Freezes when waking from suspend
I am experiencing random freezes (50% of the time) when waking from suspends.
When the system wakes up frozen, no logs can be found in journalctl.
Any help? Thx
The logs are as follows, in which the first wake from suspend worked, whereas the second attempt resulted in a freeze.
Mar 04 11:09:22 Jumbleline systemd-logind[1874]: The system will suspend now!
Mar 04 11:09:22 Jumbleline NetworkManager[1914]: <info>  [1677899362.2363] manager: sleep: sleep requested (sleeping: no  enabled: yes)
Mar 04 11:09:22 Jumbleline NetworkManager[1914]: <info>  [1677899362.4552] device (enp7s0): state change: unavailable -> unmanaged (reason 'sleeping', sys-iface-state: 'managed')
Mar 04 11:09:22 Jumbleline kernel: r8169 0000:07:00.0 enp7s0: Link is Down
Mar 04 11:09:22 Jumbleline NetworkManager[1914]: <info>  [1677899362.4631] device (p2p-dev-wlo1): state change: disconnected -> unmanaged (reason 'sleeping', sys-iface-state: 'managed')
Mar 04 11:09:22 Jumbleline NetworkManager[1914]: <info>  [1677899362.4639] manager: NetworkManager state is now ASLEEP
Mar 04 11:09:22 Jumbleline NetworkManager[1914]: <info>  [1677899362.4642] device (wlo1): state change: activated -> deactivating (reason 'sleeping', sys-iface-state: 'managed')
Mar 04 11:09:22 Jumbleline dbus-daemon[1871]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.6' (uid=0 pid=1914 comm="/usr/bin/NetworkManager --no-daemon")
Mar 04 11:09:22 Jumbleline systemd[1]: Starting Network Manager Script Dispatcher Service...
Mar 04 11:09:22 Jumbleline dbus-daemon[1871]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
Mar 04 11:09:22 Jumbleline systemd[1]: Started Network Manager Script Dispatcher Service.
Mar 04 11:09:22 Jumbleline audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 04 11:09:22 Jumbleline kernel: kauditd_printk_skb: 209 callbacks suppressed
Mar 04 11:09:22 Jumbleline kernel: audit: type=1130 audit(1677899362.523:150): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 04 11:09:22 Jumbleline kernel: wlo1: deauthenticating from 18:f2:2c:7a:00:d8 by local choice (Reason: 3=DEAUTH_LEAVING)
Mar 04 11:09:22 Jumbleline wpa_supplicant[2205]: wlo1: CTRL-EVENT-DISCONNECTED bssid=18:f2:2c:7a:00:d8 reason=3 locally_generated=1
Mar 04 11:09:22 Jumbleline wpa_supplicant[2205]: wlo1: CTRL-EVENT-DSCP-POLICY clear_all
Mar 04 11:09:22 Jumbleline NetworkManager[1914]: <info>  [1677899362.6396] device (wlo1): supplicant interface state: completed -> disconnected
Mar 04 11:09:22 Jumbleline NetworkManager[1914]: <info>  [1677899362.6399] device (wlo1): state change: deactivating -> disconnected (reason 'sleeping', sys-iface-state: 'managed')
Mar 04 11:09:22 Jumbleline avahi-daemon[1869]: Withdrawing address record for fdea:4309:f1b4:4928:7851:67d5:a97d:d02d on wlo1.
Mar 04 11:09:22 Jumbleline avahi-daemon[1869]: Leaving mDNS multicast group on interface wlo1.IPv6 with address fdea:4309:f1b4:4928:7851:67d5:a97d:d02d.
Mar 04 11:09:22 Jumbleline avahi-daemon[1869]: Joining mDNS multicast group on interface wlo1.IPv6 with address fe80::8063:7fca:7c44:6b62.
Mar 04 11:09:22 Jumbleline avahi-daemon[1869]: Registering new address record for fe80::8063:7fca:7c44:6b62 on wlo1.*.
Mar 04 11:09:22 Jumbleline avahi-daemon[1869]: Withdrawing address record for fe80::8063:7fca:7c44:6b62 on wlo1.
Mar 04 11:09:22 Jumbleline avahi-daemon[1869]: Leaving mDNS multicast group on interface wlo1.IPv6 with address fe80::8063:7fca:7c44:6b62.
Mar 04 11:09:22 Jumbleline avahi-daemon[1869]: Interface wlo1.IPv6 no longer relevant for mDNS.
Mar 04 11:09:22 Jumbleline NetworkManager[1914]: <info>  [1677899362.6684] dhcp4 (wlo1): canceled DHCP transaction
Mar 04 11:09:22 Jumbleline NetworkManager[1914]: <info>  [1677899362.6685] dhcp4 (wlo1): activation: beginning transaction (timeout in 45 seconds)
Mar 04 11:09:22 Jumbleline NetworkManager[1914]: <info>  [1677899362.6685] dhcp4 (wlo1): state changed no lease
Mar 04 11:09:22 Jumbleline avahi-daemon[1869]: Interface wlo1.IPv4 no longer relevant for mDNS.
Mar 04 11:09:22 Jumbleline avahi-daemon[1869]: Leaving mDNS multicast group on interface wlo1.IPv4 with address 192.168.1.194.
Mar 04 11:09:22 Jumbleline avahi-daemon[1869]: Withdrawing address record for 192.168.1.194 on wlo1.
Mar 04 11:09:22 Jumbleline NetworkManager[1914]: <info>  [1677899362.6941] device (wlo1): set-hw-addr: set MAC address to 62:C3:BC:6B:BD:C9 (scanning)
Mar 04 11:09:22 Jumbleline avahi-daemon[1869]: Joining mDNS multicast group on interface wlo1.IPv4 with address 192.168.1.194.
Mar 04 11:09:22 Jumbleline avahi-daemon[1869]: New relevant interface wlo1.IPv4 for mDNS.
Mar 04 11:09:22 Jumbleline avahi-daemon[1869]: Registering new address record for 192.168.1.194 on wlo1.IPv4.
Mar 04 11:09:22 Jumbleline NetworkManager[1914]: <info>  [1677899362.7310] device (wlo1): state change: disconnected -> unmanaged (reason 'sleeping', sys-iface-state: 'managed')
Mar 04 11:09:22 Jumbleline NetworkManager[1914]: <info>  [1677899362.8703] device (wlo1): set-hw-addr: reset MAC address to 8C:B8:7E:93:82:0D (unmanage)
Mar 04 11:09:22 Jumbleline wpa_supplicant[2205]: p2p-dev-wlo1: CTRL-EVENT-DSCP-POLICY clear_all
Mar 04 11:09:22 Jumbleline wpa_supplicant[2205]: nl80211: deinit ifname=p2p-dev-wlo1 disabled_11b_rates=0
Mar 04 11:09:23 Jumbleline wpa_supplicant[2205]: wlo1: CTRL-EVENT-DSCP-POLICY clear_all
Mar 04 11:09:23 Jumbleline wpa_supplicant[2205]: nl80211: deinit ifname=wlo1 disabled_11b_rates=0
Mar 04 11:09:23 Jumbleline systemd[1]: Reached target Sleep.
Mar 04 11:09:23 Jumbleline systemd[1]: Starting System Suspend...
Mar 04 11:09:23 Jumbleline snapd[1873]: daemon.go:521: gracefully waiting for running hooks
Mar 04 11:09:23 Jumbleline snapd[1873]: daemon.go:523: done waiting for running hooks
Mar 04 11:09:23 Jumbleline snapd[1873]: overlord.go:512: Released state lock file
Mar 04 11:09:23 Jumbleline snapd[1873]: daemon stop requested to wait for socket activation
Mar 04 11:09:23 Jumbleline systemd[1]: snapd.service: Deactivated successfully.
Mar 04 11:09:23 Jumbleline systemd-sleep[3367]: Entering sleep state 'suspend'...
Mar 04 11:09:23 Jumbleline kernel: PM: suspend entry (deep)
Mar 04 11:09:23 Jumbleline audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=snapd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 04 11:09:23 Jumbleline kernel: audit: type=1131 audit(1677899363.197:151): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=snapd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 04 11:09:23 Jumbleline kernel: Filesystems sync: 0.105 seconds
Mar 04 11:09:23 Jumbleline bluetoothd[1870]: profiles/audio/avdtp.c:avdtp_connect_cb() connect to 53:4A:52:FE:00:FA: Transport endpoint is not connected (107)
Mar 04 11:09:36 Jumbleline kernel: Freezing user space processes ... (elapsed 0.001 seconds) done.
Mar 04 11:09:36 Jumbleline kernel: OOM killer disabled.
Mar 04 11:09:36 Jumbleline kernel: Freezing remaining freezable tasks ... (elapsed 0.001 seconds) done.
Mar 04 11:09:36 Jumbleline kernel: printk: Suspending console(s) (use no_console_suspend to debug)
Mar 04 11:09:36 Jumbleline kernel: sd 8:0:0:0: [sda] Synchronizing SCSI cache
Mar 04 11:09:36 Jumbleline kernel: sd 8:0:0:0: [sda] Stopping disk
Mar 04 11:09:36 Jumbleline kernel: amdgpu 0000:03:00.0: amdgpu: free PSP TMR buffer
Mar 04 11:09:36 Jumbleline kernel: amdgpu 0000:03:00.0: amdgpu: MODE1 reset
Mar 04 11:09:36 Jumbleline kernel: amdgpu 0000:03:00.0: amdgpu: GPU mode1 reset
Mar 04 11:09:36 Jumbleline kernel: amdgpu 0000:03:00.0: amdgpu: GPU smu mode1 reset
Mar 04 11:09:36 Jumbleline kernel: ACPI: PM: Preparing to enter system sleep state S3
Mar 04 11:09:36 Jumbleline kernel: ACPI: PM: Saving platform NVS memory
Mar 04 11:09:36 Jumbleline kernel: Disabling non-boot CPUs ...
Mar 04 11:09:36 Jumbleline kernel: smpboot: CPU 1 is now offline
Mar 04 11:09:36 Jumbleline kernel: smpboot: CPU 2 is now offline
Mar 04 11:09:36 Jumbleline kernel: smpboot: CPU 3 is now offline
Mar 04 11:09:36 Jumbleline kernel: smpboot: CPU 4 is now offline
Mar 04 11:09:36 Jumbleline kernel: smpboot: CPU 5 is now offline
Mar 04 11:09:36 Jumbleline kernel: smpboot: CPU 6 is now offline
Mar 04 11:09:36 Jumbleline kernel: smpboot: CPU 7 is now offline
Mar 04 11:09:36 Jumbleline kernel: smpboot: CPU 8 is now offline
Mar 04 11:09:36 Jumbleline kernel: smpboot: CPU 9 is now offline
Mar 04 11:09:36 Jumbleline kernel: smpboot: CPU 10 is now offline
Mar 04 11:09:36 Jumbleline kernel: smpboot: CPU 11 is now offline
Mar 04 11:09:36 Jumbleline kernel: smpboot: CPU 12 is now offline
Mar 04 11:09:36 Jumbleline kernel: smpboot: CPU 13 is now offline
Mar 04 11:09:36 Jumbleline kernel: smpboot: CPU 14 is now offline
Mar 04 11:09:36 Jumbleline kernel: smpboot: CPU 15 is now offline
Mar 04 11:09:36 Jumbleline kernel: smpboot: CPU 16 is now offline
Mar 04 11:09:36 Jumbleline kernel: smpboot: CPU 17 is now offline
Mar 04 11:09:36 Jumbleline kernel: smpboot: CPU 18 is now offline
Mar 04 11:09:36 Jumbleline kernel: smpboot: CPU 19 is now offline
Mar 04 11:09:36 Jumbleline kernel: ACPI: PM: Low-level resume complete
Mar 04 11:09:36 Jumbleline kernel: ACPI: PM: Restoring platform NVS memory
Mar 04 11:09:36 Jumbleline kernel: Enabling non-boot CPUs ...
