kromy
5 October 2021 12:54
1
Hi all,
i have a problem with the keyboard of my Fujitsu Lifebook U7410.
The keyboard works just fine in BIOS, LUKS decryption and GRUB, but as soon as a kernel is loaded, it stops working.
It also works in a USB live booted environment and during the installation of the OS.
Already tried different kernels as well as XFCE and KDE as desktop environments but didn’t notice any changes.
I’m using a USB keyboard as a workaround at the moment, but I would love the get rid of this issue.
Thanks in advance
Fabby
7 October 2021 15:01
2
kromy
13 October 2021 12:30
3
Hi Fabby, here is the output of the command:
Kernel: 5.14.7-2-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.14-x86_64
root=UUID=93f46d74-723d-4ef8-a931-3f8df45f5e46 rw quiet
cryptdevice=UUID=6fb7eb67-d384-4065-bf4c-3d66c6edcba3:luks-6fb7eb67-d384-4065-bf4c-3d66c6edcba3
root=/dev/mapper/luks-6fb7eb67-d384-4065-bf4c-3d66c6edcba3 apparmor=1
Desktop: Xfce 4.16.0 tk: Gtk 3.24.29 info: xfce4-panel wm: xfwm 4.16.1 vt: 7
Type: Laptop System: FUJITSU CLIENT LIMITED product: LIFEBOOK U7410
v: 10601736746 serial: <filter> Chassis: type: 10 v: LIFEBOOK U7410
serial: <filter>
Mobo: FUJITSU CLIENT LIMITED model: FJNB2D4 v: A2 serial: <filter>
UEFI: FUJITSU CLIENT LIMITED v: Version 2.14 date: 03/10/2021
ID-1: CMB1 charge: 49.2 Wh (100.0%) condition: 49.2/50.3 Wh (98.0%)
volts: 16.5 min: 14.4 model: Fujitsu CP807648-01 type: Li-ion
serial: <filter> status: Full
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse MX Master
status: Discharging
RAM: total: 7.42 GiB used: 3.08 GiB (41.6%)
Info: Quad Core model: Intel Core i5-10310U bits: 64 type: MT MCP
arch: Kaby Lake note: check family: 6 model-id: 8E (142) stepping: C (12)
microcode: EA cache: L2: 6 MiB bogomips: 35210
Speed: 800 MHz min/max: 400/4400 MHz Core speeds (MHz): 1: 800 2: 800 3: 799
4: 800 5: 800 6: 800 7: 797 8: 800
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_capabilities
arch_perfmon art avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc
cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms
est f16c flexpriority flush_l1d fma fpu fsgsbase fxsr ht hwp hwp_act_window
hwp_epp hwp_notify ibpb ibrs ibrs_enhanced ida intel_pt invpcid
invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe mpx msr mtrr
nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni
popcnt pse pse36 pts rdrand rdseed rdtscp rep_good sdbg sep smap smep smx ss
ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc
tsc_adjust tsc_deadline_timer vme vmx vnmi vpid x2apic xgetbv1 xsave xsavec
xsaveopt xsaves xtopology xtpr
Type: srbds mitigation: TSX disabled
Device-1: Intel CometLake-U GT2 [UHD Graphics]
vendor: Fujitsu Client Limited driver: i915 v: kernel bus-ID: 00:02.0
chip-ID: 8086:9b41 class-ID: 0300
Device-2: Chicony FJ Camera type: USB driver: uvcvideo bus-ID: 1-8:8
chip-ID: 04f2:b6a0 class-ID: 0e02
Display: x11 server: X.Org 1.20.13 compositor: xfwm4 v: 4.16.1 driver:
loaded: modesetting unloaded: fbdev,vesa display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 5760x1080 s-dpi: 96 s-size: 1524x285mm (60.0x11.2")
s-diag: 1550mm (61")
Monitor-1: eDP-1 res: 1920x1080 hz: 60 dpi: 158 size: 309x174mm (12.2x6.9")
diag: 355mm (14")
Monitor-2: DP-2 res: 1920x1080 hz: 60 dpi: 96 size: 509x286mm (20.0x11.3")
diag: 584mm (23")
Monitor-3: DP-1-1 res: 1920x1080 hz: 60 dpi: 96 size: 509x286mm (20.0x11.3")
diag: 584mm (23")
OpenGL: renderer: Mesa Intel UHD Graphics (CML GT2) v: 4.6 Mesa 21.2.3
direct render: Yes
Device-1: Intel Comet Lake PCH-LP cAVS vendor: Fujitsu Client Limited
driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_sof_pci_intel_cnl
bus-ID: 00:1f.3 chip-ID: 8086:02c8 class-ID: 0403
Device-2: Logitech H390 headset with microphone type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-3.1:5 chip-ID: 046d:0a8f
class-ID: 0300
Device-3: Fujitsu USB Audio type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-4.2:7 chip-ID: 04c5:1570
class-ID: 0300 serial: <filter>
Sound Server-1: ALSA v: k5.14.7-2-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.38 running: no
