16:03:16.703423 omicron kernel: sd 11:0:0:0: [sdd] supports TCG Opal
Dec 10 16:03:16.703615 omicron kernel: sd 11:0:0:0: [sdd] Attached SCSI disk
Dec 10 16:03:16.703624 omicron kernel: Freeing unused decrypted memory: 2028K
Dec 10 16:03:16.703632 omicron kernel: Freeing unused kernel image (initmem) memory: 4728K
Dec 10 16:03:16.703639 omicron kernel: Write protecting the kernel read-only data: 36864k
Dec 10 16:03:16.703650 omicron kernel: Freeing unused kernel image (text/rodata gap) memory: 228K
Dec 10 16:03:16.703657 omicron kernel: Freeing unused kernel image (rodata/data gap) memory: 12K
Dec 10 16:03:16.703664 omicron kernel: x86/mm: Checked W+X mappings: passed, no W+X pages found.
Dec 10 16:03:16.703671 omicron kernel: rodata_test: all tests were successful
Dec 10 16:03:16.703678 omicron kernel: Run /init as init process
Dec 10 16:03:16.703685 omicron kernel:   with arguments:
Dec 10 16:03:16.703692 omicron kernel:     /init
Dec 10 16:03:16.703698 omicron kernel:   with environment:
Dec 10 16:03:16.703705 omicron kernel:     HOME=/
Dec 10 16:03:16.703714 omicron kernel:     TERM=linux
Dec 10 16:03:16.703863 omicron kernel: usb 5-4.1: New USB device found, idVendor=1b3f, idProduct=2008, bcdDevice= 1.00
Dec 10 16:03:16.704023 omicron kernel: usb 5-4.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Dec 10 16:03:16.704171 omicron kernel: usb 5-4.1: Product: USB Audio Device
Dec 10 16:03:16.704322 omicron kernel: usb 5-4.1: Manufacturer: GeneralPlus
Dec 10 16:03:16.704333 omicron kernel: input: GeneralPlus USB Audio Device as /devices/pci0000:00/0000:00:08.1/0000:08:00.3/usb5/5-4/5-4.1/5-4.1:1.3/0003:1B3F:2008.000C/input/input12
Dec 10 16:03:16.704540 omicron kernel: hid-generic 0003:1B3F:2008.000C: input,hidraw11: USB HID v2.01 Device [GeneralPlus USB Audio Device] on usb-0000:08:00.3-4.1/input3
Dec 10 16:03:16.704554 omicron kernel: Key type psk registered
Dec 10 16:03:16.704707 omicron kernel: nvme nvme0: pci function 0000:03:00.0
Dec 10 16:03:16.704856 omicron kernel: nvme nvme0: 16/0/0 default/read/poll queues
Dec 10 16:03:16.704866 omicron kernel: input: Valve Software Steam Controller as /devices/pci0000:00/0000:00:08.1/0000:08:00.3/usb5/5-2/5-2:1.0/0003:28DE:1142.0003/input/input13
Dec 10 16:03:16.705069 omicron kernel: hid-steam 0003:28DE:1142.0003: input,hidraw2: USB HID v1.11 Keyboard [Valve Software Steam Controller] on usb-0000:08:00.3-2/input0
Dec 10 16:03:16.705268 omicron kernel: hid-steam 0003:28DE:1142.0004: hiddev96: USB HID v1.11 Device [Valve Software Steam Controller] on usb-0000:08:00.3-2/input1
Dec 10 16:03:16.705464 omicron kernel: logitech-djreceiver 0003:046D:C52B.000B: hiddev101,hidraw3: USB HID v1.11 Device [Logitech USB Receiver] on usb-0000:01:00.0-8/input2
Dec 10 16:03:16.705667 omicron kernel: hid-steam 0003:28DE:1142.0004: Steam wireless receiver connected
Dec 10 16:03:16.705866 omicron kernel: hid-steam 0003:28DE:1142.000D: hidraw8: USB HID v1.11 Device [Valve Software Steam Controller] on usb-0000:08:00.3-2/input1
Dec 10 16:03:16.706076 omicron kernel: hid-steam 0003:28DE:1142.0005: hiddev97: USB HID v1.11 Device [Valve Software Steam Controller] on usb-0000:08:00.3-2/input2
Dec 10 16:03:16.706272 omicron kernel: hid-steam 0003:28DE:1142.0005: Steam wireless receiver connected
Dec 10 16:03:16.706471 omicron kernel: hid-steam 0003:28DE:1142.000E: hidraw4: USB HID v1.11 Device [Valve Software Steam Controller] on usb-0000:08:00.3-2/input2
Dec 10 16:03:16.706669 omicron kernel: hid-steam 0003:28DE:1142.0006: hiddev98: USB HID v1.11 Device [Valve Software Steam Controller] on usb-0000:08:00.3-2/input3
Dec 10 16:03:16.706682 omicron kernel: input: Logitech Wireless Device PID:407b Keyboard as /devices/pci0000:00/0000:00:01.2/0000:01:00.0/usb1/1-8/1-8:1.2/0003:046D:C52B.000B/0003:046D:407B.000F/input/input14
Dec 10 16:03:16.706878 omicron kernel: hid-steam 0003:28DE:1142.0006: Steam wireless receiver connected
Dec 10 16:03:16.707090 omicron kernel: hid-steam 0003:28DE:1142.0010: hidraw5: USB HID v1.11 Device [Valve Software Steam Controller] on usb-0000:08:00.3-2/input3
Dec 10 16:03:16.707291 omicron kernel: hid-steam 0003:28DE:1142.0007: hiddev99: USB HID v1.11 Device [Valve Software Steam Controller] on usb-0000:08:00.3-2/input4