Mar 04 11:09:36 Jumbleline kernel: x86: Booting SMP configuration:
Mar 04 11:09:36 Jumbleline kernel: smpboot: Booting Node 0 Processor 1 APIC 0x1
Mar 04 11:09:36 Jumbleline kernel: CPU1 is up
Mar 04 11:09:36 Jumbleline kernel: smpboot: Booting Node 0 Processor 2 APIC 0x8
Mar 04 11:09:36 Jumbleline kernel: CPU2 is up
Mar 04 11:09:36 Jumbleline kernel: smpboot: Booting Node 0 Processor 3 APIC 0x9
Mar 04 11:09:36 Jumbleline kernel: CPU3 is up
Mar 04 11:09:36 Jumbleline kernel: smpboot: Booting Node 0 Processor 4 APIC 0x10
Mar 04 11:09:36 Jumbleline kernel: CPU4 is up
Mar 04 11:09:36 Jumbleline kernel: smpboot: Booting Node 0 Processor 5 APIC 0x11
Mar 04 11:09:36 Jumbleline kernel: CPU5 is up
Mar 04 11:09:36 Jumbleline kernel: smpboot: Booting Node 0 Processor 6 APIC 0x18
Mar 04 11:09:36 Jumbleline kernel: CPU6 is up
Mar 04 11:09:36 Jumbleline kernel: smpboot: Booting Node 0 Processor 7 APIC 0x19
Mar 04 11:09:36 Jumbleline kernel: CPU7 is up
Mar 04 11:09:36 Jumbleline kernel: smpboot: Booting Node 0 Processor 8 APIC 0x20
Mar 04 11:09:36 Jumbleline kernel: CPU8 is up
Mar 04 11:09:36 Jumbleline kernel: smpboot: Booting Node 0 Processor 9 APIC 0x21
Mar 04 11:09:36 Jumbleline kernel: CPU9 is up
Mar 04 11:09:36 Jumbleline kernel: smpboot: Booting Node 0 Processor 10 APIC 0x28
Mar 04 11:09:36 Jumbleline kernel: CPU10 is up
Mar 04 11:09:36 Jumbleline kernel: smpboot: Booting Node 0 Processor 11 APIC 0x29
Mar 04 11:09:36 Jumbleline kernel: CPU11 is up
Mar 04 11:09:36 Jumbleline kernel: smpboot: Booting Node 0 Processor 12 APIC 0x30
Mar 04 11:09:36 Jumbleline kernel: CPU12 is up
Mar 04 11:09:36 Jumbleline kernel: smpboot: Booting Node 0 Processor 13 APIC 0x31
Mar 04 11:09:36 Jumbleline kernel: CPU13 is up
Mar 04 11:09:36 Jumbleline kernel: smpboot: Booting Node 0 Processor 14 APIC 0x38
Mar 04 11:09:36 Jumbleline kernel: CPU14 is up
Mar 04 11:09:36 Jumbleline kernel: smpboot: Booting Node 0 Processor 15 APIC 0x39
Mar 04 11:09:36 Jumbleline kernel: CPU15 is up
Mar 04 11:09:36 Jumbleline kernel: smpboot: Booting Node 0 Processor 16 APIC 0x48
Mar 04 11:09:36 Jumbleline kernel: core: cpu_atom PMU driver: PEBS-via-PT
Mar 04 11:09:36 Jumbleline kernel: ... version:                5
Mar 04 11:09:36 Jumbleline kernel: ... bit width:              48
Mar 04 11:09:36 Jumbleline kernel: ... generic registers:      6
Mar 04 11:09:36 Jumbleline kernel: ... value mask:             0000ffffffffffff
Mar 04 11:09:36 Jumbleline kernel: ... max period:             00007fffffffffff
Mar 04 11:09:36 Jumbleline kernel: ... fixed-purpose events:   3
Mar 04 11:09:36 Jumbleline kernel: ... event mask:             000000070000003f
Mar 04 11:09:36 Jumbleline kernel: CPU16 is up
Mar 04 11:09:36 Jumbleline kernel: smpboot: Booting Node 0 Processor 17 APIC 0x4a
Mar 04 11:09:36 Jumbleline kernel: CPU17 is up
Mar 04 11:09:36 Jumbleline kernel: smpboot: Booting Node 0 Processor 18 APIC 0x4c
Mar 04 11:09:36 Jumbleline kernel: CPU18 is up
Mar 04 11:09:36 Jumbleline kernel: smpboot: Booting Node 0 Processor 19 APIC 0x4e
Mar 04 11:09:36 Jumbleline kernel: CPU19 is up
Mar 04 11:09:36 Jumbleline kernel: ACPI: PM: Waking up from system sleep state S3
Mar 04 11:09:36 Jumbleline kernel: sd 8:0:0:0: [sda] Starting disk
Mar 04 11:09:36 Jumbleline kernel: [drm] PCIE GART of 512M enabled (table at 0x0000008000300000).
Mar 04 11:09:36 Jumbleline kernel: [drm] PSP is resuming...
Mar 04 11:09:36 Jumbleline kernel: i915 0000:00:02.0: [drm] GuC firmware i915/tgl_guc_70.bin version 70.5.1
Mar 04 11:09:36 Jumbleline kernel: i915 0000:00:02.0: [drm] HuC firmware i915/tgl_huc.bin version 7.9.3
Mar 04 11:09:36 Jumbleline kernel: nvme nvme0: 8/0/0 default/read/poll queues
Mar 04 11:09:36 Jumbleline kernel: nvme nvme1: 16/0/0 default/read/poll queues
Mar 04 11:09:36 Jumbleline kernel: nvme nvme0: Ignoring bogus Namespace Identifiers
Mar 04 11:09:36 Jumbleline kernel: i915 0000:00:02.0: [drm] HuC authenticated
Mar 04 11:09:36 Jumbleline kernel: i915 0000:00:02.0: [drm] GuC submission disabled
Mar 04 11:09:36 Jumbleline kernel: i915 0000:00:02.0: [drm] GuC SLPC disabled
Mar 04 11:09:36 Jumbleline kernel: [drm] reserve 0xa00000 from 0x83fd000000 for PSP TMR
Mar 04 11:09:36 Jumbleline kernel: amdgpu 0000:03:00.0: amdgpu: SECUREDISPLAY: securedisplay ta ucode is not available
Mar 04 11:09:36 Jumbleline kernel: amdgpu 0000:03:00.0: amdgpu: SMU is resuming...
Mar 04 11:09:36 Jumbleline kernel: amdgpu 0000:03:00.0: amdgpu: smu driver if version = 0x00000040, smu fw if version = 0x00000041, smu fw program = 0, version = 0x003a5600 (58.86.0)
Mar 04 11:09:36 Jumbleline kernel: amdgpu 0000:03:00.0: amdgpu: SMU driver if version not matched
Mar 04 11:09:36 Jumbleline kernel: amdgpu 0000:03:00.0: amdgpu: use vbios provided pptable
Mar 04 11:09:36 Jumbleline kernel: amdgpu 0000:03:00.0: amdgpu: SMU is resumed successfully!
Mar 04 11:09:36 Jumbleline kernel: [drm] DMUB hardware initialized: version=0x02020017
Mar 04 11:09:36 Jumbleline kernel: ata10: SATA link down (SStatus 0 SControl 300)
Mar 04 11:09:36 Jumbleline kernel: ata5: SATA link down (SStatus 4 SControl 300)
Mar 04 11:09:36 Jumbleline kernel: ata6: SATA link down (SStatus 4 SControl 300)
Mar 04 11:09:36 Jumbleline kernel: ata7: SATA link down (SStatus 4 SControl 300)
Mar 04 11:09:36 Jumbleline kernel: ata8: SATA link down (SStatus 4 SControl 300)
Mar 04 11:09:36 Jumbleline kernel: ata9: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
Mar 04 11:09:36 Jumbleline kernel: [drm] kiq ring mec 2 pipe 1 q 0
Mar 04 11:09:36 Jumbleline kernel: [drm] VCN decode and encode initialized successfully(under DPG Mode).
Mar 04 11:09:36 Jumbleline kernel: [drm] JPEG decode initialized successfully.
Mar 04 11:09:36 Jumbleline kernel: amdgpu 0000:03:00.0: amdgpu: ring gfx_0.0.0 uses VM inv eng 0 on hub 0
Mar 04 11:09:36 Jumbleline kernel: amdgpu 0000:03:00.0: amdgpu: ring comp_1.0.0 uses VM inv eng 1 on hub 0
Mar 04 11:09:36 Jumbleline kernel: amdgpu 0000:03:00.0: amdgpu: ring comp_1.1.0 uses VM inv eng 4 on hub 0
Mar 04 11:09:36 Jumbleline kernel: amdgpu 0000:03:00.0: amdgpu: ring comp_1.2.0 uses VM inv eng 5 on hub 0
Mar 04 11:09:36 Jumbleline kernel: amdgpu 0000:03:00.0: amdgpu: ring comp_1.3.0 uses VM inv eng 6 on hub 0
Mar 04 11:09:36 Jumbleline kernel: amdgpu 0000:03:00.0: amdgpu: ring comp_1.0.1 uses VM inv eng 7 on hub 0
Mar 04 11:09:36 Jumbleline kernel: amdgpu 0000:03:00.0: amdgpu: ring comp_1.1.1 uses VM inv eng 8 on hub 0
Mar 04 11:09:36 Jumbleline kernel: amdgpu 0000:03:00.0: amdgpu: ring comp_1.2.1 uses VM inv eng 9 on hub 0
Mar 04 11:09:36 Jumbleline kernel: amdgpu 0000:03:00.0: amdgpu: ring comp_1.3.1 uses VM inv eng 10 on hub 0
Mar 04 11:09:36 Jumbleline kernel: amdgpu 0000:03:00.0: amdgpu: ring kiq_2.1.0 uses VM inv eng 11 on hub 0
Mar 04 11:09:36 Jumbleline kernel: amdgpu 0000:03:00.0: amdgpu: ring sdma0 uses VM inv eng 12 on hub 0
Mar 04 11:09:36 Jumbleline kernel: amdgpu 0000:03:00.0: amdgpu: ring sdma1 uses VM inv eng 13 on hub 0
Mar 04 11:09:36 Jumbleline kernel: amdgpu 0000:03:00.0: amdgpu: ring sdma2 uses VM inv eng 14 on hub 0
Mar 04 11:09:36 Jumbleline kernel: amdgpu 0000:03:00.0: amdgpu: ring sdma3 uses VM inv eng 15 on hub 0
Mar 04 11:09:36 Jumbleline kernel: amdgpu 0000:03:00.0: amdgpu: ring vcn_dec_0 uses VM inv eng 0 on hub 1
Mar 04 11:09:36 Jumbleline kernel: amdgpu 0000:03:00.0: amdgpu: ring vcn_enc_0.0 uses VM inv eng 1 on hub 1
Mar 04 11:09:36 Jumbleline kernel: amdgpu 0000:03:00.0: amdgpu: ring vcn_enc_0.1 uses VM inv eng 4 on hub 1
Mar 04 11:09:36 Jumbleline kernel: amdgpu 0000:03:00.0: amdgpu: ring vcn_dec_1 uses VM inv eng 5 on hub 1
Mar 04 11:09:36 Jumbleline kernel: amdgpu 0000:03:00.0: amdgpu: ring vcn_enc_1.0 uses VM inv eng 6 on hub 1
Mar 04 11:09:36 Jumbleline kernel: amdgpu 0000:03:00.0: amdgpu: ring vcn_enc_1.1 uses VM inv eng 7 on hub 1
Mar 04 11:09:36 Jumbleline kernel: amdgpu 0000:03:00.0: amdgpu: ring jpeg_dec uses VM inv eng 8 on hub 1
Mar 04 11:09:36 Jumbleline kernel: ata9.00: configured for UDMA/133
Mar 04 11:09:36 Jumbleline kernel: usb 3-2: reset full-speed USB device number 2 using xhci_hcd
Mar 04 11:09:36 Jumbleline kernel: OOM killer enabled.
Mar 04 11:09:36 Jumbleline kernel: Restarting tasks ... done.
Mar 04 11:09:36 Jumbleline kernel: random: crng reseeded on system resumption
Mar 04 11:09:36 Jumbleline kernel: mei_hdcp 0000:00:16.0-b638ab7e-94e2-4ea2-a552-d1c54b627f04: bound 0000:00:02.0 (ops i915_hdcp_component_ops [i915])
Mar 04 11:09:36 Jumbleline kernel: mei_pxp 0000:00:16.0-fbf6fcf1-96cf-4e2e-a6a6-1bab8cbe36b1: bound 0000:00:02.0 (ops i915_pxp_tee_component_ops [i915])
Mar 04 11:09:36 Jumbleline kernel: PM: suspend exit
Mar 04 11:09:36 Jumbleline systemd[1]: Stopping User Manager for UID 966...
Mar 04 11:09:36 Jumbleline bluetoothd[1870]: Controller resume with wake event 0x0
Mar 04 11:09:36 Jumbleline systemd-sleep[3367]: System returned from sleep state.
Mar 04 11:09:36 Jumbleline systemd[2143]: Activating special unit Exit the Session...
Mar 04 11:09:36 Jumbleline systemd[2143]: Stopped target Main User Target.
Mar 04 11:09:36 Jumbleline systemd[2143]: Stopped target Basic System.
Mar 04 11:09:36 Jumbleline systemd[2143]: Stopped target Paths.
Mar 04 11:09:36 Jumbleline systemd[2143]: Stopped target Sockets.
Mar 04 11:09:36 Jumbleline systemd[2143]: Stopped target Timers.
Mar 04 11:09:36 Jumbleline systemd[2143]: Closed D-Bus User Message Bus Socket.
Mar 04 11:09:36 Jumbleline systemd[2143]: Closed GnuPG network certificate management daemon.
Mar 04 11:09:36 Jumbleline systemd[2143]: Closed GCR ssh-agent wrapper.
Mar 04 11:09:36 Jumbleline systemd[2143]: Closed GNOME Keyring daemon.
Mar 04 11:09:36 Jumbleline systemd[2143]: Closed GnuPG cryptographic agent and passphrase cache (access for web browsers).
