Fresh install does not work
Ok,
I’ve stopped trying to be smart and went on install stock manjaro, just clicking next, next, continue. Only setting up LUKS partition encryption.
I booted into the machine, see SDDM login (i.e. graphics are working), enter my password…and then the whole system gets stuck on loading bar. Not really sure what can I do about it.
Hey, this can probably be fixed, but to help you (or help yourself) some more info in required. A starting point is this post: How to provide good information
Can you post the partitioning ?
The issue appears to resolve itself on second boot. Which is great. Anyhow to fill in the required data:
partitioning:
[nmiculinic@atlas ~]$ lsblk
NAME                                          MAJ:MIN RM   SIZE RO TYPE  MOUNTPOINT
nvme0n1                                       259:0    0 953,9G  0 disk
├─nvme0n1p1                                   259:1    0     5G  0 part  /boot/efi
├─nvme0n1p2                                   259:2    0   300G  0 part
│ └─luks-e4dc2010-467e-4b24-89c7-00f6be12d428 254:0    0   300G  0 crypt /
├─nvme0n1p3                                   259:3    0    16M  0 part
└─nvme0n1p4                                   259:4    0 648,9G  0 part
  Kernel: 5.10.36-2-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
  root=UUID=9ffa1fca-9f13-4de2-84e9-b4a563a13a88 rw quiet
  cryptdevice=UUID=e4dc2010-467e-4b24-89c7-00f6be12d428:luks-e4dc2010-467e-4b24-89c7-00f6be12d428
  root=/dev/mapper/luks-e4dc2010-467e-4b24-89c7-00f6be12d428 apparmor=1
  Desktop: KDE Plasma 5.21.5 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
  Type: Desktop Mobo: ASUSTeK model: ROG MAXIMUS XI EXTREME v: Rev 1.xx
  serial: <filter> UEFI: American Megatrends v: 1302 date: 09/02/2019
  Device-1: hidpp_battery_0
  model: Logitech MX Vertical Advanced Ergonomic Mouse serial: <filter>
  charge: 55% (should be ignored) rechargeable: yes status: Discharging
  RAM: total: 31.28 GiB used: 2.29 GiB (7.3%)
  Info: 8-Core model: Intel Core i9-9900K bits: 64 type: MT MCP
  arch: Kaby Lake note: check family: 6 model-id: 9E (158) stepping: D (13)
  microcode: DE cache: L2: 16 MiB bogomips: 115232
  Speed: 800 MHz min/max: 800/5000 MHz Core speeds (MHz): 1: 800 2: 800 3: 800
  4: 800 5: 800 6: 800 7: 800 8: 800 9: 800 10: 800 11: 800 12: 800 13: 800
  14: 800 15: 800 16: 800
  Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_capabilities
  arch_perfmon art avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc
  cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms
  est f16c flexpriority flush_l1d fma fpu fsgsbase fxsr ht hwp hwp_act_window
  hwp_epp hwp_notify ibpb ibrs ibrs_enhanced ida intel_pt invpcid
  invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe mpx msr mtrr
  nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni
  popcnt pse pse36 pts rdrand rdseed rdtscp rep_good sdbg sep smap smep smx ss
  ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc
  tsc_adjust tsc_deadline_timer vme vmx vnmi vpid x2apic xgetbv1 xsave xsavec
  xsaveopt xsaves xtopology xtpr
  Type: srbds mitigation: TSX disabled
  Device-1: NVIDIA TU104 [GeForce RTX 2080 SUPER] vendor: Micro-Star MSI
  driver: nouveau v: kernel bus-ID: 01:00.0 chip-ID: 10de:1e81 class-ID: 0300
  Device-2: Huawei HiCamera type: USB driver: snd-usb-audio,uvcvideo
  bus-ID: 1-3.4:11 chip-ID: 12d1:4321 class-ID: 0102 serial: <filter>
  Display: x11 server: X.Org 1.20.11 compositor: kwin_x11 driver:
  loaded: modesetting,nouveau alternate: fbdev,nv,vesa display-ID: :0
  screens: 1
  Screen-1: 0 s-res: 3440x1440 s-dpi: 96 s-size: 910x381mm (35.8x15.0")
  s-diag: 987mm (38.8")
  Monitor-1: DP-3 res: 3440x1440 hz: 60 dpi: 109 size: 800x335mm (31.5x13.2")
  diag: 867mm (34.1")
  OpenGL: renderer: NV164 v: 4.3 Mesa 21.0.3 direct render: Yes
  Device-1: Intel Cannon Lake PCH cAVS vendor: ASUSTeK driver: snd_hda_intel
  v: kernel alternate: snd_soc_skl,snd_sof_pci bus-ID: 00:1f.3
  Device-2: NVIDIA TU104 HD Audio vendor: Micro-Star MSI driver: snd_hda_intel
  v: kernel bus-ID: 01:00.1 chip-ID: 10de:10f8 class-ID: 0403
  Device-3: RODE Microphones RODE NT-USB type: USB
  driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-3.3:10 chip-ID: 19f7:0003
  class-ID: 0300
  Device-4: Huawei HiCamera type: USB driver: snd-usb-audio,uvcvideo
  Sound Server-1: ALSA v: k5.10.36-2-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.28 running: no
  Device-1: Intel Wireless-AC 9560 [Jefferson Peak] driver: iwlwifi v: kernel
  bus-ID: 00:14.3 chip-ID: 8086:a370 class-ID: 0280
  IF: wlo1 state: down mac: <filter>
  Device-2: Intel Ethernet I219-V vendor: ASUSTeK driver: e1000e v: kernel
  port: efa0 bus-ID: 00:1f.6 chip-ID: 8086:15bc class-ID: 0200
  IF: eno2 state: down mac: <filter>
