Hello everyone,
as i connect my Garmin Smartwatch (Garmin Instinct) to my Manjaro System via USB, i have to wait a very very long time until it shows up in dolphin.
When i plug in the usb cable and type
sudo dmesg
this is the output
[ 1783.282198] usb 3-1: new full-speed USB device number 17 using xhci_hcd
[ 1783.653739] usb 3-1: New USB device found, idVendor=091e, idProduct=0003, bcdDevice= 0.01
[ 1783.653743] usb 3-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 1783.657541] garmin_gps 3-1:1.0: Garmin GPS usb/tty converter detected
[ 1783.657585] usb 3-1: Garmin GPS usb/tty converter now attached to ttyUSB0
when i use
lsblk
i can see
sda 8:0 0 3,6T 0 disk
ââsda1 8:1 0 3,6T 0 part /media/backup
sdb 8:16 0 1,8T 0 disk
ââsdb1 8:17 0 1,8T 0 part /media/backup_usb
nvme0n1 259:0 0 931,5G 0 disk
âânvme0n1p1 259:1 0 922,7G 0 part /
âânvme0n1p2 259:2 0 8,8G 0 part [SWAP]
and using
lsusb
also shows the garmin device
Is there a service or something i can trigger, to get the usb-device mounted earlier to not have to wait like 5 minutes?
Thanks a lot
System information:
System: Host: sebastian-manjaro Kernel: 5.14.0-0-MANJARO x86_64 bits: 64 Desktop: KDE Plasma 5.22.5 Distro: Manjaro Linux
Machine: Type: Desktop Mobo: ASUSTeK model: Z170 PRO GAMING v: Rev X.0x serial: <superuser required>
UEFI-[Legacy]: American Megatrends v: 3805 date: 05/16/2018
CPU: Info: Quad Core model: Intel Core i7-6700K bits: 64 type: MT MCP cache: L2: 8 MiB
Speed: 900 MHz min/max: 800/4200 MHz Core speeds (MHz): 1: 900 2: 900 3: 900 4: 900 5: 900 6: 900 7: 897 8: 900
Graphics: Device-1: NVIDIA GP106 [GeForce GTX 1060 6GB] driver: nvidia v: 470.63.01
Display: x11 server: X.Org 1.20.13 driver: loaded: nvidia resolution: 3440x1440~50Hz
OpenGL: renderer: NVIDIA GeForce GTX 1060 6GB/PCIe/SSE2 v: 4.6.0 NVIDIA 470.63.01
Audio: Device-1: Intel 100 Series/C230 Series Family HD Audio driver: snd_hda_intel
Device-2: NVIDIA GP106 High Definition Audio driver: snd_hda_intel
Sound Server-1: ALSA v: k5.14.0-0-MANJARO running: yes
Sound Server-2: PulseAudio v: 15.0 running: yes
Sound Server-3: PipeWire v: 0.3.34 running: yes
Network: Device-1: Intel Ethernet I219-V driver: e1000e
IF: enp0s31f6 state: up speed: 1000 Mbps duplex: full mac: 70:4d:7b:66:8e:96
Device-2: Intel Wireless 7265 driver: iwlwifi
IF: wlp3s0 state: down mac: ae:5f:52:21:af:50
Bluetooth: Device-1: Intel Bluetooth wireless interface type: USB driver: btusb
Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running rfk-block: hardware: no software: yes
address: see --recommends
Drives: Local Storage: total: 6.37 TiB used: 1.77 TiB (27.7%)
ID-1: /dev/nvme0n1 vendor: Western Digital model: WDS100T3X0C-00SJG0 size: 931.51 GiB
ID-2: /dev/sda vendor: Western Digital model: WD40EFRX-68WT0N0 size: 3.64 TiB
ID-3: /dev/sdb type: USB vendor: Western Digital model: WD20EARX-00PASB0 size: 1.82 TiB
Partition: ID-1: / size: 907.15 GiB used: 749.98 GiB (82.7%) fs: ext4 dev: /dev/nvme0n1p1
Swap: ID-1: swap-1 type: partition size: 8.8 GiB used: 0 KiB (0.0%) dev: /dev/nvme0n1p2
Sensors: System Temperatures: cpu: 29.8 C mobo: 27.8 C gpu: nvidia temp: 57 C
Info: Processes: 291 Uptime: 42m Memory: 62.75 GiB used: 4.33 GiB (6.9%) Shell: Bash inxi: 3.3.06