Mar 04 11:09:36 Jumbleline systemd[2143]: Closed GnuPG cryptographic agent and passphrase cache (restricted).
Mar 04 11:09:36 Jumbleline systemd[2143]: Closed GnuPG cryptographic agent (ssh-agent emulation).
Mar 04 11:09:36 Jumbleline systemd[2143]: Closed GnuPG cryptographic agent and passphrase cache.
Mar 04 11:09:36 Jumbleline systemd[2143]: Closed p11-kit server.
Mar 04 11:09:36 Jumbleline systemd[2143]: Closed PipeWire PulseAudio.
Mar 04 11:09:36 Jumbleline systemd[2143]: Closed PipeWire Multimedia System Socket.
Mar 04 11:09:36 Jumbleline systemd[2143]: Removed slice User Application Slice.
Mar 04 11:09:36 Jumbleline systemd[2143]: Reached target Shutdown.
Mar 04 11:09:36 Jumbleline systemd[2143]: Finished Exit the Session.
Mar 04 11:09:36 Jumbleline systemd[2143]: Reached target Exit the Session.
Mar 04 11:09:36 Jumbleline systemd[2144]: pam_warn(systemd-user:setcred): function=[pam_sm_setcred] flags=0x8004 service=[systemd-user] terminal=[] user=[greeter] ruser=[<unknown>] rhost=[<unknown>]
Mar 04 11:09:36 Jumbleline systemd[1]: user@966.service: Deactivated successfully.
Mar 04 11:09:36 Jumbleline systemd[1]: Stopped User Manager for UID 966.
Mar 04 11:09:36 Jumbleline audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=user@966 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 04 11:09:36 Jumbleline kernel: audit: type=1131 audit(1677899376.258:152): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=user@966 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 04 11:09:36 Jumbleline systemd[1]: Stopping User Runtime Directory /run/user/966...
Mar 04 11:09:36 Jumbleline systemd[1]: run-user-966.mount: Deactivated successfully.
Mar 04 11:09:36 Jumbleline systemd[1]: user-runtime-dir@966.service: Deactivated successfully.
Mar 04 11:09:36 Jumbleline systemd[1]: Stopped User Runtime Directory /run/user/966.
Mar 04 11:09:36 Jumbleline audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=user-runtime-dir@966 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 04 11:09:36 Jumbleline kernel: audit: type=1131 audit(1677899376.408:153): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=user-runtime-dir@966 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 04 11:09:36 Jumbleline systemd[1]: Removed slice User Slice of UID 966.
Mar 04 11:09:36 Jumbleline systemd[1]: systemd-suspend.service: Deactivated successfully.
Mar 04 11:09:36 Jumbleline systemd[1]: Finished System Suspend.
Mar 04 11:09:36 Jumbleline audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=systemd-suspend comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 04 11:09:36 Jumbleline audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=systemd-suspend comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 04 11:09:36 Jumbleline systemd[1]: Stopped target Sleep.
Mar 04 11:09:36 Jumbleline systemd[1]: Reached target Suspend.
Mar 04 11:09:36 Jumbleline systemd[1]: Stopped target Suspend.
Mar 04 11:09:36 Jumbleline systemd-logind[1874]: Operation 'sleep' finished.
Mar 04 11:09:36 Jumbleline kernel: audit: type=1130 audit(1677899376.718:154): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=systemd-suspend comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 04 11:09:36 Jumbleline kernel: audit: type=1131 audit(1677899376.718:155): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=systemd-suspend comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 04 11:09:36 Jumbleline NetworkManager[1914]: <info>  [1677899376.7236] manager: sleep: wake requested (sleeping: yes  enabled: yes)
Mar 04 11:09:36 Jumbleline NetworkManager[1914]: <info>  [1677899376.7240] device (enp7s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Mar 04 11:09:36 Jumbleline kernel: RTL8226B_RTL8221B 2.5Gbps PHY r8169-0-700:00: attached PHY driver (mii_bus:phy_addr=r8169-0-700:00, irq=MAC)
Mar 04 11:09:36 Jumbleline NetworkManager[1914]: <info>  [1677899376.9428] device (wlo1): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Mar 04 11:09:36 Jumbleline NetworkManager[1914]: <info>  [1677899376.9440] device (p2p-dev-wlo1): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Mar 04 11:09:36 Jumbleline NetworkManager[1914]: <info>  [1677899376.9445] manager: NetworkManager state is now CONNECTED_LOCAL
Mar 04 11:09:36 Jumbleline kernel: r8169 0000:07:00.0 enp7s0: Link is Down
Mar 04 11:09:36 Jumbleline NetworkManager[1914]: <info>  [1677899376.9911] device (wlo1): supplicant interface state: internal-starting -> disconnected
Mar 04 11:09:36 Jumbleline NetworkManager[1914]: <info>  [1677899376.9912] device (p2p-dev-wlo1): state change: unavailable -> unmanaged (reason 'removed', sys-iface-state: 'removed')
Mar 04 11:09:36 Jumbleline NetworkManager[1914]: <info>  [1677899376.9922] Wi-Fi P2P device controlled by interface wlo1 created
Mar 04 11:09:36 Jumbleline NetworkManager[1914]: <info>  [1677899376.9928] manager: (p2p-dev-wlo1): new 802.11 Wi-Fi P2P device (/org/freedesktop/NetworkManager/Devices/8)
Mar 04 11:09:36 Jumbleline NetworkManager[1914]: <info>  [1677899376.9932] device (p2p-dev-wlo1): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Mar 04 11:09:36 Jumbleline NetworkManager[1914]: <info>  [1677899376.9940] device (wlo1): state change: unavailable -> disconnected (reason 'supplicant-available', sys-iface-state: 'managed')
Mar 04 11:09:36 Jumbleline NetworkManager[1914]: <info>  [1677899376.9947] device (p2p-dev-wlo1): state change: unavailable -> disconnected (reason 'none', sys-iface-state: 'managed')
Mar 04 11:09:40 Jumbleline wpa_supplicant[2205]: wlo1: CTRL-EVENT-REGDOM-CHANGE init=DRIVER type=COUNTRY alpha2=CN
Mar 04 11:09:40 Jumbleline NetworkManager[1914]: <info>  [1677899380.2443] policy: auto-activating connection 'K2P_Eagle' (fe69d8c5-0f37-4a5f-8720-5bbe9d8b5d9e)
Mar 04 11:09:40 Jumbleline NetworkManager[1914]: <info>  [1677899380.2444] device (wlo1): Activation: starting connection 'K2P_Eagle' (fe69d8c5-0f37-4a5f-8720-5bbe9d8b5d9e)
Mar 04 11:09:40 Jumbleline NetworkManager[1914]: <info>  [1677899380.2444] device (wlo1): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
Mar 04 11:09:40 Jumbleline NetworkManager[1914]: <info>  [1677899380.2445] manager: NetworkManager state is now CONNECTING
Mar 04 11:09:40 Jumbleline NetworkManager[1914]: <info>  [1677899380.2446] device (wlo1): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Mar 04 11:09:40 Jumbleline NetworkManager[1914]: <info>  [1677899380.2447] device (wlo1): Activation: (wifi) access point 'K2P_Eagle' has security, but secrets are required.
Mar 04 11:09:40 Jumbleline NetworkManager[1914]: <info>  [1677899380.2447] device (wlo1): state change: config -> need-auth (reason 'none', sys-iface-state: 'managed')
Mar 04 11:09:40 Jumbleline NetworkManager[1914]: <info>  [1677899380.2450] device (wlo1): state change: need-auth -> prepare (reason 'none', sys-iface-state: 'managed')
Mar 04 11:09:40 Jumbleline NetworkManager[1914]: <info>  [1677899380.2451] device (wlo1): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Mar 04 11:09:40 Jumbleline NetworkManager[1914]: <info>  [1677899380.2452] device (wlo1): Activation: (wifi) connection 'K2P_Eagle' has security, and secrets exist.  No new secrets needed.
Mar 04 11:09:40 Jumbleline NetworkManager[1914]: <info>  [1677899380.2452] Config: added 'ssid' value 'K2P_Eagle'
Mar 04 11:09:40 Jumbleline NetworkManager[1914]: <info>  [1677899380.2452] Config: added 'scan_ssid' value '1'
Mar 04 11:09:40 Jumbleline NetworkManager[1914]: <info>  [1677899380.2452] Config: added 'bgscan' value 'simple:30:-70:86400'
Mar 04 11:09:40 Jumbleline NetworkManager[1914]: <info>  [1677899380.2452] Config: added 'key_mgmt' value 'WPA-PSK WPA-PSK-SHA256 FT-PSK SAE FT-SAE'
Mar 04 11:09:40 Jumbleline NetworkManager[1914]: <info>  [1677899380.2452] Config: added 'auth_alg' value 'OPEN'
Mar 04 11:09:40 Jumbleline NetworkManager[1914]: <info>  [1677899380.2452] Config: added 'psk' value '<hidden>'
Mar 04 11:09:40 Jumbleline wpa_supplicant[2205]: wlo1: SME: Trying to authenticate with 18:f2:2c:7a:00:d8 (SSID='K2P_Eagle' freq=5180 MHz)
Mar 04 11:09:40 Jumbleline kernel: wlo1: authenticate with 18:f2:2c:7a:00:d8
Mar 04 11:09:40 Jumbleline NetworkManager[1914]: <info>  [1677899380.2646] device (wlo1): supplicant interface state: disconnected -> authenticating
Mar 04 11:09:40 Jumbleline kernel: wlo1: send auth to 18:f2:2c:7a:00:d8 (try 1/3)
Mar 04 11:09:40 Jumbleline NetworkManager[1914]: <info>  [1677899380.2647] device (p2p-dev-wlo1): supplicant management interface state: disconnected -> authenticating
Mar 04 11:09:40 Jumbleline kernel: wlo1: authenticated
Mar 04 11:09:40 Jumbleline wpa_supplicant[2205]: wlo1: Trying to associate with 18:f2:2c:7a:00:d8 (SSID='K2P_Eagle' freq=5180 MHz)
Mar 04 11:09:40 Jumbleline NetworkManager[1914]: <info>  [1677899380.2995] device (wlo1): supplicant interface state: authenticating -> associating
Mar 04 11:09:40 Jumbleline NetworkManager[1914]: <info>  [1677899380.2995] device (p2p-dev-wlo1): supplicant management interface state: authenticating -> associating
Mar 04 11:09:40 Jumbleline kernel: wlo1: associate with 18:f2:2c:7a:00:d8 (try 1/3)
Mar 04 11:09:40 Jumbleline kernel: wlo1: RX AssocResp from 18:f2:2c:7a:00:d8 (capab=0x1511 status=0 aid=1)
Mar 04 11:09:40 Jumbleline kernel: wlo1: associated
Mar 04 11:09:40 Jumbleline kernel: wlo1: Limiting TX power to 35 (35 - 0) dBm as advertised by 18:f2:2c:7a:00:d8
Mar 04 11:09:40 Jumbleline wpa_supplicant[2205]: wlo1: Associated with 18:f2:2c:7a:00:d8
Mar 04 11:09:40 Jumbleline wpa_supplicant[2205]: wlo1: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
Mar 04 11:09:40 Jumbleline wpa_supplicant[2205]: wlo1: WPA: Key negotiation completed with 18:f2:2c:7a:00:d8 [PTK=CCMP GTK=CCMP]
Mar 04 11:09:40 Jumbleline wpa_supplicant[2205]: wlo1: CTRL-EVENT-CONNECTED - Connection to 18:f2:2c:7a:00:d8 completed [id=0 id_str=]
Mar 04 11:09:40 Jumbleline kernel: IPv6: ADDRCONF(NETDEV_CHANGE): wlo1: link becomes ready
Mar 04 11:09:40 Jumbleline wpa_supplicant[2205]: wlo1: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-52 noise=9999 txrate=490000
Mar 04 11:09:40 Jumbleline NetworkManager[1914]: <info>  [1677899380.3760] device (wlo1): supplicant interface state: associating -> completed
Mar 04 11:09:40 Jumbleline NetworkManager[1914]: <info>  [1677899380.3761] device (wlo1): Activation: (wifi) Stage 2 of 5 (Device Configure) successful. Connected to wireless network "K2P_Eagle"
Mar 04 11:09:40 Jumbleline NetworkManager[1914]: <info>  [1677899380.3761] device (p2p-dev-wlo1): supplicant management interface state: associating -> completed
Mar 04 11:09:40 Jumbleline NetworkManager[1914]: <info>  [1677899380.3764] device (wlo1): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed')
Mar 04 11:09:40 Jumbleline NetworkManager[1914]: <info>  [1677899380.3774] dhcp4 (wlo1): activation: beginning transaction (timeout in 45 seconds)
Mar 04 11:09:40 Jumbleline avahi-daemon[1869]: Joining mDNS multicast group on interface wlo1.IPv6 with address fe80::8063:7fca:7c44:6b62.
Mar 04 11:09:40 Jumbleline avahi-daemon[1869]: New relevant interface wlo1.IPv6 for mDNS.
