Freezing issues in kernel 6.15 and 6.16
Hello!
Since I bought the Zenbook S14 and install Manjaro on it, I’m facing complete random freezes. I can’t even Ctrl + PrtSc + REISUB on it and also journalctl --boot=-1 --no-pager shows no relevant info. Is there someone having the same issue?
Things that I’ve already tried:
  1. Set the CPU0 to idle (as suggested in GitHub - dantmnf/zenbook-s14-linux: ASUS Zenbook S 14 (UX5406))
  2. Use different kernel versions (6.15 and 6.16rc, freezes happens on both)
  3. Use only Performance mode
  4. sysctl "kernel.io_uring_disabled = 2"
  5. BIOS upgrade
I’m also following some threads related to the subject but didn’t found any permanent solution:
https://www.reddit.com/r/chimeralinux/comments/1l47qqo/comment/n0pi2vx/?context=3
https://bbs.archlinux.org/viewtopic.php?pid=2251990
Welcome to Manjaro! :smiling_face_with_three_hearts:
  1. Please read the information behind this link. It will help you to post necessary information.
  1. Please press the 3 dots … below your post and then press the :pencil2:
  • If you give us information about your system, we can see what we’re talking about and make better suggestions.
  • You can do this by using inxi -czv8 as root in a terminal or in console.
sudo inxi --color --filter --verbosity=8
  • Personally identifiable information such as serial numbers and MAC addresses are filtered out by this command
  • Presenting the information in this way allows everyone to be familiar with the format and quickly find the items they need without missing anything.
  1. Copy the output from inxi (including the command) and paste it into your post.
  • To make it more readable, add 3 backticks ``` on an extra line before and after the pasted text.
  1. Or we can try to play hide and seek :wink:
    Have you already :mag: for your problem in the forum ? (Wisdom lies in asking → listening → reading :wink: )
Isn’t it :point_right:Alt + PrtSc + REISUB? By the way, have you enabled SYSRQ for rebooting. I had no idea either back then, but the ArchWiki states, you have to enable it first:
https://wiki.archlinux.org/title/Keyboard_shortcuts#Enabling
systemd has the SysRq permissions bitmask set to 0x10 by default, which does not allow process signalling or rebooting.
I for one have added sysrq_always_enabled=1 to the kernel parameters at /etc/default/grub to make sure SYSRQ is fully enabled.
Have you tried switching to another terminal when the screen freezes? Like CTRL + ALT + F3. You might have to wait for up to ~30 seconds in case this works. Afterwards you can switch back with CTRL + ALT + F2 and your session should still be running. That’s at least working for me.
Have you tried an LTS kernel like 6.12?
Thank you for the reply!
Yes, it is Alt + PrtSc + REISUB (I just typed it wrong). And yes, I have enable it already.
LTS 6.12 suddenly stop working for me in Manjaro somehow and all that I get using this kernel is a completely black screen. Even though, 6.12 doesn’t work well with this laptop components.
About trying to access another terminal, that’s not possible. The entire laptop freezes, there is no response from anything, even capslock, nothing. It’s not a driver/interface issue, it’s a complete freeze. (Even trying to access using SSH from another computer isn’t possible.
sudo inxi --color --filter --verbosity=8         ✔
[sudo] password for erico:
  Kernel: 6.16.0-rc6-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.1.1
    parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.16-x86_64
    root=UUID=ae5acddc-3158-480e-984d-09438937cad1 rw rootflags=subvol=@
    quiet splash apparmor=1 security=apparmor udev.log_priority=3
  Desktop: GNOME v: 48.3 tk: GTK v: 3.24.49 wm: gnome-shell
    base: Arch Linux
  Type: Laptop System: ASUSTeK product: ASUS Zenbook S 14 UX5406SA_UX5406SA
    v: 1.0 serial: <filter>
  Mobo: ASUSTeK model: UX5406SA v: 1.0 serial: <filter>
    uuid: a81874d0-9584-a44d-b862-7004561be0aa UEFI: American Megatrends LLC.
    v: UX5406SA.307 date: 03/20/2025
  ID-1: BAT0 charge: 72.0 Wh (100.0%) condition: 72.0/72.0 Wh (100.0%)
    volts: 8.8 min: 8.0 model: ASUSTeK ASUS Battery type: Li-ion serial: N/A
    status: full cycles: 6
  System RAM: total: 32 GiB available: 30.82 GiB used: 12.56 GiB (40.7%)
  Array-1: capacity: 32 GiB slots: 8 modules: 8 EC: None
    max-module-size: 4 GiB note: est.