Dec 10 16:03:16.707301 omicron kernel: input: Logitech Wireless Device PID:407b Mouse as /devices/pci0000:00/0000:00:01.2/0000:01:00.0/usb1/1-8/1-8:1.2/0003:046D:C52B.000B/0003:046D:407B.000F/input/input15
Dec 10 16:03:16.707504 omicron kernel: hid-generic 0003:046D:407B.000F: input,hidraw6: USB HID v1.11 Keyboard [Logitech Wireless Device PID:407b] on usb-0000:01:00.0-8/input2:1
Dec 10 16:03:16.707706 omicron kernel: hid-steam 0003:28DE:1142.0007: Steam wireless receiver connected
Dec 10 16:03:16.707909 omicron kernel: hid-steam 0003:28DE:1142.0011: hidraw9: USB HID v1.11 Device [Valve Software Steam Controller] on usb-0000:08:00.3-2/input4
Dec 10 16:03:16.707919 omicron kernel: input: Logitech MX Vertical as /devices/pci0000:00/0000:00:01.2/0000:01:00.0/usb1/1-8/1-8:1.2/0003:046D:C52B.000B/0003:046D:407B.000F/input/input19
Dec 10 16:03:16.708121 omicron kernel: logitech-hidpp-device 0003:046D:407B.000F: input,hidraw6: USB HID v1.11 Keyboard [Logitech MX Vertical] on usb-0000:01:00.0-8/input2:1
Dec 10 16:03:16.708132 omicron kernel: EXT4-fs (sdd2): warning: mounting fs with errors, running e2fsck is recommended
Dec 10 16:03:16.708139 omicron kernel: EXT4-fs (sdd2): recovery complete
Dec 10 16:03:16.708147 omicron kernel: EXT4-fs (sdd2): mounted filesystem a00987d8-776e-4c90-9249-92a768927523 r/w with ordered data mode. Quota mode: none.
Dec 10 16:03:16.708155 omicron systemd[1]: systemd 258.2-2-manjaro running in system mode (+PAM +AUDIT -SELINUX -APPARMOR -IMA +IPE +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBCRYPTSETUP_PLUGINS +LIBFDISK +PCRE2 +PWQUALITY +P11KIT +QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD +BPF_FRAMEWORK +BTF +XKBCOMMON +UTMP -SYSVINIT +LIBARCHIVE)
Dec 10 16:03:16.708170 omicron systemd[1]: Detected architecture x86-64.
Dec 10 16:03:16.708178 omicron systemd[1]: Hostname set to <omicron>.
Dec 10 16:03:16.708186 omicron systemd[1]: bpf-restrict-fs: LSM BPF program attached
Dec 10 16:03:16.708193 omicron systemd[1]: Queued start job for default target Graphical Interface.
Dec 10 16:03:16.708200 omicron systemd[1]: Created slice Slice /system/dirmngr.
Dec 10 16:03:16.708208 omicron systemd[1]: Created slice Slice /system/getty.
Dec 10 16:03:16.708216 omicron systemd[1]: Created slice Slice /system/gpg-agent.
Dec 10 16:03:16.708225 omicron systemd[1]: Created slice Slice /system/gpg-agent-browser.
Dec 10 16:03:16.708234 omicron systemd[1]: Created slice Slice /system/gpg-agent-extra.
Dec 10 16:03:16.708242 omicron systemd[1]: Created slice Slice /system/gpg-agent-ssh.
Dec 10 16:03:16.708249 omicron systemd[1]: Created slice Slice /system/keyboxd.
Dec 10 16:03:16.708256 omicron systemd[1]: Created slice Slice /system/modprobe.
Dec 10 16:03:16.708263 omicron systemd[1]: Created slice User and Session Slice.
Dec 10 16:03:16.708271 omicron systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
Dec 10 16:03:16.708280 omicron systemd[1]: Started Forward Password Requests to Wall Directory Watch.
Dec 10 16:03:16.708289 omicron systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
Dec 10 16:03:16.708297 omicron systemd[1]: Expecting device /dev/disk/by-uuid/3bb2783d-253e-4b79-90b2-3679a77f5c18...
Dec 10 16:03:16.708304 omicron systemd[1]: Expecting device /dev/disk/by-uuid/48ca8e34-8561-4e89-89e1-86cad44d43b3...
Dec 10 16:03:16.708311 omicron systemd[1]: Expecting device /dev/disk/by-uuid/4b2d2e05-9732-4f3f-931c-65cc32fa033b...
Dec 10 16:03:16.708319 omicron systemd[1]: Expecting device /dev/disk/by-uuid/6b8f5169-2ef2-4996-a06c-b0a8f7c70146...
Dec 10 16:03:16.708326 omicron systemd[1]: Expecting device /dev/disk/by-uuid/EFF7-15BD...
Dec 10 16:03:16.708333 omicron systemd[1]: Expecting device /dev/disk/by-uuid/a6e3f400-3c5f-4229-a6ea-5d99b04fab19...
Dec 10 16:03:16.708343 omicron systemd[1]: Reached target Local Encrypted Volumes.
Dec 10 16:03:16.708352 omicron systemd[1]: Reached target Login Prompts.
Dec 10 16:03:16.708367 omicron systemd[1]: Reached target Image Downloads.
Dec 10 16:03:16.708376 omicron systemd[1]: Reached target Local Integrity Protected Volumes.
Dec 10 16:03:16.708384 omicron systemd[1]: Reached target Preparation for Network.
