Qaa
18 March 2023 22:52
1
Hello!
When I play games after a while my screen turns blank and i have to do a hard restart to get the monitor up and running again…
OS: Manjaro Linux x86_64
Host: MS-7A31 1.0
Kernel: 6.1.12-1-MANJARO
DE: GNOME 43.3
WM: Mutter
CPU: AMD Ryzen 7 1700X (16) @ 3.400GHz
GPU: AMD ATI Radeon RX 470/480/570/570X/580/580X
Memory: 2714MiB / 15942MiB
Got this error message from command: journalctl --system --boot=-1 --priority=3 | tail --lines=35
kernel: amdgpu 0000:24:00.0: [drm] ERROR [CRTC:53:crtc-0] flip_done timed out
Hi and welcome to the Forum
Please read and follow all advice in this thread:
Difficulty: ★☆☆☆☆
Strong of its many members, the Manjaro support forum can provide you help whenever you have an issue with your Manjaro installation. But in order to work efficiently, we shall also ask you to follow three major points.
Provide context
Simply signaling an issue is rarely enough to understand how it occurred. It is thus important to provide details on how it happened:
Detail prior actions leading to the issue.
List solutions and guides you already tried, with links whene…
Especially:
Difficulty: ★☆☆☆☆
Formatting differences
Discourse – this forum’s engine – uses Markdown to format its posts, and removes “unnecessary” whitespace.
Terminal commands often produce output formatted so that they are better readable by the user, taking advantage of the monospaced font used.
Programming code often rely on indentation to make it more readable.
Using preformatting in Markdown
Markdown includes a pattern to provide preformatting when necessary.
You only need to put the part to form…
If you are unable to boot into your system to provide the needed info, then use a Live-ISO image to boot from a USB-Stick…
Some commands as mentioned in the articles above are:
inxi -v7azy
If you often have a need to do a “Hard reset ” or “Power off ” to get back to your system, then avoid that when possible by following:
Difficulty: ★★☆☆☆
This tutorial was created because people are using a hard power off during freezes, so this will teach you how to turn off your computer when everything is frozen using softer means.
So whenever you see someone saying they had to “Power Off” or “Hard Reset” their system without doing a REISUB, please send them here!
If you’re reading this in response to a question, please click the green link above this text to bring you to the full unabridged text of the tutorial…
Most likely your GPU (or whole system) is over-heating , try to lower your graphics settings in your game…
