Garbled screen in some applications
I don’t think it’s their hardware failing. I’m experiencing the same problem on a nearly identical system:
System Information
  • KDE Plasma Version: 6.3.4
  • KDE Frameworks Version: 6.12.0
  • Qt Version: 6.9.0
  • Kernel Version: 6.6.85-2-MANJARO (64-bit)
  • Graphics Platform: X11
  • Processors: 16 × AMD Ryzen 7 PRO 7840U w/ Radeon 780M Graphics
  • Memory: 58.5 GiB of RAM
  • Graphics Processor: AMD Radeon 780M
  • Manufacturer: LENOVO
  • System Version: ThinkPad P16s Gen 2
Inxi Output
  Kernel: 6.6.85-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    root=UUID=b654cffc-bb78-4706-8854-b63493e6e62c rw quiet
    cryptdevice=UUID=bf642133-6529-4799-b595-82d890e1220c:luks-bf642133-6529-4799-b595-82d890e1220c
    root=/dev/mapper/luks-bf642133-6529-4799-b595-82d890e1220c splash
    resume=/dev/mapper/luks-e70bcb06-0ec6-45da-acb4-986ca2e06ef4
    udev.log_priority=3
  Desktop: KDE Plasma v: 6.3.4 tk: Qt v: N/A info: frameworks v: 6.12.0
  Type: Laptop System: LENOVO product: 21K9001NUS v: ThinkPad P16s Gen 2
  Mobo: LENOVO model: 21K9001NUS v: SDK0T76530 WIN
    serial: <superuser required> part-nu: LENOVO_MT_21K9_BU_Think_FM_ThinkPad
    P16s Gen 2 uuid: <superuser required> UEFI: LENOVO v: R2FET61W (1.41 )
    date: 11/15/2024
  ID-1: BAT0 charge: 82.0 Wh (95.3%) condition: 86.0/86.0 Wh (100.0%)
    volts: 16.7 min: 15.5 model: Celxpert 5B10W51872 type: Li-poly
    serial: <filter> status: not charging cycles: 30
  Device-1: hidpp_battery_0 model: Logitech MX Ergo Multi-Device Trackball
    serial: <filter> charge: 50% (should be ignored) rechargeable: yes
    status: charging
  System RAM: total: 64 GiB available: 58.51 GiB used: 7.4 GiB (12.6%)
  Array-1: capacity: 64 GiB slots: 4 modules: 4 EC: None
  Device-1: Channel-A DIMM 0 type: LPDDR5 detail: synchronous unbuffered
    (unregistered) size: 16 GiB speed: 6400 MT/s volts: curr: 0.5 min: 0.5
    max: 0.5 width (bits): data: 32 total: 32 manufacturer: Micron Technology
    part-no: MT62F4G32D8DV-026 WT serial: N/A
  Device-2: Channel-B DIMM 0 type: LPDDR5 detail: synchronous unbuffered
  Device-3: Channel-C DIMM 0 type: LPDDR5 detail: synchronous unbuffered
  Device-4: Channel-D DIMM 0 type: LPDDR5 detail: synchronous unbuffered
  Info: model: AMD Ryzen 7 PRO 7840U w/ Radeon 780M Graphics bits: 64
    type: MT MCP arch: Zen 4 gen: 4 level: v4 note: check built: 2022+
    process: TSMC n5 (5nm) family: 0x19 (25) model-id: 0x74 (116) stepping: 1
    microcode: 0xA704107
    smt: enabled cache: L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 8 MiB
    desc: 8x1024 KiB L3: 16 MiB desc: 1x16 MiB
  Speed (MHz): avg: 1397 min/max: 400/5132 scaling: driver: amd-pstate-epp
    governor: powersave cores: 1: 1397 2: 1397 3: 1397 4: 1397 5: 1397 6: 1397
    7: 1397 8: 1397 9: 1397 10: 1397 11: 1397 12: 1397 13: 1397 14: 1397
    15: 1397 16: 1397 bogomips: 105436
    apic arat avx avx2 avx512_bf16 avx512_bitalg avx512_vbmi2 avx512_vnni
    avx512_vpopcntdq avx512bw avx512cd avx512dq avx512f avx512ifma avx512vbmi
    avx512vl bmi1 bmi2 bpext cat_l3 cdp_l3 clflush clflushopt clwb clzero
    cmov cmp_legacy constant_tsc cpb cppc cpuid cqm cqm_llc cqm_mbm_local
    cqm_mbm_total cqm_occup_llc cr8_legacy cx16 cx8 de decodeassists erms
    extapic extd_apicid f16c flush_l1d flushbyasid fma fpu fsgsbase fsrm fxsr
    fxsr_opt gfni ht hw_pstate ibpb ibrs ibrs_enhanced ibs invpcid irperf
    lahf_lm lbrv lm mba mca mce misalignsse mmx mmxext monitor movbe msr mtrr
    mwaitx nonstop_tsc nopl npt nrip_save nx ospke osvw overflow_recov pae
    perfmon_v2 pfthreshold pge pku pni popcnt pse pse36 rapl rdpid rdpru
    rdrand rdseed rdt_a rdtscp rep_good sep sha_ni skinit smap smca smep ssbd
    sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce
    topoext tsc tsc_scale umip user_shstk v_spec_ctrl v_vmsave_vmload vaes
    vgif vmcb_clean vme vmmcall vnmi vpclmulqdq wbnoinvd wdt x2apic x2avic
    conditional; STIBP: always-on; RSB filling; PBRSB-eIBRS: Not affected;
    BHI: Not affected
  Device-1: Advanced Micro Devices [AMD/ATI] Phoenix1 vendor: Lenovo
    driver: amdgpu v: kernel arch: RDNA-3 code: Phoenix process: TSMC n4 (4nm)
    built: 2023+ pcie: gen: 4 speed: 16 GT/s lanes: 16 ports:
    active: DP-9,eDP-1 empty: DP-1, DP-2, DP-3, DP-4, DP-5, DP-6, DP-7, DP-8,
    HDMI-A-1 bus-ID: 64:00.0 chip-ID: 1002:15bf class-ID: 0300 temp: 39.0 C
  Device-2: Bison Integrated Camera driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-1:2 chip-ID: 5986:118c
  Device-3: Logitech BRIO Ultra HD Webcam
    driver: hid-generic,snd-usb-audio,usbhid,uvcvideo type: USB rev: 3.1
    speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 8-1.3.1:5
    chip-ID: 046d:085e class-ID: 0300 serial: <filter>
  Display: x11 server: X.Org v: 21.1.16 with: Xwayland v: 24.1.6
    compositor: kwin_x11 driver: X: loaded: amdgpu unloaded: modesetting
    alternate: fbdev,vesa dri: radeonsi gpu: amdgpu display-ID: :0 screens: 1
  Screen-1: 0 s-res: 7680x2400 s-dpi: 144 s-size: 1353x423mm (53.27x16.65")
    s-diag: 1418mm (55.81")
  Monitor-1: DP-9 mapped: DisplayPort-8 pos: primary,bottom-l
    model: LG (GoldStar) ULTRAFINE serial: <filter> built: 2023 res:
    mode: 3840x2160 hz: 30 scale: 100% (1) dpi: 382 gamma: 1.2 chroma: red:
    x: 0.682 y: 0.318 green: x: 0.259 y: 0.678 blue: x: 0.149 y: 0.059 white:
    x: 0.314 y: 0.329 size: 255x255mm (10.04x10.04") diag: 806mm (31.7")
    ratio: 16:9 modes: 1920x1080, 3840x2160, 2560x1440, 1280x720, 1024x768,
    800x600, 720x576, 720x480, 640x480
  EDID-Warnings: 1: parse_edid: unhandled CEA mode 97 2: parse_edid:
    unhandled CEA mode 96 3: parse_edid: unhandled CEA mode 95 4: parse_edid:
    unhandled CEA mode 94 5: parse_edid: unhandled CEA mode 93
  Monitor-2: eDP-1 mapped: eDP pos: top-right model: Samsung 0x4165
    built: 2021 res: mode: 3840x2400 hz: 60 scale: 100% (1) dpi: 284 gamma: 1.2
    chroma: red: x: 0.682 y: 0.322 green: x: 0.235 y: 0.725 blue: x: 0.137
    y: 0.047 white: x: 0.314 y: 0.329 size: 344x215mm (13.54x8.46")
    diag: 406mm (16") ratio: 16:10 modes: 3840x2400, 1920x1200, 1920x1080,
    1600x1200, 1680x1050, 1280x1024, 1440x900, 1280x800, 1280x720, 1024x768,
    800x600, 640x480
    device: 1 drv: swrast gbm: drv: kms_swrast surfaceless: drv: radeonsi x11:
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 25.0.3-arch1.1
    glx-v: 1.4 direct-render: yes renderer: AMD Radeon 780M (radeonsi phoenix
    LLVM 19.1.7 DRM 3.54 6.6.85-2-MANJARO) device-ID: 1002:15bf
    memory: 3.91 GiB unified: no
  API: Vulkan v: 1.4.309 layers: 4 device: 0 type: integrated-gpu name: AMD
    Radeon 780M (RADV PHOENIX) driver: mesa radv v: 25.0.3-arch1.1
    device-ID: 1002:15bf surfaces: xcb,xlib
    de: kscreen-console,kscreen-doctor gpu: amdgpu_top wl: wayland-info
    x11: xdpyinfo, xprop, xrandr
  Device-1: Advanced Micro Devices [AMD/ATI] Rembrandt Radeon High Definition
    Audio vendor: Lenovo driver: snd_hda_intel v: kernel pcie: gen: 4
    speed: 16 GT/s lanes: 16 bus-ID: 64:00.1 chip-ID: 1002:1640 class-ID: 0403
  Device-2: Advanced Micro Devices [AMD] ACP/ACP3X/ACP6x Audio Coprocessor
    vendor: Lenovo driver: snd_pci_ps v: kernel alternate: snd_pci_acp3x,
    snd_rn_pci_acp3x, snd_pci_acp5x, snd_pci_acp6x, snd_acp_pci,
    snd_rpl_pci_acp6x, snd_sof_amd_renoir, snd_sof_amd_rembrandt,
    snd_sof_amd_vangogh pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 64:00.5
    chip-ID: 1022:15e2 class-ID: 0480
    vendor: Lenovo driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
    lanes: 16 bus-ID: 64:00.6 chip-ID: 1022:15e3 class-ID: 0403
  Device-4: Audio-Technica ATR2100-USB
    driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 1.1 speed: 12 Mb/s
    lanes: 1 mode: 1.1 bus-ID: 7-1.1.2:6 chip-ID: 0909:001b class-ID: 0300
  Device-5: Lenovo ThinkPad USB-C Dock Audio
    driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 2.0 speed: 12 Mb/s
    lanes: 1 mode: 1.1 bus-ID: 7-1.2:4 chip-ID: 17ef:30b0 class-ID: 0300
    serial: <filter>
  Device-6: Logitech BRIO Ultra HD Webcam
  API: ALSA v: k6.6.85-2-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.4.1 status: off with: pipewire-media-session
    status: active tools: pw-cli
  Server-3: PulseAudio v: 17.0-43-g3e2bb status: active
    with: pulseaudio-alsa type: plugin tools: pacat,pactl
    vendor: Lenovo driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
    port: 6000 bus-ID: 01:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp1s0f0 state: down mac: <filter>
  Device-2: Qualcomm QCNFA765 Wireless Network Adapter vendor: Lenovo
    driver: ath11k_pci v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 1
    bus-ID: 02:00.0 chip-ID: 17cb:1103 class-ID: 0280
  Device-3: Realtek RTL8153 Gigabit Ethernet Adapter driver: r8152 type: USB
    rev: 3.2 speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 8-1.1:3
    chip-ID: 0bda:8153 class-ID: 0000 serial: <filter>
  IF: enp102s0f4u1u1 state: up speed: 1000 Mbps duplex: full mac: <filter>
  IF-ID-1: br-01fab31d9097 state: down mac: <filter>
  IF-ID-2: br-070224052f36 state: down mac: <filter>
  IF-ID-3: br-384aefd0c77d state: up speed: 10000 Mbps duplex: unknown
    mac: <filter>
  IP v6: <filter> virtual: proto kernel_ll scope: link
  IF-ID-4: br-43d908826d20 state: down mac: <filter>
  IF-ID-5: br-4a313c7a44f4 state: down mac: <filter>
  IF-ID-6: br-6a6f86073b21 state: down mac: <filter>
  IF-ID-7: br-7dd52d063a36 state: down mac: <filter>
  IF-ID-8: br-8a51ac8f1b96 state: down mac: <filter>
  IF-ID-9: br-8b78a38d33a7 state: down mac: <filter>
  IF-ID-10: br-9339f05036c9 state: up speed: 10000 Mbps duplex: unknown
    mac: <filter>
  IF-ID-11: br-a54f59b656a1 state: down mac: <filter>
  IF-ID-12: br-c5edc4349333 state: down mac: <filter>
  IF-ID-13: br-dee65ee77df2 state: down mac: <filter>
  IF-ID-14: br-eb6b8f1eea62 state: up speed: 10000 Mbps duplex: unknown
    mac: <filter>
  IF-ID-15: br-fb224ccfdf45 state: down mac: <filter>
  IF-ID-16: br-fe81f822a80c state: down mac: <filter>
  IF-ID-17: docker0 state: down mac: <filter>
  IF-ID-18: veth1089621 state: up speed: 10000 Mbps duplex: full
    mac: <filter>
  IF-ID-19: veth2e4d80b state: up speed: 10000 Mbps duplex: full
    mac: <filter>
  IF-ID-20: veth35dd2b6 state: up speed: 10000 Mbps duplex: full
    mac: <filter>
  IF-ID-21: veth4176217 state: up speed: 10000 Mbps duplex: full
    mac: <filter>
  IF-ID-22: veth67baf95 state: up speed: 10000 Mbps duplex: full
    mac: <filter>
  IF-ID-23: vethf0dffeb state: up speed: 10000 Mbps duplex: full
    mac: <filter>
  Device-1: USI driver: btusb v: 0.8 type: USB rev: 1.1 speed: 12 Mb/s