Mar 04 11:09:40 Jumbleline avahi-daemon[1869]: Registering new address record for fe80::8063:7fca:7c44:6b62 on wlo1.*.
Mar 04 11:09:40 Jumbleline NetworkManager[1914]: <info>  [1677899380.4240] dhcp4 (wlo1): state changed new lease, address=192.168.1.194
Mar 04 11:09:40 Jumbleline NetworkManager[1914]: <info>  [1677899380.4246] policy: set 'K2P_Eagle' (wlo1) as default for IPv4 routing and DNS
Mar 04 11:09:40 Jumbleline avahi-daemon[1869]: Joining mDNS multicast group on interface wlo1.IPv4 with address 192.168.1.194.
Mar 04 11:09:40 Jumbleline avahi-daemon[1869]: New relevant interface wlo1.IPv4 for mDNS.
Mar 04 11:09:40 Jumbleline avahi-daemon[1869]: Registering new address record for 192.168.1.194 on wlo1.IPv4.
Mar 04 11:09:40 Jumbleline NetworkManager[1914]: <info>  [1677899380.4338] device (wlo1): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'managed')
Mar 04 11:09:40 Jumbleline NetworkManager[1914]: <info>  [1677899380.4366] device (wlo1): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'managed')
Mar 04 11:09:40 Jumbleline NetworkManager[1914]: <info>  [1677899380.4368] device (wlo1): state change: secondaries -> activated (reason 'none', sys-iface-state: 'managed')
Mar 04 11:09:40 Jumbleline NetworkManager[1914]: <info>  [1677899380.4373] manager: NetworkManager state is now CONNECTED_SITE
Mar 04 11:09:40 Jumbleline NetworkManager[1914]: <info>  [1677899380.4383] device (wlo1): Activation: successful, device activated.
Mar 04 11:09:41 Jumbleline NetworkManager[1914]: <info>  [1677899381.0177] manager: NetworkManager state is now CONNECTED_GLOBAL
Mar 04 11:09:41 Jumbleline bluetoothd[1870]: profiles/audio/avdtp.c:avdtp_connect_cb() connect to 53:4A:52:FE:00:FA: Host is down (112)
Mar 04 11:09:41 Jumbleline avahi-daemon[1869]: Leaving mDNS multicast group on interface wlo1.IPv6 with address fe80::8063:7fca:7c44:6b62.
Mar 04 11:09:41 Jumbleline avahi-daemon[1869]: Joining mDNS multicast group on interface wlo1.IPv6 with address fdea:4309:f1b4:4928:7851:67d5:a97d:d02d.
Mar 04 11:09:41 Jumbleline avahi-daemon[1869]: Registering new address record for fdea:4309:f1b4:4928:7851:67d5:a97d:d02d on wlo1.*.
Mar 04 11:09:41 Jumbleline avahi-daemon[1869]: Withdrawing address record for fe80::8063:7fca:7c44:6b62 on wlo1.
Mar 04 11:09:42 Jumbleline systemd[1]: NetworkManager-dispatcher.service: Deactivated successfully.
Mar 04 11:09:42 Jumbleline audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 04 11:09:42 Jumbleline kernel: audit: type=1131 audit(1677899382.551:156): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 04 11:09:44 Jumbleline dbus-daemon[1871]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.52' (uid=1000 pid=3341 comm="swaylock --daemonize --color #282a2b --inside-colo")
Mar 04 11:09:44 Jumbleline dbus-daemon[1871]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.home1.service': Unit dbus-org.freedesktop.home1.service not found.
Mar 04 11:09:44 Jumbleline swaylock[3341]: pam_systemd_home(swaylock:auth): systemd-homed is not available: Unit dbus-org.freedesktop.home1.service not found.
Mar 04 11:09:44 Jumbleline audit[3785]: USER_AUTH pid=3785 uid=1000 auid=1000 ses=3 subj=unconfined msg='op=PAM:unix_chkpwd acct="dotin13" exe="/usr/bin/unix_chkpwd" hostname=? addr=? terminal=? res=success'
Mar 04 11:09:44 Jumbleline swaylock[3341]: gkr-pam: unlocked login keyring
Mar 04 11:09:44 Jumbleline kernel: audit: type=1100 audit(1677899384.058:157): pid=3785 uid=1000 auid=1000 ses=3 subj=unconfined msg='op=PAM:unix_chkpwd acct="dotin13" exe="/usr/bin/unix_chkpwd" hostname=? addr=? terminal=? res=success'
Mar 04 11:09:51 Jumbleline dbus-daemon[1871]: [system] Activating via systemd: service name='org.freedesktop.UPower' unit='upower.service' requested by ':1.55' (uid=1000 pid=3814 comm="/opt/google/chrome-unstable/chrome")
Mar 04 11:09:51 Jumbleline audit: BPF prog-id=44 op=LOAD
Mar 04 11:09:51 Jumbleline audit: BPF prog-id=45 op=LOAD
Mar 04 11:09:51 Jumbleline kernel: audit: type=1334 audit(1677899391.838:158): prog-id=44 op=LOAD
Mar 04 11:09:51 Jumbleline kernel: audit: type=1334 audit(1677899391.838:159): prog-id=45 op=LOAD
Mar 04 11:09:51 Jumbleline xray[2033]: 2023/03/04 11:09:51 127.0.0.1:60352 accepted //accounts.google.com:443
Mar 04 11:09:51 Jumbleline xray[2033]: 2023/03/04 11:09:51 127.0.0.1:60340 accepted //www.googleapis.com:443
Mar 04 11:09:51 Jumbleline systemd[1]: Starting Daemon for power management...
Mar 04 11:09:51 Jumbleline dbus-daemon[1871]: [system] Successfully activated service 'org.freedesktop.UPower'
Mar 04 11:09:51 Jumbleline systemd[1]: Started Daemon for power management.
Mar 04 11:09:51 Jumbleline audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=upower comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 04 11:09:51 Jumbleline kernel: audit: type=1130 audit(1677899391.934:160): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=upower comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 04 11:09:52 Jumbleline xray[2033]: 2023/03/04 11:09:52 127.0.0.1:60364 accepted //www.google.com:443
Mar 04 11:09:52 Jumbleline xray[2033]: 2023/03/04 11:09:52 127.0.0.1:60374 accepted //raw.githubusercontent.com:443
Mar 04 11:09:52 Jumbleline xray[2033]: 2023/03/04 11:09:52 127.0.0.1:60378 accepted //www.google.com:443
Mar 04 11:09:52 Jumbleline xray[2033]: 2023/03/04 11:09:52 127.0.0.1:60384 accepted //www.google.com:443
Mar 04 11:09:52 Jumbleline xray[2033]: 2023/03/04 11:09:52 127.0.0.1:60388 accepted //www.google.com:443
Mar 04 11:09:52 Jumbleline xray[2033]: 2023/03/04 11:09:52 127.0.0.1:60404 accepted //clients4.google.com:443
Mar 04 11:09:52 Jumbleline xray[2033]: 2023/03/04 11:09:52 127.0.0.1:60418 accepted //history.google.com:443
Mar 04 11:09:54 Jumbleline kernel: sd 8:0:0:0: [sda] Synchronizing SCSI cache
Mar 04 11:09:54 Jumbleline kernel: sd 8:0:0:0: [sda] Stopping disk
Mar 04 11:09:55 Jumbleline appimagelauncherd[2313]: Directories to watch disappeared, unintegrating AppImages formerly found in there
Mar 04 11:09:57 Jumbleline systemd-logind[1874]: The system will suspend now!
Mar 04 11:09:57 Jumbleline NetworkManager[1914]: <info>  [1677899397.7387] manager: sleep: sleep requested (sleeping: no  enabled: yes)
Mar 04 11:09:57 Jumbleline NetworkManager[1914]: <info>  [1677899397.9518] device (enp7s0): state change: unavailable -> unmanaged (reason 'sleeping', sys-iface-state: 'managed')
Mar 04 11:09:57 Jumbleline kernel: r8169 0000:07:00.0 enp7s0: Link is Down
Mar 04 11:09:57 Jumbleline NetworkManager[1914]: <info>  [1677899397.9605] device (p2p-dev-wlo1): state change: disconnected -> unmanaged (reason 'sleeping', sys-iface-state: 'managed')
Mar 04 11:09:57 Jumbleline NetworkManager[1914]: <info>  [1677899397.9608] manager: NetworkManager state is now ASLEEP
Mar 04 11:09:57 Jumbleline NetworkManager[1914]: <info>  [1677899397.9614] device (wlo1): state change: activated -> deactivating (reason 'sleeping', sys-iface-state: 'managed')
Mar 04 11:09:57 Jumbleline dbus-daemon[1871]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.6' (uid=0 pid=1914 comm="/usr/bin/NetworkManager --no-daemon")
Mar 04 11:09:58 Jumbleline systemd[1]: Starting Network Manager Script Dispatcher Service...
Mar 04 11:09:58 Jumbleline dbus-daemon[1871]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
Mar 04 11:09:58 Jumbleline systemd[1]: Started Network Manager Script Dispatcher Service.
Mar 04 11:09:58 Jumbleline audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 04 11:09:58 Jumbleline kernel: audit: type=1130 audit(1677899398.011:161): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 04 11:09:58 Jumbleline kernel: wlo1: deauthenticating from 18:f2:2c:7a:00:d8 by local choice (Reason: 3=DEAUTH_LEAVING)
Mar 04 11:09:58 Jumbleline wpa_supplicant[2205]: wlo1: CTRL-EVENT-DISCONNECTED bssid=18:f2:2c:7a:00:d8 reason=3 locally_generated=1
Mar 04 11:09:58 Jumbleline wpa_supplicant[2205]: wlo1: CTRL-EVENT-DSCP-POLICY clear_all
Mar 04 11:09:58 Jumbleline NetworkManager[1914]: <info>  [1677899398.0963] device (wlo1): supplicant interface state: completed -> disconnected
Mar 04 11:09:58 Jumbleline NetworkManager[1914]: <info>  [1677899398.0966] device (wlo1): state change: deactivating -> disconnected (reason 'sleeping', sys-iface-state: 'managed')
Mar 04 11:09:58 Jumbleline avahi-daemon[1869]: Withdrawing address record for fdea:4309:f1b4:4928:7851:67d5:a97d:d02d on wlo1.
Mar 04 11:09:58 Jumbleline avahi-daemon[1869]: Leaving mDNS multicast group on interface wlo1.IPv6 with address fdea:4309:f1b4:4928:7851:67d5:a97d:d02d.
Mar 04 11:09:58 Jumbleline avahi-daemon[1869]: Joining mDNS multicast group on interface wlo1.IPv6 with address fe80::8063:7fca:7c44:6b62.
Mar 04 11:09:58 Jumbleline avahi-daemon[1869]: Registering new address record for fe80::8063:7fca:7c44:6b62 on wlo1.*.
Mar 04 11:09:58 Jumbleline avahi-daemon[1869]: Withdrawing address record for fe80::8063:7fca:7c44:6b62 on wlo1.
Mar 04 11:09:58 Jumbleline avahi-daemon[1869]: Leaving mDNS multicast group on interface wlo1.IPv6 with address fe80::8063:7fca:7c44:6b62.
Mar 04 11:09:58 Jumbleline avahi-daemon[1869]: Interface wlo1.IPv6 no longer relevant for mDNS.
Mar 04 11:09:58 Jumbleline NetworkManager[1914]: <info>  [1677899398.1251] dhcp4 (wlo1): canceled DHCP transaction
Mar 04 11:09:58 Jumbleline NetworkManager[1914]: <info>  [1677899398.1251] dhcp4 (wlo1): activation: beginning transaction (timeout in 45 seconds)
Mar 04 11:09:58 Jumbleline NetworkManager[1914]: <info>  [1677899398.1251] dhcp4 (wlo1): state changed no lease
Mar 04 11:09:58 Jumbleline avahi-daemon[1869]: Interface wlo1.IPv4 no longer relevant for mDNS.
Mar 04 11:09:58 Jumbleline avahi-daemon[1869]: Leaving mDNS multicast group on interface wlo1.IPv4 with address 192.168.1.194.
Mar 04 11:09:58 Jumbleline avahi-daemon[1869]: Withdrawing address record for 192.168.1.194 on wlo1.
Mar 04 11:09:58 Jumbleline NetworkManager[1914]: <info>  [1677899398.1577] device (wlo1): set-hw-addr: set MAC address to 3E:A4:76:B8:43:AF (scanning)
Mar 04 11:09:58 Jumbleline avahi-daemon[1869]: Joining mDNS multicast group on interface wlo1.IPv4 with address 192.168.1.194.
Mar 04 11:09:58 Jumbleline avahi-daemon[1869]: New relevant interface wlo1.IPv4 for mDNS.
Mar 04 11:09:58 Jumbleline avahi-daemon[1869]: Registering new address record for 192.168.1.194 on wlo1.IPv4.