  Device-1: Controller0-ChannelA type: LPDDR5 detail: synchronous
    size: 4 GiB speed: 8533 MT/s volts: curr: 0.5 min: 0.5 max: 0.5
    width (bits): data: 16 total: 16 manufacturer: Micron Technology
    part-no: N/A serial: <filter>
  Device-2: Controller0-ChannelB type: LPDDR5 detail: synchronous
  Device-3: Controller0-ChannelC type: LPDDR5 detail: synchronous
  Device-4: Controller0-ChannelD type: LPDDR5 detail: synchronous
  Device-5: Controller1-ChannelA type: LPDDR5 detail: synchronous
  Device-6: Controller1-ChannelB type: LPDDR5 detail: synchronous
  Device-7: Controller1-ChannelC type: LPDDR5 detail: synchronous
  Device-8: Controller1-ChannelD type: LPDDR5 detail: synchronous
  Slot: 1 type: PCIe gen: 4 status: in use length: other volts: 3.3
    bus-ID: 00:1c.0 children: 1: 55:00.0 class-ID: 0108 type: mass-storage
  Info: model: Intel Core Ultra 7 258V socket: U3E1 bits: 64 type: MCP
    arch: Lunar Lake level: v3 note: check built: 2024+ process: TSMC n3b (3nm)
    family: 6 model-id: 0xBD (189) stepping: 1 microcode: 0x11F
  Topology: cpus: 1x dies: 1 clusters: 5 cores: 8 smt: <unsupported> cache:
    L1: 832 KiB desc: d-4x32 KiB, 4x48 KiB; i-8x64 KiB L2: 14 MiB
    desc: 4x2.5 MiB, 1x4 MiB L3: 12 MiB desc: 1x12 MiB
  Speed (MHz): avg: 1357 min/max: 400/4700:4800:3700 base/boost: 4700/4800
    scaling: driver: intel_pstate governor: powersave volts: 1.1 V
    ext-clock: 100 MHz cores: 1: 1357 2: 1357 3: 1357 4: 1357 5: 1357 6: 1357
    7: 1357 8: 1357 bogomips: 52838
    bts bus_lock_detect clflush clflushopt clwb cmov constant_tsc cpuid
    f16c flexpriority flush_l1d fma fpu fsgsbase fsrm fxsr gfni hfi ht hwp
    hwp_act_window hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ibt
    ida intel_pt invpcid lahf_lm lam lm mca mce md_clear mmx monitor movbe
    movdir64b movdiri msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid
    pclmulqdq pconfig pdcm pdpe1gb pebs pge pku pln pni popcnt pse pse36 pts
    rdpid rdrand rdseed rdt_a rdtscp rep_good sdbg sep serialize sha_ni smap
    smep smx split_lock_detect ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
    syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer
    tsc_known_freq umip user_shstk vaes vme vmx vnmi vpclmulqdq vpid waitpkg
    wbnoinvd x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
    conditional; PBRSB-eIBRS: Not affected; BHI: BHI_DIS_S
  Device-1: Intel Lunar Lake [Intel Arc Graphics 130V / 140V] vendor: ASUSTeK
    driver: xe v: kernel arch: Xe2 process: TSMC n3 (3nm) built: 2024+ ports:
    active: HDMI-A-1,eDP-1 empty: DP-1,DP-2 bus-ID: 00:02.0 chip-ID: 8086:64a0
    class-ID: 0300
  Device-2: Shinetech ASUS FHD webcam driver: hid-sensor-hub,usbhid,uvcvideo
    type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-5:3
    chip-ID: 3277:0059 class-ID: fe01 serial: <filter>
  Display: unspecified server: X.org v: 1.21.1.18 with: Xwayland v: 24.1.8
    compositor: gnome-shell driver: X: loaded: N/A unloaded: modesetting
    alternate: fbdev,vesa gpu: xe display-ID: :0
    note: <missing: xdpyinfo/xrandr>
  Monitor-1: HDMI-A-1 model: LG (GoldStar) ULTRAWIDE serial: <filter>
    built: 2016 res: 2560x1080 dpi: 81 gamma: 1.2 chroma: red: x: 0.651 y: 0.333
    green: x: 0.306 y: 0.631 blue: x: 0.149 y: 0.059 white: x: 0.314 y: 0.329
    size: 798x334mm (31.42x13.15") diag: 869mm (34.2") modes: 2560x1080,
    1920x1080, 1680x1050, 1600x900, 1280x1024, 1280x800, 1152x864, 1280x720,
    1024x768, 832x624, 800x600, 720x576, 720x480, 640x480
  Monitor-2: eDP-1 model: Samsung 0x419d built: 2022 res: 2880x1800 dpi: 242
    gamma: 1.2 chroma: red: x: 0.682 y: 0.318 green: x: 0.243 y: 0.714 blue:
