Is there anything I can do, even if it’s distro hopping?
I don’t understand why, no matter what I try, it just never enables prime sync. This thing is supposed to have a 144hz refresh rate but i only see 60 available. my EXTERNAL monitor is 240hz, and it shows that in xrandr.
Is there anything else that I can do… maybe open source drivers of some kind… cause I don’t like proprietary to begin with.
Please, we’ve gotten this far… which is further than I ever would’ve thought… and also, I remove optimus-manager now – it did absolutely no good and the configuration regarding nvidia is kinda ignorant… it’s as if configuration doesn’t get picked up or something, but it still seems to be picking up that I put one Separate screen section for each display (or, more accurately, an extended display) … so i have to wonder how i can get these settings saved and WORKING. I’m sorry but if others here have the same hardware and the same drivers with the same CRAP then why the hell wouldn’t it work on my end? it makes NO sense
Please excuse the tantrum, I’ve just had it… I’ve tried so much it’s insane; I haven’t worked this hard in my life…
Start from scratch and reinstall and use KDE instead of cinnamon if you have the RAM available. (You never posted a full inxi --admin --verbosity=7 --filter --no-host, so can’t tell)
Ensure the monitor (and any other hardware you’re going to use) is attached to the system while you’re reinstalling.
You now know more about Manjaro and how hardware detection works, so this time you should be fine…
That’s all the last-minute, ultimate, nuke it from orbit advice I can give…
Yeah I’m going to try a different DE and might try starting from scratch. I think I need to get rid of Cinnamon, which might be the damn problem in the first place… I went back to the configuration someone posted awhile ago for someone with similar hardware. You were right, though… this internal display is AMD only… I was re-reading before I saw your response, but it’s possible the DE is the problem, and it seems to point to it. I could be wrong but we’ll find out. And yes I have learned enough about mhwd lol.
Thank you for your help though. You’ve been fabulous and I will be updating you on my little start from scratch journey lol. Alright… I’ll let you know when I’m able to do so… gonna back some stuff up. At least the rest of it works… it could be worse…
I’ll try… GNOME3 or MATE for my next shot. and if PRIME doesn’t work, I’ll go to KDE. There are solutions for this stuff, it seems, with KDE. But I do have a question, @Fabby or @pobrn – a quick question… Does Manjaro handle more than one DWM very well? I know it works in Ubuntu but can be a bit dangerous and lead to dependency hell. Thoughts on this? I’m… moderately “experienced” but nowhere near the knowledge that you both have.
Difficulty is about 1 of 5 for me so I guess I’m not too bad at this I’m sure you’ll be the judge of this at a later date, lol.
I’m glad I looked it up and then asked the questions about installing, for instance–I decided not install GNOME or MATE because of the version of this ISO–it came equipped via lightdm because of cinnamon, right? I’m worried about the dependencies since Cinnamon = GNOME fork, so something could probably overlap in the dependencies, I would think… That brings me to a question I have. Maybe I’m just over-analyzing this, but why did I have to create a different user for the separate DE I installed?
Why can’t I use my normal username, in theory? Is this new user a precaution or is it a 100% requirement? If so, I just want to know why, really. It was the very first thing I did.
In the mean time this discussion has been dragging along for way too long and differs substantially from your original question, so please do me a favour and:
click the 3 dots below the answer to mark a solution like this below the answer that helped you most:
Open a new topic on this… (We don’t charge more if you open more topics, you know…)
It’s been dragging along with no actual solution… Would it be okay if I left this open for a little longer while I open another topic about installing multiple Desktop Environments? Eventually I’ll mark it as solved but until then, I’d like to keep this thread alive a little bit longer.
Because you keep asking other questions that side-track people.
I was on “Normal” in this topic already, but anything left open for a week or longer is bad as people lose track, so now I’ve muted this topic and you will not be able to contact me any more from this point forward inside this topic although I still will be able to see any other questions you ask on the site.
IOW:
This is a friendly forum geared towards problems and solutions, not towards discussion
If you open another discussion thread instead of a Problem-Solution thread in the future, you will be muted as a user in my personal settings so I’ll never see any of you future questions again.
Not everyone here warns you that they will mute you, they’ll just do it.
After enough users mute you, none of your questions will receive any attention any more…
