hi ! , im new as linux user
the problem is my front panel doesnt work
i really tried alot of commands like reinstall alsa and install it again and so on for week and nothing new
my mic works good but the output is not
Welcome to Manjaro!
- Please read this:
[HowTo] Provide System Information
and press the three dots … below your post and press theto give us more information so we can see what’s really going on.
Now we know the symptom of the disease, but we need some more probing to know where the origin lies… - An
would be the minimum required information for us to be able to help you. (Personally Identifiable Information like serial numbers and MAC addresses will be filtered out by the above command)
Also, please copy-paste that output in-between 3 backticks ``` at the beginning and end of the code/text. (use the option “preformatted text”)
3.) Do you use a Dual-Boot or Multi-Boot System (Yes/No)? If so, which other Operating-Systems are installed ?
4.) Do you have a manual (printed or digital) of your Mainboard and additional Hardware, they are useful.
Welcome to Manjaro forum
Please post more information about audio devices detected in ALSA
sudo alsa-info.sh --upload
Since you are new to the forum you will probably not be allowed to post an active link to the uploaded data
But an inactive link can be posted in preformatted text using </> button or Ctrl+E
http://alsa-project.org/db/?f=4d387...
Kernel: 6.1.30-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=469741d3-1d05-4e44-8221-04fcf3530a1d rw quiet splash
udev.log_priority=3
Desktop: KDE Plasma v: 5.27.4 tk: Qt v: 5.15.9 wm: kwin_wayland vt: 2
Type: Desktop System: Hewlett-Packard product: HP Z220 CMT Workstation v: N/A
serial: <superuser required> Chassis: type: 6 serial: <superuser required>
Mobo: Hewlett-Packard model: 1790 serial: <superuser required>
UEFI: Hewlett-Packard v: K51 v01.87 date: 06/10/2019
Info: model: Intel Core i5-3470 bits: 64 type: MCP arch: Ivy Bridge
gen: core 3 level: v2 built: 2012-15 process: Intel 22nm family: 6
model-id: 0x3A (58) stepping: 9 microcode: 0x21
Topology: cpus: 1x cores: 4 smt: <unsupported> cache: L1: 256 KiB
desc: d-4x32 KiB; i-4x32 KiB L2: 1024 KiB desc: 4x256 KiB L3: 6 MiB
desc: 1x6 MiB
Speed (MHz): avg: 2250 high: 3005 min/max: 1600/3600 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 3005 2: 2027 3: 2373
4: 1597 bogomips: 25549
Flags: avx ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
disabled
STIBP: disabled, RSB filling, PBRSB-eIBRS: Not affected
Type: srbds status: Vulnerable: No microcode
Device-1: AMD Ellesmere [Radeon RX 470/480/570/570X/580/580X/590]
driver: amdgpu v: kernel arch: GCN-4 code: Arctic Islands process: GF 14nm
built: 2016-20 pcie: gen: 3 speed: 8 GT/s lanes: 16 ports: active: DP-3
empty: DP-1, DP-2, DVI-D-1, HDMI-A-1 bus-ID: 01:00.0 chip-ID: 1002:67df
class-ID: 0300 temp: 34.0 C
Display: wayland server: X.org v: 1.21.1.8 with: Xwayland v: 23.1.1
alternate: fbdev,vesa dri: radeonsi gpu: amdgpu display-ID: 0
Monitor-1: DP-3 res: 1920x1080 size: N/A modes: N/A
API: OpenGL v: 4.6 Mesa 23.0.3 renderer: AMD Radeon RX 570 Series
(polaris10 LLVM 15.0.7 DRM 3.49 6.1.30-1-MANJARO) direct-render: Yes
vendor: Hewlett-Packard driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
chip-ID: 8086:1c20 class-ID: 0403
Device-2: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]
bus-ID: 01:00.1 chip-ID: 1002:aaf0 class-ID: 0403
API: ALSA v: k6.1.30-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 0.3.70 status: off with: wireplumber status: active
tools: pw-cli,wpctl
Device-1: Intel 82579LM Gigabit Network vendor: Hewlett-Packard
driver: e1000e v: kernel port: f040 bus-ID: 00:19.0 chip-ID: 8086:1502
class-ID: 0200
Hardware-1: Intel SATA Controller [RAID mode] driver: ahci v: 3.0 port: f020
bus-ID: 00:1f.2 chip-ID: 8086:2822 rev: N/A class-ID: 0104
Local Storage: total: 577.55 GiB used: 7.3 GiB (1.3%)
ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital
model: WD5000AVCS-632DY1 size: 465.76 GiB block-size: physical: 512 B
logical: 512 B speed: 3.0 Gb/s tech: N/A serial: <filter> fw-rev: 0A01
scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Western Digital
model: WDS120G2G0A-00JH30 size: 111.79 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s tech: SSD serial: <filter> fw-rev: 0400
scheme: GPT
ID-1: / raw-size: 65.76 GiB size: 64.17 GiB (97.59%) used: 7.27 GiB (11.3%)
fs: ext4 dev: /dev/sda2 maj-min: 8:2
used: 30.5 MiB (31.8%) fs: vfat dev: /dev/sdb1 maj-min: 8:17
System Temperatures: cpu: 39.0 C mobo: N/A gpu: amdgpu temp: 34.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 978
Processes: 209 Uptime: 4m wakeups: 0 Memory: available: 7.72 GiB
used: 1.77 GiB (22.9%) Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7 Packages: pm: pacman
pkgs: 1126 libs: 325 tools: pamac pm: flatpak pkgs: 0 Shell: Zsh v: 5.9