Dec 10 16:03:16.708391 omicron systemd[1]: Reached target Path Units.
Dec 10 16:03:16.708399 omicron systemd[1]: Reached target Remote File Systems.
Dec 10 16:03:16.708408 omicron systemd[1]: Reached target Slice Units.
Dec 10 16:03:16.708415 omicron systemd[1]: Reached target Local Verity Protected Volumes.
Dec 10 16:03:16.708423 omicron systemd[1]: Listening on Device-mapper event daemon FIFOs.
Dec 10 16:03:16.708430 omicron systemd[1]: Listening on LVM2 poll daemon socket.
Dec 10 16:03:16.708437 omicron systemd[1]: Listening on Query the User Interactively for a Password.
Dec 10 16:03:16.708444 omicron systemd[1]: Listening on Process Core Dump Socket.
Dec 10 16:03:16.708452 omicron systemd[1]: Listening on Credential Encryption/Decryption.
Dec 10 16:03:16.708459 omicron systemd[1]: Listening on Factory Reset Management.
Dec 10 16:03:16.708470 omicron systemd[1]: Listening on Journal Socket (/dev/log).
Dec 10 16:03:16.708478 omicron systemd[1]: Listening on Journal Sockets.
Dec 10 16:03:16.708485 omicron systemd[1]: TPM PCR Measurements was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
Dec 10 16:03:16.708493 omicron systemd[1]: Make TPM PCR Policy was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
Dec 10 16:03:16.708500 omicron systemd[1]: Listening on udev Control Socket.
Dec 10 16:03:16.708508 omicron systemd[1]: Listening on udev Kernel Socket.
Dec 10 16:03:16.708515 omicron systemd[1]: Listening on udev Varlink Socket.
Dec 10 16:03:16.708524 omicron systemd[1]: Mounting Huge Pages File System...
Dec 10 16:03:16.708531 omicron systemd[1]: Mounting POSIX Message Queue File System...
Dec 10 16:03:16.708539 omicron systemd[1]: Mounting Kernel Debug File System...
Dec 10 16:03:16.708546 omicron systemd[1]: Mounting Kernel Trace File System...
Dec 10 16:03:16.708556 omicron systemd[1]: Starting Create List of Static Device Nodes...
Dec 10 16:03:16.708564 omicron systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
Dec 10 16:03:16.708571 omicron systemd[1]: Load Kernel Module configfs was skipped because of an unmet condition check (ConditionKernelModuleLoaded=!configfs).
Dec 10 16:03:16.708579 omicron systemd[1]: Mounting Kernel Configuration File System...
Dec 10 16:03:16.708586 omicron systemd[1]: Starting Load Kernel Module dm_mod...
Dec 10 16:03:16.708595 omicron systemd[1]: Load Kernel Module drm was skipped because of an unmet condition check (ConditionKernelModuleLoaded=!drm).
Dec 10 16:03:16.708603 omicron systemd[1]: Load Kernel Module fuse was skipped because of an unmet condition check (ConditionKernelModuleLoaded=!fuse).
Dec 10 16:03:16.708610 omicron systemd[1]: Mounting FUSE Control File System...
Dec 10 16:03:16.708618 omicron systemd[1]: Starting Load Kernel Module loop...
Dec 10 16:03:16.708625 omicron systemd[1]: Clear Stale Hibernate Storage Info was skipped because of an unmet condition check (ConditionPathExists=/sys/firmware/efi/efivars/HibernateLocation-8cf2644b-4b0b-428f-9387-6d876050dc67).
Dec 10 16:03:16.708633 omicron systemd[1]: Starting Journal Service...
Dec 10 16:03:16.708640 omicron systemd[1]: Starting Load Kernel Modules...
Dec 10 16:03:16.708647 omicron systemd[1]: TPM PCR Machine ID Measurement was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
Dec 10 16:03:16.708656 omicron systemd[1]: Starting Remount Root and Kernel File Systems...
Dec 10 16:03:16.708664 omicron systemd[1]: Early TPM SRK Setup was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
Dec 10 16:03:16.708671 omicron systemd[1]: Starting Load udev Rules from Credentials...
Dec 10 16:03:16.708678 omicron systemd[1]: Starting Coldplug All udev Devices...
Dec 10 16:03:16.708687 omicron systemd[1]: Mounted Huge Pages File System.
Dec 10 16:03:16.708694 omicron systemd[1]: Mounted POSIX Message Queue File System.
Dec 10 16:03:16.708702 omicron systemd[1]: Mounted Kernel Debug File System.
Dec 10 16:03:16.708709 omicron systemd[1]: Mounted Kernel Trace File System.
Dec 10 16:03:16.708716 omicron systemd[1]: Finished Create List of Static Device Nodes.
Dec 10 16:03:16.708725 omicron systemd[1]: Mounted Kernel Configuration File System.
Dec 10 16:03:16.708732 omicron systemd[1]: Mounted FUSE Control File System.
Dec 10 16:03:16.708739 omicron systemd[1]: Starting Create Static Device Nodes in /dev gracefully...
Dec 10 16:03:16.708746 omicron kernel: loop: module loaded
Dec 10 16:03:16.708754 omicron systemd[1]: modprobe@loop.service: Deactivated successfully.
Dec 10 16:03:16.708762 omicron systemd[1]: Finished Load Kernel Module loop.
Dec 10 16:03:16.708769 omicron kernel: device-mapper: uevent: version 1.0.3
Dec 10 16:03:16.708776 omicron kernel: device-mapper: ioctl: 4.50.0-ioctl (2025-04-28) initialised: dm-devel@lists.linux.dev
Dec 10 16:03:16.708784 omicron systemd[1]: modprobe@dm_mod.service: Deactivated successfully.