    lanes: 1 mode: 1.1 bus-ID: 1-3.1:5 chip-ID: 10ab:9309 class-ID: e001
  Report: btmgmt ID: hci0 rfk-id: 1 state: up address: <filter> bt-v: 5.3
    lmp-v: 12 status: discoverable: no pairing: no class-ID: 6c010c
  Device-1: luks-bf642133-6529-4799-b595-82d890e1220c maj-min: 254:0
    type: LUKS dm: dm-0 size: 1.76 TiB
  Components:
  p-1: nvme0n1p2 maj-min: 259:2 size: 1.76 TiB
  Device-2: luks-e70bcb06-0ec6-45da-acb4-986ca2e06ef4 maj-min: 254:1
    type: LUKS dm: dm-1 size: 64.42 GiB
  Components:
  p-1: nvme0n1p3 maj-min: 259:3 size: 64.42 GiB
  Local Storage: total: 1.82 TiB used: 539.64 GiB (29.0%)
    model: WD BLACK SN850X 2000GB size: 1.82 TiB block-size: physical: 512 B
    fw-rev: 620331WD temp: 41.9 C scheme: GPT
  ID-1: / raw-size: 1.76 TiB size: 1.73 TiB (98.37%) used: 539.6 GiB (30.5%)
    fs: ext4 dev: /dev/dm-0 maj-min: 254:0
    mapped: luks-bf642133-6529-4799-b595-82d890e1220c label: N/A
    uuid: b654cffc-bb78-4706-8854-b63493e6e62c
    used: 448 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
    uuid: C167-3374
  ID-1: swap-1 type: partition size: 64.42 GiB used: 42 MiB (0.1%)
    priority: -2 dev: /dev/dm-1 maj-min: 254:1
    mapped: luks-e70bcb06-0ec6-45da-acb4-986ca2e06ef4 label: swap
    uuid: 5d9c286b-4c9f-4e91-b61b-9ecbf8d9a3e0
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 5 rev: 2.0
  Device-1: 1-2:2 info: Logitech Unifying Receiver type: keyboard,mouse,HID
    driver: logitech-djreceiver,usbhid interfaces: 3 rev: 2.0
    chip-ID: 046d:c52b class-ID: 0300
  Hub-2: 1-3:3 info: Genesys Logic Hub ports: 2 rev: 2.0
  Device-1: 1-3.1:5 info: USI type: bluetooth driver: btusb interfaces: 2
    rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 100mA
  Device-2: 1-5:4 info: Shenzhen Goodix USB2.0 MISC type: <vendor specific>
    driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
    mode: 1.1 power: 100mA chip-ID: 27c6:6594 class-ID: ef00 serial: <filter>
  Hub-3: 2-0:1 info: super-speed hub ports: 2 rev: 3.1
  Hub-4: 3-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  Device-1: 3-1:2 info: Bison Integrated Camera type: video driver: uvcvideo
    interfaces: 5 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0
    power: 500mA chip-ID: 5986:118c class-ID: fe01 serial: <filter>
  Hub-5: 4-0:1 info: super-speed hub ports: 1 rev: 3.1
  Hub-6: 5-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  Hub-7: 6-0:1 info: super-speed hub ports: 1 rev: 3.1
  Hub-8: 7-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  Hub-9: 7-1:2 info: Lenovo USB2.0 Hub ports: 3 rev: 2.0
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 17ef:30af
  Hub-10: 7-1.1:3 info: Lenovo USB2.0 Hub ports: 4 rev: 2.1
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 17ef:30ac
  Device-1: 7-1.1.2:6 info: Audio-Technica ATR2100-USB type: audio,HID
    driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 1.1
  Hub-11: 7-1.1.3:7 info: Lenovo USB2.0 Hub ports: 4 rev: 2.1
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 17ef:30ae
  Device-1: 7-1.1.3.3:8 info: Microdia Backlit Gaming Keyboard
    type: keyboard,mouse driver: hid-generic,usbhid interfaces: 2 rev: 2.0
    speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 400mA
    chip-ID: 0c45:652f class-ID: 0301
  Device-2: 7-1.2:4 info: Lenovo ThinkPad USB-C Dock Audio type: audio,HID
    driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 2.0
    speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 30mA
    chip-ID: 17ef:30b0 class-ID: 0300 serial: <filter>
  Device-3: 7-1.3:5 info: Lenovo 40AY type: billboard driver: N/A
    chip-ID: 17ef:30a9 class-ID: 1100 serial: <filter>
  Hub-12: 8-0:1 info: super-speed hub ports: 1 rev: 3.1
  Hub-13: 8-1:2 info: Lenovo USB3.1 Hub ports: 4 rev: 3.2
    speed: 10 Gb/s (1.16 GiB/s) lanes: 1 mode: 3.2 gen-2x1 chip-ID: 17ef:30ab
  Device-1: 8-1.1:3 info: Realtek RTL8153 Gigabit Ethernet Adapter
    type: Network driver: r8152 interfaces: 1 rev: 3.2
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 power: 112mA
  Hub-14: 8-1.3:4 info: Lenovo USB3.1 Hub ports: 4 rev: 3.2
    speed: 10 Gb/s (1.16 GiB/s) lanes: 1 mode: 3.2 gen-2x1 chip-ID: 17ef:30ad
  Device-1: 8-1.3.1:5 info: Logitech BRIO Ultra HD Webcam
    type: video,audio,HID driver: hid-generic,snd-usb-audio,usbhid,uvcvideo
    interfaces: 6 rev: 3.1 speed: 5 Gb/s (596.0 MiB/s) lanes: 1
    mode: 3.2 gen-1x1 power: 896mA chip-ID: 046d:085e class-ID: 0300
    serial: <filter>
  System Temperatures: cpu: 44.0 C mobo: N/A gpu: amdgpu temp: 39.0 C
  Fan Speeds (rpm): fan-1: 2637 fan-2: 2637
  Packages: 1768 pm: pacman pkgs: 1763 libs: 506 tools: pamac,yay pm: flatpak
    pkgs: 5
    1: http://mirror.fcix.net/manjaro/stable/$repo/$arch
    2: https://codingflyboy.mm.fcix.net/manjaro/stable/$repo/$arch
    3: https://mirrors.ocf.berkeley.edu/manjaro/stable/$repo/$arch
    4: https://quantum-mirror.hu/mirrors/pub/manjaro/stable/$repo/$arch
    5: https://mirror.dkm.cz/manjaro/stable/$repo/$arch
    6: https://mirror.easyname.at/manjaro/stable/$repo/$arch
    7: https://mirrors.eric.ovh/manjaro/stable/$repo/$arch
    8: https://ftp.psnc.pl/linux/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 466
  1: cpu: 25.7% command: firefox pid: 4812 mem: 658.1 MiB (1.0%)
  2: cpu: 10.3% command: firefox pid: 5327 mem: 234.1 MiB (0.3%)