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.27
- yes , windows 10
- Dual boot
- no. my case is “hp z220”
!!ALSA Information Script v 0.5.1
!!Script ran on: Fri Aug 25 05:50:09 UTC 2023
!!Linux Distribution
ID_LIKE=arch
!!DMI Information
Manufacturer: Hewlett-Packard
Product Name: HP Z220 CMT Workstation
Product Version:
Firmware Version: K51 v01.87
System SKU: B8U95UT#ABA
Board Vendor: Hewlett-Packard
Board Name: 1790
!!ACPI Device Status Information
/sys/bus/acpi/devices/INT3F0D:00/status 15
/sys/bus/acpi/devices/PNP0103:00/status 15
/sys/bus/acpi/devices/PNP0C01:00/status 15
/sys/bus/acpi/devices/PNP0C02:04/status 15
/sys/bus/acpi/devices/PNP0C0C:00/status 11
/sys/bus/acpi/devices/PNP0C0F:00/status 9
/sys/bus/acpi/devices/PNP0C0F:01/status 9
/sys/bus/acpi/devices/PNP0C0F:02/status 9
/sys/bus/acpi/devices/PNP0C0F:03/status 9
/sys/bus/acpi/devices/PNP0C0F:04/status 9
/sys/bus/acpi/devices/PNP0C0F:05/status 9
/sys/bus/acpi/devices/PNP0C0F:06/status 9
/sys/bus/acpi/devices/PNP0C0F:07/status 9
!!Kernel Information
Kernel release: 6.1.30-1-MANJARO
Operating System: GNU/Linux
Architecture: x86_64
Processor: unknown
SMP Enabled: Yes
!!ALSA Version
Driver version: k6.1.30-1-MANJARO
Library version: 1.2.8
Utilities version: 1.2.8
!!Loaded ALSA modules
snd_hda_intel (card 0)
snd_hda_intel (card 1)
!!Sound Servers on this system
PipeWire:
Installed - Yes (/usr/bin/pipewire)
Running - Yes
Pulseaudio:
Installed - Yes (/usr/bin/pulseaudio)
Running - Yes
Jack:
Installed - Yes (/usr/bin/jackd)
Running - No
!!Soundcards recognised by ALSA
0 [PCH ]: HDA-Intel - HDA Intel PCH
HDA Intel PCH at 0xf7f20000 irq 29
1 [HDMI ]: HDA-Intel - HDA ATI HDMI
HDA ATI HDMI at 0xf7e60000 irq 30
!!PCI Soundcards installed in the system
00:1b.0 Audio device [0403]: Intel Corporation 6 Series/C200 Series Chipset Family High Definition Audio Controller [8086:1c20] (rev 05)
Subsystem: Hewlett-Packard Company Device [103c:1790]
01:00.1 Audio device [0403]: Advanced Micro Devices, Inc. [AMD/ATI] Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590] [1002:aaf0]
Subsystem: Advanced Micro Devices, Inc. [AMD/ATI] Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590] [1002:aaf0]
!!Loaded sound module options
!!Module: snd_hda_intel
align_buffer_size : -1
bdl_pos_adj : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
beep_mode : N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N
ctl_dev_id : N
dmic_detect : Y
enable : Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y
enable_msi : -1
id : (null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
index : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
jackpoll_ms : 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
model : (null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
patch : (null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
pm_blacklist : Y
position_fix : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
power_save : 1
power_save_controller : Y
probe_mask : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
probe_only : 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
single_cmd : -1
snoop : -1
ctl_dev_id : N
dmic_detect : Y
enable_msi : -1
pm_blacklist : Y
power_save : 1
single_cmd : -1
snoop : -1
!!Sysfs card info
!!Card: /sys/class/sound/card0
Driver: /sys/bus/pci/drivers/snd_hda_intel
Tree:
!!Card: /sys/class/sound/card1
Tree:
!!HDA-Intel Codec information
--startcollapse--
Codec: Realtek ALC262
Address: 0
AFG Function Id: 0x1 (unsol 1)
Vendor Id: 0x10ec0262
Subsystem Id: 0x10ec0262
Revision Id: 0x100202
No Modem Function Group found
Default PCM:
rates [0x560]: 44100 48000 96000 192000
bits [0xe]: 16 20 24
formats [0x1]: PCM
Default Amp-In caps: N/A
Default Amp-Out caps: N/A
State of AFG node 0x01:
Power states: D0 D1 D2 D3
Power: setting=D0, actual=D0
GPIO: io=4, o=0, i=0, unsolicited=1, wake=0
IO[0]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
IO[1]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
IO[2]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
IO[3]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
Node 0x02 [Audio Output] wcaps 0x11: Stereo
Device: name="ALC262 Analog", type="Audio", device=0
Converter: stream=0, channel=0
PCM:
formats [0x1]: PCM
Node 0x03 [Audio Output] wcaps 0x11: Stereo
PCM:
formats [0x1]: PCM
Node 0x04 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x05 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x06 [Audio Output] wcaps 0x211: Stereo Digital
Control: name="IEC958 Playback Con Mask", index=0, device=0
Control: name="IEC958 Playback Pro Mask", index=0, device=0
Control: name="IEC958 Playback Default", index=0, device=0
Control: name="IEC958 Playback Switch", index=0, device=0
Control: name="IEC958 Default PCM Playback Switch", index=0, device=0
Device: name="ALC262 Digital", type="SPDIF", device=1