Dec 10 16:03:16.708792 omicron systemd[1]: Finished Load Kernel Module dm_mod.
Dec 10 16:03:16.708799 omicron systemd[1]: Repartition Root Disk was skipped because no trigger condition checks were met.
Dec 10 16:03:16.708806 omicron systemd[1]: Finished Load udev Rules from Credentials.
Dec 10 16:03:16.708831 omicron systemd-journald[397]: Collecting audit messages is disabled.
Dec 10 16:03:16.708850 omicron kernel: EXT4-fs (sdd2): re-mounted a00987d8-776e-4c90-9249-92a768927523.
Dec 10 16:03:16.708858 omicron systemd[1]: Finished Remount Root and Kernel File Systems.
Dec 10 16:03:16.708865 omicron systemd[1]: Rebuild Hardware Database was skipped because of an unmet condition check (ConditionNeedsUpdate=/etc).
Dec 10 16:03:16.708873 omicron systemd[1]: Starting Load/Save OS Random Seed...
Dec 10 16:03:16.708880 omicron systemd[1]: TPM SRK Setup was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
Dec 10 16:03:16.709087 omicron kernel: sd 0:0:0:0: Attached scsi generic sg0 type 0
Dec 10 16:03:16.709286 omicron kernel: sd 2:0:0:0: Attached scsi generic sg1 type 0
Dec 10 16:03:16.709480 omicron kernel: sd 3:0:0:0: Attached scsi generic sg2 type 0
Dec 10 16:03:16.709679 omicron kernel: sd 11:0:0:0: Attached scsi generic sg3 type 0
Dec 10 16:03:16.709688 omicron kernel: i2c_dev: i2c /dev entries driver
Dec 10 16:03:16.709696 omicron systemd[1]: Finished Load/Save OS Random Seed.
Dec 10 16:03:16.709704 omicron systemd[1]: Finished Create Static Device Nodes in /dev gracefully.
Dec 10 16:03:16.709711 omicron systemd[1]: Create System Users was skipped because no trigger condition checks were met.
Dec 10 16:03:16.709719 omicron systemd[1]: Starting Network Time Synchronization...
Dec 10 16:03:16.709726 omicron systemd[1]: Starting Create Static Device Nodes in /dev...
Dec 10 16:03:16.709733 omicron kernel: nvidia: loading out-of-tree module taints kernel.
Dec 10 16:03:16.709743 omicron kernel: nvidia: module verification failed: signature and/or required key missing - tainting kernel
Dec 10 16:03:16.709753 omicron systemd[1]: Finished Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling.
Dec 10 16:03:16.709760 omicron systemd[1]: Finished Create Static Device Nodes in /dev.
Dec 10 16:03:16.709767 omicron systemd[1]: Reached target Preparation for Local File Systems.
Dec 10 16:03:16.709775 omicron systemd[1]: Starting Rule-based Manager for Device Events and Files...
Dec 10 16:03:16.709782 omicron systemd[1]: Started Network Time Synchronization.
Dec 10 16:03:16.709790 omicron systemd[1]: Reached target System Time Set.
Dec 10 16:03:16.710131 omicron systemd[1]: Started Journal Service.
Dec 10 16:03:16.803692 omicron systemd-journald[397]: Received client request to flush runtime journal.
Dec 10 16:03:16.803756 omicron systemd-journald[397]: File /var/log/journal/5480f2217d5948e8af6aab287e180a3b/system.journal corrupted or uncleanly shut down, renaming and replacing.
Dec 10 16:03:16.803789 omicron kernel: nvidia-nvlink: Nvlink Core is being initialized, major device number 237
Dec 10 16:03:16.803809 omicron kernel:
Dec 10 16:03:16.803829 omicron kernel: nvidia 0000:06:00.0: vgaarb: VGA decodes changed: olddecodes=io+mem,decodes=none:owns=io+mem
Dec 10 16:03:17.013909 omicron kernel: NVRM: loading NVIDIA UNIX Open Kernel Module for x86_64  580.105.08  Release Build  (root@)
Dec 10 16:03:17.050896 omicron kernel: ccp 0000:08:00.1: enabling device (0000 -> 0002)
Dec 10 16:03:17.056037 omicron kernel: mousedev: PS/2 mouse device common for all mice
Dec 10 16:03:17.062895 omicron kernel: ccp 0000:08:00.1: ccp: unable to access the device: you might be running a broken BIOS.
Dec 10 16:03:17.067932 omicron kernel: ccp 0000:08:00.1: psp enabled
Dec 10 16:03:17.089903 omicron kernel: Bluetooth: Core ver 2.22
Dec 10 16:03:17.089931 omicron kernel: NET: Registered PF_BLUETOOTH protocol family
Dec 10 16:03:17.089967 omicron kernel: Bluetooth: HCI device and connection manager initialized
Dec 10 16:03:17.089990 omicron kernel: Bluetooth: HCI socket layer initialized
Dec 10 16:03:17.090014 omicron kernel: Bluetooth: L2CAP socket layer initialized
Dec 10 16:03:17.090033 omicron kernel: Bluetooth: SCO socket layer initialized
Dec 10 16:03:17.118900 omicron kernel: mc: Linux media interface: v0.10
Dec 10 16:03:17.119934 omicron kernel: cfg80211: Loading compiled-in X.509 certificates for regulatory database
Dec 10 16:03:17.123901 omicron kernel: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
Dec 10 16:03:17.123931 omicron kernel: Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600'
Dec 10 16:03:17.249893 omicron kernel: Adding 16777212k swap on /dev/sda2.  Priority:-2 extents:1 across:16777212k SS
Dec 10 16:03:17.282896 omicron kernel: ACPI Warning: SystemIO range 0x0000000000000B00-0x0000000000000B08 conflicts with OpRegion 0x0000000000000B00-0x0000000000000B0F (\GSA1.SMBI) (20250807/utaddress-204)
Dec 10 16:03:17.282925 omicron kernel: ACPI: OSL: Resource conflict; ACPI support missing from driver?
