Hi,
Currently having a decent experience with Manjaro on a Dell XPS 15 9520, with the exception that the laptop frequently locks up on resume after closing the lid. The screen turns on and displays the GNOME lock screen, with the time that the system was suspended.
Last couple of dmesg messages are not enlightening:
Feb 17 10:25:04.504127 [HOSTNAME] systemd[1]: Reached target Sleep.
Feb 17 10:25:04.533830 [HOSTNAME] systemd[1]: Starting System Suspend...
Feb 17 10:25:04.554140 [HOSTNAME] systemd-sleep[3050]: Entering sleep state 'suspend'...
inxi output:
Kernel: 6.1.11-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=54ee7e84-f24b-45ec-b518-765fe97860b1 rw quiet ibt=off
cryptdevice=UUID=c07b9399-ee9e-4f97-95e0-4ed7e38ff812:luks-c07b9399-ee9e-4f97-95e0-4ed7e38ff812
root=/dev/mapper/luks-c07b9399-ee9e-4f97-95e0-4ed7e38ff812 splash
udev.log_priority=3
Desktop: GNOME v: 43.2 tk: GTK v: 3.24.36 wm: gnome-shell dm: GDM v: 43.0
Type: Laptop System: Dell product: XPS 15 9520 v: N/A
Mobo: Dell model: 0YD3W1 v: A00 serial: <superuser required> UEFI: Dell
v: 1.2.0 date: 03/30/2022
ID-1: BAT0 charge: 49.7 Wh (64.2%) condition: 77.4/84.3 Wh (91.8%)
volts: 11.7 min: 11.4 model: BYD DELL M59JH21 type: Li-poly serial: <filter>
status: discharging
RAM: total: 15.3 GiB used: 3.63 GiB (23.7%)
Info: model: 12th Gen Intel Core i7-12700H bits: 64 type: MST AMCP
arch: Alder Lake gen: core 12 level: v3 note: check built: 2021+
process: Intel 7 (10nm ESF) family: 6 model-id: 0x9A (154) stepping: 3
microcode: 0x424
Topology: cpus: 1x cores: 14 mt: 6 tpc: 2 st: 8 threads: 20 smt: enabled
cache: L1: 1.2 MiB desc: d-8x32 KiB, 6x48 KiB; i-6x32 KiB, 8x64 KiB
L2: 11.5 MiB desc: 6x1.2 MiB, 2x2 MiB L3: 24 MiB desc: 1x24 MiB
Speed (MHz): avg: 2384 high: 2700 min/max: 400/4600:4700:3500 scaling:
driver: intel_pstate governor: powersave cores: 1: 588 2: 577 3: 2700 4: 2700
5: 2700 6: 2700 7: 618 8: 2700 9: 2700 10: 2700 11: 2700 12: 2700 13: 2700
14: 2700 15: 2700 16: 2700 17: 2700 18: 2700 19: 2700 20: 2700
bogomips: 107560
bts cat_l2 cdp_l2 clflush clflushopt clwb cmov constant_tsc cpuid
f16c flexpriority flush_l1d fma fpu fsgsbase fsrm fxsr gfni hfi ht hwp
hwp_act_window hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ida
intel_pt invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor
movbe movdir64b movdiri msr mtrr nonstop_tsc nopl nx ospke pae pat pbe
pcid pclmulqdq pdcm pdpe1gb pebs pge pku pln pni popcnt pse pse36 pts
rdpid rdrand rdseed rdt_a rdtscp rep_good sdbg sep serialize sha_ni smap
smep smx split_lock_detect ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer tsc_known_freq
umip vaes vme vmx vnmi vpclmulqdq vpid waitpkg x2apic xgetbv1 xsave xsavec
xsaveopt xsaves xtopology xtpr
Type: spectre_v2 mitigation: Enhanced IBRS, IBPB: conditional, RSB
filling, PBRSB-eIBRS: SW sequence
Device-1: Intel Alder Lake-P Integrated Graphics vendor: Dell driver: i915
v: kernel arch: Gen-12.2 process: Intel 10nm built: 2021-22+ ports:
active: eDP-1 empty: DP-1, DP-2, DP-3, DP-4, HDMI-A-1 bus-ID: 00:02.0
chip-ID: 8086:46a6 class-ID: 0300
Device-2: NVIDIA GA107M [GeForce RTX 3050 Ti Mobile] vendor: Dell
driver: nvidia v: 525.89.02 alternate: nouveau,nvidia_drm non-free: 525.xx+
status: current (as of 2023-02) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 4 speed: 16 GT/s lanes: 8