Digital:
Digital category: 0x0
IEC Coding Type: 0x0
PCM:
bits [0x1e]: 16 20 24 32
formats [0x1]: PCM
Node 0x07 [Audio Input] wcaps 0x10011b: Stereo Amp-In
Control: name="Capture Volume", index=0, device=0
ControlAmp: chs=3, dir=In, idx=0, ofs=0
Control: name="Capture Switch", index=0, device=0
Amp-In caps: ofs=0x08, nsteps=0x1f, stepsize=0x05, mute=1
Amp-In vals: [0x1f 0x1f]
SDI-Select: 0
PCM:
rates [0x160]: 44100 48000 96000
bits [0x6]: 16 20
formats [0x1]: PCM
Connection: 1
0x24
Node 0x08 [Audio Input] wcaps 0x10011b: Stereo Amp-In
Control: name="Capture Volume", index=1, device=0
Control: name="Capture Switch", index=1, device=0
Device: name="ALC262 Alt Analog", type="Audio", device=2
Amp-In vals: [0x80 0x80]
SDI-Select: 0
PCM:
bits [0x6]: 16 20
formats [0x1]: PCM
Connection: 1
0x23
Node 0x09 [Audio Input] wcaps 0x10011b: Stereo Amp-In
Control: name="Capture Volume", index=2, device=0
Control: name="Capture Switch", index=2, device=0
SDI-Select: 0
PCM:
bits [0x6]: 16 20
formats [0x1]: PCM
Connection: 1
0x22
Node 0x0a [Audio Input] wcaps 0x100391: Stereo Digital
Control: name="IEC958 Capture Switch", index=0, device=0
Control: name="IEC958 Capture Default", index=0, device=0
SDI-Select: 0
Digital:
PCM:
formats [0x1]: PCM
Unsolicited: tag=00, enabled=0
Connection: 1
0x1f
Node 0x0b [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
Control: name="Rear Mic Playback Volume", index=0, device=0
Control: name="Rear Mic Playback Switch", index=0, device=0
Control: name="Front Mic Playback Volume", index=0, device=0
ControlAmp: chs=3, dir=In, idx=1, ofs=0
Control: name="Front Mic Playback Switch", index=0, device=0
Control: name="Line Playback Volume", index=0, device=0
ControlAmp: chs=3, dir=In, idx=2, ofs=0
Control: name="Line Playback Switch", index=0, device=0
Control: name="CD Playback Volume", index=0, device=0
ControlAmp: chs=3, dir=In, idx=4, ofs=0
Control: name="CD Playback Switch", index=0, device=0
Control: name="Beep Playback Volume", index=0, device=0
ControlAmp: chs=3, dir=In, idx=5, ofs=0
Control: name="Beep Playback Switch", index=0, device=0
Amp-In caps: ofs=0x17, nsteps=0x1f, stepsize=0x05, mute=1
Amp-In vals: [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80]
Connection: 8
0x18 0x19 0x1a 0x1b 0x1c 0x1d 0x14 0x15
Node 0x0c [Audio Mixer] wcaps 0x20010f: Stereo Amp-In Amp-Out
Control: name="Master Playback Volume", index=0, device=0
ControlAmp: chs=3, dir=Out, idx=0, ofs=0
Amp-In caps: ofs=0x00, nsteps=0x00, stepsize=0x00, mute=1
Amp-In vals: [0x00 0x00] [0x80 0x80]
Amp-Out caps: ofs=0x1f, nsteps=0x1f, stepsize=0x05, mute=0
Amp-Out vals: [0x11 0x11]
Connection: 2
0x02 0x0b
Node 0x0d [Audio Mixer] wcaps 0x20010f: Stereo Amp-In Amp-Out
Amp-Out vals: [0x01 0x01]
Connection: 2
0x03 0x0b
Node 0x0e [Audio Mixer] wcaps 0x20010e: Mono Amp-In Amp-Out
Amp-In vals: [0x00] [0x80]
Amp-Out vals: [0x01]
Connection: 2
0x02 0x0b
Node 0x0f [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x10 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x11 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x12 [Pin Complex] wcaps 0x400001: Stereo
Pincap 0x00000020: IN
Pin Default 0x411111f0: [N/A] Speaker at Ext Rear
Conn = 1/8, Color = Black
DefAssociation = 0xf, Sequence = 0x0
Misc = NO_PRESENCE
Pin-ctls: 0x00:
Node 0x13 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x14 [Pin Complex] wcaps 0x40018f: Stereo Amp-In Amp-Out
Control: name="Master Playback Switch", index=0, device=0
Amp-In caps: ofs=0x00, nsteps=0x03, stepsize=0x27, mute=0
Amp-Out caps: ofs=0x00, nsteps=0x00, stepsize=0x00, mute=1
Amp-Out vals: [0x00 0x00]
Pincap 0x0000003e: IN OUT HP Detect Trigger
Pin Default 0x01014010: [Jack] Line Out at Ext Rear
Conn = 1/8, Color = Green
DefAssociation = 0x1, Sequence = 0x0
Pin-ctls: 0x40: OUT
Unsolicited: tag=05, enabled=1
Connection: 2
0x0c* 0x0d
Node 0x15 [Pin Complex] wcaps 0x40018f: Stereo Amp-In Amp-Out
Amp-Out vals: [0x80 0x80]
Misc = NO_PRESENCE
Pin-ctls: 0x20: IN
Connection: 2
0x0c 0x0d*
Node 0x16 [Pin Complex] wcaps 0x40010c: Mono Amp-Out
Amp-Out vals: [0x80]
Pincap 0x00000010: OUT
Misc = NO_PRESENCE
Pin-ctls: 0x40: OUT
Connection: 1
0x0e
Node 0x17 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x18 [Pin Complex] wcaps 0x40018f: Stereo Amp-In Amp-Out
Control: name="Rear Mic Boost Volume", index=0, device=0
Pincap 0x0000173e: IN OUT HP Detect Trigger
Vref caps: HIZ 50 GRD 80
Pin Default 0x01a19840: [Jack] Mic at Ext Rear
Conn = 1/8, Color = Pink
DefAssociation = 0x4, Sequence = 0x0
Pin-ctls: 0x21: IN VREF_50
Unsolicited: tag=01, enabled=1
Connection: 2
0x0c* 0x0d
Node 0x19 [Pin Complex] wcaps 0x40018f: Stereo Amp-In Amp-Out
Control: name="Front Mic Boost Volume", index=0, device=0
Amp-In vals: [0x03 0x03]
Pin Default 0x02a19c50: [Jack] Mic at Ext Front
DefAssociation = 0x5, Sequence = 0x0