Dec 10 16:03:17.282944 omicron kernel: input: PC Speaker as /devices/platform/pcspkr/input/input20
Dec 10 16:03:17.282961 omicron kernel: RAPL PMU: API unit is 2^-32 Joules, 2 fixed counters, 163840 ms ovfl timer
Dec 10 16:03:17.282979 omicron kernel: RAPL PMU: hw unit of domain package 2^-16 Joules
Dec 10 16:03:17.282995 omicron kernel: RAPL PMU: hw unit of domain core 2^-16 Joules
Dec 10 16:03:17.300901 omicron kernel: nvidia-modeset: Loading NVIDIA UNIX Open Kernel Mode Setting Driver for x86_64  580.105.08  Release Build  (root@)
Dec 10 16:03:17.344902 omicron kernel: sp5100_tco: SP5100/SB800 TCO WatchDog Timer Driver
Dec 10 16:03:17.344982 omicron kernel: sp5100-tco sp5100-tco: Using 0xfeb00000 for watchdog MMIO address
Dec 10 16:03:17.345286 omicron kernel: ACPI: bus type thunderbolt registered
Dec 10 16:03:17.345957 omicron kernel: sp5100-tco sp5100-tco: initialized. heartbeat=60 sec (nowayout=0)
Dec 10 16:03:17.346225 omicron kernel: videodev: Linux video capture interface: v2.00
Dec 10 16:03:17.349900 omicron kernel: [drm] [nvidia-drm] [GPU ID 0x00000600] Loading driver
Dec 10 16:03:17.351926 omicron kernel: r8169 0000:04:00.0 eth0: RTL8125B, 10:ff:e0:0c:39:de, XID 641, IRQ 99
Dec 10 16:03:17.352288 omicron kernel: r8169 0000:04:00.0 eth0: jumbo features [frames: 16362 bytes, tx checksumming: ko]
Dec 10 16:03:17.358896 omicron kernel: usbcore: registered new interface driver btusb
Dec 10 16:03:17.363896 omicron kernel: Bluetooth: hci0: RTL: examining hci_ver=0c hci_rev=000b lmp_ver=0c lmp_subver=8851
Dec 10 16:03:17.366893 omicron kernel: Bluetooth: hci0: RTL: rom_version status=0 version=0
Dec 10 16:03:17.366918 omicron kernel: r8169 0000:04:00.0 eno1: renamed from eth0
Dec 10 16:03:17.369896 omicron kernel: Bluetooth: hci0: RTL: btrtl_initialize: key id 0
Dec 10 16:03:17.369923 omicron kernel: Bluetooth: hci0: RTL: loading rtl_bt/rtl8851bu_fw.bin
Dec 10 16:03:17.409894 omicron kernel: Bluetooth: hci0: RTL: loading rtl_bt/rtl8851bu_config.bin
Dec 10 16:03:17.418894 omicron kernel: Bluetooth: hci0: RTL: cfg_sz 6, total sz 49707
Dec 10 16:03:17.436896 omicron kernel: gspca_main: v2.14.0 registered
Dec 10 16:03:17.439896 omicron kernel: snd_hda_intel 0000:06:00.1: Disabling MSI
Dec 10 16:03:17.440200 omicron kernel: snd_hda_intel 0000:06:00.1: Handle vga_switcheroo audio client
Dec 10 16:03:17.440467 omicron kernel: snd_hda_intel 0000:08:00.4: enabling device (0000 -> 0002)
Dec 10 16:03:17.442893 omicron kernel: intel_rapl_common: Found RAPL domain package
Dec 10 16:03:17.442925 omicron kernel: intel_rapl_common: Found RAPL domain core
Dec 10 16:03:17.442940 omicron kernel: amd_atl: AMD Address Translation Library initialized
Dec 10 16:03:17.461892 omicron kernel: rtw89_8851be 0000:05:00.0: loaded firmware rtw89/rtw8851b_fw.bin
Dec 10 16:03:17.462197 omicron kernel: rtw89_8851be 0000:05:00.0: enabling device (0000 -> 0003)
Dec 10 16:03:17.464897 omicron kernel: snd_hda_codec_alc662 hdaudioC2D0: autoconfig for ALC897: line_outs=3 (0x14/0x15/0x16/0x0/0x0) type:line
Dec 10 16:03:17.465199 omicron kernel: snd_hda_codec_alc662 hdaudioC2D0:    speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
Dec 10 16:03:17.465437 omicron kernel: snd_hda_codec_alc662 hdaudioC2D0:    hp_outs=1 (0x1b/0x0/0x0/0x0/0x0)
Dec 10 16:03:17.465668 omicron kernel: snd_hda_codec_alc662 hdaudioC2D0:    mono: mono_out=0x0
Dec 10 16:03:17.465907 omicron kernel: snd_hda_codec_alc662 hdaudioC2D0:    dig-out=0x1e/0x0
Dec 10 16:03:17.466152 omicron kernel: snd_hda_codec_alc662 hdaudioC2D0:    inputs:
Dec 10 16:03:17.466381 omicron kernel: snd_hda_codec_alc662 hdaudioC2D0:      Rear Mic=0x18
Dec 10 16:03:17.466613 omicron kernel: snd_hda_codec_alc662 hdaudioC2D0:      Front Mic=0x19
Dec 10 16:03:17.466844 omicron kernel: snd_hda_codec_alc662 hdaudioC2D0:      Line=0x1a
Dec 10 16:03:17.467893 omicron kernel: input: HDA NVidia HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:03.1/0000:06:00.1/sound/card1/input21
