FRITZ!WLan Stick n v2 "not" working
I have a FRITZ!WLan Stick n v2. It is working sometimes, but then it disconnects (the wireless menu dissapears from the network menu and then appears again). I searched on the internet and found out that this has to do with the stick recognized as a cd-rom due to the windows drivers on it.
How can I fix this issue?
Thanks for all help :slight_smile:
Here the inxi-output (i only took a photo from the output; if there are any questions, please ask):
Kernel: 5.15.60-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.1 parameters: BOOT_IMAGE=/boot/vmlinuz-5.15-x86_64
root-UUID=d946b701-62c0-44fe-9c4c-e8aca920326c rw quiet apparmor=1 security-apparmor udev.log priority=3
Desktop: Xfce v: 4.16.0 tk: Gtk v: 3.24.29 info: xfce4-panel wm: xfwm v: 4.16.1 dm: LightDM v: 1.32.0 Distro: Manjaro Linux base: Arch Linux Machine:
Type: Desktop System: Dell product: OptiPlex 3020 v: 01 serial: <filter> Chassis: type: 6 serial: <filter>
Mobo: Dell model: 040DDP v: A01 serial: <filter> BIOS: Dell v: A07 date: 01/14/2015
RAM: total: 7.68 GiB used: 847.1 MiB (10.8%)
Array-1: capacity: 16 GiB slots: 2 EC: None max-module-size: 8 GiB note: est.
Device-1: DIMM1 type: DDR3 detail: synchronous size: 4 GiB
speed: 1600 MT/s volts: N/A width (bits): data: 64 total: 64 manufacturer: Micron part-no: 8JTF51264AZ-1G6E1 serial: <filter> Device-2: DIMM2 type: DDR3 detail: synchronous size: 4 GiB speed: 1600 MT/s volts: N/A width (bits): data: 64 total: 64 manufacturer: Micron part-no: 8JTF51264AZ-1G6E1 serial: <filter>
Info: model: Intel Core i5-4590 socket: BGA1155 bits: 64 type: MCP arch: Haswell gen: core 4 built: 2013-15 process: Intel 22nm family: 6 model-id: 0x3C (60) stepping: 3 microcode: 0x28 I
Topology: cpus: 1x cores: 4 smt: <unsupported> cache: L1: 256 KiB desc: d-4x32 KiB; 1-4x32 KiB L2: 1024 KiB desc: 4x256 KiB L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 1059 high: 1504 min/max: 800/3700 base/boost: 3300/3800 scaling: driver: intel_cpufreq governor: schedutil volts: 1.2 V ext-clock: 100 MHz cores: 1: 1504 2: 798 3: 798 4: 1138 bogomips: 26349 Flags: abm acpi aes aperfmperf apic arat arch_perfmon avx avx2 bmi1 bmi2 bts clflush cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority flush_l1d fma fpu fsgsbase fxsr ht ibpb ibrs ida invpcid invpcid_single lahf_lm 1m mca mce md_clear mmx monitor movbe msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand rdtscp rep_good sdbg sep smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer vme vmx vnmi vpid x2apic xsave xsaveopt xtopology xtpr
Type: 11tf mitigation: PTE Inversion; VMX: conditional cache flushes, SMT disabled
Type: spec_store_bypass mitigation: Speculative Store Bypass disabled via pretl and seccomp
Type: spectre vi mitigation: usercopy/swapgs barriers and user pointer sanitization
Type: spectre v2 mitigation: Retpolines, IBPB: conditional, IBRS_FW, STIBP: disabled, RSB filling, PBRSB-eIDRS: Not affected
Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor Integrated Graphics vendor: Dell driver: 1915 v: kernel arch: Gen-5.75 process: Intel 45nm built: 2010 ports: active: VGA-1 empty: DP-1, HDMI-A-1 bus-ID: 00392.0 chip-ID: 8086:0412 class-ID: 0300
Display: x11 server: X.Org v: 21.1.4 compositor: xfum v: 4.16.1 driver: X: loaded: modesetting alternate: fbdev, vesa gpu: 1915 display-ID: :0.0 screens: 1
Screen-1:s-res: 1920x1080 s-dpl: 96 8-size: 508x285mm (20.00x11.22") 8-ding: $82mm (22.93")
Monitor-1: VGA-1 model: LG (GoldStar) W2343 serial: <filter> built: 2009 res: 1920x1080 hz: 60 dpi: 96 gamma: 1.2 size: 510x290mm (20.08x11.42") diag: 587mm (23.1") ratio: 16:9 modes: max: 1920x1080 min: 720x400 Message: Unable to show GL data. Required tool glxinfo missing.
Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor HD Audio vendor: Dell driver: snd_hda_intel v: kernel bus-ID: 00:03.0 chip-ID: 8086:0c0c
class-ID: 0403
Device-2: Intel 8 Series/C220 Series High Definition Audio vendor: Dell driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:8c20 class-ID: 0403
Sound Server-1: ALSA v: k5.15.60-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.56 running: no
vendor: Dell driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: e000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: AVM GmbH FRITZ WLAN N v2 [RT5572/1t2870.bin] type: USB driver: rt2800usb bus-ID: 3-9:15 chip-ID: 057c:8501 class-ID: 0000 serial: <filter>
IF: wlp0s20u9 state: down mac: <filter>
WAN IP: No WAN IP found. Connected to web? SSL issues? Try enabling dig
Local Storage: total: 931.51 GiB used: 10.56 GiB (1.1%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000DM003-1ER162
size: 931.51 GiB block-size: physical: 4096 B logical: 512 8 speed: 6.0 Gb/s type: HDD xpm: 7200 serial: <filter> rev: CC45 scheme: GPT
Optical-1: /dev/sze vendor: HL-DT-ST model: DVD+-RW GHBON rev: A181
dev-links: cdrom
Features: speed: 12 multisession: yes audio: yes dvd: yes
rw: cd-z,cd-zw.dvd-x, dvd-zam state: running
ID-1: /raw-size: 244.14 GiB size: 239.25 GiB (98.00%) used: 10.56 GiB
(4.4%) fs: ext4 block-size: 4096 B dev: /dev/sda5 maj-min: 8:5 label: N/A uuid: d946b701-62c0-44fe-9c4c-e8aca920326c
10-1: /dev/sda1 maj-min: 8:1 size: 100 MiB
uuid: 7CD9-1A78
vfat label: SYSTEM
TD-2: /dev/sda2 maj-min: 8:2 size: 16 MiB fs: N/A label: N/A uuid: N/A
3D-35 /dev/sda3 maj-min: 8:3 size: 686.74 61B
uuid: 886ADF926ADF4BAE
ntfs label: N/A
ID:4: /dev/sda4 maj-min: 8:4 size: 531 MiB fs: ntfs label: N/A
uuid: DEDC7B80DC78522F
Hub-1: 1-0:1 info: Full speed or Foot hub ports: 2 rev: 2.0 speed: 480 Mb/s chip-ID: 1d6b:0002 class-ID: 0900
Hub-2; 1-1:2 info: Intel Integrated Rate Matching Hub ports: 4 rev: 2,0 speed: 480 Mb/s chip-ID: 8087:8008 class-ID: 0900
Hub-3: 2-0:1 info: Full speed of root hub ports: 2 rev: 2.0 speed: 480 Mb/s chip-ID: 1d6b:0002 class-ID: 0900
Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 6 rev: 2.0 speed: 480 Mb/s chip-ID: 8087:8000 class-ID: 0900
Hub-5: 3-0:1 info: Hi-speed hub with single TT ports: 10 rev: 2.0 speed: 480 Mb/s chip-ID: 1d6b:0002 class-ID: 0900
Device-1: 3-3:2 info: Lenovo USB Optical Mouse type: Mouse
driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 1.5 Mb/s power: 100mA chip-ID: 17ef:6020 class-ID: 0301
Device-2: 3-4:3 info: Lenovo Black Silk Keyboard type: Keyboard, MID driver: hid-generic,usbhid interfaces: 2 rev: 2.0 speed: 1.5 Mb/s power: 100mA chip-ID: 17ef:6024 class-ID: 0300
Device-3: 3-9:15 info: AVM GmbH FRITZ WLAN N v2 (RTS572/xt2870.bin] type: Network driver: rt2800usb interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 450mA chip-ID: 057c:8501 class-ID: 0000 serial: <filter> Hub-6: 4-0:1 info: Super-speed hub ports: 2 rev: 3.0 speed: 5 Gb/s chip-ID: 1d6b:0003 class-ID: 0900
System Temperatures: cpu: 304 C mobo: MA
Fan Speeds (RPM): MA
Processes: 101 Uptime: 1m makeups: Init: systand v: 251 default: graphical tool: systemctl Compilers: gcc: 12.4.1 clang: 14.4.6 Packages: pacman: 1003 14b: 924 flatpak: Shell: Bash (audio) : 5.4.16 running-in: xfce-terminal inxi: 3.3.29
Welcome to Manjaro! :smiling_face_with_three_hearts:
  1. Please read the information behind this link. It will help you to post necessary information. [HowTo] Provide System Information
  2. Please press the three dots … below your post and then press the :pencil2:
  • If you give us information about your system, we can see what we’re talking about and make better suggestions.
  • You can do this by using inxi in a terminal or in console.
(while the stick is pluged in)
  • Personally identifiable information such as serial numbers and MAC addresses are filtered out by this command
  • Presenting the information in this way allows everyone to be familiar with the format and quickly find the items they need without missing anything.
  1. Copy the output from inxi (including the command) and paste it into your post.
  • To make it more readable, add 3 backticks ``` on an extra line before and after the pasted text.
    (Wisdom lies in reading :wink: )