  Device-3: Aquantia AQC111 NBase-T/IEEE 802.3bz Ethernet [AQtion]
  vendor: ASUSTeK driver: atlantic v: kernel port: 3000 bus-ID: 04:00.0
  chip-ID: 1d6a:11b1 class-ID: 0200
  IF: enp4s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) type: USB
  driver: btusb v: 0.8 bus-ID: 1-14:6 chip-ID: 8087:0aaa class-ID: e001
  Device-1: luks-e4dc2010-467e-4b24-89c7-00f6be12d428 maj-min: 254:0
  type: LUKS dm: dm-0 size: 300 GiB
  Components:
  p-1: nvme0n1p2 maj-min: 259:2 size: 300 GiB
  Local Storage: total: 953.87 GiB used: 9.03 GiB (0.9%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 970 PRO 1TB
  size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
  lanes: 4 rotation: SSD serial: <filter> rev: 1B2QEXP7 temp: 38.9 C
  scheme: GPT
  ID-1: / raw-size: 300 GiB size: 294.23 GiB (98.08%) used: 8.87 GiB (3.0%)
  fs: ext4 dev: /dev/dm-0 maj-min: 254:0
  mapped: luks-e4dc2010-467e-4b24-89c7-00f6be12d428 label: N/A
  uuid: 9ffa1fca-9f13-4de2-84e9-b4a563a13a88
  ID-2: /boot/efi raw-size: 5 GiB size: 4.99 GiB (99.80%)
  used: 165.7 MiB (3.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
  label: N/A uuid: 501B-DA92
  ID-1: /dev/nvme0n1p3 maj-min: 259:3 size: 16 MiB fs: <superuser required>
  label: N/A uuid: N/A
  ID-2: /dev/nvme0n1p4 maj-min: 259:4 size: 648.85 GiB fs: ntfs label: N/A
  uuid: 6AFEFC54FEFC1A51
  Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 16 rev: 2.0
  Hub-2: 1-2:2 info: ASMedia ASM1074 High-Speed hub ports: 4 rev: 2.1
  speed: 480 Mb/s power: 100mA chip-ID: 174c:2074 class-ID: 0900
  Hub-3: 1-3:3 info: Texas Instruments ports: 6 rev: 2.1 speed: 480 Mb/s
  chip-ID: 0451:8442 class-ID: 0900
  Device-1: 1-3.1:9 info: Alcor Micro Keyboard type: Keyboard,HID
  driver: maltron,usbhid interfaces: 2 rev: 1.1 speed: 1.5 Mb/s power: 50mA
  chip-ID: 058f:9410 class-ID: 0300
  Device-2: 1-3.2:5 info: Logitech Unifying Receiver type: Keyboard,Mouse,HID
  power: 98mA chip-ID: 046d:c52b class-ID: 0300
  Device-3: 1-3.3:10 info: RODE Microphones RODE NT-USB type: Audio,HID
  driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 1.1
  speed: 12 Mb/s power: 100mA chip-ID: 19f7:0003 class-ID: 0300
  Device-4: 1-3.4:11 info: Huawei HiCamera type: Video,Audio
  power: 2mA chip-ID: 12d1:4321 class-ID: 0102 serial: <filter>
  Device-5: 1-3.5:7 info: Texas Instruments type: HID
  driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 480 Mb/s
  chip-ID: 0451:82ff class-ID: 0300 serial: <filter>
  Hub-4: 1-13:4 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
  power: 100mA chip-ID: 05e3:0610 class-ID: 0900
  Device-1: 1-13.3:8 info: ASUSTek AURA LED Controller type: HID
  driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 12 Mb/s
  power: 100mA chip-ID: 0b05:1872 class-ID: 0300 serial: <filter>
  Device-2: 1-14:6 info: Intel Bluetooth 9460/9560 Jefferson Peak (JfP)
  type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s
  power: 100mA chip-ID: 8087:0aaa class-ID: e001
  Hub-5: 2-0:1 info: Full speed (or root) Hub ports: 10 rev: 3.1
  speed: 10 Gb/s chip-ID: 1d6b:0003 class-ID: 0900
  Hub-6: 2-2:2 info: ASMedia ASM1074 SuperSpeed hub ports: 4 rev: 3.0
  speed: 5 Gb/s power: 8mA chip-ID: 174c:3074 class-ID: 0900
  Hub-7: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
  Hub-8: 4-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s
  Hub-9: 5-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
  Hub-10: 6-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.0 speed: 5 Gb/s
  System Temperatures: cpu: 27.8 C mobo: N/A gpu: nouveau temp: 31.0 C
  Fan Speeds (RPM): N/A gpu: nouveau fan: 760
  Processes: 372 Uptime: 12m wakeups: 2 Init: systemd v: 247 tool: systemctl
  Compilers: gcc: 10.2.0 Packages: pacman: 1212 lib: 330 flatpak: 0
  Shell: Bash v: 5.1.8 running-in: yakuake inxi: 3.3.04
(manjaro log helper)
https://paste.ubuntu.com/p/mjfR6qbFQQ/
If you see some potential issue that’d be great
Hi,
One option to check is if the nvidia drivers produce the same issue after install , the nouveau drivers are open source, the nvidia are closed. For nvidia cards my experience is that this matters and running one or the other can greatly improve your experience depending on the specific hardware one is running. See the manjaro wiki for guidance on installing the drivers on a running system.
If installing again is your preferred option to check, booting with propriety drivers enabled would be the same albeit more lengthy process. iirc this forces the installation of the propriety drivers during installation but is has been a while since I installed on hardware.
I’m not using nvidia drivers since I’m connected via Display Port…and in latest updates they borked DP support, causing me to have to reinstall everything.
Can you give some more system info ?
Like posted from @Hanzel ! (Post #2)