Dec 10 16:03:17.467918 omicron kernel: input: HDA NVidia HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:03.1/0000:06:00.1/sound/card1/input22
Dec 10 16:03:17.467932 omicron kernel: input: HDA NVidia HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:03.1/0000:06:00.1/sound/card1/input23
Dec 10 16:03:17.467950 omicron kernel: input: HDA NVidia HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:03.1/0000:06:00.1/sound/card1/input24
Dec 10 16:03:17.471896 omicron kernel: rtw89_8851be 0000:05:00.0: Firmware version 0.29.41.5 (4bd6ebac), cmd version 0, type 5
Dec 10 16:03:17.472209 omicron kernel: rtw89_8851be 0000:05:00.0: Firmware version 0.29.41.5 (4bd6ebac), cmd version 0, type 3
Dec 10 16:03:17.483896 omicron kernel: input: HD-Audio Generic Rear Mic as /devices/pci0000:00/0000:00:08.1/0000:08:00.4/sound/card2/input25
Dec 10 16:03:17.483926 omicron kernel: input: HD-Audio Generic Front Mic as /devices/pci0000:00/0000:00:08.1/0000:08:00.4/sound/card2/input26
Dec 10 16:03:17.483945 omicron kernel: input: HD-Audio Generic Line as /devices/pci0000:00/0000:00:08.1/0000:08:00.4/sound/card2/input27
Dec 10 16:03:17.483962 omicron kernel: input: HD-Audio Generic Line Out Front as /devices/pci0000:00/0000:00:08.1/0000:08:00.4/sound/card2/input28
Dec 10 16:03:17.483976 omicron kernel: input: HD-Audio Generic Line Out Surround as /devices/pci0000:00/0000:00:08.1/0000:08:00.4/sound/card2/input29
Dec 10 16:03:17.483991 omicron kernel: input: HD-Audio Generic Line Out CLFE as /devices/pci0000:00/0000:00:08.1/0000:08:00.4/sound/card2/input30
Dec 10 16:03:17.484008 omicron kernel: input: HD-Audio Generic Front Headphone as /devices/pci0000:00/0000:00:08.1/0000:08:00.4/sound/card2/input31
Dec 10 16:03:17.796915 omicron kernel: rtw89_8851be 0000:05:00.0: chip rfe_type is 2
Dec 10 16:03:17.823893 omicron kernel: gspca_main: vc032x-2.14.0 probing 046d:0892
Dec 10 16:03:17.824892 omicron kernel: gspca_vc032x: reg_r err -32
Dec 10 16:03:17.824904 omicron kernel: vc032x 5-3:1.0: probe with driver vc032x failed with error -32
Dec 10 16:03:17.825155 omicron kernel: usbcore: registered new interface driver vc032x
Dec 10 16:03:17.833898 omicron kernel: rtw89_8851be 0000:05:00.0: rfkill hardware state changed to enable
Dec 10 16:03:17.835894 omicron kernel: uvcvideo 5-3:1.0: Found UVC 1.00 device HD Pro Webcam C920 (046d:0892)
Dec 10 16:03:17.845895 omicron kernel: usbcore: registered new interface driver uvcvideo
Dec 10 16:03:17.848895 omicron kernel: rtw89_8851be 0000:05:00.0 wlp5s0: renamed from wlan0
Dec 10 16:03:18.057912 omicron kernel: usbcore: registered new interface driver snd-usb-audio
Dec 10 16:03:18.667894 omicron kernel: EXT4-fs (sda1): recovery complete
Dec 10 16:03:18.667923 omicron kernel: EXT4-fs (sda1): mounted filesystem 48ca8e34-8561-4e89-89e1-86cad44d43b3 r/w with ordered data mode. Quota mode: none.
Dec 10 16:03:18.678894 omicron kernel: FAT-fs (sdd1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
Dec 10 16:03:18.684892 omicron kernel: Bluetooth: hci0: RTL: fw version 0x048ad230
Dec 10 16:03:18.698893 omicron kernel: EXT4-fs (nvme0n1): recovery complete
Dec 10 16:03:18.698921 omicron kernel: EXT4-fs (nvme0n1): mounted filesystem 3bb2783d-253e-4b79-90b2-3679a77f5c18 r/w with ordered data mode. Quota mode: none.
Dec 10 16:03:18.722892 omicron kernel: EXT4-fs (sdb1): recovery complete
Dec 10 16:03:18.722925 omicron kernel: EXT4-fs (sdb1): mounted filesystem 4b2d2e05-9732-4f3f-931c-65cc32fa033b r/w with ordered data mode. Quota mode: none.
Dec 10 16:03:18.735892 omicron kernel: [drm] Initialized nvidia-drm 0.0.0 for 0000:06:00.0 on minor 1
Dec 10 16:03:18.739893 omicron kernel: EXT4-fs (sdc1): recovery complete
Dec 10 16:03:18.739906 omicron kernel: EXT4-fs (sdc1): mounted filesystem a6e3f400-3c5f-4229-a6ea-5d99b04fab19 r/w with ordered data mode. Quota mode: none.
