Gcc12 - Problem updating manjaro libgcc_s.so exists
Is there a quick fix to workaround that error when updating ?
I get this when running the last update
gcc13: /usr/lib/gcc/x86_64-pc-linux-gnu/lib/libgcc_s.so exists in filesystem (owned by gcc12)
gcc13: /usr/lib/gcc/x86_64-pc-linux-gnu/lib/libgcc_s.so.1 exists in filesystem (owned by gcc12)
xxx@xxx-desktop
██████████████████  ████████   OS: Manjaro Linux x86_64
██████████████████  ████████   Host: Alienware Aurora Ryzen Edition 2.1.2
████████            ████████   Kernel: 6.6.30-2-MANJARO
████████  ████████  ████████   Uptime: 8 mins
████████  ████████  ████████   Packages: 1654 (pacman)
████████  ████████  ████████   Shell: bash 5.2.26
████████  ████████  ████████   Resolution: 3440x1440
████████  ████████  ████████   DE: Plasma 6.0.4
████████  ████████  ████████   WM: KWin
████████  ████████  ████████   Theme: [Plasma], Breeze [GTK2/3]
████████  ████████  ████████   Icons: [Plasma], breeze [GTK2/3]
████████  ████████  ████████   Terminal: yakuake
                              CPU: AMD Ryzen 9 5900X (24) @ 3.700GHz
                              GPU: NVIDIA GeForce GT 710
                              Memory: 7185MiB / 32018MiB
Moderator edit: In the future, please use proper formatting: [HowTo] Post command output and file content as formatted text
Remove the AUR packages you installed.
Noobie here
All AUR PACKAGES ?
If not
Quick way to know how to remove the right one ?
tks !!!
gcc12 is in AUR :wink:
removed 2 gcc12 packaged and the update is going through now !
TKS !!!