Mar 04 11:09:58 Jumbleline NetworkManager[1914]: <info>  [1677899398.1876] device (wlo1): state change: disconnected -> unmanaged (reason 'sleeping', sys-iface-state: 'managed')
Mar 04 11:09:58 Jumbleline NetworkManager[1914]: <info>  [1677899398.3239] device (wlo1): set-hw-addr: reset MAC address to 8C:B8:7E:93:82:0D (unmanage)
Mar 04 11:09:58 Jumbleline wpa_supplicant[2205]: p2p-dev-wlo1: CTRL-EVENT-DSCP-POLICY clear_all
Mar 04 11:09:58 Jumbleline wpa_supplicant[2205]: nl80211: deinit ifname=p2p-dev-wlo1 disabled_11b_rates=0
Mar 04 11:09:58 Jumbleline wpa_supplicant[2205]: nl80211: deinit ifname=wlo1 disabled_11b_rates=0
Mar 04 11:09:58 Jumbleline systemd[1]: Reached target Sleep.
Mar 04 11:09:58 Jumbleline systemd[1]: Starting System Suspend...
Mar 04 11:09:58 Jumbleline systemd-sleep[4276]: Entering sleep state 'suspend'...
Mar 04 11:09:58 Jumbleline kernel: PM: suspend entry (deep)
inxi -b
  Host: Jumbleline Kernel: 6.1.12-1-MANJARO arch: x86_64 bits: 64
    Desktop: sway v: 1.8.1 Distro: Manjaro Linux
  Type: Desktop System: Micro-Star product: MS-7D42 v: 1.0
    serial: <superuser required>
  Mobo: Micro-Star model: MAG B660M MORTAR WIFI DDR4 (MS-7D42) v: 1.0
    serial: <superuser required> UEFI: American Megatrends LLC. v: 1.A0
    date: 01/10/2023
  Info: 12-core (8-mt/4-st) 12th Gen Intel Core i7-12700 [MST AMCP]
    speed (MHz): avg: 1389 min/max: 800/4800:4900:3600
  Device-1: Intel AlderLake-S GT1 driver: i915 v: kernel
  Device-2: AMD Navi 21 [Radeon RX 6950 XT] driver: amdgpu v: kernel
  Device-3: Realtek AUSDOM AW651 type: USB driver: snd-usb-audio,uvcvideo
  Display: wayland server: X.org v: 1.21.1.7 with: Xwayland v: 22.1.8
    compositor: sway v: 1.8.1 driver: gpu: amdgpu resolution: 1920x1080~240Hz
  API: OpenGL v: 4.6 Mesa 22.3.5 renderer: AMD Radeon RX 6950 XT (navi21
    LLVM 15.0.7 DRM 3.49 6.1.12-1-MANJARO)
  Device-1: Intel Alder Lake-S PCH CNVi WiFi driver: iwlwifi
  Device-2: Realtek RTL8125 2.5GbE driver: r8169
  Local Storage: total: raw: 2.71 TiB usable: 4.43 TiB used: 1.5 TiB (33.8%)
  Processes: 636 Uptime: 19m Memory: 15.4 GiB used: 2.58 GiB (16.8%)
  Shell: Zsh inxi: 3.3.25
Hi and welcome to the Forum :+1:
Looking at the time stamps, it looks like your computer resumes right after it had suspended, which is not normal behavior.
Can you pin-point where your system “freezes”, because the combined logs are a bit long to walk through…
And try to give a bit more time between suspending and resuming so the logs can be checked easier with timestamps.
Also a side note:
Hope you are not using “Force power off” when your computer “freezes”, because that could be one of the reasons of your problem…
Thanks so much for helping!
For REISUB, when the system wakes up frozen, the keyboard and mouse are frozen too. The mouse rgb is on, so the USB power is back on I think. But the NUMLOCK indicator is off and the system is not responding to any inputs, including REISUB. So the only option I had was the power button.
And I tried to record the logs again. In the previous logs, I think I just did wake it right after I suspended it, so the logs would appear that the system went back on right after.
An example of a failed suspend, where you can see no logs are generated after I tried to wake it up via keyboard press at 00:05:00-ish:
Mar 05 00:04:38 Jumbleline systemd-logind[1944]: The system will suspend now!
Mar 05 00:04:38 Jumbleline NetworkManager[2010]: <info>  [1677945878.9250] manager: sleep: sleep requested (sleeping: no  enabled: yes)
Mar 05 00:04:39 Jumbleline NetworkManager[2010]: <info>  [1677945879.1430] device (enp7s0): state change: unavailable -> unmanaged (reason 'sleeping', sys-iface-state: 'managed')
Mar 05 00:04:39 Jumbleline kernel: r8169 0000:07:00.0 enp7s0: Link is Down
Mar 05 00:04:39 Jumbleline NetworkManager[2010]: <info>  [1677945879.1503] device (p2p-dev-wlo1): state change: disconnected -> unmanaged (reason 'sleeping', sys-iface-state: 'managed')
Mar 05 00:04:39 Jumbleline NetworkManager[2010]: <info>  [1677945879.1504] manager: NetworkManager state is now ASLEEP
Mar 05 00:04:39 Jumbleline NetworkManager[2010]: <info>  [1677945879.1505] device (wlo1): state change: activated -> deactivating (reason 'sleeping', sys-iface-state: 'managed')
Mar 05 00:04:39 Jumbleline dbus-daemon[1941]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.6' (uid=0 pid=2010 comm="/usr/bin/NetworkManager --no-daemon")
Mar 05 00:04:39 Jumbleline systemd[1]: Starting Network Manager Script Dispatcher Service...
Mar 05 00:04:39 Jumbleline dbus-daemon[1941]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
Mar 05 00:04:39 Jumbleline systemd[1]: Started Network Manager Script Dispatcher Service.
Mar 05 00:04:39 Jumbleline audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 05 00:04:39 Jumbleline kernel: audit: type=1130 audit(1677945879.206:165): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 05 00:04:39 Jumbleline kernel: wlo1: deauthenticating from 18:f2:2c:7a:00:d8 by local choice (Reason: 3=DEAUTH_LEAVING)
Mar 05 00:04:39 Jumbleline wpa_supplicant[2254]: wlo1: CTRL-EVENT-DISCONNECTED bssid=18:f2:2c:7a:00:d8 reason=3 locally_generated=1
Mar 05 00:04:39 Jumbleline wpa_supplicant[2254]: wlo1: CTRL-EVENT-DSCP-POLICY clear_all
Mar 05 00:04:39 Jumbleline NetworkManager[2010]: <info>  [1677945879.3009] device (wlo1): supplicant interface state: completed -> disconnected
Mar 05 00:04:39 Jumbleline NetworkManager[2010]: <info>  [1677945879.3012] device (wlo1): state change: deactivating -> disconnected (reason 'sleeping', sys-iface-state: 'managed')
Mar 05 00:04:39 Jumbleline avahi-daemon[1939]: Withdrawing address record for fdea:4309:f1b4:4928:7851:67d5:a97d:d02d on wlo1.
Mar 05 00:04:39 Jumbleline avahi-daemon[1939]: Leaving mDNS multicast group on interface wlo1.IPv6 with address fdea:4309:f1b4:4928:7851:67d5:a97d:d02d.
Mar 05 00:04:39 Jumbleline avahi-daemon[1939]: Joining mDNS multicast group on interface wlo1.IPv6 with address fe80::8063:7fca:7c44:6b62.
Mar 05 00:04:39 Jumbleline avahi-daemon[1939]: Registering new address record for fe80::8063:7fca:7c44:6b62 on wlo1.*.
Mar 05 00:04:39 Jumbleline avahi-daemon[1939]: Withdrawing address record for fe80::8063:7fca:7c44:6b62 on wlo1.
Mar 05 00:04:39 Jumbleline avahi-daemon[1939]: Leaving mDNS multicast group on interface wlo1.IPv6 with address fe80::8063:7fca:7c44:6b62.
Mar 05 00:04:39 Jumbleline avahi-daemon[1939]: Interface wlo1.IPv6 no longer relevant for mDNS.
Mar 05 00:04:39 Jumbleline NetworkManager[2010]: <info>  [1677945879.3197] dhcp4 (wlo1): canceled DHCP transaction
Mar 05 00:04:39 Jumbleline NetworkManager[2010]: <info>  [1677945879.3198] dhcp4 (wlo1): activation: beginning transaction (timeout in 45 seconds)
Mar 05 00:04:39 Jumbleline NetworkManager[2010]: <info>  [1677945879.3198] dhcp4 (wlo1): state changed no lease
Mar 05 00:04:39 Jumbleline avahi-daemon[1939]: Interface wlo1.IPv4 no longer relevant for mDNS.
Mar 05 00:04:39 Jumbleline avahi-daemon[1939]: Leaving mDNS multicast group on interface wlo1.IPv4 with address 192.168.1.194.
Mar 05 00:04:39 Jumbleline avahi-daemon[1939]: Withdrawing address record for 192.168.1.194 on wlo1.
Mar 05 00:04:39 Jumbleline NetworkManager[2010]: <info>  [1677945879.3418] device (wlo1): set-hw-addr: set MAC address to D2:7F:E6:32:BD:90 (scanning)
Mar 05 00:04:39 Jumbleline avahi-daemon[1939]: Joining mDNS multicast group on interface wlo1.IPv4 with address 192.168.1.194.
Mar 05 00:04:39 Jumbleline avahi-daemon[1939]: New relevant interface wlo1.IPv4 for mDNS.
Mar 05 00:04:39 Jumbleline avahi-daemon[1939]: Registering new address record for 192.168.1.194 on wlo1.IPv4.
Mar 05 00:04:39 Jumbleline NetworkManager[2010]: <info>  [1677945879.3823] device (wlo1): state change: disconnected -> unmanaged (reason 'sleeping', sys-iface-state: 'managed')
Mar 05 00:04:39 Jumbleline NetworkManager[2010]: <info>  [1677945879.5113] device (wlo1): set-hw-addr: reset MAC address to 8C:B8:7E:93:82:0D (unmanage)
Mar 05 00:04:39 Jumbleline wpa_supplicant[2254]: p2p-dev-wlo1: CTRL-EVENT-DSCP-POLICY clear_all
Mar 05 00:04:39 Jumbleline wpa_supplicant[2254]: nl80211: deinit ifname=p2p-dev-wlo1 disabled_11b_rates=0
Mar 05 00:04:39 Jumbleline wpa_supplicant[2254]: nl80211: deinit ifname=wlo1 disabled_11b_rates=0
Mar 05 00:04:39 Jumbleline systemd[1]: Reached target Sleep.
Mar 05 00:04:39 Jumbleline systemd[1]: Starting System Suspend...
Mar 05 00:04:39 Jumbleline nmbd[2318]: [2023/03/05 00:04:39.926568,  0] ../../source3/libsmb/nmblib.c:923(send_udp)
Mar 05 00:04:39 Jumbleline nmbd[2318]:   Packet send failed to 192.168.1.255(138) ERRNO=Network is unreachable
Mar 05 00:04:39 Jumbleline systemd-sleep[4428]: Entering sleep state 'suspend'...
Mar 05 00:04:39 Jumbleline kernel: PM: suspend entry (deep)
And btw, It seems that @litmus-ritten is having the same issue in his post.
Logs from a working suspend:
Suspending:
Mar 05 00:47:37 Jumbleline systemd-logind[2094]: The system will suspend now!
Mar 05 00:47:37 Jumbleline NetworkManager[2125]: <info>  [1677948457.0502] manager: sleep: sleep requested (sleeping: no  enabled: yes)
Mar 05 00:47:37 Jumbleline NetworkManager[2125]: <info>  [1677948457.0504] device (enp7s0): state change: unavailable -> unmanaged (reason 'sleeping', sys-iface-state: 'managed')
Mar 05 00:47:37 Jumbleline NetworkManager[2125]: <info>  [1677948457.0597] device (p2p-dev-wlo1): state change: disconnected -> unmanaged (reason 'sleeping', sys-iface-state: 'managed')
Mar 05 00:47:37 Jumbleline NetworkManager[2125]: <info>  [1677948457.0603] manager: NetworkManager state is now ASLEEP
Mar 05 00:47:37 Jumbleline NetworkManager[2125]: <info>  [1677948457.0605] device (wlo1): state change: activated -> deactivating (reason 'sleeping', sys-iface-state: 'managed')
Mar 05 00:47:37 Jumbleline dbus-daemon[2091]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.7' (uid=0 pid=2125 comm="/usr/bin/NetworkManager --no-daemon")
Mar 05 00:47:37 Jumbleline systemd[1]: Starting Network Manager Script Dispatcher Service...
Mar 05 00:47:37 Jumbleline dbus-daemon[2091]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
Mar 05 00:47:37 Jumbleline systemd[1]: Started Network Manager Script Dispatcher Service.