link-max: lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:25a0 class-ID: 0302
Device-3: Microdia Integrated_Webcam_HD type: USB driver: uvcvideo
bus-ID: 3-6:3 chip-ID: 0c45:6732 class-ID: 0e02
Display: x11 server: X.org v: 1.21.1.7 with: Xwayland v: 22.1.7
compositor: gnome-shell driver: X: loaded: modesetting,nvidia
unloaded: nouveau alternate: fbdev,nv,vesa dri: iris gpu: i915
display-ID: :0 screens: 1
Screen-1: 0 s-res: 3840x2400 s-size: <missing: xdpyinfo>
Monitor-1: eDP-1 model: Sharp 0x1516 built: 2021 res: 3840x2400 hz: 60
dpi: 290 gamma: 1.2 size: 336x210mm (13.23x8.27") diag: 396mm (15.6")
ratio: 16:10 modes: 3840x2400
API: OpenGL v: 4.6 Mesa 22.3.5 renderer: Mesa Intel Graphics (ADL GT2)
direct-render: Yes
Device-1: Intel Alder Lake PCH-P High Definition Audio vendor: Dell
driver: snd_hda_intel v: kernel alternate: snd_sof_pci_intel_tgl
bus-ID: 00:1f.3 chip-ID: 8086:51c8 class-ID: 0403
Sound API: ALSA v: k6.1.11-1-MANJARO running: yes
Sound Server-3: PipeWire v: 0.3.65 running: no
Device-1: Intel Alder Lake-P PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:51f0 class-ID: 0280
IF-ID-1: tailscale0 state: unknown speed: -1 duplex: full mac: N/A
IP v4: <filter> scope: global
IP v6: <filter> scope: global
IP v6: <filter> virtual: stable-privacy scope: link
Device-1: Intel type: USB driver: btusb v: 0.8 bus-ID: 3-10:5
chip-ID: 8087:0033 class-ID: e001
Device-1: luks-c07b9399-ee9e-4f97-95e0-4ed7e38ff812 maj-min: 254:0
type: LUKS dm: dm-0 size: 476.64 GiB
Components:
p-1: nvme0n1p2 maj-min: 259:2 size: 476.64 GiB
Local Storage: total: 476.94 GiB used: 52.05 GiB (10.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: PM9A1 NVMe 512GB
size: 476.94 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
lanes: 4 type: SSD serial: <filter> rev: 36308229 temp: 34.9 C scheme: GPT
ID-1: / raw-size: 476.64 GiB size: 468.09 GiB (98.21%)
used: 52.05 GiB (11.1%) fs: ext4 dev: /dev/dm-0 maj-min: 254:0
mapped: luks-c07b9399-ee9e-4f97-95e0-4ed7e38ff812 label: N/A
uuid: 54ee7e84-f24b-45ec-b518-765fe97860b1
used: 508 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: 8388-B694
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 1 rev: 2.0
Hub-2: 2-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 20 Gb/s
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 3-2:2 info: Yubicom Yubikey 4/5 OTP+U2F+CCID
type: Keyboard,HID,Smart Card driver: hid-generic,usbhid interfaces: 3
rev: 2.0 speed: 12 Mb/s power: 30mA chip-ID: 1050:0407 class-ID: 0b00
Device-2: 3-6:3 info: Microdia Integrated_Webcam_HD type: Video
driver: uvcvideo interfaces: 4 rev: 2.0 speed: 480 Mb/s power: 500mA
Device-3: 3-9:4 info: Shenzhen Goodix USB2.0 MISC type: <vendor specific>
driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s power: 100mA
chip-ID: 27c6:63ac class-ID: ef00 serial: <filter>
Device-4: 3-10:5 info: Intel type: Bluetooth driver: btusb interfaces: 2
rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 8087:0033 class-ID: e001
Hub-4: 4-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 48.0 C mobo: N/A
Processes: 385 Uptime: 6m wakeups: 821 Init: systemd v: 252
default: graphical tool: systemctl Compilers: gcc: 12.2.1 alt: 11
clang: 15.0.7 Packages: pm: pacman pkgs: 1202 libs: 341
tools: gnome-software,pamac Shell: Zsh v: 5.9 running-in: tilix inxi: 3.3.25
Any ideas? Thanks.