    x: 0.137 y: 0.043 white: x: 0.314 y: 0.329 size: 302x189mm (11.89x7.44")
    diag: 356mm (14") ratio: 16:10 modes: 2880x1800
  EDID-Warnings: 1: parse_edid: unknown tag 112
    device: 1 drv: swrast gbm: drv: iris surfaceless: drv: iris x11: drv: iris
    inactive: wayland
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 25.1.6-arch1.1
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel Graphics (LNL)
    device-ID: 8086:64a0 memory: 30.1 GiB unified: yes
  Info: Tools: api: eglinfo,glxinfo x11: xprop
  Device-1: Intel Lunar Lake-M HD Audio vendor: ASUSTeK
    driver: sof-audio-pci-intel-lnl
    alternate: snd_hda_intel,snd_sof_pci_intel_lnl bus-ID: 00:1f.3
    chip-ID: 8086:a828 class-ID: 0401
  API: ALSA v: k6.16.0-rc6-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.4.6 status: n/a (root, process) with:
  Device-1: Intel BE201 320MHz driver: iwlwifi v: kernel port: N/A
    bus-ID: 00:14.3 chip-ID: 8086:a840 class-ID: 0280
  IF: wlo1 state: down mac: <filter>
  Device-2: ASIX AX88179 Gigabit Ethernet driver: cdc_ncm type: USB rev: 3.2
    speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 2-1.3:3 chip-ID: 0b95:1790
    class-ID: 0a00 serial: <filter>
  IF: enp0s13f0u1u3c2 state: up speed: 1000 Mbps duplex: half mac: <filter>
  Device-1: Intel driver: btusb v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s
    lanes: 1 mode: 1.1 bus-ID: 3-6:5 chip-ID: 8087:0037 class-ID: e001
  Local Storage: total: 953.87 GiB used: 51.17 GiB (5.4%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: WD PC
    SN560 SDDPNQE-1T00-1102 size: 953.87 GiB block-size: physical: 512 B
    fw-rev: 74114000 temp: 27.9 C scheme: GPT
  ID-1: / raw-size: 673.08 GiB size: 673.08 GiB (100.00%)
    used: 51.08 GiB (7.6%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p6
    maj-min: 259:6 label: N/A uuid: ae5acddc-3158-480e-984d-09438937cad1
  ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%)
    used: 88.3 MiB (34.5%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
    maj-min: 259:1 label: SYSTEM uuid: 36CE-DF22
  ID-3: /home raw-size: 673.08 GiB size: 673.08 GiB (100.00%)
  ID-4: /var/cache raw-size: 673.08 GiB size: 673.08 GiB (100.00%)
  ID-5: /var/log raw-size: 673.08 GiB size: 673.08 GiB (100.00%)
  ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: N/A label: N/A
    uuid: N/A
  ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 279.44 GiB fs: ntfs label: OS
    uuid: DEEAD137EAD10D21
  ID-3: /dev/nvme0n1p4 maj-min: 259:4 size: 850 MiB fs: ntfs label: RECOVERY
    uuid: D6323C6C323C5429
  ID-4: /dev/nvme0n1p5 maj-min: 259:5 size: 260 MiB fs: vfat label: MYASUS
    uuid: 58F0-9FBB
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  Hub-3: 2-1:2 info: Genesys Logic USB3.2 Hub ports: 4 rev: 3.2
    speed: 10 Gb/s (1.16 GiB/s) lanes: 1 mode: 3.2 gen-2x1 chip-ID: 05e3:0625
  Device-1: 2-1.3:3 info: ASIX AX88179 Gigabit Ethernet
    type: communication,CDC-data driver: cdc_ncm interfaces: 2 rev: 3.2
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 power: 184mA
    chip-ID: 0b95:1790 class-ID: 0a00 serial: <filter>
  Hub-4: 3-0:1 info: hi-speed hub with single TT ports: 8 rev: 2.0
  Hub-5: 3-1:2 info: Genesys Logic Hub ports: 4 rev: 2.1
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 05e3:0610
  Hub-6: 3-1.3:4 info: Genesys Logic Hub ports: 4 rev: 2.0
  Device-1: 3-1.3.1:6 info: Microdia Redragon Mitra RGB Keyboard
    type: keyboard,mouse driver: hid-generic,usbhid interfaces: 2 rev: 2.0
    speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 400mA
    chip-ID: 0c45:5004 class-ID: 0301
  Device-2: 3-5:3 info: Shinetech ASUS FHD webcam type: video,HID