Mar 05 00:47:37 Jumbleline audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 05 00:47:37 Jumbleline kernel: audit: type=1130 audit(1677948457.114:161): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 05 00:47:37 Jumbleline kernel: wlo1: deauthenticating from 18:f2:2c:7a:00:d8 by local choice (Reason: 3=DEAUTH_LEAVING)
Mar 05 00:47:37 Jumbleline wpa_supplicant[2409]: wlo1: CTRL-EVENT-DISCONNECTED bssid=18:f2:2c:7a:00:d8 reason=3 locally_generated=1
Mar 05 00:47:37 Jumbleline wpa_supplicant[2409]: wlo1: CTRL-EVENT-DSCP-POLICY clear_all
Mar 05 00:47:37 Jumbleline NetworkManager[2125]: <info>  [1677948457.3089] device (wlo1): supplicant interface state: completed -> disconnected
Mar 05 00:47:37 Jumbleline NetworkManager[2125]: <info>  [1677948457.3092] device (wlo1): state change: deactivating -> disconnected (reason 'sleeping', sys-iface-state: 'managed')
Mar 05 00:47:37 Jumbleline avahi-daemon[2089]: Withdrawing address record for fdea:4309:f1b4:4928:7851:67d5:a97d:d02d on wlo1.
Mar 05 00:47:37 Jumbleline avahi-daemon[2089]: Leaving mDNS multicast group on interface wlo1.IPv6 with address fdea:4309:f1b4:4928:7851:67d5:a97d:d02d.
Mar 05 00:47:37 Jumbleline avahi-daemon[2089]: Joining mDNS multicast group on interface wlo1.IPv6 with address fe80::8063:7fca:7c44:6b62.
Mar 05 00:47:37 Jumbleline NetworkManager[2125]: <info>  [1677948457.3108] dhcp4 (wlo1): canceled DHCP transaction
Mar 05 00:47:37 Jumbleline avahi-daemon[2089]: Registering new address record for fe80::8063:7fca:7c44:6b62 on wlo1.*.
Mar 05 00:47:37 Jumbleline NetworkManager[2125]: <info>  [1677948457.3109] dhcp4 (wlo1): activation: beginning transaction (timeout in 45 seconds)
Mar 05 00:47:37 Jumbleline NetworkManager[2125]: <info>  [1677948457.3109] dhcp4 (wlo1): state changed no lease
Mar 05 00:47:37 Jumbleline avahi-daemon[2089]: Withdrawing address record for fe80::8063:7fca:7c44:6b62 on wlo1.
Mar 05 00:47:37 Jumbleline avahi-daemon[2089]: Leaving mDNS multicast group on interface wlo1.IPv6 with address fe80::8063:7fca:7c44:6b62.
Mar 05 00:47:37 Jumbleline avahi-daemon[2089]: Interface wlo1.IPv6 no longer relevant for mDNS.
Mar 05 00:47:37 Jumbleline avahi-daemon[2089]: Interface wlo1.IPv4 no longer relevant for mDNS.
Mar 05 00:47:37 Jumbleline avahi-daemon[2089]: Leaving mDNS multicast group on interface wlo1.IPv4 with address 192.168.1.194.
Mar 05 00:47:37 Jumbleline avahi-daemon[2089]: Withdrawing address record for 192.168.1.194 on wlo1.
Mar 05 00:47:37 Jumbleline NetworkManager[2125]: <info>  [1677948457.3439] device (wlo1): set-hw-addr: set MAC address to 02:8B:9D:EA:57:28 (scanning)
Mar 05 00:47:37 Jumbleline avahi-daemon[2089]: Joining mDNS multicast group on interface wlo1.IPv4 with address 192.168.1.194.
Mar 05 00:47:37 Jumbleline avahi-daemon[2089]: New relevant interface wlo1.IPv4 for mDNS.
Mar 05 00:47:37 Jumbleline avahi-daemon[2089]: Registering new address record for 192.168.1.194 on wlo1.IPv4.
Mar 05 00:47:37 Jumbleline NetworkManager[2125]: <info>  [1677948457.3735] device (wlo1): state change: disconnected -> unmanaged (reason 'sleeping', sys-iface-state: 'managed')
Mar 05 00:47:37 Jumbleline NetworkManager[2125]: <info>  [1677948457.4030] device (wlo1): set-hw-addr: reset MAC address to 8C:B8:7E:93:82:0D (unmanage)
Mar 05 00:47:37 Jumbleline wpa_supplicant[2409]: p2p-dev-wlo1: CTRL-EVENT-DSCP-POLICY clear_all
Mar 05 00:47:37 Jumbleline wpa_supplicant[2409]: nl80211: deinit ifname=p2p-dev-wlo1 disabled_11b_rates=0
Mar 05 00:47:37 Jumbleline wpa_supplicant[2409]: nl80211: deinit ifname=wlo1 disabled_11b_rates=0
Mar 05 00:47:37 Jumbleline systemd[1]: Reached target Sleep.
Mar 05 00:47:37 Jumbleline systemd[1]: Starting System Suspend...
Mar 05 00:47:38 Jumbleline systemd-sleep[3691]: Entering sleep state 'suspend'...
Mar 05 00:47:38 Jumbleline kernel: PM: suspend entry (deep)
Mar 05 00:47:38 Jumbleline kernel: Filesystems sync: 0.098 seconds
Waking:
Mar 05 00:48:19 Jumbleline kernel: Freezing user space processes ... (elapsed 0.002 seconds) done.
Mar 05 00:48:19 Jumbleline kernel: OOM killer disabled.
Mar 05 00:48:19 Jumbleline kernel: Freezing remaining freezable tasks ... (elapsed 0.001 seconds) done.
Mar 05 00:48:19 Jumbleline kernel: printk: Suspending console(s) (use no_console_suspend to debug)
Mar 05 00:48:19 Jumbleline kernel: queueing ieee80211 work while going to suspend
Mar 05 00:48:19 Jumbleline kernel: sd 8:0:0:0: [sda] Synchronizing SCSI cache
Mar 05 00:48:19 Jumbleline kernel: sd 8:0:0:0: [sda] Stopping disk
Mar 05 00:48:19 Jumbleline kernel: amdgpu 0000:03:00.0: amdgpu: free PSP TMR buffer
Mar 05 00:48:19 Jumbleline kernel: amdgpu 0000:03:00.0: amdgpu: MODE1 reset
Mar 05 00:48:19 Jumbleline kernel: amdgpu 0000:03:00.0: amdgpu: GPU mode1 reset
Mar 05 00:48:19 Jumbleline kernel: amdgpu 0000:03:00.0: amdgpu: GPU smu mode1 reset
Mar 05 00:48:19 Jumbleline kernel: ACPI: PM: Preparing to enter system sleep state S3
Mar 05 00:48:19 Jumbleline kernel: ACPI: PM: Saving platform NVS memory
Mar 05 00:48:19 Jumbleline kernel: Disabling non-boot CPUs ...
Mar 05 00:48:19 Jumbleline kernel: smpboot: CPU 1 is now offline
Mar 05 00:48:19 Jumbleline kernel: smpboot: CPU 2 is now offline
Mar 05 00:48:19 Jumbleline kernel: smpboot: CPU 3 is now offline
Mar 05 00:48:19 Jumbleline kernel: smpboot: CPU 4 is now offline
Mar 05 00:48:19 Jumbleline kernel: smpboot: CPU 5 is now offline
Mar 05 00:48:19 Jumbleline kernel: smpboot: CPU 6 is now offline
Mar 05 00:48:19 Jumbleline kernel: smpboot: CPU 7 is now offline
Mar 05 00:48:19 Jumbleline kernel: smpboot: CPU 8 is now offline
Mar 05 00:48:19 Jumbleline kernel: smpboot: CPU 9 is now offline
Mar 05 00:48:19 Jumbleline kernel: smpboot: CPU 10 is now offline
Mar 05 00:48:19 Jumbleline kernel: smpboot: CPU 11 is now offline
Mar 05 00:48:19 Jumbleline kernel: smpboot: CPU 12 is now offline
Mar 05 00:48:19 Jumbleline kernel: smpboot: CPU 13 is now offline
Mar 05 00:48:19 Jumbleline kernel: smpboot: CPU 14 is now offline
Mar 05 00:48:19 Jumbleline kernel: smpboot: CPU 15 is now offline
Mar 05 00:48:19 Jumbleline kernel: smpboot: CPU 16 is now offline
Mar 05 00:48:19 Jumbleline kernel: smpboot: CPU 17 is now offline
Mar 05 00:48:19 Jumbleline kernel: smpboot: CPU 18 is now offline
Mar 05 00:48:19 Jumbleline kernel: smpboot: CPU 19 is now offline
Mar 05 00:48:19 Jumbleline kernel: ACPI: PM: Low-level resume complete
Mar 05 00:48:19 Jumbleline kernel: ACPI: PM: Restoring platform NVS memory
Mar 05 00:48:19 Jumbleline kernel: Enabling non-boot CPUs ...
Mar 05 00:48:19 Jumbleline kernel: x86: Booting SMP configuration:
Mar 05 00:48:19 Jumbleline kernel: smpboot: Booting Node 0 Processor 1 APIC 0x1
Mar 05 00:48:19 Jumbleline kernel: CPU1 is up
Mar 05 00:48:19 Jumbleline kernel: smpboot: Booting Node 0 Processor 2 APIC 0x8
Mar 05 00:48:19 Jumbleline kernel: CPU2 is up
Mar 05 00:48:19 Jumbleline kernel: smpboot: Booting Node 0 Processor 3 APIC 0x9
Mar 05 00:48:19 Jumbleline kernel: CPU3 is up
Mar 05 00:48:19 Jumbleline kernel: smpboot: Booting Node 0 Processor 4 APIC 0x10
Mar 05 00:48:19 Jumbleline kernel: CPU4 is up
Mar 05 00:48:19 Jumbleline kernel: smpboot: Booting Node 0 Processor 5 APIC 0x11
Mar 05 00:48:19 Jumbleline kernel: CPU5 is up
Mar 05 00:48:19 Jumbleline kernel: smpboot: Booting Node 0 Processor 6 APIC 0x18
Mar 05 00:48:19 Jumbleline kernel: CPU6 is up
Mar 05 00:48:19 Jumbleline kernel: smpboot: Booting Node 0 Processor 7 APIC 0x19
Mar 05 00:48:19 Jumbleline kernel: CPU7 is up
Mar 05 00:48:19 Jumbleline kernel: smpboot: Booting Node 0 Processor 8 APIC 0x20
Mar 05 00:48:19 Jumbleline kernel: CPU8 is up
Mar 05 00:48:19 Jumbleline kernel: smpboot: Booting Node 0 Processor 9 APIC 0x21
Mar 05 00:48:19 Jumbleline kernel: CPU9 is up
Mar 05 00:48:19 Jumbleline kernel: smpboot: Booting Node 0 Processor 10 APIC 0x28
Mar 05 00:48:19 Jumbleline kernel: CPU10 is up
Mar 05 00:48:19 Jumbleline kernel: smpboot: Booting Node 0 Processor 11 APIC 0x29
Mar 05 00:48:19 Jumbleline kernel: CPU11 is up
Mar 05 00:48:19 Jumbleline kernel: smpboot: Booting Node 0 Processor 12 APIC 0x30
Mar 05 00:48:19 Jumbleline kernel: CPU12 is up
Mar 05 00:48:19 Jumbleline kernel: smpboot: Booting Node 0 Processor 13 APIC 0x31
Mar 05 00:48:19 Jumbleline kernel: CPU13 is up
Mar 05 00:48:19 Jumbleline kernel: smpboot: Booting Node 0 Processor 14 APIC 0x38
Mar 05 00:48:19 Jumbleline kernel: CPU14 is up
Mar 05 00:48:19 Jumbleline kernel: smpboot: Booting Node 0 Processor 15 APIC 0x39
Mar 05 00:48:19 Jumbleline kernel: CPU15 is up
Mar 05 00:48:19 Jumbleline kernel: smpboot: Booting Node 0 Processor 16 APIC 0x48
Mar 05 00:48:19 Jumbleline kernel: core: cpu_atom PMU driver: PEBS-via-PT
Mar 05 00:48:19 Jumbleline kernel: ... version:                5
Mar 05 00:48:19 Jumbleline kernel: ... bit width:              48
Mar 05 00:48:19 Jumbleline kernel: ... generic registers:      6
Mar 05 00:48:19 Jumbleline kernel: ... value mask:             0000ffffffffffff
Mar 05 00:48:19 Jumbleline kernel: ... max period:             00007fffffffffff
Mar 05 00:48:19 Jumbleline kernel: ... fixed-purpose events:   3
Mar 05 00:48:19 Jumbleline kernel: ... event mask:             000000070000003f
Mar 05 00:48:19 Jumbleline kernel: CPU16 is up
Mar 05 00:48:19 Jumbleline kernel: smpboot: Booting Node 0 Processor 17 APIC 0x4a
Mar 05 00:48:19 Jumbleline kernel: CPU17 is up
Mar 05 00:48:19 Jumbleline kernel: smpboot: Booting Node 0 Processor 18 APIC 0x4c
Mar 05 00:48:19 Jumbleline kernel: CPU18 is up
Mar 05 00:48:19 Jumbleline kernel: smpboot: Booting Node 0 Processor 19 APIC 0x4e
Mar 05 00:48:19 Jumbleline kernel: CPU19 is up
Mar 05 00:48:19 Jumbleline kernel: ACPI: PM: Waking up from system sleep state S3
Mar 05 00:48:19 Jumbleline kernel: sd 8:0:0:0: [sda] Starting disk
Mar 05 00:48:19 Jumbleline kernel: [drm] PCIE GART of 512M enabled (table at 0x0000008000300000).