Dec 10 16:03:18.760893 omicron kernel: nvidia 0000:06:00.0: vgaarb: deactivate vga console
Dec 10 16:03:18.823893 omicron kernel: fbcon: nvidia-drmdrmfb (fb0) is primary device
Dec 10 16:03:18.823910 omicron kernel: fbcon: Deferring console take-over
Dec 10 16:03:18.823926 omicron kernel: nvidia 0000:06:00.0: [drm] fb0: nvidia-drmdrmfb frame buffer device
Dec 10 16:03:18.861892 omicron kernel: Bluetooth: hci0: AOSP extensions version v1.00
Dec 10 16:03:19.801897 omicron kernel: fbcon: Taking over console
Dec 10 16:03:19.814897 omicron kernel: Bluetooth: BNEP (Ethernet Emulation) ver 1.3
Dec 10 16:03:19.814928 omicron kernel: Bluetooth: BNEP filters: protocol multicast
Dec 10 16:03:19.814950 omicron kernel: Bluetooth: BNEP socket layer initialized
Dec 10 16:03:19.815896 omicron kernel: Bluetooth: MGMT ver 1.23
Dec 10 16:03:19.835899 omicron kernel: NET: Registered PF_ALG protocol family
Dec 10 16:03:19.895895 omicron kernel: Console: switching to colour frame buffer device 240x67
Dec 10 16:03:20.037894 omicron kernel: NET: Registered PF_QIPCRTR protocol family
Dec 10 16:03:20.076892 omicron kernel: Realtek Internal NBASE-T PHY r8169-0-400:00: attached PHY driver (mii_bus:phy_addr=r8169-0-400:00, irq=MAC)
Dec 10 16:03:20.235895 omicron kernel: r8169 0000:04:00.0 eno1: Link is Down
Dec 10 16:03:20.885900 omicron kernel: tun: Universal TUN/TAP device driver, 1.6
Dec 10 16:03:22.830404 omicron kernel: r8169 0000:04:00.0 eno1: Link is Up - 1Gbps/Full - flow control rx/tx
Dec 10 16:03:22.974894 omicron kernel: rfkill: input handler disabled
Dec 10 16:03:23.459895 omicron kernel: usb 5-3: reset high-speed USB device number 4 using xhci_hcd
Dec 10 16:03:23.620894 omicron kernel: logitech-hidpp-device 0003:046D:407B.000F: HID++ 4.5 device connected.
Dec 10 16:03:25.166947 omicron kernel: Bluetooth: RFCOMM TTY layer initialized
Dec 10 16:03:25.166998 omicron kernel: Bluetooth: RFCOMM socket layer initialized
Dec 10 16:03:25.167013 omicron kernel: Bluetooth: RFCOMM ver 1.11
Dec 10 16:03:27.559973 omicron systemd-journald[397]: File /var/log/journal/5480f2217d5948e8af6aab287e180a3b/user-1000.journal corrupted or uncleanly shut down, renaming and replacing.
Dec 10 16:03:31.070910 omicron kernel: rfkill: input handler enabled
Dec 10 16:03:39.095898 omicron kernel: traps: gnome-shell[1184] general protection fault ip:7f2825b328f2 sp:7ffdd88facf0 error:0 in libglib-2.0.so.0.8600.2[5c8f2,7f2825af4000+a7000]
Dec 10 16:03:41.078899 omicron kernel: EXT4-fs (sda1): unmounting filesystem 48ca8e34-8561-4e89-89e1-86cad44d43b3.
Dec 10 16:03:41.078924 omicron kernel: EXT4-fs (sdc1): unmounting filesystem a6e3f400-3c5f-4229-a6ea-5d99b04fab19.
Dec 10 16:03:41.078946 omicron kernel: EXT4-fs (sdb1): unmounting filesystem 4b2d2e05-9732-4f3f-931c-65cc32fa033b.
Dec 10 16:03:41.078963 omicron kernel: EXT4-fs (nvme0n1): unmounting filesystem 3bb2783d-253e-4b79-90b2-3679a77f5c18.
Dec 10 16:03:41.267893 omicron kernel: watchdog: watchdog0: watchdog did not stop!
Dec 10 16:03:41.269894 omicron systemd-shutdown[1]: Using hardware watchdog /dev/watchdog0: 'SP5100 TCO timer', version 0.
Dec 10 16:03:41.288192 omicron systemd-shutdown[1]: Watchdog running with a hardware timeout of 10min.
Dec 10 16:03:41.288215 omicron systemd-shutdown[1]: Syncing filesystems and block devices.
Dec 10 16:03:41.293254 omicron systemd-shutdown[1]: Sending SIGTERM to remaining processes...
Dec 10 16:03:41.293279 omicron systemd-journald[397]: Received SIGTERM from PID 1 (systemd-shutdow).
journalctl -u gdm -b -1 --no-pager
Dec 10 16:03:20 omicron systemd[1]: Starting GNOME Display Manager...
Dec 10 16:03:20 omicron systemd[1]: Started GNOME Display Manager.
Dec 10 16:03:27 omicron gdm-password][4610]: gkr-pam: unable to locate daemon control file
Dec 10 16:03:27 omicron gdm-password][4610]: gkr-pam: stashed password to try later in open session
Dec 10 16:03:27 omicron gdm-password][4610]: pam_unix(gdm-password:session): session opened for user brian(uid=1000) by brian(uid=0)
Dec 10 16:03:27 omicron gdm-password][4610]: gkr-pam: unlocked login keyring
Dec 10 16:03:31 omicron gdm[797]: Gdm: GdmDisplay: Session never registered, failing
Dec 10 16:03:38 omicron systemd[1]: Stopping GNOME Display Manager...