Pin-ctls: 0x24: IN VREF_80
Unsolicited: tag=02, enabled=1
Connection: 2
0x0c* 0x0d
Node 0x1a [Pin Complex] wcaps 0x40018f: Stereo Amp-In Amp-Out
Control: name="Line Boost Volume", index=0, device=0
Pin Default 0x01813041: [Jack] Line In at Ext Rear
Conn = 1/8, Color = Blue
DefAssociation = 0x4, Sequence = 0x1
Pin-ctls: 0x20: IN VREF_HIZ
Unsolicited: tag=03, enabled=1
Connection: 2
0x0c* 0x0d
Node 0x1b [Pin Complex] wcaps 0x40018f: Stereo Amp-In Amp-Out
Pin Default 0x02014c20: [Jack] Line Out at Ext Front
DefAssociation = 0x2, Sequence = 0x0
Connection: 2
0x0c* 0x0d
Node 0x1c [Pin Complex] wcaps 0x400001: Stereo
Pin Default 0x9933014f: [Fixed] CD at Int ATAPI
Conn = ATAPI, Color = Unknown
DefAssociation = 0x4, Sequence = 0xf
Misc = NO_PRESENCE
Pin-ctls: 0x20: IN
Node 0x1d [Pin Complex] wcaps 0x400000: Mono
Misc = NO_PRESENCE
Pin-ctls: 0x20: IN
Node 0x1e [Pin Complex] wcaps 0x400380: Mono Digital
Pin Default 0x01441130: [Jack] SPDIF Out at Ext Rear
Conn = RCA, Color = Black
DefAssociation = 0x3, Sequence = 0x0
Misc = NO_PRESENCE
Pin-ctls: 0x40: OUT
Connection: 1
0x06
Node 0x1f [Pin Complex] wcaps 0x400280: Mono Digital
Pin Default 0x01c46160: [Jack] SPDIF In at Ext Rear
Conn = RCA, Color = Orange
DefAssociation = 0x6, Sequence = 0x0
Misc = NO_PRESENCE
Pin-ctls: 0x20: IN
Node 0x20 [Vendor Defined Widget] wcaps 0xf00040: Mono
Processing caps: benign=0, ncoeff=17
Node 0x21 [Volume Knob Widget] wcaps 0x600080: Mono
Volume-Knob: delta=0, steps=32, direct=0, val=64
Connection: 0
Node 0x22 [Audio Selector] wcaps 0x300101: Stereo
Connection: 10
0x18* 0x19 0x1a 0x1b 0x1c 0x1d 0x14 0x15 0x0b 0x12
Node 0x23 [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
Amp-In vals: [0x00 0x00] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80]
Connection: 9
0x18 0x19 0x1a 0x1b 0x1c 0x1d 0x14 0x15 0x0b
Node 0x24 [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
Amp-In vals: [0x80 0x80] [0x00 0x00] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80]
Connection: 9
Codec: ATI R6xx HDMI
Address: 0
AFG Function Id: 0x1 (unsol 0)
Vendor Id: 0x1002aa01
Subsystem Id: 0x00aa0100
Revision Id: 0x100700
Default PCM:
rates [0x70]: 32000 44100 48000
bits [0x2]: 16
formats [0x1]: PCM
Power states: D0 D3 CLKSTOP EPSS
Power: setting=D0, actual=D0, Clock-stop-OK
GPIO: io=0, o=0, i=0, unsolicited=0, wake=0
Node 0x02 [Audio Output] wcaps 0x221: Stereo Digital Stripe
Digital: Enabled
Node 0x03 [Pin Complex] wcaps 0x400381: Stereo Digital
Pincap 0x00000094: OUT Detect HDMI
Pin Default 0x185600f0: [Jack] Digital Out at Int HDMI
Conn = Digital, Color = Unknown
Pin-ctls: 0x40: OUT
Connection: 1
0x02
Node 0x04 [Audio Output] wcaps 0x221: Stereo Digital Stripe
Digital: Enabled
Node 0x05 [Pin Complex] wcaps 0x400381: Stereo Digital
Pin-ctls: 0x40: OUT
Connection: 1
0x04
Node 0x06 [Audio Output] wcaps 0x221: Stereo Digital Stripe
Digital: Enabled
Node 0x07 [Pin Complex] wcaps 0x400381: Stereo Digital
Pin-ctls: 0x40: OUT
Connection: 1
0x06
Node 0x08 [Audio Output] wcaps 0x221: Stereo Digital Stripe
Digital: Enabled
Node 0x09 [Pin Complex] wcaps 0x400381: Stereo Digital
Pin-ctls: 0x40: OUT
Connection: 1
0x08
Node 0x0a [Audio Output] wcaps 0x221: Stereo Digital Stripe
Digital: Enabled
Node 0x0b [Pin Complex] wcaps 0x400381: Stereo Digital
Pin-ctls: 0x40: OUT
Connection: 1
0x0a
Node 0x0c [Audio Output] wcaps 0x221: Stereo Digital Stripe
Digital: Enabled
Node 0x0d [Pin Complex] wcaps 0x400381: Stereo Digital
Pin-ctls: 0x40: OUT
Connection: 1
0x0c
Node 0x0e [Audio Output] wcaps 0x221: Stereo Digital Stripe
Digital:
Node 0x0f [Pin Complex] wcaps 0x400381: Stereo Digital
Pin Default 0x585600f0: [N/A] Digital Out at Int HDMI
Pin-ctls: 0x40: OUT
Connection: 1
0x0e
--endcollapse--
!!ALSA Device nodes
crw-rw---- 1 root audio 116, 16 Aug 25 08:41 /dev/snd/controlC0
crw-rw---- 1 root audio 116, 9 Aug 25 08:41 /dev/snd/controlC1
crw-rw---- 1 root audio 116, 15 Aug 25 08:41 /dev/snd/hwC0D0
crw-rw---- 1 root audio 116, 8 Aug 25 08:41 /dev/snd/hwC1D0
crw-rw---- 1 root audio 116, 11 Aug 25 08:43 /dev/snd/pcmC0D0c
crw-rw---- 1 root audio 116, 10 Aug 25 08:43 /dev/snd/pcmC0D0p
crw-rw---- 1 root audio 116, 13 Aug 25 08:43 /dev/snd/pcmC0D1c
crw-rw---- 1 root audio 116, 12 Aug 25 08:43 /dev/snd/pcmC0D1p
crw-rw---- 1 root audio 116, 14 Aug 25 08:41 /dev/snd/pcmC0D2c
crw-rw---- 1 root audio 116, 6 Aug 25 08:43 /dev/snd/pcmC1D10p
crw-rw---- 1 root audio 116, 7 Aug 25 08:43 /dev/snd/pcmC1D11p
crw-rw---- 1 root audio 116, 2 Aug 25 08:43 /dev/snd/pcmC1D3p
crw-rw---- 1 root audio 116, 3 Aug 25 08:43 /dev/snd/pcmC1D7p
crw-rw---- 1 root audio 116, 4 Aug 25 08:43 /dev/snd/pcmC1D8p
crw-rw---- 1 root audio 116, 5 Aug 25 08:43 /dev/snd/pcmC1D9p
crw-rw---- 1 root audio 116, 1 Aug 25 08:41 /dev/snd/seq
crw-rw---- 1 root audio 116, 33 Aug 25 08:41 /dev/snd/timer
/dev/snd/by-path:
total 0
drwxr-xr-x 2 root root 80 Aug 25 08:41 .