Mar 05 00:48:19 Jumbleline kernel: [drm] PSP is resuming...
Mar 05 00:48:19 Jumbleline kernel: i915 0000:00:02.0: [drm] GuC firmware i915/tgl_guc_70.bin version 70.5.1
Mar 05 00:48:19 Jumbleline kernel: i915 0000:00:02.0: [drm] HuC firmware i915/tgl_huc.bin version 7.9.3
Mar 05 00:48:19 Jumbleline kernel: nvme nvme0: 8/0/0 default/read/poll queues
Mar 05 00:48:19 Jumbleline kernel: nvme nvme1: 16/0/0 default/read/poll queues
Mar 05 00:48:19 Jumbleline kernel: nvme nvme0: Ignoring bogus Namespace Identifiers
Mar 05 00:48:19 Jumbleline kernel: i915 0000:00:02.0: [drm] HuC authenticated
Mar 05 00:48:19 Jumbleline kernel: i915 0000:00:02.0: [drm] GuC submission disabled
Mar 05 00:48:19 Jumbleline kernel: i915 0000:00:02.0: [drm] GuC SLPC disabled
Mar 05 00:48:19 Jumbleline kernel: [drm] reserve 0xa00000 from 0x83fd000000 for PSP TMR
Mar 05 00:48:19 Jumbleline kernel: amdgpu 0000:03:00.0: amdgpu: SECUREDISPLAY: securedisplay ta ucode is not available
Mar 05 00:48:19 Jumbleline kernel: amdgpu 0000:03:00.0: amdgpu: SMU is resuming...
Mar 05 00:48:19 Jumbleline kernel: amdgpu 0000:03:00.0: amdgpu: smu driver if version = 0x00000040, smu fw if version = 0x00000041, smu fw program = 0, version = 0x003a5600 (58.86.0)
Mar 05 00:48:19 Jumbleline kernel: amdgpu 0000:03:00.0: amdgpu: SMU driver if version not matched
Mar 05 00:48:19 Jumbleline kernel: amdgpu 0000:03:00.0: amdgpu: use vbios provided pptable
Mar 05 00:48:19 Jumbleline kernel: amdgpu 0000:03:00.0: amdgpu: SMU is resumed successfully!
Mar 05 00:48:19 Jumbleline kernel: [drm] DMUB hardware initialized: version=0x02020017
Mar 05 00:48:19 Jumbleline kernel: ata10: SATA link down (SStatus 0 SControl 300)
Mar 05 00:48:19 Jumbleline kernel: ata8: SATA link down (SStatus 4 SControl 300)
Mar 05 00:48:19 Jumbleline kernel: ata6: SATA link down (SStatus 4 SControl 300)
Mar 05 00:48:19 Jumbleline kernel: ata7: SATA link down (SStatus 4 SControl 300)
Mar 05 00:48:19 Jumbleline kernel: ata5: SATA link down (SStatus 4 SControl 300)
Mar 05 00:48:19 Jumbleline kernel: ata9: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
Mar 05 00:48:19 Jumbleline kernel: [drm] DP Alt mode state on HPD: 1
Mar 05 00:48:19 Jumbleline kernel: ata9.00: configured for UDMA/133
Mar 05 00:48:19 Jumbleline kernel: [drm] kiq ring mec 2 pipe 1 q 0
Mar 05 00:48:19 Jumbleline kernel: [drm] VCN decode and encode initialized successfully(under DPG Mode).
Mar 05 00:48:19 Jumbleline kernel: [drm] JPEG decode initialized successfully.
Mar 05 00:48:19 Jumbleline kernel: amdgpu 0000:03:00.0: amdgpu: ring gfx_0.0.0 uses VM inv eng 0 on hub 0
Mar 05 00:48:19 Jumbleline kernel: amdgpu 0000:03:00.0: amdgpu: ring comp_1.0.0 uses VM inv eng 1 on hub 0
Mar 05 00:48:19 Jumbleline kernel: amdgpu 0000:03:00.0: amdgpu: ring comp_1.1.0 uses VM inv eng 4 on hub 0
Mar 05 00:48:19 Jumbleline kernel: amdgpu 0000:03:00.0: amdgpu: ring comp_1.2.0 uses VM inv eng 5 on hub 0
Mar 05 00:48:19 Jumbleline kernel: amdgpu 0000:03:00.0: amdgpu: ring comp_1.3.0 uses VM inv eng 6 on hub 0
Mar 05 00:48:19 Jumbleline kernel: amdgpu 0000:03:00.0: amdgpu: ring comp_1.0.1 uses VM inv eng 7 on hub 0
Mar 05 00:48:19 Jumbleline kernel: amdgpu 0000:03:00.0: amdgpu: ring comp_1.1.1 uses VM inv eng 8 on hub 0
Mar 05 00:48:19 Jumbleline kernel: amdgpu 0000:03:00.0: amdgpu: ring comp_1.2.1 uses VM inv eng 9 on hub 0
Mar 05 00:48:19 Jumbleline kernel: amdgpu 0000:03:00.0: amdgpu: ring comp_1.3.1 uses VM inv eng 10 on hub 0
Mar 05 00:48:19 Jumbleline kernel: amdgpu 0000:03:00.0: amdgpu: ring kiq_2.1.0 uses VM inv eng 11 on hub 0
Mar 05 00:48:19 Jumbleline kernel: amdgpu 0000:03:00.0: amdgpu: ring sdma0 uses VM inv eng 12 on hub 0
Mar 05 00:48:19 Jumbleline kernel: amdgpu 0000:03:00.0: amdgpu: ring sdma1 uses VM inv eng 13 on hub 0
Mar 05 00:48:19 Jumbleline kernel: amdgpu 0000:03:00.0: amdgpu: ring sdma2 uses VM inv eng 14 on hub 0
Mar 05 00:48:19 Jumbleline kernel: amdgpu 0000:03:00.0: amdgpu: ring sdma3 uses VM inv eng 15 on hub 0
Mar 05 00:48:19 Jumbleline kernel: amdgpu 0000:03:00.0: amdgpu: ring vcn_dec_0 uses VM inv eng 0 on hub 1
Mar 05 00:48:19 Jumbleline kernel: amdgpu 0000:03:00.0: amdgpu: ring vcn_enc_0.0 uses VM inv eng 1 on hub 1
Mar 05 00:48:19 Jumbleline kernel: amdgpu 0000:03:00.0: amdgpu: ring vcn_enc_0.1 uses VM inv eng 4 on hub 1
Mar 05 00:48:19 Jumbleline kernel: amdgpu 0000:03:00.0: amdgpu: ring vcn_dec_1 uses VM inv eng 5 on hub 1
Mar 05 00:48:19 Jumbleline kernel: amdgpu 0000:03:00.0: amdgpu: ring vcn_enc_1.0 uses VM inv eng 6 on hub 1
Mar 05 00:48:19 Jumbleline kernel: amdgpu 0000:03:00.0: amdgpu: ring vcn_enc_1.1 uses VM inv eng 7 on hub 1
Mar 05 00:48:19 Jumbleline kernel: amdgpu 0000:03:00.0: amdgpu: ring jpeg_dec uses VM inv eng 8 on hub 1
Mar 05 00:48:19 Jumbleline kernel: usb 3-2: reset full-speed USB device number 2 using xhci_hcd
Mar 05 00:48:19 Jumbleline kernel: OOM killer enabled.
Mar 05 00:48:19 Jumbleline kernel: Restarting tasks ... done.
Mar 05 00:48:19 Jumbleline kernel: random: crng reseeded on system resumption
Mar 05 00:48:19 Jumbleline kernel: mei_hdcp 0000:00:16.0-b638ab7e-94e2-4ea2-a552-d1c54b627f04: bound 0000:00:02.0 (ops i915_hdcp_component_ops [i915])
Mar 05 00:48:19 Jumbleline kernel: mei_pxp 0000:00:16.0-fbf6fcf1-96cf-4e2e-a6a6-1bab8cbe36b1: bound 0000:00:02.0 (ops i915_pxp_tee_component_ops [i915])
Mar 05 00:48:19 Jumbleline systemd-sleep[3691]: System returned from sleep state.
Mar 05 00:48:19 Jumbleline kernel: PM: suspend exit
Mar 05 00:48:19 Jumbleline bluetoothd[2090]: Controller resume with wake event 0x0
Mar 05 00:48:19 Jumbleline systemd[1]: systemd-suspend.service: Deactivated successfully.
Mar 05 00:48:19 Jumbleline systemd[1]: Finished System Suspend.
Mar 05 00:48:19 Jumbleline audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=systemd-suspend comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 05 00:48:19 Jumbleline audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=systemd-suspend comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 05 00:48:19 Jumbleline systemd[1]: Stopped target Sleep.
Mar 05 00:48:19 Jumbleline systemd[1]: Reached target Suspend.
Mar 05 00:48:19 Jumbleline systemd[1]: Stopped target Suspend.
Mar 05 00:48:19 Jumbleline systemd-logind[2094]: Operation 'sleep' finished.
Mar 05 00:48:19 Jumbleline kernel: audit: type=1130 audit(1677948499.763:162): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=systemd-suspend comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 05 00:48:19 Jumbleline kernel: audit: type=1131 audit(1677948499.763:163): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=systemd-suspend comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 05 00:48:19 Jumbleline NetworkManager[2125]: <info>  [1677948499.7694] manager: sleep: wake requested (sleeping: yes  enabled: yes)
Mar 05 00:48:19 Jumbleline NetworkManager[2125]: <info>  [1677948499.7697] device (enp7s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Mar 05 00:48:19 Jumbleline kernel: RTL8226B_RTL8221B 2.5Gbps PHY r8169-0-700:00: attached PHY driver (mii_bus:phy_addr=r8169-0-700:00, irq=MAC)
Mar 05 00:48:19 Jumbleline NetworkManager[2125]: <info>  [1677948499.9754] device (wlo1): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Mar 05 00:48:19 Jumbleline NetworkManager[2125]: <info>  [1677948499.9765] device (p2p-dev-wlo1): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Mar 05 00:48:19 Jumbleline NetworkManager[2125]: <info>  [1677948499.9768] manager: NetworkManager state is now CONNECTED_LOCAL
Mar 05 00:48:19 Jumbleline kernel: r8169 0000:07:00.0 enp7s0: Link is Down
Mar 05 00:48:20 Jumbleline NetworkManager[2125]: <info>  [1677948500.0226] device (wlo1): supplicant interface state: internal-starting -> disconnected
Mar 05 00:48:20 Jumbleline NetworkManager[2125]: <info>  [1677948500.0226] device (p2p-dev-wlo1): state change: unavailable -> unmanaged (reason 'removed', sys-iface-state: 'removed')
Mar 05 00:48:20 Jumbleline NetworkManager[2125]: <info>  [1677948500.0235] Wi-Fi P2P device controlled by interface wlo1 created
Mar 05 00:48:20 Jumbleline NetworkManager[2125]: <info>  [1677948500.0238] manager: (p2p-dev-wlo1): new 802.11 Wi-Fi P2P device (/org/freedesktop/NetworkManager/Devices/8)
Mar 05 00:48:20 Jumbleline NetworkManager[2125]: <info>  [1677948500.0242] device (p2p-dev-wlo1): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Mar 05 00:48:20 Jumbleline NetworkManager[2125]: <info>  [1677948500.0248] device (wlo1): state change: unavailable -> disconnected (reason 'supplicant-available', sys-iface-state: 'managed')
Mar 05 00:48:20 Jumbleline NetworkManager[2125]: <info>  [1677948500.0255] device (p2p-dev-wlo1): state change: unavailable -> disconnected (reason 'none', sys-iface-state: 'managed')
Mar 05 00:48:23 Jumbleline wpa_supplicant[2409]: wlo1: CTRL-EVENT-REGDOM-CHANGE init=DRIVER type=COUNTRY alpha2=CN
Mar 05 00:48:23 Jumbleline NetworkManager[2125]: <info>  [1677948503.3729] policy: auto-activating connection 'K2P_Eagle' (fe69d8c5-0f37-4a5f-8720-5bbe9d8b5d9e)
Mar 05 00:48:23 Jumbleline NetworkManager[2125]: <info>  [1677948503.3730] device (wlo1): Activation: starting connection 'K2P_Eagle' (fe69d8c5-0f37-4a5f-8720-5bbe9d8b5d9e)
Mar 05 00:48:23 Jumbleline NetworkManager[2125]: <info>  [1677948503.3730] device (wlo1): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
Mar 05 00:48:23 Jumbleline NetworkManager[2125]: <info>  [1677948503.3731] manager: NetworkManager state is now CONNECTING
Mar 05 00:48:23 Jumbleline NetworkManager[2125]: <info>  [1677948503.3732] device (wlo1): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Mar 05 00:48:23 Jumbleline NetworkManager[2125]: <info>  [1677948503.3733] device (wlo1): Activation: (wifi) access point 'K2P_Eagle' has security, but secrets are required.