Dec 10 16:03:39 omicron gdm[797]: Gdm: Child process -966 was already dead.
Dec 10 16:03:39 omicron systemd[1]: gdm.service: Deactivated successfully.
Dec 10 16:03:39 omicron systemd[1]: Stopped GNOME Display Manager.
I did a quick test with your latest command: Exactly the same result (with my parameters) !
It definitely seems like we have the same issue. Comparing our inxi -zv8 output it looks like our systems are very different: different motherboards, different CPU vendors, different GPU vendors, different kernel versions.
I did notice that these lines are very similar, however, and relevant to this update I think:
  Display: unspecified server: X.org v: 1.21.1.21 with: Xwayland v: 24.1.9
    compositor: gnome-shell driver: X: loaded: nvidia gpu: nv_platform,nvidia,nvidia-nvswitch
    tty: 192x60
    compositor: gnome-shell driver: X: loaded: amdgpu unloaded: modesetting,radeon
    alternate: fbdev,vesa dri: radeonsi gpu: amdgpu tty: 240x67
Is it possible this is saying that we’re both still configured to use X11, despite the update removing X11 sessions from the options? I could imagine that would cause problems, and explain this message from my gdm journal ouput Dec 10 16:03:31 omicron gdm[797]: Gdm: GdmDisplay: Session never registered, failing
Thank you for finding that, I appreciate it. I’m at work overnight so I’ll update more in the morning when I can try updating from chroot. For now, here’s the order I did the update:
  1. I updated using sudo pacman -Syuu from a gnome-terminal within Gnome, which didn’t indicate any errors
  2. I then installed the most recent kernel with the graphical tool in manjaro-settings
  3. I proceeded to update flatpak apps with sudo flatpak update. There are a couple flatpaks which warn they are deprecated but no other errors
  4. I rebooted my system, logged in, and encountered this issue
I do have AUR packages installed but I had not yet updated them with pamac update –aur before rebooting (I forgot). I still have not updated AUR packages.
I’m able to start a graphical shell with gnome-shell –wayland from a TTY session, however gnome-session fails with an error that I’ll edit in when I get home.
@keeblebrox
To be clear, my responses in the other topic were directed at @TJF (the “OP” of that thread, owner of their original post). While offering assistance to other forum users is welcomed, so-called “hijacking” of a topic/thread (adding one’s own issue to another member’s topic) is not.
Otherwise, addressing issues from two separate users – no matter how similar the issue may be – can quickly become confusing for others reading.
As a member since 2020 you should already be aware of this rule.
See Forum Rules: Thread Hijacking
Your posts have been moved to a separate topic.
Because my post in the other topic may indeed also be helpful to you, I have included a modified version here. Cheers.
The following Tutorial shows how to enter a chroot environment, allowing you to perform various actions as the Super User (root).
You would need to boot with the Manjaro Installer USB, and use its Terminal. As you are using the ext4 filesystem, you can use manjaro-chroot -a to enter the chroot environment.
In the chroot environment, you are already the Super User, so sudo is not required for any command.
Try performing the update again:
1. Refresh the mirrors
  • pacman-mirrors --continent
2. Update packages from the Manjaro repo(s):
  • pacman -Syu
3. Build/update software sourced via the AUR:
  • pamac update --aur (using pamac)
4. If you use flatpak containerised apps:
  • flatpak update
Some helpful notes:
1. sudo pacman -Syuu should not be used to update your system. :eyes:
  • -Syuu allows packages to be downgraded (specifically, the uu)
  • To sync/update a Manjaro system sudo pacman -Syu should always be used, unless specifically instructed otherwise during troubleshooting or to resolve an issue (note that only a single u is used).
  • It’s possible that incorrect pacman syntax will lead to update issues. :eyes:
It’s always recommended to be aware of changes that will result from updating Manjaro – especially the larger pseudo-monthy updates – monitoring the Update Announcements for your particular branch prior to updating is a way to achieve that.
2. The following method isn’t set in stone (but perhaps it should be):
When a large update is looming, especially one that introduces system changes, it can often be preferable to update from outside of the GUI. This can help avoid some complications arising from upgrading components while they are still in use.
  1. Logout from the GUI
  2. Open a TTY and perform the update:
    Maintain separation between Repo and foreign sources (AUR):
    – Update from the repo first; for example sudo pacman -Syu
    – and then the AUR pamac update --aur
    – followed by flatpak update (if flatpak is used).
  3. Logout and Reboot (required when system packages are updated)
Thank you for these resources. I followed the instructions about recovering from an interrupted update. Unfortunately that didn’t fix my issue, but it was informative and necessary anyway. I particularly appreciate your note about the dangers of using pacman -Syuu. It seems like pacman has some regrettable footguns that I’ve now taken time to learn to avoid.
I found a solution in installing and enabling lightdm by following these instructions (and @lukasschober apparently used the same method):
https://wiki.manjaro.org/index.php?title=Install_Display_Managers
Once I was able to log in to a gnome session using lightdm, I removed the gdm, gdm-settings, and manjaro-gdm-tweak packages with sudo pacman -Rsn gdm gdm-settings manjaro-gdm-tweak in order to purge any configuration files. Instructions from this thread:
Afterwards I was able to reinstall gdm and gdm-settings using pamac install gdm gdm-settings and then re-enable gdm by following the instructions above. After a reboot I am able to log in using gdm again.