drwxr-xr-x 3 root root 400 Aug 25 08:41 ..
lrwxrwxrwx 1 root root 12 Aug 25 08:41 pci-0000:00:1b.0 -> ../controlC0
lrwxrwxrwx 1 root root 12 Aug 25 08:41 pci-0000:01:00.1 -> ../controlC1
!!Aplay/Arecord output
APLAY
**** List of PLAYBACK Hardware Devices ****
card 0: PCH [HDA Intel PCH], device 0: ALC262 Analog [ALC262 Analog]
Subdevices: 1/1
Subdevice #0: subdevice #0
card 0: PCH [HDA Intel PCH], device 1: ALC262 Digital [ALC262 Digital]
Subdevices: 1/1
card 1: HDMI [HDA ATI HDMI], device 3: HDMI 0 [HDMI 0]
Subdevices: 1/1
card 1: HDMI [HDA ATI HDMI], device 7: HDMI 1 [HDMI 1]
Subdevices: 1/1
card 1: HDMI [HDA ATI HDMI], device 8: HDMI 2 [HDMI 2]
Subdevices: 1/1
card 1: HDMI [HDA ATI HDMI], device 9: HDMI 3 [HDMI 3]
Subdevices: 1/1
card 1: HDMI [HDA ATI HDMI], device 10: HDMI 4 [HDMI 4]
Subdevices: 1/1
card 1: HDMI [HDA ATI HDMI], device 11: HDMI 5 [HDMI 5]
Subdevices: 1/1
ARECORD
**** List of CAPTURE Hardware Devices ****
Subdevices: 1/1
Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 2: ALC262 Alt Analog [ALC262 Alt Analog]
Subdevices: 2/2
Subdevice #1: subdevice #1
!!Amixer output
!!-------Mixer controls for card PCH
Card sysdefault:0 'PCH'/'HDA Intel PCH at 0xf7f20000 irq 29'
Mixer name : 'Realtek ALC262'
Components : 'HDA:10ec0262,10ec0262,00100202'
Controls : 46
Simple ctrls : 19
Simple mixer control 'Master',0
Capabilities: pvolume pswitch
Limits: Playback 0 - 31
Mono:
Front Left: Playback 17 [55%] [-21.00dB] [on]
Front Right: Playback 17 [55%] [-21.00dB] [on]
Simple mixer control 'PCM',0
Limits: Playback 0 - 255
Mono:
Front Left: Playback 255 [100%] [0.00dB]
Front Right: Playback 255 [100%] [0.00dB]
Simple mixer control 'Front Mic',0
Mono:
Front Left: Playback 0 [0%] [-34.50dB] [off]
Front Right: Playback 0 [0%] [-34.50dB] [off]
Simple mixer control 'Front Mic Boost',0
Capabilities: volume
Limits: 0 - 3
Front Left: 3 [100%] [30.00dB]
Front Right: 3 [100%] [30.00dB]
Simple mixer control 'Line',0
Mono:
Simple mixer control 'Line Boost',0
Limits: 0 - 3
Front Left: 0 [0%] [0.00dB]
Front Right: 0 [0%] [0.00dB]
Simple mixer control 'CD',0
Mono:
Simple mixer control 'IEC958',0
Capabilities: pswitch pswitch-joined cswitch cswitch-joined
Playback channels: Mono
Capture channels: Mono
Mono: Playback [off] Capture [off]
Simple mixer control 'IEC958 Default PCM',0
Mono: Playback [on]
Simple mixer control 'Beep',0
Mono:
Simple mixer control 'Capture',0
Capabilities: cvolume cswitch
Limits: Capture 0 - 31
Front Left: Capture 31 [100%] [34.50dB] [on]
Front Right: Capture 31 [100%] [34.50dB] [on]
Simple mixer control 'Capture',1
Front Left: Capture 0 [0%] [-12.00dB] [off]
Front Right: Capture 0 [0%] [-12.00dB] [off]
Simple mixer control 'Capture',2
Simple mixer control 'Input Source',0
Capabilities: cenum
Items: 'Rear Mic' 'Front Mic' 'Line' 'CD'
Item0: 'Front Mic'
Simple mixer control 'Input Source',1
Capabilities: cenum
Item0: 'Rear Mic'
Simple mixer control 'Input Source',2
Capabilities: cenum
Item0: 'Rear Mic'
Simple mixer control 'Loopback Mixing',0
Capabilities: enum
Items: 'Disabled' 'Enabled'
Item0: 'Disabled'
Simple mixer control 'Rear Mic',0
Mono:
Simple mixer control 'Rear Mic Boost',0
Limits: 0 - 3
!!-------Mixer controls for card HDMI
Card sysdefault:1 'HDMI'/'HDA ATI HDMI at 0xf7e60000 irq 30'
Mixer name : 'ATI R6xx HDMI'
Components : 'HDA:1002aa01,00aa0100,00100700'
Controls : 42
Simple ctrls : 6
Mono: Playback [on]
Simple mixer control 'IEC958',1
Mono: Playback [on]
Simple mixer control 'IEC958',2
Mono: Playback [on]
Simple mixer control 'IEC958',3
Mono: Playback [on]
Simple mixer control 'IEC958',4
Mono: Playback [on]
Simple mixer control 'IEC958',5
Mono: Playback [on]
!!Alsactl output
--startcollapse--
state.PCH {
control.1 {
iface MIXER
name 'Master Playback Volume'
value.0 17
value.1 17
comment {
access 'read write'
type INTEGER
count 2
range '0 - 31'
dbmin -4650
dbmax 0
dbvalue.0 -2100
dbvalue.1 -2100
control.2 {
iface MIXER
name 'Master Playback Switch'
value.0 true
value.1 true
comment {
access 'read write'
type BOOLEAN
count 2
control.3 {
iface MIXER
name 'Loopback Mixing'
value Disabled
comment {
access 'read write'
type ENUMERATED
count 1
item.0 Disabled
item.1 Enabled
control.4 {
iface MIXER
name 'Rear Mic Playback Volume'
value.0 0
value.1 0
comment {
access 'read write'
type INTEGER
count 2
range '0 - 31'
dbmin -3450
dbmax 1200
dbvalue.0 -3450
dbvalue.1 -3450
control.5 {
iface MIXER
name 'Rear Mic Playback Switch'
value.0 false
value.1 false
comment {
access 'read write'
type BOOLEAN
count 2
control.6 {
iface MIXER
name 'Front Mic Playback Volume'
value.0 0
value.1 0
comment {
access 'read write'
type INTEGER
count 2
range '0 - 31'
dbmin -3450
dbmax 1200