  3: cpu: 7.1% command: firefox pid: 5037 mem: 673.4 MiB (1.1%)
  4: cpu: 4.4% command: firefox pid: 5029 mem: 547.4 MiB (0.9%)
  5: cpu: 4.2% command: slack pid: 5745 mem: 428.5 MiB (0.7%)
  Memory top: 5 of 466
  1: mem: 717.7 MiB (1.1%) command: plasmashell pid: 3079 cpu: 1.2%
  2: mem: 673.4 MiB (1.1%) command: firefox pid: 5037 cpu: 7.1%
  3: mem: 658.1 MiB (1.0%) command: firefox pid: 4812 cpu: 25.7%
  4: mem: 547.4 MiB (0.9%) command: firefox pid: 5029 cpu: 4.4%
  5: mem: 502.5 MiB (0.8%) command: firefox pid: 5033 cpu: 3.4%
  Processes: 466 Power: uptime: 13m states: freeze,mem,disk suspend: s2idle
    image: 23.39 GiB services: org_kde_powerdevil, power-profiles-daemon,
    upowerd Init: systemd v: 257 default: graphical tool: systemctl
  Compilers: clang: 19.1.7 gcc: 14.2.1 Shell: Zsh v: 5.9 default: Bash
    v: 5.2.37 running-in: konsole inxi: 3.3.38
Journal log
I did manage to pull a journal log from before my system glitched and completely froze:
Apr 18 17:24:33 firefox[375690]: [GFX1-]: RenderCompositorSWGL failed mapping default framebuffer, no dt
Apr 18 17:25:38 rtkit-daemon[2576]: Supervising 17 threads of 6 processes of 1 users.
Apr 18 17:25:38 rtkit-daemon[2576]: Successfully made thread 382168 of process 375690 owned by '1000' RT at priority 10.
Apr 18 17:25:38 rtkit-daemon[2576]: Supervising 18 threads of 6 processes of 1 users.
Apr 18 17:25:41 firefox[375690]: ATTENTION: default value of option mesa_glthread overridden by environment.
Apr 18 17:27:29 onedrive[3189]: Attempting to contact Microsoft OneDrive Login Service
Apr 18 17:27:30 onedrive[3189]: Successfully reached Microsoft OneDrive Login Service
Apr 18 17:27:30 onedrive[3189]: Starting a sync with Microsoft OneDrive
Apr 18 17:27:30 onedrive[3189]: Syncing changes from Microsoft OneDrive ...
Apr 18 17:27:32 kernel: amdgpu 0000:64:00.0: amdgpu: [gfxhub] page fault (src_id:0 ring:24 vmid:7 pasid:32781, for process firefox pid 375690 thread firefox:cs0 pid 375774)
Apr 18 17:27:32 kernel: amdgpu 0000:64:00.0: amdgpu:   in page starting at address 0x0000800146200000 from client 10
Apr 18 17:27:32 kernel: amdgpu 0000:64:00.0: amdgpu: GCVM_L2_PROTECTION_FAULT_STATUS:0x00701030
Apr 18 17:27:32 kernel: amdgpu 0000:64:00.0: amdgpu:          Faulty UTCL2 client ID: TCP (0x8)
Apr 18 17:27:32 kernel: amdgpu 0000:64:00.0: amdgpu:          MORE_FAULTS: 0x0
Apr 18 17:27:32 kernel: amdgpu 0000:64:00.0: amdgpu:          WALKER_ERROR: 0x0
Apr 18 17:27:32 kernel: amdgpu 0000:64:00.0: amdgpu:          PERMISSION_FAULTS: 0x3
Apr 18 17:27:32 kernel: amdgpu 0000:64:00.0: amdgpu:          MAPPING_ERROR: 0x0
Apr 18 17:27:32 kernel: amdgpu 0000:64:00.0: amdgpu:          RW: 0x0
Apr 18 17:27:32 onedrive[3189]: Sync with Microsoft OneDrive is complete
Apr 18 17:27:42 kernel: [drm:amdgpu_job_timedout [amdgpu]] *ERROR* ring gfx_0.0.0 timeout, but soft recovered
Apr 18 17:27:42 firefox[375690]: [GFX1-]: Detect DeviceReset DeviceResetReason::RESET DeviceResetDetectPlace::WR_POST_UPDATE in Parent process
Apr 18 17:27:42 firefox[375690]: ATTENTION: default value of option mesa_glthread overridden by environment.
Apr 18 17:27:42 kernel: amdgpu 0000:64:00.0: amdgpu: [gfxhub] page fault (src_id:0 ring:40 vmid:7 pasid:32781, for process firefox pid 375690 thread firefox:cs0 pid 375774)
Apr 18 17:27:42 kernel: amdgpu 0000:64:00.0: amdgpu:   in page starting at address 0x0000800146201000 from client 10
Apr 18 17:27:42 kernel: amdgpu 0000:64:00.0: amdgpu: GCVM_L2_PROTECTION_FAULT_STATUS:0x00741051
Apr 18 17:27:42 kernel: amdgpu 0000:64:00.0: amdgpu:          Faulty UTCL2 client ID: TCP (0x8)
Apr 18 17:27:42 kernel: amdgpu 0000:64:00.0: amdgpu:          MORE_FAULTS: 0x1
Apr 18 17:27:42 kernel: amdgpu 0000:64:00.0: amdgpu:          WALKER_ERROR: 0x0
Apr 18 17:27:42 kernel: amdgpu 0000:64:00.0: amdgpu:          PERMISSION_FAULTS: 0x5
Apr 18 17:27:42 kernel: amdgpu 0000:64:00.0: amdgpu:          MAPPING_ERROR: 0x0
Apr 18 17:27:42 kernel: amdgpu 0000:64:00.0: amdgpu:          RW: 0x1
Apr 18 17:27:42 kernel: amdgpu 0000:64:00.0: amdgpu:   in page starting at address 0x0000800146200000 from client 10
Apr 18 17:27:42 kernel: amdgpu 0000:64:00.0: amdgpu: GCVM_L2_PROTECTION_FAULT_STATUS:0x00000000
Apr 18 17:27:42 kernel: amdgpu 0000:64:00.0: amdgpu:          Faulty UTCL2 client ID: CB/DB (0x0)
Apr 18 17:27:42 kernel: amdgpu 0000:64:00.0: amdgpu:          MORE_FAULTS: 0x0
Apr 18 17:27:42 kernel: amdgpu 0000:64:00.0: amdgpu:          PERMISSION_FAULTS: 0x0
Apr 18 17:27:42 kernel: amdgpu 0000:64:00.0: amdgpu:          RW: 0x0
Apr 18 17:27:53 kernel: [drm:amdgpu_dm_atomic_check [amdgpu]] *ERROR* [CRTC:79:crtc-0] hw_done or flip_done timed out
Apr 18 17:28:04 kernel: [drm:amdgpu_dm_atomic_check [amdgpu]] *ERROR* [CRTC:79:crtc-0] hw_done or flip_done timed out
Apr 18 17:28:11 slack[3958]: [0418/172811.681819:ERROR:directory_reader_posix.cc(43)] opendir /home/USERNAME/.config/Slack/Crashpad/attachments/7110394b-a227-4e4a-81e5-bd85d920f286: No such file or directory (2)
Apr 18 17:28:44 kernel: [drm:amdgpu_job_timedout [amdgpu]] *ERROR* ring comp_1.3.0 timeout, signaled seq=7621, emitted seq=7623
Apr 18 17:28:44 kernel: [drm:amdgpu_job_timedout [amdgpu]] *ERROR* Process information: process firefox pid 375690 thread firefox:cs0 pid 375774
Apr 18 17:28:44 kernel: amdgpu 0000:64:00.0: amdgpu: GPU reset begin!