    driver: hid-sensor-hub,usbhid,uvcvideo interfaces: 6 rev: 2.0
  Device-3: 3-6:5 info: Intel type: bluetooth driver: btusb interfaces: 2
    rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 100mA
  Hub-7: 4-0:1 info: super-speed hub ports: 2 rev: 3.1
  System Temperatures: cpu: 41.0 C mobo: N/A
  Fan Speeds (rpm): cpu: 0
  Packages: 1302 pm: nix-default pkgs: 0 pm: nix-sys pkgs: 0 pm: nix-usr
    pkgs: 0 pm: pacman pkgs: 1292 libs: 332 tools: gnome-software,pamac,yay
    pm: flatpak pkgs: 10
    1: https://ftp.tu-chemnitz.de/pub/linux/manjaro/stable/$repo/$arch
    2: https://ask4.mm.fcix.net/manjaro/stable/$repo/$arch
    3: https://ftp.halifax.rwth-aachen.de/manjaro/stable/$repo/$arch
    4: https://ftp.nluug.nl/pub/os/Linux/distr/manjaro/stable/$repo/$arch
    5: https://mirrors.up.pt/pub/manjaro/stable/$repo/$arch
    6: https://mirror.xeonbd.com/manjaro/stable/$repo/$arch
    7: https://mirror.2degrees.nz/manjaro/stable/$repo/$arch
  No nix channels found for user: root
Processes:
  CPU top: 5 of 500
  1: cpu: 10.8% command: fprintd pid: 16421 mem: 13.0 MiB (0.0%)
  2: cpu: 9.9% command: chrome pid: 16147 mem: 313.0 MiB (0.9%)
  3: cpu: 9.5% command: chrome pid: 16186 mem: 362.6 MiB (1.1%)
  4: cpu: 9.0% command: chrome pid: 2490 mem: 605.5 MiB (1.9%)
  5: cpu: 5.9% command: chrome pid: 2908 mem: 317.6 MiB (1.0%)
  Memory top: 5 of 500
  1: mem: 1064.5 MiB (3.3%) command: pamac-manager pid: 6637 cpu: 0.8%
  2: mem: 605.5 MiB (1.9%) command: chrome pid: 2490 cpu: 9.0%
  3: mem: 436.2 MiB (1.3%) command: electron pid: 12913 cpu: 3.8%
  4: mem: 418.8 MiB (1.3%) command: slack pid: 3316 cpu: 1.5%
  5: mem: 404.8 MiB (1.2%) command: tsserver[5.8.2]: pid: 13467 cpu: 1.2%
  Processes: 500 Power: uptime: 18m states: freeze,mem,disk suspend: s2idle
    avail: deep wakeups: 0 hibernate: platform avail: shutdown, reboot,
    suspend, test_resume image: 12.31 GiB services: gsd-power,
    tool: systemctl
  Compilers: gcc: 15.1.1 Shell: Sudo (sudo) v: 1.9.17p1 default: Bash
    v: 5.3.0 running-in: terminator inxi: 3.3.38
My ‘System freezes’ (the discussion you attached in your original post) are caused by ‘race conditions’ in the AMD driver. According to your inxi output, zenbook S14 doesn’t come with an AMD GPU though.
The tip about switching virtual terminals was given under the assumption of a running AMD GPU. Chances are low then, switching terminals will fix your problem.
Unfortunately I’m not very experienced in Linux and particularly with notebooks. The Arch Wiki doesn’t mention any obvious problems (apart from sound) with the device.
Not sure how to help any further than to try the (now released) kernel 6.16 instead of the release candidate. Maybe a search in the Arch Linux forum might turn up some helpful tips too. Like:
https://bbs.archlinux.org/viewtopic.php?pid=2248376#p2248376
EDIT
Just noticed you’re already posted it in this exact discussion in the ArchLinux forums. :sweat_smile: Sorry.
Yeah, I’m trying to shoot everywhere :sweat_smile:
Thank you anyway, I’ll try the latest 6.16 (non-RC) and keep this thread updated.
I’d take a shot at 6.17.0-rc1 too. :sweat_smile:
Good news. It seems to be fixed since 6.15.9-2. At least after upgrading to that version (and versions above), I didn’t get any complete freezing anymore.
I’ll wait a few weeks more until marking the issue as solved.
Yep. It seems fixed now. No more freezings for Zenbook S14.
And now the issue you face is that kernel 6.15 reached EOL several weeks ago – on August 20 – which means that updates are no longer provided from the official Manjaro repositories.
I’m using Kernel 6.16 and the problem was fixed there too at the same time it was fixed for 6.15
