I have Linux 6.6.26-1 running on Manjaro KDE, and added kernel 6.8.5-1. When I boot into 6.8.5-1, I now get messages:
/dev/nune0n1p2: clean, 501713/3196816 files, 8963954/12800000 blocks
[FAILED] Failed to mount /dos.
[DEPEND] Dependency failed for Local File Systems.
[DEPEND]] Dependency failed for Local File Systems.
You are in emergency mode. After logging in, type "journalct1 -xb" to view systen logs, "systemctl reboot" to reboot, or "exit"
to continue bootup.
Give root password for maintenance (or press Control-D to continue
Since 2021-07-08, I have had the following mount in fstab.
UUID=98EA0440EA041CDE /dos ntfs-3g defaults,locale=en_US.utf8 0 0
Rebooting back into 6.6.26-1 works.
Following Can't mount external drives after updating kernel and the sugestions of @linux-aarhus, I have tried …
UUID=98EA0440EA041CDE /dos ntfs-3g defaults,rw,noatime,iocharset=utf8,umask=000 0 0
… and …
UUID=98EA0440EA041CDE /dos ntfs-3g defaults,rw,noatime,iocharset=utf8,umask=0000 0 0
… but without success.
For reference, here is what my partitions look like (under 6.6.26-1).
sudo lsblk -f -m
NAME FSTYPE FSVER LABEL UUID FSAVAIL FSUSE% MOUNTPOINTS SIZE OWNER GROUP MODE
nvme1n1
476.9G root disk brw-rw----
├─nvme1n1p1
│ vfat FAT32 SYSTEM 4C01-3927 260M root disk brw-rw----
├─nvme1n1p2
│ 16M root disk brw-rw----
├─nvme1n1p3
│ ntfs Windows 98EA0440EA041CDE 279.5G 41% /dos 475.7G root disk brw-rw----
└─nvme1n1p4
ntfs WinRE_DRV 7002049002045D8A 1000M root disk brw-rw----
nvme0n1
465.8G root disk brw-rw----
├─nvme0n1p1
│ vfat FAT32 ESP D99F-2F77 240M 3% /boot/efi 250M root disk brw-rw----
├─nvme0n1p2
│ ext4 1.0 e336ea36-9445-48dc-875e-ad7a58ebbeac 12.2G 69% / 48.8G root disk brw-rw----
├─nvme0n1p3
│ ext4 1.0 be550a89-b98a-4271-b1a2-814ae6915175 29.3G root disk brw-rw----
├─nvme0n1p4
│ ext4 1.0 a5e20ecf-1871-481d-a70e-6a43b417af31 309G 10% /home 371.8G root disk brw-rw----
└─nvme0n1p5
swap 1 ca150e80-ab12-4408-9fee-b62040556ae8 [SWAP] 15.6G root disk brw-rw----
I’m writing this message while running Linux 6.6.26-1, so has something changed with kernel 6.8.5-1 ?