Apr 18 17:28:45 kernel: amdgpu 0000:64:00.0: amdgpu: MODE2 reset
Apr 18 17:28:45 kernel: amdgpu 0000:64:00.0: amdgpu: GPU reset succeeded, trying to resume
Apr 18 17:28:45 kernel: [drm] PCIE GART of 512M enabled (table at 0x00000080FFD00000).
Apr 18 17:28:45 kernel: [drm] VRAM is lost due to GPU reset!
Apr 18 17:28:45 kernel: amdgpu 0000:64:00.0: amdgpu: SMU is resuming...
Apr 18 17:28:45 kernel: amdgpu 0000:64:00.0: amdgpu: SMU is resumed successfully!
Apr 18 17:28:45 kernel: [drm] DMUB hardware initialized: version=0x08004D00
Apr 18 17:28:46 kernel: [drm] kiq ring mec 3 pipe 1 q 0
Apr 18 17:28:46 kernel: [drm] VCN decode and encode initialized successfully(under DPG Mode).
Apr 18 17:28:46 kernel: amdgpu 0000:64:00.0: [drm:jpeg_v4_0_hw_init [amdgpu]] JPEG decode initialized successfully.
Apr 18 17:28:46 kernel: amdgpu 0000:64:00.0: amdgpu: ring gfx_0.0.0 uses VM inv eng 0 on hub 0
Apr 18 17:28:46 kernel: amdgpu 0000:64:00.0: amdgpu: ring comp_1.0.0 uses VM inv eng 1 on hub 0
Apr 18 17:28:46 kernel: amdgpu 0000:64:00.0: amdgpu: ring comp_1.1.0 uses VM inv eng 4 on hub 0
Apr 18 17:28:46 kernel: amdgpu 0000:64:00.0: amdgpu: ring comp_1.2.0 uses VM inv eng 6 on hub 0
Apr 18 17:28:46 kernel: amdgpu 0000:64:00.0: amdgpu: ring comp_1.3.0 uses VM inv eng 7 on hub 0
Apr 18 17:28:46 kernel: amdgpu 0000:64:00.0: amdgpu: ring comp_1.0.1 uses VM inv eng 8 on hub 0
Apr 18 17:28:46 kernel: amdgpu 0000:64:00.0: amdgpu: ring comp_1.1.1 uses VM inv eng 9 on hub 0
Apr 18 17:28:46 kernel: amdgpu 0000:64:00.0: amdgpu: ring comp_1.2.1 uses VM inv eng 10 on hub 0
Apr 18 17:28:46 kernel: amdgpu 0000:64:00.0: amdgpu: ring comp_1.3.1 uses VM inv eng 11 on hub 0
Apr 18 17:28:46 kernel: amdgpu 0000:64:00.0: amdgpu: ring sdma0 uses VM inv eng 12 on hub 0
Apr 18 17:28:46 kernel: amdgpu 0000:64:00.0: amdgpu: ring vcn_unified_0 uses VM inv eng 0 on hub 8
Apr 18 17:28:46 kernel: amdgpu 0000:64:00.0: amdgpu: ring jpeg_dec uses VM inv eng 1 on hub 8
Apr 18 17:28:46 kernel: amdgpu 0000:64:00.0: amdgpu: ring mes_kiq_3.1.0 uses VM inv eng 13 on hub 0
Apr 18 17:28:46 kernel: amdgpu 0000:64:00.0: amdgpu: recover vram bo from shadow start
Apr 18 17:28:46 kernel: amdgpu 0000:64:00.0: amdgpu: recover vram bo from shadow done
Apr 18 17:28:46 kernel: [drm:amdgpu_cs_ioctl [amdgpu]] *ERROR* Failed to initialize parser -125!