dbvalue.0 -3450
dbvalue.1 -3450
control.7 {
iface MIXER
name 'Front Mic Playback Switch'
value.0 false
value.1 false
comment {
access 'read write'
type BOOLEAN
count 2
control.8 {
iface MIXER
name 'Line Playback Volume'
value.0 0
value.1 0
comment {
access 'read write'
type INTEGER
count 2
range '0 - 31'
dbmin -3450
dbmax 1200
dbvalue.0 -3450
dbvalue.1 -3450
control.9 {
iface MIXER
name 'Line Playback Switch'
value.0 false
value.1 false
comment {
access 'read write'
type BOOLEAN
count 2
control.10 {
iface MIXER
name 'CD Playback Volume'
value.0 0
value.1 0
comment {
access 'read write'
type INTEGER
count 2
range '0 - 31'
dbmin -3450
dbmax 1200
dbvalue.0 -3450
dbvalue.1 -3450
control.11 {
iface MIXER
name 'CD Playback Switch'
value.0 false
value.1 false
comment {
access 'read write'
type BOOLEAN
count 2
control.12 {
iface MIXER
name 'Input Source'
value 'Front Mic'
comment {
access 'read write'
type ENUMERATED
count 1
item.0 'Rear Mic'
item.1 'Front Mic'
item.2 Line
item.3 CD
control.13 {
iface MIXER
name 'Input Source'
index 1
value 'Rear Mic'
comment {
access 'read write'
type ENUMERATED
count 1
item.0 'Rear Mic'
item.1 'Front Mic'
item.2 Line
item.3 CD
control.14 {
iface MIXER
name 'Input Source'
index 2
value 'Rear Mic'
comment {
access 'read write'
type ENUMERATED
count 1
item.0 'Rear Mic'
item.1 'Front Mic'
item.2 Line
item.3 CD
control.15 {
iface MIXER
name 'Capture Volume'
value.0 31
value.1 31
comment {
access 'read write'
type INTEGER
count 2
range '0 - 31'
dbmin -1200
dbmax 3450
dbvalue.0 3450
dbvalue.1 3450
control.16 {
iface MIXER
name 'Capture Switch'
value.0 true
value.1 true
comment {
access 'read write'
type BOOLEAN
count 2
control.17 {
iface MIXER
index 1
value.0 0
value.1 0
comment {
access 'read write'
type INTEGER
count 2
range '0 - 31'
dbmin -1200
dbmax 3450
dbvalue.0 -1200
dbvalue.1 -1200
control.18 {
iface MIXER
index 1
value.0 false
value.1 false
comment {
access 'read write'
type BOOLEAN
count 2
control.19 {
iface MIXER
index 2
value.0 0
value.1 0
comment {
access 'read write'
type INTEGER
count 2
range '0 - 31'
dbmin -1200
dbmax 3450
dbvalue.0 -1200
dbvalue.1 -1200
control.20 {
iface MIXER
index 2
value.0 false
value.1 false
comment {
access 'read write'
type BOOLEAN
count 2
control.21 {
iface MIXER
name 'Rear Mic Boost Volume'
value.0 0
value.1 0
comment {
access 'read write'
type INTEGER
count 2
range '0 - 3'
dbmin 0
dbmax 3000
dbvalue.0 0
dbvalue.1 0
control.22 {
iface MIXER
name 'Front Mic Boost Volume'
value.0 3
value.1 3
comment {
access 'read write'
type INTEGER
count 2
range '0 - 3'
dbmin 0
dbmax 3000
dbvalue.0 3000
dbvalue.1 3000
control.23 {
iface MIXER
name 'Line Boost Volume'
value.0 0
value.1 0
comment {
access 'read write'
type INTEGER
count 2
range '0 - 3'
dbmin 0
dbmax 3000
dbvalue.0 0
dbvalue.1 0
control.24 {
iface MIXER
name 'Beep Playback Volume'
value.0 0
value.1 0
comment {
access 'read write'
type INTEGER
count 2
range '0 - 31'
dbmin -3450
dbmax 1200
dbvalue.0 -3450
dbvalue.1 -3450
control.25 {
iface MIXER
name 'Beep Playback Switch'
value.0 false
value.1 false
comment {
access 'read write'
type BOOLEAN
count 2
control.26 {
iface MIXER
name 'IEC958 Playback Con Mask'
value '0fff000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
comment {
access read
type IEC958
count 1
control.27 {
iface MIXER
name 'IEC958 Playback Pro Mask'
value '0f00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
comment {
access read
type IEC958
count 1
control.28 {
iface MIXER
name 'IEC958 Playback Default'
value '0400000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
comment {
access 'read write'
type IEC958
count 1
control.29 {
iface MIXER
name 'IEC958 Playback Switch'
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.30 {
iface MIXER
name 'IEC958 Default PCM Playback Switch'
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.31 {
iface MIXER
name 'IEC958 Capture Switch'
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.32 {
iface MIXER
name 'IEC958 Capture Default'
comment {
access read
type IEC958
count 1
control.33 {
iface CARD
name 'Rear Mic Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.34 {
iface CARD
name 'Front Mic Jack'
value true
comment {
access read
type BOOLEAN
count 1
control.35 {
iface CARD
name 'Line Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.36 {
iface CARD
name 'CD Phantom Jack'
value true
comment {
access read
type BOOLEAN
count 1
control.37 {
iface CARD
name 'Line Out Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.38 {
iface CARD
name 'SPDIF Phantom Jack'
value true
comment {
access read
type BOOLEAN
count 1
control.39 {
iface CARD
name 'SPDIF In Phantom Jack'
value true
comment {
access read
type BOOLEAN
