I switched to Manjaro a day ago, it’s my first linux distribution, everything works great, for games the performance (fps) is much better BUT
I will take as an example a game that everyone has already experienced: Minecraft.
If I press very quickly the keys 1 and 2 (above the a and z since I use an azerty keyboard) the active inventory slot does not change
so I can’t use an item quickly from my hotbar
Even if the keys 1,2,3,4,5,6,7,8,9 allow me to change the hotbar slot, I can’t put an item in my hotbar from the inventory
I took Minecraft as an example, but if these two things are solved it will solve the problems of other games, I have tried the solutions of similar topics without success
(I used deepl to translate, im french)
Thanks in advance!
EDIT SOLUTION
original title : Bad layout for French keyboard and input latency
You have to add a US keyboard in addition to the French (or foreign) keyboard in fcitx
and I also solved the same problem for a friend who uses gnome:
Please read this: How to provide good information
and post some more information so we can see what’s really going on. Now we know the symptom of the disease, but we need some more probing to know where the origin lies…
An inxi --admin --verbosity=7 --filter --no-host --width would be the minimum required information… (Personally Identifiable Information like serial numbers and MAC addresses will be filtered out by the above command)
Also, please copy-paste that output in-between 3 backticks ``` at the beginning and end of the code/text.
Notre forum en Français se trouve ici. Si tu remets tout en , je veux bien migrer ta question là-bas puisque des traductions automatiques son nuls quand on y mets des commandes en …
P.S. If you enter a bit more details in your profile, we can also see which Desktop Environment you’re using, which CPU/GPU or Kernel, … you have without typing it every time
If you press keys very fast, then the system thinks you hold the button, thus it stops reacting and waits for the delay until it repeats the key. And while the delay is working, it rejects any input.
It probably has to do with “key repeat”. So the “delay” and the “speed”. You should be able to change that somewhere under “Keyboard” at the XFCE Settings.
With the package “keyboard layout viewer” I see that the system does not consider that I maintain the keys
I also tried to modify the delay and speed in the parameters (I should have put that I had already tried), even if I put the delay at the minimum and the speed at the maximum then if I type in a row “1,2,3,4,5” then the slot will go from slot 1 to 5 directly
it’s normal the pressed,pressed,pressed , released,released,released , the real problem is that the pressed between the first pressed and the last pressed are not taken into account