Apr 18 17:28:46 kernel: general protection fault, probably for non-canonical address 0x79726f6d656d2fa5: 0000 [#1] PREEMPT SMP NOPTI
Apr 18 17:28:46 kernel: CPU: 6 PID: 251770 Comm: kworker/u32:7 Not tainted 6.6.85-2-MANJARO #1 e1699a48c9f4d67df013517ef54b0ac21e05602a
Apr 18 17:28:46 kernel: Hardware name: LENOVO 21K9001NUS/21K9001NUS, BIOS R2FET61W (1.41 ) 11/15/2024
Apr 18 17:28:46 kernel: Workqueue: events_unbound commit_work
Apr 18 17:28:46 kernel: RIP: 0010:dm_enable_per_frame_crtc_master_sync+0x8/0xf0 [amdgpu]
Apr 18 17:28:46 kernel: Code: ac 00 00 00 e9 6f ff ff ff 66 0f 1f 84 00 00 00 00 00 90 90 90 90 90 90 90 90 90 90 90 90 90 90 90 90 0f 1f 44 00 00 48 89 fe <0f> b6 bf 40 02 00 00 40 80 ff 01 0f 86 c5 00 00 00 31 c9 45 31 c9
Apr 18 17:28:46 kernel: RSP: 0018:ffffc900267e7bd8 EFLAGS: 00010246
Apr 18 17:28:46 kernel: RAX: ffff888115400010 RBX: 79726f6d656d2d65 RCX: ffff8886714cef00
Apr 18 17:28:46 kernel: RDX: ffff8886714cefa8 RSI: 79726f6d656d2d65 RDI: 79726f6d656d2d65
Apr 18 17:28:46 kernel: RBP: ffffc900267e7e38 R08: 0000000000000000 R09: 0000000000000001
Apr 18 17:28:46 kernel: R10: ffff888115400010 R11: 0000000000000001 R12: 0000000000000000
Apr 18 17:28:46 kernel: R13: ffff888200bc9e00 R14: 0000000000000004 R15: ffff888115400010
Apr 18 17:28:46 kernel: FS:  0000000000000000(0000) GS:ffff888f61f80000(0000) knlGS:0000000000000000
Apr 18 17:28:46 kernel: CS:  0010 DS: 0000 ES: 0000 CR0: 0000000080050033
Apr 18 17:28:46 kernel: CR2: 00007fd5bb442000 CR3: 0000000a5f620000 CR4: 0000000000f50ee0
Apr 18 17:28:46 kernel: PKRU: 55555554
Apr 18 17:28:46 kernel: Call Trace:
Apr 18 17:28:46 kernel:  <TASK>
Apr 18 17:28:46 kernel:  ? die_addr+0x36/0x90
Apr 18 17:28:46 kernel:  ? exc_general_protection+0x17d/0x430
Apr 18 17:28:46 kernel:  ? asm_exc_general_protection+0x26/0x30
Apr 18 17:28:46 kernel:  ? dm_enable_per_frame_crtc_master_sync+0x8/0xf0 [amdgpu b48cc040a5adeb562aad6e43c5bc725087b63ce8]
Apr 18 17:28:46 kernel:  ? srso_alias_return_thunk+0x5/0xfbef5
Apr 18 17:28:46 kernel:  amdgpu_dm_atomic_commit_tail+0x555/0x3990 [amdgpu b48cc040a5adeb562aad6e43c5bc725087b63ce8]
Apr 18 17:28:46 kernel:  ? psi_task_switch+0xb7/0x200
Apr 18 17:28:46 kernel:  ? finish_task_switch.isra.0+0x94/0x2f0
Apr 18 17:28:46 kernel:  ? __schedule+0x3f5/0x1420
Apr 18 17:28:46 kernel:  ? dm_crtc_get_scanoutpos+0x82/0xe0 [amdgpu b48cc040a5adeb562aad6e43c5bc725087b63ce8]
Apr 18 17:28:46 kernel:  ? schedule+0x5e/0xd0
Apr 18 17:28:46 kernel:  ? schedule_timeout+0x151/0x160
Apr 18 17:28:46 kernel:  ? dma_fence_default_wait+0x8c/0x270
Apr 18 17:28:46 kernel:  ? __pfx_dma_fence_default_wait_cb+0x10/0x10
Apr 18 17:28:46 kernel:  ? wait_for_completion_timeout+0x144/0x170
Apr 18 17:28:46 kernel:  commit_tail+0x91/0x130
Apr 18 17:28:46 kernel:  process_one_work+0x186/0x390
Apr 18 17:28:46 kernel:  worker_thread+0x280/0x3d0
Apr 18 17:28:46 kernel:  ? __pfx_worker_thread+0x10/0x10
Apr 18 17:28:46 kernel:  kthread+0xe5/0x120
Apr 18 17:28:46 kernel:  ? __pfx_kthread+0x10/0x10
Apr 18 17:28:46 kernel:  ret_from_fork+0x31/0x50
Apr 18 17:28:46 kernel:  ret_from_fork_asm+0x1b/0x30
Apr 18 17:28:46 kernel:  </TASK>
Apr 18 17:28:46 kernel: Modules linked in: tls rfcomm nf_conntrack_netlink iptable_raw xt_nat xt_tcpudp veth xt_conntrack xt_MASQUERADE bridge stp llc ip6table_nat ip6table_filter ip6_tables xt_set ip_set iptable_nat xt_addrtype iptable_filter ccm michael_mic overlay cmac algif_hash algif_skcipher af_alg bnep qrtr_mhi r8153_ecm cdc_ether usbnet intel_rapl_msr intel_rapl_common snd_soc_ps_mach snd_soc_dmic snd_ps_pdm_dma snd_sof_amd_vangogh snd_sof_amd_rembrandt snd_sof_amd_renoir snd_sof_amd_acp snd_sof_pci snd_sof_xtensa_dsp snd_sof vfat snd_sof_utils qrtr fat ath11k_pci snd_soc_core snd_compress ath11k ac97_bus snd_ctl_led snd_pcm_dmaengine snd_hda_codec_realtek qmi_helpers snd_pci_ps snd_hda_codec_generic snd_hda_codec_hdmi snd_rpl_pci_acp6x edac_mce_amd uvcvideo btusb snd_acp_pci mac80211 btrtl videobuf2_vmalloc snd_acp_legacy_common snd_hda_intel snd_usb_audio btintel kvm_amd uvc snd_pci_acp6x snd_intel_dspcfg btbcm videobuf2_memops snd_usbmidi_lib videobuf2_v4l2 snd_intel_sdw_acpi snd_pci_acp5x libarc4 btmtk hid_multitouch
Apr 18 17:28:46 kernel:  snd_rn_pci_acp3x r8169 kvm videodev snd_hda_codec snd_ump ucsi_acpi snd_acp_config realtek bluetooth cfg80211 snd_hda_core snd_rawmidi r8152 sp5100_tco typec_ucsi irqbypass videobuf2_common mdio_devres think_lmi snd_seq_device snd_hwdep snd_soc_acpi rapl pcspkr psmouse typec wmi_bmof firmware_attributes_class thunderbolt mii k10temp snd_pcm mc i2c_piix4 ecdh_generic mhi snd_timer mousedev libphy snd_pci_acp3x joydev roles i2c_hid_acpi i2c_hid amd_pmc mac_hid nft_reject_inet nf_reject_ipv4 nf_reject_ipv6 nft_reject nft_masq nft_ct nft_chain_nat nf_nat nf_conntrack nf_defrag_ipv6 nf_defrag_ipv4 nf_tables libcrc32c uinput i2c_dev crypto_user fuse loop nfnetlink bpf_preload ip_tables x_tables ext4 crc32c_generic crc16 mbcache jbd2 dm_crypt cbc encrypted_keys trusted asn1_encoder tee dm_mod hid_logitech_hidpp hid_logitech_dj usbhid amdgpu crct10dif_pclmul crc32_pclmul crc32c_intel polyval_clmulni i2c_algo_bit polyval_generic drm_ttm_helper gf128mul ttm ghash_clmulni_intel thinkpad_acpi serio_raw sha512_ssse3
Apr 18 17:28:46 kernel:  drm_exec atkbd ledtrig_audio drm_suballoc_helper sha256_ssse3 libps2 platform_profile amdxcp sha1_ssse3 vivaldi_fmap drm_buddy snd aesni_intel nvme gpu_sched soundcore crypto_simd rfkill drm_display_helper nvme_core cryptd ccp xhci_pci video i8042 cec nvme_common xhci_pci_renesas serio wmi
Apr 18 17:28:46 kernel: ---[ end trace 0000000000000000 ]---
Apr 18 17:28:46 kernel: [drm] ring gfx_32782.1.1 was added
Apr 18 17:28:46 kernel: [drm] ring compute_32782.2.2 was added
Apr 18 17:28:46 kernel: [drm] ring sdma_32782.3.3 was added
Apr 18 17:28:46 kernel: [drm] ring gfx_32782.1.1 ib test pass
Apr 18 17:28:46 kernel: [drm] ring compute_32782.2.2 ib test pass
Apr 18 17:28:46 kernel: [drm] ring sdma_32782.3.3 ib test pass
Apr 18 17:28:46 kernel: amdgpu 0000:64:00.0: amdgpu: GPU reset(2) succeeded!