count 1
control.40 {
iface PCM
name 'Playback Channel Map'
value.0 0
value.1 0
comment {
access read
type INTEGER
count 2
range '0 - 36'
control.41 {
iface PCM
name 'Capture Channel Map'
value.0 0
value.1 0
comment {
access read
type INTEGER
count 2
range '0 - 36'
control.42 {
iface PCM
device 1
value.0 0
value.1 0
comment {
access read
type INTEGER
count 2
range '0 - 36'
control.43 {
iface PCM
device 1
value.0 0
value.1 0
comment {
access read
type INTEGER
count 2
range '0 - 36'
control.44 {
iface PCM
device 2
value.0 0
value.1 0
comment {
access read
type INTEGER
count 2
range '0 - 36'
control.45 {
iface PCM
device 2
index 1
value.0 0
value.1 0
comment {
access read
type INTEGER
count 2
range '0 - 36'
control.46 {
iface MIXER
name 'PCM Playback Volume'
value.0 255
value.1 255
comment {
access 'read write user'
type INTEGER
count 2
range '0 - 255'
tlv '0000000100000008ffffec1400000014'
dbmin -5100
dbmax 0
dbvalue.0 0
dbvalue.1 0
state.HDMI {
control.1 {
iface CARD
name 'HDMI/DP,pcm=3 Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.2 {
iface MIXER
comment {
access read
type IEC958
count 1
control.3 {
iface MIXER
comment {
access read
type IEC958
count 1
control.4 {
iface MIXER
comment {
access 'read write'
type IEC958
count 1
control.5 {
iface MIXER
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.6 {
iface PCM
device 3
name ELD
value ''
comment {
access 'read volatile'
type BYTES
count 0
control.7 {
iface CARD
name 'HDMI/DP,pcm=7 Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.8 {
iface MIXER
index 1
comment {
access read
type IEC958
count 1
control.9 {
iface MIXER
index 1
comment {
access read
type IEC958
count 1
control.10 {
iface MIXER
index 1
comment {
access 'read write'
type IEC958
count 1
control.11 {
iface MIXER
index 1
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.12 {
iface PCM
device 7
name ELD
value ''
comment {
type BYTES
count 0
control.13 {
iface CARD
name 'HDMI/DP,pcm=8 Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.14 {
iface MIXER
index 2
comment {
access read
type IEC958
count 1
control.15 {
iface MIXER
index 2
comment {
access read
type IEC958
count 1
control.16 {
iface MIXER
index 2
comment {
access 'read write'
type IEC958
count 1
control.17 {
iface MIXER
index 2
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.18 {
iface PCM
device 8
name ELD
value ''
comment {
type BYTES
count 0
control.19 {
iface CARD
name 'HDMI/DP,pcm=9 Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.20 {
iface MIXER
index 3
comment {
access read
type IEC958
count 1
control.21 {
iface MIXER
index 3
comment {
access read
type IEC958
count 1
control.22 {
iface MIXER
index 3
comment {
access 'read write'
type IEC958
count 1
control.23 {
iface MIXER
index 3
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.24 {
iface PCM
device 9
name ELD
value ''
comment {
type BYTES
count 0
control.25 {
iface CARD
name 'HDMI/DP,pcm=10 Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.26 {
iface MIXER
index 4
comment {
access read
type IEC958
count 1
control.27 {
iface MIXER
index 4
comment {
access read
type IEC958
count 1
control.28 {
iface MIXER
index 4
comment {
access 'read write'
type IEC958
count 1
control.29 {
iface MIXER
index 4
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.30 {
iface PCM
device 10
name ELD
value ''
comment {
type BYTES
count 0
control.31 {
iface CARD
name 'HDMI/DP,pcm=11 Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.32 {
iface MIXER
index 5
comment {
access read
type IEC958
count 1
control.33 {
iface MIXER
index 5
comment {
access read
type IEC958
count 1
control.34 {
iface MIXER
index 5
comment {
access 'read write'
type IEC958
count 1
control.35 {
iface MIXER
index 5
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.36 {
iface PCM
device 11
name ELD
value ''
comment {
type BYTES
count 0
control.37 {
iface PCM
device 3
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access 'read write'
type INTEGER
count 8
range '0 - 36'
control.38 {
iface PCM
device 7
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access 'read write'
type INTEGER
count 8
range '0 - 36'
control.39 {
iface PCM
device 8
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access 'read write'
type INTEGER
count 8
range '0 - 36'
control.40 {
iface PCM
device 9
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access 'read write'
type INTEGER
count 8
range '0 - 36'
control.41 {
iface PCM
device 10
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access 'read write'
type INTEGER
count 8
range '0 - 36'
control.42 {
iface PCM
device 11
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access 'read write'
type INTEGER
count 8
range '0 - 36'
