Hello all,
For some reason, all windows (terminal, web browser, …) started to get full screen automatically, but deactivate full screen at same time, like flickering. There is no regular interval, it just happen between few minutes interval.
Also, the touch pad stopped to work, and I can’t identify when running libinput list-devices. Actually I can see my wireless keyboard, but the touchpad is not listed there.
Finally, another weird thing is I press LSHIFT + P on my laptop keyboard “nothing happens”, I mean I can’t write P. When I press p alone it works, and also LSHIFT works with others keys. I checked on keyboard layout to show pressed keys and LSHIFT + P doesn’t show anything. However, when using xorg-xev, LSHIFT + P is listed as pressed.
Here is my system configuration:
Kernel: 5.10.70-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=2ac4c4a5-5f31-4100-9370-3146a89847b4 rw quiet apparmor=1
Desktop: MATE 1.26.0 info: mate-panel wm: marco 1.26.0 vt: 7
dm: GDM 40.1, LightDM 1.30.0 Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: SAMSUNG
product: 500R4K/500R5H/5400RK/501R5H/5500RH/500R5S v: P08RDD
serial: <filter> Chassis: type: 9 serial: <filter>
Mobo: SAMSUNG model: NP500R5H-XD1BR v: SGL8623A06-C01-G002-S0001+10.0.10586
serial: <filter> UEFI: American Megatrends v: P08RDD.171.160427.CL
date: 04/27/2016
ID-1: BAT1 charge: 17.1 Wh (100.0%) condition: 17.1/43.1 Wh (39.7%)
volts: 12.5 min: 11.4 model: SAMSUNG Electronics SR Real Battery
type: Li-ion serial: <filter> status: Full cycles: 174
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse serial: <filter>
charge: 55% (should be ignored) rechargeable: yes status: Discharging
Device-2: hidpp_battery_1 model: Logitech Wireless Keyboard K540/K545
serial: <filter> charge: 100% (should be ignored) rechargeable: yes
status: Discharging
RAM: total: 7.67 GiB used: 4.4 GiB (57.4%)
Info: Dual Core model: Intel Core i5-5200U bits: 64 type: MT MCP
arch: Broadwell family: 6 model-id: 3D (61) stepping: 4 microcode: 2F cache:
L2: 3 MiB bogomips: 17564
Speed: 1512 MHz min/max: 500/2700 MHz Core speeds (MHz): 1: 1512 2: 1591
3: 1229 4: 2014
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon avx
avx2 bmi1 bmi2 bts clflush cmov constant_tsc cpuid cpuid_fault cx16 cx8 de
ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority flush_l1d
fma fpu fsgsbase fxsr ht ibpb ibrs ida intel_pt invpcid invpcid_single
lahf_lm lm mca mce md_clear mmx monitor movbe msr mtrr nonstop_tsc nopl nx
pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36
pti pts rdrand rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2
tsc_deadline_timer vme vmx vnmi vpid x2apic xsave xsaveopt xtopology xtpr
Type: l1tf
Device-1: Intel HD Graphics 5500 vendor: Samsung Co driver: i915 v: kernel
bus-ID: 00:02.0 chip-ID: 8086:1616 class-ID: 0300
Device-2: NVIDIA GM108M [GeForce 940M] vendor: Samsung Co driver: nvidia
v: 470.63.01 alternate: nouveau,nvidia_drm bus-ID: 03:00.0
chip-ID: 10de:1347 class-ID: 0302
Device-3: Silicon Motion ATIV VGA Camera type: USB driver: uvcvideo
bus-ID: 2-5:4 chip-ID: 2232:1069 class-ID: 0e02 serial: <filter>
Display: x11 server: X.org 1.20.13 compositor: marco v: 1.26.0 driver:
loaded: intel,nvidia resolution: <missing: xdpyinfo>
OpenGL: renderer: Mesa Intel HD Graphics 5500 (BDW GT2) v: 4.6 Mesa 21.2.3
direct render: Yes
Device-1: Intel Broadwell-U Audio vendor: Samsung Co driver: snd_hda_intel
v: kernel bus-ID: 00:03.0 chip-ID: 8086:160c class-ID: 0403
Device-2: Intel Wildcat Point-LP High Definition Audio vendor: Samsung Co
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:9ca0
class-ID: 0403
Sound Server-1: ALSA v: k5.10.70-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.38 running: no
Device-1: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter
vendor: Samsung Co driver: ath10k_pci v: kernel bus-ID: 01:00.0
chip-ID: 168c:0042 class-ID: 0280
vendor: Samsung Co driver: r8169 v: kernel port: e000 bus-ID: 02:00.0
IF-ID-1: docker0 state: down mac: <filter>
Device-1: Qualcomm Atheros type: USB driver: btusb v: 0.8 bus-ID: 2-4:3
chip-ID: 0cf3:e360 class-ID: e001
Report: bt-adapter ID: hci0 rfk-id: 0 state: up address: <filter>
Local Storage: total: 447.13 GiB used: 120.79 GiB (27.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: SanDisk model: Ultra II 480GB
size: 447.13 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 00RL scheme: GPT
ID-1: / raw-size: 372.53 GiB size: 365.68 GiB (98.16%)
used: 120.78 GiB (33.0%) fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: 2ac4c4a5-5f31-4100-9370-3146a89847b4
ID-2: /boot/efi raw-size: 513 MiB size: 512 MiB (99.80%)
used: 312 KiB (0.1%) fs: vfat dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: FD0E-9EB9
ID-1: swap-1 type: partition size: 7.45 GiB used: 10.5 MiB (0.1%)
priority: -2 dev: /dev/sda4 maj-min: 8:4 label: N/A
uuid: 0331c07a-eca4-4868-9e30-46b2a7e3ad20
ID-1: /dev/sda5 maj-min: 8:5 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-2: /dev/sda6 maj-min: 8:6 size: 66.11 GiB fs: ntfs label: N/A
uuid: AA0ECDF30ECDB899
ID-3: /dev/sda7 maj-min: 8:7 size: 533 MiB fs: ntfs label: N/A
uuid: 027C2DA87C2D9785
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Hub-2: 1-1:2 info: Intel Integrated Hub ports: 8 rev: 2.0 speed: 480 Mb/s
chip-ID: 8087:8001 class-ID: 0900
Hub-3: 2-0:1 info: Full speed (or root) Hub ports: 11 rev: 2.0
Device-1: 2-2:2 info: Logitech Unifying Receiver type: Keyboard,Mouse,HID
power: 98mA chip-ID: 046d:c52b class-ID: 0300
Device-2: 2-4:3 info: Qualcomm Atheros type: Bluetooth driver: btusb
interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 0cf3:e360
class-ID: e001
Device-3: 2-5:4 info: Silicon Motion ATIV VGA Camera type: Video
Device-4: 2-8:5 info: Realtek RTS5129 Card Reader Controller
interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 0bda:0129
class-ID: ff00 serial: <filter>
Hub-4: 3-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 49.0 C mobo: 49.0 C
Processes: 212 Uptime: 5h 9m wakeups: 34 Init: systemd v: 249
tool: systemctl Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: pacman: 1433
lib: 425 Shell: Bash v: 5.1.8 running-in: terminator inxi: 3.3.08