Apr 18 17:28:47 kernel: [drm:amdgpu_dm_atomic_check [amdgpu]] *ERROR* [CRTC:79:crtc-0] hw_done or flip_done timed out
Apr 18 17:28:57 kernel: [drm:amdgpu_dm_atomic_check [amdgpu]] *ERROR* [CRTC:79:crtc-0] hw_done or flip_done timed out
Apr 18 17:30:01 plasmashell[2640]: QRhiGles2: Context is lost.
Apr 18 17:30:01 plasmashell[2640]: Graphics device lost, cleaning up scenegraph and releasing RHI
Apr 18 17:31:11 kernel: usb 1-1: USB disconnect, device number 7
Apr 18 17:32:32 onedrive[3189]: Attempting to contact Microsoft OneDrive Login Service
Apr 18 17:32:33 onedrive[3189]: Successfully reached Microsoft OneDrive Login Service
Apr 18 17:32:33 onedrive[3189]: Starting a sync with Microsoft OneDrive
Apr 18 17:32:33 onedrive[3189]: Performing a full scan of online data to ensure consistent local state
Apr 18 17:36:36 onedrive[3189]: Fetching items from the OneDrive API for Drive ID: 3C392138C1D49805 ......................................................................................................................................................CAUTION:    The JSON element transmitted by the Microsoft OneDrive API includes HTML URL encoded items, which may complicate pattern matching and potentially lead to synchronisation problems for this item.
Apr 18 17:36:39 onedrive[3189]: ..
Apr 18 17:36:43 onedrive[3189]: Processing 14419 applicable JSON items received from Microsoft OneDrive ....
Apr 18 17:36:44 onedrive[3189]: Performing a database consistency and integrity check on locally stored data ..
Apr 18 17:36:44 onedrive[3189]: Scanning the local file system '~/OneDrive' for new data to upload ..
Apr 18 17:36:44 onedrive[3189]: Performing a last examination of the most recent online data within Microsoft OneDrive to complete the reconciliation process
Apr 18 17:36:45 onedrive[3189]: Fetching items from the OneDrive API for Drive ID: 3C392138C1D49805 .
Apr 18 17:36:45 onedrive[3189]: No changes or items that can be applied were discovered while processing the data received from Microsoft OneDrive
Apr 18 17:36:45 onedrive[3189]: Sync with Microsoft OneDrive is complete
Apr 18 17:37:08 systemd-logind[809]: Power key pressed short.
Your post has been moved to a dedicated topic. Please do not add your issues to another member’s Support request. It is best always to create your own topic.
Quick tip: The full inxi command output is the only system information that’s typically needed.
Update Announcements
System Information
While information from *-fetch type apps might be fine for someone wishing to buy your computer, for Support purposes more indepth information is usually needed;
It’s best to ask your system directly. :eyes:
Output of the inxi command with appropriate parameters will achieve this (naturally, formatted according to forum requirements) and will generally be more useful for those wishing to help:
inxi --filter --verbosity=8
or the short form:
inxi -zv8
Required reading
Resources
Have a look at this and the linked thread here.
It has helped a forum member before and I recognise the Ryzen7/AMD780graphics combo that seems to be the culprit.
Adding that second link here to increase visibility.
There a several possible reasons for garbled screens, ranging from bad fonts to faulty graphics, but as there have now been a few similar reports, I dare say this is likely to be the culprit, or at least worth considering.
I gave this a small attempt and I’d say it was inconclusive. I used the live USB for maybe 30 minutes or so, and tried to stress it a little bit; I installed a few apps, watched a 4k youtube video while browsing. I did not see any glitches during that time, however, upon returning to my normal install, I noticed that it also took 30-60 minutes for the glitches to start appearing. It seems like they might get worse as usage time increases, though I’m not entirely sure about that yet.
My point is: I didn’t see the glitches in the live usb, but I might not have used it long enough and/or with enough applications for the glitches to start. Unfortunately, since this is the computer I use for work, I don’t have many opportune moments for me to spend a couple hours on a live usb. I’ll try to respond if I’m able to get more time to try it again, assuming suggestions in the forked thread don’t lead me to any solutions.
As AMD drivers are supplied with the kernel and the APU is fairly recent, I suggest using the latest kernel - perhaps not 6.14 but 6.12.
I use a Thinkpad x13 with the same APU - I have had no issues with screen output.
I tested on youtube on the 4K channel - no problems.
It could be a hardware issue - perhaps run some extensive memory testing overnight?
Just wanted to add on to this that I was encountering the same issues.
It showed up around the same time as the most recent major update to Plasma. (early April 2025)
Often little dots or triangles
https://github.com/user-attachments/assets/a1764a4c-9192-4e3b-8b0a-d2880a2c4112
inxi -zv8         INT ✘  3.3.0 
perl: warning: Setting locale failed.
perl: warning: Please check that your locale settings:
        LANGUAGE = "da",
        LC_ALL = (unset),
        LC_CTYPE = (unset),
        LC_NUMERIC = "en_US.UTF-8",
        LC_COLLATE = (unset),
        LC_TIME = "en_US.UTF-8",
        LC_MESSAGES = (unset),
        LC_MONETARY = "en_US.UTF-8",
        LC_ADDRESS = "en_US.UTF-8",
        LC_IDENTIFICATION = "en_US.UTF-8",
        LC_MEASUREMENT = "en_US.UTF-8",
        LC_PAPER = "en_US.UTF-8",
        LC_TELEPHONE = "en_US.UTF-8",
        LC_NAME = "en_US.UTF-8",
        LANG = "da"
    are supported and installed on your system.
perl: warning: Falling back to the standard locale ("C").