Device-1: Intel Comet Lake PCH-LP CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:02f0 class-ID: 0280
IF: wlp0s20f3 state: down mac: <filter>
Device-2: Intel Ethernet I219-LM vendor: Fujitsu Client Limited
driver: e1000e v: kernel port: N/A bus-ID: 00:1f.6 chip-ID: 8086:0d4e
class-ID: 0200
IF: enp0s31f6 state: up speed: 1000 Mbps duplex: full mac: <filter>
IF-ID-1: vpn0 state: down mac: N/A
bus-ID: 1-10:10 chip-ID: 8087:0026 class-ID: e001
Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
Device-1: luks-6fb7eb67-d384-4065-bf4c-3d66c6edcba3 maj-min: 254:0
type: LUKS dm: dm-0 size: 238.17 GiB
Components:
p-1: nvme0n1p2 maj-min: 259:2 size: 238.17 GiB
Local Storage: total: 238.47 GiB used: 15.67 GiB (6.6%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Toshiba model: KBG40ZNV256G KIOXIA
size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 type: SSD serial: <filter> rev: AEJA0103 temp: 16.9 C scheme: GPT
ID-1: / raw-size: 238.17 GiB size: 233.37 GiB (97.99%)
used: 15.67 GiB (6.7%) fs: ext4 dev: /dev/dm-0 maj-min: 254:0
mapped: luks-6fb7eb67-d384-4065-bf4c-3d66c6edcba3 label: N/A
uuid: 93f46d74-723d-4ef8-a931-3f8df45f5e46
used: 440 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
label: NO_LABEL uuid: E250-5A3E
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 12 rev: 2.0
Device-1: 1-2:11 info: HP Smart Card Keyboard type: Keyboard,Smart Card
power: 100mA chip-ID: 03f0:1024 class-ID: 0b00 serial: <filter>
Hub-2: 1-3:3 info: Texas Instruments TUSB8041 4-Port Hub ports: 4 rev: 2.1
speed: 480 Mb/s chip-ID: 0451:8142 class-ID: 0900
Device-1: 1-3.1:5 info: Logitech H390 headset with microphone
type: Audio,HID driver: hid-generic,snd-usb-audio,usbhid interfaces: 4
rev: 1.1 speed: 12 Mb/s power: 100mA chip-ID: 046d:0a8f class-ID: 0300
Device-2: 1-3.3:9 info: Logitech Unifying Receiver type: Keyboard,Mouse,HID
power: 98mA chip-ID: 046d:c52b class-ID: 0300
Hub-3: 1-4:4 info: Texas Instruments TUSB8041 4-Port Hub ports: 4 rev: 2.1
Device-1: 1-4.2:7 info: Fujitsu USB Audio type: Audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 2.0
speed: 480 Mb/s power: 100mA chip-ID: 04c5:1570 class-ID: 0300
serial: <filter>
Hub-4: 1-6:6 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
Device-1: 1-8:8 info: Chicony FJ Camera type: Video driver: uvcvideo
interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 04f2:b6a0
class-ID: 0e02
Device-2: 1-10:10 info: Intel AX201 Bluetooth type: Bluetooth driver: btusb
interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 8087:0026
class-ID: e001
Hub-5: 2-0:1 info: Full speed (or root) Hub ports: 6 rev: 3.1 speed: 10 Gb/s
Hub-6: 2-3:2 info: Texas Instruments TUSB8041 4-Port Hub ports: 4 rev: 3.0
speed: 5 Gb/s chip-ID: 0451:8140 class-ID: 0900
Hub-7: 2-4:3 info: Texas Instruments TUSB8041 4-Port Hub ports: 4 rev: 3.0
Hub-8: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Hub-9: 4-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 54.0 C mobo: N/A
Processes: 255 Uptime: 6h 17m wakeups: 15 Init: systemd v: 249
tool: systemctl Compilers: gcc: 11.1.0 Packages: pacman: 1171 lib: 321
flatpak: 0 Shell: Bash v: 5.1.8 running-in: xfce4-terminal inxi: 3.3.07
Fabby
13 October 2021 12:34
4
kromy:
Please read this:
Difficulty: ☆☆☆☆☆
Remember when you installed your very first Windows, added bells and whistles and then couldn’t see the wood for the trees any more and had to re-install?
Well, you’re in the same situation now: You’re a N00b again! Embrace it!
I know right now you’re thinking:
Why is this so much more difficult than Windows? [image]
Whereas in 6 months time, you’ll be like:
Why can't I make Windows jump through fiery hoops like I do with Linux??? <a class="lightbox&qu…
Especially the Linux has multiple kernels section, then try an LTS kernel and hopefully the problem will go away “automagically”.
kromy
13 October 2021 12:55
5
Within those kernels I tried, there were 5.10 (LTS), 5.4 (LTS), 4.19 (LTS) and 4.9 (LTS).
The keyboard worked on none of them.
I read a lot of USB hubs - have tried removing every connected usb devices?
serial: <filter>
class-ID: 0e02
class-ID: e001
kromy
14 October 2021 06:54
7
Yes I tried that as well, sadly without success.