Mar 05 00:48:23 Jumbleline NetworkManager[2125]: <info>  [1677948503.3733] device (wlo1): state change: config -> need-auth (reason 'none', sys-iface-state: 'managed')
Mar 05 00:48:23 Jumbleline NetworkManager[2125]: <info>  [1677948503.3735] device (wlo1): state change: need-auth -> prepare (reason 'none', sys-iface-state: 'managed')
Mar 05 00:48:23 Jumbleline NetworkManager[2125]: <info>  [1677948503.3736] device (wlo1): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Mar 05 00:48:23 Jumbleline NetworkManager[2125]: <info>  [1677948503.3737] device (wlo1): Activation: (wifi) connection 'K2P_Eagle' has security, and secrets exist.  No new secrets needed.
Mar 05 00:48:23 Jumbleline NetworkManager[2125]: <info>  [1677948503.3737] Config: added 'ssid' value 'K2P_Eagle'
Mar 05 00:48:23 Jumbleline NetworkManager[2125]: <info>  [1677948503.3737] Config: added 'scan_ssid' value '1'
Mar 05 00:48:23 Jumbleline NetworkManager[2125]: <info>  [1677948503.3737] Config: added 'bgscan' value 'simple:30:-70:86400'
Mar 05 00:48:23 Jumbleline NetworkManager[2125]: <info>  [1677948503.3737] Config: added 'key_mgmt' value 'WPA-PSK WPA-PSK-SHA256 FT-PSK SAE FT-SAE'
Mar 05 00:48:23 Jumbleline NetworkManager[2125]: <info>  [1677948503.3737] Config: added 'auth_alg' value 'OPEN'
Mar 05 00:48:23 Jumbleline NetworkManager[2125]: <info>  [1677948503.3737] Config: added 'psk' value '<hidden>'
Mar 05 00:48:23 Jumbleline wpa_supplicant[2409]: wlo1: SME: Trying to authenticate with 18:f2:2c:7a:00:d8 (SSID='K2P_Eagle' freq=5180 MHz)
Mar 05 00:48:23 Jumbleline kernel: wlo1: authenticate with 18:f2:2c:7a:00:d8
Mar 05 00:48:23 Jumbleline kernel: wlo1: send auth to 18:f2:2c:7a:00:d8 (try 1/3)
Mar 05 00:48:23 Jumbleline NetworkManager[2125]: <info>  [1677948503.3842] device (wlo1): supplicant interface state: disconnected -> authenticating
Mar 05 00:48:23 Jumbleline NetworkManager[2125]: <info>  [1677948503.3843] device (p2p-dev-wlo1): supplicant management interface state: disconnected -> authenticating
Mar 05 00:48:23 Jumbleline wpa_supplicant[2409]: wlo1: Trying to associate with 18:f2:2c:7a:00:d8 (SSID='K2P_Eagle' freq=5180 MHz)
Mar 05 00:48:23 Jumbleline NetworkManager[2125]: <info>  [1677948503.4198] device (wlo1): supplicant interface state: authenticating -> associating
Mar 05 00:48:23 Jumbleline NetworkManager[2125]: <info>  [1677948503.4198] device (p2p-dev-wlo1): supplicant management interface state: authenticating -> associating
Mar 05 00:48:23 Jumbleline kernel: wlo1: authenticated
Mar 05 00:48:23 Jumbleline kernel: wlo1: associate with 18:f2:2c:7a:00:d8 (try 1/3)
Mar 05 00:48:23 Jumbleline kernel: wlo1: RX AssocResp from 18:f2:2c:7a:00:d8 (capab=0x1511 status=0 aid=1)
Mar 05 00:48:23 Jumbleline wpa_supplicant[2409]: wlo1: Associated with 18:f2:2c:7a:00:d8
Mar 05 00:48:23 Jumbleline wpa_supplicant[2409]: wlo1: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
Mar 05 00:48:23 Jumbleline kernel: wlo1: associated
Mar 05 00:48:23 Jumbleline wpa_supplicant[2409]: wlo1: WPA: Key negotiation completed with 18:f2:2c:7a:00:d8 [PTK=CCMP GTK=CCMP]
Mar 05 00:48:23 Jumbleline wpa_supplicant[2409]: wlo1: CTRL-EVENT-CONNECTED - Connection to 18:f2:2c:7a:00:d8 completed [id=0 id_str=]
Mar 05 00:48:23 Jumbleline kernel: IPv6: ADDRCONF(NETDEV_CHANGE): wlo1: link becomes ready
Mar 05 00:48:23 Jumbleline NetworkManager[2125]: <info>  [1677948503.4778] device (wlo1): supplicant interface state: associating -> completed
Mar 05 00:48:23 Jumbleline NetworkManager[2125]: <info>  [1677948503.4779] device (wlo1): Activation: (wifi) Stage 2 of 5 (Device Configure) successful. Connected to wireless network "K2P_Eagle"
Mar 05 00:48:23 Jumbleline NetworkManager[2125]: <info>  [1677948503.4779] device (p2p-dev-wlo1): supplicant management interface state: associating -> completed
Mar 05 00:48:23 Jumbleline NetworkManager[2125]: <info>  [1677948503.4781] device (wlo1): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed')
Mar 05 00:48:23 Jumbleline NetworkManager[2125]: <info>  [1677948503.4786] dhcp4 (wlo1): activation: beginning transaction (timeout in 45 seconds)
Mar 05 00:48:23 Jumbleline avahi-daemon[2089]: Joining mDNS multicast group on interface wlo1.IPv6 with address fe80::8063:7fca:7c44:6b62.
Mar 05 00:48:23 Jumbleline avahi-daemon[2089]: New relevant interface wlo1.IPv6 for mDNS.
Mar 05 00:48:23 Jumbleline avahi-daemon[2089]: Registering new address record for fe80::8063:7fca:7c44:6b62 on wlo1.*.
Mar 05 00:48:23 Jumbleline kernel: wlo1: Limiting TX power to 35 (35 - 0) dBm as advertised by 18:f2:2c:7a:00:d8
Mar 05 00:48:23 Jumbleline NetworkManager[2125]: <info>  [1677948503.5279] dhcp4 (wlo1): state changed new lease, address=192.168.1.194
Mar 05 00:48:23 Jumbleline NetworkManager[2125]: <info>  [1677948503.5285] policy: set 'K2P_Eagle' (wlo1) as default for IPv4 routing and DNS
Mar 05 00:48:23 Jumbleline avahi-daemon[2089]: Joining mDNS multicast group on interface wlo1.IPv4 with address 192.168.1.194.
Mar 05 00:48:23 Jumbleline avahi-daemon[2089]: New relevant interface wlo1.IPv4 for mDNS.
Mar 05 00:48:23 Jumbleline avahi-daemon[2089]: Registering new address record for 192.168.1.194 on wlo1.IPv4.
Mar 05 00:48:23 Jumbleline NetworkManager[2125]: <info>  [1677948503.5383] device (wlo1): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'managed')
Mar 05 00:48:23 Jumbleline NetworkManager[2125]: <info>  [1677948503.5413] device (wlo1): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'managed')
Mar 05 00:48:23 Jumbleline NetworkManager[2125]: <info>  [1677948503.5415] device (wlo1): state change: secondaries -> activated (reason 'none', sys-iface-state: 'managed')
Mar 05 00:48:23 Jumbleline NetworkManager[2125]: <info>  [1677948503.5419] manager: NetworkManager state is now CONNECTED_SITE
Mar 05 00:48:23 Jumbleline NetworkManager[2125]: <info>  [1677948503.5430] device (wlo1): Activation: successful, device activated.
Mar 05 00:48:23 Jumbleline wpa_supplicant[2409]: wlo1: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-62 noise=9999 txrate=490000
Mar 05 00:48:24 Jumbleline avahi-daemon[2089]: Leaving mDNS multicast group on interface wlo1.IPv6 with address fe80::8063:7fca:7c44:6b62.
Mar 05 00:48:24 Jumbleline avahi-daemon[2089]: Joining mDNS multicast group on interface wlo1.IPv6 with address fdea:4309:f1b4:4928:7851:67d5:a97d:d02d.
Mar 05 00:48:24 Jumbleline avahi-daemon[2089]: Registering new address record for fdea:4309:f1b4:4928:7851:67d5:a97d:d02d on wlo1.*.
Mar 05 00:48:24 Jumbleline avahi-daemon[2089]: Withdrawing address record for fe80::8063:7fca:7c44:6b62 on wlo1.
Mar 05 00:48:25 Jumbleline NetworkManager[2125]: <info>  [1677948505.0859] manager: NetworkManager state is now CONNECTED_GLOBAL
Mar 05 00:48:25 Jumbleline systemd[1]: NetworkManager-dispatcher.service: Deactivated successfully.
Mar 05 00:48:25 Jumbleline appimagelauncherd[2915]: Directories to watch disappeared, unintegrating AppImages formerly found in there
Mar 05 00:48:25 Jumbleline audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 05 00:48:25 Jumbleline kernel: audit: type=1131 audit(1677948505.169:164): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 05 00:48:25 Jumbleline dbus-daemon[2091]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.53' (uid=1000 pid=3666 comm="swaylock --daemonize --color #282a2b --inside-colo")
Mar 05 00:48:25 Jumbleline dbus-daemon[2091]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.home1.service': Unit dbus-org.freedesktop.home1.service not found.
Mar 05 00:48:25 Jumbleline swaylock[3666]: pam_systemd_home(swaylock:auth): systemd-homed is not available: Unit dbus-org.freedesktop.home1.service not found.
Mar 05 00:48:25 Jumbleline audit[4089]: USER_AUTH pid=4089 uid=1000 auid=1000 ses=3 subj=unconfined msg='op=PAM:unix_chkpwd acct="dotin13" exe="/usr/bin/unix_chkpwd" hostname=? addr=? terminal=? res=success'
Mar 05 00:48:25 Jumbleline kernel: audit: type=1100 audit(1677948505.303:165): pid=4089 uid=1000 auid=1000 ses=3 subj=unconfined msg='op=PAM:unix_chkpwd acct="dotin13" exe="/usr/bin/unix_chkpwd" hostname=? addr=? terminal=? res=success'
Mar 05 00:48:25 Jumbleline swaylock[3666]: gkr-pam: unlocked login keyring
Mar 05 00:48:33 Jumbleline sudo[4840]: PAM unable to dlopen(/usr/lib/security/pam_fprintd.so): /usr/lib/security/pam_fprintd.so: cannot open shared object file: No such file or directory
Mar 05 00:48:33 Jumbleline sudo[4840]: PAM adding faulty module: /usr/lib/security/pam_fprintd.so
Mar 05 00:48:36 Jumbleline audit[4840]: USER_AUTH pid=4840 uid=1000 auid=1000 ses=3 subj=unconfined msg='op=PAM:authentication grantors=pam_unix acct="dotin13" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
Mar 05 00:48:36 Jumbleline dbus-daemon[2091]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.54' (uid=0 pid=4840 comm="sudo journalctl -b -r")
Mar 05 00:48:36 Jumbleline dbus-daemon[2091]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.home1.service': Unit dbus-org.freedesktop.home1.service not found.
Mar 05 00:48:36 Jumbleline sudo[4840]: pam_systemd_home(sudo:account): systemd-homed is not available: Unit dbus-org.freedesktop.home1.service not found.
Mar 05 00:48:36 Jumbleline audit[4840]: USER_ACCT pid=4840 uid=1000 auid=1000 ses=3 subj=unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="dotin13" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
Mar 05 00:48:36 Jumbleline sudo[4840]:  dotin13 : TTY=pts/0 ; PWD=/home/dotin13 ; USER=root ; COMMAND=/usr/bin/journalctl -b -r
Mar 05 00:48:36 Jumbleline audit[4840]: CRED_REFR pid=4840 uid=1000 auid=1000 ses=3 subj=unconfined msg='op=PAM:setcred grantors=pam_unix acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
The issue became even more random. This morning I suspended the system and tried to turn it back on after 5 minutes, longer than all of my previous attempts, and the system just booted from scratch. It felt like the memory was wiped so the system didn’t even care about the suspension. So maybe it was a hardware issue? Memory power loss? Rotten bits? I don’t know.
This is indeed very suspicious, and indicate some hardware/driver issue…
  • Do you see any ACPI problems in your logs?
  • Do you use any extra software for Power Management, aside from systemd itself?
    (Maybe you installed an extra package for that)
Like i said your system is waking up right after it goes to sleep…
(CPU cores are shut down then immediately following that they are woken up again…)
That indicates that your Suspend/Resume cycle is not setup properly, or at the least is interrupted by something.
Im very sorry but this goes beyond my knowledge… :woman_shrugging:
:vulcan_salute:
Yeah sure, I can see what you mean now. The line Preparing to enter system sleep state S3 only appeared AFTER the system was waken up, which should have instead happened when I suspended it.