    root=UUID=429e3632-0827-4b73-b3b8-d35529cd74ba rw quiet splash
    udev.log_priority=3
    wm: kwin_x11 vt: 1 dm: SDDM Distro: Manjaro base: Arch Linux
  Type: Laptop System: LENOVO product: 21F8CTO1WW v: ThinkPad T14s Gen 4
  Mobo: LENOVO model: 21F8CTO1WW serial: <superuser required>
    part-nu: LENOVO_MT_21F8_BU_Think_FM_ThinkPad T14s Gen 4
    uuid: <superuser required> UEFI: LENOVO v: R2EET35W (1.16 )
    date: 10/24/2023
  ID-1: BAT0 charge: 34.7 Wh (68.7%) condition: 50.5/57.0 Wh (88.6%)
    power: 7.4 W volts: 15.8 min: 15.4 model: Sunwoda 5B11M90032 type: Li-poly
    serial: <filter> status: discharging cycles: 179
  System RAM: total: 32 GiB available: 30.06 GiB used: 6.63 GiB (22.1%)
    (unregistered) size: 8 GiB speed: 6400 MT/s volts: curr: 0.5 min: 0.5
    part-no: MT62F2G32D4DS-026 WT serial: N/A
    15: 1397 16: 1397 bogomips: 105441
    extapic extd_apicid f16c flush_l1d flushbyasid fma fpu fsgsbase fxsr
    BHI: Not affected
    built: 2023+ pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: eDP-1
    empty: DP-1, DP-2, DP-3, DP-4, DP-5, DP-6, HDMI-A-1 bus-ID: c3:00.0
    chip-ID: 1002:15bf class-ID: 0300 temp: 35.0 C
  Device-2: Syntek Integrated Camera driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-1:2 chip-ID: 174f:11a8
  Screen-1: 0 s-res: 1920x1200 s-dpi: 96 s-size: 508x317mm (20.00x12.48")
    s-diag: 599mm (23.57")
  Monitor-1: eDP-1 mapped: eDP model: LG Display 0x06f7 built: 2021 res:
    mode: 1920x1200 hz: 60 scale: 100% (1) dpi: 161 gamma: 1.2 chroma: red:
    x: 0.600 y: 0.369 green: x: 0.357 y: 0.549 blue: x: 0.153 y: 0.110 white:
    x: 0.314 y: 0.329 size: 302x189mm (11.89x7.44") diag: 356mm (14")
    ratio: 16:10 modes: 1920x1200, 1920x1080, 1600x1200, 1680x1050,
    1280x1024, 1440x900, 1280x800, 1280x720, 1024x768, 800x600, 640x480
    memory: 1000 MiB unified: no
    speed: 16 GT/s lanes: 16 bus-ID: c3:00.1 chip-ID: 1002:1640 class-ID: 0403
    snd_sof_amd_vangogh pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: c3:00.5
    lanes: 16 bus-ID: c3:00.6 chip-ID: 1022:15e3 class-ID: 0403
  Server-2: PipeWire v: 1.4.1 status: active with: 1: pipewire-pulse
  Device-1: Qualcomm QCNFA765 Wireless Network Adapter vendor: Lenovo
    bus-ID: 01:00.0 chip-ID: 17cb:1103 class-ID: 0280
    lanes: 1 mode: 1.1 bus-ID: 1-3.1:4 chip-ID: 10ab:9309 class-ID: e001
  Local Storage: total: 476.94 GiB used: 122.54 GiB (25.7%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: KIOXIA model: N/A
    size: 476.94 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
    lanes: 4 tech: SSD serial: <filter> fw-rev: 1108ANLA temp: 33.9 C
    scheme: GPT
  ID-1: / raw-size: 476.64 GiB size: 468.09 GiB (98.21%)
    used: 122.54 GiB (26.2%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
    label: N/A uuid: 429e3632-0827-4b73-b3b8-d35529cd74ba
    used: 296 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
    uuid: 5842-BF69
  Hub-2: 1-3:2 info: Genesys Logic Hub ports: 2 rev: 2.0
  Device-1: 1-3.1:4 info: USI type: bluetooth driver: btusb interfaces: 2
  Device-2: 1-5:3 info: Shenzhen Goodix USB2.0 MISC type: <vendor specific>
  Device-1: 3-1:2 info: Syntek Integrated Camera type: video
    driver: uvcvideo interfaces: 5 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
    lanes: 1 mode: 2.0 power: 500mA chip-ID: 174f:11a8 class-ID: fe01
    serial: <filter>
  Hub-9: 8-0:1 info: super-speed hub ports: 1 rev: 3.1
  System Temperatures: cpu: 37.0 C mobo: N/A gpu: amdgpu temp: 36.0 C
  Fan Speeds (rpm): fan-1: 0 fan-2: 0
  Packages: pm: pacman pkgs: 1468 libs: 369 tools: pamac
    1: https://mirrors.eric.ovh/manjaro/stable/$repo/$arch
    2: https://ask4.mm.fcix.net/manjaro/stable/$repo/$arch
    3: http://manjaro.mirrors.uk2.net/stable/$repo/$arch
    4: https://manjaro.mirror.garr.it/manjaro/stable/$repo/$arch
    5: http://mirror.fcix.net/manjaro/stable/$repo/$arch
    6: https://muug.ca/mirror/manjaro/stable/$repo/$arch
    7: https://mirrors.ucr.ac.cr/manjaro/stable/$repo/$arch
    8: http://manjaro.grena.ge/stable/$repo/$arch
Processes:
  CPU top: 5 of 374
  1: cpu: 15.5% command: firefox pid: 15883 mem: 762.3 MiB (2.4%)
  2: cpu: 9.9% command: firefox pid: 20661 mem: 273.7 MiB (0.8%)
  3: cpu: 3.8% command: slack pid: 16455 mem: 384.9 MiB (1.2%)
  4: cpu: 2.9% command: Xorg pid: 15193 mem: 188.7 MiB (0.6%)
  5: cpu: 2.9% command: firefox pid: 16226 mem: 465.2 MiB (1.5%)
  Memory top: 5 of 374
  1: mem: 762.3 MiB (2.4%) command: firefox pid: 15883 cpu: 15.5%
  2: mem: 475.5 MiB (1.5%) command: plasmashell pid: 15477 cpu: 0.3%
  3: mem: 465.2 MiB (1.5%) command: firefox pid: 16226 cpu: 2.9%
  4: mem: 384.9 MiB (1.2%) command: slack pid: 16455 cpu: 3.8%
  5: mem: 361.4 MiB (1.1%) command: firefox pid: 16141 cpu: 1.2%
  Processes: 374 Power: uptime: 1h 56m states: freeze,mem,disk suspend: s2idle
    wakeups: 2 hibernate: platform avail: shutdown, reboot, suspend, test_resume
    image: 12.01 GiB services: org_kde_powerdevil,upowerd Init: systemd v: 257
Primarily I see the issue in firefox, chromium, and slack-desktop.
Attempting an update to 6.12 and will report back.
Update: I’m too new to post a reply. But it’s been glitch free since I updated the Kernel.
Looks like the solution on this set of hardware was to update to Kernel 6.12.
I updated to kernel 6.12 a few days ago and so far the issue appears to have stopped for me as well.