--endcollapse--
!!All Loaded Modules
aesni_intel
amdgpu
at24
bpf_preload
cec
coretemp
crc16
crc32_pclmul
crc32c_generic
crc32c_intel
crct10dif_pclmul
cryptd
crypto_simd
crypto_user
dm_mod
drm_buddy
drm_display_helper
drm_ttm_helper
e1000e
ext4
fat
fuse
gf128mul
ghash_clmulni_intel
gpu_sched
hp_wmi
i2c_i801
i2c_smbus
iTCO_vendor_support
iTCO_wdt
intel_cstate
intel_pmc_bxt
intel_powerclamp
intel_rapl_common
intel_rapl_msr
intel_uncore
ip_tables
irqbypass
jbd2
joydev
kvm
kvm_intel
ledtrig_audio
loop
lpc_ich
mac_hid
mbcache
mei
mei_hdcp
mei_me
mei_pxp
mousedev
pcspkr
platform_profile
polyval_clmulni
polyval_generic
qrtr
rapl
rfkill
sha512_ssse3
snd
snd_hda_codec
snd_hda_codec_generic
snd_hda_codec_hdmi
snd_hda_codec_realtek
snd_hda_core
snd_hda_intel
snd_hwdep
snd_intel_dspcfg
snd_intel_sdw_acpi
snd_pcm
snd_timer
soundcore
sparse_keymap
ttm
usbhid
vfat
video
wmi
wmi_bmof
x86_pkg_temp_thermal
x_tables
!!Sysfs Files
/sys/class/sound/hwC0D0/init_pin_configs:
0x12 0x411111f0
0x14 0x01014010
0x15 0x411111f0
0x16 0x411111f0
0x18 0x01a19840
0x19 0x02a19c50
0x1a 0x01813041
0x1b 0x02014c20
0x1c 0x9933014f
0x1d 0x411111f0
0x1e 0x01441130
0x1f 0x01c46160
/sys/class/sound/hwC0D0/driver_pin_configs:
/sys/class/sound/hwC0D0/user_pin_configs:
/sys/class/sound/hwC0D0/init_verbs:
/sys/class/sound/hwC0D0/hints:
/sys/class/sound/hwC1D0/init_pin_configs:
0x03 0x185600f0
0x05 0x185600f0
0x07 0x185600f0
0x09 0x185600f0
0x0b 0x185600f0
0x0d 0x185600f0
0x0f 0x585600f0
/sys/class/sound/hwC1D0/driver_pin_configs:
/sys/class/sound/hwC1D0/user_pin_configs:
/sys/class/sound/hwC1D0/init_verbs:
/sys/class/sound/hwC1D0/hints:
!!ALSA/HDA dmesg
[ 18.885075] intel_rapl_common: RAPL package-0 domain package locked by BIOS
[ 19.046322] snd_hda_intel 0000:00:1b.0: enabling device (0100 -> 0102)
[ 19.046715] snd_hda_intel 0000:01:00.1: enabling device (0100 -> 0102)
[ 19.046830] snd_hda_intel 0000:01:00.1: Force to non-snoop mode
[ 19.127264] audit: type=1130 audit(1692942072.145:7): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-fsck@dev-disk-by\x2duuid-CEE9\x2dFA86 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 19.307380] mousedev: PS/2 mouse device common for all mice
[ 19.388421] input: HDA ATI HDMI HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input10
[ 19.388459] input: HDA ATI HDMI HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input11
[ 19.388489] input: HDA ATI HDMI HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input12
[ 19.388519] input: HDA ATI HDMI HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input13
[ 19.388558] input: HDA ATI HDMI HDMI/DP,pcm=10 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input14
[ 19.388588] input: HDA ATI HDMI HDMI/DP,pcm=11 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input15
[ 19.838674] snd_hda_codec_realtek hdaudioC0D0: ALC262: SKU not ready 0x411111f0
[ 19.839026] snd_hda_codec_realtek hdaudioC0D0: ignore pin 0x1b with mismatching assoc# 0x2 vs 0x1
[ 19.839153] snd_hda_codec_realtek hdaudioC0D0: autoconfig for ALC262: line_outs=1 (0x14/0x0/0x0/0x0/0x0) type:line
[ 19.839157] snd_hda_codec_realtek hdaudioC0D0: speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[ 19.839161] snd_hda_codec_realtek hdaudioC0D0: hp_outs=0 (0x0/0x0/0x0/0x0/0x0)
[ 19.839164] snd_hda_codec_realtek hdaudioC0D0: mono: mono_out=0x0
[ 19.839166] snd_hda_codec_realtek hdaudioC0D0: dig-out=0x1e/0x0
[ 19.839168] snd_hda_codec_realtek hdaudioC0D0: inputs:
[ 19.839170] snd_hda_codec_realtek hdaudioC0D0: Rear Mic=0x18
[ 19.839173] snd_hda_codec_realtek hdaudioC0D0: Front Mic=0x19
[ 19.839175] snd_hda_codec_realtek hdaudioC0D0: Line=0x1a
[ 19.839177] snd_hda_codec_realtek hdaudioC0D0: CD=0x1c
[ 19.839179] snd_hda_codec_realtek hdaudioC0D0: dig-in=0x1f
[ 19.849444] input: HDA Intel PCH Rear Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input16
[ 19.849484] input: HDA Intel PCH Front Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input17
[ 19.849513] input: HDA Intel PCH Line as /devices/pci0000:00/0000:00:1b.0/sound/card0/input18
[ 19.849542] input: HDA Intel PCH Line Out as /devices/pci0000:00/0000:00:1b.0/sound/card0/input19
[ 20.140495] audit: type=1130 audit(1692942073.159:8): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=plymouth-read-write comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 22.134934] [drm] Display Core initialized with v3.2.207!
[ 22.154720] snd_hda_intel 0000:01:00.1: bound 0000:01:00.0 (ops amdgpu_dm_audio_component_bind_ops [amdgpu])
[ 22.287161] audit: type=1130 audit(1692942075.305:14): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-tmpfiles-setup comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
