I recently installed Manjaro and have been having issues with it freezing completely. REISUB or REISUO do not work despite the sysrq key being enabled manually every time on restart, and the only way to get it to shut off from what I can tell is holding the power button. This issue has persisted on multiple different kernels.
Kernel: 5.14.0-0-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.14-x86_64
root=UUID=735ea156-b68c-496c-bb0a-99bb18b47a7c rw quiet udev.log_priority=3
Console: tty pts/2 wm: kwin_x11 DM: SDDM Distro: Manjaro Linux
base: Arch Linux
Type: Laptop System: HP product: HP Laptop 15-dw0xxx v: Type1ProductConfigId
serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: HP model: 85EF v: 36.30 serial: <filter> UEFI: Insyde v: F.13
date: 08/01/2019
ID-1: BAT1 charge: 31.2 Wh (87.2%) condition: 35.8/41.0 Wh (87.1%)
volts: 13.0 min: 11.4 model: Hewlett-Packard PABAS0241231 type: Li-ion
serial: <filter> status: Charging
RAM: total: 3.73 GiB used: 926.7 MiB (24.3%)
Array-1: capacity: 32 GiB slots: 2 EC: None max-module-size: 16 GiB
note: est.
Device-1: Bottom-Slot 1(left) size: 4 GiB speed: 2400 MT/s type: DDR4
detail: synchronous bus-width: 64 bits total: 64 bits manufacturer: Micron
part-no: 4ATF51264HZ-2G6E1 serial: <filter>
Device-2: Bottom-Slot 2(right) size: No Module Installed
Info: Dual Core model: Intel Core i3-8145U socket: BGA1528 (U3E1)
note: check bits: 64 type: MT MCP arch: Kaby Lake note: check family: 6
model-id: 8E (142) stepping: B (11) microcode: EA cache: L2: 4 MiB
bogomips: 18406
Speed: 800 MHz min/max: 400/3900 MHz base/boost: 1980/3900 volts: 0.7 V
ext-clock: 100 MHz Core speeds (MHz): 1: 800 2: 800 3: 782 4: 800
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_capabilities
arch_perfmon art avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc
cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms
est f16c flexpriority flush_l1d fma fpu fsgsbase fxsr ht hwp hwp_act_window
hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid invpcid_single lahf_lm lm
mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat
pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pts rdrand
rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1 sse4_2
ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer vme
vmx vnmi vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
Device-1: Intel WhiskeyLake-U GT2 [UHD Graphics 620] vendor: Hewlett-Packard
driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:3ea0 class-ID: 0300
Device-2: Quanta HP TrueVision HD Camera type: USB driver: uvcvideo
bus-ID: 1-5:2 chip-ID: 0408:5365 class-ID: 0e02
Display: server: X.Org 1.20.13 compositor: kwin_x11 driver:
loaded: modesetting alternate: fbdev,vesa display-ID: :0 screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.2x8.0")
s-diag: 414mm (16.3")
OpenGL: renderer: Mesa Intel UHD Graphics 620 (WHL GT2) v: 4.6 Mesa 21.2.1
direct render: Yes
Device-1: Intel Cannon Point-LP High Definition Audio
vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
alternate: snd_soc_skl,snd_sof_pci_intel_cnl bus-ID: 00:1f.3
chip-ID: 8086:9dc8 class-ID: 0403
Sound Server-1: ALSA v: k5.14.0-0-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.34 running: yes
vendor: Hewlett-Packard driver: r8169 v: kernel port: 4000 bus-ID: 01:00.0
Device-2: Realtek RTL8821CE 802.11ac PCIe Wireless Network Adapter
vendor: Hewlett-Packard driver: rtw_8821ce v: N/A modules: rtw88_8821ce
port: 3000 bus-ID: 02:00.0 chip-ID: 10ec:c821 class-ID: 0280
Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci
v: 3.0 port: 5060 bus-ID: 00:17.0 chip-ID: 8086.282a rev: 30 class-ID: 0104
Local Storage: total: 119.24 GiB used: 7.4 GiB (6.2%)
ID-1: /dev/sda maj-min: 8:0 vendor: SanDisk model: SD9SN8W-128G-1006
size: 119.24 GiB block-size: physical: 4096 B logical: 512 B sata: 3.3
speed: 6.0 Gb/s type: SSD serial: <filter> rev: 4006 temp: 42 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 115d 3h cycles: 1472
read: 399.9 MiB written: 205.5 MiB
ID-1: / raw-size: 118.95 GiB size: 116.52 GiB (97.96%) used: 7.4 GiB (6.4%)
fs: ext4 block-size: 4096 B dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: 735ea156-b68c-496c-bb0a-99bb18b47a7c
used: 288 KiB (0.1%) fs: vfat block-size: 512 B dev: /dev/sda1 maj-min: 8:1
label: NO_LABEL uuid: EC32-BCD5
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 12 rev: 2.0
Device-1: 1-5:2 info: Quanta HP TrueVision HD Camera type: Video
Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 6 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 39.0 C mobo: 29.8 C
Processes: 191 Uptime: 4m wakeups: 1 Init: systemd v: 248 tool: systemctl
Compilers: gcc: N/A Packages: pacman: 1046 lib: 294 Shell: Zsh (sudo) v: 5.8
default: Bash v: 5.1.8 running-in: konsole inxi: 3.3.06
Any suggestions on what I should do?
